    4. Keine Updates / Fehlende Adapter Ansicht
    • Yoda
      Yoda @Thomas Braun last edited by Homoran
      @thomas-braun hatte es nochmal gemacht nun ;
      Skript v.2024-04-21
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       11:10:06 up 5 days, 16:27,  2 users,  load average: 1.49, 1.14, 1.19
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Wed 2024-05-22 11:10:06 CEST
                 Universal time: Wed 2024-05-22 09:10:06 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           3.8G        2.1G        804M        100M        907M        1.4G
      Swap:           99M         16M         83M
      Total:         3.9G        2.1G        887M
      Active iob-Instances:   31
               3838 M total memory
               2127 M used memory
                429 M active memory
               2418 M inactive memory
                804 M free memory
                266 M buffer memory
                641 M swap cache
                 99 M total swap
                 16 M used swap
                 83 M free swap
      top - 11:10:06 up 5 days, 16:27,  2 users,  load average: 1.49, 1.14, 1.19
      Tasks: 170 total,   2 running, 168 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  7.1 us,  4.3 sy,  0.0 ni, 88.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3838.7 total,    804.0 free,   2126.7 used,    908.1 buff/cache
      MiB Swap:    100.0 total,     83.2 free,     16.8 used.   1447.2 avail Mem
      *** FAILED SERVICES ***
        UNIT            LOAD   ACTIVE SUB    DESCRIPTION
      * lightdm.service loaded failed failed Light Display Manager
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4       59G   22G   35G  40% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G   16K  1.9G   1% /dev/shm
      tmpfs          tmpfs     1.9G  113M  1.8G   6% /run
      tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      [Thu May 16 18:42:37 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:B2:75:50 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=98ea7740-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Thu May 16 18:42:38 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Thu May 16 18:42:38 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Thu May 16 18:42:39 2024] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Thu May 16 18:42:39 2024] EXT4-fs (mmcblk0p2): 4 orphan inodes deleted
      [Thu May 16 18:42:39 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Thu May 16 18:42:39 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Thu May 16 18:42:39 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Thu May 16 18:42:41 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET                                SOURCE         FSTYPE      OPTIONS
      /                                     /dev/mmcblk0p2 ext4        rw,noatime
      |-/dev                                devtmpfs       devtmpfs    rw,relatime,size=1800568k,nr_inodes=84157,mode=755
      | |-/dev/shm                          tmpfs          tmpfs       rw,nosuid,nodev
      | |-/dev/pts                          devpts         devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue                       mqueue         mqueue      rw,relatime
      |-/sys                                sysfs          sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security              securityfs     securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                    tmpfs          tmpfs       ro,nosuid,nodev,noexec,mode=755
      | | |-/sys/fs/cgroup/unified          cgroup2        cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate
      | | |-/sys/fs/cgroup/systemd          cgroup         cgroup      rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
      | | |-/sys/fs/cgroup/pids             cgroup         cgroup      rw,nosuid,nodev,noexec,relatime,pids
      | | |-/sys/fs/cgroup/net_cls,net_prio cgroup         cgroup      rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
      | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup         cgroup      rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
      | | |-/sys/fs/cgroup/perf_event       cgroup         cgroup      rw,nosuid,nodev,noexec,relatime,perf_event
      | | |-/sys/fs/cgroup/blkio            cgroup         cgroup      rw,nosuid,nodev,noexec,relatime,blkio
      | | |-/sys/fs/cgroup/freezer          cgroup         cgroup      rw,nosuid,nodev,noexec,relatime,freezer
      | | |-/sys/fs/cgroup/cpuset           cgroup         cgroup      rw,nosuid,nodev,noexec,relatime,cpuset
      | | `-/sys/fs/cgroup/devices          cgroup         cgroup      rw,nosuid,nodev,noexec,relatime,devices
      | |-/sys/fs/bpf                       none           bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                 debugfs        debugfs     rw,relatime
      | `-/sys/kernel/config                configfs       configfs    rw,relatime
      |-/proc                               proc           proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc          systemd-1      autofs      rw,relatime,fd=40,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |   `-/proc/sys/fs/binfmt_misc        binfmt_misc    binfmt_misc rw,relatime
      |-/run                                tmpfs          tmpfs       rw,nosuid,nodev,mode=755
      | |-/run/lock                         tmpfs          tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/rpc_pipefs                   sunrpc         rpc_pipefs  rw,relatime
      | `-/run/user/1000                    tmpfs          tmpfs       rw,nosuid,nodev,relatime,size=393084k,mode=700,uid=1000,gid=1000
      `-/boot                               /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.5G    /var/
      2.2G    /var/cache
      2.1G    /var/cache/apt/archives
      2.1G    /var/cache/apt
      144M    /var/lib
      Archived and active journals take up 112.0M in the file system.
