    4. Node-Red
    5. Node-Red Filter
    Node-Red Filter
    • mickym
      mickym Most Active @ranzen last edited by mickym
      @ranzen sagte in Node-Red Filter:
      16.5
      16.5
      16.400000000000006
      -100
      15.299999999999997
      -100
      15.099999999999994
      15.400000000000006
      16.099999999999994
      16.799999999999997
      17.400000000000006
      18.299999999999997
      18.5
      Ist das ein Array aus Zahlen?
      Falls dem so ist - entweder mit einer Switch Nodes die unerwünschten Werte ausfiltern.
      Hier alles zusammen zum Import:
      [{"id":"3d235207a6ec473c","type":"debug","z":"289f539dcc33814e","name":"Array","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":770,"y":5600,"wires":[]},{"id":"da4a22c6c93ff7f8","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":5600,"wires":[["8210f8d23f2e3b99"]]},{"id":"8210f8d23f2e3b99","type":"template","z":"289f539dcc33814e","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"16.5\n16.5\n16.400000000000006\n-100\n15.299999999999997\n-100\n15.099999999999994\n15.400000000000006\n16.099999999999994\n16.799999999999997\n17.400000000000006\n18.299999999999997\n18.5","output":"str","x":360,"y":5600,"wires":[["3f43c3b365968227"]]},{"id":"3f43c3b365968227","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$split(payload,\"\\n\").$number()","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":5600,"wires":[["3d235207a6ec473c","e259d08c2c4841b7","bfe84a1beb7dcb3f"]]},{"id":"ad881d5147a9b75b","type":"switch","z":"289f539dcc33814e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"0","vt":"num"}],"checkall":"true","repair":true,"outputs":1,"x":890,"y":5680,"wires":[["5d2cc22962edafe1"]]},{"id":"07c3ea21296c6061","type":"debug","z":"289f539dcc33814e","name":"gefiltertes Array","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1200,"y":5680,"wires":[]},{"id":"e259d08c2c4841b7","type":"split","z":"289f539dcc33814e","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":750,"y":5680,"wires":[["ad881d5147a9b75b"]]},{"id":"5d2cc22962edafe1","type":"join","z":"289f539dcc33814e","name":"","mode":"auto","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1030,"y":5680,"wires":[["07c3ea21296c6061"]]},{"id":"bfe84a1beb7dcb3f","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$filter(payload, function($v){$v > 0})\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":5760,"wires":[["79cbf6a910fbec2f"]]},{"id":"79cbf6a910fbec2f","type":"debug","z":"289f539dcc33814e","name":"gefiltertes Array mit JSONATA","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1030,"y":5760,"wires":[]}]
      1. Mit switch Node die unerwünschten Werte aus dem Array filtern:
      2. oder mit JSONATA
        ranzen @mickym last edited by
        @mickym
        Danke für Deine Hilfe.
        Ich habe mein Node-RED Programmierung angepasst.
        Nach meiner Funktion, in der ich den Payload extrahiere, habe ich folgendes Ergebnis:
        msg.payload : array[1]
        array[1]
        0: object
        battery: 3.378
        resistance: 7.386
        sensorType: 1
        temperature: 20.5
        trigger: 0
        Von meinem Problem ist nur der temperature-Wert betroffen.
        Jetzt leite ich den Datenfluss weiter in Deine Kaskade (change, split, switch, join) und dann in die InfluxDB.
        Dann kommt folgender Fehler:
        msg : string[92]
        "Invalid JSONata expression: Argument 1 of function "split" does not match function signature"
        In die DB wird nicht geschrieben.
        VG Heiner
        • mickym
          Also Du musst nur eine von beiden Methoden verwenden. Dann nimm halt nur die ChangeNode und filtere halt nach der Temperatur direkt deinem Output Deiner function Node..
          Also nur die change Node mit folgendem JSONATA:
          $filter(payload, function($v){$v.temperature > 0})
            @mickym said in Node-Red Filter:
            Da kommt dann die folgende Fehlermeldung:
            "Invalid JSONata expression: The expressions either side of operator ">" must evaluate to numeric or string values"
            • mickym
              @ranzen Ich würde vorschlagen, Du kopierst das was Du filtern willst direkt aus dem Debug Fenster in CodeTags hier rein.
