    4. ioBroker friert ein: "Request actual repository...".....
      Clyde @Thomas Braun last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.64-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : armhf
      Systemuptime and Load:
       15:57:44 up 1 day, 21:51,  2 users,  load average: 0.93, 1.07, 1.00
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2024-04-22 15:57:44 CEST
                 Universal time: Mon 2024-04-22 13:57:44 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            1.8G        1.1G        263M        0.0K        477M        673M
      Swap:            99M         23M         76M
      Total:          1.9G        1.1G        340M
               1847 M total memory
               1106 M used memory
                966 M active memory
                453 M inactive memory
                263 M free memory
                 46 M buffer memory
                431 M swap cache
                 99 M total swap
                 23 M used swap
                 76 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       59G   36G   21G  64% /
      devtmpfs       devtmpfs  666M     0  666M   0% /dev
      tmpfs          tmpfs     924M     0  924M   0% /dev/shm
      tmpfs          tmpfs     370M  1.1M  369M   1% /run
      /dev/sda1      vfat      253M   60M  193M  24% /boot
      tmpfs          tmpfs     185M  4.0K  185M   1% /run/user/1000
      [Sat Apr 20 18:06:22 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enab                   le_hdmi=0  smsc95xx.macaddr=E4:5F:01:A3:D6:28 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=811c5af8-02 rootfstype=ext4 fsck.repai                   r=yes rootwait
      [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): write access will be enabled during recovery
      [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): 1 orphan inode deleted
      [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): recovery complete
      [Sat Apr 20 18:06:24 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Apr 20 18:06:24 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sat Apr 20 18:06:26 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      802M    /var/
      543M    /var/cache
      538M    /var/cache/apt
      473M    /var/cache/apt/archives
      101M    /var/lib
      Archived and active journals take up 55.0M in the file system.
      /opt/iobroker/backups:
      84M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      31G     /opt/iobroker/iobroker-data/history
      324M    /opt/iobroker/iobroker-data/files
      99M     /opt/iobroker/iobroker-data/history/20230624
      98M     /opt/iobroker/iobroker-data/history/20230702
      31M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/states.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.2
      /usr/bin/node           v18.20.2
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 500
           18.20.0-1nodesource1 500
           18.19.1-1nodesource1 500
           18.19.0-1nodesource1 500
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
           12.22.12~dfsg-1~deb11u4 500
              500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.1.204, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
      + system.adapter.fronius.0                : fronius               : raspberrypi                              -  enabled
      + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      + system.adapter.viessmann.0              : viessmann             : raspberrypi                              -  enabled, port: 3002
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
        system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
      Adapter    "backitup"     : 2.11.0   , installed 2.10.11 [Updatable]
      Adapter    "fronius"      : 2.0.2    , installed 1.1.6  [Updatable]
      Adapter    "go-e"         : 1.0.29   , installed 1.0.29
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.17.0   , installed 1.16.0 [Updatable]
      Adapter    "hue"          : 3.10.2   , installed 3.10.2
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "modbus"       : 6.1.0    , installed 6.1.0
      Adapter    "shelly"       : 6.8.0    , installed 6.8.0
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "telegram"     : 3.2.1    , installed 3.1.0  [Updatable]
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "viessmann"    : 1.4.7    , installed 1.4.7
      Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.0  [Updatable]
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Objects and States
      Objects:        12641
      States:         14186
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.1.204:18701     0.0.0.0:*               LISTEN      1001       3132060    32457/io.hm-rpc.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       3131143    32322/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       3128867    32322/iobroker.js-c
