    4. Roborock - Adapter stürzt ständig ab
    • Michael Sauer
      Michael Sauer @Glasfaser last edited by
      @glasfaser Hast recht.
      Hier der vollständige Log:
      roborock.0
      2023-09-29 20:44:27.997	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
      roborock.0
      2023-09-29 20:44:27.787	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      roborock.0
      2023-09-29 20:44:27.769	debug	Plugin sentry Initialize Plugin (enabled=true)
      roborock.0
      2023-09-29 20:43:40.797	warn	Failed to execute get_clean_summary on robot 5Eo7zrAcFZhjGJqyG5saSx TypeError: Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-29 20:43:40.797	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
      roborock.0
      2023-09-29 20:43:40.791	warn	Failed to execute get_clean_record_map on robot 5Eo7zrAcFZhjGJqyG5saSx retry
      roborock.0
      2023-09-29 20:43:40.790	debug	ERROR Online state for 5Eo7zrAcFZhjGJqyG5saSx: true
      roborock.0
      2023-09-29 20:43:40.775	debug	Length of message queue: 0
      roborock.0
      2023-09-29 20:43:40.774	debug	dps debug: {"id":3403,"result":["retry"]}
      roborock.0
      2023-09-29 20:43:40.614	warn	State "roborock.0.Devices.5Eo7zrAcFZhjGJqyG5saSx.cleaningInfo.Records.0.avoid_count" has no existing object, this might lead to an error in future versions
      roborock.0
      2023-09-29 20:43:40.611	warn	setTimeout called, but adapter is shutting down
      roborock.0
      2023-09-29 20:43:40.610	warn	setTimeout called, but adapter is shutting down
      roborock.0
      2023-09-29 20:43:40.591	debug	Length of message queue: 0
      roborock.0
      2023-09-29 20:43:40.591	debug	dps debug: {"id":8382,"result":[{"begin":1695980402,"end":1695981303,"duration":901,"area":11682500,"error":0,"complete":0,"start_type":3,"clean_type":3,"finish_reason":62,"dust_collection_status":1,"avoid_count":2,"map_flag":0}]}
      roborock.0
      2023-09-29 20:43:40.379	warn	Failed to create map. retry
      roborock.0
      2023-09-29 20:43:40.377	warn	setTimeout called, but adapter is shutting down
      roborock.0
      2023-09-29 20:43:40.344	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      2023-09-29 20:43:40.343	debug	Plugin sentry destroyed
      roborock.0
      2023-09-29 20:43:40.341	info	terminating
      roborock.0
      2023-09-29 20:43:40.321	error	Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-29 20:43:40.320	error	TypeError: Cannot read properties of undefined (reading 'captureException') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:142:53 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:68:4)
      roborock.0
      2023-09-29 20:43:40.319	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      roborock.0
      2023-09-29 20:43:40.319	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      2023-09-29 20:43:40.316	debug	Length of message queue: 2
      roborock.0
      2023-09-29 20:43:40.316	debug	Not clearing messageQueue. null - 24752
      roborock.0
      2023-09-29 20:43:40.315	debug	dps debug: {"id":5996,"result":["retry"]}
      roborock.0
      2023-09-29 20:43:40.312	debug	Length of message queue: 2
      roborock.0
      2023-09-29 20:43:40.312	debug	dps debug: {"id":1492,"result":{"clean_time":202871,"clean_area":2843662500,"clean_count":144,"dust_collection_count":128,"records":[1695980402,1695978009,1695807600,1695805205,1695718805,1695634800,1695632403,1695546005,1695459607,1695375600,1695373208,1695286806,1695202799,1695200405,1695114008,1695030000,1695027609,1694941211,1694854807,1694770801]}}
      roborock.0
      2023-09-29 20:43:39.961	debug	downloadURL: https://github.com/AlexxIT/go2rtc/releases/download/v1.3.0/go2rtc_linux_arm
      roborock.0
      2023-09-29 20:43:39.961	debug	System type: go2rtc_linux_arm
      roborock.0
