    4. Keine Updates / Fehlende Adapter Ansicht
    • Yoda
      Yoda @Thomas Braun last edited by Homoran
      @thomas-braun @thomas-braun ich habe das System nun neu gemacht, alles schick auch mit den Bildern Lokal speichern.
      Meine Daten sehen nun wie unten aus.
      Nur der simple-api bekomme ch nicht am laufen, kann aber jetzt auch nicht sagen das ich Negative Auswirkungen deswegen sehe.
      Habt ihr da noch einen Tip für mich
      simple-api.0
      2024-05-24 13:43:27.478	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      simple-api.0
      2024-05-24 13:43:27.473	error	Cannot create webserver: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
      simple-api.0
      2024-05-24 13:43:27.438	info	starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.20.3, js-controller: 5.0.19
      Skript v.2024-04-21
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.6.28+rpt-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       13:36:50 up 9 min,  4 users,  load average: 1.72, 2.13, 1.42
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Fri 2024-05-24 13:36:50 CEST
                 Universal time: Fri 2024-05-24 11:36:50 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        2.4G        594M         17M        1.0G        1.5G
      Swap:           104M          0B        104M
      Total:          4.1G        2.4G        699M
      Active iob-Instances:   26
               3792 M total memory
               2330 M used memory
               2483 M active memory
                577 M inactive memory
                567 M free memory
                 52 M buffer memory
                934 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 13:36:50 up 9 min,  4 users,  load average: 1.72, 2.13, 1.42
      Tasks: 241 total,   1 running, 240 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3792.1 total,    565.4 free,   2331.7 used,    987.2 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1460.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.4M  378M   1% /run
      /dev/mmcblk0p2 ext4       58G   11G   45G  20% /
      tmpfs          tmpfs     1.9G  148K  1.9G   1% /dev/shm
      /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
      tmpfs          tmpfs     380M   40K  380M   1% /run/user/1000
      [Fri May 24 13:26:58 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:41:85:01 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=9aa16d6b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Fri May 24 13:27:01 2024] EXT4-fs (mmcblk0p2): mounted filesystem fc7a1f9e-4967        -4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
      [Fri May 24 13:27:03 2024] EXT4-fs (mmcblk0p2): re-mounted fc7a1f9e-4967-4f41-a1        f5-1b5927e6c5f9 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                                                  SOURCE         FSTYPE        OPTIONS
      /                                                       /dev/mmcblk0p2 ext4        rw,noatime
      |-/sys                                                  sysfs          sysfs        rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                                securityfs     securityf        s      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                                      cgroup2        cgroup2        rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                                      pstore         pstore        rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                                         bpf            bpf        rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                                   debugfs        debugfs        rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                                 tracefs        tracefs        rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                            fusectl        fusectl        rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                                  configfs       configfs        rw,nosuid,nodev,noexec,relatime
      |-/proc                                                 proc           proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc                            systemd-1      autofs        rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=        5492
      |   `-/proc/sys/fs/binfmt_misc                          binfmt_misc    binfmt_mi        sc     rw,nosuid,nodev,noexec,relatime
      |-/dev                                                  udev           devtmpfs        rw,nosuid,relatime,size=1668360k,nr_inodes=417090,mode=755
      | |-/dev/pts                                            devpts         devpts        rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                            tmpfs          tmpfs        rw,nosuid,nodev
      | `-/dev/mqueue                                         mqueue         mqueue        rw,nosuid,nodev,noexec,relatime
      |-/run                                                  tmpfs          tmpfs        rw,nosuid,nodev,noexec,relatime,size=388308k,mode=755
      | |-/run/lock                                           tmpfs          tmpfs        rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service             ramfs          ramfs        ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service           ramfs          ramfs        ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs          ramfs        ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                                     sunrpc         rpc_pipef        s      rw,relatime
      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs          ramfs        ro,nosuid,nodev,noexec,relatime,mode=700
      | `-/run/user/1000                                      tmpfs          tmpfs        rw,nosuid,nodev,relatime,size=388304k,nr_inodes=97076,mode=700,uid=1000,g        id=1000
      |   |-/run/user/1000/gvfs                               gvfsd-fuse     fuse.gvfs        d-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |   `-/run/user/1000/doc                                portal         fuse.port        al     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/firmware                                        /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=        mixed,errors=remount-ro
      /var:
      923M    /var/
      536M    /var/cache
      529M    /var/cache/apt
      416M    /var/cache/apt/archives
      197M    /var/lib
      Archived and active journals take up 87.9M in the file system.
