    4. npm fehlt nach node.js update
      AlphaSierra @Thomas Braun last edited by
      das sieht nun so aus:
      andy@ioBroker:~$ groups
      andy cdrom floppy sudo audio dip video plugdev netdev
      andy@ioBroker:~$
        Thomas Braun Most Active @AlphaSierra last edited by
        @alphasierra
        sudo usermod -aG iobroker,adm,dialout andy
        exit
        Dann wieder mit dem andy einloggen und
        groups
        nochmal anschauen, ob die jetzt alle drin sind.
          OK:
          andy adm dialout cdrom floppy sudo audio dip video plugdev netdev iobroker
          andy@ioBroker:~$
            @alphasierra
            Dann
            iob stop
            iob fix
            iob start
            Und wenn der ioBroker rennt nochmal die Langfassung von
            iob diag
            Und nie mehr direkt als root anmelden.
              AlphaSierra @Thomas Braun last edited by AlphaSierra
              Danke!
              Skript v.2024-04-21
              *** BASE SYSTEM ***
               Static hostname: ioBroker
                     Icon name: computer-vm
                       Chassis: vm 🖴
                Virtualization: kvm
                        Kernel: Linux 6.1.0-20-amd64
                  Architecture: x86-64
               Hardware Vendor: QEMU
                Hardware Model: Standard PC _i440FX + PIIX, 1996_
              Firmware Version: rel-1.15.0-0-g2dd4b9b3f840-prebuilt.qemu.org
              model name      : Common KVM processor
              Docker          : false
              Virtualization  : kvm
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               00:29:05 up  2:06,  2 users,  load average: 4.49, 1.45, 0.70
              CPU threads: 4
              *** Time and Time Zones ***
                             Local time: Wed 2024-05-22 00:29:06 CEST
                         Universal time: Tue 2024-05-21 22:29:06 UTC
                               RTC time: Tue 2024-05-21 22:29:06
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              andy
              HOME=/home/andy
              GROUPS=andy adm dialout cdrom floppy sudo audio dip video plugdev netdev iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev
              *** Display-Server-Setup ***
              pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
              Try `pgrep -f' option to match against the complete command line.
              Display-Server: false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            4.1G        1.0G        2.0G        512K        1.4G        3.1G
              Swap:           3.2G          0B        3.2G
              Total:          7.3G        1.0G        5.2G
              Active iob-Instances:   8
                       3915 M total memory
                        957 M used memory
                        478 M active memory
                       1176 M inactive memory
                       1927 M free memory
                        210 M buffer memory
                       1102 M swap cache
                       3069 M total swap
                          0 M used swap
                       3069 M free swap
              top - 00:29:06 up  2:06,  2 users,  load average: 4.49, 1.45, 0.70
              Tasks: 101 total,   8 running,  93 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us, 40.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si, 60.0 st
              MiB Mem :   3915.2 total,   1926.4 free,    958.8 used,   1312.8 buff/cache
              MiB Swap:   3070.0 total,   3070.0 free,      0.0 used.   2956.4 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** FILESYSTEM ***
              udev           devtmpfs  1.9G     0  1.9G   0% /dev
              tmpfs          tmpfs     392M  500K  392M   1% /run
              /dev/sda1      ext4       29G  8.1G   19G  30% /
              tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
              [Tue May 21 22:22:56 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
              [Tue May 21 22:22:58 2024] EXT4-fs (sda1): re-mounted. Quota mode: none.
              Show mounted filesystems:
              TARGET                                                  SOURCE      FSTYPE      OPTIONS
              /                                                       /dev/sda1   ext4        rw,relatime,errors=remount-ro
              |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
              | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
              | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
              | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
              | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
              | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
              |-/proc                                                 proc        proc        rw,nosuid,nodev,noexec,relatime
              | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_in        o=12271
              |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
              |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=1985500k,nr_inodes=496375,mode=755,inode64
              | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
              | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev,inode64
              | |-/dev/hugepages                                      hugetlbfs   hugetlbfs   rw,relatime,pagesize=2M
              | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
              `-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=400920k,mode=755,inode64
                |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
                |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
                |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
                `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=400916k,nr_inodes=100229,mode=700,uid=100        0,gid=1000,inode64
              /var:
              981M    /var/
              558M    /var/cache
              550M    /var/cache/apt
              472M    /var/cache/apt/archives
              295M    /var/log
              Archived and active journals take up 239.1M in the file system.
