    4. "Wait" in blockly?
    "Wait" in blockly?
      Mac last edited by
      So, hab ich bisher noch nicht gemacht?
      <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on" id="JQK^0|z(du)IM*U6TwJG" x="-287" y="-162"><field name="OID">knx.1.Heizungskeller.Temperaturfühler.Vorlauf_WW_Bereitung</field>
      <statement name="STATEMENT"><block type="controls_if" id=".B.X5K){dsZl]:/^=lLe"><value name="IF0"><block type="logic_compare" id="WwH:4O`a{h[2:+TZUone"><field name="OP">LT</field>
              <value name="A"><block type="convert_tonumber" id="Y^`a;t/+NBzH]%IUFz2v"><value name="VALUE"><block type="on_source" id="bhR_~?IvaV|{*ybh^]RQ"><field name="ATTR">state.val</field></block></value></block></value>
              <value name="B"><block type="math_number" id="un=0::SIrHLcE+o*A*={"><field name="NUM">55</field></block></value></block></value>
          <statement name="DO0"><block type="pushover" id="u--/U[0+PAM8{}c0b61s"><field name="SOUND">siren</field>
              <field name="PRIORITY">1</field>
              <value name="MESSAGE"><shadow type="text" id="KC,0;:gM^:5s}:7-O.wb"><field name="TEXT">text</field></shadow>
                <block type="text" id=";zQua-=(yd6}*?TiU;Kl"><field name="TEXT">Achtung: Die WW-Heizung Vorlauf ist zu kalt < 55°C, bitte Service verständigen.</field></block></value>
              <value name="TITLE"><block type="text" id="cjiw_U0*JpK-nd5?lTOS"><field name="TEXT">LS50 Temoeraturwarnung</field></block></value>
              <next><block type="debug" id="%^xI1?GD2O;Wl678TnE|"><field name="Severity">log</field>
                  <value name="TEXT"><shadow type="text" id="3Bl~5bs^c3P,3V_dc,u4"><field name="TEXT">Achtung: Die WW-Heizung Vorlauf ist zu kalt < 55°C</field></shadow></value></block></next></block></statement></block></statement>
      <next><block type="on_ext" id="`,Z?}tI`A(Z_e8ZqminA"><mutation items="1"></mutation>
          <value name="OID0"><shadow type="field_oid" id="h89UobD}Vg=-]BTFV7TM"><field name="oid">knx.1.Heizungskeller.Temperaturfühler.Vorlauf_WW_Bereitung</field></shadow></value>
          <statement name="STATEMENT"><block type="controls_if" id="{0um4s_71S121vyB,Zw,"><value name="IF0"><block type="logic_compare" id="^`!SV,KB)6K4!MK}-:cA"><field name="OP">LT</field>
                  <value name="A"><block type="convert_tonumber" id="_E9Buth1~5|Lzu]T%R;e"><value name="VALUE"><block type="on_source" id="DOE[,j2vjk!y5QX#OZ:{"><field name="ATTR">state.val</field></block></value></block></value>
                  <value name="B"><block type="math_number" id="mom?P`juZv[pF^8p2RYo"><field name="NUM">60</field></block></value></block></value>
              <statement name="DO0"><block type="timeouts_settimeout" id="`z3QFws(tE}Tf-2E~2q9"><field name="NAME">timeout</field>
                  <field name="DELAY">1</field>
                  <statement name="STATEMENT"><block type="pushover" id="*~j)H=w|w]9pQVy7ACZ5"><field name="PRIORITY">0</field>
                      <value name="MESSAGE"><shadow type="text" id="ZGa0=[A(Rr5=*`mjJKMF"><field name="TEXT">text</field></shadow>
                        <block type="text" id="B/z]v77kH7yJdN2a,3u:"><field name="TEXT">Achtung: Die WW-Heizung Vorlauf ist zu kalt < 60°C</field></block></value>
                      <value name="TITLE"><block type="text" id="jr^!Oc2cOrp5Yx#54NI%"><field name="TEXT">LS50 Temeraturhinweis</field></block></value>
                      <next><block type="debug" id="m{}{`G_3gds~pk;C5{I3"><field name="Severity">log</field>
                          <value name="TEXT"><shadow type="text" id="-.FZ?`b}MnO|)-k7Yvb4"><field name="TEXT">Achtung: Die WW-Heizung Vorlauf ist zu kalt < 60°C</field></shadow></value></block></next></block></statement></block></statement></block></statement></block></next></block>
      <block type="controls_whileUntil" id="A|s#1Fr5U;}`^e]ra.1^" x="212" y="363"><field name="MODE">WHILE</field></block></xml>
      • Dutchman
        @Mac:
        So, hab ich bisher noch nicht gemacht? `
        jup naeste mal aber bitte auch in "code" bloecken.