      /opt/iobroker/backups:
      365M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      823M    /opt/iobroker/iobroker-data/
      607M    /opt/iobroker/iobroker-data/files
      179M    /opt/iobroker/iobroker-data/files/vis-2
      119M    /opt/iobroker/iobroker-data/backup-objects
      81M     /opt/iobroker/iobroker-data/files/vis-2/static
      44M     /opt/iobroker/iobroker-data/states.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2153973-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.12
      admin:          6.13.16
      javascript:     7.8.0
      nodejs modules from github:     3
      | +-- onvif@0.7.0 (git+ssh://git@github.com/agsh/onvif.git#74c21e63f4f8c3db19c5e529842af361050138cf)
      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
      `-- iobroker.zendure-solarflow@1.6.1 (git+ssh://git@github.com/nograx/ioBroker.zendure-solarflow.git#b56b690481e55f1b06d4a8d6e76895221748ffd6)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.cloud.3                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
        system.adapter.deyeidc.0                : deyeidc               : raspberrypi                              - disabled, port: 8899
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.email.1                  : email                 : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hmip.0                   : hmip                  : raspberrypi                              -  enabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              -  enabled
        system.adapter.mobile.0                 : mobile                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
      + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
      + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zendure-solarflow.0      : zendure-solarflow     : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      List is empty
      Installed ioBroker-Instances
      Error: Object "system.repositories" not found
      Objects and States
      Objects:        42450
      States:         39349
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 17
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       18402      446/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          19469      573/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          58848278   29012/cupsd
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       37829      3693/io.shelly.0
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       21145      446/deCONZ
      tcp        0      0 0.0.0.0:8765            0.0.0.0:*               LISTEN      0          21688      361/python
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       45449775   7774/io.mqtt.0
      tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       45449776   7774/io.mqtt.0
      tcp        0      0 0.0.0.0:7999            0.0.0.0:*               LISTEN      0          21569      680/motion
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       22131      542/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19829      542/iobroker.js-con
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          20936      569/vncserver-x11-c
      tcp        0      0 0.0.0.0:8079            0.0.0.0:*               LISTEN      0          21568      680/motion
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31101      2401/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       37617      4792/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          19471      573/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          58848277   29012/cupsd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       37632      5152/io.simple-api.