      /opt/iobroker/backups:
      728M    /opt/iobroker/backups/
      1.5M    /opt/iobroker/backups/Neuer Ordner
      /opt/iobroker/iobroker-data:
      776M    /opt/iobroker/iobroker-data/
      638M    /opt/iobroker/iobroker-data/files
      179M    /opt/iobroker/iobroker-data/files/vis-2
      138M    /opt/iobroker/iobroker-data/files/javascript.admin
      118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      38M     /opt/iobroker/iobroker-data/states.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.m        ap
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.        js.map
      31M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.m        ap
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.3
      /usr/bin/node           v18.20.3
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.0
      nodejs:
        Installed: 18.20.3-1nodesource1
        Candidate: 18.20.3-1nodesource1
        Version table:
       *** 18.20.3-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.20.2-1nodesource1 1001
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      admin:          6.13.16
      javascript:     8.3.1
      nodejs modules from github:     2
      +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/iobroker-community-        adapters/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
      `-- iobroker.zendure-solarflow@1.6.1 (git+ssh://git@github.com/nograx/ioBroker.z        endure-solarflow.git#b56b690481e55f1b06d4a8d6e76895221748ffd6)
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi        -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi        -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi        -  enabled
      + system.adapter.cloud.3                  : cloud                 : raspberrypi        -  enabled
        system.adapter.deconz.0                 : deconz                : raspberrypi        - disabled, port: 80
        system.adapter.devices.0                : devices               : raspberrypi        - disabled
        system.adapter.deyeidc.0                : deyeidc               : raspberrypi        - disabled, port: 8899
      + system.adapter.discovery.0              : discovery             : raspberrypi        -  enabled
      + system.adapter.email.1                  : email                 : raspberrypi        -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi        - disabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi        -  enabled
      + system.adapter.history.0                : history               : raspberrypi        -  enabled
      + system.adapter.hmip.0                   : hmip                  : raspberrypi        -  enabled
      + system.adapter.hue.0                    : hue                   : raspberrypi        -  enabled, port: 443
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi        - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi        - disabled
        system.adapter.info.0                   : info                  : raspberrypi        - disabled
      + system.adapter.iot.0                    : iot                   : raspberrypi        -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi        -  enabled
        system.adapter.lgtv.0                   : lgtv                  : raspberrypi        - disabled
        system.adapter.mobile.0                 : mobile                : raspberrypi        - disabled
        system.adapter.mqtt.0                   : mqtt                  : raspberrypi        - disabled, port: 1886, bind: 0.0.0.0
      + system.adapter.onvif.0                  : onvif                 : raspberrypi        -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
      + system.adapter.scenes.0                 : scenes                : raspberrypi        -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi        -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : raspberrypi        -  enabled, port: 8087, bind: 0.0.0.0, run as: admi        n
        system.adapter.sonoff.0                 : sonoff                : raspberrypi        - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi        -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi        -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi        -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi        -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi        -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi        - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi        - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi        - disabled
      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi        -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi        - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi        - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi        - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi        - disabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi        - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi        - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi        -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi        - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi        - disabled
        system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi        - disabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi        - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi        - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi        - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi        - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi        -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
      + system.adapter.zendure-solarflow.0      : zendure-solarflow     : raspberrypi        -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "broadlink2"   : 2.2.0    , installed 2.2.0
      Adapter    "deconz"       : 1.4.1    , installed 1.4.1
      Adapter    "deyeidc"      : 0.0.14   , installed 0.0.14
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "email"        : 1.3.0    , installed 1.3.0
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "hmip"         : 1.22.0   , installed 1.22.0
      Adapter    "hue"          : 3.11.0   , installed 3.11.0
      Adapter    "iot"          : 3.2.2    , installed 3.2.2
      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
      Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "onvif"        : 1.1.3    , installed 1.1.3
      Adapter    "shelly"       : 6.9.0    , installed 6.9.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "telegram"     : 3.2.1    , installed 3.2.1
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
      Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
      Adapter    "vis-2-widgets-material": 1.3.25, installed 1.3.25
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Adapter    "zendure-solarflow": 1.5.3, installed 1.6.1
      Objects and States
      Objects:        42481
      States:         39476
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       9671       787/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6985       787/iobroker.js-con
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7465       786/cupsd
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       12866      2208/io.shelly.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8224       837/sshd: /usr/sbin
      tcp6       0      0 :::5900                 :::*                    LISTEN      992        7769       821/wayvnc
      tcp6       0      0 :::8095                 :::*                    LISTEN      1001       12824      2285/io.onvif.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10222      1664/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10818      2410/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          8235       837/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7464       786/cupsd
      udp        0      0 192.168.178.133:5353    0.0.0.0:*                           1001       10683      2209/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7304       552/avahi-daemon: r
      udp        0      0 0.0.0.0:38821           0.0.0.0:*                           1001       10532      2144/io.broadlink2.
      udp        0      0 0.0.0.0:59590           0.0.0.0:*                           1001       10531      2144/io.broadlink2.
