    4. Adapter vollständig deinstallieren...
      guitardoc @Thomas Braun last edited by
      iobroker.inst@3.0.0 /opt/iobroker
      +-- eufy-security-client@3.0.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#2c376bc8889b1f92961289b96a7bc667deda8609)
      +-- iobroker.admin@6.13.16
      +-- iobroker.alias-manager@1.2.6
      +-- iobroker.backitup@2.11.0
      +-- iobroker.cloud@5.0.1
      +-- iobroker.discovery@4.4.0
      +-- iobroker.echarts@1.7.2
      +-- iobroker.eusec@1.2.1
      +-- iobroker.feiertage@1.2.0
      +-- iobroker.followthesun@0.5.0
      +-- iobroker.homeconnect@1.3.0
      +-- iobroker.hydrawise@1.0.0
      +-- iobroker.javascript@8.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#34769285d99d2b547c039b27e7522d02fac6434e)
      +-- iobroker.js-controller@5.0.19
      +-- iobroker.logparser@2.2.2
      +-- iobroker.modbus@6.1.0
      +-- iobroker.mqtt@5.2.0
      +-- iobroker.pvforecast@2.9.1
      +-- iobroker.shelly@6.9.0
      +-- iobroker.shuttercontrol@1.7.0
      +-- iobroker.socketio@6.7.0
      +-- iobroker.solaredge@1.3.0
      +-- iobroker.sonoff@3.0.3
      +-- iobroker.sql@2.2.0
      +-- iobroker.telegram@3.2.1
      +-- iobroker.tuya@3.15.0
      +-- iobroker.viessmannapi@2.3.0
      +-- iobroker.vis-map@1.0.5
      +-- iobroker.vis-materialdesign@0.5.9
      +-- iobroker.vis@1.5.4
      +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
      +-- iobroker.weatherunderground@3.7.0
      +-- iobroker.web@6.2.5
      +-- iobroker.ws@2.6.1
      +-- iobroker.yahka@1.0.3
      `-- iobroker.zigbee@1.10.3
        Thomas Braun Most Active @guitardoc last edited by
        @guitardoc
        Der hat auf der Ebene nix verloren.
        npm uninstall eufy-security-client
          @thomas-braun said in Adapter vollständig deinstallieren...:
          OK, da war er weg. Dann noch mal neu die Installation versuchen?
            @guitardoc
            Starte den eigentlichen Adapter mal neu. Meldungen aus dem log dann hier rein.
            iob logs --watch
              guitardoc @Thomas Braun last edited by guitardoc
              2024-05-12 08:47:25.761  - info: eusec.0 (25157) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.2, js-controller: 5.0.19
              2024-05-12 08:47:27.894  - info: eusec.0 (25157) Connected to station T8010P2320100018 on host 192.168.188.100 and port 21399
              2024-05-12 08:47:27.910  - info: eusec.0 (25157) Connected to station T8010N2320201304 on host 192.168.188.103 and port 21025
              2024-05-12 08:47:28.410  - error: eusec.0 (25157) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
              2024-05-12 08:47:28.417  - error: eusec.0 (25157) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
              2024-05-12 08:47:28.885  - error: eusec.0 (25157) onStationDatabaseQueryLatest Error [{"error":{"message":"DeviceNotFoundError: Device doesn't exists","context":{"device":"T8114P02195250D1"},"stacktrace":"DeviceNotFoundError: Device doesn't exists\n    at EufySecurity.getDevice (/opt/iobroker/node_modules/iobroker.eusec/node_modules/eufy-security-client/build/eufysecurity.js:372:15)\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"},"stationSN":"T8010P2320100018","returnCode":0}]
              2024-05-12 08:47:28.961  - info: eusec.0 (25157) go2rtc started: 08:47:28.961 INF go2rtc version 1.8.5 linux/amd64
              2024-05-12 08:47:28.961  - info: eusec.0 (25157) go2rtc started: 08:47:28.961 INF [api] listen addr=:1984
              2024-05-12 08:47:28.962  - info: eusec.0 (25157) go2rtc started: 08:47:28.962 INF [rtsp] listen addr=:8554
              2024-05-12 08:47:28.962  - info: eusec.0 (25157) go2rtc started: 08:47:28.962 INF [webrtc] listen addr=:8555
              2024-05-12 08:47:29.701  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010P2320100018.cameras.T8114P0219521BCE.recording_clip_length" has value "0" less than min "5"