              Ich hab das nun zwar mühsam versucht, aber wenn man keine Daten hat, um das nachzustellen, dann kann man auch nicht helfen.
              Also schau mal ob Deine Debug Ausgabe so aussieht.
              Und dann kopiert man aus dem Debug-Fenster den Wert der payload in die Zwischenablage
              und stellt den hier in CodeTags ein:
              [{"battery":3.378,"resistance":7.386,"sensorType":1,"temperature":20.5,"trigger":0}]
              Dann muss ich keine Gänsefüsschen, Klammern etc selbst drum rum machen.
              So und wenn ich nun mit meiner Change Node teste dann werden die Objekte, die eine ungültige Temperatur haben - ausgefiltert - sprich die payload ist undefined (rot markiert). Kannst ggf noch eine Switch Node dahinter machen, um diese Nachrichten komplett zu filtern.
              Hier kannst ja selbst testen oder in die Inject NOde ein Objekt rein machen, was passt.
              [{"id":"e45337f4a3f55c96","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"battery\":3.378,\"resistance\":7.386,\"sensorType\":1,\"temperature\":-100,\"trigger\":0}]","payloadType":"json","x":390,"y":6180,"wires":[["6ef399891f05414c","c6fa94570d7b3b5a"]]},{"id":"6ef399891f05414c","type":"debug","z":"289f539dcc33814e","name":"Input","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":550,"y":6120,"wires":[]},{"id":"c6fa94570d7b3b5a","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$filter(payload, function($v){$v.temperature > 0})","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":6180,"wires":[["ca0c74d4d7932b9f"]]},{"id":"ca0c74d4d7932b9f","type":"debug","z":"289f539dcc33814e","name":"gefiltert","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":780,"y":6180,"wires":[]}]
              • mickym
                mickym Most Active @mickym last edited by
                @mickym Und wenn Du nur den negativen Temperaturwert oder -100 herausfiltern willst, dann aktualisierst Du halt das Objekt.
                  @mickym
                  23.5.2024, 16:30:35node: 2da49fa7d532a2d4
                  array[1]
                  0: object
                  battery: 3.389
                  resistance: 17.991
                  sensorType: 1
                  temperature: 20.900000000000006
                  trigger: 0
                  Ja, so der Payload aus, den ich aus der Funktion Richtung DB schicke.
                  Mein Code in der Funktion sieht so aus:
                  var msg1 = {};
                  msg1.payload = [
                          battery: msg.payload.uplink_message.decoded_payload["battery"],
                          resistance: msg.payload.uplink_message.decoded_payload["resistance"],
                          sensorType: msg.payload.uplink_message.decoded_payload["sensorType"],
                          temperature: msg.payload.uplink_message.decoded_payload["temperature"],
                          trigger: msg.payload.uplink_message.decoded_payload["trigger"]
                  return (msg1);
                  R mickym 2 Replies Last reply Reply Quote 0
                    ranzen @ranzen last edited by
                    Und in der DB sieht das dann so aus:
                    time                           battery resistance sensorType temperature          trigger
                    2024-04-08T15:59:41.629377294Z 3.398   1000       1          24.400000000000006   0
                    2024-04-08T16:14:41.795550813Z 3.401   1000       1          24.400000000000006   0
                    2024-04-08T16:29:41.794306826Z 3.398   1000       1          24.400000000000006   0
                    2024-04-08T16:44:41.73256775Z  3.403   1000       1          24.5                 0
                    2024-04-08T16:59:41.786260269Z 3.398   1000       1          24.400000000000006   0
                    2024-04-08T17:14:41.783145044Z 3.401   1000       1          24.299999999999997   0
                    2024-04-08T17:44:41.779760184Z 3.401   1000       1          24.200000000000003   0
                    2024-04-08T17:59:41.612032196Z 3.401   1000       1          24.099999999999994   0
                    2024-04-08T18:14:41.774595375Z 3.401   1000       1          24                   0
                    2024-04-08T18:29:41.705639142Z 3.401   1000       1          23.900000000000006   0
                    2024-04-08T18:44:41.768656569Z 3.398   1000       1          23.900000000000006   0
                    2024-04-08T18:59:41.767234983Z 3.398   1000       1          23.900000000000006   0
                    2024-04-08T19:14:41.772372995Z 3.401   1000       1          23.799999999999997   0
                    2024-04-08T19:29:41.768979924Z 3.401   1000       1          23.799999999999997   0
                    2024-04-08T19:44:41.605064779Z 3.398   1000       1          23.799999999999997   0
                    2024-04-08T19:59:41.696679475Z 3.398   1000       1          23.799999999999997   0
                    2024-04-08T20:14:41.776049783Z 3.398   1000       1          23.700000000000003   0
                    2024-04-08T20:29:41.760546515Z 3.401   1000       1          23.599999999999994   0
                    2024-04-08T20:44:41.758661338Z 3.398   1000       1          23.599999999999994   0
                      Aber die Fehlermeldung kommt immer noch.
