    4. Adapter vollständig deinstallieren...
      Thomas Braun Most Active @guitardoc last edited by
      @guitardoc
      Und wo stehst du da?
      cd /opt/iobroker/
      npm ls
      sagt?
        guitardoc @Thomas Braun last edited by
        iobroker.inst@3.0.0 /opt/iobroker
        +-- eufy-security-client@3.0.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#2c376bc8889b1f92961289b96a7bc667deda8609)
        +-- iobroker.admin@6.13.16
        +-- iobroker.alias-manager@1.2.6
        +-- iobroker.backitup@2.11.0
        +-- iobroker.cloud@5.0.1
        +-- iobroker.discovery@4.4.0
        +-- iobroker.echarts@1.7.2
        +-- iobroker.eusec@1.2.1
        +-- iobroker.feiertage@1.2.0
        +-- iobroker.followthesun@0.5.0
        +-- iobroker.homeconnect@1.3.0
        +-- iobroker.hydrawise@1.0.0
        +-- iobroker.javascript@8.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#34769285d99d2b547c039b27e7522d02fac6434e)
        +-- iobroker.js-controller@5.0.19
        +-- iobroker.logparser@2.2.2
        +-- iobroker.modbus@6.1.0
        +-- iobroker.mqtt@5.2.0
        +-- iobroker.pvforecast@2.9.1
        +-- iobroker.shelly@6.9.0
        +-- iobroker.shuttercontrol@1.7.0
        +-- iobroker.socketio@6.7.0
        +-- iobroker.solaredge@1.3.0
        +-- iobroker.sonoff@3.0.3
        +-- iobroker.sql@2.2.0
        +-- iobroker.telegram@3.2.1
        +-- iobroker.tuya@3.15.0
        +-- iobroker.viessmannapi@2.3.0
        +-- iobroker.vis-map@1.0.5
        +-- iobroker.vis-materialdesign@0.5.9
        +-- iobroker.vis@1.5.4
        +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
        +-- iobroker.weatherunderground@3.7.0
        +-- iobroker.web@6.2.5
        +-- iobroker.ws@2.6.1
        +-- iobroker.yahka@1.0.3
        `-- iobroker.zigbee@1.10.3
          @guitardoc
          Der hat auf der Ebene nix verloren.
          npm uninstall eufy-security-client
            @thomas-braun said in Adapter vollständig deinstallieren...:
            OK, da war er weg. Dann noch mal neu die Installation versuchen?
              @guitardoc
              Starte den eigentlichen Adapter mal neu. Meldungen aus dem log dann hier rein.
              iob logs --watch
                guitardoc @Thomas Braun last edited by guitardoc
                2024-05-12 08:47:25.761  - info: eusec.0 (25157) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.2, js-controller: 5.0.19
                2024-05-12 08:47:27.894  - info: eusec.0 (25157) Connected to station T8010P2320100018 on host 192.168.188.100 and port 21399
                2024-05-12 08:47:27.910  - info: eusec.0 (25157) Connected to station T8010N2320201304 on host 192.168.188.103 and port 21025
                2024-05-12 08:47:28.410  - error: eusec.0 (25157) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
                2024-05-12 08:47:28.417  - error: eusec.0 (25157) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
                2024-05-12 08:47:28.885  - error: eusec.0 (25157) onStationDatabaseQueryLatest Error [{"error":{"message":"DeviceNotFoundError: Device doesn't exists","context":{"device":"T8114P02195250D1"},"stacktrace":"DeviceNotFoundError: Device doesn't exists\n    at EufySecurity.getDevice (/opt/iobroker/node_modules/iobroker.eusec/node_modules/eufy-security-client/build/eufysecurity.js:372:15)\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"},"stationSN":"T8010P2320100018","returnCode":0}]
                2024-05-12 08:47:28.961  - info: eusec.0 (25157) go2rtc started: 08:47:28.961 INF go2rtc version 1.8.5 linux/amd64
                2024-05-12 08:47:28.961  - info: eusec.0 (25157) go2rtc started: 08:47:28.961 INF [api] listen addr=:1984
                2024-05-12 08:47:28.962  - info: eusec.0 (25157) go2rtc started: 08:47:28.962 INF [rtsp] listen addr=:8554
                2024-05-12 08:47:28.962  - info: eusec.0 (25157) go2rtc started: 08:47:28.962 INF [webrtc] listen addr=:8555
                2024-05-12 08:47:29.701  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010P2320100018.cameras.T8114P0219521BCE.recording_clip_length" has value "0" less than min "5"