              2024-05-12 08:47:29.702  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010P2320100018.cameras.T8114P0219521D94.recording_clip_length" has value "0" less than min "5"
              2024-05-12 08:47:29.703  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010P2320100018.cameras.T8114P0220032A09.recording_clip_length" has value "0" less than min "5"
              2024-05-12 08:47:29.703  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010N2320201304.cameras.T8114P0219522104.recording_clip_length" has value "0" less than min "5"
              2024-05-12 08:47:29.704  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010N2320201304.cameras.T8114P0219524FBF.recording_clip_length" has value "0" less than min "5"
              2024-05-12 08:47:45.315  - info: eusec.0 (25157) Push notification connection successfully established
              Das ist das Protokoll nach dem Neustart des Adapters in der offiziellen Version 1.2.1. Der Fehler
              kommt dann in unregelmäßigen Abständen immer wieder, deswegen war die Empfehlung, die Version 1.3.0 aus dem Developer Branch zu installieren. Das hab ich jetzt mal getan, und dann kommen die folgenden Fehler:
              2024-05-12 09:30:26.409  - info: eusec.0 (25536) starting. Version 1.3.0 (non-npm: bropat/ioBroker.eusec#develop) in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.2, js-controller: 5.0.19
              2024-05-12 09:30:26.822  - info: eusec.0 (25536) Got terminate signal TERMINATE_YOURSELF
              2024-05-12 09:30:26.827  - warn: web.0 (25521) Terminated (-100): Without reason
              2024-05-12 09:30:26.827  - warn: eusec.0 (25536) Required fix to use livestreaming with this version of Node.js (CVE-2023-46809) applied. Restart of the adapter initiated to activate the fix.
              2024-05-12 09:30:26.827  - warn: eusec.0 (25536) Restart initiated
              2024-05-12 09:30:26.887  - info: eusec.0 (25536) terminating
              2024-05-12 09:30:26.887  - info: eusec.0 (25536) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-05-12 09:30:27.323  - info: eusec.0 (25536) terminating
              2024-05-12 09:30:27.331  - warn: web.0 (25521) setTimeout called, but adapter is shutting down
              2024-05-12 09:30:29.126  - error: web.0 (25551) Cannot start extension "eusec.0": Error: Cannot find module 'iobroker.eusec/build/lib/web.js'
              Require stack:
              - /opt/iobroker/node_modules/iobroker.web/main.js
              2024-05-12 09:30:30.642  - info: eusec.0 (25566) starting. Version 1.3.0 (non-npm: bropat/ioBroker.eusec#develop) in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.2, js-controller: 5.0.19
              2024-05-12 09:30:31.056  - warn: eusec.0 (25566) Migrated configuration files to new location (needs restart). Restart of the adapter initiated.
              2024-05-12 09:30:31.056  - warn: eusec.0 (25566) Restart initiated
              2024-05-12 09:30:31.063  - info: eusec.0 (25566) terminating
              2024-05-12 09:30:31.064  - info: eusec.0 (25566) Terminated (NO_ERROR): Without reason
              2024-05-12 09:30:31.559  - info: eusec.0 (25566) terminating
              Ich bekomme die Version nicht zum Laufen...
              Edit: Ich werd verrückt. Hab den Adapter in Version 1.3.0 noch mal neu gestartet und jetzt läuft er. Hurra!!!!
                Thomas Braun Most Active @guitardoc last edited by Thomas Braun
                @guitardoc
                Insgesamt scheinst du aber falsch zu installieren.
                GitHub/'die Katze' ist keine reguläre Installationsweise. Pick den vw-connect und den javascript-Adapter aus dem Beta-Repository, wenn du testen willst. Ansonsten ist das stable-Repo dein erster Anlaufpunkt.
                  Was ist da genau der Unterschied? Hab mir da nie groß Gedanken drüber gemacht... Von der Katze ging es immer schneller, beim Beta-Repo muss man immer erst aufwändig die Repos umstellen, oder gibt es da eine Abkürzung?
