    4. Alpha Test js-controller Kiera (v6.0)
      Thomas Braun Most Active @foxriver76 last edited by
      @foxriver76 sagte in Alpha Test js-controller Kiera (v6.0):
      bitte die Linux Fraktion nochmal updaten
      Jau, das sieht wesentlich ruhiger aus im Log.
      • Feuersturm
        Feuersturm @foxriver76 last edited by
        @foxriver76 Update auf 6.0.1-alpha.0-20240522-72e34be5c
        ical Fehler
        2024-05-22 20:11:50.378 - error: ical.0 (7436) adapter disabled
        2024-05-22 20:11:50.614 - info: host.ioBrokerTestsystem instance system.adapter.worx.0 started with pid 7503
        2024-05-22 20:11:50.785 - info: hm-rpc.0 (7395) xmlrpc -> 0 devices
        2024-05-22 20:11:51.194 - info: hm-rega.0 (7380) subscribe .BidCoS-RF.50.PRESS_SHORT
        2024-05-22 20:11:51.219 - warn: ical.0 (7436) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        2024-05-22 20:11:51.704 - info: hm-rega.0 (7380) ReGaHSS 192.168.178.84 up
        2024-05-22 20:11:55.249 - info: hm-rpc.0 (7395) xmlrpc <- newDevices 323
        2024-05-22 20:11:56.282 - warn: proxmox.0 (7458) slow connection to states DB. Still waiting ...
        2024-05-22 20:11:57.053 - info: hm-rpc.0 (7395) new HMIP devices/channels after filter: 0
        2024-05-22 20:12:02.833 - error: host.ioBrokerTestsystem instance system.adapter.ical.5 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        2024-05-22 20:12:03.873 - info: admin.0 (7291) Repository received successfully.
        vis-inventwo
        2024-05-22 20:12:35.031 - error: host.ioBrokerTestsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.vis-google-fonts/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
        2024-05-22 20:12:35.035 - error: host.ioBrokerTestsystem Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
        2024-05-22 20:12:35.038 - error: host.ioBrokerTestsystem Caught by controller[0]: ^
        2024-05-22 20:12:35.041 - error: host.ioBrokerTestsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module zipFiles.js
        2024-05-22 20:12:35.044 - error: host.ioBrokerTestsystem Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.vis-google-fonts/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
        2024-05-22 20:12:35.047 - error: host.ioBrokerTestsystem Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.vis-google-fonts/node_modules/@iobroker/adapter-core/build/controllerTools.js:128:15)
        2024-05-22 20:12:35.050 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
        2024-05-22 20:12:35.053 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
        2024-05-22 20:12:35.058 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
        2024-05-22 20:12:35.061 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
        2024-05-22 20:12:35.065 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
        2024-05-22 20:12:35.072 - error: host.ioBrokerTestsystem Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
        2024-05-22 20:12:35.076 - error: host.ioBrokerTestsystem Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.vis-google-fonts/node_modules/@iobroker/adapter-core/build/index.js:19:27)
        2024-05-22 20:12:35.089 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
        2024-05-22 20:12:35.092 - error: host.ioBrokerTestsystem Caught by controller[0]: Node.js v18.20.3
        2024-05-22 20:12:35.095 - info: host.ioBrokerTestsystem instance system.adapter.vis-google-fonts.0 terminated while should be started once
        2024-05-22 20:12:36.370 - info: host.ioBrokerTestsystem instance system.adapter.web.0 started with pid 7630
        2024-05-22 20:12:36.977 - warn: hue.0 (7429) channel "Tannenbaum" already exists, using "Tannenbaum_On/Off_plug-in_unit" for light 15
        2024-05-22 20:12:37.330 - info: host.ioBrokerTestsystem instance system.adapter.echarts.0 started with pid 7637
        2024-05-22 20:12:37.352 - info: hue.0 (7429) created/updated 13 light channels
        2024-05-22 20:12:38.782 - error: host.ioBrokerTestsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
        2024-05-22 20:12:38.810 - error: host.ioBrokerTestsystem Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
        2024-05-22 20:12:38.825 - error: host.ioBrokerTestsystem Caught by controller[0]: ^
        2024-05-22 20:12:38.835 - error: host.ioBrokerTestsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module zipFiles.js
