    4. Adapter lassen sich nicht mehr aktualisieren
      t1m0 @amg_666 last edited by
      @amg_666 said in Adapter lassen sich nicht mehr aktualisieren:
      /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
      schon probiert, bringt nix 😕
      pi@iobroker:~$ nano /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
        GNU nano 3.2        /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@10.5.0
      2 info using node@v18.20.2
      3 timing npm:load:whichnode Completed in 2ms
      4 timing config:load:defaults Completed in 2ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 0ms
      6 timing config:load:builtin Completed in 0ms
      7 timing config:load:cli Completed in 3ms
      8 timing config:load:env Completed in 0ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 2ms
      10 timing config:load:project Completed in 7ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
      12 timing config:load:user Completed in 0ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 0ms
      15 timing config:load:setEnvs Completed in 1ms
      16 timing config:load Completed in 13ms
      17 timing npm:load:configload Completed in 13ms
      18 timing config:load:flatten Completed in 2ms
      19 timing npm:load:mkdirpcache Completed in 0ms
      20 timing npm:load:mkdirplogs Completed in 0ms
      21 verbose title npm install iobroker.hm-rpc@1.17.0
      22 verbose argv "install" "--save-exact" "iobroker.hm-rpc@1.17.0"
      23 timing npm:load:setTitle Completed in 0ms
      24 timing npm:load:display Completed in 1ms
      25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-
      26 verbose logfile /home/iobroker/.npm/_logs/2024-05-14T13_19_12_049Z-debug-0.log
      27 timing npm:load:logFile Completed in 6ms
      28 timing npm:load:timers Completed in 0ms
      29 timing npm:load:configScope Completed in 0ms
      30 timing npm:load Completed in 34ms
      31 timing arborist:ctor Completed in 0ms
      32 silly logfile start cleaning logs, removing 3 files
      33 timing idealTree:init Completed in 7ms
      34 timing idealTree:userRequests Completed in 3ms
      35 silly idealTree buildDeps
      36 silly fetch manifest colors@^1.3.2
      37 silly logfile done cleaning log files
      38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
      39 http fetch GET 200 https://registry.npmjs.org/colors 575ms (cache revalidated)
      40 silly fetch manifest fs-extra@^7.0.0
      41 http fetch GET 200 https://registry.npmjs.org/fs-extra 160ms (cache revalidated)
      42 silly fetch manifest iobroker.acme@0.1.2
      43 http fetch GET 200 https://registry.npmjs.org/iobroker.acme 567ms (cache revalidated)
      44 silly fetch manifest iobroker.admin@6.13.16
      45 http fetch GET 200 https://registry.npmjs.org/iobroker.admin 592ms (cache revalidated)
      46 silly fetch manifest iobroker.alexa2@3.26.4
      47 http fetch GET 200 https://registry.npmjs.org/iobroker.alexa2 591ms (cache revalidated)
      48 silly fetch manifest iobroker.alias-manager@1.2.6
      49 http fetch GET 200 https://registry.npmjs.org/iobroker.alias-manager 561ms (cache revalidated)
      50 silly fetch manifest iobroker.amazon-dash@1.2.0
      51 http fetch GET 200 https://registry.npmjs.org/iobroker.amazon-dash 581ms (cache revalidated)
      52 silly fetch manifest iobroker.backitup@2.9.8
      53 http fetch GET 200 https://registry.npmjs.org/iobroker.backitup 568ms (cache revalidated)
      54 silly fetch manifest iobroker.ble@0.13.4
      55 http fetch GET 200 https://registry.npmjs.org/iobroker.ble 225ms (cache revalidated)
      56 silly fetch manifest iobroker.broadlink2@2.1.5
      57 http fetch GET 200 https://registry.npmjs.org/iobroker.broadlink2 591ms (cache revalidated)
        t1m0 @Thomas Braun last edited by
        @thomas-braun okay, danke! War da nie dran. Werde das dann mal probieren 😵
          t1m0 @DJMarc75 last edited by
          @djmarc75 ich werde es mal versuchen und berichten
            Thomas Braun Most Active @t1m0 last edited by Thomas Braun
            @t1m0 sagte in Adapter lassen sich nicht mehr aktualisieren:
            War da nie dran.
            Das sieht man...
            Das Log ist nicht vollständig.