      tcp6       0      0 :::8095                 :::*                    LISTEN      1001       45275461   18028/io.onvif.0
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          20935      569/vncserver-x11-c
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       37849      4131/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       37850      4131/io.tuya.0
      udp        0      0 0.0.0.0:34848           0.0.0.0:*                           108        16976      357/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19657      476/dhcpcd
      udp        0      0 0.0.0.0:49759           0.0.0.0:*                           1001       1193620    10941/io.broadlink2
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          58847555   29014/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       1193591    10941/io.broadlink2
      udp        0      0 0.0.0.0:53918           0.0.0.0:*                           1001       1195574    10941/io.broadlink2
      udp        0      0 192.168.178.119:5353    0.0.0.0:*                           1001       35325      3191/io.tr-064.0
      udp        0      0 192.168.178.118:5353    0.0.0.0:*                           1001       35324      3191/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16974      357/avahi-daemon: r
      udp        0      0 0.0.0.0:48885           0.0.0.0:*                           1001       57894443   10941/io.broadlink2
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       38776      5844/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       38773      5844/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       21352      446/deCONZ
      udp6       0      0 :::52730                :::*                                108        16977      357/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          27481      476/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        16975      357/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       38778      5844/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       38777      5844/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       38775      5844/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       38774      5844/io.deconz.0
      2024-05-22 11:10:54.599  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 32.821undefined
      2024-05-22 11:10:55.876  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 39.769undefined
      2024-05-22 11:10:59.062  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 31.324undefined
      2024-05-22 11:11:02.596  - warn: tuya.0 (4131) bf06b08cba98cae305vmq9.1: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
      2024-05-22 11:11:02.609  - warn: tuya.0 (4131) bf06b08cba98cae305vmq9.1: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
      2024-05-22 11:11:02.619  - warn: tuya.0 (4131) bf06b08cba98cae305vmq9.1: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
      2024-05-22 11:11:02.757  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 27.724undefined
      2024-05-22 11:11:03.006  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 24.258undefined
      2024-05-22 11:11:03.062  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 210.72undefined
      2024-05-22 11:11:03.877  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 21.415undefined
      2024-05-22 11:11:05.843  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 24.157undefined
      2024-05-22 11:11:06.892  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 22.828undefined
      2024-05-22 11:11:08.339  - info: web.0 (4792) <== Disconnect system.user.admin from ::ffff:192.168.178.133 flot
      2024-05-22 11:11:08.381  - info: web.0 (4792) <== Disconnect system.user.admin from ::ffff:192.168.178.133 flot
      2024-05-22 11:11:08.647  - info: web.0 (4792) ==> Connected system.user.admin from ::ffff:192.168.178.133
      2024-05-22 11:11:08.773  - info: web.0 (4792) ==> Connected system.user.admin from ::ffff:192.168.178.133
      2024-05-22 11:11:10.840  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 21.651undefined
      2024-05-22 11:11:11.839  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 53.025undefined
      2024-05-22 11:11:12.840  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 21.112undefined
      2024-05-22 11:11:14.910  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 29.103undefined
      2024-05-22 11:11:17.855  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 25.84undefined
      2024-05-22 11:11:19.844  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 50.518undefined
      2024-05-22 11:11:20.876  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 32.283undefined
      2024-05-22 11:11:23.857  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 56.524undefined
      2024-05-22 11:11:24.845  - info: javascript.0 (2453) script.js.Manni_Schalter.Aussen.Teichfilter-Sommer: 27.959undefined
      iob diag has finished.
      Press any key for a summary
        Thomas Braun Most Active @Yoda last edited by
        @yoda sagte in Keine Updates / Fehlende Adapter Ansicht:
        buster
        Brauch ich gar nicht weiterlesen.
        Bring das ganze Spiel auf ein aktuelles 64Bit-Release von 'Bookworm'.
        Geht nur per NEUINSTALLATION.
        Yoda 1 Reply Last reply Reply Quote 0
        • Yoda
          @thomas-braun sagte in Keine Updates / Fehlende Adapter Ansicht:
          buster
          arh neh ......😧
            Thomas Braun Most Active @Yoda last edited by Thomas Braun
            @yoda
            iobBroker in Gänze auf einen aktuellen Stand bringen, Backup ziehen und damit auf das frische System umziehen.
            Und geh mit dem System dann besser um:
            Da gibt es Einschläge im Dateisystem. NIE einfach im laufenden Betrieb den Stecker ziehen.
            Dann auch gleich OHNE Desktop installieren.
            Yoda 1 Reply Last reply Reply Quote 1
            • Yoda
              @yoda
              Danke für deine Hilfe @Thomas-Braun .
              Da war dann sicher die Sicherung mal raus 😊
              Werde deinen Rat aber beherzigen 👍
              Habe hier noch ein gleichen Raspi 4 zur VIS Darstellung. Muss mal schauen wie ich den am besten neu aufsetzten kann...
