    4. Alpha Test js-controller Kiera (v6.0)
    • foxriver76
      foxriver76 Developer last edited by foxriver76
      Folgende Erfahrungen haben wir bislang im Alpha Test gemacht:
      Falls einer der folgenden Adapter im Einsatz ist muss er mindestens die folgende Version haben:
      rest-api mindestens 2.0.1
      simple-api mindestens 2.8.0
      telegram mindestens 3.3.0
      samsung mindestens 0.6.0
      heating-control mindestens 2.12.6
      daswetter mindestens 3.1.14
      M 1 Reply Last reply Reply Quote 2
        mrjeschke @foxriver76 last edited by
        @foxriver76
        Installation war problemlos, aber es kommt jetzt ständig ein Error.
        2024-05-22 12:40:47.406 - error: host.raspi4 Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sql/node_modules/@iobroker/adapter-core/build/controllerTools.js:94
        2024-05-22 12:40:47.407 - error: host.raspi4 Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
        2024-05-22 12:40:47.408 - error: host.raspi4 Caught by controller[0]: ^
        2024-05-22 12:40:47.408 - error: host.raspi4 Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
        2024-05-22 12:40:47.408 - error: host.raspi4 Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.sql/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:11)
        2024-05-22 12:40:47.408 - error: host.raspi4 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.sql/node_modules/@iobroker/adapter-core/build/controllerTools.js:137:18)
        2024-05-22 12:40:47.408 - error: host.raspi4 Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
        2024-05-22 12:40:47.409 - error: host.raspi4 Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
        2024-05-22 12:40:47.409 - error: host.raspi4 Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
        2024-05-22 12:40:47.409 - error: host.raspi4 Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
        2024-05-22 12:40:47.409 - error: host.raspi4 Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
        2024-05-22 12:40:47.409 - error: host.raspi4 Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
        2024-05-22 12:40:47.409 - error: host.raspi4 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.sql/node_modules/@iobroker/adapter-core/build/index.js:19:27)
        2024-05-22 12:40:47.410 - error: host.raspi4 Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
        2024-05-22 12:40:47.410 - error: host.raspi4 Caught by controller[0]: Node.js v20.13.1
        2024-05-22 12:40:47.410 - error: host.raspi4 instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        iob diag
        Skript v.2024-04-21
        *** BASE SYSTEM ***
        Static hostname: raspi4
              Icon name: computer
                 Kernel: Linux 6.6.28+rpt-rpi-v8
           Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
        12:47:25 up 9 min,  2 users,  load average: 1.02, 0.77, 0.47
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                      Local time: Wed 2024-05-22 12:47:26 CEST
                  Universal time: Wed 2024-05-22 10:47:26 UTC
                        RTC time: n/a
                     NTP service: active
                 RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        maik
        HOME=/home/maik
        GROUPS=maik adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** Display-Server-Setup ***
        pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
        Try `pgrep -f' option to match against the complete command line.
        Display-Server: false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            8.2G        954M        6.5G        1.2M        847M        7.2G
        Swap:           104M          0B        104M
        Total:          8.3G        954M        6.6G
        Active iob-Instances:   8
                7809 M total memory
                 910 M used memory
                 915 M active memory
                 481 M inactive memory
                6220 M free memory
                  54 M buffer memory
                 753 M swap cache
                  99 M total swap
                   0 M used swap
                  99 M free swap
        top - 12:47:26 up 9 min,  2 users,  load average: 1.02, 0.77, 0.47
        Tasks: 177 total,   2 running, 175 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7809.0 total,   6219.2 free,    911.0 used,    808.3 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6898.1 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     781M  1.2M  780M   1% /run
        /dev/sda2      ext4      235G  6.1G  217G   3% /
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        /dev/sda1      vfat      510M   64M  447M  13% /boot/firmware
        tmpfs          tmpfs     781M     0  781M   0% /run/user/1000
        [Wed May 22 12:38:03 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B6:1B:80 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=eacfac28-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Wed May 22 12:38:06 2024] EXT4-fs (sda2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
        [Wed May 22 12:38:07 2024] EXT4-fs (sda2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET                                                  SOURCE      FSTYPE      OPTIONS
        /                                                       /dev/sda2   ext4        rw,noatime
        |-/sys                                                  sysfs       sysfs       rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security                                securityfs  securityfs  rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                                      cgroup2     cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore                                      pstore      pstore      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf                                         bpf         bpf         rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                                   debugfs     debugfs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing                                 tracefs     tracefs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config                                  configfs    configfs    rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections                            fusectl     fusectl     rw,nosuid,nodev,noexec,relatime
        |-/proc                                                 proc        proc        rw,relatime
        | `-/proc/sys/fs/binfmt_misc                            systemd-1   autofs      rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=4292
        |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc binfmt_misc rw,nosuid,nodev,noexec,relatime
        |-/dev                                                  udev        devtmpfs    rw,nosuid,relatime,size=3728000k,nr_inodes=932000,mode=755
        | |-/dev/pts                                            devpts      devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | |-/dev/shm                                            tmpfs       tmpfs       rw,nosuid,nodev
        | `-/dev/mqueue                                         mqueue      mqueue      rw,nosuid,nodev,noexec,relatime
        |-/run                                                  tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=799648k,mode=755
        | |-/run/lock                                           tmpfs       tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/credentials/systemd-sysctl.service             ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-sysusers.service           ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | |-/run/rpc_pipefs                                     sunrpc      rpc_pipefs  rw,relatime
        | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs       ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
        | `-/run/user/1000                                      tmpfs       tmpfs       rw,nosuid,nodev,relatime,size=799644k,nr_inodes=199911,mode=700,uid=1000,gid=1000
        `-/boot/firmware                                        /dev/sda1   vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.3G    /var/
        739M    /var/log
        719M    /var/log/journal/414d8e09672c402ba1be5faf8e41bcf0
        239M    /var/cache
        Archived and active journals take up 718.6M in the file system.