        2024-05-22 20:12:38.851 - error: host.ioBrokerTestsystem Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
        2024-05-22 20:12:38.857 - error: host.ioBrokerTestsystem Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/@iobroker/adapter-core/build/controllerTools.js:128:15)
        2024-05-22 20:12:38.864 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
        2024-05-22 20:12:38.904 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
        2024-05-22 20:12:38.913 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
        2024-05-22 20:12:38.928 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
        2024-05-22 20:12:38.946 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
        2024-05-22 20:12:38.956 - error: host.ioBrokerTestsystem Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
        2024-05-22 20:12:38.970 - error: host.ioBrokerTestsystem Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.vis-inventwo/node_modules/@iobroker/adapter-core/build/index.js:19:27)
        2024-05-22 20:12:38.985 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
        2024-05-22 20:12:39.044 - error: host.ioBrokerTestsystem Caught by controller[0]: Node.js v18.20.3
        2024-05-22 20:12:39.054 - error: host.ioBrokerTestsystem instance system.adapter.vis-inventwo.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        device-manager
        2024-05-22 20:12:50.402 - error: host.ioBrokerTestsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.device-manager/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
        2024-05-22 20:12:50.405 - error: host.ioBrokerTestsystem Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
        2024-05-22 20:12:50.409 - error: host.ioBrokerTestsystem Caught by controller[0]: ^
        2024-05-22 20:12:50.412 - error: host.ioBrokerTestsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module zipFiles.js
        2024-05-22 20:12:50.415 - error: host.ioBrokerTestsystem Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.device-manager/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
        2024-05-22 20:12:50.418 - error: host.ioBrokerTestsystem Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.device-manager/node_modules/@iobroker/adapter-core/build/controllerTools.js:128:15)
        2024-05-22 20:12:50.422 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
        2024-05-22 20:12:50.426 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
        2024-05-22 20:12:50.428 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
        2024-05-22 20:12:50.431 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
        2024-05-22 20:12:50.434 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
        2024-05-22 20:12:50.437 - error: host.ioBrokerTestsystem Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
        2024-05-22 20:12:50.441 - error: host.ioBrokerTestsystem Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.device-manager/node_modules/@iobroker/adapter-core/build/index.js:19:27)
        2024-05-22 20:12:50.444 - error: host.ioBrokerTestsystem Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
        2024-05-22 20:12:50.448 - error: host.ioBrokerTestsystem Caught by controller[0]: Node.js v18.20.3
        2024-05-22 20:12:50.450 - error: host.ioBrokerTestsystem instance system.adapter.device-manager.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-05-22 20:12:50.453 - info: host.ioBrokerTestsystem Restart adapter system.adapter.device-manager.0 because enabled
        discovery.0 (läuft auf dem Slave mit jsc 5.0.19)
        2024-05-22 20:12:56.274 - error: discovery.0 (7655) discovery.0 invalid process id scenario 13242 vs. own ID 7655. Stopping
        • foxriver76
          foxriver76 Developer @Feuersturm last edited by
          @feuersturm welche Version hat ical denn?
            Thomas Braun Most Active @foxriver76 last edited by Thomas Braun
            @foxriver76
            Was mir gerade noch auffällt: Ein eChart wird nicht mehr aktualisiert. Die Datenwerte kommen vornehmlich als alias rein, da vermute ich einen Zusammenhang mit
            (foxriver76) optimize alias subscribe performance for non-redis dbs
            Bastel aber noch dran herum.
            Gegentest: Mit "js-controller": 5.0.19 füllen sich die DPs wieder korrekt.