              • mcm1957
                mcm1957 @Yoda last edited by
                @yoda
                Ohne repositories geht mal sicher kein Update
                Verscuch mal die Repos zu resetten (Button mit Pfeil gegen Uhrzeigersinn):
                Und dem Updatebedarf stimme ich zu - nicht dass da ein falscher Eindruck entsteht!
                • Yoda
                  Yoda @mcm1957 last edited by Yoda
                  @mcm1957 Danke - ich habs dort mal auf Beta und dann auch wieder auf stable eingetragen.
                  Leider keine Veränderung- Danke für den Lösungsansatz.
                  Komisch ... wen ich nun wieder reingehe sehe ich keinen Eintrag vom Link - alles leer...
                  Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                    @yoda
                    Kein Wunder. Denn:
                    List is empty
                    Vielleicht waren die in den
                    drin.
                    • mcm1957
                      @yoda
                      Ev schau mal in dem Topic:
                      https://forum.iobroker.net/topic/58458/nur-installierte-adapter-werden-angezeigt-bei-adapter/17?_=1716388632796
                      Kern iob setup first
                      In jedem Fall stell vor irgendwelchen weiteren Versuchen sicher, dass du ein funktionierende BACKUP hast.
                      • Yoda
                        @mcm1957 denke leider ich muss das System wirklich neu machen.
                        Plane meinen 2 Raspi mal dafür ein - wenn ich den dann am laufen habe.
                        Setzte ich den Raspi 1 ( Aktuell Iobroker) auch neu auf. Der ist dann mit Browser, rein für für die Vis Darstellung.
                        Wie mache ich das am Besten?
                        Raspi Nr.2 neu aufsetzten ohne Browser - Backup einspielen.
                        Nun würde ich gern zum Abgleich den jetzigen Raspi Nr.1 Deaktivieren, aber noch die Möglichkeit haben mögliche Adapter Einstellungen abzugleichen. Wenn ich ich nun den Admin stoppe, sehe ich vermutlich auch nichts mehr oder?
                          Das sowieso. Ein 32Bit-Buster ist halt eh schon geraume Zeit verstorben.
                          Neu aufsetzen, iobroker 'leer' installieren, vorhandenes Backup wieder einspielen, fertig. Dauert 'ne Stunde, je nach Umfang der Installation.
                          Yoda 2 Replies Last reply Reply Quote 0
                          • Yoda
                            @thomas-braun habe nun einen neuen Raspi mit Iobroker.
                            Ich suche grade verzweifelt nach der Möglichkeit ein Backup einzuspielen.
                            Eines erstellen klappt - aber ich finde den Button zur Wiederherstellung nicht 😞
                              Homoran Global Moderator Administrators @Yoda last edited by
                              sieh mal in die Sidebar 😉
                              • Yoda
                                Yoda @Homoran last edited by
                                @homoran oh man ich habes - wird langsam zu spät 😊
                                • Yoda
                                  @thomas-braun @thomas-braun ich habe das System nun neu gemacht, alles schick auch mit den Bildern Lokal speichern.
                                  Meine Daten sehen nun wie unten aus.
                                  Nur der simple-api bekomme ch nicht am laufen, kann aber jetzt auch nicht sagen das ich Negative Auswirkungen deswegen sehe.