        /opt/iobroker/backups:
        52M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        341M    /opt/iobroker/iobroker-data/
        236M    /opt/iobroker/iobroker-data/files
        138M    /opt/iobroker/iobroker-data/files/javascript.admin
        118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.39d2b15b.js.map
        12M     /opt/iobroker/iobroker-data/objects.jsonl
        9.0M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.39d2b15b.js
        8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.13.1
        /usr/bin/node           v20.13.1
        /usr/bin/npm            10.5.2
        /usr/bin/npx            10.5.2
        /usr/bin/corepack       0.28.0
        nodejs:
         Installed: 20.13.1-1nodesource1
         Candidate: 20.13.1-1nodesource1
         Version table:
        *** 20.13.1-1nodesource1 1001
               500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
               100 /var/lib/dpkg/status
            20.13.0-1nodesource1 1001
            20.12.2-1nodesource1 1001
            20.12.1-1nodesource1 1001
            20.12.0-1nodesource1 1001
            20.11.1-1nodesource1 1001
            20.11.0-1nodesource1 1001
            20.10.0-1nodesource1 1001
            20.9.0-1nodesource1 1001
            20.8.1-1nodesource1 1001
            20.8.0-1nodesource1 1001
            20.7.0-1nodesource1 1001
            20.6.1-1nodesource1 1001
            20.6.0-1nodesource1 1001
            20.5.1-1nodesource1 1001
            20.5.0-1nodesource1 1001
            20.4.0-1nodesource1 1001
            20.3.1-1nodesource1 1001
            20.3.0-1nodesource1 1001
            20.2.0-1nodesource1 1001
            20.1.0-1nodesource1 1001
            20.0.0-1nodesource1 1001
            18.19.0+dfsg-6~deb12u1 500
            18.13.0+dfsg1-1 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  6.0.0
        admin:          6.17.11
        javascript:     8.3.1
        nodejs modules from github:     1
        `-- iobroker.yahoo-stock-market@0.0.6 (git+ssh://git@github.com/Newan/ioBroker.yahoo-stock-market.git#f0a85b1871286173cbc3922b9ed705d740643511)
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspi4                                   -  enabled, port: 80, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspi4                                   -  enabled
         system.adapter.daswetter.0              : daswetter             : raspi4                                   -  enabled
        + system.adapter.discovery.0              : discovery             : raspi4                                   -  enabled
        + system.adapter.javascript.0             : javascript            : raspi4                                   -  enabled
        + system.adapter.modbus.0                 : modbus                : raspi4                                   -  enabled
        + system.adapter.node-red.0               : node-red              : raspi4                                   -  enabled, port: 1880, bind: 0.0.0.0
         system.adapter.sql.0                    : sql                   : raspi4                                   -  enabled
         system.adapter.vis.0                    : vis                   : raspi4                                   -  enabled
        + system.adapter.web.0                    : web                   : raspi4                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.17.11  , installed 6.17.11
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "javascript"   : 8.3.1    , installed 8.3.1
        Controller "js-controller": 5.0.19   , installed 6.0.0
        Adapter    "modbus"       : 6.2.2    , installed 6.2.2
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "sql"          : 2.2.0    , installed 2.2.0
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Adapter    "yahoo-stock-market": 0.0.6, installed 0.0.6
        Objects and States
        Objects:        2375
        States:         2177
        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10094      882/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10099      882/iobroker.js-con
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1894       674/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:502             0.0.0.0:*               LISTEN      0          6443       703/./core/openplc
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       13387      1024/node-red
        tcp        0      0 127.0.0.1:43628         0.0.0.0:*               LISTEN      0          1936       703/./core/openplc
        tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      0          5614       703/./core/openplc
        tcp        0      0 0.0.0.0:44818           0.0.0.0:*               LISTEN      0          5616       703/./core/openplc
        tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          5621       659/python3
        tcp6       0      0 :::8888                 :::*                    LISTEN      0          6434       703/./core/openplc
        tcp6       0      0 :::22                   :::*                    LISTEN      0          1896       674/sshd: /usr/sbin
        tcp6       0      0 :::80                   :::*                    LISTEN      1001       13346      954/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8019       948/io.web.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1815       526/avahi-daemon: r
        udp        0      0 0.0.0.0:36702           0.0.0.0:*                           104        1817       526/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        1816       526/avahi-daemon: r
        udp6       0      0 :::52680                :::*                                104        1818       526/avahi-daemon: r
        2024-05-22 12:47:07.135  - error: host.raspi4 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
        2024-05-22 12:47:07.135  - error: host.raspi4 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
        2024-05-22 12:47:07.135  - error: host.raspi4 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
        2024-05-22 12:47:07.135  - error: host.raspi4 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
        2024-05-22 12:47:07.135  - error: host.raspi4 Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
        2024-05-22 12:47:07.135  - error: host.raspi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/node_modules/@iobroker/adapter-core/build/index.js:19:27)
        2024-05-22 12:47:07.135  - error: host.raspi4 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
        2024-05-22 12:47:07.136  - error: host.raspi4 Caught by controller[1]: Node.js v20.13.1
        2024-05-22 12:47:07.136  - error: host.raspi4 instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-05-22 12:47:39.012  - error: host.raspi4 Caught by controller[0]: /opt/iobroker/node_modules/iobroker.sql/node_modules/@iobroker/adapter-core/build/controllerTools.js:94
        2024-05-22 12:47:39.013  - error: host.raspi4 Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
        2024-05-22 12:47:39.014  - error: host.raspi4 Caught by controller[0]:     ^
        2024-05-22 12:47:39.014  - error: host.raspi4 Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
        2024-05-22 12:47:39.014  - error: host.raspi4 Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.sql/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:11)
        2024-05-22 12:47:39.014  - error: host.raspi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/node_modules/@iobroker/adapter-core/build/controllerTools.js:137:18)
        2024-05-22 12:47:39.015  - error: host.raspi4 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
        2024-05-22 12:47:39.015  - error: host.raspi4 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
        2024-05-22 12:47:39.015  - error: host.raspi4 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
        2024-05-22 12:47:39.015  - error: host.raspi4 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
        2024-05-22 12:47:39.016  - error: host.raspi4 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
        2024-05-22 12:47:39.016  - error: host.raspi4 Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
        2024-05-22 12:47:39.017  - error: host.raspi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.sql/node_modules/@iobroker/adapter-core/build/index.js:19:27)
        2024-05-22 12:47:39.017  - error: host.raspi4 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
        2024-05-22 12:47:39.017  - error: host.raspi4 Caught by controller[0]: Node.js v20.13.1
        2024-05-22 12:47:39.018  - error: host.raspi4 instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          Thomas Braun Most Active @mrjeschke last edited by
          @mrjeschke @foxriver76
          Bei mir auch ganz ähnliche Meldungen.