        Probier mal so:
        Ich habe nicht eingebaut das er alle 2-3 minuten wiederhohlt. was jetzt passiert: wen die temperatur sich aendert wird nach einer minute eine meldunge generiert.
        Das passiert jedesmal wen der wert sich erneuert aber kleiner ist als 60 war das was du erreichen woltest ?
            <statement name="STATEMENT"><block type="timeouts_cleartimeout" id=")dU=a:ByKY}!XAWX9@Kq"><field name="NAME">timeout</field>
                <next><block type="timeouts_settimeout" id="`z3QFws(tE}Tf-2E~2q9"><field name="NAME">timeout</field>
                        <statement name="DO0"><block type="pushover" id="*~j)H=w|w]9pQVy7ACZ5"><field name="PRIORITY">0</field>
                                <value name="TEXT"><shadow type="text" id="-.FZ?`b}MnO|)-k7Yvb4"><field name="TEXT">Achtung: Die WW-Heizung Vorlauf ist zu kalt < 60°C</field></shadow></value></block></next></block></statement></block></statement></block></next></block></statement></block></next></block></xml>
          Mac last edited by
          Danke erst einmal.
          Ist es richtig, dass ich das von Dir überarbeitet Script nicht mehr in Blockly einlesen kann?
          Leider bekomme ich unten eine Fehlermeldung wenn ich starte > unexpected token, daher kann ich nicht probieren, aber im Prinzip richtig, ich wollte nicht alle 10 Sekunden eine Meldung wenn Alarm gegeben wird
          • Dutchman
            Wie hast du es importiert ?
            Mir den Import Knopf hoffe ich?
            Send from mobile device
              Mit dem Import Knopf über der Arbeitsfläche, nicht im Skript-Explorer
                Mac last edited by
                ENTSCHULDIGUNG!
                Tatsächlich habe ich es einfach einkopiert, ist mir eine Lehre, danke. Ab jetzt nur noch den Importknopf, der ist aber auch verrdammt klein. 😐
                • Dutchman
                  @Mac:
                  ENTSCHULDIGUNG!
                  Tatsächlich habe ich es einfach einkopiert, ist mir eine Lehre, danke. Ab jetzt nur noch den Importknopf, der ist aber auch verrdammt klein. 😐 `
                  Hat es jetzt geklappt?
                    Mac last edited by
                    Ja, super! Vielen Dank.
                      Mac last edited by
                      Ja, jetzt klappt es prima, vielen Dank für Deine super Hilfe!
                        Mac last edited by
                        @UweRLP
                        Leider doch nicht ganz, hab alles noch mal ausgiebig getestet, aber der Wert schaltet einfach nicht von wahr auf falsch: hier die Bilder. Was habe ich falsch eingerichtet?
                          Mac last edited by
                          Sorry, leider muß ich zurückrudern. Die Vorschläge mit dem Timeout stop und Timeout funktionieren leider nicht. Egal welche Variante ich probiert habe, der Alarm kommt bei einer Testverzögerung von 1 Sek. im Sekundentakt durch. Beide Varianten, Stop nur oben und Stop oben und unten habe ich probiert.
                          Zur Frage was das Ganze soll. In einem Mehrfamilienhaus haben wir sogenannte Frischwasserstationen, diese werden wie ein Durchlauferhitzer mit diesem WW-Heizvorauf im Gegenstrom betrieben und erzeugen das Duschwasser direkt in der Wohnung. Dieser Kreis wird aus einem ein m3 Speicher versorgt, ein Mischer sorgt dafür, dass die Vorlauftemperatur nicht über 65 Grad geht wegen der Verkalkung. Wenn die eine oder zwei Familien Duschen wir ad hoc eine sehr große Leistung abgefordert, es gibt immer seine starke Verzögerung, bis der Fühler die abgefallene Temperatur merkt und das Vebtil dann reagiert. Eine Familie im Erdgeschoß hat immer sehr stark schwankende Temperaturen es sehr schwierig die Speichertemperatur, WW Heizvorlauf ins richtige Verhältnis zu setzen. Der untere Wert unter 60 °C taucht immer für kurze Zeit ab, dann reißt das Ventil auf , schließt dann wieder usw.