            • Feuersturm
              v1.15.0
              ich hab ical.0 ical.1 ical.2 ical.3 ical.4 ical.5 im Einsatz
              ical.0 bis 4 sind inaktiv, ical.5 ist aktiv
              foxriver76 mcm1957 2 Replies Last reply Reply Quote 0
              • foxriver76
                @feuersturm hm kannst du auch mal die Adapter-Core Version von iCal zeigen. npm ls @iobroker/adapter-core
                Feuersturm mcm1957 2 Replies Last reply Reply Quote 0
                • Feuersturm
                  proxmox@ioBrokerTestsystem:/opt/iobroker$ npm ls @iobroker/adapter-core
                  [sudo] password for proxmox:
                  iobroker.inst@2.0.3 /opt/iobroker
                  +-- iobroker.admin@6.17.11
                  | +-- @iobroker/adapter-core@3.1.4
                  | `-- @iobroker/socket-classes@1.5.0
                  |   `-- @iobroker/adapter-core@3.1.4 deduped
                  +-- iobroker.backitup@2.11.0
                  +-- iobroker.benchmark@1.2.0
                  +-- iobroker.daswetter@3.1.13
                  | `-- @iobroker/adapter-core@3.0.4
                  +-- iobroker.device-manager@0.0.3
                  | +-- @iobroker/adapter-core@2.6.8
                  | `-- @jey-cee/dm-utils@0.0.1
                  |   `-- @iobroker/adapter-core@2.6.8
                  +-- iobroker.device-watcher@2.12.1
                  +-- iobroker.discovery@4.5.0
                  +-- iobroker.dwd@2.8.5
                  +-- iobroker.fritzbox@0.6.0
                  +-- iobroker.fully-tablet-control@0.3.4-0 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#7117121d4e659a2ddf69feb2698a4014588a5f94)
                  +-- iobroker.hm-rega@4.0.0
                  +-- iobroker.hm-rpc@1.17.0
                  | +-- @iobroker/adapter-core@3.1.4 deduped
                  | `-- @iobroker/dm-utils@0.1.9
                  +-- iobroker.hue@3.11.0
                  +-- iobroker.ical@1.15.0
                  +-- iobroker.influxdb@4.0.2
                  +-- iobroker.javascript@8.3.1
                  +-- iobroker.js-controller@6.0.1-alpha.0-20240522-72e34be5c
                  +-- iobroker.mqtt@5.2.0
                  +-- iobroker.nina@0.0.26
                  +-- iobroker.openweathermap@1.0.4
                  +-- iobroker.proxmox@2.3.0
                  +-- iobroker.rainbird@0.2.3 (git+ssh://git@github.com/StrathCole/ioBroker.rainbird.git#0caa24dcbb11024865ff9161c6f6bb5e6db6a9ce)
                  | `-- @iobroker/adapter-core@1.0.3
                  +-- iobroker.samsung-community@0.5.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung-community.git#dd5c173cf9056c3ab9bd45006f17bb639d9ff5f8)
                  +-- iobroker.sayit@3.0.5
                  +-- iobroker.scenes@3.0.4
                  +-- iobroker.scheduler@1.3.12
                  +-- iobroker.simple-api@2.7.2
                  +-- iobroker.socketio@6.7.0
                  +-- iobroker.spotify-premium@1.5.0
                  +-- iobroker.tankerkoenig@3.4.0
                  +-- iobroker.telegram@3.2.1
                  +-- iobroker.tr-064@4.3.0
                  +-- iobroker.trashschedule@3.3.0
                  +-- iobroker.unifi@0.7.0
                  +-- iobroker.valloxmv@1.2.0 (git+ssh://git@github.com/hacki11/ioBroker.valloxmv.git#51ef16846b53016d658f1df5afa0cf42296000be)
                  +-- iobroker.vis-2@2.9.63
                  +-- iobroker.vis-google-fonts@1.0.4
                  +-- iobroker.vis-history@1.0.0
                  +-- iobroker.vis-inventwo@3.3.4
                  +-- iobroker.vis-timeandweather@1.2.2
                  +-- iobroker.vis@1.5.6
                  +-- iobroker.web@6.2.5
                  | +-- iobroker.socketio@6.6.1
                  | `-- iobroker.ws@2.5.11
                  +-- iobroker.worx@3.0.2
                  `-- iobroker.ws@2.6.1
                  • mcm1957
                    mcm1957 @Feuersturm last edited by
                    @feuersturm
                    Kannst du mal versuchen den ical mit DEBUG Loglevel zu starten?