      2023-09-29 20:43:39.961	debug	platform: linux
      roborock.0
      2023-09-29 20:43:39.960	debug	arch: arm
      roborock.0
      2023-09-29 20:43:39.958	debug	Update map
      roborock.0
      2023-09-29 20:43:39.955	debug	Length of message queue: 1
      roborock.0
      2023-09-29 20:43:39.954	debug	dps debug: {"id":1643,"result":{"water_box_mode":201}}
      roborock.0
      2023-09-29 20:43:39.684	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_water_box_custom_mode
      roborock.0
      2023-09-29 20:43:39.681	debug	Length of message queue: 1
      roborock.0
      2023-09-29 20:43:39.679	debug	dps debug: {"id":3641,"result":[{"carpet_clean_mode":3}]}
      roborock.0
      2023-09-29 20:43:39.388	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_clean_mode
      roborock.0
      2023-09-29 20:43:39.386	debug	Length of message queue: 1
      roborock.0
      2023-09-29 20:43:39.384	debug	dps debug: {"id":5183,"result":[{"enable":1,"current_integral":1000,"current_high":500,"current_low":1000,"stall_time":10}]}
      roborock.0
      2023-09-29 20:43:39.303	debug	get_timer: []
      roborock.0
      2023-09-29 20:43:39.302	debug	Length of message queue: 2
      roborock.0
      2023-09-29 20:43:39.301	debug	dps debug: {"id":1710,"result":[]}
      roborock.0
      2023-09-29 20:43:39.299	debug	get_server_timer: [["1688127243968","on",0],["1688127295244","on",0]]
      roborock.0
      2023-09-29 20:43:39.298	debug	Length of message queue: 3
      roborock.0
      2023-09-29 20:43:39.297	debug	dps debug: {"id":9140,"result":[["1688127243968","on",0],["1688127295244","on",0]]}
      roborock.0
      2023-09-29 20:43:38.906	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_carpet_mode
      roborock.0
      2023-09-29 20:43:38.905	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_timer
      roborock.0
      2023-09-29 20:43:38.904	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_server_timer
      roborock.0
      2023-09-29 20:43:38.903	debug	Length of message queue: 1
      roborock.0
      2023-09-29 20:43:38.902	debug	dps debug: {"id":1525,"result":{"ssid":"S-Home","ip":"192.168.78.122","mac":"b0:4a:39:6b:e2:59","bssid":"b0:f2:08:d9:88:ed","rssi":-68}}
      roborock.0
      2023-09-29 20:43:38.555	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_network_info
      roborock.0
      2023-09-29 20:43:38.554	debug	Consumables of robot: [{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]
      roborock.0
      2023-09-29 20:43:38.551	debug	Length of message queue: 1
      roborock.0
      2023-09-29 20:43:38.550	debug	dps debug: {"id":1936,"result":[{"main_brush_work_time":203079,"side_brush_work_time":203079,"filter_work_time":203079,"filter_element_work_time":0,"sensor_dirty_time":90815,"dust_collection_work_times":128}]}
      roborock.0
      2023-09-29 20:43:38.287	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_consumable
      roborock.0
      2023-09-29 20:43:38.286	debug	Mapped room matched: 11316198 with name: Küche
      roborock.0
      2023-09-29 20:43:38.285	debug	Mapped room matched: 11316194 with name: Flur
      roborock.0
      2023-09-29 20:43:38.284	debug	Mapped room matched: 12646380 with name: Esszimmer
      roborock.0
      2023-09-29 20:43:38.283	debug	Mapped room matched: 11309675 with name: Wohnzimmer
      roborock.0
      2023-09-29 20:43:38.282	debug	All mapped rooms: [[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]
      roborock.0
      2023-09-29 20:43:38.281	debug	Length of message queue: 1
      roborock.0
      2023-09-29 20:43:38.281	debug	dps debug: {"id":8606,"result":[[16,"11309675",6],[17,"12646380",13],[18,"11316194",8],[19,"11316198",14]]}
      roborock.0
      2023-09-29 20:43:38.238	debug	foreign.message attribute: 128 with value: 4
      roborock.0
