    4. (Close) User PI Kein Zugang / Berechtigung
    • Yoda
      Yoda last edited by Yoda
      Hallo, ich habe mir grade mein neu aufgesetztes System stubellig gemacht.
      Wollte zuletzt eine schreib Berichtigung innerhalb der Ordners /home/pi/Videos setzten.
      Nun kann der Iobroker dort nicht mehr schreiben.
      Auch wenn ich mich über die Konsole anmelden möchte klappt es nicht.
      login as: pi
      pi@192.168.178.133's password:
      Linux raspberrypi 6.6.28+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.28-1+rpt1 (2024-                        04-22) aarch64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Thu May 23 23:48:39 2024
      Could not chdir to home directory /home/pi: Permission denied
      -bash: /home/pi/.bash_profile: Permission denied
      pi@raspberrypi:/$
      Könntet ihr mir die Befehle sagen wie ich die Berechtigung für pi wieder hinbekomme?
      sourceanalytix.0
      2024-05-23 23:51:32.937	error	Troubleshoot Data 0_userdata.0.Strom.9-3-3_Solar-Genutzt custom Data : {"common":{"name":"9-3-3_Solar-Genutzt","desc":"Manuell erzeugt","role":"value","type":"number","read":true,"unit":"kWh","write":true,"def":"","custom":{"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","deviceResetLogicEnabled":true,"threshold":1,"start_day":52.316,"start_week":46.209,"start_month":52.316,"start_quarter":0,"start_year":0,"selectedPrice":"ElectricityDay","consumption":true,"meter_values":true,"valueAtDeviceReset":52.316,"valueAtDeviceInit":0,"cumulativeValue":52.316}}},"type":"state","native":{},"_id":"0_userdata.0.Strom.9-3-3_Solar-Genutzt","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1714514460088}
      sourceanalytix.0
      2024-05-23 23:51:32.931	error	Check settings for 0_userdata.0.Strom.9-3-3_Solar-Genutzt ! Known valueAtDeviceReset : (52.316) > known cumulative value (52.315000000000005) cannot proceed
      shelly.0
      2024-05-23 23:51:13.712	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-fcb467a6c634"
      cloud.3
      2024-05-23 23:50:50.347	error	Cloud says: timeout
      onvif.0
      2024-05-23 23:50:45.040	error	Error Error: ONVIF SOAP Fault: HTTP Error: 401 Unauthorized
      onvif.0
      2024-05-23 23:50:45.039	error	Failed to login to 192.168.178.151:888 with Manni:& ******W
      onvif.0
      2024-05-23 23:50:44.997	error	Error Error: ONVIF SOAP Fault: Sender not Authorized. Invalid username or password! You still have 0 attempt(s).
      onvif.0
      2024-05-23 23:50:44.996	error	Failed to login to 192.168.178.48:80 with Manni:& ******W
      onvif.0
      2024-05-23 23:50:44.547	error	Error Error: ONVIF SOAP Fault: HTTP Error: 401 Unauthorized
      onvif.0
      2024-05-23 23:50:44.546	error	Failed to login to 192.168.178.150:888 with Manni:& ******W
      onvif.0
      2024-05-23 23:50:44.014	error	Error: connect EHOSTUNREACH 192.168.178.110:8080 at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1555:16)
      onvif.0
      2024-05-23 23:50:44.009	error	You can change user and password under object and edit device or delete device under objects and restart adapter
      onvif.0
      2024-05-23 23:50:44.008	error	Error initializing device: Error: connect EHOSTUNREACH 192.168.178.110:8080 device: {"id":"192_168_178_110_8080","name":"IPCAM C6F0SfZ0N0P3L0
      onvif.0
      2024-05-23 23:50:44.006	error	Data: null XML: undefined
      cloud.3
      2024-05-23 23:50:20.912	error	Cloud says: timeout
      host.raspberrypi
      2024-05-23 23:48:36.622	error	iobroker npm-install: host.raspberrypi Unknown packetName info. Please install packages from outside the repository using npm!
        Thomas Braun Most Active @Yoda last edited by Thomas Braun
        @yoda sagte in User PI Kein Zugang / Berechtigung:
        Der user iobroker soll auch in /home/pi nix schreiben.
        sudo ls -lah /home/pi/.bash_profile
        sagt z. B.?
        Yoda 1 Reply Last reply Reply Quote 0
        • Yoda
          Yoda @Thomas Braun last edited by
          @thomas-braun sagte in User PI Kein Zugang / Berechtigung:
          sudo ls - lah /home/pi/.bash_profile
          login as: pi
          Linux raspberrypi 6.6.28+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.28-1+rpt1 (2024-04-22) aarch64
          Last login: Fri May 24 00:28:20 2024 from 192.168.178.166
          pi@raspberrypi:/$ sudo ls - lah /home/pi/.bash_profile
          ls: cannot access '-': No such file or directory
          ls: cannot access 'lah': No such file or directory
          ls: cannot access '/home/pi/.bash_profile': No such file or directory
          pi@raspberrypi:/$
          Glaube der loggt sich schon nicht mehr richtig ein...
            @yoda
            Sorry, mein Fehler. Muss
            lauten.
            • Yoda
              login as: pi
              Last login: Fri May 24 00:29:50 2024 from 192.168.178.166
              pi@raspberrypi:/$ sudo ls -lah /home/pi/.bash_profile
              pi@raspberrypi:/$
                @yoda
                Und
                ls -lah /home/
                • Yoda
                  ls -lah /home/
                  pi@raspberrypi:/$ ls -lah /home/
                  total 16K
                  drwxr-xr-x  4 root     root     4.0K May 22 19:42 .
                  drwxr-xr-x 18 root     root     4.0K Mar 15 16:12 ..
                  drwxr-xr-x  5 iobroker iobroker 4.0K May 22 23:14 iobroker
                  drwx------ 18 root     root     4.0K May 23 19:04 pi
                  pi@raspberrypi:/$
                  da kommt was
                    Das ist klar. Da hast du mit root-Rechten an einer Stelle herumgefummelt, an der man das besser bleiben lässt.
                    Wie man ohnehin nicht mit sudo/root um sich wirft...
                    sudo chown -R  pi:pi /home/pi
                    Yoda 1 Reply Last reply Reply Quote 1
                    • Yoda
                      @thomas-braun hab vielen lieben Dank für deine Hilfe.
                      ja wollte eigentlich nur die Berechtigung vom Video Ordner setzten 😞
                      hatte ich mir so vor jahren mal Notiert - Notitz wird nun weg geschmissen
                      sieht nun so aus:
                      pi@raspberrypi:/$ sudo chown -R  pi:pi /home/pi
                      total 16K
                      drwx------ 18 pi       pi       4.0K May 23 19:04 pi
                      pi@raspberrypi:/$
                      Neuanmeldung übers terminal und berechtigung pi sehen wieder gut aus.
                      login as: pi
                      Last login: Fri May 24 00:33:06 2024 from 192.168.178.166
                      pi@raspberrypi:~ $
                      Das Thema mit Bilder auf Raspi ablegen und per Telegramm senden würde ich separat mal schreiben.
                      Nach dem der Raspi nun auf 64 Bit umgestellt wurde läuft soweit alles wieder, nur das Thema Bilder ablegen und senden wäre noch offen.
                      Nochmals Danke für deine Hilfe !
                        Sinnvollerweise natürlich aus Verzeichnissen heraus, auf die der ioBroker von Natur aus Zugriff hat. Also dessen /home oder das data-Verzeichnis in /opt/iobroker
                        • Yoda
                          @thomas-braun alles klar gehe ich morgen mal an 👍
                          315