                          Der Temperaturwert kommt von einer KNX Meßstelle, die verläßlich die richtige Temperatur vorgibt. Dieses Objekt habe ich "Vorlauf WW Bereitung" genannt.
                          Um schnell reagieren zu könne hilft mir der "Voralarm". Der richtige Alarm ist dann bei 55°C, dann ist wirklich etwas defekt.
                          ! <xml 1999/xmlns="<URL url=" http:/www.w3.org/xhtml"="">http://www.w3.org/1999/xhtml">
                          ! <block type="on" id="JQK^0|z(du)IMU6TwJG" x="-412" y="-387"><field name="OID">knx.1.Heizungskeller.Temperaturfühler.Vorlauf_WW_Bereitung</field>
                          ! <field name="CONDITION">ne</field>
                          ! <statement name="STATEMENT"><block type="controls_if" id=".B.X5K){dsZl]:/^=lLe"><value name="IF0"><block type="logic_compare" id="WwH:4Oa{h[2:+TZUone"><field name="OP">LT</field> ! <value name="A"><block type="convert_tonumber" id="Y^a;t/+NBzH]%IUFz2v"><value name="VALUE"><block type="on_source" id="bhR_~?IvaV|{ybh^]RQ"><field name="ATTR">state.val</field></block></value></block></value>
                          ! <value name="B"><block type="math_number" id="un=0::SIrHLcE+o
                          A
                          ! <statement name="DO0"><block type="pushover" id="u–/U[0+PAM8{}c0b61s"><field name="SOUND">siren</field>
                          ! <field name="PRIORITY">1</field>
                          ! <value name="MESSAGE"><shadow type="text" id="KC,0;:gM^:5s}:7-O.wb"><field name="TEXT">text</field></shadow>
                          ! <block type="text" id=";zQua-=(yd6}?TiU;Kl"><field name="TEXT">Achtung: Die WW-Heizung Vorlauf ist zu kalt < 55°C, bitte Service verständigen.</field></block></value>
                          ! <value name="TITLE"><block type="text" id="cjiw_U0
                          ! <next><block type="debug" id="%^xI1?GD2O;Wl678TnE|"><field name="Severity">log</field>
                          ! <value name="TEXT"><shadow type="text" id="3Bl~5bs^c3P,3V_dc,u4"><field name="TEXT">Achtung: Die WW-Heizung Vorlauf ist zu kalt < 55°C</field></shadow></value></block></next></block></statement></block></statement>
                          ! <next><block type="on_ext" id=",Z?}tIA(Z_e8ZqminA"><mutation items="1"></mutation>
                          ! <value name="OID0"><shadow type="field_oid" id="h89UobD}Vg=-]BTFV7TM"><field name="oid">knx.1.Heizungskeller.Temperaturfühler.Vorlauf_WW_Bereitung</field></shadow></value>
                          ! <statement name="STATEMENT"><block type="timeouts_cleartimeout" id=")dU=a:ByKY}!XAWX9@Kq"><field name="NAME">timeout</field>
                          ! <next><block type="timeouts_settimeout" id="z3QFws(tE}Tf-2E~2q9"><field name="NAME">timeout</field> ! <field name="DELAY">1</field> ! <field name="UNIT">sec</field> ! <statement name="STATEMENT"><block type="controls_if" id="{0um4s_71S121vyB,Zw,"><mutation else="1"></mutation> ! <value name="IF0"><block type="logic_compare" id="^!SV,KB)6K4!MK}-:cA"><field name="OP">LT</field>
                          ! <value name="A"><block type="convert_tonumber" id="_E9Buth1~5|Lzu]T%R;e"><value name="VALUE"><block type="on_source" id="DOE[,j2vjk!y5QX#OZ:{"><field name="ATTR">state.val</field></block></value></block></value>
                          ! <value name="B"><block type="math_number" id="mom?PjuZv[pF^8p2RYo"><field name="NUM">60</field></block></value></block></value> ! <statement name="DO0"><block type="pushover" id="*~j)H=w|w]9pQVy7ACZ5"><field name="PRIORITY">0</field> ! <value name="MESSAGE"><shadow type="text" id="ZGa0=[A(Rr5=*mjJKMF"><field name="TEXT">text</field></shadow>
                          ! <block type="text" id="B/z]v77kH7yJdN2a,3u:"><field name="TEXT">Achtung: Die WW-Heizung Vorlauf ist zu kalt < 60°C</field></block></value>