                    Der ical hat in der Version noch das nicht mehr unterstütze subscribe: <stateid> drinnen. Das sollte aber eigentlich keinen Start verhindern sondern nur den manuellen Trigger de facto außer Betrieb setzen.
                    @foxriver76
                    Achtung: Github ist etwas neuer als die Release. Auf Github hat Klein0r das subscribe schon aus io-package entfernt
                    Sobald windows js-controlelr geht, könnt ich da was checken. Hab aber kein Linux Testsystem - und für production ist js-controller 6 noch etwas zu alpha 🙂
                    • mcm1957
                      mcm1957 @foxriver76 last edited by
                      @foxriver76
                      Der adapter-core von ical sollte aktuell sein
                      • foxriver76
                        foxriver76 Developer @mcm1957 last edited by foxriver76
                        @mcm1957 Jop am Handy das log falsch zugeordnet Problem sind nur die <2.6.9 noch aber fixe ich morgen im Controller.
                        Ja iCal villt was mit subscribe zu tun kann ich morgen evtl auch testen.
                        • mcm1957
                          @foxriver76 said in Alpha Test js-controller Kiera (v6.0):
                          Der ical ist auch ein subscribe Adapter. Kann sein, dass das der einzige ist.
                          • mcm1957
                            mcm1957 last edited by mcm1957
                            Ich hab jetzt mal mein Windowssytem auf js-controller 6 gebracht (mit dem manuellen Fix)
                            Der ical startet bei mir einwandfrei:
                            host.Envy
                            2024-05-22 21:25:08.287	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            ical.0
                            2024-05-22 21:25:07.726	info	Terminated (NO_ERROR): Without reason
                            ical.0
                            2024-05-22 21:25:02.716	info	All calenders could not be processed, Do not clean up events
                            ical.0
                            2024-05-22 21:25:02.715	warn	Error reading "http://11111.ics": Cannot read URL: "http://11111.ics"
                            ical.0
                            2024-05-22 21:25:02.714	warn	Error reading from URL "http://11111.ics"
                            ical.0
                            2024-05-22 21:25:02.474	info	starting. Version 1.15.0 in C:/ioBroker/node_modules/iobroker.ical, node: v18.20.2, js-controller: 6.0.1-alpha.0-20240522-72e34be5c
                            host.Envy
                            2024-05-22 21:25:01.952	info	Restart compact group controller 3
                            Hinweis: Das System läuft im compact mode - das sollte aber wohl kaum ein Problem BEHEBEN-
                            Hinweis2: Ich hab keine echte Config sondern nur das was als Default drinnen ist abgespeichert.
                            Feuersturm mcm1957 foxriver76 3 Replies Last reply Reply Quote 0
                            • Feuersturm
                              Feuersturm @mcm1957 last edited by
                              @mcm1957 Ich versuche das Problem etwas weiter einzugrenzen. Ich habe 6 ICAL Instanzen für verschiedene Kalender laufen die ich verschieden behandel. Ein Debug Log von verschiedenen Kalendern ist nicht so einfach möglich, da dort ja die Produktivdaten in den Kalendern stecken. Ich habe auf meinem Produktivsystem und auf meinem Testsystem verschiedene Versionen im Einsatz, ich schau mal ob das auch noch einen Einfluss hat.
                              • mcm1957
                                mcm1957 @mcm1957 last edited by
                                @Feuersturm
                                Kannst du mal in den system objects checken of eine Config dort sichtbar ist und via admin UI schaun ob die Config dort sichtbar ist?
                                • mcm1957
                                  @feuersturm
                                  Ja klar.
                                  Aber schau mal (für dich) mit DEBUG log ob da überhaupt Kalenderdaten kommen. Dein Logging von oben schaut so aus als würde der ical gar nicht starten :-). Und es wäre ein großer Unterschied ob er nicjht startet oder "nur" nicht normal arbeitet.
                                  kommt ja vom js-controller. Steht da vorher was vom ical drinnen?