            • Meister Mopper
              Meister Mopper @t1m0 last edited by
              Ja, da gibt es hier im Forum gefühlt zehntausend Beiträge für Systemupgrades. Einfach suchen und das Problem selbst lösen.
                t1m0 @t1m0 last edited by t1m0
                So ich habe nun alles auf den neuesten Stand gebracht (hoffe ich zumindest).
                Trotzdem bekomme ich weiterhin diese Fehlermeldung...
                $ iobroker upgrade alexa2@3.26.5
                Update alexa2 from @3.26.4 to @3.26.5
                NPM version: 10.5.0Installing iobroker.alexa2@3.26.5... (System call)
                npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-14T20_53_59_908Z-debug-0.loghost.iobroker Cannot install iobroker.alexa2@3.26.5: 127
                ERROR: Process exited with code 25
                uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                pi@iobroker:~$ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                x86_64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v18.20.2
                v18.20.2
                10.5.0
                5.0.19
                pi
                pi cdrom floppy sudo audio dip video plugdev netdev iobroker
                /home/pi
                OK:1 http://deb.debian.org/debian bookworm InRelease
                OK:2 http://security.debian.org/debian-security bookworm-security InRelease
                OK:3 http://deb.debian.org/debian bookworm-updates InRelease
                OK:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                Paketlisten werden gelesen… Fertig
                Abhängigkeitsbaum wird aufgebaut… Fertig
                Statusinformationen werden eingelesen… Fertig
                Alle Pakete sind aktuell.
                nodejs:
                  Installiert:           18.20.2-1nodesource1
                  Installationskandidat: 18.20.2-1nodesource1
                  Versionstabelle:
                 *** 18.20.2-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                        100 /var/lib/dpkg/status
                     18.20.1-1nodesource1 500
                     18.20.0-1nodesource1 500
                     18.19.1-1nodesource1 500
                     18.19.0+dfsg-6~deb12u1 500
                        500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                     18.19.0-1nodesource1 500
                     18.18.2-1nodesource1 500
                     18.18.1-1nodesource1 500
                     18.18.0-1nodesource1 500
                     18.17.1-1nodesource1 500
                     18.17.0-1nodesource1 500
                     18.16.1-1nodesource1 500
                     18.16.0-1nodesource1 500
                     18.15.0-1nodesource1 500
                     18.14.2-1nodesource1 500
                     18.14.1-1nodesource1 500
                     18.14.0-1nodesource1 500
                     18.13.0+dfsg1-1 500
                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                     18.13.0-1nodesource1 500
                     18.12.0-1nodesource1 500
                     18.11.0-1nodesource1 500
                     18.10.0-1nodesource1 500
                     18.9.1-1nodesource1 500
                     18.9.0-1nodesource1 500
                     18.8.0-1nodesource1 500
                     18.7.0-1nodesource1 500
                     18.6.0-1nodesource1 500
                     18.5.0-1nodesource1 500
                     18.4.0-1nodesource1 500
                     18.3.0-1nodesource1 500
                     18.2.0-1nodesource1 500
                     18.1.0-1nodesource1 500
                     18.0.0-1nodesource1 500
                pi@iobroker:~$
                  @t1m0
                  Gib mal die Langfassung von
                  iob diag
                  bekannt.
                    node-waf
                    Das Ding macht seit einiger Zeit Trouble. Siehe auch hier:
                    https://forum.iobroker.net/topic/73800/iobroker-exit-25-bei-adapter-update
                      Skript v.2024-04-21
                      *** BASE SYSTEM ***
                       Static hostname: iobroker
                             Icon name: computer-vm
                               Chassis: vm 🖴
                        Virtualization: kvm
                                Kernel: Linux 6.1.0-21-amd64
                          Architecture: x86-64
                       Hardware Vendor: QEMU
                        Hardware Model: Standard PC _i440FX + PIIX, 1996_
                      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
                      model name      : Common KVM processor
                      Docker          : false
                      Virtualization  : kvm
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       23:42:01 up 10 min,  2 users,  load average: 0.15, 0.30, 0.20
                      CPU threads: 4
                      *** Time and Time Zones ***
                                     Local time: Thu 2024-05-16 23:42:01 CEST
                                 Universal time: Thu 2024-05-16 21:42:01 UTC
                                       RTC time: Thu 2024-05-16 21:42:01
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      pi
                      HOME=/home/pi
                      GROUPS=pi cdrom floppy sudo audio dip video plugdev netdev iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev bluetooth
                      *** Display-Server-Setup ***
                      pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
                      Try `pgrep -f' option to match against the complete command line.