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       3129144    32517/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       3132545    32547/io.sonoff.0
      tcp        0      0 0.0.0.0:3002            0.0.0.0:*               LISTEN      0          3693       542/vcontrold
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15542      533/sshd: /usr/sbin
      tcp        0      0 192.168.1.204:8081      0.0.0.0:*               LISTEN      1001       3128918    32343/io.admin.0
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        15578      506/redis-server 12
      tcp        0      0 192.168.1.204:12010     0.0.0.0:*               LISTEN      1001       3132463    32487/io.hm-rpc.2
      tcp        0      0 192.168.1.204:12001     0.0.0.0:*               LISTEN      1001       3132423    32472/io.hm-rpc.1
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3138863    1257/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15552      533/sshd: /usr/sbin
      tcp6       0      0 ::1:6379                :::*                    LISTEN      109        15579      506/redis-server 12
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14644      711/dhcpcd
      udp        0      0 0.0.0.0:53397           0.0.0.0:*                           108        12267      392/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12265      392/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        12266      392/avahi-daemon: r
      udp6       0      0 :::41461                :::*                                108        12268      392/avahi-daemon: r
      2024-04-22 15:46:57.720  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 adapter for vis-material-advanced
      2024-04-22 15:46:58.251  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 states (system.adapter.vis-material-advanced.*) from states
      2024-04-22 15:47:03.233  - info: host.raspberrypi iobroker host.raspberrypi file vis/widgets/vis-material-advanced deleted
      2024-04-22 15:47:03.316  - info: host.raspberrypi iobroker host.raspberrypi file vis/widgets/vis-material-advanced.html deleted
      2024-04-22 15:47:03.415  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
      2024-04-22 15:47:03.486  - info: host.raspberrypi iobroker host.raspberrypi file vis-material-advanced.admin deleted
      2024-04-22 15:47:03.514  - info: host.raspberrypi iobroker host.raspberrypi object vis-material-advanced deleted
      2024-04-22 15:47:03.576  - info: host.raspberrypi iobroker host.raspberrypi object vis-material-advanced.admin deletedhost.raspberrypi Deleting 3 object(s).
      2024-04-22 15:47:03.726  - info: host.raspberrypi object deleted system.adapter.vis-material-advanced.0
      2024-04-22 15:47:03.731  - info: host.raspberrypi iobroker host.raspberrypi Deleting 1 state(s).
      2024-04-22 15:47:08.787  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 flot
      2024-04-22 15:47:08.824  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 vis.0
      2024-04-22 15:47:08.827  - info: web.0 (1257) <== Disconnect system.user.admin from ::ffff:192.168.1.61 flot
      2024-04-22 15:47:11.243  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
      2024-04-22 15:47:12.265  - info: web.0 (1257) ==> Connected system.user.admin from ::ffff:192.168.1.61
      2024-04-22 15:47:19.819  - info: vis.0 (1239) Uploaded. 0
      2024-04-22 15:47:20.142  - info: host.raspberrypi iobroker removed 1 package in 15s266 packages are looking for funding  run `npm fund` for details
      2024-04-22 15:47:20.273  - info: host.raspberrypi "system.adapter.vis.0" disabled
      2024-04-22 15:47:20.274  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
      2024-04-22 15:47:20.302  - info: host.raspberrypi "system.adapter.vis.0" enabled
      2024-04-22 15:47:20.302  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
      2024-04-22 15:47:20.307  - info: host.raspberrypi iobroker Adapter "system.adapter.vis.0" restarted.
      2024-04-22 15:47:20.335  - info: vis.0 (1239) Terminated (NO_ERROR): Without reason
      2024-04-22 15:47:20.983  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
      2024-04-22 15:47:21.349  - info: host.raspberrypi iobroker exit 0
      ============ Mark until here for C&P =============```
        Lollo_C @Clyde last edited by Lollo_C
        @clyde sagte in ioBroker friert ein: "Request actual repository...".....:
        @lollo_c Bist du schon schlauer geworden?
        Wie ich weiter oben angekündigt hatte, habe ich den Fehler genutzt und meine Hardware umgestellt. Der Master läuft nun auf einem Raspberry Pi 5 mit 8 GB und der Slave auf einem Raspberry Pi 4 mit 4 GB.
        Das System läuft nun seit über einer Woche ohne Probleme, obwohl jeden Tag auf Updates überprüft wird.
        Das "alte" System läuft noch leer nebenher und ich denke mal, dass er in 2 Tagen wieder einfrieren wird. Dann sind die 14 Tage um und er wird wieder nach Updates suchen wollen.