                2024-05-12 08:47:29.702  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010P2320100018.cameras.T8114P0219521D94.recording_clip_length" has value "0" less than min "5"
                2024-05-12 08:47:29.703  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010P2320100018.cameras.T8114P0220032A09.recording_clip_length" has value "0" less than min "5"
                2024-05-12 08:47:29.703  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010N2320201304.cameras.T8114P0219522104.recording_clip_length" has value "0" less than min "5"
                2024-05-12 08:47:29.704  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010N2320201304.cameras.T8114P0219524FBF.recording_clip_length" has value "0" less than min "5"
                2024-05-12 08:47:45.315  - info: eusec.0 (25157) Push notification connection successfully established
                Das ist das Protokoll nach dem Neustart des Adapters in der offiziellen Version 1.2.1. Der Fehler
                kommt dann in unregelmäßigen Abständen immer wieder, deswegen war die Empfehlung, die Version 1.3.0 aus dem Developer Branch zu installieren. Das hab ich jetzt mal getan, und dann kommen die folgenden Fehler:
                2024-05-12 09:30:26.409  - info: eusec.0 (25536) starting. Version 1.3.0 (non-npm: bropat/ioBroker.eusec#develop) in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.2, js-controller: 5.0.19
                2024-05-12 09:30:26.822  - info: eusec.0 (25536) Got terminate signal TERMINATE_YOURSELF
                2024-05-12 09:30:26.827  - warn: web.0 (25521) Terminated (-100): Without reason
                2024-05-12 09:30:26.827  - warn: eusec.0 (25536) Required fix to use livestreaming with this version of Node.js (CVE-2023-46809) applied. Restart of the adapter initiated to activate the fix.
                2024-05-12 09:30:26.827  - warn: eusec.0 (25536) Restart initiated
                2024-05-12 09:30:26.887  - info: eusec.0 (25536) terminating
                2024-05-12 09:30:26.887  - info: eusec.0 (25536) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2024-05-12 09:30:27.323  - info: eusec.0 (25536) terminating
                2024-05-12 09:30:27.331  - warn: web.0 (25521) setTimeout called, but adapter is shutting down
                2024-05-12 09:30:29.126  - error: web.0 (25551) Cannot start extension "eusec.0": Error: Cannot find module 'iobroker.eusec/build/lib/web.js'
                Require stack:
                - /opt/iobroker/node_modules/iobroker.web/main.js
                2024-05-12 09:30:30.642  - info: eusec.0 (25566) starting. Version 1.3.0 (non-npm: bropat/ioBroker.eusec#develop) in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.2, js-controller: 5.0.19
                2024-05-12 09:30:31.056  - warn: eusec.0 (25566) Migrated configuration files to new location (needs restart). Restart of the adapter initiated.
                2024-05-12 09:30:31.056  - warn: eusec.0 (25566) Restart initiated
                2024-05-12 09:30:31.063  - info: eusec.0 (25566) terminating
                2024-05-12 09:30:31.064  - info: eusec.0 (25566) Terminated (NO_ERROR): Without reason
                2024-05-12 09:30:31.559  - info: eusec.0 (25566) terminating
                Ich bekomme die Version nicht zum Laufen...
                Edit: Ich werd verrückt. Hab den Adapter in Version 1.3.0 noch mal neu gestartet und jetzt läuft er. Hurra!!!!
                  Thomas Braun Most Active @guitardoc last edited by Thomas Braun
                  @guitardoc
                  Insgesamt scheinst du aber falsch zu installieren.
                  GitHub/'die Katze' ist keine reguläre Installationsweise. Pick den vw-connect und den javascript-Adapter aus dem Beta-Repository, wenn du testen willst. Ansonsten ist das stable-Repo dein erster Anlaufpunkt.
                    Was ist da genau der Unterschied? Hab mir da nie groß Gedanken drüber gemacht... Von der Katze ging es immer schneller, beim Beta-Repo muss man immer erst aufwändig die Repos umstellen, oder gibt es da eine Abkürzung?