                    @guitardoc sagte in Adapter vollständig deinstallieren...:
                    Der Unterschied ist, dass die räudige Katze immer 'irgendeinen' Code anschleppt. Was halt so gerade im GitHub herumliegt. Über das Beta-Repo sind zumindest rudimentäre Tests gelaufen und es sind dann definierte Versionsstände.
                      @guitardoc
                      'Abkürzung':
                      Den Reiter 'npm' benutzen:
                        @thomas-braun Wenn ich Beta als Repo auswähle
                        dann erhalte ich sogar noch geringere Versionsstände als bei Stable? Oder hab ich nicht das richtige Verzeichnis?
                          @guitardoc
                          iob update
                          iob repo list
                            iob repo list
                            mn@iobroker:~$ iob update
                            Used repository: stable
                            Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                            Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                            Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                            Adapter    "eusec"        : 1.2.1    , installed 1.3.0
                            Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                            Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                            Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                            Adapter    "hydrawise"    : 1.0.0    , installed 1.0.0
                            Adapter    "javascript"   : 7.8.0    , installed 8.0.3
                            Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                            Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                            Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                            Adapter    "shelly"       : 6.9.0    , installed 6.9.0
                            Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                            Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                            Adapter    "solaredge"    : 1.3.0    , installed 1.3.0
                            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                            Adapter    "sql"          : 2.2.0    , installed 2.2.0
                            Adapter    "telegram"     : 3.2.1    , installed 3.2.1
                            Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                            Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                            Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
                            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                            Adapter    "ws"           : 2.6.1    , installed 2.6.1
                            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                            Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                            mn@iobroker:~$ iob repo list
                            stable        : https://download.iobroker.net/sources-dist.json
                            beta          : https://download.iobroker.net/sources-dist-latest.json
                            live-stable   : http://iobroker.live/repo/sources-dist.json
                            live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                            Active repo(s): stable
                                @thomas-braun Ja, ich hatte wieder umgestellt. Nach dem ioB Update unter Beta zeigt er die richtigen Versionsstände:
                                Used repository: beta
                                Adapter    "admin"        : 6.17.6   , installed 6.13.16 [Updatable]
                                Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
                                Adapter    "homeconnect"  : 1.4.0    , installed 1.3.0  [Updatable]
                                Adapter    "javascript"   : 8.3.0    , installed 8.0.3  [Updatable]
                                Adapter    "modbus"       : 6.2.2    , installed 6.1.0  [Updatable]
                                Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
                                Adapter    "solaredge"    : 1.4.1    , installed 1.3.0  [Updatable]
                                Adapter    "viessmannapi" : 2.4.0    , installed 2.3.0  [Updatable]
                                Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
                                Adapter    "vis-map"      : 1.1.0    , installed 1.0.5  [Updatable]
                                Adapter    "vw-connect"   : 0.6.0    , installed 0.6.0
                                Active repo(s): beta
                                mn@iobroker:~$
                                Das ist aber verwirrend, dass man da erst ein ioB update ausführen muss nach der Umstellung der Repos...
                                  Nee, das ist normal, weil ein 'iob update' halt den Inhalt der Repos aktualisiert und synchronisert und nicht die Adapter, falls du das meinen solltest.
                                    @thomas-braun Aber müssten nach der Umstellung des Repos von Stable auf Beta nicht gleich die Beta-Versionsnummern der Adapter angezeigt werden? Ohne ioB update waren die bei mir in Beta ja viel niedriger als in Stable (siehe Screenshots oben).
                                      Nein, nach der Umstellung muss zwingend das Repo aktualisiert werden. Halt per iob update
                                        @thomas-braun OK, vielleicht könnte man das als Hinweis mit in die repository-Seite aufnehmen? Viele Anwender werden das nicht wissen und ich hab das in drei Monaten bestimmt auch wieder vergessen... 🙂
                                        Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                                          @guitardoc
                                          Ist halt Basis-Wissen. Das Update deines Linux-Systems funktioniert ja genauso.
                                          sudo apt update aktualisiert das Inhaltsverzeichnis, sudo apt upgrade aktualisiert die Softwarepakete.
                                            Ist aber auch wurscht, weil du das Repo am besten eh auf stable setzt und von beta oder gar alpha-Versionen besser die Finger lässt. Und wenn es schon was unstabiles sein muss, dann pick eine Beta-Version über den Reiter 'npm'.
                                            1152
