    4. Test Adapter MercedesMe v0.0.x
    • O
      oFbEQnpoLKKl6mbY5e13 @bishop9191 last edited by
      @bishop9191
      https://github.com/TA2k/ioBroker.mercedesme/issues/213
      MrIngenieur created this issue in TA2k/ioBroker.mercedesme
      open Extremely high CPU loads caused by adapter #213
        michael 1975 @oFbEQnpoLKKl6mbY5e13 last edited by
        @ofbeqnpolkkl6mby5e13 ja bei mir wird der Adapter auch immer gelb und grün
        • wendy2702
          wendy2702 last edited by
          bei mir ist der Adapter mit diesen Meldungen abgeschmiert:
          Zeile 1083: 2024-05-06 03:42:30.247  - info: mercedesme.0 (1725) Lost WebSocket connection. Reconnect WebSocket
          	Zeile 1435: 2024-05-06 06:53:15.653  - info: mercedesme.0 (1725) Lost WebSocket connection. Reconnect WebSocket
          	Zeile 2511: 2024-05-06 13:12:30.157  - info: mercedesme.0 (1725) Lost WebSocket connection. Reconnect WebSocket
          	Zeile 2517: 2024-05-06 13:13:02.160  - error: mercedesme.0 (1725) uncaught exception: WebSocket is not open: readyState 0 (CONNECTING)
          	Zeile 2518: 2024-05-06 13:13:02.161  - error: mercedesme.0 (1725) Error: WebSocket is not open: readyState 0 (CONNECTING)
          	Zeile 2519:     at WebSocket.ping (/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/ws/lib/websocket.js:361:13)
          	Zeile 2520:     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:1479:17)
          	Zeile 2523: 2024-05-06 13:13:02.161  - error: mercedesme.0 (1725) WebSocket is not open: readyState 0 (CONNECTING)
          	Zeile 2524: 2024-05-06 13:13:02.205  - info: mercedesme.0 (1725) terminating
          	Zeile 2525: 2024-05-06 13:13:02.206  - warn: mercedesme.0 (1725) Terminated (UNCAUGHT_EXCEPTION): Without reason
          	Zeile 2526: 2024-05-06 13:13:02.707  - info: mercedesme.0 (1725) terminating
          	Zeile 2528: 2024-05-06 13:13:03.707  - info: mercedesme.0 (1725) terminating with timeout
          	Zeile 2529: 2024-05-06 13:13:04.238  - error: host.iobroker instance system.adapter.mercedesme.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          	Zeile 2530: 2024-05-06 13:13:04.239  - info: host.iobroker Restart adapter system.adapter.mercedesme.0 because enabled
          	Zeile 2535: 2024-05-06 13:13:34.617  - info: host.iobroker instance system.adapter.mercedesme.0 started with pid 82075
          	Zeile 2536: 2024-05-06 13:13:37.054  - info: mercedesme.0 (82075) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v18.20.1, js-controller: 5.0.19
          	Zeile 2537: 2024-05-06 13:13:37.532  - error: mercedesme.0 (82075) Error: getaddrinfo ENOTFOUND id.mercedes-benz.com
          	Zeile 2538: 2024-05-06 13:13:37.564  - error: mercedesme.0 (82075) Error: getaddrinfo EAI_AGAIN bff.emea-prod.mobilesdk.mercedes-benz.com
          	Zeile 2539: 2024-05-06 13:13:37.565  - info: mercedesme.0 (82075) Start Websocket Connection
          	Zeile 2544: 2024-05-06 13:14:07.567  - error: mercedesme.0 (82075) uncaught exception: WebSocket is not open: readyState 0 (CONNECTING)
          	Zeile 2545: 2024-05-06 13:14:07.568  - error: mercedesme.0 (82075) Error: WebSocket is not open: readyState 0 (CONNECTING)
          	Zeile 2546:     at WebSocket.ping (/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/ws/lib/websocket.js:361:13)
          	Zeile 2547:     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:1479:17)
          	Zeile 2550: 2024-05-06 13:14:07.569  - error: mercedesme.0 (82075) WebSocket is not open: readyState 0 (CONNECTING)
          	Zeile 2551: 2024-05-06 13:14:07.571  - info: mercedesme.0 (82075) terminating
          	Zeile 2552: 2024-05-06 13:14:07.572  - warn: mercedesme.0 (82075) Terminated (UNCAUGHT_EXCEPTION): Without reason
          	Zeile 2553: 2024-05-06 13:14:08.073  - info: mercedesme.0 (82075) terminating