                                  Habt ihr da noch einen Tip für mich
                                  simple-api.0
                                  2024-05-24 13:43:27.478	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  simple-api.0
                                  2024-05-24 13:43:27.473	error	Cannot create webserver: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
                                  simple-api.0
                                  2024-05-24 13:43:27.438	info	starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.20.3, js-controller: 5.0.19
                                  Skript v.2024-04-21
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                            Kernel: Linux 6.6.28+rpt-rpi-v8
                                      Architecture: arm64
                                  Model           : Raspberry Pi 4 Model B Rev 1.1
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                   13:36:50 up 9 min,  4 users,  load average: 1.72, 2.13, 1.42
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Fri 2024-05-24 13:36:50 CEST
                                             Universal time: Fri 2024-05-24 11:36:50 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  HOME=/home/pi
                                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev lpadmin gpio i2c spi iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  Display-Server: true
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            4.0G        2.4G        594M         17M        1.0G        1.5G
                                  Swap:           104M          0B        104M
                                  Total:          4.1G        2.4G        699M
                                  Active iob-Instances:   26
                                           3792 M total memory
                                           2330 M used memory
                                           2483 M active memory
                                            577 M inactive memory
                                            567 M free memory
                                             52 M buffer memory
                                            934 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  top - 13:36:50 up 9 min,  4 users,  load average: 1.72, 2.13, 1.42
                                  Tasks: 241 total,   1 running, 240 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   3792.1 total,    565.4 free,   2331.7 used,    987.2 buff/cache
                                  MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1460.4 avail Mem
                                  0 loaded units listed.
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                  tmpfs          tmpfs     380M  1.4M  378M   1% /run
                                  /dev/mmcblk0p2 ext4       58G   11G   45G  20% /
                                  tmpfs          tmpfs     1.9G  148K  1.9G   1% /dev/shm
                                  /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
                                  tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
                                  [Fri May 24 13:26:58 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:41:85:01 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=9aa16d6b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                                  [Fri May 24 13:27:01 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967        -4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
                                  [Fri May 24 13:27:03 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1        f5-1b5927e6c5f9 r/w. Quota mode: none.
                                  | |-/sys/kernel/security                                securityfs     securityf        s      rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/fs/cgroup                                      cgroup2        cgroup2        rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                                  | |-/sys/fs/pstore                                      pstore         pstore        rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/fs/bpf                                         bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
                                  | |-/sys/kernel/debug                                   debugfs        debugfs        rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/kernel/tracing                                 tracefs        tracefs        rw,nosuid,nodev,noexec,relatime
                                  | |-/sys/fs/fuse/connections                            fusectl        fusectl        rw,nosuid,nodev,noexec,relatime
                                  | `-/sys/kernel/config                                  configfs       configfs        rw,nosuid,nodev,noexec,relatime
                                  | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs        rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=        5492
                                  |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_mi        sc     rw,nosuid,nodev,noexec,relatime
                                  |-/dev                                                  udev           devtmpfs        rw,nosuid,relatime,size=1668360k,nr_inodes=417090,mode=755
                                  | `-/dev/mqueue                                         mqueue         mqueue        rw,nosuid,nodev,noexec,relatime
                                  |-/run                                                  tmpfs          tmpfs        rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
                                  | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs        ro,nosuid,nodev,noexec,relatime,mode=700
                                  | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs        ro,nosuid,nodev,noexec,relatime,mode=700
                                  | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs        ro,nosuid,nodev,noexec,relatime,mode=700
                                  | |-/run/rpc_pipefs                                     sunrpc         rpc_pipef        s      rw,relatime
                                  | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs        ro,nosuid,nodev,noexec,relatime,mode=700
                                  | `-/run/user/1000                                      tmpfs          tmpfs        rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,g        id=1000
                                  |   |-/run/user/1000/gvfs                               gvfsd-fuse     fuse.gvfs        d-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                  |   `-/run/user/1000/doc                                portal         fuse.port        al     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                                  `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=        mixed,errors=remount-ro
                                  /var:
                                  923M    /var/
                                  536M    /var/cache
                                  529M    /var/cache/apt
                                  416M    /var/cache/apt/archives
                                  197M    /var/lib
                                  Archived and active journals take up 87.9M in the file system.