      2023-09-29 20:43:38.237	debug	dps debug: {"128":4}
      roborock.0
      2023-09-29 20:43:38.143	debug	Length of message queue: 1
      roborock.0
      2023-09-29 20:43:38.142	debug	dps debug: {"id":8398,"result":[{"msg_ver":2,"msg_seq":126,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
      roborock.0
      2023-09-29 20:43:37.907	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_room_mapping
      roborock.0
      2023-09-29 20:43:37.891	debug	get_status: {"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}
      roborock.0
      2023-09-29 20:43:37.889	debug	Length of message queue: 0
      roborock.0
      2023-09-29 20:43:37.888	debug	dps debug: {"id":5982,"result":[{"msg_ver":2,"msg_seq":125,"state":8,"battery":100,"clean_time":901,"clean_area":11682500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":1,"fan_power":103,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":201,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":385,"is_exploring":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":5,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":2,"mop_mode":300,"debug_mode":0,"collision_avoid_status":1,"switch_map_mode":0,"dock_error_status":0,"charge_status":0,"unsave_map_reason":4,"unsave_map_flag":0,"clean_percent":0,"rss":2,"dss":128}]}
      roborock.0
      2023-09-29 20:43:37.645	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_status
      roborock.0
      2023-09-29 20:43:37.644	debug	Latest data requested
      roborock.0
      2023-09-29 20:43:37.642	debug	Length of message queue: 0
      roborock.0
      2023-09-29 20:43:37.640	debug	dps debug: {"id":1305,"result":[{"max_multi_map":4,"max_bak_map":1,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1695979052,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1695806345}]},{"mapFlag":1,"add_time":1692254347,"length":12,"name":"Obergeschoss","bak_maps":[{"mapFlag":5,"add_time":1688451884}]}]}]}
      roborock.0
      2023-09-29 20:43:37.486	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_multi_maps_list
      roborock.0
      2023-09-29 20:43:37.382	debug	Length of message queue: 0
      roborock.0
      2023-09-29 20:43:37.379	debug	dps debug: {"id":3178,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
      roborock.0
      2023-09-29 20:43:37.164	debug	Firmware features request
      roborock.0
      2023-09-29 20:43:37.164	debug	getParameter for 5Eo7zrAcFZhjGJqyG5saSx : get_fw_features
      roborock.0
      2023-09-29 20:43:37.160	debug	5Eo7zrAcFZhjGJqyG5saSx online. Starting mainUpdateInterval.
      roborock.0
      2023-09-29 20:43:23.804	debug	Robot key: roborock.vacuum.a51
      roborock.0
      2023-09-29 20:43:23.803	debug	RoomIDs debug: {"11309675":"Wohnzimmer","11314643":"Wohnzimmer1","11316194":"Flur","11316198":"Küche","11316201":"Küche1","11319794":"Badezimmer","11319802":"Spielzimmer","11319804":"Kinderzimmer","11319806":"Schlafzimmer","12646380":"Esszimmer","13421850":"Standard","13421863":"Phillip Schlafzimmer","13421865":"Badezimmer1"}
      roborock.0
      2023-09-29 20:43:23.801	info	MQTT initialized
      roborock.0
      2023-09-29 20:43:20.623	info	starting. Version 0.4.4 in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.0, js-controller: 5.0.12
      roborock.0
      2023-09-29 20:43:20.491	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      roborock.0
      2023-09-29 20:43:20.474	debug	Plugin sentry Initialize Plugin (enabled=true)
      roborock.0
      2023-09-29 20:43:20.348	debug	States connected to redis: 127.0.0.1:6379
      roborock.0
      2023-09-29 20:43:20.336	debug	States create User PubSub Client
      roborock.0
      2023-09-29 20:43:20.335	debug	States create System PubSub Client
      roborock.0
      2023-09-29 20:43:20.327	debug	Redis States: Use Redis connection: 127.0.0.1:6379
