    4. JavaScript
    5. [gelöst] Skript auf AXIOS/httpGet umbauen
    • Codierknecht
      Codierknecht Developer Most Active @DJMarc75 last edited by
      @djmarc75
      quick & dirty:
      async function updateLocation(latitude, longitude) {
          const url = `https://nominatim.openstreetmap.org/reverse?lat=${latitude}&lon=${longitude}&format=json`;
          const response = await axios.get(url);
          if (response && response.data.display_name) {
            return(response.data.display_name);
        MCU @DJMarc75 last edited by MCU
        @djmarc75 Wenn du Blockly nutzt kannst du auch direkt den Block verwenden?
          <variables>
            <variable id="`eps4Xu;/O9P-h|FWJ-E">lat</variable>
            <variable id="qICBRrCi%-}_(mq;vWM^">lon</variable>
            <variable id=")AQ%}HdiHDw^ZDxO0d[?">response</variable>
          </variables>
          <block type="variables_set" id="2DF6oAFi1G}uOwa_3?)w" x="88" y="113">
            <field name="VAR" id="`eps4Xu;/O9P-h|FWJ-E">lat</field>
              <block type="math_number" id="FduAcw*36HRQdJJcnT(M">
                <field name="NUM">52.52</field>
              <block type="variables_set" id="flw^g!3aB+q_~hAO83[g">
                <field name="VAR" id="qICBRrCi%-}_(mq;vWM^">lon</field>
                  <block type="math_number" id=":CT|HqW-VISJ=XBdNMzY">
                    <field name="NUM">13.405</field>
                  <block type="http_get" id="er#Datp2ZE*VyGUa%*Kv">
                    <field name="TIMEOUT">2000</field>
                    <field name="UNIT">ms</field>
                    <field name="TYPE">text</field>
                    <value name="URL">
                      <shadow type="text" id="Q_WE@|3:]0*%[l-.!;qf">
                        <field name="TEXT"></field>
                      <block type="text_join" id="-ys2STS:FUWU@%[8~o[=">
                        <mutation items="5"></mutation>
                        <value name="ADD0">
                          <block type="text" id="B25~4=^wMHf(vUb3ay~3">
                            <field name="TEXT">https://nominatim.openstreetmap.org/reverse.php?format=json&amp;lat=</field>
                        <value name="ADD1">
                          <block type="variables_get" id="3Y8[4Y4CR#bn(@$tYkc+">
                        <value name="ADD2">
                          <block type="text" id="==#V5Ah1PyKx_!-*~JfY">
                            <field name="TEXT">&amp;lon=</field>
                        <value name="ADD3">
                          <block type="variables_get" id="ya.!JwNXi/PO.!GZE@tX">
                        <value name="ADD4">
                          <block type="text" id="[JnnacT#;5U-rwb.89lc">
                            <field name="TEXT">&amp;zoom=18</field>
                      <block type="debug" id="Z/p^=2Hb40.14a$HJF{b">
                        <value name="TEXT">
                          <shadow type="text" id="X7.E)1NBlIOrpnS^9XwS">
                          <block type="variables_get" id="Jgr?*Epm}01s%F=YGUa+">
                            <field name="VAR" id=")AQ%}HdiHDw^ZDxO0d[?">response</field>
        DJMarc75 1 Reply Last reply Reply Quote 3
        • DJMarc75
          DJMarc75 @MCU last edited by
          @mcu Jou, so (ähnlich) habe ich es mir eben auch zusammen gebastelt 😉
          Funktioniert !
          Merci auch an @Codierknecht & @Lucky_ESA
          Muss noch viel was JS angeht lernen.
          • haus-automatisierung
            haus-automatisierung Developer Most Active @DJMarc75 last edited by
            @djmarc75 Die Idee mit den neuen Versionen war ja eigentlich, nicht wieder in das gleiche Problem zu laufen wie aktuell mit request. Also am besten kommt axios gar nicht in deinem Code vor, sondern Du nutzt httpGet (oder die Blockly-Bausteine dafür).
            Dann können wir in Zukunft die Library darunter austauschen und alle Scripts laufen weiter.