                                  • mcm1957
                                    @foxriver76
                                    Noch ne Idee:
                                    Der ical beendet sich mit adapter.stop();
                                    Ab js-controller 6 kann die Funktion ja nun Parameter (Exist Status). Kann es sein, dass der Status 3 nur ein reiner Zufallswert ist weil der js-controller / adapter-code "kein Paramater" nicht richtig erkennen und zu einem definierten Wert mappen? Sprich - 'undefinierte Variable Problem'
                                    • Feuersturm
                                      Feuersturm @mcm1957 last edited by Feuersturm
                                      @mcm1957 @foxriver76
                                      zum ical Thema.
                                      Ich habe auf meiner anderen Produktivinstanz mit ical 1.15.0 auch einmal meinen ical.5 ioBroker Testkalender eingerichtet. Dort läuft js-controller 5.0.19. Auf dem System kann ich das Debug Loglevel von ical.5 einschalten und der Kalender wird mit zwei Testterminen korrekt ausgelesen. Alle anderen ical Instanzen 0 bis 4 sind nicht aktiv.
                                      Auf meinem Testsystem mit js-controller 6 ist ical5 der gleiche ioBroker Testkalender.
                                      Wenn ich dort versuche das Debug Loglevel von ical5 einzuschalten sehe ich folgendes im Log:
                                      2024-05-22 21:50:36.753 - info: host.ioBrokerTestsystem instance scheduled system.adapter.ical.5 * * * * *
                                      2024-05-22 21:50:36.797 - info: host.ioBrokerTestsystem instance system.adapter.ical.5 started with pid 10678
                                      2024-05-22 21:50:42.079 - error: ical.0 (10678) adapter disabled
                                      2024-05-22 21:50:42.143 - warn: ical.0 (10678) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                                      2024-05-22 21:50:42.872 - error: host.ioBrokerTestsystem instance system.adapter.ical.5 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                                      2024-05-22 21:51:00.146 - info: host.ioBrokerTestsystem instance system.adapter.ical.5 started with pid 10689
                                      2024-05-22 21:51:04.861 - error: ical.0 (10689) ical.0 already running
                                      2024-05-22 21:51:04.873 - warn: ical.0 (10689) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                      2024-05-22 21:51:05.465 - error: host.ioBrokerTestsystem instance system.adapter.ical.5 having pid 10689 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                      2024-05-22 21:51:54.169 - info: host.ioBrokerTestsystem stopInstance system.adapter.ical.5 (force=false, process=false)
                                      2024-05-22 21:51:54.182 - info: host.ioBrokerTestsystem stopInstance canceled schedule system.adapter.ical.5
                                      2024-05-22 21:51:58.028 - info: host.ioBrokerTestsystem instance scheduled system.adapter.ical.5 * * * * *
                                      2024-05-22 21:51:58.083 - info: host.ioBrokerTestsystem instance system.adapter.ical.5 started with pid 10700
                                      2024-05-22 21:52:00.039 - warn: host.ioBrokerTestsystem instance system.adapter.ical.5 already running with pid 10700
                                      2024-05-22 21:52:03.062 - error: ical.0 (10700) adapter disabled
                                      2024-05-22 21:52:03.132 - warn: ical.0 (10700) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                                      2024-05-22 21:52:03.918 - error: host.ioBrokerTestsystem instance system.adapter.ical.5 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                                      Es kommen keine weiteren Debugdaten vom ical5. Unter ical.5.data werden auch nicht die Daten aus dem Kalender eingetragen. ical5 startet aus meiner Sicht also gar nicht erst.
                                      • mcm1957
                                        @feuersturm
                                        Ich glaub da muss wirklich Foxriver mal ein Auge drauf werfen (ohne es zu beschädigen 🙂 )
                                        Already running kommt oft wenn ein scheduled adapter nicht sauber beendet wird. Aber warum !?!? k.A.
                                        • mcm1957
                                          @feuersturm said in Alpha Test js-controller Kiera (v6.0):
                                          Grad gesehen:
                                          Hast du wirklich einen cron * * * * * eingestellt ?
                                          Mit * * * * * schaff ich auch already running. Aber die NO_CONFIG Meldung schaff ich nicht.
                                          • Feuersturm
                                            @mcm1957 sagte in Alpha Test js-controller Kiera (v6.0):
                                            Ja, das war jetzt zum testen.
                                            alpha js-controller kiera test
                                            20
                                            234
                                            44244