          Thomas Braun Most Active @Clyde last edited by
          @clyde
          Stell es auf ein reines 64Bit 'Bookworm' um.
          Und 2GB RAM sind für einen 'normalen' Betrieb unterdimensioniert.
          Dann hast du Einschläge auf dem Dateisystem:
          Bei den ioBroker-Adaptern herrscht Update-Stau.
            Clyde @Thomas Braun last edited by Clyde
            @thomas-braun lief über Jahre mit den 2 GB.
            Wie stelle ich auf Bookworm um?
            Vor zwei Wochen alles geupdadet, aber ja, müsste ich mal wieder machen.
            Was bedeutet das mit den Einschlägen? 18:06 am 20. April war übrigens direkt zum Reboot nach dem letzten Hänger. Also beim Hochfahren nach dem Fehler und dementsprechend eher nicht ursächlich.
              Das ist immer so. Irgendwann läuft es eben nicht mehr.
              Komplette Neuinstallation, weil du da im Userland auf 32Bit hängst.
              Dann machst du es deutlich zu selten. Die 8 Updates sind doch nicht alle aus den letzten zwei Wochen? Nicht im Stable-Repo...
              Das bedeutet, dass nach deiner Exekution durch Stromentzug das System einige Dateien nicht wieder reanimieren konnte und die beerdigt/gelöscht hat.
              Nö, vielleicht nicht, aber da hat es die nächsten Rumms im Dateisystem gegeben, trägt alles nicht zu einem stabilen System bei. Im Gegenteil.
                Alle zwei Wochen ist zu selten? Dachte eigentlich, dass iobroker für mich arbeitet und nicht umgekehrt. Bis auf den Fronius-Adapter war vor zwei Wochen alles aktuell. Bei dem gibt es wohl ein größere Update mit Objektänderungen, was ich mal irgendwann mache, wenn ich mehr Zeit habe.
                Vermutlich dann im Zuge der 64-Bit-Umstellung.
                Der "Einschlag" war wie gesagt nach dem harten Reset; vermutlich einfach dem geschuldet. Was bleibt: "wir haben keine Ahnung, also Neuinstallation." Ärgerlich aber nach ein paar Jahren ohne Probleme wohl mal verschmerzbar.
                Thomas Braun Homoran Codierknecht 3 Replies Last reply Reply Quote 0
                  Ich habe genug Ahnung und ich sage dir, das eine Umstellung des Userlands von 32Bit auf 64Bit nicht per Upgrade sondern nur per kompletter Neuinstallation geht.
                  Und meine Ahnung lässt mich auch wissen, das gelöschte Inodes halt gelöscht sind und nicht wiederhergestellt werden konnten. Auch das bekommst du nur durch eine Neuinstallation und Einspielen eines hoffentlich vorhandenen Backups geheilt.
                    Homoran Global Moderator Administrators @Clyde last edited by
                    dann ist gut,
                    @thomas-braun sagte in ioBroker friert ein: "Request actual repository...".....:
                    ich habe im stable keine 8 updates in den letzten 2 Wochen gehabt, höchstens 3.
                    nicht ernst gemeint, oder doch?
                    • Codierknecht
                      Codierknecht Developer Most Active @Clyde last edited by
                      Was - wenn auch mit einem gewissen Risiko verbunden - auch noch gehen würde, wäre ein automatisches Update per Script.
                      Wenn man eh nur alles durchwinken würde, kommt das aufs Gleiche raus.
                      Damit lassen sich sowohl die Adapter als auch das OS immer aktuell halten.
                        leif1 last edited by
                        Ich hab ein ähnliches Problem. Bei mir läuft es auf einem ausgemusterten Laptop unter Debian Bookworm im Docker / Portainer.
                        crash log:
                        2024-05-24 03:40:29.848 - info: admin.0 (168) Request actual repository...