                      Display-Server: false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            6.2G        2.6G        2.7G        544K        1.1G        3.6G
                      Swap:           5.4G          0B        5.4G
                      Total:           11G        2.6G        8.1G
                      Active iob-Instances:   31
                               5925 M total memory
                               2523 M used memory
                                374 M active memory
                               2621 M inactive memory
                               2583 M free memory
                                156 M buffer memory
                                938 M swap cache
                               5117 M total swap
                                  0 M used swap
                               5117 M free swap
                      top - 23:42:01 up 10 min,  2 users,  load average: 0.15, 0.30, 0.20
                      Tasks: 123 total,   1 running, 122 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   5925.2 total,   2583.4 free,   2523.1 used,   1094.5 buff/cache
                      MiB Swap:   5118.0 total,   5118.0 free,      0.0 used.   3402.1 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      udev           devtmpfs  2.9G     0  2.9G   0% /dev
                      tmpfs          tmpfs     593M  536K  592M   1% /run
                      /dev/vda1      ext4       27G   19G  6.6G  74% /
                      tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
                      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                      tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
                      [Thu May 16 23:31:21 2024] EXT4-fs (vda1): mounted filesystem with ordered data mode. Quota mode: none.
                      [Thu May 16 23:31:22 2024] EXT4-fs (vda1): re-mounted. Quota mode: none.
                      Show mounted filesystems:
                      TARGET                                                  SOURCE      FSTYPE      OPTIONS
                      /                                                       /dev/vda1   ext4        rw,relatime,errors=remount-ro
                      |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                      | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
                      | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
                      | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
                      | |-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
                      | `-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
                      |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
                      | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13012
                      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
                      |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=3014624k,nr_inodes=753656,mode=755,inode64
                      | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                      | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
                      | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
                      | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
                      `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=606744k,mode=755,inode64
                        |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                        |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                        |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                        `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=606740k,nr_inodes=151685,mode=700,uid=1000,gid=1000,inode64
                      /var:
                      1.3G    /var/
                      1020M   /var/cache
                      1011M   /var/cache/apt
                      935M    /var/cache/apt/archives
                      179M    /var/lib
                      Archived and active journals take up 15.3M in the file system.
                      /opt/iobroker/backups:
                      7.2G    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      2.0G    /opt/iobroker/iobroker-data/
                      1.4G    /opt/iobroker/iobroker-data/sonosCache
                      289M    /opt/iobroker/iobroker-data/files
                      159M    /opt/iobroker/iobroker-data/backup-objects
                      57M     /opt/iobroker/iobroker-data/files/javascript.admin
                      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                      20M     /opt/iobroker/iobroker-data/objects.jsonl
                      18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
                      16M     /opt/iobroker/iobroker-data/objects.json.migrated
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      HINT:
                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f6cab8486cd9eb11a420178e6fe9f4d9-if00-port0
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.20.2
                      /usr/bin/node           v18.20.2
                      /usr/bin/npm            10.5.0
                      /usr/bin/npx            10.5.0
                      /usr/bin/corepack       0.25.2
                      nodejs:
                        Installed: 18.20.2-1nodesource1
                        Candidate: 18.20.2-1nodesource1
                        Version table:
                           18.13.0+dfsg1-1 500
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      js-controller:  5.0.19
                      admin:          6.13.16
                      javascript:     7.8.0
                      nodejs modules from github:     1
                      |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                      + system.adapter.amazon-dash.0            : amazon-dash           : iobroker                                 -  enabled
                        system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
                        system.adapter.ble.0                    : ble                   : iobroker                                 - disabled
                        system.adapter.broadlink2.0             : broadlink2            : iobroker                                 - disabled
                        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                        system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                      + system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
                        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                      + system.adapter.history.0                : history               : iobroker                                 -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12002
                      + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                      + system.adapter.hue.1                    : hue                   : iobroker                                 -  enabled, port: 443