      roborock.0
      2023-09-29 20:43:20.307	debug	Objects connected to redis: 127.0.0.1:6379
      roborock.0
      2023-09-29 20:43:20.300	debug	Objects client initialize lua scripts
      roborock.0
      2023-09-29 20:43:19.846	debug	Objects create User PubSub Client
      roborock.0
      2023-09-29 20:43:19.844	debug	Objects create System PubSub Client
      roborock.0
      2023-09-29 20:43:19.842	debug	Objects client ready ... initialize now
      roborock.0
      2023-09-29 20:43:19.803	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
      Skript v.2023-06-20
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
              Machine ID: 5f09e0dc24364fc8951dcf01ea03774d
                 Boot ID: 687f969e56cf41c2bcbbdd9cffef19bb
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       20:55:52 up 23:02,  1 user,  load average: 4.01, 3.35, 2.81
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      Other values than 0x0 hint to temperature/voltage problems
      temp=57.4'C
      volt=0.8500V
      *** Time and Time Zones ***
                     Local time: Fri 2023-09-29 20:55:53 CEST
                 Universal time: Fri 2023-09-29 18:55:53 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.8G        2.7G        111M         13M        1.0G        971M
      Swap:           99M         99M        0.0K
      Total:         3.9G        2.8G        111M
               3838 M total memory
               2706 M used memory
                670 M active memory
               2888 M inactive memory
                111 M free memory
                167 M buffer memory
                853 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /dev/root      ext4       59G   19G   38G  34% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G  2.2M  1.9G   1% /dev/shm
      tmpfs          tmpfs     1.9G   18M  1.9G   1% /run
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/loop1     squashfs   41M   41M     0 100% /snap/certbot/3025
      /dev/loop0     squashfs   54M   54M     0 100% /snap/core20/2018
      /dev/loop2     squashfs   91M   91M     0 100% /snap/core/15929
      /dev/loop3     squashfs   91M   91M     0 100% /snap/core/16098
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      Show mounted filesystems (real ones only):
      TARGET               SOURCE         FSTYPE   OPTIONS
      /                    /dev/mmcblk0p2 ext4     rw,noatime
      |-/sys/fs/bpf        none           bpf      rw,nosuid,nodev,noexec,relatime,mode=700
      |-/snap/certbot/3025 /dev/loop1     squashfs ro,nodev,relatime
      |-/snap/core20/2018  /dev/loop0     squashfs ro,nodev,relatime
      |-/snap/core/15929   /dev/loop2     squashfs ro,nodev,relatime
      |-/snap/core/16098   /dev/loop3     squashfs ro,nodev,relatime
      `-/boot              /dev/mmcblk0p1 vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.6G    /var/
      3.1G    /var/lib
      1.9G    /var/lib/mysql
      1.7G    /var/lib/mysql/iobroker
      525M    /var/lib/piVCCU3
      Archived and active journals take up 16.0M in the file system.
      /opt/iobroker/backups:
      197M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      695M    /opt/iobroker/iobroker-data/
      466M    /opt/iobroker/iobroker-data/files
      136M    /opt/iobroker/iobroker-data/backup-objects
      87M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      28M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c4efe404.js.map
      20M     /opt/iobroker/iobroker-data/objects.json.migrated
      20M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.18.0
      /usr/bin/node           v18.18.0
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Installed: 18.18.0-1nodesource1
        Candidate: 18.18.0-1nodesource1
        Version table:
       *** 18.18.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      No configuration change needed.
      Multihost discovery server: disabled
      Discovery authentication:   enabled
      Persistent activation:      disabled
      Objects:                    redis on 127.0.0.1
      States:                     redis on 127.0.0.1
      Core adapters versions
      admin:          6.10.2
      javascript:     7.1.4
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : iobroker                                 - disabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        system.adapter.coronavirus-statistics.0 : coronavirus-statistics: iobroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 42001
      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
      + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      + system.adapter.radar2.0                 : radar2                : iobroker                                 -  enabled
      + system.adapter.radar2.1                 : radar2                : iobroker                                 -  enabled
        system.adapter.ring.0                   : ring                  : iobroker                                 - disabled
        system.adapter.roadtraffic.0            : roadtraffic           : iobroker                                 - disabled
        system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
        system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
      + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
        system.adapter.socketio.0               : socketio              : iobroker                                 - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
        system.adapter.tr-064.1                 : tr-064                : iobroker                                 - disabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.10.4   , installed 6.10.2 [Updatable]
      Adapter    "alarm"        : 3.3.13   , installed 3.3.13
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "backitup"     : 2.8.2    , installed 2.8.1  [Updatable]
      Adapter    "bring"        : 1.8.4    , installed 1.8.1  [Updatable]
      Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
      Adapter    "daswetter"    : 3.1.10   , installed 3.1.10
      Adapter    "email"        : 1.2.0    , installed 1.2.0
      Adapter    "eusec"        : 1.1.2    , installed 1.1.0  [Updatable]
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
      Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "lgtv"         : 1.1.12   , installed 1.1.12
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "mqtt"         : 5.0.0    , installed 5.0.0
      Adapter    "node-red"     : 4.0.3    , installed 4.0.3
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
      Adapter    "pvforecast"   : 2.8.1    , installed 2.8.1
      Adapter    "radar2"       : 2.0.7    , installed 2.0.7
      Adapter    "ring"         : 5.0.0-alpha.0, installed 3.4.0 [Updatable]
      Adapter    "roadtraffic"  : 0.2.0    , installed 0.2.0
      Adapter    "roborock"     : 0.4.4    , installed 0.4.4
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "schoolfree"   : 1.1.2    , installed 1.1.2
      Adapter    "shelly"       : 6.4.5    , installed 6.4.1  [Updatable]
      Adapter    "shuttercontrol": 1.6.2   , installed 1.6.2
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.5.6    , installed 6.5.5  [Updatable]
      Adapter    "sonos"        : 2.3.3    , installed 2.3.1  [Updatable]
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "trashschedule": 2.2.0    , installed 2.2.0
      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
      Adapter    "vis"          : 1.4.16   , installed 1.4.16
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.1.3    , installed 6.1.2  [Updatable]
      Adapter    "ws"           : 2.5.6    , installed 2.5.5  [Updatable]
      Adapter    "zigbee"       : 1.8.24   , installed 1.8.24
      Objects and States
      Objects:        32411
      States:         52049
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://phoscon.de/apt/deconz buster InRelease
      Ign:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:4 http://archive.raspberrypi.org/debian buster InRelease
      Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
      Err:6 https://deb.nodesource.com/node_18.x nodistro Release
        Could not handshake: Error in the pull function. [IP: 2606:4700:10::6816:41a 443]
      Get:7 https://apt.grafana.com stable InRelease [5984 B]
      Reading package lists...
      E: The repository 'https://deb.nodesource.com/node_18.x nodistro Release' no longer has a Release file.
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1318755    12061/io.jarvis.0
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          22913      809/lighttpd
      tcp        0      0 192.168.78.83:42001     0.0.0.0:*               LISTEN      1001       87501      6525/io.hm-rpc.0
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        21806      724/pihole-FTL
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18356      738/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          332335     14432/cupsd
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       88205      6262/node-red
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       86309      6281/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       87235      6402/io.mqtt.0
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          22964      818/smbd
      tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        21812      724/pihole-FTL
      tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      110        16875      808/mysqld
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          22965      818/smbd
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        16819      772/redis-server 12
      tcp6       0      0 :::80                   :::*                    LISTEN      0          22914      809/lighttpd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       3021956    27005/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2963823    25413/io.web.0
      tcp6       0      0 :::53                   :::*                    LISTEN      999        21808      724/pihole-FTL