                        2024-05-24 03:40:30.341 - info: host.b925cd8b2911 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                        2024-05-24 03:40:34.189 - error: sonoff.0 (472) Objects database error: read ECONNRESET
                        2024-05-24 03:40:34.186 - error: zigbee.0 (502) Objects database error: read ECONNRESET
                        2024-05-24 03:40:39.163 - error: bambulab.0 (113047) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2024-05-24 03:40:39.164 - error: bambulab.0 (113047) States database error: connect ECONNREFUSED 127.0.0.1:9000
                        2024-05-24 03:40:39.180 - error: bambulab.1 (648) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        2024-05-24 03:40:39.191 - error: mqtt.1 (429) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        iob diag
                        Skript v.2024-04-21
                        *** BASE SYSTEM ***
                        Hardware Vendor : Timi
                        Kernel          : x86_64
                        Userland        : 64 bit
                        Docker          : v9.1.2
                        Virtualization  : Docker
                        Kernel          : x86_64
                        Userland        : 64 bit
                         17:05:23 up 43 days, 14:40,  0 user,  load average: 0.43, 0.38, 0.35
                        CPU threads: 4
                        Fri May 24 15:05:23 UTC 2024
                        Fri May 24 17:05:23 CEST 2024
                        CEST +0200
                        Etc/UTC
                        *** Users and Groups ***
                        User that called 'iob diag':
                        root
                        HOME=/root
                        GROUPS=root
                        iobroker
                        HOME=/opt/iobroker
                        GROUPS=iobroker tty dialout audio video
                        *** Display-Server-Setup ***
                        pgrep: pattern that searches for process name longer than 15 characters will result in zero matches
                        Try `pgrep -f' option to match against the complete command line.
                        Display-Server: false
                        Desktop:
                        Terminal:
                        *** MEMORY ***
                        Mem:            4.0G        3.1G        183M         47M        993M        881M
                        Swap:           1.0G        536M        488M
                        Total:          5.0G        3.6G        671M
                        Active iob-Instances:   25
                                 3798 M total memory
                                 2958 M used memory
                                  573 M active memory
                                 2585 M inactive memory
                                  174 M free memory
                                   79 M buffer memory
                                  868 M swap cache
                                  976 M total swap
                                  511 M used swap
                                  465 M free swap
                        top - 17:05:23 up 43 days, 14:40,  0 user,  load average: 0.43, 0.38, 0.35
                        Tasks:  34 total,   1 running,  33 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3798.3 total,    173.9 free,   2958.8 used,    947.8 buff/cache
                        MiB Swap:    977.0 total,    465.5 free,    511.5 used.    839.5 avail Mem
                        *** FILESYSTEM ***
                        Filesystem     Type     Size  Used Avail Use% Mounted on
                        overlay        overlay  116G   13G   97G  12% /
                        tmpfs          tmpfs     64M     0   64M   0% /dev
                        shm            tmpfs     64M     0   64M   0% /dev/shm
                        /dev/sda2      ext4     116G   13G   97G  12% /opt/iobroker
                        tmpfs          tmpfs    1.9G     0  1.9G   0% /proc/asound
                        tmpfs          tmpfs    1.9G     0  1.9G   0% /proc/acpi
                        tmpfs          tmpfs    1.9G     0  1.9G   0% /sys/firmware
                        tmpfs          tmpfs    1.9G     0  1.9G   0% /sys/devices/virtual/powercap
                        dmesg: read kernel buffer failed: Operation not permitted
                        Show mounted filesystems:
                        /                                 overlay        overlay rw,relatime,lowerdir=/var/lib/docker/overlay2/l/GTMQFZAWFB26W5VQ7BYDASQVNN:/var/lib/docker/overlay2/l/PGLBUKV6RIHYO232G6QI7C3LHM:                                                           /var/lib/docker/overlay2/l/ANPZ2SFP5FKYIIQU2B5PRFNLK2:/var/lib/docker/overlay2/l/TGZICKKI2EYDBDS7HLFBWY4MIT:/var/lib/docker/overlay2/l/3LUUBBYV                                                           GGC76HFJYEFVCBNGHX:/var/lib/docker/overlay2/l/RHORYH5P4PDYH2KBWPSUT3GDLP,upperdir=/var/lib/docker/overlay2/ed6e0cf52866c709d8ca41e6467e95c2841c                                                           2aca934dcd7ce9fac355a5322f12/diff,workdir=/var/lib/docker/overlay2/ed6e0cf52866c709d8ca41e6467e95c2841c2aca934dcd7ce9fac355a5322f12/work
                        |-/proc                           proc        proc    rw,nosuid,nodev,noexec,relatime
                        | |-/proc/bus                     proc[/bus]        proc    ro,nosuid,nodev,noexec,relatime