                        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                        system.adapter.info.0                   : info                  : iobroker                                 - disabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                      + system.adapter.milight-smart-light.0    : milight-smart-light   : iobroker                                 -  enabled
                      + system.adapter.milight-smart-light.1    : milight-smart-light   : iobroker                                 -  enabled
                        system.adapter.milight.0                : milight               : iobroker                                 - disabled, port: 5987
                        system.adapter.milight.1                : milight               : iobroker                                 - disabled, port: 5987
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                        system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: iobroker                                 - disabled
                        system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                        system.adapter.proxmox.0                : proxmox               : iobroker                                 - disabled, port: 8006
                      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1337, bind: 10.0.0.9
                      + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled
                        system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
                        system.adapter.tankerkoenig.1           : tankerkoenig          : iobroker                                 - disabled
                      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                        system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
                      + system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : iobroker                                 -  enabled
                        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                        system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                        system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
                        system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                        system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.yahka.1                  : yahka                 : iobroker                                 -  enabled
                        system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f6cab8486cd9eb11a420178e6fe9f4d9-if00-port0
                      + instance is alive
                      ioBroker-Repositories
                      Stable (default): http://download.iobroker.net/sources-dist.json
                      Active repo(s): Stable (default)
                      Installed ioBroker-Instances
                      Used repository: Stable (default)
                      Adapter    "acme"         : 0.1.2    , installed 0.1.2
                      Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
                      Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
                      Adapter    "backitup"     : 2.11.0   , installed 2.9.8  [Updatable]
                      Adapter    "ble"          : 0.14.0   , installed 0.13.4 [Updatable]
                      Adapter    "broadlink2"   : 2.2.0    , installed 2.1.5  [Updatable]
                      Adapter    "daswetter"    : 3.1.13   , installed 3.1.10 [Updatable]
                      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                      Adapter    "doorbird"     : 1.5.0    , installed 1.3.1  [Updatable]
                      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                      Adapter    "hm-rpc"       : 1.17.0   , installed 1.16.0 [Updatable]
                      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                      Adapter    "hue"          : 3.11.0   , installed 3.10.2 [Updatable]
                      Adapter    "ical"         : 1.14.3   , installed 1.13.3 [Updatable]
                      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
                      Adapter    "mihome-vacuum": 4.2.0    , installed 4.1.0  [Updatable]
                      Adapter    "milight"      : 0.4.0    , installed 0.4.0
                      Adapter    "milight-smart-light": 1.2.2, installed 1.2.2
                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                      Adapter    "nut"          : 1.6.0    , installed 1.6.0
                      Adapter    "openweathermap": 1.0.4   , installed 0.4.5  [Updatable]
                      Adapter    "panasonic-comfort-cloud": 2.3.0, installed 2.3.0
                      Adapter    "parser"       : 2.1.0    , installed 2.1.0
                      Adapter    "proxmox"      : 2.3.0    , installed 2.2.1  [Updatable]
                      Adapter    "pushover"     : 3.0.6    , installed 3.0.3  [Updatable]
                      Adapter    "socketio"     : 6.7.0    , installed 6.6.0  [Updatable]
                      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.3.7  [Updatable]
                      Adapter    "telegram"     : 3.2.1    , installed 3.0.1  [Updatable]
                      Adapter    "text2command" : 3.0.3    , installed 3.0.2  [Updatable]
                      Adapter    "trashschedule": 3.2.0    , installed 2.3.0  [Updatable]
                      Adapter    "unifi"        : 0.7.0    , installed 0.6.6  [Updatable]
                      Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
                      Adapter    "vis-colorpicker": 2.0.3  , installed 1.2.0  [Updatable]
                      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
                      Adapter    "vis-justgage" : 2.1.7    , installed 2.0.2  [Updatable]
                      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                      Adapter    "vis-map"      : 1.0.5    , installed 1.0.4  [Updatable]
                      Adapter    "web"          : 6.2.5    , installed 6.2.3  [Updatable]
                      Adapter    "ws"           : 2.6.1    , installed 2.5.10 [Updatable]
                      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                      Adapter    "zigbee"       : 1.10.3   , installed 1.8.24 [Updatable]
                      Objects and States
                      Objects:        23842
                      States:         20725
                      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15559      471/sshd: /usr/sbin
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1864       1/init
                      tcp        0      0 0.0.0.0:42629           0.0.0.0:*               LISTEN      1001       19144      1127/io.yahka.1
                      tcp        0      0 10.0.0.9:12002          0.0.0.0:*               LISTEN      1001       17198      758/io.hm-rpc.1
                      tcp        0      0 10.0.0.9:12001          0.0.0.0:*               LISTEN      1001       16893      671/io.hm-rpc.0
                      tcp        0      0 10.0.0.9:8100           0.0.0.0:*               LISTEN      1001       18938      1021/io.doorbird.0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15608      448/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15601      448/iobroker.js-con