                          ! <value name="TITLE"><block type="text" id="jr^!Oc2cOrp5Yx#54NI%"><field name="TEXT">LS50 Temeraturhinweis</field></block></value>
                          ! <next><block type="debug" id="m{}{G_3gds~pk;C5{I3"><field name="Severity">log</field> ! <value name="TEXT"><shadow type="text" id="-.FZ?b}MnO|)-k7Yvb4"><field name="TEXT">Achtung: Die WW-Heizung Vorlauf ist zu kalt < 60°C</field></shadow></value></block></next></block></statement>
                          ! <statement name="ELSE"><block type="timeouts_cleartimeout" id="T8jIG:vZkU?g8eDqa497"><field name="NAME">timeout</field></block></statement></block></statement></block></next></block></statement></block></next></block></xml>
                            Mac last edited by
                            Hallo Uwe,
                            klappt gut mit dem Tapatalk, hab ich mir auch gerade eingerichtet.
                            Jetzt klappt es tatsächlich super, ich habs ausgiebig getestet kommt eine Meldung durch, dann Ruhe bis zum nächsten Eintreten der Störung, vielen Dank.
                            Das ist die eleganteste Lösung, der Ansatz mit dem Stop Timeout klappt leider doch nicht.
                            Noch nachgeschoben zur Erläuterung der Nutzung:
                            In unserem Mehrfamilienhaus haben wir sogenannte Frischwasserstationen, diese werden wie ein Durchlauferhitzer mit diesem WW-Heizvorauf im Gegenstrom betrieben und erzeugen das Duschwasser direkt in der Wohnung. Dieser Kreis wird aus einem ein m3 Speicher versorgt, ein Mischer sorgt dafür, dass die Vorlauftemperatur nicht über 65 Grad geht wegen der Verkalkung. Wenn die eine oder zwei Familien Duschen wir ad hoc eine sehr große Leistung abgefordert, es gibt immer seine starke Verzögerung, bis der Fühler die abgefallene Temperatur merkt und das Vebtil dann reagiert. Eine Familie im Erdgeschoß hat immer sehr stark schwankende Temperaturen es sehr schwierig die Speichertemperatur, WW Heizvorlauf ins richtige Verhältnis zu setzen. Der untere Wert unter 60 °C taucht immer für kurze Zeit ab, dann reißt das Ventil auf, schließt dann wieder, fängt dann an stark zu pendeln usw.
                              Mac last edited by
                              Noch eine Frage bitte, da es jetzt so gut funktioniert:
                              Kann ich aus den False/True Zuständen von "WW_KI60", wenn ich sie speichere eine Liste erzeugen - wann wie lange die Störung anstand, und wäre das sehr aufwendig?
                              • Dutchman
                                @Mac:
                                Kann ich aus den False/True Zuständen von "WW_KI60", wenn ich sie speichere eine Liste erzeugen - wann wie lange die Störung anstand, und wäre das sehr aufwendig? `
                                Jup das geht mir flot oder vis und history Tabelle
                                  aleks-83 last edited by
                                  Ich hänge mich mal an…
                                  Frage 1: Kann man folgendes mit blockly tun?
                                  Ich starte ein blockly Script (ScriptA). Schslte dort ein eigenes Datenobjekt auf true.
                                  (Daraufhin wird ein anderes Script (ScriptB) getriggert und führt ein paar Dinge aus)
                                  ScriptA wartet, bis ScriptB das Datenobjekt auf false gesetzt hat, und macht dann weiter?
                                  Geht das überhaupt grundsätzlich bei Javascript, oder würde ScriptA durch das Warten den CPU blockieren?
                                  Frage 2:
                                  Meinen Temperaturalarm vom Pi möchte ich etwas entprellen.
                                  Kann man sagen dass die Temperatur erst für eine gewisse Zeit > X sein muss bevor das Alarm ausgelöst wird?
                                  Mit einer Schleife?
