    4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
      bimmi @Beowolf last edited by
      @beowolf sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
      host.raspberrypi 2024-05-10 14:00:33.724 error instance system.adapter.open-epaper-link.0 terminated with code 6 (UNCAUGHT_EXCEPTION) open-epaper-link.0 2024-05-10 14:00:32.953 warn Terminated (UNCAUGHT_EXCEPTION): Without reason open-epaper-link.0 2024-05-10 14:00:32.952 info terminating open-epaper-link.0 2024-05-10 14:00:32.948 error Cannot read properties of undefined (reading 'mac') open-epaper-link.0 2024-05-10 14:00:32.948 error TypeError: Cannot read properties of undefined (reading 'mac') at WebSocket.<anonymous> (/opt/iobroker/node_modules/iobroker.open-epaper-link/build/main.js:124:102) at WebSocket.emit (node:events:517:28) at Receiver.receiverOnMessage (/opt/iobroker/node_modules/ws/lib/websocket.js:1209:20) at Receiver.emit (node:events:517:28) at /opt/iobroker/node_modules/ws/lib/receiver.js:608:16 at node:internal/process/task_queues:140:7 at AsyncResource.runInAsyncScope (node:async_hooks:203:9) at AsyncResource.runMicrotask (node:internal/process/task_queues:137:8) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) open-epaper-link.0 2024-05-10 14:00:32.947 error uncaught exception: Cannot read properties of undefined (reading 'mac')
      kannst du mal das script hier testen:
      const WebSocket = require('websocket').w3cwebsocket;
      // Funktion zum Behandeln der WebSocket-Verbindung für EPS
      function handleEPSWebSocket(deviceIP) {
          const ws = new WebSocket(deviceIP);
          // Ereignishandler, wenn die WebSocket-Verbindung geöffnet wird
          ws.onopen = () => {
              console.log(`Verbindung zu ${deviceIP} erfolgreich hergestellt.`);
          // Fehlerbehandlung für die WebSocket-Verbindung
          ws.onerror = (error) => {
              console.error(`WebSocket-Fehler: ${error.message}`);
          // Behandlung der Schließung der WebSocket-Verbindung
          ws.onclose = (event) => {
              console.log(`WebSocket-Verbindung geschlossen: Code=${event.code}, Grund=${event.reason}`);
          // Datenempfang über WebSocket
          ws.onmessage = (event) => {
              const data = event.data.toString();
              console.log(`Empfangene Daten von EPS (${deviceIP}): ${data}`);
              try {
                  const jsonData = JSON.parse(data);
                  console.log('JSON-Daten:', jsonData); // Ausgabe der empfangenen Daten für Überprüfung
                  // Sicherstellen, dass das 'tags' Array existiert und mindestens ein Element enthält
                  if (jsonData.tags && jsonData.tags.length > 0) {
                      const tag = jsonData.tags[0];
                      // Überprüfen, ob die notwendigen Eigenschaften vorhanden sind
                      if (tag && tag.wakeupReason && tag.mac) {
                          console.log(`Wakeup Reason erhalten: ${tag.wakeupReason}`);
                          console.log(`MAC erhalten: ${tag.mac}`);
                          // Schreibe den aktuellen Wert von Mac und wakeupReason in den Datenpunkt
                          setState('0_userdata.0.EPS.Websocket', `${tag.mac}_${tag.wakeupReason}`, true);
                          console.log(`Aktueller Wert von Wakeup Reason (${tag.wakeupReason}) und MAC (${tag.mac}) in Datenpunkt geschrieben.`);
                      } else {
                          console.log('Notwendige Eigenschaften `wakeupReason` oder `mac` fehlen in den Daten.');
                  } else {
                      console.log('Keine oder leere Tags im JSON-Datenobjekt vorhanden.');
              } catch (error) {
                  console.error(`Fehler beim Verarbeiten der empfangenen Daten: ${error}`);
      // Verbindung zum EPS WebSocket-Server herstellen und behandeln
      handleEPSWebSocket('ws://192.168.1.70/ws');
        Kommt direkt das
        10.5.2024, 22:56:34.853	[warn ]: javascript.0 (10472)     at W3CWebSocket.ws.onmessage (script.js.common.EPaper-Displays.Erdgeschoss.button:42:21)
        10.5.2024, 22:56:34.857	[warn ]: javascript.0 (10472)     at W3CWebSocket.ws.onmessage (script.js.common.EPaper-Displays.Erdgeschoss.button:41:21)
        10.5.2024, 22:56:34.860	[warn ]: javascript.0 (10472)     at W3CWebSocket.ws.onmessage (script.js.common.EPaper-Displays.Erdgeschoss.button:42:21)
          @beowolf ich schau dieses Wochenende nochmal drüber 👍
            bimmi last edited by bimmi
            So, hab mich mal ein bisschen bemüht und dann ist folgendes herausgekommen:
            https://github.com/slimline33/OpenEPaperLink-IOBROKER-JavaScript
            Bitte testen.
            "javascript.0 (1401318) script.js.EPS.Websocket2_Test: Object "0_userdata.0.OpenEPaperLink.4467090B10421125" can't be copied: {}"
            Den Fehler bekomm ich noch nicht weg, ändert aber nichts an der Funktion!
            ? B 2 Replies Last reply Reply Quote 1
              A Former User @bimmi last edited by
              @bimmi
              super, laeuft einwandfrei!
              Hat n bisschen gedauert, bis alle Datenpunkte angelegt wurden, und man das im Admin gesehen hat.. aber ich glaube das war noch ein Bug im Admin 6.17.3... die neueren Versionen geiern ja ab, wenn man was aendert..