                      Im Change-Node steht als Regel:
                      Setze msg.payload
                      to the value
                      • mickym
        23.5.2024, 16:30:35node: 2da49fa7d532a2d4        msg.payload : array[1]        array[1]        0: object        battery: 3.389        resistance: 17.991        sensorType: 1        temperature: 20.900000000000006        trigger: 0
                        Du hast schon wieder den Wert nicht über das Debug Fenster und der Schaltfläche Wert kopieren rauskopiert, sondern mit der MAUS - das ist Unsinn. Ich habe Dir doch unten einen Screenshot eingestellt, wie man die Werte sauber aus dem Debugfenster kopiert. So ist das unbrauchbar.
                        Aber OK - ich habs nochmal transformiert.
                        Das dann nächste ist, Du willst mir nicht sagen, dass Du wegen so einem Input Objekt eine function mit JS Code erstellst??
                          @mickym
                          code_text
                          So sah mein Code aus.
                            @ranzen
                            Ok, jetzt habe ich es kapiert. Debugfenster und dann Schaltfläche Wert.
                              Doch 😉
                              So habe ich es mir in den letzten Jahren abgeguckt. Ich mache sehr wenig mit der Jvascipt-Programmierung. Sicherlich geht das eleganter.
                                ranzen @ranzen last edited by ranzen
                                Wie geht es eleganter ?
                                Ich hole die Daten per MQTT (in diesem Fall mit MQTT in) von der Quelle ab.
                                Dann kommt schon die Funktion, in die ich die geholten Daten rein kippe. Und dann in die DB, wo sich Grafana dann bedient.
                                Das hat bis jetzt immer super funktioniert.
                                Wenn es eleganter geht. Nur zu, ich lerne gern dazu.
                                • mickym
                                  Wenn also der Sinn Deiner function Node ist nur das ganze nach oben zu ziehen , da braucht man gar nichts programmieren. Dann nimmt man eine Change Node und VERÄNDERT die payload entsprechend.
                                  Diese EINE Regel in der Change Node - macht das Gleiche wie dein Javascript Code. Also vielleicht solltest Du Dich mal mit Objekten beschäftigen. 😉
                                    @mickym
                                    ok, da werde ich mich bestimmt mit beschäftigen.
                                    Aber die Fehlermeldung ist immer noch 😉 Im Moment wird die DB nicht bedient.
                                    • mickym
                                      mickym Most Active last edited by mickym
                                      Ich bin ja auch noch nicht fertig
                                      So ich hab Dir nun 2 Möglichkeiten zum Filtern gemacht - da ich auch noch keine Antwort hatte, ob Du das ganze Objekt wegfiltern willst, wenn die Temperatur -100 ist oder nur die Objekteigenschaft Temperatur:
                                      Im ersten Fall kommt also gar nichts hinten raus, wenn in der temperature Eigenschaft -100 steht
                                        @mickym
                                        Ich möchte alles, was kommt, in die DB schreiben. Ausser: -100.
                                          @mickym
                                          Dieser Wert -100 zieht mir die schöne Visualisierung vom Grafana runter.
                                          • mickym
                                            @mickym
                                            OK dann hätte ich mir das wahrscheinlich sparen können, dann willst Du also nur die temperature Eigenschaft wegfiltern.
                                            dann sollte also im Prinzip das langen:
                                            [{"id":"487d44863b93b5de","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.temperature = -100 ? payload~>|$|{},\"temperature\"|","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":6440,"wires":[["7b3c154c0eb45240"]]}]
                                            Und zum Schluss mach ich Dir noch eine Version, in der Du Dir die ganze function Node sparen kannst.
                                            4622