                                  728M    /opt/iobroker/backups/
                                  1.5M    /opt/iobroker/backups/Neuer Ordner
                                  776M    /opt/iobroker/iobroker-data/
                                  638M    /opt/iobroker/iobroker-data/files
                                  138M    /opt/iobroker/iobroker-data/files/javascript.admin
                                  118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                  38M     /opt/iobroker/iobroker-data/states.jsonl
                                  38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.m        ap
                                  35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
                                  31M     /opt/iobroker/iobroker-data/objects.jsonl
                                  24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
                                  USB-Devices by-id:
                                  USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
                                  No Devices found 'by-id'
                                  /usr/bin/nodejs         v18.20.3
                                  /usr/bin/node           v18.20.3
                                  /usr/bin/npm            10.7.0
                                  /usr/bin/npx            10.7.0
                                  /usr/bin/corepack       0.28.0
                                  nodejs:
                                    Installed: 18.20.3-1nodesource1
                                    Candidate: 18.20.3-1nodesource1
                                    Version table:
                                   *** 18.20.3-1nodesource1 1001
                                       18.19.0+dfsg-6~deb12u1 500
                                          500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                                       18.13.0+dfsg1-1 500
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.13.16
                                  javascript:     8.3.1
                                  nodejs modules from github:     2
                                  +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/iobroker-community-        adapters/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
                                  `-- iobroker.zendure-solarflow@1.6.1 (git+ssh://git@github.com/nograx/ioBroker.z        endure-solarflow.git#b56b690481e55f1b06d4a8d6e76895221748ffd6)
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
                                    system.adapter.deconz.0                 : deconz                : raspberrypi        - disabled, port: 80
                                    system.adapter.devices.0                : devices               : raspberrypi        - disabled
                                    system.adapter.flot.0                   : flot                  : raspberrypi        - disabled
                                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi        - disabled
                                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi        - disabled
                                    system.adapter.info.0                   : info                  : raspberrypi        - disabled
                                    system.adapter.lgtv.0                   : lgtv                  : raspberrypi        - disabled
                                    system.adapter.mobile.0                 : mobile                : raspberrypi        - disabled
                                    system.adapter.mqtt.0                   : mqtt                  : raspberrypi        - disabled, port: 1886, bind: 0.0.0.0
                                    system.adapter.simple-api.0             : simple-api            : raspberrypi        -  enabled, port: 8087, bind: 0.0.0.0, run as: admi        n
                                    system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi        - disabled
                                    system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi        - disabled
                                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi        - disabled
                                    system.adapter.vis-bars.0               : vis-bars              : raspberrypi        - disabled
                                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi        - disabled
                                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi        - disabled
                                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi        - disabled
                                    system.adapter.vis-history.0            : vis-history           : raspberrypi        - disabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi        - disabled
                                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi        - disabled
                                    system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi        - disabled
                                    system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi        - disabled
                                    system.adapter.vis-metro.0              : vis-metro             : raspberrypi        - disabled
                                    system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi        - disabled
                                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi        - disabled
                                    system.adapter.vis-weather.0            : vis-weather           : raspberrypi        - disabled
                                  + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
                                  + instance is alive
                                  Active repo(s): stable
                                  Used repository: stable
                                  Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                  Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                  Adapter    "broadlink2"   : 2.2.0    , installed 2.2.0
                                  Adapter    "deconz"       : 1.4.1    , installed 1.4.1
                                  Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
                                  Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                                  Adapter    "email"        : 1.3.0    , installed 1.3.0
                                  Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                                  Adapter    "hmip"         : 1.22.0   , installed 1.22.0
                                  Adapter    "hue"          : 3.11.0   , installed 3.11.0
                                  Adapter    "iot"          : 3.2.2    , installed 3.2.2
                                  Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                                  Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
                                  Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                  Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                  Adapter    "onvif"        : 1.1.3    , installed 1.1.3
                                  Adapter    "shelly"       : 6.9.0    , installed 6.9.0
                                  Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                  Adapter    "telegram"     : 3.2.1    , installed 3.2.1
                                  Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                  Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                  Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                                  Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
                                  Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
                                  Adapter    "vis-2-widgets-material": 1.3.25, installed 1.3.25
                                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                                  Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                  Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                                  Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                                  Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                                  Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                  Adapter    "zendure-solarflow": 1.5.3, installed 1.6.1
                                  Objects and States
                                  Objects:        42481
                                  States:         39476
                                  Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Pending Updates: 0
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9671       787/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6985       787/iobroker.js-con
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7465       786/cupsd
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12866      2208/io.shelly.0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8224       837/sshd: /usr/sbin
                                  tcp6       0      0 :::5900                 :::*                    LISTEN      992        7769       821/wayvnc
                                  tcp6       0      0 :::8095                 :::*                    LISTEN      1001       12824      2285/io.onvif.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10222      1664/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10818      2410/io.web.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          8235       837/sshd: /usr/sbin
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7464       786/cupsd
                                  udp        0      0 192.168.178.133:5353    0.0.0.0:*                           1001       10683      2209/io.tr-064.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7304       552/avahi-daemon: r
                                  udp        0      0 0.0.0.0:38821           0.0.0.0:*                           1001       10532      2144/io.broadlink2.
