    4. Objekte werden nicht mehr angezeigt
      knopers1 last edited by
      siehe das hier, Interessant! http://forum.iobroker.net/viewtopic.php?t=1170
      • lobomau
        lobomau last edited by
        @knopers1:
        siehe das hier, Interessant! http://forum.iobroker.net/viewtopic.php?t=1170 `
        Meinst du die Muffbu.de? 🙂
          ja Lobomau…
          Ich habe jetzt nodejs von 6.12.0 auf 6.12.2 installiert. Jetzt restarten sich mein Cloud.0 Adapter ständig 😐
          cloud.0	2017-12-22 12:19:54.851	info	2017-12-22T11:19:54.850Z Connected system.user.admin
          cloud.0	2017-12-22 12:19:54.069	info	Connection changed: CONNECTED1
          cloud.0	2017-12-22 12:19:53.396	info	Connecting with https://iobroker.net:10555 with "knopers1_xxxxxxxxxxxxxxxxxxxxxxxxxx"
          cloud.0	2017-12-22 12:19:52.956	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.2
          host.orangepiplus2e	2017-12-22 12:19:49.038	info	instance system.adapter.cloud.0 started with pid 1499
          host.orangepiplus2e	2017-12-22 12:19:47.979	info	Restart adapter system.adapter.cloud.0 because enabled
          host.orangepiplus2e	2017-12-22 12:19:47.977	error	instance system.adapter.cloud.0 terminated with code 156 ()
          cloud.0	2017-12-22 12:19:37.867	info	Connection changed: DISCONNECTED3
          cloud.0	2017-12-22 12:19:20.468	info	Connection changed: CONNECTED1
          cloud.0	2017-12-22 12:19:13.369	info	2017-12-22T11:19:13.369Z Connected system.user.admin
          cloud.0	2017-12-22 12:19:12.216	info	Connecting with https://iobroker.net:10555 with "knopers1_xxxxxxxxxxxxxxxxxxxxxxxx"
          cloud.0	2017-12-22 12:19:11.819	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.2
          host.orangepiplus2e	2017-12-22 12:19:07.901	info	instance system.adapter.cloud.0 started with pid 1442
          host.orangepiplus2e	2017-12-22 12:19:06.852	info	Restart adapter system.adapter.cloud.0 because enabled
          host.orangepiplus2e	2017-12-22 12:19:06.850	error	instance system.adapter.cloud.0 terminated with code 156 ()
          cloud.0	2017-12-22 12:19:04.919	info	Connection changed: CONNECTED2
          cloud.0	2017-12-22 12:18:56.784	info	Connection changed: DISCONNECTED3
          cloud.0	2017-12-22 12:18:45.685	info	Connection changed: CONNECTED1
          cloud.0	2017-12-22 12:18:40.459	info	2017-12-22T11:18:40.457Z Connected system.user.admin
          cloud.0	2017-12-22 12:18:39.343	info	Connecting with https://iobroker.net:10555 with "knopers1_xxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          cloud.0	2017-12-22 12:18:38.947	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.2
          host.orangepiplus2e	2017-12-22 12:18:34.786	info	instance system.adapter.cloud.0 started with pid 1390
          host.orangepiplus2e	2017-12-22 12:18:33.728	info	Restart adapter system.adapter.cloud.0 because enabled
          host.orangepiplus2e	2017-12-22 12:18:33.726	error	instance system.adapter.cloud.0 terminated with code 156 ()
          cloud.0	2017-12-22 12:18:23.650	info	Connection changed: DISCONNECTED3
          cloud.0	2017-12-22 12:18:12.768	info	Connection changed: CONNECTED4
          cloud.0	2017-12-22 12:18:06.971	info	Connection changed: CONNECTED2
          javascript.0	2017-12-22 12:18:01.495	info	script.js.common.GaszaehlerWemo: setForeignState(id=javascript.0.GasMeter.Wert, state="529.70")
          cloud.0	2017-12-22 12:17:59.561	error	Error while connecting to cloud: timeout
          cloud.0	2017-12-22 12:17:49.738	info	2017-12-22T11:17:49.737Z Connected system.user.admin
          cloud.0	2017-12-22 12:17:48.275	info	Connecting with https://iobroker.net:10555 with "knopers1_xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          cloud.0	2017-12-22 12:17:47.831	info	starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.12.2
          host.orangepiplus2e	2017-12-22 12:17:43.267	info	instance system.adapter.cloud.0 started with pid 1363
          host.orangepiplus2e	2017-12-22 12:17:42.158	info	Restart adapter system.adapter.cloud.0 because enabled
          host.orangepiplus2e	2017-12-22 12:17:42.142	error	instance system.adapter.cloud.0 terminated with code 156 ()
          cloud.0	2017-12-22 12:17:37.053	error	Error while connecting to cloud: Error: xhr poll error
          cloud.0	2017-12-22 12:17:32.002	info	Connection changed: DISCONNECTED3
          • lobomau
            Man findet paar Beiträge zum Thema "terminated with code 156".