              /opt/iobroker/backups:
              70M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              1.1G    /opt/iobroker/iobroker-data/
              686M    /opt/iobroker/iobroker-data/history
              215M    /opt/iobroker/iobroker-data/files
              113M    /opt/iobroker/iobroker-data/backup-objects
              57M     /opt/iobroker/iobroker-data/files/javascript.admin
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map
              24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
              19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
              12M     /opt/iobroker/iobroker-data/objects.jsonl
              8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js
              USB-Devices by-id:
              No Devices found 'by-id'
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              /usr/bin/corepack       0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.20.3-1nodesource1
                Version table:
                   18.20.3-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                   18.20.2-1nodesource1 1001
                   18.20.1-1nodesource1 1001
                   18.20.0-1nodesource1 1001
                   18.19.1-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u1 500
                      500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
               *** 18.19.0-1nodesource1 1001
                      100 /var/lib/dpkg/status
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0+dfsg1-1 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  5.0.19
              admin:          6.13.16
              javascript:     7.8.0
              nodejs modules from github:     1
              +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55        a8b13f)
              Adapter State
                system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run        as: admin
              + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 - disabled
                system.adapter.backitup.0               : backitup              : ioBroker                                 - disabled
              + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                system.adapter.flot.0                   : flot                  : ioBroker                                 -  enabled
                system.adapter.history.0                : history               : ioBroker                                 -  enabled
                system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 18701
              + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 - disabled, port: 18701
                system.adapter.hm-rpc.3                 : hm-rpc                : ioBroker                                 - disabled, port: 12001
                system.adapter.hm-rpc.4                 : hm-rpc                : ioBroker                                 - disabled, port: 12010
              + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
              + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                system.adapter.pushover.0               : pushover              : ioBroker                                 - disabled
                system.adapter.shelly.0                 : shelly                : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
                system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1883, bind: 0.0.0.0
                system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 - disabled
              + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
                system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
              + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run        as: admin
                system.adapter.weishaupt-wem.0          : weishaupt-wem         : ioBroker                                 - disabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "awtrix-light" : 0.16.0   , installed 0.16.0
              Adapter    "backitup"     : 2.11.0   , installed 2.11.0
              Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
              Adapter    "deconz"       : 1.4.0    , installed 1.4.0
              Adapter    "discovery"    : 4.4.0    , installed 4.4.0
              Adapter    "harmony"      : 1.4.0    , installed 1.4.0
              Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
              Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
              Adapter    "hue"          : 3.11.0   , installed 3.11.0
              Adapter    "iot"          : 3.2.2    , installed 3.2.2
              Adapter    "javascript"   : 7.8.0    , installed 7.8.0
              Adapter    "pushover"     : 3.0.6    , installed 3.0.6
              Adapter    "shelly"       : 6.9.0    , installed 6.9.0
              Adapter    "socketio"     : 6.7.0    , installed 6.7.0
              Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
              Adapter    "text2command" : 3.0.3    , installed 3.0.3
              Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
              Adapter    "weishaupt-wem": 0.0.15   , installed 0.0.15
              Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
              Adapter    "ws"           : 2.6.1    , installed 2.6.1
              Objects and States
              Objects:        9587
              States:         9449
              Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
              Hit:2 http://deb.debian.org/debian bookworm InRelease
              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 8
              *** Listening Ports ***
              tcp        0      0 192.168.2.108:18701     0.0.0.0:*               LISTEN      1001       43762      6702/io.hm-rpc.0
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       41655      6449/iobroker.js-co
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       41659      6449/iobroker.js-co
              tcp        0      0 192.168.2.108:2010      0.0.0.0:*               LISTEN      1001       44705      6863/io.hm-rpc.1
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13808      449/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12817      1/init
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45068      7049/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       44503      6635/io.admin.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          13810      449/sshd: /usr/sbin
              tcp6       0      0 :::111                  :::*                    LISTEN      0          12280      1/init
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13659      365/dhclient
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12818      1/init
              udp6       0      0 :::111                  :::*                                0          12821      1/init
              2024-05-22 00:30:31.524  - warn: text2command.0 (7027) slow connection to states DB. Still waiting ...
              2024-05-22 00:30:32.908  - info: hm-rega.0 (6675) time difference local-ccu 1s
              2024-05-22 00:30:33.502  - info: javascript.0 (6674) Start javascript script.js.eigen.fenster_status_script
              2024-05-22 00:30:33.729  - info: javascript.0 (6674) script.js.eigen.fenster_status_script: registered 1 subscription, 0 schedules, 0 messages, 0 logs        and 0 file subscriptions
              2024-05-22 00:30:33.730  - info: javascript.0 (6674) Start javascript script.js.wol_whs
              2024-05-22 00:30:33.745  - info: javascript.0 (6674) script.js.wol_whs: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscript        ions
              2024-05-22 00:30:34.266  - info: discovery.0 (6919) starting. Version 4.4.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v18.19.0, js-contro        ller: 5.0.19
              2024-05-22 00:30:42.517  - info: text2command.0 (7027) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.text2command, node: v18.19.0, js-        controller: 5.0.19
              2024-05-22 00:30:43.278  - info: web.0 (7049) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.19
              2024-05-22 00:30:45.115  - info: iot.0 (6968) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.19
              2024-05-22 00:30:45.657  - info: web.0 (7049) socket.io server listening on port 8082
              2024-05-22 00:30:45.691  - info: iot.0 (6968) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
              2024-05-22 00:30:45.733  - info: web.0 (7049) http server listening on port 8082
              2024-05-22 00:30:49.212  - info: iot.0 (6968) Connection changed: connect "andyxxxxxx"
              2024-05-22 00:30:50.981  - info: admin.0 (6635) Repository received successfully.