                        | |-/proc/fs                      proc[/fs]        proc    ro,nosuid,nodev,noexec,relatime
                        | |-/proc/irq                     proc[/irq]        proc    ro,nosuid,nodev,noexec,relatime
                        | |-/proc/sys                     proc[/sys]        proc    ro,nosuid,nodev,noexec,relatime
                        | |-/proc/sysrq-trigger           proc[/sysrq-trigger]        proc    ro,nosuid,nodev,noexec,relatime
                        | |-/proc/asound                  tmpfs        tmpfs   ro,relatime,inode64
                        | |-/proc/acpi                    tmpfs        tmpfs   ro,relatime,inode64
                        | |-/proc/kcore                   tmpfs[/null]        tmpfs   rw,nosuid,size=65536k,mode=755,inode64
                        | |-/proc/keys                    tmpfs[/null]        tmpfs   rw,nosuid,size=65536k,mode=755,inode64
                        | `-/proc/timer_list              tmpfs[/null]        tmpfs   rw,nosuid,size=65536k,mode=755,inode64
                        |-/dev                            tmpfs        tmpfs   rw,nosuid,size=65536k,mode=755,inode64
                        | |-/dev/pts                      devpts        devpts  rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
                        | |-/dev/mqueue                   mqueue        mqueue  rw,nosuid,nodev,noexec,relatime
                        | `-/dev/shm                      shm        tmpfs   rw,nosuid,nodev,noexec,relatime,size=65536k,inode64
                        |-/sys                            sysfs        sysfs   ro,nosuid,nodev,noexec,relatime
                        | |-/sys/fs/cgroup                cgroup        cgroup2 ro,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                        | |-/sys/firmware                 tmpfs        tmpfs   ro,relatime,inode64
                        | `-/sys/devices/virtual/powercap tmpfs        tmpfs   ro,relatime,inode64
                        |-/opt/iobroker                   /dev/sda2[/var/lib/docker/volumes/iobroker/_data]        ext4    rw,relatime,errors=remount-ro
                        |-/etc/resolv.conf                /dev/sda2[/var/lib/docker/containers/5841fce69162b678a2fb22a62d339d1ded9c22a653176dd9d649a5c329065cfd/resolv.                                                           conf] ext4    rw,relatime,errors=remount-ro
                        |-/etc/hostname                   /dev/sda2[/var/lib/docker/containers/5841fce69162b678a2fb22a62d339d1ded9c22a653176dd9d649a5c329065cfd/hostnam                                                           e]    ext4    rw,relatime,errors=remount-ro
                        `-/etc/hosts                      /dev/sda2[/var/lib/docker/containers/5841fce69162b678a2fb22a62d339d1ded9c22a653176dd9d649a5c329065cfd/hosts]        ext4    rw,relatime,errors=remount-ro
                        /var:
                        34M     /var/
                        32M     /var/lib
                        19M     /var/lib/apt/lists
                        19M     /var/lib/apt
                        13M     /var/lib/dpkg
                        212M    /opt/iobroker/backups/
                        573M    /opt/iobroker/iobroker-data/
                        434M    /opt/iobroker/iobroker-data/files
                        142M    /opt/iobroker/iobroker-data/files/vis-2
                        138M    /opt/iobroker/iobroker-data/files/javascript.admin
                        118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map
                        21M     /opt/iobroker/iobroker-data/objects.jsonl
                        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
                        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
                        USB-Devices by-id:
                        No Devices found 'by-id'
                        HINT:
                        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                        /dev/ttyUSB0
                        /usr/bin/npm            10.5.2
                        /usr/bin/npx            10.5.2
                        nodejs:
                          Candidate: 18.20.3-1nodesource1
                          Version table:
                             18.20.3-1nodesource1 1001
                               1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                         *** 18.20.2-1nodesource1 1001
                             18.20.1-1nodesource1 1001
                             18.20.0-1nodesource1 1001
                             18.19.1-1nodesource1 1001
                             18.19.0+dfsg-6~deb12u1 500
                                500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                             18.19.0-1nodesource1 1001
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0+dfsg1-1 500
                                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.13.16
                        javascript:     8.3.1
                        nodejs modules from github:     2
                        +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#fd28f98d7ec46f36f4a2dae2d9ac740966453704)
                        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : b925cd8b2911                             -  enabled, port: 8081, bind: 0.0.                                                           0.0, run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : b925cd8b2911                             -  enabled