            Nach dem Update nodejs wurde der Rechner neugestartet?
            Welche cloud Version läuft? -> 2.1.1 (sieht man ja im log)
            Hat der Adapter cron job laufen? Welcher Verbindungs- und Ping-timeout eingestellt? Vielleicht Dauer mal verlängern?
            • cvidal
              @Bluefox:
              Man versucht alles in einen Topf zu schmeißen.
              Es gibt tatsächlich das Problem mit Empty ID.
              Fix dafür kommt erst in Admin 3.0
              Um das Problem jetzt zu fixen, muss man objects.json patchen.
              Dafür backup machen!!
              iobroker stoppen.
              dann die Datei /opt/iobroker/iobroker-data/objects.json editieren und da
              "_id":"",
              ````oder
              "_id":" ",
              finden.
              Ersetzen mit
              "_id":"javascript.0.variable1",
              iobroker starten und die Variable über admin löschen. `
              Ich finde die .jason Datei nicht suche ich falsch?
              Hier nochmal Konsole der Objekte Seite
              Hier Konsole von der Skripte Seite
              Gruß Christian
              • lobomau
                @cvidal:
                @Bluefox:
                iobroker stoppen.
                "_id":"",
                ````oder
                "_id":" ",
                finden.
                Ersetzen mit
                Gruß Christian `
                Ist im Ordner iobroker-data, wie beschrieben:
                Ist eine große Datei bei mir von 6 MB. Ich habe Probleme damit sie überhaupt zu öffnen. Mit meinem schwachen Laptop habe ich aufgegeben… mit Ubuntu und win10... mit notepad ++ und Editor...
                Bin dann an Desktop mit Win10. Mit Notepad ++ kannst du auch vergessen. Wir nur eine Zeile angezeigt. Das Suchen dauert eine Ewigkeit. Habe es weiter mit Editor probiert. Der ungefähr 28. Suchergebnis nach "_id" ist wohl der richtige:
                Aber irgendwie scheint das alles mit dem Kopieren oder der Datei-Art nicht zu funktionieren. Iobroker startet wie vorher und objects.jason scheint nicht geändert worden zu sein.
                Ich warte lieber auf den Fix.
                • cvidal
                  Habe es jetzt auch mal versucht, hab es dort geändert wie du es auch gemacht. Bei mir hat sich auch nichts verändert.
                  Ich warte auch erstmal ab sonst zerschieße ich mir noch das ganze System.
                  Gruß Christian
                  • Bluefox
                    Bluefox last edited by
                    @lobomau:
                    @cvidal:
                    @Bluefox:
                    iobroker stoppen.
                    "_id":"",
                    ````oder
                    "_id":" ",
                    finden.
                    Ersetzen mit
                    Gruß Christian `
                    Ich warte lieber auf den Fix. `
                    Mit notepad++ habe ich schon 600MB Dateien editieren.
                    Das wundert mich, dass du die Datei nicht editieren kannst.
                    Du musst nicht irgendeine "_id" finden sondern genau die, die ich gegeben habe.
                    Du verstehst schon, dass es um "Empty Object ID" sich handelt?
                    Ist diese Meldung weiterhin drin?
                    • lobomau
                      @Bluefox:
                      @lobomau:
                      @cvidal:
                      Gruß Christian `
                      Ist diese Meldung weiterhin drin? `
                      Hatte dann falsche Stelle geändert. Nach Weihnachten geht's weiter.
                      Frohes Fest!
                      • cvidal
                        Ich habe es bei mir in der ersten Zeile editiert, leider keine Verbesserung…
                        Also von
                        {"_design/system":{"_id":"_design/system","language":"javascript","views":{"host":{"map":"function(doc) { if (doc.type=='host')
                        in
                        {"_design/system":{"_id":"javascript.0.variable1"_design/system","language":"javascript","views":{"host":{"map":"function(doc) { if (doc.type=='host')
                        Gruß Christian
                        • lobomau
                          @cvidal:
                          Also von
                          in
                          Gruß Christian `
                          Ist da denn was von "Empty Object ID" zu finden? Die Stelle musst du wohl finden. Ich kann es selbst leider nicht testen. Bin nicht vor Ort.
                          Edit: du bist an der falschen STelle. Du musst es findet wo nichst eingetragen ist zwischen den "_id":"".