                      tcp        0      0 10.0.0.9:1337           0.0.0.0:*               LISTEN      1001       17663      824/io.sonoff.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15561      471/sshd: /usr/sbin
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          1866       1/init
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15679      497/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18589      898/io.web.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       18105      985/io.simple-api.0
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14120      411/dhclient
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1865       1/init
                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       16278      741/io.mihome-vacuu
                      udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       17893      882/io.mihome-vacuu
                      udp        0      0 0.0.0.0:57980           0.0.0.0:*                           1001       19514      1178/io.milight-sma
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           106        15520      432/avahi-daemon: r
                      udp        0      0 0.0.0.0:38379           0.0.0.0:*                           106        15522      432/avahi-daemon: r
                      udp        0      0 0.0.0.0:1905            0.0.0.0:*                           1001       32778      706/io.sonos.0
                      udp        0      0 0.0.0.0:38880           0.0.0.0:*                           1001       19228      1161/io.milight-sma
                      udp6       0      0 :::111                  :::*                                0          1867       1/init
                      udp6       0      0 :::5353                 :::*                                106        15521      432/avahi-daemon: r
                      udp6       0      0 :::59121                :::*                                106        15523      432/avahi-daemon: r
                      2024-05-16 23:34:01.580  - info: panasonic-comfort-cloud.0 (1145) Got terminate signal TERMINATE_YOURSELF
                      2024-05-16 23:34:01.580  - info: panasonic-comfort-cloud.0 (1145) cleaned everything up...
                      2024-05-16 23:34:01.580  - info: panasonic-comfort-cloud.0 (1145) terminating
                      2024-05-16 23:34:01.581  - info: panasonic-comfort-cloud.0 (1145) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-05-16 23:34:01.623  - info: host.iobroker stopInstance system.adapter.panasonic-comfort-cloud.0 send kill signal
                      2024-05-16 23:34:02.081  - info: panasonic-comfort-cloud.0 (1145) terminating
                      2024-05-16 23:34:02.135  - info: host.iobroker instance system.adapter.panasonic-comfort-cloud.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2024-05-16 23:34:37.708  - info: sonoff.0 (824) Client [zwischensteckernous2] connected with secret 1715895277708_8747
                      2024-05-16 23:34:38.721  - info: sonoff.0 (824) Client [zwischensteckernous5] connected with secret 1715895278721_6036
                      2024-05-16 23:34:59.544  - info: mihome-vacuum.0 (741) create state for carpet_mode
                      2024-05-16 23:35:00.010  - info: host.iobroker instance system.adapter.dwd.0 started with pid 1332
                      2024-05-16 23:35:00.820  - info: dwd.0 (1332) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
                      2024-05-16 23:35:01.346  - info: dwd.0 (1332) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-05-16 23:35:01.857  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2024-05-16 23:35:19.650  - info: mihome-vacuum.0 (741) change states from State control.fan_power
                      2024-05-16 23:35:19.650  - info: mihome-vacuum.0 (741) create states for water box
                      2024-05-16 23:36:01.350  - info: host.iobroker iobroker upgrade doorbird@1.5.0
                      2024-05-16 23:36:02.157  - info: host.iobroker iobroker Update doorbird from @1.3.1 to @1.5.0
                      2024-05-16 23:36:02.448  - info: host.iobroker iobroker NPM version: 10.5.0Installing iobroker.doorbird@1.5.0... (System call)
                      2024-05-16 23:39:32.894  - error: host.iobroker iobroker npm ERR! code 127npm ERR! path /opt/iobroker/node_modules/zlibnpm ERR! command failednpm ERR! command sh -c node-waf clean || true; node-waf configure buildnpm ERR! sh: 1: node-waf: not foundnpm ERR! sh: 1: node-waf: not foundnpm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-16T21_36_02_664Z-debug-0.loghost.iobroker Cannot install iobroker.doorbird@1.5.0: 127
                      2024-05-16 23:39:33.904  - info: host.iobroker iobroker exit 25
                      2024-05-16 23:40:00.012  - info: host.iobroker instance system.adapter.dwd.0 started with pid 2663
                      2024-05-16 23:40:00.853  - info: dwd.0 (2663) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.20.2, js-controller: 5.0.19
                      2024-05-16 23:40:01.511  - info: dwd.0 (2663) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-05-16 23:40:02.022  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                              v.2024-04-21
                               Chassis: vm 🖴
                        Virtualization: kvm
                      Installation:           kvm
                      Kernel:                 x86_64
                      Userland:               64 bit
                      Timezone:               Europe/Berlin (CEST, +0200)
                      User-ID:                1000
                      Boot Target:            graphical.target
                      Pending OS-Updates:     0
                      Pending iob updates:    26
                      Nodejs-Installation:
                      /usr/bin/npm            10.5.0
                      /usr/bin/npx            10.5.0
                      Recommended versions are nodejs 18.20.2 and npm 10.5.0
                      MEMORY:
                      Mem:            6.2G        2.7G        2.7G        548K        1.1G        3.6G
                      Swap:           5.4G          0B        5.4G
                      Total:           11G        2.7G        8.1G
                      ioBroker Core:          js-controller           5.0.19
                                              admin                   6.13.16
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                23842
                      States:                 20725
                      Size of iob-Database:
                      16M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                      6.4M    /opt/iobroker/iobroker-data/states.jsonl
                      4.6M    /opt/iobroker/iobroker-data/states.json.migrated
                      4.6M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                      0       /opt/iobroker/iobroker-data/states.json.broken
                        @t1m0
                        Da klemmt es:
                        Installier den homematic-Adapter nochmal.