                        + system.adapter.alexa2.1                 : alexa2                : b925cd8b2911                             -  enabled
                        + system.adapter.backitup.0               : backitup              : b925cd8b2911                             -  enabled
                        + system.adapter.bambulab.0               : bambulab              : b925cd8b2911                             -  enabled, port: 8883
                        + system.adapter.bambulab.1               : bambulab              : b925cd8b2911                             -  enabled, port: 8883
                        + system.adapter.broadlink2.0             : broadlink2            : b925cd8b2911                             -  enabled
                        + system.adapter.discovery.0              : discovery             : b925cd8b2911                             -  enabled
                        + system.adapter.hue.0                    : hue                   : b925cd8b2911                             -  enabled, port: 80
                        + system.adapter.influxdb.0               : influxdb              : b925cd8b2911                             -  enabled, port: 8086
                          system.adapter.info.0                   : info                  : b925cd8b2911                             - disabled
                        + system.adapter.iot.0                    : iot                   : b925cd8b2911                             -  enabled
                        + system.adapter.javascript.0             : javascript            : b925cd8b2911                             -  enabled
                          system.adapter.mihome.0                 : mihome                : b925cd8b2911                             - disabled, port: 9898, bind: 0.0.                                                           0.0
                        + system.adapter.mqtt.1                   : mqtt                  : b925cd8b2911                             -  enabled, port: 1883, bind: 0.0.                                                           0.0
                        + system.adapter.node-red.0               : node-red              : b925cd8b2911                             -  enabled, port: 1880, bind: 0.0.                                                           0.0
                          system.adapter.parcel.0                 : parcel                : b925cd8b2911                             - disabled
                          system.adapter.radar2.0                 : radar2                : b925cd8b2911                             - disabled
                        + system.adapter.samsung.0                : samsung               : b925cd8b2911                             -  enabled
                        + system.adapter.scenes.0                 : scenes                : b925cd8b2911                             -  enabled
                        + system.adapter.simple-api.0             : simple-api            : b925cd8b2911                             -  enabled, port: 8087, bind: 0.0.                                                           0.0, run as: admin
                        + system.adapter.sonoff.0                 : sonoff                : b925cd8b2911                             -  enabled, port: 1884, bind: 0.0.                                                           0.0
                        + system.adapter.telegram.0               : telegram              : b925cd8b2911                             -  enabled, port: 8443, bind: 0.0.                                                           0.0
                        + system.adapter.text2command.0           : text2command          : b925cd8b2911                             -  enabled
                        + system.adapter.tuya.0                   : tuya                  : b925cd8b2911                             -  enabled
                          system.adapter.tuya.1                   : tuya                  : b925cd8b2911                             - disabled
                          system.adapter.vis-2.0                  : vis-2                 : b925cd8b2911                             - disabled
                        + system.adapter.web.0                    : web                   : b925cd8b2911                             -  enabled, port: 8082, bind: 0.0.                                                           0.0, run as: admin
                        + system.adapter.wled.0                   : wled                  : b925cd8b2911                             -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : b925cd8b2911                             -  enabled, port: /dev/ttyUSB0
                        + instance is alive
                        Stable (default): http://download.iobroker.net/sources-dist.json
                        Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                        Active repo(s): Stable (default)
                        Used repository: Stable (default)
                        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                        Adapter    "broadlink2"   : 2.2.0    , installed 2.2.0
                        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                        Adapter    "hue"          : 3.11.0   , installed 3.11.0
                        Adapter    "iot"          : 3.2.2    , installed 3.2.2