                                  • rantanplan
                                    rantanplan last edited by
                                    @aleks-83:
                                    ScriptA wartet, bis ScriptB das Datenobjekt auf false gesetzt hat, und macht dann weiter? `
                                    Grundsätzlich ja.
                                    Aber bedenke, dass "ScriptA" auch einen Trigger haben muss!
                                    Solche gegenseitige Beeinflussungen sollten genau überdacht werden.
                                    Sonst geht da schnell ein PingPong los und die Rechenleistung geht in den Keller.
                                    @aleks-83:
                                    Geht das überhaupt grundsätzlich bei Javascript, oder würde ScriptA durch das Warten den CPU blockieren? `
                                    Trigger "warten" ja immer auf ein Ereignis. Ist also kein Problem.
                                    @aleks-83:
                                    Frage 2:
                                    Mit einer Schleife? `
                                    Könnte so funktionieren. (nicht getestet!)
                                    EDIT: Nochmal angepasst. Hatte vergessen, dass die Temperatur ja auch wieder kleiner werden kann 😉
                                    Export:
                                    <xml xmlns="http://www.w3.org/1999/xhtml"><block type="comment" id="b_}m+8nvy6q6]:n-Hq)H" x="-388" y="-162"><field name="COMMENT">Beim Start auf 0 setzen</field>
                                    <next><block type="variables_set" id="T*8Xo{`DaLI,fzK8kmsZ"><field name="VAR">SchleifenZaehler</field>
                                    <value name="VALUE"><block type="math_number" id="H!N#^;%rn++UG]1PBBJk"><field name="NUM">0</field></block></value>
                                    <next><block type="on_ext" id="?jtfqya)vUNMutIE:8(["><mutation items="1"></mutation>
                                            <value name="OID0"><shadow type="field_oid" id=",b0[CASnuW)~r)l3tnd1"><field name="oid">default</field></shadow></value>
                                            <statement name="STATEMENT"><block type="controls_if" id=".2v;b18-Y}4;g84{ao*6"><mutation else="1"></mutation>
                                                <value name="IF0"><block type="logic_compare" id="?24mu[mhlJnCClVBF/Ku"><field name="OP">GT</field>
                                                    <value name="A"><block type="on_source" id="AsOzK;zYeK!F2G6!A:%J"><field name="ATTR">state.val</field></block></value>
                                                    <value name="B"><block type="math_number" id="8(p`P@wfLAs?3U=UFACr"><field name="NUM">70</field></block></value></block></value>
                                                <statement name="DO0"><block type="timeouts_setinterval" id="d;8r+xhyj/60VvnGsVRi"><field name="NAME">Intervall</field>
                                                    <field name="INTERVAL">2</field>
                                                    <statement name="STATEMENT"><block type="variables_set" id="F/X(K#OH8mzJ/6i[-;%@"><field name="VAR">SchleifenZaehler</field>
                                                        <value name="VALUE"><block type="math_arithmetic" id="fu=E,.nX|^_u*N%@97QY"><field name="OP">ADD</field>
                                                            <value name="A"><shadow type="math_number" id="(z8}5YerV4mZkwY0R(nN"><field name="NUM">1</field></shadow>
                                                              <block type="variables_get" id="z?l01Q(vE/u?a4z:43,t"><field name="VAR">SchleifenZaehler</field></block></value>
                                                            <value name="B"><shadow type="math_number" id="5=;.lYhz1*_hEilamay-"><field name="NUM">1</field></shadow></value></block></value>
                                                        <next><block type="controls_if" id="11q_s*`@uqH,9H4uOkhT"><value name="IF0"><block type="logic_compare" id="X/{}z?^4n%MnX2YgfTmo"><field name="OP">GT</field>
        <value name="A"><block type="variables_get" id=".B-)Z%vkzQw|D5[0OpJ1"><field name="VAR">SchleifenZaehler</field></block></value>
        <value name="B"><block type="math_number" id="3bi{Y!Q%R+PTIWG(Lrt2"><field name="NUM">3</field></block></value></block></value>
                                                            <statement name="DO0"><block type="telegram" id="IsG^jMs%`prVZ-g}0tuL"><value name="MESSAGE"><shadow type="text" id="@qysYLa*EiLrVfI0?_)p"><field name="TEXT">Temperatur zu hoch</field></shadow></value>
        <next><block type="comment" id="QvrRE^AEC2D=G6;WVsn9"><field name="COMMENT">WICHTIG!!! Intervall stoppen!!!!</field>
        <next><block type="timeouts_clearinterval" id="iw;NuCEZ9~NX,LFxh-8+"><field name="NAME">Intervall</field></block></next></block></next></block></statement></block></next></block></statement></block></statement>
                                                <statement name="ELSE"><block type="variables_set" id="nd-!V~+C5I?xWI?R5il%"><field name="VAR">SchleifenZaehler</field>
                                                    <value name="VALUE"><block type="math_number" id="~H6ntDlWG7G/w5d8wEy#"><field name="NUM">0</field></block></value>
                                                    <next><block type="timeouts_clearinterval" id="8iiDrDrR/Fa/:b9DAPhA"><field name="NAME">Intervall</field></block></next></block></statement></block></statement></block></next></block></next></block>
                                    <block type="comment" id="flcgZXuN`F8mbx,K87F:" x="-88" y="-112"><field name="COMMENT">Datenpunkt Temperatur</field></block></xml>
                                      @rantanplan:
                                      @aleks-83:
                                      Grundsätzlich ja.