      tcp6       0      0 :::22                   :::*                    LISTEN      0          18358      738/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          332334     14432/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      113        136316     8949/grafana
      tcp6       0      0 :::445                  :::*                    LISTEN      0          22962      818/smbd
      tcp6       0      0 ::1:4711                :::*                    LISTEN      999        21813      724/pihole-FTL
      tcp6       0      0 ::1:6379                :::*                    LISTEN      109        16820      772/redis-server 12
      tcp6       0      0 :::139                  :::*                    LISTEN      0          22963      818/smbd
      tcp6       0      0 :::3500                 :::*                    LISTEN      1001       90354      6593/io.sonos.0
      udp        0      0 0.0.0.0:41879           0.0.0.0:*                           1001       601710     9411/io.backitup.0
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        21805      724/pihole-FTL
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       89218      6437/io.radar2.0
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       88118      6318/io.radar2.1
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16209      471/dhclient
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          332343     14433/cups-browsed
      udp        0      0 192.168.78.255:137      0.0.0.0:*                           0          21669      701/nmbd
      udp        0      0 192.168.78.83:137       0.0.0.0:*                           0          21668      701/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          21656      701/nmbd
      udp        0      0 192.168.78.255:138      0.0.0.0:*                           0          21671      701/nmbd
      udp        0      0 192.168.78.83:138       0.0.0.0:*                           0          21670      701/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          21657      701/nmbd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17448      402/avahi-daemon: r
      udp        0      0 0.0.0.0:44942           0.0.0.0:*                           108        17450      402/avahi-daemon: r
      udp6       0      0 :::53                   :::*                                999        21807      724/pihole-FTL
      udp6       0      0 :::5353                 :::*                                108        17449      402/avahi-daemon: r
      udp6       0      0 :::52557                :::*                                108        17451      402/avahi-daemon: r
      2023-09-29 20:45:44.387  - warn: host.iobroker Do not restart adapter system.adapter.roborock.0 because restart loop detected
      2023-09-29 20:46:00.229  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
          at /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/maps/core/core/modbus-client-core.js:79:156
          at processTicksAndRejections (node:internal/process/task_queues:95:5)
      2023-09-29 20:46:00.249  - error: node-red.0 (6192) 29 Sep 20:46:00 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
      2023-09-29 20:48:08.985  - error: node-red.0 (6192) 29 Sep 20:48:08 - [error] [modbus-getter:n37000-37123] Error: Timed out
      2023-09-29 20:48:09.020  - error: node-red.0 (6192) 29 Sep 20:48:09 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
      2023-09-29 20:50:45.740  - info: javascript.0 (6113) script.js.common.Weather: Material Design Widgets: Wetter Skript triggered by 'linkeddevices.0.Sensor.Wetter.temperature'
      2023-09-29 20:55:00.944  - info: sql.0 (6216) Do not store value "NULL" for hm-rpc.0.LTK0086602.4.VALVE_STATE because no number
      2023-09-29 20:56:42.693  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Timed out
      2023-09-29 20:56:42.720  - error: node-red.0 (6192) 29 Sep 20:56:42 - [error] [modbus-getter:n37000-37123] Error: Modbus exception 6: Slave device busy (retry request again later)
      Danke fürs ansehen.
      • Michael Sauer
        Michael Sauer @ticaki last edited by
        @ticaki Ist jetzt aktiviert.
        • Glasfaser
          Glasfaser @Michael Sauer last edited by
          @michael-sauer sagte in Roborock - Adapter stürzt ständig ab:
          Bullseye ist aktuell
          free 111M
          Dein Speicher geht aus ...
          Redis OK , dann läuft aber
          redis-server 12
          Beta Tester ... OK ... aber nicht Aktuell ... up to Date!!!
          Dann
          Michael Sauer 1 Reply Last reply Reply Quote 0
          • Michael Sauer
            @glasfaser Was möchtest du mir damit sagen?
            Glasfaser S 2 Replies Last reply Reply Quote 0
            • Glasfaser
              @michael-sauer
              Ziemlich ausgelastet dein Raspberry und auch nicht ioBroker als "Beta Tester" gepflegt !
              Ich würde auf jeden Fall mal PiHole prüfen , denn ich habe oben geschrieben :
              @glasfaser sagte in Roborock - Adapter stürzt ständig ab:
              setInterval called, but adapter is shutting down
              Keine Verbindung !?
                SpacerX @Michael Sauer last edited by
                @michael-sauer ich bleibe dabei. Stelle die Maperstellung ab, dann sollte er laufen.
                  ticaki Developer last edited by ticaki
                  Der hängt in der Fehlerbehandlung(Map) beim Aufruf von Sentry. Das abschalten der Maperzeugung, so das diese Fehlerbehandlung nicht mehr aufgerufen wird, ist sicher ein Weg. @copystring
                  Hab nur den Sauger aber nicht den Adapter im Einsatz, sollte wohl ein github issue aufgemacht werden.
                  https://github.com/copystring/ioBroker.roborock
                  Michael Sauer A 2 Replies Last reply Reply Quote 0
                  • copystring
                    copystring @Michael Sauer last edited by
                    @michael-sauer Die Kartenerstellung kann auf einem RPi nicht funktionieren. Da gibt es ein Problem mit der Canvas-Bibliothek.
                    https://github.com/copystring/ioBroker.roborock#map-creation-does-not-work-on-raspberry-pi
                    • Michael Sauer
                      @ticaki sagte in Roborock - Adapter stürzt ständig ab:
                      Das war die Lösung. Danke.