          Hab es aber über mein Handy angeschubst, daher Log Files später, wenn ich an einem gescheiten Terminal sitze.
          foxriver76 1 Reply Last reply Reply Quote -1
          • foxriver76
            foxriver76 Developer @Thomas Braun last edited by
            @thomas-braun mal bitte in opt/iobroker Den Befehl npm ls @iobroker/adapter-core ausführen und Ausgabe zeigen.
              Thomas Braun Most Active last edited by Thomas Braun
              @foxriver76
              echad@chet:/opt/iobroker $ npm ls @iobroker/adapter-core
              iobroker.inst@3.0.0 /opt/iobroker
              +-- iobroker.admin@6.17.11
              | +-- @iobroker/adapter-core@3.1.4
              | `-- @iobroker/socket-classes@1.5.0
              |   `-- @iobroker/adapter-core@3.1.4 deduped
              +-- iobroker.alexa2@3.26.5
              +-- iobroker.alias-manager@1.2.6
              | `-- @iobroker/adapter-core@2.6.9
              +-- iobroker.awtrix-light@1.2.0
              +-- iobroker.backitup@2.11.0
              +-- iobroker.ble@0.14.0
              +-- iobroker.cloud@5.0.1
              +-- iobroker.drops-weather@0.3.1 (git+ssh://git@github.com/inbux/ioBroker.drops-weather.git#608ed1fcbbde3f59b6a09f2f188b92823481ae90)
              +-- iobroker.firetv@2.1.0
              +-- iobroker.followthesun@0.5.0
              +-- iobroker.govee-app@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85)
              +-- iobroker.govee-local@0.2.6
              +-- iobroker.history@3.0.1
              +-- iobroker.ical@1.15.0
              +-- iobroker.iceroad@1.2.1
              +-- iobroker.iot@3.3.0
              +-- iobroker.javascript@8.3.1
              +-- iobroker.js-controller@6.0.0
              +-- iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#0d037c0c9a025b193546f881f747c8f998bfc724)
              +-- iobroker.mihome-cloud@0.1.1
              +-- iobroker.mihome-vacuum@4.2.0
              +-- iobroker.mihome@1.4.0
              +-- iobroker.mqtt@5.2.0
              +-- iobroker.nina@0.0.26
              +-- iobroker.nuki-extended@2.7.0
              +-- iobroker.nut@1.6.0
              +-- iobroker.opendtu@1.0.1
              +-- iobroker.openweathermap@1.0.4
              +-- iobroker.parcel@0.2.7 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#a9656c8ef3d0e85a75d911c9392440e98e13b958)
              +-- iobroker.rpi2@1.3.2
              +-- iobroker.sainlogic@0.10.5
              +-- iobroker.samsung_tizen@1.1.0
              +-- iobroker.samsung@0.5.11
              +-- iobroker.socketio@6.7.0
              +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
              +-- iobroker.tado@0.5.4
              +-- iobroker.tankerkoenig@3.4.0
              +-- iobroker.tr-064@4.3.0
              +-- iobroker.tradfri@3.1.3
              +-- iobroker.trashschedule@3.3.0
              +-- iobroker.tuya@3.15.0
              +-- iobroker.vis-2@2.9.63
              +-- iobroker.weather-warnings@0.6.7
              +-- iobroker.web@6.2.5
              | +-- @iobroker/adapter-core@3.1.4 deduped
              | +-- iobroker.simple-api@2.7.2
              | +-- iobroker.socketio@6.6.1
              | `-- iobroker.ws@2.5.11
              +-- iobroker.whatsapp-cmb@0.2.3
              +-- iobroker.ws@2.6.1
              `-- iobroker.zigbee@1.10.3
                `-- @iobroker/dm-utils@0.1.9
              Die Adapter mit github-Installationen sorgen für den Trouble, scheint mir. Die stehen auch in der Instanzen-Übersicht auf Rot.
              Sind aber auch 'ordentlich installierte / aus dem Beta-Repo' Adapter auf Rot.
              • foxriver76
                @thomas-braun Ja das Problem ist, dass wir adapter-core 2.6.11 oder 3.1.4 brauchen. Leider ist wohl npm mittlerweile ziemlich faul und da kein adapter ausdrücklich 2.6.11 required sondern z. b. mindestens 2.6.8 wird npm das wohl nur bei einem neu installieren eines Packages anfassen. Müssen wir mal schauen wie wir das am besten angehen.
                • mcm1957
                  mcm1957 @foxriver76 last edited by mcm1957
                  @foxriver76 said in Alpha Test js-controller Kiera (v6.0):
                  der sql adapter benutzt noch adapter-core 3.0.3:
                  "@iobroker/adapter-core": "^3.0.3"
                  Ist für js-controller nicht adapter-core 3.1.4 erforderlich?