                          t1m0 @Thomas Braun last edited by t1m0
                          Wie soll ich denn etwas neu installieren? Kann ich doch nicht. Oder meinst du es ändert sich, wenn ich die Adapter vorher lösche?
                          Habe 3Stk
                            @t1m0
                            Versuch es mal über die Kommandozeile
                            iobroker upgrade ADAPTERNAME@VERSIONSNUMMER
                            €dit: Falschen Fehler korrigiert.
                            Homoran T 2 Replies Last reply Reply Quote 0
                              @thomas-braun sagte in Adapter lassen sich nicht mehr aktualisieren:
                              @t1m0
                              iobroker update ADAPTERNAME@VERSIONSNUMMER
                              @t1m0 am besten mit `--debug`` hinten dran. Und dann die Ausgabe posten
                                oder meinst du "upgrade"?
                                pi@iobroker:~$ iobroker update zigbee@1.10.3 --debug
                                Used repository: zigbee@1.10.3
                                Error: unknown repository is active - "zigbee@1.10.3". Known: Stable (default)
                                pi@iobroker:~$
                                  @t1m0
                                  Ja, sorry, hab aus dem Gedächtnis geschrieben.
                                  upgrade muss das heißen.
                                  Ich würde auch die homematic-Adapter ins Auge fassen, nicht den zigbee.
                                    pi@iobroker:~$ iobroker upgrade hm-rpc@1.17.0 --debug
                                    This upgrade of "hm-rpc" will introduce the following changes:
                                    -> 1.17.0:
                                    Fixed encrypted configuration
                                    -> 1.16.1:
                                    Improved the configuration layout
                                    Would you like to upgrade hm-rpc from @1.16.0 to @1.17.0 now? [(y)es, (n)o]: y
                                    Update hm-rpc from @1.16.0 to @1.17.0
                                    NPM version: 10.5.0
                                    Installing iobroker.hm-rpc@1.17.0... (System call)
                                    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
                                    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                                    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                    npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
                                    npm ERR! code 127
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-17T09_55_38_815Z-debug-0.log
                                    npm ERR! code 127
                                    host.iobroker Cannot install iobroker.hm-rpc@1.17.0: 127
                                    pi@iobroker:~$
                                    Qix- created this issue in visionmedia/debug
                                    closed ReDos Vulnerability Regression Visibility Notice #797
                                    mikeal created this issue in request/request
                                    open Request’s Past, Present and Future #3142
                                    timemachine3030 created this issue in axios/axios
                                    closed Hotfix: Prevent SSRF #3410
                                      Keiner mehr eine Idee was ich noch tun kann, oder woran es liegen könnte?
                                        t1m0 last edited by
                                        Ich habe nun keinen anderen Ausweg gesehen, als Iobroker neu zu installieren und ein Backup einzuspielen. Dies hat auch alles wunderbar funktioniert. Ich kann nun wieder alles aktualisieren.
                                        Ein Adapter hat aber Probleme gemacht, und den gleichen Fehler ausgespuckt. Den Adapter habe ich dann gelöscht und neu installiert. Nun habe ich auch hier keine Probleme mehr und Iobroker funktioniert wieder!!! 😳
                                          Und welcher Adapter war das?
                                          1101