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       13584      2222/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       13585      2222/io.tuya.0
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          9154       1442/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       12050      2144/io.broadlink2.
      udp        0      0 0.0.0.0:53927           0.0.0.0:*                           104        7306       552/avahi-daemon: r
      udp        0      0 0.0.0.0:60083           0.0.0.0:*                           1001       12648      2144/io.broadlink2.
      udp6       0      0 :::5353                 :::*                                104        7305       552/avahi-daemon: r
      udp6       0      0 :::37124                :::*                                104        7307       552/avahi-daemon: r
      udp6       0      0 fe80::d68f:e843:de6:546 :::*                                0          8144       678/NetworkManager
      2024-05-24 13:37:24.024  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 20.81undefined
      2024-05-24 13:37:27.280  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 13.273undefined
      2024-05-24 13:37:27.393  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 17.563undefined
      2024-05-24 13:37:28.488  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 29.423undefined
      2024-05-24 13:37:29.050  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 12.011undefined
      2024-05-24 13:37:30.787  - info: tuya.0 (2222) bf28a342545afcead8nqea: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.74:6668
      2024-05-24 13:37:31.806  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 15.796undefined
      2024-05-24 13:37:33.554  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 10.043undefined
      2024-05-24 13:37:34.386  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 21.701undefined
      2024-05-24 13:37:35.520  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 24.056undefined
      2024-05-24 13:37:41.157  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 13.71undefined
      2024-05-24 13:37:43.939  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 15.039undefined
      2024-05-24 13:37:44.952  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 3.768undefined
      2024-05-24 13:37:47.119  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 16.638undefined
      2024-05-24 13:37:47.927  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 21.953undefined
      2024-05-24 13:37:51.508  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 19.077undefined
      2024-05-24 13:37:51.535  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 11.423undefined
      2024-05-24 13:37:52.966  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 17.95undefined
      2024-05-24 13:37:53.927  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 12.937undefined
      2024-05-24 13:37:54.927  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 14.299undefined
      2024-05-24 13:37:55.942  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 11.776undefined
      2024-05-24 13:37:58.926  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 17.899undefined
      2024-05-24 13:38:01.071  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 22.256undefined
      2024-05-24 13:38:02.023  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 13.475undefined
      2024-05-24 13:38:03.939  - info: javascript.0 (2077) script.js.Pool.Pool-Solar-Steuerung-2: 10.363undefined
      iob diag has finished.
      Press any key for a summary
        Thomas Braun Most Active @Yoda last edited by
        @yoda sagte in Keine Updates / Fehlende Adapter Ansicht:
        Dürfte sich mit einer aktuellen Version des Adapters einrenken. Einfach abwarten und dann aktualisieren.
        Yoda 1 Reply Last reply Reply Quote 0
        • Yoda
          @thomas-braun sagte in Keine Updates / Fehlende Adapter Ansicht:
          Alles klar Danke, dann warte ich einfach....
          • mcm1957
            mcm1957 @Yoda last edited by
            @yoda
            simple-api 2.8.0 ist schon seit gestern im LATEST Repository verfügbar.
            Bitte mal damit testen.
            • Yoda
              Yoda @mcm1957 last edited by
              @mcm1957 sagte in Keine Updates / Fehlende Adapter Ansicht:
              @yoda
                Thomas Braun Most Active last edited by Thomas Braun
                @yoda
                iob update
                iob upgrade
                ausführen. Bei mir ist die Version verfügbar.
                • mcm1957
                  @yoda
                  .. im LATEST repository...
                  Du bist stable unterwegs was an sich OK ist - nur dann kriegst du die Version ev. erst in ca 2 bis 4 Wochen...
                  • Yoda
                    iob upgrade
                    habe ich gemacht- aber wird weiterhin nicht angezeigt....
                    login as: pi
                    pi@192.168.178.133's password:
                    Linux raspberrypi 6.6.28+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.28-1+rpt1 (2024-04-22) aarch64
                    The programs included with the Debian GNU/Linux system are free software;
                    the exact distribution terms for each program are described in the
                    individual files in /usr/share/doc/*/copyright.
                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                    permitted by applicable law.
                    Last login: Fri May 24 13:36:06 2024 from 192.168.178.166
                    pi@raspberrypi:~ $ iob update
                    pi@raspberrypi:~ $ iob upgrade
                    All adapters are up to date
                    pi@raspberrypi:~ $
                      Da ist es noch nicht drin. Muss erst durch latest/beta durch.
                      • Yoda
                        @yoda
                        oki verstanden - habs eben umgestellt - und werde es gleich wieder instable ändern.
                        Adapter Läuft.
                        Danke euch beiden @Thomas-Braun und @mcm1957
                        1425