                  Edit:
                  OK, warst schneller 🙂
                  foxriver76 1 Reply Last reply Reply Quote 1
                  • foxriver76
                    foxriver76 Developer @mcm1957 last edited by
                    @mcm1957 im Endeffekt sind die 3er egal, da alle mit ^3.x.x spezifiziert erlauben sie das Upgrade auf 3.1.4 und der Controller required das explizit, damit werden die alle hochgezogen, aber die 2er bleiben leider problematisch.. da wir nur entweder 2 forcieren können hoch zu ziehen oder 3, evtl wird es dann noch einen shim im Controller brauchen damit die alten Versionen nicht crashen.
                    • mcm1957
                      @foxriver76
                      sql ist da aber eher der Gegenbeweis. Da steht ^3.0.3 drinnen. Und trotzdem crashed es.
                      • foxriver76
                        foxriver76 Developer @mcm1957 last edited by foxriver76
                        @mcm1957 ne die offizielle version von sql hat 2.6.0 daher crasht es https://www.npmjs.com/package/iobroker.sql?activeTab=code
                        Was auf GitHub steht hat keine Auswirkung wenn es nicht von GitHub installiert wurde
                        • Feuersturm
                          Feuersturm @foxriver76 last edited by
                          @foxriver76 Ich habe meine System gerade einmal auf nodejs 20 (über iob nodejs-update 20 aktualisiert, da du ganz am Anfang geschrieben hattest, dass die Empfehlung jetzt nodejs20 ist.
                          Wenn ich jetzt den js-controller installieren will kommt folgende Fehlermeldung
                          proxmox@ioBrokerTestsystem:~$ iob stop
                          proxmox@ioBrokerTestsystem:~$ cd /opt/iobroker/
                          proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next --omit=dev
                          npm ERR! code EBADENGINE
                          npm ERR! engine Unsupported engine
                          npm ERR! engine Not compatible with your version of node/npm: @appland/appmap-agent-js@13.9.1
                          npm ERR! notsup Not compatible with your version of node/npm: @appland/appmap-agent-js@13.9.1
                          npm ERR! notsup Required: {"node":"14.x.x || 16.x.x || 17.x.x || 18.x.x || 19.x.x"}
                          npm ERR! notsup Actual:   {"npm":"10.5.2","node":"v20.13.1"}
                          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-22T11_53_14_435Z-debug-0.log
                          iob diag:
                          Skript v.2024-04-21
                          *** BASE SYSTEM ***
                          Static hostname: ioBrokerTestsystem
                                Icon name: computer-container
                                  Chassis: container
                           Virtualization: lxc
                          Operating System: Ubuntu 22.04.4 LTS
                                   Kernel: Linux 6.5.13-1-pve
                             Architecture: x86-64
                          model name      : Intel(R) Celeron(R) CPU  N3150  @ 1.60GHz
                          Docker          : false
                          Virtualization  : lxc
                          Kernel          : x86_64
                          Userland        : 64 bit
                          13:58:17 up 10:47,  2 users,  load average: 3.28, 2.65, 2.81
                          CPU threads: 4
                                        Local time: Wed 2024-05-22 13:58:18 CEST
                                    Universal time: Wed 2024-05-22 11:58:18 UTC
                                          RTC time: n/a
                                       NTP service: inactive
                                   RTC in local TZ: no
                          proxmox
                          HOME=/home/proxmox
                          GROUPS=proxmox sudo iobroker
                          js-controller is not running
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            6.0G        313M        4.6G        0.0K        1.1G        5.7G
                          Swap:           1.5G        0.0K        1.5G
                          Total:          7.5G        313M        6.1G
                          Active iob-Instances:   1
                                  6000 M total memory
                                   313 M used memory
                                   258 M active memory
                                   910 M inactive memory
                                  4600 M free memory
                                     0 M buffer memory
                                  1086 M swap cache
                                  1512 M total swap
                                     0 M used swap
                                  1511 M free swap
                          top - 13:58:18 up 10:47,  2 users,  load average: 3.28, 2.65, 2.81
                          Tasks:  37 total,   1 running,  36 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  4.8 us, 14.3 sy,  0.0 ni, 81.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   6000.0 total,   4599.5 free,    313.8 used,   1086.8 buff/cache
                          MiB Swap:   1512.0 total,   1512.0 free,      0.0 used.   5686.2 avail Mem
                           UNIT                   LOAD   ACTIVE SUB    DESCRIPTION
                          * run-rpc_pipefs.mount   loaded failed failed RPC Pipe File System
                          * sys-kernel-debug.mount loaded failed failed Kernel Debug File System
                          * iobroker.service       loaded failed failed ioBroker Server
                          LOAD   = Reflects whether the unit definition was properly loaded.
                          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                          SUB    = The low-level unit activation state, values depend on unit type.
                          3 loaded units listed.