                        Adapter    "javascript"   : 8.3.1    , installed 8.3.1
                        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                        Adapter    "radar2"       : 2.2.0    , installed 2.2.0
                        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                        Adapter    "telegram"     : 3.2.1    , installed 3.2.1
                        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
                        Adapter    "wled"         : 0.7.2    , installed 0.7.2
                        Adapter    "ws"           : 2.6.1    , installed 2.6.1
                        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                        Objects and States
                        Objects:        13854
                        States:         12028
                        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                        Pending Updates: 13
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       34915000   -
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       34917401   -
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       34917908   -
                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       34917657   -
                        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       34918648   -
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       34918283   -
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       34915677   -
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       34918931   -
                        udp        0      0 0.0.0.0:57826           0.0.0.0:*                           1000       34916954   -
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       34918034   -
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       34918035   -
                        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       34918439   -
                        udp        0      0 0.0.0.0:40108           0.0.0.0:*                           1000       34916955   -
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       34918297   -
                        2024-05-24 17:04:29.639  - warn: bambulab.0 (518) Connection to Printer closed
                        2024-05-24 17:04:30.173  - info: mqtt.1 (401) Client [ParticleSensor] connection closed: timeout
                        2024-05-24 17:04:30.610  - info: mqtt.1 (401) Client [ParticleSensor] connected with secret 1716563070606_743
                        2024-05-24 17:04:53.112  - info: mqtt.1 (401) Client [ParticleSensor] connection closed: timeout
                        2024-05-24 17:04:53.519  - info: mqtt.1 (401) Client [ParticleSensor] connected with secret 1716563093518_3560
                        2024-05-24 17:04:53.990  - error: bambulab.1 (632) Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.155:8883
                        2024-05-24 17:04:53.991  - warn: bambulab.1 (632) Connection to Printer closed
                        2024-05-24 17:05:02.694  - error: bambulab.0 (518) Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.147:8883
                        2024-05-24 17:05:02.695  - warn: bambulab.0 (518) Connection to Printer closed
                        2024-05-24 17:05:04.755  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                        2024-05-24 17:05:04.761  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                        2024-05-24 17:05:16.020  - info: mqtt.1 (401) Client [ParticleSensor] connection closed: timeout
                        2024-05-24 17:05:17.520  - info: mqtt.1 (401) Client [ParticleSensor] connected with secret 1716563117516_3832
                        2024-05-24 17:05:19.756  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                        2024-05-24 17:05:19.762  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                        2024-05-24 17:05:22.463  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                        2024-05-24 17:05:22.467  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                        2024-05-24 17:05:27.046  - error: bambulab.1 (632) Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.155:8883
                        2024-05-24 17:05:27.047  - warn: bambulab.1 (632) Connection to Printer closed
                        2024-05-24 17:05:35.750  - error: bambulab.0 (518) Connection issue occurred Error: connect EHOSTUNREACH 192.168.178.147:8883
                        2024-05-24 17:05:35.751  - warn: bambulab.0 (518) Connection to Printer closed
                        2024-05-24 17:05:37.465  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                        2024-05-24 17:05:37.468  - warn: javascript.0 (231) script.js.Telegram_Menu.Statuslicht: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                        2024-05-24 17:05:40.021  - info: mqtt.1 (401) Client [ParticleSensor] connection closed: timeout
                        2024-05-24 17:05:42.673  - info: mqtt.1 (401) Client [ParticleSensor] connected with secret 1716563142672_6098
                        (die Bambus sind derzeit nicht aktiv gewesen, daher deren Fehler)
                        • Codierknecht
                          Codierknecht Developer Most Active @leif1 last edited by
                          @leif1 sagte in ioBroker friert ein: "Request actual repository...".....:
                          Und welches genau?