            D 1 Reply Last reply Reply Quote 7
              darkiop Most Active @haus-automatisierung last edited by
              Der httpGet Block hat aktuell keine Option um Zertifikatsfehler zu ignorieren oder?
                haus-automatisierung Developer Most Active @darkiop last edited by
                @darkiop sagte in [gelöst] Skript auf AXIOS umbauen:
                Ja, richtig. Weiß auch noch nicht ob ich das anbieten soll. Immerhin ist die Validierung ein Sicherheitsfeature.
                  Stimmt - allerdings gerade im häuslichen Umfeld oft "normal".
                  Am Ende ist ist es ein abwägen von Risiko und Nutzen 😉
                    @darkiop Ja, und was ist der Nutzen von einer https Verbindung im LAN?
                      Lässt sich manchmal ja nicht ohne zusätzlichen Aufwand (z.B. per ReverseProxy) vermeiden.
                      Unser SMA WR liefert das WebUi per https aus, eine Möglichkeit ein eigenes Zertifikat zu hinterlegen gibt es imho nicht.
                      Hier läuft alles über einen internen ReverseProxy, mir ist nur aufgefallen das die Option SSL Prüfungen abzuschalten, noch nicht implementiert ist.
                      • bahnuhr
                        Guten Morgen,
                        bin auch gerade an dem Thema dran:
                        mit request lasse ich mir Bilder der cam an telegram senden, wie folgt:
                        var ip = 159; var vUser = "Dieter"; var cam = "Test";
                        var request = require('request');
                        var fs      = require('fs');
                            request.get({url: 'http://192.168.243.' + ip + ':88//cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=xx&pwd=xx', encoding: 'binary'}, function (err, response, body) {
                                fs.writeFile('/opt/iobroker/iobroker-data/tmp/snap' + ip + '.jpg', body, 'binary', function(err) {
                                if (err) {
                                    console.error(err);
                                } else {
                                    log('Snapshot sent '+ ip);
                                    sendTo('telegram.0', {user: vUser, text: '/opt/iobroker/iobroker-data/tmp/snap' + ip + '.jpg', caption: cam});
                        Wenn ich dies nun mit axios versuche, klappt dies nicht:
                        const axios = require('axios');
                            axios.get({url: 'http://192.168.243.' + ip + ':88//cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=xx&pwd=xx', encoding: 'binary'}, function (err, response, body) {
                                if (err) {
                                    console.error(err);
                                } else {
                        Kann der axios diesen "binary" nicht ?
                        Oder liegt es an etwas anderes ?
                        Vielleicht auch ne Info wie der Befehl mit httpget aussehen müsste.
                        Danke.
                          haus-automatisierung Developer Most Active @bahnuhr last edited by
                          @bahnuhr sagte in [gelöst] Skript auf AXIOS umbauen:
                          Du kannst nicht einfach nur 1:1 die Funktion austauschen. Dokumentation gibts hier: https://github.com/axios/axios
                          Das Ganze heißt responseEncoding: 'binary', im Config-Objekt. Aber warum nutzt Du nicht httpGet ?
                          https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#httpget
                          haus-automatisierung bahnuhr 2 Replies Last reply Reply Quote 1
                            haus-automatisierung Developer Most Active @haus-automatisierung last edited by haus-automatisierung
                            nicht getestet, nur im Forum programmiert
                            const fs = require('node:fs');
                            const ip = 159;
                            const vUser = 'Dieter';
                            const cam = 'Test';
                            httpGet(`http://192.168.243.${ip}:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=xx&pwd=xx`, { responseType: 'arraybuffer' }, (err, response) => {
                                if (err) {
                                    console.error(err);
                                } else {
                                    const filePath = `/opt/iobroker/iobroker-data/tmp/snap${ip}.jpg`;
                                    fs.writeFile(filePath, response.data, (err) => {
                                        if (err) {
                                            console.error(err);
                                        } else {
                                            log(`Snapshot sent: ${ip}`);
                                                user: vUser,
                                                text: filePath,
                                                caption: cam
                            • bahnuhr
                              bahnuhr Forum Testing Most Active @haus-automatisierung last edited by
                              @haus-automatisierung sagte in [gelöst] Skript auf AXIOS umbauen:
                              weil es mit der 7.8.0 noch nicht funktioniert.
                              und die 7.9.0 ist noch nicht stable.
                              Muss ich wohl mal die beta installieren.