              Aber super, so habe ich alle Datenpunkte mit Mac etc drin und darauf zieh ich mir dann die Daten fuer die Scripte..
              • Walter.O.
                Walter.O. @Walter.O. last edited by
                Wollte jetzt mal OpenEPaperLink instalieren bekomme aber diese Fehlermeldung
                $ iobroker url https://github.com/jjwbruijn/OpenEPaperLink.git --host Mini-pc-Master --debug
                install jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c
                NPM version: 10.5.0Installing jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c... (System call)
                npm WARN tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.
                npm ERR! syscall open
                npm ERR! errno -2
                npm ERR! enoent ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneZ4T6jc/package.json'
                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-11T15_15_08_501Z-debug-0.log
                npm WARN tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.npm WARN tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.npm ERR! code ENOENTnpm ERR! syscall opennpm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneZ4T6jc/package.jsonnpm ERR! errno -2npm ERR! enoent ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneZ4T6jc/package.json'npm ERR! enoent This is related to npm not being able to find a file.npm ERR! enoent npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-11T15_15_08_501Z-debug-0.log
                host.Mini-pc-Master Cannot install jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c: 254
                ERROR: Process exited with code 25
                Was muss ich denn da jetzt machen, blicke da jetzt mal gar nicht durch.
                Thomas Braun B ? 3 Replies Last reply Reply Quote 0
                  Thomas Braun Most Active @Walter.O. last edited by
                  @walter-o
                  Da kannst du gar nix machen, die Dateien sind im Moment wohl defekt.
                  Bei mir kommt das auch so um die Ecke:
                  $ iobroker url https://github.com/jjwbruijn/OpenEPaperLink --host chet --debug
                  NPM version: 10.7.0
                  npm warn tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.
                  npm error code ENOENT
                  npm error path /home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.jsonnpm error errno -2
                  npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.json'
                  npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-11T15_24_06_313Z-debug-0.log
                  npm warn tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.npm warn tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.npm error code ENOENTnpm error syscall opennpm error path /home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.jsonnpm error errno -2npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.json'npm error enoent This is related to npm not being able to find a file.npm error enoentnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-11T15_24_06_313Z-debug-0.log
                  host.chet Cannot install jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c: 254
                  Walter.O. B 2 Replies Last reply Reply Quote 0
                  • Walter.O.
                    Walter.O. @Thomas Braun last edited by
                    @thomas-braun Okay,Danke dir
                      bimmi @Walter.O. last edited by
                      @walter-o was genau willst du installieren? Der OpenEPaperLink Adapter wird nicht weiter entwickelt.
                      Den Access Point am besten über www.openepaperlink.de installieren.
                        bimmi @Thomas Braun last edited by bimmi
                        @thomas-braun sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                        @walter-o
                        NPM version: 10.7.0
                        Man könnte auch diesen fork nutzen. Der ist aktueller :
                        https://github.com/jonasniesner/OpenEPaperLink
                        Jedoch würde ich wie gesagt über openepaperlink.de gehen.
                        Aber: mit der aktuellsten Version geht gar nichts im Moment. Auch der zigbee Teil ist defekt.
                          Beowolf @bimmi last edited by
                          @bimmi sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                          Bitte testen.
                          Super. Vielen Dank dafür.
                          Der löpp ja richtig gut. Die Buttonabfrage funktioniert auch top. 👍 👍 👍 👍 👍
                            Jetzt noch json push einbauen und fertig ist der Adapter 😅🤣
                              A Former User @Walter.O. last edited by
                              @walter-o @Thomas-Braun
                              was macht ihr da denn? Das ist doch kein iobroker Adapter... tss.. 🙂
                              OpenEpaperlink flasht man auf einen entsprechenden Accesspoint, meist ein ESP32 mit zigbee Modul... auch hier, wie bei Tasmota, einfach das Webinterface nehmen. Oder einfach mal die Anleitung lesen (mach ich auch erst, wenn nix geht.. 🙂 )
                                @ilovegym sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                                🙂 Hatte nur den github-Link aus dem ersten Beitrag genommen. Und erst danach gesehen, das es kein Adapter ist.
                                  Ich hab mein Script etwas angepasst.
                                  folgende Sachen kommen jetzt über websocket / tag.json mit
                                  • hwType / Alias (Display Bezeichnung)
                                  • height in px
                                  • widht in px
                                  • colors
                                  • colortable (json um die richten Farben zu setzen für rot, schwarz, grau usw)
                                  ein kleiner Fehler ist noch drin, aber das ändere ich evtl. heute Abend. Wäre schön wenn Ihr testen würdet und mir entsprechend ein issue auf github öffnen würdet!
                                  • haselchen
                                    haselchen Most Active @bimmi last edited by haselchen
                                    @bimmi
                                    Sollte, glaube ich, in einer der letzten Versionen implementiert worden sein: Update Anzeige.
                                    Find ich es nicht oder wie muss das eingestellt werden?
                                    Möchte gerne , vornehmlich oben rechts , angezeigt bekommen wann der Tag zuletzt aktualisiert worden ist .
                                      bimmi @haselchen last edited by
                                      @haselchen Es wird der timestamp im unix Format angezeigt. Musst du entsprechend umrechnen. Ich könnte das auch mit machen im Script
                                      • haselchen
                                        @bimmi
                                        Da ich die Voreinstellungen nehme ( Wetter, Kalender…) , wie kriege ich das da mit rein ? 🤔
                                          @haselchen das ist unabhängig von iobroker und wird ja über den ap gestellt.
                                          Das Skript ist nur zum Daten holen vom AP.
                                          • haselchen
                                            @bimmi
                                            Wir wäre dann die Vorgehensweise für mein Vorhaben?
                                            1028
                                            335922