                                      Sonst geht da schnell ein PingPong los und die Rechenleistung geht in den Keller. `
                                      OK, ich wollte mir damit eigentlich nur Arbeit ersparen.
                                      Mit dem eigenen Datenobjekt würde ich dann eine meiner Standard Routinen aufrufen die ich häufig verwende.
                                      z.B. das Raufdimmen von Lampen.
                                      Bin kein Javascript Programmierer, daher denke ich vllt etwas anders rum.
                                      Ich komme aus dem Bereich eines Zeilenweise arbeitenden Programmcodes. Dort gibt es auch Wait Befehle.
                                      @rantanplan:
                                      @aleks-83:
                                      Geht das überhaupt grundsätzlich bei Javascript, oder würde ScriptA durch das Warten den CPU blockieren? Trigger "warten" ja immer auf ein Ereignis. Ist also kein Problem.
                                      Ja schon. Aber aber Trigger der hier "warten" würde, wäre ja hinter einem anderem Trigger.
                                      Wenn also in dem moment wo der erste Trigger ausgelöst wird, nicht auch der andere Trigger den gewünschten Zustand hat, wird der Trigger übersprungen, richtig?
                                      @rantanplan:
                                      @aleks-83:
                                      Frage 2:
                                      EDIT: Nochmal angepasst. Hatte vergessen, dass die Temperatur ja auch wieder kleiner werden kann 😉 `
                                      Super, Danke.
                                      Aber müsste in die Intervall-Schleife nicht noch eine Temperatur-Abfrage rein?
                                      Sonst würde jetzt einfach nur 6 Minuten nachdem die Temp > 70 ist, eine Meldung an telegram gesendet.
                                      Oder ?
                                      • rantanplan
                                        @aleks-83:
                                        Wenn also in dem moment wo der erste Trigger ausgelöst wird, nicht auch der andere Trigger den gewünschten Zustand hat, wird der Trigger übersprungen, richtig? `
                                        Wo ein Trigger steht ist völlig egal.
                                        Außer Trigger in Trigger. Das sollte man tunlichst vermeiden!
                                        Ein Trigger führt seine Befehle immer nur aus, wenn seine Bedingung erfüllt ist.
                                        @aleks-83:
                                        Oder ? `
                                        Wenn dann die Temperatur dann immer noch >70 ist, ja.
                                        Sollte die Temperatur <=70 werden, wird ja der Intervall gestoppt.
                                        Wird ein Intervall oder Timer gestoppt, werden die Befehle innerhalb eines Intervall/Timer NICHT ausgeführt.
                                          stundenblume @rantanplan last edited by
                                          @rantanplan said in "Wait" in blockly?:
                                          Der undokumentierte "Trick" mit der Variablen funktioniert nicht mehr.
                                          @NUCChris said in "Wait" in blockly?:
                                          kennt jemand einen neuen Trick? :shock:
                                          [EDIT] Stand 18.10.17 Das Folgende funktioniert NICHT mehr*****
                                          Bei mir funktioniert des Ersetzten der Zahl durch einen Variablennamen. Sogar Rechnen im Feld ist möglich. Also zB die Umrechnung von Minuten im Millisekunden.
                                          48
                                          18414