              2024-05-22 00:31:00.366  - info: info.0 (7028) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.19.0, js-controller: 5.0.        19
              2024-05-22 00:31:01.845  - info: info.0 (7028) Reading/updating systemdata.
              2024-05-22 00:31:07.657  - info: info.0 (7028) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number        "
              2024-05-22 00:31:09.927  - info: info.0 (7028) cpu Temp res = {"main":null,"cores":[],"max":null,"socket":[],"chipset":null}
              2024-05-22 00:31:14.543  - info: hm-rega.0 (6675) request state values
              2024-05-22 00:31:38.922  - info: hm-rega.0 (6675) Updated all datapoints
              2024-05-22 00:31:39.207  - info: hm-rega.0 (6675) got 24 variables
              2024-05-22 00:31:40.400  - info: hm-rega.0 (6675) added/updated 24 variables
              2024-05-22 00:31:40.401  - info: hm-rega.0 (6675) deleted 0 variables
              2024-05-22 00:31:40.464  - info: hm-rega.0 (6675) got 32 programs
              /Andy
                @alphasierra sagte in npm fehlt nach node.js update:
                ...das Code einfügen sah nun irgendwie komisch aus...
                Brauchst du nicht, die CodeTags sind im Output von iob diag schon enthalten. Du kannst die jetzt überzähligen oben und unten entfernen, dann sieht es wieder schön aus.
                  Danke, kaum macht man's richtig, schon sieht's besser aus.
                    Boot Target: graphical.target
                    Setz das auf multi-user.target
                    sudo systemctl set-default multi-user.target
                    Pending Updates: 8
                    sudo apt update
                    iob stop
                    sudo apt full-upgrade
                    iob start
                      Skript v.2024-04-21
                      *** BASE SYSTEM ***
                               Chassis: vm 🖴
                        Virtualization: kvm
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       00:52:45 up  2:29,  2 users,  load average: 4.37, 2.45, 1.55
                      CPU threads: 4
                                     Local time: Wed 2024-05-22 00:52:46 CEST
                                 Universal time: Tue 2024-05-21 22:52:46 UTC
                                       RTC time: Tue 2024-05-21 22:52:46
                                    NTP service: active
                                RTC in local TZ: no
                      andy
                      HOME=/home/andy
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            4.1G        1.6G        1.1G        507K        1.7G        2.5G
                      Swap:           3.2G          0B        3.2G
                      Total:          7.3G        1.6G        4.4G
                      Active iob-Instances:   13
                               3915 M total memory
                               1498 M used memory
                                423 M active memory
                               2028 M inactive memory
                               1089 M free memory
                                 10 M buffer memory
                               1599 M swap cache
                               3069 M total swap
                                  0 M used swap
                               3069 M free swap
                      top - 00:52:46 up  2:29,  2 users,  load average: 4.37, 2.45, 1.55
                      Tasks: 102 total,   2 running, 100 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 25.0 us, 25.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si, 50.0 st
                      MiB Mem :   3915.2 total,   1089.0 free,   1499.0 used,   1610.1 buff/cache
                      MiB Swap:   3070.0 total,   3070.0 free,      0.0 used.   2416.2 avail Mem
                      *** FILESYSTEM ***
                      /dev/sda1      ext4       29G  8.2G   19G  31% /
                      | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12271
                        `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=400916k,nr_inodes=100229,mode=700,uid=1000,gid=1000,inode64
                      /var:
                      981M    /var/
                      558M    /var/cache
                      550M    /var/cache/apt
                      295M    /var/log
                      685M    /opt/iobroker/iobroker-data/history
                      15M     /opt/iobroker/iobroker-data/objects.jsonl
                      USB-Devices by-id:
                      /usr/bin/nodejs         v18.20.3
                      /usr/bin/node           v18.20.3
                      /usr/bin/npm            10.7.0
                      /usr/bin/npx            10.7.0
                      /usr/bin/corepack       0.28.0
                      nodejs:
                        Installed: 18.20.3-1nodesource1
                        Version table:
                       *** 18.20.3-1nodesource1 1001
                           18.13.0+dfsg1-1 500
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.13.16
                      javascript:     7.8.0
                      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.history.0                : history               : ioBroker                                 -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 18701
                      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                      + instance is alive
                      Objects and States
                      Objects:        9587
                      States:         9449
                      Pending Updates: 0
                      tcp        0      0 192.168.2.108:18701     0.0.0.0:*               LISTEN      1001       55247      13813/io.hm-rpc.0
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       54949      13733/iobroker.js-c
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       54955      13733/iobroker.js-c
                      tcp        0      0 192.168.2.108:2010      0.0.0.0:*               LISTEN      1001       56322      13835/io.hm-rpc.1
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       55530      13902/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54193      13754/io.admin.0
                      2024-05-22 00:51:29.566  - info: web.0 (13902) http server listening on port 8082
                      2024-05-22 00:51:30.971  - info: iot.0 (13884) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.iot, node: v18.20.3, js-controller: 5.0.19
                      2024-05-22 00:51:31.989  - info: iot.0 (13884) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                      2024-05-22 00:51:33.904  - info: info.0 (13857) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v18.20.3, js-controller: 5.0.19
                      2024-05-22 00:51:33.883  - info: alexa2.0 (13828) Initialize all Device states ...