                                haus-automatisierung Developer Most Active @bahnuhr last edited by haus-automatisierung
                                In 8.3.0 habe ich heute noch eine weitere Funktion eingefügt. Damit wird das noch kürzer:
                                const ip = 159;
                                const user = 'Dieter';
                                const caption = 'Test';
                                    if (err) {
                                        console.error(err);
                                    } else {
                                            user,
                                            caption,
                                            text: createTempFile(`snap${ip}.jpg`, response.data),
                                bahnuhr 1 Reply Last reply Reply Quote 1
                                • bahnuhr
                                  so, habs ausprobiert (bin jetzt auf 8.3.0).
                                  Wenn ich folgenden kleinen code ausführe:
                                  httpGet(`http://192.168.243.203/YamahaExtendedControl/v1/main/setPower?power=standby`, { responseType: 'text' }, (err, response) => {
                                      if (err) { console.error(err); } else { log (""); }
                                  kommt trotzdem im log:
                                  	script.js.Scripte.test6: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                                  Warum kommt dies im log ?
                                  (httpGet ist in JS auch rot unterstrichen)
                                  Benutze doch httpGet.
                                  haus-automatisierung liv-in-sky 2 Replies Last reply Reply Quote 0
                                    Kann ich nicht reproduzieren, die Meldung kommt auch nur, wenn require aufgerufen wird. Und das passiert bei Dir im Script ja nicht.
                                    Du hast aber schon über npm installiert (und nicht über GitHub), oder?
                                    bahnuhr 2 Replies Last reply Reply Quote 0
                                    • bahnuhr
                                      korrekt, aber die Meldung kommt trotzdem.
                                      ja, über npm
                                      • bahnuhr
                                        Das ist bei mir nicht so.
                                        Habe mal iob komplett neu gestartet.
                                        Meldung kommt, obwohl im aufgerufenen Script kein request drin steht.
                                        (wohl aber noch bei anderen).
                                        Kann es sein, dass die Meldung trotzdem kommt, weil irgendwo noch ein request drin steht (von den gefühlt 500 Scripten).
                                        joergeli 1 Reply Last reply Reply Quote 0
                                        • joergeli
                                          joergeli @bahnuhr last edited by
                                          Meines Erachtens nicht, da ich ebenfalls gerade am Umbauen von request auf httpGet bin.
                                          Bei bereits auf httpGet umgestellten Scripten kommt keine request-deprecated-Meldung mehr, bei den Scripten die noch request verwenden, kommt sie noch.
                                          bahnuhr 1 Reply Last reply Reply Quote 2
                                          • bahnuhr
                                            bahnuhr Forum Testing Most Active @joergeli last edited by
                                            @joergeli
                                            Danke für die Info.
                                            Bei mir ist das nicht ! so.
                                            Folgendes Script zum Starten von Licht:
                                            // Bewegung: Bad_EG -> Dimmer einschalten
                                            on('alias.0.HM.Bewegung.Bad_EG.MOTION', function (obj) {  // Bewegung erkannt
                                                var Status_auto = getState('javascript.0.System.Automatik.Licht.Bad_EG').val;   //  Automatik Licht true
                                                var Licht_level = getState('alias.0.HM.Dimmer.Bad_EG.LEVEL').val;   //  Licht level aktuell
                                                var Hell = getState('alias.0.HM.Bewegung.Bad_EG.BRIGHTNESS').val;   //  Helligkeit
                                                var Modus_Dusche = getState('javascript.0.System.Modus.Modus_Dusche').val;   //  Modus Dusche aktiv?