                      @guitardoc sagte in Adapter vollständig deinstallieren...:
                      Der Unterschied ist, dass die räudige Katze immer 'irgendeinen' Code anschleppt. Was halt so gerade im GitHub herumliegt. Über das Beta-Repo sind zumindest rudimentäre Tests gelaufen und es sind dann definierte Versionsstände.
                        @guitardoc
                        'Abkürzung':
                        Den Reiter 'npm' benutzen:
                          @thomas-braun Wenn ich Beta als Repo auswähle
                          dann erhalte ich sogar noch geringere Versionsstände als bei Stable? Oder hab ich nicht das richtige Verzeichnis?
                            @guitardoc
                            iob update
                            iob repo list
                              iob repo list
                              mn@iobroker:~$ iob update
                              Used repository: stable
                              Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                              Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                              Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                              Adapter    "eusec"        : 1.2.1    , installed 1.3.0
                              Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                              Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                              Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                              Adapter    "hydrawise"    : 1.0.0    , installed 1.0.0
                              Adapter    "javascript"   : 7.8.0    , installed 8.0.3
                              Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                              Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                              Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                              Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                              Adapter    "shelly"       : 6.9.0    , installed 6.9.0
                              Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                              Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                              Adapter    "solaredge"    : 1.3.0    , installed 1.3.0
                              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                              Adapter    "sql"          : 2.2.0    , installed 2.2.0
                              Adapter    "telegram"     : 3.2.1    , installed 3.2.1
                              Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                              Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                              Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
                              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                              Adapter    "ws"           : 2.6.1    , installed 2.6.1
                              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                              Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                              mn@iobroker:~$ iob repo list
                              stable        : https://download.iobroker.net/sources-dist.json
                              beta          : https://download.iobroker.net/sources-dist-latest.json
                              live-stable   : http://iobroker.live/repo/sources-dist.json
                              live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                              Active repo(s): stable
                                  @thomas-braun Ja, ich hatte wieder umgestellt. Nach dem ioB Update unter Beta zeigt er die richtigen Versionsstände:
                                  Used repository: beta
                                  Adapter    "admin"        : 6.17.6   , installed 6.13.16 [Updatable]
                                  Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
                                  Adapter    "homeconnect"  : 1.4.0    , installed 1.3.0  [Updatable]
                                  Adapter    "javascript"   : 8.3.0    , installed 8.0.3  [Updatable]
                                  Adapter    "modbus"       : 6.2.2    , installed 6.1.0  [Updatable]
                                  Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
                                  Adapter    "solaredge"    : 1.4.1    , installed 1.3.0  [Updatable]
                                  Adapter    "viessmannapi" : 2.4.0    , installed 2.3.0  [Updatable]
                                  Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
                                  Adapter    "vis-map"      : 1.1.0    , installed 1.0.5  [Updatable]
                                  Adapter    "vw-connect"   : 0.6.0    , installed 0.6.0
                                  Active repo(s): beta
                                  mn@iobroker:~$
                                  Das ist aber verwirrend, dass man da erst ein ioB update ausführen muss nach der Umstellung der Repos...
                                    Nee, das ist normal, weil ein 'iob update' halt den Inhalt der Repos aktualisiert und synchronisert und nicht die Adapter, falls du das meinen solltest.
                                      @thomas-braun Aber müssten nach der Umstellung des Repos von Stable auf Beta nicht gleich die Beta-Versionsnummern der Adapter angezeigt werden? Ohne ioB update waren die bei mir in Beta ja viel niedriger als in Stable (siehe Screenshots oben).
                                        Nein, nach der Umstellung muss zwingend das Repo aktualisiert werden. Halt per iob update
                                          @thomas-braun OK, vielleicht könnte man das als Hinweis mit in die repository-Seite aufnehmen? Viele Anwender werden das nicht wissen und ich hab das in drei Monaten bestimmt auch wieder vergessen... 🙂
                                          Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                            @guitardoc
                                            Ist halt Basis-Wissen. Das Update deines Linux-Systems funktioniert ja genauso.
                                            sudo apt update aktualisiert das Inhaltsverzeichnis, sudo apt upgrade aktualisiert die Softwarepakete.
                                            1152