                          Ich hatte eine Stelle gefunden, wo da nichts steht, aber war wohl trotzdem falsche, weil es nichts mit Empty Object ID zu tun hatte.
                          • cvidal
                            Ich habe jetzt mal nach der Datei gesucht, habe aber nichts gefunden wo ich meine das es die Richtige ist.
                            Ich habe jetzt mal Admin 3..0.1 installiert, das brachte Leider auch keine besserung, cache leeren bringt auch nichts.
                            Hier mal ein Paar Screenshots:
                            Version 3.0.1 Installiert
                            Warum steht aber hier noch Version 2.0.9?
                            Hier nochmal die Objekte, leider noch fehlerhaft.
                            Und Komischerweise fehlen mir immer noch ca.8 Scripte, die sind nicht sichtbar aber funktionieren noch :?
                            Gruß Christian
                            • lobomau
                              Bei mir kam auch erst die korrekte Anzeige der Version nach einem Server Neustart.
                              Admin und Vis sind auch die einzigen Adapter, die mir angezeigt werden.
                              • cvidal
                                Ich habe es wieder am laufen, es liegt tatsächlich an der fehlenden id. Nur habe ich das selber nicht gefunden hat @ple für mich gemacht, ich bin gleich unterwegs dann suche ich mal wo das genau war. Melde mich heute Abend.
                                Schöne Feiertage zusammen.
                                Edit: In den Blockly und Vis.Edit lassen sich immer noch keine Objekte auswählen… Also noch nicht gelöst.
                                • cvidal
                                  So kurze Rückmeldung hier wurde editiert:
                                  ":{"common":{"name":""},"type":"channel","from":"system.adapter.admin.0","ts":1513850519069,"_id":"javascript.0.variable1","acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
                                  Da ich meine Scripte noch nicht alle wieder finde und in Vis.Edit und Blockly keine Objekte auswählen kann habe ich versucht mit iobroker upload all da irgendwas zu Retten, ging leider nicht und die Objekte waren danach auch wieder weg. Einzig in dem Webif wurde mir rechts Oben Admin Version 3.0.1 angezeigt. Danach nochmal iobroker stop dann Datei nochmals editiert und iobroker start. Objekte waren dann wieder da aber in dem Webif stand rechts Oben wieder Admin Version 2.0.9. Ich bin da mit meiner logik auch erstmal raus, weiß leider nicht weiter.
                                  Meine Scripte werden unter dem Reiter Objekte aufgelistet, warum die nicht im Reiter Scripte auftauchen ist mir ein Rätsel.
                                  Gruß Christian
                                  • lobomau
                                    @cvidal:
                                    Gruß Christian `
                                    Dann war ich doch nicht an der falschen Stelle. Mein Problem ist nur, ich bekomme es nicht auf Dauer gesichert. Die object.json springt immer auf die Version ohne "javascript.0.variable1" zurück.
                                    Meine Reihenfolge am Win10 mit Filezilla:
                                    1. über putty sudo iobroker stop
                                    2. mit filezilla ansehen/bearbeiten
                                    3. Bearbeite wird mit Editor, gesichert, filezilla beendet
                                    4. sudo iobroker start
                                    5. bearbeitete objects.json hat wieder vorherige Version
                                    Es gibt im Verzeichnis immer auch eine objects.json.bak. Muss die auch gelöscht werden? Holt sie sich hier vielleicht ihr Backup zurück?
                                      @lobomau:
                                      Bearbeite wird mit Editor, gesichert, `
                                      ich hoffe doch nicht mit dem Windows editor!
                                      nimm notepad++ und achte darauf, dass es auf UNix steht.
                                      Rainer
                                      • lobomau
                                        @Homoran:
                                        @lobomau:
                                        Rainer `
                                        Doch mit Windows Editor. Und da war auch meine Idee, dass der Fehler liegt.
                                        Ich bin deswegen auf den Editor gegangen, weil mein notepad ++ irgendwie nicht mit der Datei zurecht kommt. Wird nur eine seeeehr lange Zeile angezeigt. Format richtig erkannt als JSON file. notepad ++ reagiert super langsam mit der Datei.
                                        Wo stelle ich auf UNIX?
                                          @lobomau:
                                          Wo stelle ich auf UNIX? `
                                          Unten rechts wo bei dir Windows (!) Steht.
                                          Also ist deine datei bereits im win format
                                          Gruß Rainer
                                          • Dolomiti
                                            Dolomiti last edited by
                                            Bei mir wird im SciTe auch nur eine lange Zeile angezeigt. Der gesuchte Text steht bei mir ganz am Ende.
                                            81.1k
                                            64
                                            12463