                                                if(Status_auto === true && Licht_level === 0 && Modus_Dusche == false) {   //  Automatik Licht auf true und Licht ist aus und Modus überprüfen
                                                    if (Hell < 35) {
                                                        setState('alias.0.HM.Dimmer.Bad_EG.LEVEL',5);
                                                        log("Helligkeit = " + Hell + "; Dimmer Bad_EG auf 5% eingeschaltet.");
                                                        setTimeout(function() {
                                                            pruef_aus();
                                                        }, 120000);   // nach 2 min. Prüfung
                                            function pruef_aus() {
                                                var level = getState('alias.0.HM.Dimmer.Bad_EG.LEVEL').val;   //  Licht level aktuell
                                                if (level > 0) {
                                                    if (getState('alias.0.HM.Bewegung.Bad_EG.MOTION').val == false){
                                                        if (Modus_Dusche == false) {
                                                            setState('alias.0.HM.Dimmer.Bad_EG.LEVEL', 0);
                                                            log("Licht Bad EG ausgeschaltet.");
                                                    } else {
                                                        log("Licht Bad EG nicht ausgeschaltet. Erneute Prüfung nach 2 min.");
                                                            pruef_aus ();
                                                        }, 120000);   // nach 2 min. erneute Prüfung
                                            // Bewegung: Bad_EG -> Spiegelschrank einschalten
                                            on('mqtt.2.Wemos_BadEG.PIR1', function (obj) {  // Bewegung erkannt mit Wemos
                                                var Status_auto2 = getState('javascript.0.System.Automatik.Licht.Bad_EG').val;   //  Automatik Licht true
                                                var Licht_state = getState('mqtt.2.Wemos_BadEG.POWER').val;   //  Licht Spiegelschrank aktuell
                                                var Hell2 = getState('alias.0.HM.Bewegung.Bad_EG.BRIGHTNESS').val;   //  Helligkeit
                                                var Modus_Dusche2 = getState('javascript.0.System.Modus.Modus_Dusche').val;   //  Modus Dusche aktiv?
                                                if(obj.state.val == "ON" && Status_auto2 == true && Licht_state == "OFF" && Modus_Dusche2 == false) {   //  Automatik Licht auf true und Licht ist aus und Modus überprüfen
                                                    if (Hell2 < 100) {
                                                        httpGet("http://192.168.243.175/cm?cmnd=Power1%20On", { responseType: 'text' }, (err, response) => { if (err) { console.error(err); } else { log (""); } });
                                                        log("Helligkeit = " + Hell2 + "; Licht Bad EG - Spiegelschrank eingeschaltet.");
                                                            pruef_aus2();
                                            function pruef_aus2() {
                                                var state2 = getState('mqtt.2.Wemos_BadEG.POWER').val;   //  Licht Spiegelschrank aktuell
                                                if (state2 == "ON") {
                                                    if (getState('alias.0.HM.Bewegung.Bad_EG.MOTION').val === false){
                                                        if (Modus_Dusche2 === false) {
                                                            httpGet("http://192.168.243.175/cm?cmnd=Power1%20Off", { responseType: 'text' }, (err, response) => { if (err) { console.error(err); } else { log (""); } });
                                                            log("Licht Bad EG - Spiegelschrank ausgeschaltet.");
                                                    } else {
                                                        log("Licht Bad EG - Spiegelschrank nicht ausgeschaltet. Erneute Prüfung nach 2 min.");
                                                            pruef_aus2();
                                            // Bewegung: Bad_EG -> Spiegelschrank - Status ändert sich
                                                on('mqtt.2.Wemos_BadEG.POWER', function (obj) {  // Status Power ändert sich
                                                    if (obj.state.val == "ON") { if (getState("javascript.0.Geräte.Bad-EG.Spiegelschrank").val != true) { setState("javascript.0.Geräte.Bad-EG.Spiegelschrank", true); }
                                                    } else { if (getState("javascript.0.Geräte.Bad-EG.Spiegelschrank").val != false) { setState("javascript.0.Geräte.Bad-EG.Spiegelschrank", false); }}
                                                on('javascript.0.Geräte.Bad-EG.Spiegelschrank', function (obj) {  // Status Variable ändert sich
                                                    if (obj.state.val == true) { if (getState("mqtt.2.Wemos_BadEG.POWER").val != "ON") {
                                                    } else { if (getState("mqtt.2.Wemos_BadEG.POWER").val != "OFF") {
                                            Wenn ich dieses Script neu starte mit:
                                            dann kommt sofort im log:
                                            javascript.0	08:31:27.975	info	Start JavaScript script.js.Scripte.Licht.Bad_EG (JavaScript/js)
                                            javascript.0	08:31:27.987	warn	script.js.Scripte.Licht.Bad_EG: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                                            javascript.0	08:31:27.987	info	script.js.Scripte.Licht.Bad_EG: registered 4 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                            und dieses ist umgestellt auf httpGet.
                                            Äußerst merkwürdig das ganze.
                                            59
                                            10977