                                  udp        0      0 0.0.0.0:59590           0.0.0.0:*                           1001       10531      2144/io.broadlink2.
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       13584      2222/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       13585      2222/io.tuya.0
                                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          9154       1442/cups-browsed
                                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       12050      2144/io.broadlink2.
                                  udp        0      0 0.0.0.0:53927           0.0.0.0:*                           104        7306       552/avahi-daemon: r
                                  udp        0      0 0.0.0.0:60083           0.0.0.0:*                           1001       12648      2144/io.broadlink2.
                                  udp6       0      0 :::5353                 :::*                                104        7305       552/avahi-daemon: r
                                  udp6       0      0 :::37124                :::*                                104        7307       552/avahi-daemon: r
                                  udp6       0      0 fe80::d68f:e843:de6:546 :::*                                0          8144       678/NetworkManager
                                  2024-05-24 13:37:24.024  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 20.81undefined
                                  2024-05-24 13:37:27.280  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 13.273undefined
                                  2024-05-24 13:37:27.393  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 17.563undefined
                                  2024-05-24 13:37:28.488  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 29.423undefined
                                  2024-05-24 13:37:29.050  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 12.011undefined
                                  2024-05-24 13:37:30.787  - info: tuya.0 (2222) bf28a342545afcead8nqea: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.74:6668
                                  2024-05-24 13:37:31.806  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 15.796undefined
                                  2024-05-24 13:37:33.554  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 10.043undefined
                                  2024-05-24 13:37:34.386  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 21.701undefined
                                  2024-05-24 13:37:35.520  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 24.056undefined
                                  2024-05-24 13:37:41.157  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 13.71undefined
                                  2024-05-24 13:37:43.939  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 15.039undefined
                                  2024-05-24 13:37:44.952  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 3.768undefined
                                  2024-05-24 13:37:47.119  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 16.638undefined
                                  2024-05-24 13:37:47.927  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 21.953undefined
                                  2024-05-24 13:37:51.508  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 19.077undefined
                                  2024-05-24 13:37:51.535  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 11.423undefined
                                  2024-05-24 13:37:52.966  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 17.95undefined
                                  2024-05-24 13:37:53.927  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 12.937undefined
                                  2024-05-24 13:37:54.927  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 14.299undefined
                                  2024-05-24 13:37:55.942  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 11.776undefined
                                  2024-05-24 13:37:58.926  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 17.899undefined
                                  2024-05-24 13:38:01.071  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 22.256undefined
                                  2024-05-24 13:38:02.023  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 13.475undefined
                                  2024-05-24 13:38:03.939  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 10.363undefined
                                    Dürfte sich mit einer aktuellen Version des Adapters einrenken. Einfach abwarten und dann aktualisieren.
                                    • Yoda
                                      Alles klar Danke, dann warte ich einfach....
                                      • mcm1957
                                        @yoda
                                        simple-api 2.8.0 ist schon seit gestern im LATEST Repository verfügbar.
                                        Bitte mal damit testen.
                                        • Yoda
                                          @mcm1957 sagte in Keine Updates / Fehlende Adapter Ansicht:
                                          @yoda
                                            Thomas Braun Most Active last edited by Thomas Braun
                                            @yoda
                                            iob update
                                            iob upgrade
                                            ausführen. Bei mir ist die Version verfügbar.
                                            1425
