    4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
      Thomas Braun Most Active @Walter.O. last edited by
      @walter-o
      Was muss ich denn da jetzt machen, blicke da jetzt mal gar nicht durch.
      Da kannst du gar nix machen, die Dateien sind im Moment wohl defekt.
      Bei mir kommt das auch so um die Ecke:
      $ iobroker url https://github.com/jjwbruijn/OpenEPaperLink --host chet --debug
      install jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c
      NPM version: 10.7.0
      Installing jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c... (System call)
      npm warn tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.
      npm error code ENOENT
      npm error path /home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.jsonnpm error errno -2
      npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.json'
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-11T15_24_06_313Z-debug-0.log
      npm warn tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.npm warn tarball tarball data for github:jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c (null) seems to be corrupted. Trying again.npm error code ENOENTnpm error syscall opennpm error path /home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.jsonnpm error errno -2npm error enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/iobroker/.npm/_cacache/tmp/git-cloneXXXXXXZkFV1r/package.json'npm error enoent This is related to npm not being able to find a file.npm error enoentnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-11T15_24_06_313Z-debug-0.log
      host.chet Cannot install jjwbruijn/OpenEPaperLink#73db8d52a88260640b7252a382410c26c9ceec2c: 254
      ERROR: Process exited with code 25
      Walter.O. B 2 Replies Last reply Reply Quote 0
      • Walter.O.
        Walter.O. @Thomas Braun last edited by
        @thomas-braun Okay,Danke dir
          bimmi @Walter.O. last edited by
          @walter-o was genau willst du installieren? Der OpenEPaperLink Adapter wird nicht weiter entwickelt.
          Den Access Point am besten über www.openepaperlink.de installieren.
            bimmi @Thomas Braun last edited by bimmi
            @thomas-braun sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
            @walter-o
            NPM version: 10.7.0
            Man könnte auch diesen fork nutzen. Der ist aktueller :
            https://github.com/jonasniesner/OpenEPaperLink
            Jedoch würde ich wie gesagt über openepaperlink.de gehen.
            Aber: mit der aktuellsten Version geht gar nichts im Moment. Auch der zigbee Teil ist defekt.
              Beowolf @bimmi last edited by
              @bimmi sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
              So, hab mich mal ein bisschen bemüht und dann ist folgendes herausgekommen:
              https://github.com/slimline33/OpenEPaperLink-IOBROKER-JavaScript
              Bitte testen.
              "javascript.0 (1401318) script.js.EPS.Websocket2_Test: Object "0_userdata.0.OpenEPaperLink.4467090B10421125" can't be copied: {}"
              Den Fehler bekomm ich noch nicht weg, ändert aber nichts an der Funktion!
              Super. Vielen Dank dafür.
              Der löpp ja richtig gut. Die Buttonabfrage funktioniert auch top. 👍 👍 👍 👍 👍
                Jetzt noch json push einbauen und fertig ist der Adapter 😅🤣
                  A Former User @Walter.O. last edited by
                  @walter-o @Thomas-Braun
                  was macht ihr da denn? Das ist doch kein iobroker Adapter... tss.. 🙂
                  OpenEpaperlink flasht man auf einen entsprechenden Accesspoint, meist ein ESP32 mit zigbee Modul... auch hier, wie bei Tasmota, einfach das Webinterface nehmen. Oder einfach mal die Anleitung lesen (mach ich auch erst, wenn nix geht.. 🙂 )
                    @ilovegym sagte in EPS E-INK Display Ansteuerung -> Statusdisplay für 2€:
                    🙂 Hatte nur den github-Link aus dem ersten Beitrag genommen. Und erst danach gesehen, das es kein Adapter ist.
                      bimmi last edited by bimmi
                      Ich hab mein Script etwas angepasst.
                      folgende Sachen kommen jetzt über websocket / tag.json mit
                      • hwType / Alias (Display Bezeichnung)
                      • height in px
                      • widht in px
                      • colors
                      • colortable (json um die richten Farben zu setzen für rot, schwarz, grau usw)
                      ein kleiner Fehler ist noch drin, aber das ändere ich evtl. heute Abend. Wäre schön wenn Ihr testen würdet und mir entsprechend ein issue auf github öffnen würdet!
                      • haselchen
                        haselchen Most Active @bimmi last edited by haselchen
                        @bimmi
                        Sollte, glaube ich, in einer der letzten Versionen implementiert worden sein: Update Anzeige.
                        Find ich es nicht oder wie muss das eingestellt werden?
                        Möchte gerne , vornehmlich oben rechts , angezeigt bekommen wann der Tag zuletzt aktualisiert worden ist .
                          bimmi @haselchen last edited by
                          @haselchen Es wird der timestamp im unix Format angezeigt. Musst du entsprechend umrechnen. Ich könnte das auch mit machen im Script
                          • haselchen
                            @bimmi
                            Da ich die Voreinstellungen nehme ( Wetter, Kalender…) , wie kriege ich das da mit rein ? 🤔
                              @haselchen das ist unabhängig von iobroker und wird ja über den ap gestellt.
                              Das Skript ist nur zum Daten holen vom AP.
                              • haselchen
                                @bimmi
                                Wir wäre dann die Vorgehensweise für mein Vorhaben?
                                  @haselchen gute Frage! Frag das doch mal im discord bei den Entwicklern.
                                    Ich bin irgendwie mit dem Puppeteer Screenshot nicht zufrieden. Die Qualität passt einfach nicht. Ich hab Qualität auf 100% und trotzdem diese ausgefranste Schrift. Ist das bei Euch auch so?
                                    Beispiel Foto VIS / Puppeteer:
                                    Beispiel Foto Photoshop JPG (andere Schriftart):
                                    • BananaJoe
                                      BananaJoe Most Active @bimmi last edited by BananaJoe
                                      @bimmi jetzt wo du es schreibst:
                                      43ace26c-838c-401c-afda-7b32dca75faa-image.png 59a44457-32ce-46f7-835a-564d8e3f0348-image.png
                                      Die Images sind "Image URL", die "Originale", also die vom Puppeteer-Adapter gespeicherten Bilder, sehen so aus:
                                      Wenn man reinzoomt sieht man die verwaschenen Ränder.
                                      • BananaJoe
                                        Nachtrag: Wenn ich vom Adapter ein png erzeugen lasse, sieht das 1:1 aus wie das jpg
                                        Edit: Scheint ein allgemeines Problem in Puppeteer zu sein. Einige scheinen sich damit zu helfen deviceScaleFactor=2 zu nutzen und so das Bild doppelt so groß anzufordern und dann wieder runter zu skalieren.
                                        Wäre ein Test wert, die View in VIS also in doppelter Auflösung, den Screenshot dann doppelt so groß und dann runterskalieren. Der Adapter kann das scheinbar nicht übernehmen (jedenfalls nicht mit SendTo)
                                        Ich teste das mal
                                        • BananaJoe
                                          mhh, unscharf ist unscharf ... ich experimentiere mit downscaling und schärfen ... aber das Problem ist das Ausgangsmaterial.
                                          Wenn die VIS doppelt so groß ist, ist auch der unscharfe Bereich doppelt so groß
                                            Thomas Braun Most Active @BananaJoe last edited by
                                            @bananajoe
                                            Jag das doch noch durch imagemagick durch.
                                            1028
                                            335618
