    4. Adapter vollständig deinstallieren...
      guitardoc @Thomas Braun last edited by
      @thomas-braun said in Adapter vollständig deinstallieren...:
      iob repo list
      mn@iobroker:~$ iob update
      Used repository: stable
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "eusec"        : 1.2.1    , installed 1.3.0
      Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
      Adapter    "followthesun" : 0.5.0    , installed 0.5.0
      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
      Adapter    "hydrawise"    : 1.0.0    , installed 1.0.0
      Adapter    "javascript"   : 7.8.0    , installed 8.0.3
      Adapter    "logparser"    : 2.2.2    , installed 2.2.2
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "shelly"       : 6.9.0    , installed 6.9.0
      Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "solaredge"    : 1.3.0    , installed 1.3.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "telegram"     : 3.2.1    , installed 3.2.1
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
      Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
      mn@iobroker:~$ iob repo list
      stable        : https://download.iobroker.net/sources-dist.json
      beta          : https://download.iobroker.net/sources-dist-latest.json
      live-stable   : http://iobroker.live/repo/sources-dist.json
      live-beta     : http://iobroker.live/repo/sources-dist-latest.json
      Active repo(s): stable
        Thomas Braun Most Active @guitardoc last edited by
        @guitardoc sagte in Adapter vollständig deinstallieren...:
          @thomas-braun Ja, ich hatte wieder umgestellt. Nach dem ioB Update unter Beta zeigt er die richtigen Versionsstände:
          Used repository: beta
          Adapter    "admin"        : 6.17.6   , installed 6.13.16 [Updatable]
          Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
          Adapter    "homeconnect"  : 1.4.0    , installed 1.3.0  [Updatable]
          Adapter    "javascript"   : 8.3.0    , installed 8.0.3  [Updatable]
          Adapter    "modbus"       : 6.2.2    , installed 6.1.0  [Updatable]
          Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
          Adapter    "solaredge"    : 1.4.1    , installed 1.3.0  [Updatable]
          Adapter    "viessmannapi" : 2.4.0    , installed 2.3.0  [Updatable]
          Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
          Adapter    "vis-map"      : 1.1.0    , installed 1.0.5  [Updatable]
          Adapter    "vw-connect"   : 0.6.0    , installed 0.6.0
          Active repo(s): beta
          mn@iobroker:~$
          Das ist aber verwirrend, dass man da erst ein ioB update ausführen muss nach der Umstellung der Repos...
            Nee, das ist normal, weil ein 'iob update' halt den Inhalt der Repos aktualisiert und synchronisert und nicht die Adapter, falls du das meinen solltest.
              @thomas-braun Aber müssten nach der Umstellung des Repos von Stable auf Beta nicht gleich die Beta-Versionsnummern der Adapter angezeigt werden? Ohne ioB update waren die bei mir in Beta ja viel niedriger als in Stable (siehe Screenshots oben).
                Nein, nach der Umstellung muss zwingend das Repo aktualisiert werden. Halt per iob update
                  @thomas-braun OK, vielleicht könnte man das als Hinweis mit in die repository-Seite aufnehmen? Viele Anwender werden das nicht wissen und ich hab das in drei Monaten bestimmt auch wieder vergessen... 🙂
                  Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
                    @guitardoc
                    Ist halt Basis-Wissen. Das Update deines Linux-Systems funktioniert ja genauso.
                    sudo apt update aktualisiert das Inhaltsverzeichnis, sudo apt upgrade aktualisiert die Softwarepakete.
                      Ist aber auch wurscht, weil du das Repo am besten eh auf stable setzt und von beta oder gar alpha-Versionen besser die Finger lässt. Und wenn es schon was unstabiles sein muss, dann pick eine Beta-Version über den Reiter 'npm'.
                        @thomas-braun Najaaaaa, der Vergleich passt nicht ganz. sudo apt update aktualisiert das Inhaltsverzeichnis, sudo apt upgrade aktualisiert die Pakete.
                        Hier stellt aber Repo auf beta erst mal nur das Repo um, iob update aktualisiert dann erst mal nur die Versionsstände in der Adapterliste und erst beim Klick auf den Pfeil wird der Adapter tatsächlich aktualisiert. Sind also drei Schritte notwendig. Mir hat sich das nicht gleich erschlossen, dass ich das so machen muss, aber ich bin auch kein Linux-Insider, nur "normaler" Anwender des ioB... Ich vermute, dass das vielen anderen Anwendern auch so gehen könnte.
                          Thomas Braun Most Active @guitardoc last edited by Thomas Braun
                          Der passt 100%, weil das Vorgehen 100% gleich ist.
                          Wenn du Repos änderst muss immer die Quelle auch aktualisiert werden.
                            guitardoc @Thomas Braun last edited by guitardoc
                            Das ist allerdings richtig - das werde ich jetzt immer so machen. Dass das darüber geht wusste ich auch nicht - wieder was gelernt! 🙂 Vielen Dank für deine Hilfe, alleine wäre ich wieder mal verzweifelt...
                              Homoran Global Moderator Administrators @guitardoc last edited by Homoran
                              du kannst alternativ ja auch im admin auf den dafür vorgesehenen Refresh Button klicken.
                              der ist ja nicht ohne Grund da
                              siehe
                              https://www.iobroker.net/#de/documentation/admin/adapter.md
                              (2)
                              G 1 Reply Last reply Reply Quote 3
                                guitardoc @Homoran last edited by
                                @homoran Stimmt, den gibt’s auch noch… gar nicht mehr dran gedacht…
                                1152