                          *** FILESYSTEM ***
                          Filesystem                          Type   Size  Used Avail Use% Mounted on
                          /dev/mapper/data2-vm--3108--disk--1 ext4    20G  9.3G  9.3G  51% /
                          none                                tmpfs  492K  4.0K  488K   1% /dev
                          tmpfs                               tmpfs  7.7G     0  7.7G   0% /dev/shm
                          tmpfs                               tmpfs  3.1G  156K  3.1G   1% /run
                          tmpfs                               tmpfs  5.0M     0  5.0M   0% /run/lock
                          tmpfs                               tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-sysusers.service
                          tmpfs                               tmpfs  1.6G     0  1.6G   0% /run/user/1001
                          dmesg: read kernel buffer failed: Operation not permitted
                          /                                             /dev/mapper/data2-vm--3108--disk--1 ext4       rw,relatime,stripe=16
                          |-/run                                        tmpfs                               tmpfs      rw,nosuid,nodev,size=3206044k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                          | |-/run/lock                                 tmpfs                               tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                          | |-/run/credentials/systemd-sysusers.service tmpfs                               tmpfs      ro,nosuid,nodev,noexec,relatime,size=1024k,nr_inodes=1024,mode=700,uid=100000,gid=100000,inode64
                          | `-/run/user/1001                            tmpfs                               tmpfs      rw,nosuid,nodev,relatime,size=1603020k,nr_inodes=400755,mode=700,uid=101001,gid=101001,inode64
                          |-/dev                                        none                                tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                          | |-/dev/shm                                  tmpfs                               tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
                          | |-/dev/full                                 udev[/full]                         devtmpfs   rw,nosuid,relatime,size=7981392k,nr_inodes=1995348,mode=755,inode64
                          | |-/dev/null                                 udev[/null]                         devtmpfs   rw,nosuid,relatime,size=7981392k,nr_inodes=1995348,mode=755,inode64
                          | |-/dev/random                               udev[/random]                       devtmpfs   rw,nosuid,relatime,size=7981392k,nr_inodes=1995348,mode=755,inode64
                          | |-/dev/tty                                  udev[/tty]                          devtmpfs   rw,nosuid,relatime,size=7981392k,nr_inodes=1995348,mode=755,inode64
                          | |-/dev/urandom                              udev[/urandom]                      devtmpfs   rw,nosuid,relatime,size=7981392k,nr_inodes=1995348,mode=755,inode64
                          | |-/dev/zero                                 udev[/zero]                         devtmpfs   rw,nosuid,relatime,size=7981392k,nr_inodes=1995348,mode=755,inode64
                          | |-/dev/pts                                  devpts                              devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                          | |-/dev/ptmx                                 devpts[/ptmx]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                          | |-/dev/console                              devpts[/0]                          devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                          | |-/dev/tty1                                 devpts[/1]                          devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                          | `-/dev/tty2                                 devpts[/2]                          devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                          |-/proc                                       proc                                proc       rw,nosuid,nodev,noexec,relatime
                          | |-/proc/sys                                 proc[/sys]                          proc       ro,relatime
                          | | |-/proc/sys/net                           proc[/sys/net]                      proc       rw,nosuid,nodev,noexec,relatime
                          | | `-/proc/sys/kernel/random/boot_id         none[/.lxc-boot-id]                 tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                          | |-/proc/sysrq-trigger                       proc[/sysrq-trigger]                proc       ro,relatime
                          | |-/proc/cpuinfo                             lxcfs[/proc/cpuinfo]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/diskstats                           lxcfs[/proc/diskstats]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/loadavg                             lxcfs[/proc/loadavg]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/meminfo                             lxcfs[/proc/meminfo]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/slabinfo                            lxcfs[/proc/slabinfo]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/stat                                lxcfs[/proc/stat]                   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | |-/proc/swaps                               lxcfs[/proc/swaps]                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          | `-/proc/uptime                              lxcfs[/proc/uptime]                 fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          `-/sys                                        sysfs                               sysfs      ro,nosuid,nodev,noexec,relatime
                           |-/sys/devices/virtual/net                  sysfs[/devices/virtual/net]         sysfs      rw,nosuid,nodev,noexec,relatime
                           |-/sys/fs/cgroup                            none                                cgroup2    rw,nosuid,nodev,noexec,relatime
                           `-/sys/devices/system/cpu                   lxcfs[/sys/devices/system/cpu]      fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                          /var:
                          1.6G    /var/
                          698M    /var/log
                          689M    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
                          507M    /var/lib
                          Archived and active journals take up 48.0M in the file system.
                          109M    /opt/iobroker/backups/
                          1.3G    /opt/iobroker/iobroker-data/
                          1.1G    /opt/iobroker/iobroker-data/files
                          223M    /opt/iobroker/iobroker-data/files/vis
                          215M    /opt/iobroker/iobroker-data/files/vis/widgets
                          203M    /opt/iobroker/iobroker-data/files/vis-2
                          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                          35M     /opt/iobroker/iobroker-data/files/device-manager.admin/build/tab.js.map
                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                          26M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.8947f24d.js.map
                          USB-Devices by-id:
                          /usr/bin/npm            10.5.2
                          /usr/bin/npx            10.5.2
                          nodejs:
                           Version table:
                                 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                              12.22.9~dfsg-1ubuntu3.5 500
                                 500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                                 500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                              12.22.9~dfsg-1ubuntu3 500
                                 500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                          Errors in npm tree:
                          ioBroker Status
                          iobroker is not running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                          js-controller:  5.0.19
                          admin:          6.17.11
                          javascript:     8.3.1
                          nodejs modules from github:     5
                          +-- iobroker.fully-tablet-control@0.3.4-0 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#7117121d4e659a2ddf69feb2698a4014588a5f94)
                          +-- iobroker.rainbird@0.2.3 (git+ssh://git@github.com/StrathCole/ioBroker.rainbird.git#0caa24dcbb11024865ff9161c6f6bb5e6db6a9ce)
                          +-- iobroker.samsung-community@0.5.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung-community.git#dd5c173cf9056c3ab9bd45006f17bb639d9ff5f8)