                        Almeda @ticaki last edited by
                        @ticaki said in Roborock - Adapter stürzt ständig ab:
                        ich möchte mich an dieses Thema kurz mit anhängen. Nutze den Roborock Adapter seit ca. 4 Wochen und habe seit Anbeginn, trotz ausgeschalteter Map Erstellung, das Problem, dass der Adapter laut dem Host ständig abstürzt und er ihn daher regelhaft nach 1-2 Tagen aus dem Rennen nimmt und den Neustart verhindert.
                        Tatsächlich hat die Einrichtung nach der Installation problemlos geklappt und auch die Anbindung an Node-Red zum Ausspielen der Stati über Telegramm hat sofort funktioniert.
                        Eine De- und Neuinstallation des Apdaters hat nichts gebracht. Ich habe dann auf das aktuelle Update gewartet, weil ich es für ein vllt. bekanntes Problem hielt. Das Update von vor einigen Tagen hat jedoch keine Besserung gebracht.
                        IoB läuft auf einem Synology 918+ mit ausreichend RAM. Kein anderer Adapter macht Probleme.
                        Kann einer weiterhelfen?
                        Vielen Dank
                        Almeda
                        Thomas Braun haselchen 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @Almeda last edited by
                          @almeda sagte in Roborock - Adapter stürzt ständig ab:
                          Ohne Log? Schwierig.
                          • haselchen
                            haselchen Most Active @Almeda last edited by
                            @almeda
                            Warum nicht den Mihome-Vacuum?
                            Der funktioniert völlig unkompliziert und macht meines Erachtens das Gleiche wie Dein Adapter.
                            Bei meinem weiß ich allerdings, dass er funktioniert 😉
                              Almeda @Thomas Braun last edited by
                              @thomas-braun said in Roborock - Adapter stürzt ständig ab:
                              Sorry, vergessen anzuhängen. Es erscheint die Warnung:
                              Failed to execute get_fw_features on robot 4d98R7TEpn6C0ZcYPNY52Q Error: Local request with id 5 with method get_fw_features timed out after 10 seconds
                              @haselchen said in Roborock - Adapter stürzt ständig ab:
                              @almeda
                              Den hatte ich bisher nicht auf dem Schirm. Ich danke dir für den Hinweis. Probiere ihn gerne mal aus!
                              haselchen 1 Reply Last reply Reply Quote 1
                              • haselchen
                                @almeda
                                Gib dann mal bitte Feedback….
                                  Almeda @haselchen last edited by
                                  @almeda
                                  Eben versucht und in der Dokumentation festgestellt, dass der S7 nicht funktioniert. Damit ist die Option leider auch raus 😞
                                  • haselchen
                                    @almeda
                                    Wird der Roboter in der Instanz gefunden ?
                                    Werden Objekte angelegt ?
                                    Was sagt das Log?
                                    Da S8 und ich meine S10 unterstützt werden, warum sollte der S7 da nicht bei sein?
                                    Hab noch nen S50 2. Gen.
                                      Almeda @haselchen last edited by Almeda
                                      @almeda
                                      Was sagt das Log?
                                      So zurück aus dem Urlaub und Zeit fürs Hobby 😉
                                      Danke für deine Rückfrage:
                                      Es geht ja schon damit los, dass der Mihome-Vacuum Adapter einen Xiaomi Login will, denn ich für den Roborock S7 ja nicht habe. Der Roborock wird ja über den Roborock eigenen Cloudserver verwaltet.
                                      Darüber habe ich mich dann gewundert und im Logg nachgesehen. Da steht eindeutig drin, dass alle Roboter, ausgenommen S7, unterstützt werden. Liegt wohl daran, dass der S7 anders kommuniziert, als die anderen Roboter.