          	Zeile 2554: 2024-05-06 13:14:08.244  - error: host.iobroker instance system.adapter.mercedesme.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          	Zeile 2555: 2024-05-06 13:14:08.245  - info: host.iobroker Restart adapter system.adapter.mercedesme.0 because enabled
          	Zeile 2563: 2024-05-06 13:14:38.625  - info: host.iobroker instance system.adapter.mercedesme.0 started with pid 82093
          	Zeile 2564: 2024-05-06 13:14:40.862  - info: mercedesme.0 (82093) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v18.20.1, js-controller: 5.0.19
          	Zeile 2565: 2024-05-06 13:14:41.338  - error: mercedesme.0 (82093) Error: getaddrinfo ENOTFOUND id.mercedes-benz.com
          	Zeile 2566: 2024-05-06 13:14:41.379  - error: mercedesme.0 (82093) Error: getaddrinfo EAI_AGAIN bff.emea-prod.mobilesdk.mercedes-benz.com
          	Zeile 2567: 2024-05-06 13:14:41.380  - info: mercedesme.0 (82093) Start Websocket Connection
          	Zeile 2575: 2024-05-06 13:15:11.383  - error: mercedesme.0 (82093) uncaught exception: WebSocket is not open: readyState 0 (CONNECTING)
          	Zeile 2576: 2024-05-06 13:15:11.384  - error: mercedesme.0 (82093) Error: WebSocket is not open: readyState 0 (CONNECTING)
          	Zeile 2577:     at WebSocket.ping (/opt/iobroker/node_modules/iobroker.mercedesme/node_modules/ws/lib/websocket.js:361:13)
          	Zeile 2578:     at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:1479:17)
          	Zeile 2581: 2024-05-06 13:15:11.385  - error: mercedesme.0 (82093) WebSocket is not open: readyState 0 (CONNECTING)
          	Zeile 2582: 2024-05-06 13:15:11.389  - info: mercedesme.0 (82093) terminating
          	Zeile 2583: 2024-05-06 13:15:11.390  - warn: mercedesme.0 (82093) Terminated (UNCAUGHT_EXCEPTION): Without reason
          	Zeile 2584: 2024-05-06 13:15:11.891  - info: mercedesme.0 (82093) terminating
          	Zeile 2585: 2024-05-06 13:15:12.078  - error: host.iobroker instance system.adapter.mercedesme.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          	Zeile 2586: 2024-05-06 13:15:12.079  - info: host.iobroker Restart adapter system.adapter.mercedesme.0 because enabled
          	Zeile 2587: 2024-05-06 13:15:12.079  - warn: host.iobroker Do not restart adapter system.adapter.mercedesme.0 because restart loop detected
          Nach restart heute läuft er aktuell wieder.
          • wendy2702
            Habe mich heute darüber gewundert das ich keine Meldungen vom Auto mehr bekomme.
            Nach öffnen IOB dann das
            Wird ein weiteres Logfile oder Issue benötigt?
            EDIT: heute 17.05.2024 ist der Adapter bei mir wieder ausgestiegen. Hat das verhalten sonst noch jemand?
            XBiT 1 Reply Last reply Reply Quote 0
            • XBiT
              XBiT @wendy2702 last edited by
              @wendy2702
              Läuft bei mir ohne restart loop etc.
              • wendy2702
                wendy2702 @XBiT last edited by
                @xbit OK.
                Ich glaube das tritt bei mir immer auf wenn wir leider aktuell immer mal wieder einen DSL Ausfall haben.
                Mal ne Störung provozieren und schauen was passiert.
                • mickym
                  mickym Most Active @wendy2702 last edited by mickym
                  @wendy2702 sagte in Test Adapter MercedesMe v0.0.x:
                  @xbit OK.
                  Das ist doch logisch. Der Adapter pausiert wenn die websocket Verbindung unterbrochen ist. In der Regel wird ja die DSL Verbindung einmal täglich getrennt und dann wird der Adapter auch gelb, verbindet sich dann aber selbstständig wieder. Wenn aber die Verbindung dauerhaft wegbleibt, was soll der Adapter da bitte machen?
                  Wenn der Adapter gelb ist - dauert es aber sicherlich eine ganze Weile (bis zu einer Stunde) bis er sich wieder verbindet.
                  • wendy2702
                    wendy2702 @mickym last edited by
                    @mickym sagte in Test Adapter MercedesMe v0.0.x:
                    Wer hat denn was von Dauerhaft geschrieben?