                          | +-- samsungtv@0.0.0 (git+ssh://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                          +-- iobroker.valloxmv@1.2.0 (git+ssh://git@github.com/hacki11/ioBroker.valloxmv.git#51ef16846b53016d658f1df5afa0cf42296000be)
                          Adapter State
                           system.adapter.admin.0                  : admin                 : ioBrokerTestsystem                       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                           system.adapter.backitup.0               : backitup              : ioBrokerTestsystem                       -  enabled
                           system.adapter.benchmark.0              : benchmark             : ioBrokerTestsystem                       - disabled
                           system.adapter.daswetter.0              : daswetter             : ioBrokerTestsystem                       -  enabled
                           system.adapter.device-manager.0         : device-manager        : ioBrokerTestsystem                       -  enabled
                           system.adapter.device-watcher.0         : device-watcher        : ioBrokerTestsystem                       - disabled
                           system.adapter.devices.0                : devices               : ioBrokerTestsystem                       - disabled
                           system.adapter.discovery.0              : discovery             : ioBrokerNew                              -  enabled
                           system.adapter.discovery.1              : discovery             : ioBrokerTestsystem                       -  enabled
                           system.adapter.dwd.0                    : dwd                   : ioBrokerTestsystem                       -  enabled
                           system.adapter.echarts.0                : echarts               : ioBrokerTestsystem                       -  enabled
                           system.adapter.fritzbox.0               : fritzbox              : ioBrokerTestsystem                       -  enabled
                           system.adapter.fully-tablet-control.0   : fully-tablet-control  : ioBrokerTestsystem                       - disabled
                           system.adapter.history.1                : history               : ioBrokerNew                              - disabled
                           system.adapter.hm-rega.0                : hm-rega               : ioBrokerTestsystem                       -  enabled
                           system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerTestsystem                       -  enabled, port: 0
                           system.adapter.hue.0                    : hue                   : ioBrokerTestsystem                       -  enabled, port: 443
                           system.adapter.ical.0                   : ical                  : ioBrokerTestsystem                       - disabled
                           system.adapter.ical.1                   : ical                  : ioBrokerTestsystem                       - disabled
                           system.adapter.ical.2                   : ical                  : ioBrokerTestsystem                       - disabled
                           system.adapter.ical.3                   : ical                  : ioBrokerTestsystem                       - disabled
                           system.adapter.ical.4                   : ical                  : ioBrokerTestsystem                       - disabled
                           system.adapter.ical.5                   : ical                  : ioBrokerTestsystem                       -  enabled
                           system.adapter.icons-material-png.0     : icons-material-png    : ioBrokerTestsystem                       - disabled
                           system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBrokerTestsystem                       - disabled
                           system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBrokerTestsystem                       - disabled
                           system.adapter.influxdb.0               : influxdb              : ioBrokerTestsystem                       -  enabled, port: 8086
                           system.adapter.javascript.0             : javascript            : ioBrokerTestsystem                       -  enabled
                           system.adapter.mqtt.0                   : mqtt                  : ioBrokerTestsystem                       - disabled, port: 1883, bind: 0.0.0.0
                           system.adapter.nina.0                   : nina                  : ioBrokerTestsystem                       -  enabled
                           system.adapter.openweathermap.0         : openweathermap        : ioBrokerTestsystem                       -  enabled
                           system.adapter.proxmox.0                : proxmox               : ioBrokerTestsystem                       -  enabled, port: 8006
                           system.adapter.rainbird.0               : rainbird              : ioBrokerTestsystem                       - disabled
                           system.adapter.samsung-community.0      : samsung-community     : ioBrokerTestsystem                       - disabled
                           system.adapter.sayit.0                  : sayit                 : ioBrokerTestsystem                       - disabled, port: 0
                           system.adapter.scenes.0                 : scenes                : ioBrokerTestsystem                       -  enabled
                           system.adapter.scheduler.0              : scheduler             : ioBrokerTestsystem                       - disabled
                           system.adapter.simple-api.0             : simple-api            : ioBrokerTestsystem                       - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                           system.adapter.socketio.0               : socketio              : ioBrokerTestsystem                       - disabled, port: 8084, bind: 192.168.178.77, run as: admin
                           system.adapter.spotify-premium.0        : spotify-premium       : ioBrokerTestsystem                       - disabled
                           system.adapter.sql.0                    : sql                   : ioBrokerNew                              - disabled, port: 3306
                           system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerTestsystem                       -  enabled
                           system.adapter.telegram.0               : telegram              : ioBrokerTestsystem                       - disabled, port: 8443, bind: 0.0.0.0
                           system.adapter.tr-064.0                 : tr-064                : ioBrokerTestsystem                       -  enabled
                           system.adapter.trashschedule.0          : trashschedule         : ioBrokerTestsystem                       -  enabled
                           system.adapter.unifi.0                  : unifi                 : ioBrokerTestsystem                       -  enabled
                           system.adapter.valloxmv.0               : valloxmv              : ioBrokerTestsystem                       - disabled, port: 80
                           system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBrokerTestsystem                       - disabled
                           system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBrokerTestsystem                       - disabled
                           system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBrokerTestsystem                       - disabled
                           system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBrokerTestsystem                       - disabled
                           system.adapter.vis-2.0                  : vis-2                 : ioBrokerTestsystem                       -  enabled
                           system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBrokerTestsystem                       - disabled
                           system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBrokerTestsystem                       -  enabled
                           system.adapter.vis-history.0            : vis-history           : ioBrokerTestsystem                       - disabled
                           system.adapter.vis-inventwo.0           : vis-inventwo          : ioBrokerTestsystem                       -  enabled
                           system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBrokerTestsystem                       - disabled
                           system.adapter.vis-justgage.0           : vis-justgage          : ioBrokerTestsystem                       - disabled
                           system.adapter.vis-map.0                : vis-map               : ioBrokerTestsystem                       - disabled