                                      Zurück zu meinem eigentlichen Problem eines ständig abstürzenden Roborock-Adapters:
                                      Seit dem letzten Update ist der Adapter nicht mehr abgestürzt. Aber ob er stabil läuft, kann ich auch nicht sagen, da ich nun gelbe Warnungen bekomme:
                                      code_text
                                      ```2024-05-24 00:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                      2024-05-24 00:44:00.485 - warn: roborock.0 (508) MQTT connection close.
                                      2024-05-24 00:44:00.485 - warn: roborock.0 (508) MQTT connection reconnect.
                                      2024-05-24 01:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                      2024-05-24 01:44:00.445 - warn: roborock.0 (508) MQTT connection close.
                                      2024-05-24 01:44:00.445 - warn: roborock.0 (508) MQTT connection reconnect.
                                      2024-05-24 02:44:00.429 - warn: roborock.0 (508) Reconnecting mqtt client!
                                      2024-05-24 02:44:00.446 - warn: roborock.0 (508) MQTT connection close.
                                      2024-05-24 02:44:00.446 - warn: roborock.0 (508) MQTT connection reconnect.
                                      2024-05-24 03:10:28.073 - warn: roborock.0 (508) Unable to decode message for 4d98R7TEpn6C0ZcYPNY52Q. The the device is most likely offline. data: {"version":"1.0","seq":74,"random":641679,"timestamp":1716513028,"protocol":500,"payload":{"type":"Buffer","data":[123,34,111,110,108,105,110,101,34,58,102,97,108,115,101,125]},"crc32":2579086837}
                                      2024-05-24 03:11:07.991 - warn: roborock.0 (508) Unable to decode message for 4d98R7TEpn6C0ZcYPNY52Q. The the device is most likely offline. data: {"version":"1.0","seq":87,"random":721864,"timestamp":1716513067,"protocol":500,"payload":{"type":"Buffer","data":[123,34,111,110,108,105,110,101,34,58,116,114,117,101,125]},"crc32":3231908517}
                                      2024-05-24 03:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                      2024-05-24 03:44:00.445 - warn: roborock.0 (508) MQTT connection close.
                                      2024-05-24 03:44:00.445 - warn: roborock.0 (508) MQTT connection reconnect.
                                      2024-05-24 04:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                      2024-05-24 04:44:00.445 - warn: roborock.0 (508) MQTT connection close.
                                      2024-05-24 04:44:00.446 - warn: roborock.0 (508) MQTT connection reconnect.
                                      2024-05-24 05:44:00.430 - warn: roborock.0 (508) Reconnecting mqtt client!
                                      2024-05-24 05:44:00.446 - warn: roborock.0 (508) MQTT connection close.
                                      2024-05-24 05:44:00.446 - warn: roborock.0 (508) MQTT connection reconnect.```
                                      code_text
                                      So geht das jede Stunde in der 44. Minute der Stunde einmal durch...
                                      • haselchen
                                        @almeda
                                        Wie gesagt, beim Roborock Adaper wäre ich raus.
                                        Was spricht aber dagegen, dass Du ihn in der Xiaomi App registrierst?
                                        Hab ich, und logischerweise alle anderen Nutzer, auch.
                                        Und dann könnte man mal weitersehen , wie es im Mihome-Vacuum Adapter aussieht.
                                        • Z
                                          ZeroQool last edited by
                                          Wenn ich den Adapter installieren möchte kommt der Fehler:
                                          $ iobroker add roborock --host iobroker
                                          file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupBackup.js:5import tar from 'tar'; ^^^SyntaxError: The requested module 'tar' does not provide an export named 'default' at ModuleJob._instantiate (node:internal/modules/esm/module_job:134:21) at async ModuleJob.run (node:internal/modules/esm/module_job:217:5) at async ModuleLoader.import (node:internal/modules/esm/loader:316:24)Node.js v20.15.1
                                          ERROR: Process exited with code 1
                                          Weißt jemand was das sein könnte?
                                          • wendy2702
                                            wendy2702 @ZeroQool last edited by wendy2702
                                            @zeroqool warum Doppelpost?
                                            https://forum.iobroker.net/topic/67186/neuer-adapter-für-roborock-staubsauger/810#
                                            Zumal es hier um Absturz geht.
                                            30
                                            1587