                    Die DSL Unterbrechungen die wir derzeit haben dauern zwischen 1-5 minuten. Reicht das schon aus um den Adapter ins Nirvana zu schicken?
                    • mickym
                      @wendy2702 Wenn eine Websocket Verbindung unterbrochen wird, wird das sofort registriert und ja wenn alle 5 Minuten die DSL Verbindung abbricht, dann wird der Adapter irgendwann immer wieder neu gestartet. Jedenfalls sollte man sich eher um eine stabile DSL Verbindung kümmern, als dem Adapter dies anzulasten.
                      • wendy2702
                        @mickym wie kommst du darauf das ich dem Adapter das anlaste?
                        des Weiteren ist das DSL für maximal 5 Minuten unterbrochen… dann läuft es wieder Tage stabil.
                        Ich werde mal die FB neu starten um zu schauen ob das reicht um den Adapter bei mir zum Abstürzen zu bringen.
                        Wenn andere das nicht haben muss es ja scheinbar was lokales sein.
                        • mickym
                          @wendy2702 Wie gesagt mein Adapter wird sofort gelb, wenn die Verbinung zum Mercedes Server unterbrochen wurde, er baut die Verbindung dann aber wieder auf (nicht sofort nach dem DSL wieder verfügbar ist) aber innerhalb der nächsten Stunde.
                          • wendy2702
                            wendy2702 @mickym last edited by wendy2702
                            @mickym Das warte ich jetzt mal ab.
                            DSL Weg:
                            2024-05-18 19:57:51.594  - warn: telegram.0 (101455) polling_error: EFATAL, EFATAL: Error: read ETIMEDOUT
                            2024-05-18 19:57:56.602  - error: telegram.0 (101455) getMe (reconnect #0) Error:Error: EFATAL: Error: getaddrinfo EAI_AGAIN api.telegram.org
                            Adapter verliert Verbindung:
                            2024-05-18 19:58:51.102  - error: mercedesme.0 (168661) WS error:Error: getaddrinfo EAI_AGAIN websocket.emea-prod.mobilesdk.mercedes-benz.com
                            DSL wieder verbunden:
                            2024-05-18 20:02:41.210  - info: telegram.0 (101455) getMe (reconnect): Success
                            Jetzt mal warten ob und wann der Mercedes Adapter wieder connected.
                            Werde dann hier das Ergebnis zeigen.
                            EDIT: Schon passiert während ich hier geschrieben habe:
                            2024-05-18 20:03:41.090  - info: mercedesme.0 (168661) Try to reconnect
                            Hm, ob er denn doch aus einem anderen Grund bei mir abschmiert? Mal schauen was an den Tagen rund um den Adapter im log steht.
                              tombox @wendy2702 last edited by
                              @wendy2702 bitte mit 0.2.3 testen
                              • wendy2702
                                wendy2702 @tombox last edited by wendy2702
                                @tombox mache ich morgen.
                                Danke!
                                EDIT: @tombox ist jetzt installiert. Werde berichten.
                                • wendy2702
                                  @tombox :
                                  Bisher kein Absturz mehr.
                                    FM-Audio @wendy2702 last edited by
                                    Hi, ich hab den Adapter zum ersten mal installiert, bekomme auch connect auf true und die Werte sind plausible. Aber Fahrzeug lässt sich nicht steuern. Ist das über remote angedacht oder über commands? Egal wo ich drücke es passiert nichts weiter. Einmal hab ich aber gehört, dass er die Türen entriegelt hat.
                                    Danke und liebe Grüße
                                      hssk @FM-Audio last edited by
                                      @fm-audio Die remote-Befehle sollten funktionieren.
                                        FM-Audio last edited by FM-Audio
                                        @hssk nachdem ich den PIN eingetragen habe, geht jetzt Remote, super. Woher weiß der Adapter, was das Auto alles steuern kann? Vorklimatisierung? Geht sowas, ohne dass der Motor läuft?
                                        • wendy2702
                                          wendy2702 @FM-Audio last edited by
                                          @fm-audio kommt auf das Fahrzeug und die Ausstattung an.
                                          Bei mir ist mit Vorklimatisierung z.B. die Standheizung gemeint
                                            K_o_bold @wendy2702 last edited by
                                            Falls ihr auch diesen Fehler habt:
                                            WS error:Error: Unexpected server response: 418
                                            Mit der Github Version 0.2.4 ist es behoben
                                            Friedhofsblond M K 3 Replies Last reply Reply Quote 2
                                            mercedes
                                            120
                                            935
                                            235096