                           system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBrokerTestsystem                       - disabled
                           system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBrokerTestsystem                       - disabled
                           system.adapter.vis.0                    : vis                   : ioBrokerTestsystem                       -  enabled
                           system.adapter.web.0                    : web                   : ioBrokerTestsystem                       -  enabled, port: 8082, bind: 192.168.178.77, run as: admin
                           system.adapter.worx.0                   : worx                  : ioBrokerTestsystem                       - disabled
                          + instance is alive
                          Adapter    "benchmark"    : 1.2.0    , installed 1.2.0
                          Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                          Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                          Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                          Adapter    "hue"          : 3.11.0   , installed 3.11.0
                          Adapter    "ical"         : 1.15.0   , installed 1.15.0
                          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                          Adapter    "nina"         : 0.0.26   , installed 0.0.26
                          Adapter    "openweathermap": 1.0.4   , installed 1.0.4
                          Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                          Adapter    "rainbird"     : 0.2.2    , installed 0.2.3
                          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                          Adapter    "scenes"       : 3.0.4    , installed 3.0.4
                          Adapter    "scheduler"    : 1.3.12   , installed 1.3.12
                          Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
                          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                          Adapter    "telegram"     : 3.2.1    , installed 3.2.1
                          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                          Adapter    "valloxmv"     : 1.2.0    , installed 1.2.0
                          Adapter    "vis-2"        : 2.9.63   , installed 2.9.63
                          Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
                          Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
                          Adapter    "vis-2-widgets-jaeger-design": 1.1.23, installed 1.1.23
                          Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
                          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                          Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
                          Adapter    "worx"         : 3.0.2    , installed 3.0.2
                          Objects and States
                          Objects:        12986
                          States:         11386
                          Hit:1 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
                          Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                          Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          17872762   300/master
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17873349   1/init
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17872599   130/sshd: /usr/sbin
                          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        17870806   95/systemd-resolved
                          tcp6       0      0 :::3000                 :::*                    LISTEN      108        17876054   113/grafana-server
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          17873351   1/init
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          17872610   130/sshd: /usr/sbin
                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          17872763   300/master
                          udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        17870805   95/systemd-resolved
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17873350   1/init
                          udp6       0      0 :::111                  :::*                                0          17873352   1/init
                          • mcm1957
                            @foxriver76
                            OK, sorry - mein Fehler.
                            Ich bin davon ausgegangen dass jemand der js-controller 6 alpha installiert auch die latest Versionen der anderern Adapter installiert hat.
                            Offenbar ist der SQL Adapter auf GH um einiges weiter als der npm / latest / stable Stand 😭
                            Alles klar soweit.
                            • foxriver76
                              @mcm1957 Ja, es ist echt nur auf GitHub mit 3.x sql latest und stable ist 2 jahre alt
                              • foxriver76
                                foxriver76 Developer @Feuersturm last edited by
                                @feuersturm sagte in Alpha Test js-controller Kiera (v6.0):
                                das dürfte nicht vom controller kommen, mach mal npm ls @appland/appmap-agent-js in /opt/iobroker
                                • Feuersturm
                                  @foxriver76 Das ist die Ausgabe
                                  proxmox@ioBrokerTestsystem:/opt/iobroker$ npm ls @appland/appmap-agent-js
                                  iobroker.inst@2.0.3 /opt/iobroker
                                  `-- iobroker.device-manager@0.0.3
                                    `-- @appland/appmap-agent-js@13.9.1
                                  • foxriver76
                                    @feuersturm die inkompatible dependency bringt der device-manager Adapter mit, gerne dort mal ein Issue eröffnen. Ansonsten kannst du natürlich auch gerne mit node v18 testen.
                                    • Feuersturm
                                      @foxriver76 Danke. Issue https://github.com/ioBroker/ioBroker.device-manager/issues/42 wurde beim device-manager erstellt. Dann mach ich mal ein downgrade 🙂
                                      Feuer-sturm created this issue in ioBroker/ioBroker.device-manager
                                      closed Not compatible with your version of node/npm: @appland/appmap-agent-js@13.9.1 #42
                                      • Feuersturm
                                        @foxriver76 Nach dem Downgrade auf nodejs18 ging die Installation vom js-controller6 ohne Probleme.
                                        Beim Start wirft der Admin Adapter 6.17.11 fehler und kann nicht gestartet werden.
                                        2024-05-22 14:28:04.907  - info: host.ioBrokerTestsystem iobroker.js-controller version 6.0.0 js-controller starting
                                        2024-05-22 14:28:04.921  - info: host.ioBrokerTestsystem Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                        2024-05-22 14:28:04.925  - info: host.ioBrokerTestsystem hostname: ioBrokerTestsystem, node: v18.20.3
                                        2024-05-22 14:28:04.929  - info: host.ioBrokerTestsystem ip addresses: 192.168.178.77 fe80::f854:cfff:fe5f:6c25
                                        2024-05-22 14:28:07.666  - info: host.ioBrokerTestsystem connected to Objects and States
                                        2024-05-22 14:28:07.713  - info: host.ioBrokerTestsystem added notifications configuration of host
                                        2024-05-22 14:28:08.866  - info: host.ioBrokerTestsystem 64 instances found
                                        2024-05-22 14:28:08.975  - info: host.ioBrokerTestsystem starting 27 instances
                                        2024-05-22 14:28:09.740  - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.nodeCurrent"
                                        2024-05-22 14:28:09.822  - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.nodeNewest"
                                        2024-05-22 14:28:09.893  - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.nodeNewestNext"
                                        2024-05-22 14:28:09.929  - info: host.ioBrokerTestsystem instance system.adapter.admin.0 started with pid 19670
                                        2024-05-22 14:28:10.082  - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.npmCurrent"
                                        2024-05-22 14:28:10.108  - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.npmNewest"
                                        2024-05-22 14:28:10.126  - info: host.ioBrokerTestsystem Delete state "system.host.ioBrokerTestsystem.versions.npmNewestNext"
                                        2024-05-22 14:28:10.137  - info: host.ioBrokerTestsystem Some obsolete host states deleted.