                          Pending Updates: 13
                            leif1 @Codierknecht last edited by leif1
                            @codierknecht said in ioBroker friert ein: "Request actual repository...".....:
                            Und welches genau?
                            Dass sich der ioBroker einfach nach
                            beendet.
                            Pending Updates: 13
                            Die sind nun auf 0. Aber sollte es daran gelegen haben dass ein paar Wochen keine Updates durchgeführt wurden (ca 4-5, die Installation ist noch nicht alt) wäre es ja schon reichlich ungünstig wenn nicht sofort durchgeführte Updates das komplette SmartHome lahmlegen können.
                            In den Jahren zuvor, auf dem Raspi ohne Docker / Portainer, hatte ich das Problem noch nicht. Erscheint mir schon ungewöhnlich und nicht normal.
                              Thomas Braun Most Active @leif1 last edited by
                              @leif1
                              Ich würde ja glatt behaupten, das hängt mit den Eigen- und Besonderheiten von Docker und Portainer zusammen. Da müssen gewisse Dinge anders gemacht werden.
                                leif1 @Thomas Braun last edited by
                                @thomas-braun said in ioBroker friert ein: "Request actual repository...".....:
                                @leif1
                                Danke für den Input, das klingt so als wenn ich nochmal etwas Zeit in die Pro-/Kontra Abwägung bezüglich Docker investieren und meine Entscheidung evtl. noch einmal überdenken sollte.
                                • Meister Mopper
                                  Meister Mopper @leif1 last edited by
                                  Du musst doch nur eine Entscheidung treffen, in welche Richtung du lernen möchstest.
                                  Übrigens, die optimale Lösung wäre in alle Richtungen, dann könntest du allen helfen! 😉
                                    leif1 @Meister Mopper last edited by leif1
                                    @meister-mopper
                                    Für noch mehr Hobbys fehlt mir leider die Zeit - in sofern ist die Zeit für Linux beschränkt. In erster Linie soll das SmartHome laufen, und nicht mehr Zeit kosten als es ohne würde. Bzw sollte es im Idealfall Probleme selbst erkennen und zumindest eigenständig einen restart durchführen können - gerade in dem Bereich eines SmartHomes solltes dies doch die oberste Priorität haben dass so wenig wie möglich zu einem totalen Ausfall des Systems führen kann.
                                    Ich bin auf autoheal gestoßen, aber wenn man die Diskussionen dazu ließt scheint das auch nicht zuverlässig zu funktionieren. Da fragt man sich wieso es einen Health Status gibt, wenn es dann an so etwas simplen wie einem automatische restart scheitert.
                                    Heute hatte ich wieder einen Ausfall nach:
                                    "2024-05-27 16:54:14.301 - info: host.b925cd8b2911 Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json""
                                    Bin der letzte der nicht auch gern mal nach einem Problem tiefer taucht, aber die Fehlermeldung ist halt nicht wirklich hilfreich wenn das alles ist was man bekommt. Ich mein warum sollte ein laufendes System sich selbst beenden, nur weil ein Update Versuch fehlschlägt. Gib ne Fehlermeldung dass so etwas nicht funktioniert - aber ein crash und beenden des Dienstes? Klingt für mich nicht logisch. Warum schlägt dieser fehl? Ergibt sich mir aus der Fehlermeldung auch nicht.
                                    Die Konnektivität zum repository ist gegeben - daran kann es nicht liegen. Aufgesetzt wurde es damals nach einem Guide - der hoffentlich auch stimmte. Dieses Mal war das System außerdem up to date, also kann es daran auch nicht liegen.
                                    Also komm ich als Linux Laie zu dem Fazit dass ioBroker offenbar für den 08/15 Anwender ohne Docker zuverlässiger läuft. Ohne es irgendwie bös zu meinen, aber getreu dem KISS Prinzip ... keep it simple. Jede extra Ebene schafft offenbar nur mehr potentielle Probleme.
                                    Werd's die Tage nochmal ohne aufsetzen und dann hoffentlich Ruhe haben.
                                    81
                                    5108