                      2024-05-22 00:51:35.438  - info: info.0 (13857) Reading/updating systemdata.
                      2024-05-22 00:51:36.979  - info: iot.0 (13884) Connection changed: connect "andyxxxxxxxx"
                      2024-05-22 00:51:39.756  - info: info.0 (13857) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                      2024-05-22 00:51:43.363  - info: info.0 (13857) cpu Temp res = {"main":null,"cores":[],"max":null,"socket":[],"chipset":null}
                      2024-05-22 00:51:46.905  - info: hm-rega.0 (13799) request state values
                      2024-05-22 00:51:49.707  - info: admin.0 (13754) <== Disconnect system.user.admin from ::ffff:192.168.2.23 admin
                      2024-05-22 00:51:49.710  - info: admin.0 (13754) <== Disconnect system.user.admin from ::ffff:192.168.2.23
                      2024-05-22 00:52:08.465  - info: hm-rega.0 (13799) Updated all datapoints
                      2024-05-22 00:52:08.587  - info: hm-rega.0 (13799) got 24 variables
                      2024-05-22 00:52:10.596  - info: hm-rega.0 (13799) added/updated 24 variables
                      2024-05-22 00:52:10.598  - info: hm-rega.0 (13799) deleted 0 variables
                      2024-05-22 00:52:10.692  - info: hm-rega.0 (13799) got 32 programs
                      2024-05-22 00:52:17.015  - info: hm-rega.0 (13799) added/updated 32 programs
                      2024-05-22 00:52:17.016  - info: hm-rega.0 (13799) deleted 0 programs
                      2024-05-22 00:52:17.080  - info: hm-rega.0 (13799) update rooms to enum.rooms
                      2024-05-22 00:52:17.176  - info: hm-rega.0 (13799) update functions to enum.functions
                      2024-05-22 00:52:17.320  - info: hm-rega.0 (13799) update favorites to enum.favorites
                      2024-05-22 00:53:58.816  - info: alexa2.0 (13828) Unknown Device, but enabling commands, Try it and report back if commands work.
                      2024-05-22 00:53:58.817  - info: alexa2.0 (13828) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
                      2024-05-22 00:53:58.818  - info: alexa2.0 (13828)     Device-type:A1VGB7MHSIEYFK - Andreas' Fire TV Cube (AUDIO_PLAYER,FAR_FIELD_WAKE_WORD,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,SUPPORTS_LOCALE,FLASH_BRIEFING,AMAZON_MUSIC,DEEZER,SUPPORTS_SOFTWARE_VERSION,PANDORA,I_HEART_RADIO,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,SUPPORT_CALENDAR_ALERT,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SIRIUSXM,APPLE_MUSIC,SPEECH_RECOGNIZER_USS,ARTHUR_TARGET,AUDIBLE,MUSIC_SKILL,SET_LOCALE,PAIR_BT_SINK,GOLDFISH,DREAM_TRAINING,MICROPHONE,BT_PAIRING_FLOW_V2,SALMON,REMINDERS,VOICE_TRAINING,SUPPORTS_LOCALE_SWITCH,EARCONS,KINDLE_BOOKS,TUNE_IN,SOUND_SETTINGS,VOLUME_SETTING,SLEEP,CHANGE_NAME,TIDAL,ADAPTIVE_LISTENING,CUSTOM_ALARM_TONE,SHARKNADO,MULTI_WAKEWORDS_SUPPORTED,ACTIVE_AFTER_FRO,DIALOG_INTERFACE_VERSION)
                        @alphasierra
                        Jetzt dürfte es passen. Wenn du dir mit der root shell nicht noch irgendwas anderes verbogen hast jedenfalls.
                          😬 Vielen Dank für die Hilfe und die Zeit!
                          762