                                        2024-05-22 14:28:13.695  - info: host.ioBrokerTestsystem instance system.adapter.influxdb.0 started with pid 19677
                                        2024-05-22 14:28:16.342  - info: admin.0 (19670) starting. Version 6.17.11 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.3, js-controller: 6.0.0
                                        2024-05-22 14:28:16.436  - info: admin.0 (19670) requesting all objects
                                        2024-05-22 14:28:20.148  - info: admin.0 (19670) received all objects
                                        2024-05-22 14:28:20.331  - info: host.ioBrokerTestsystem instance system.adapter.javascript.0 started with pid 19708
                                        2024-05-22 14:28:20.749  - error: admin.0 (19670) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2024-05-22 14:28:20.753  - error: admin.0 (19670) unhandled promise rejection: utils.commonTools.session is not a function
                                        2024-05-22 14:28:20.768  - error: admin.0 (19670) TypeError: utils.commonTools.session is not a function
                                            at Web.#init (/opt/iobroker/node_modules/iobroker.admin/build-backend/lib/web.js:451:50)
                                            at new Web (/opt/iobroker/node_modules/iobroker.admin/build-backend/lib/web.js:167:19)
                                            at /opt/iobroker/node_modules/iobroker.admin/build-backend/main.js:1289:46
                                            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build-backend/main.js:1136:25)
                                            at processImmediate (node:internal/timers:478:21)
                                        2024-05-22 14:28:20.772  - error: admin.0 (19670) utils.commonTools.session is not a function
                                        2024-05-22 14:28:21.208  - info: admin.0 (19670) terminating http server on port 8081
                                        2024-05-22 14:28:21.215  - info: admin.0 (19670) terminating
                                        2024-05-22 14:28:21.221  - warn: admin.0 (19670) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2024-05-22 14:28:21.237  - info: admin.0 (19670) Request actual repository...
                                        2024-05-22 14:28:21.738  - info: admin.0 (19670) terminating
                                        2024-05-22 14:28:22.423  - warn: admin.0 (19670) redis get admin.0.info.newsLastId, error - Connection is closed.
                                        2024-05-22 14:28:22.445  - warn: admin.0 (19670) get state error: Connection is closed.
                                        2024-05-22 14:28:22.518  - warn: admin.0 (19670) get state error: Connection is closed.
                                        2024-05-22 14:28:22.526  - warn: admin.0 (19670) get state error: Connection is closed.
                                        2024-05-22 14:28:22.530  - warn: admin.0 (19670) get state error: Connection is closed.
                                        2024-05-22 14:28:22.534  - warn: admin.0 (19670) get state error: Connection is closed.
                                        2024-05-22 14:28:22.538  - warn: admin.0 (19670) get state error: Connection is closed.
                                        2024-05-22 14:28:22.594  - warn: admin.0 (19670) Cannot check node.js/npm version
                                        2024-05-22 14:28:22.981  - error: host.ioBrokerTestsystem Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                        2024-05-22 14:28:22.986  - error: host.ioBrokerTestsystem Caught by controller[0]: TypeError: utils.commonTools.session is not a function
                                        2024-05-22 14:28:22.992  - error: host.ioBrokerTestsystem Caught by controller[0]:     at Web.#init (/opt/iobroker/node_modules/iobroker.admin/build-backend/lib/web.js:451:50)
                                        2024-05-22 14:28:22.997  - error: host.ioBrokerTestsystem Caught by controller[0]:     at new Web (/opt/iobroker/node_modules/iobroker.admin/build-backend/lib/web.js:167:19)
                                        2024-05-22 14:28:23.001  - error: host.ioBrokerTestsystem Caught by controller[0]:     at /opt/iobroker/node_modules/iobroker.admin/build-backend/main.js:1289:46
                                        2024-05-22 14:28:23.007  - error: host.ioBrokerTestsystem Caught by controller[0]:     at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.admin/build-backend/main.js:1136:25)
                                        2024-05-22 14:28:23.011  - error: host.ioBrokerTestsystem Caught by controller[0]:     at processImmediate (node:internal/timers:478:21)
                                        2024-05-22 14:28:23.015  - error: host.ioBrokerTestsystem instance system.adapter.admin.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        • mcm1957
                                          mcm1957 @Feuersturm last edited by
                                          @feuersturm said in Alpha Test js-controller Kiera (v6.0):
                                          Da muss der device-manager ev. intensiver angepasst werden. Das Repo von appmap-agent-js wurde archiviert und auf npm ist das package nicht mehr via Suche zu finden.
                                          https://github.com/getappmap/appmap-agent-js
                                          Ist aber für js-controlelr 6 irrelevant.
                                            sigi234 Forum Testing Most Active @foxriver76 last edited by sigi234
                                            @foxriver76 sagte in Alpha Test js-controller Kiera (v6.0):
                                            Windows
                                            Generell muss das Update manuell via npm installiert werden.
                                            Hierzu im ioBroker-Verzeichnis nach stoppen des ioBroker den Befehl npm i iobroker.js-controller@next --omit=dev ausführen.
                                            nach dem installieren startet der IOB nicht, er beendet sich immer automatisch.
                                            ***               Welcome to ioBroker.                 ***
                                            ***     Type 'iob help' for list of instructions.      ***
                                            ***                For more help see                   ***
                                            ***     https://github.com/ioBroker/ioBroker.docs      ***
                                            Your environment has been set up for using Node.js 18.20.3 (x64) and npm.
                                            C:\Test>npm ls @iobroker/adapter-core
                                            iobroker.inst@3.0.0 C:\Test
                                            +-- iobroker.admin@6.13.16
                                            +-- iobroker.discovery@4.4.0
                                            `-- iobroker.js-controller@6.0.1-alpha.0-20240522-f267270b9
                                            C:\Test>
                                            Edit:
                                            Bin wieder auf Version 5.0.19 , alles läuft wieder.
                                            Gaspode 1 Reply Last reply Reply Quote 0
                                            alpha js-controller kiera test
                                            20
                                            234
                                            43237
