    4. Alpha Test js-controller Kiera (v6.0)
      Thomas Braun Most Active @foxriver76 last edited by
      @foxriver76 sagte in Alpha Test js-controller Kiera (v6.0):
      @thomas-braun https://forum.iobroker.net/topic/74822/alpha-test-js-controller-kiera-v6-0/100 hast du gesehen?
      Ja, aber noch nicht testen können. Kein gescheites Terminal zur Hand, nur eine Android-App und mit der will ich nix aufwändigeres per SSH machen.
      • foxriver76
        An alle: bitte nochmal updaten
        A F T 3 Replies Last reply Reply Quote 2
          ag @foxriver76 last edited by
          @foxriver76
          js-controller 6.01 auf dem testsystem läuft alles wieder.
          Beim Start der Instamcen nach reboot oder iobroker start.
          2024-05-24 18:16:06.510 - info: host.RPI5Test instance system.adapter.daikin.0 started with pid 1646
          2024-05-24 18:16:07.191 - error: daikin.0 (1646) daikin.0 invalid instance object: {"_id":"","type":"device","common":{},"native":{}}
          2024-05-24 18:16:07.232 - info: daikin.0 (1646) starting. Version 1.4.2 in /opt/iobroker/node_modules/iobroker.daikin, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240524-14a872375
          2024-05-24 18:16:08.169 - info: daikin.0 (1646) Daikin Device initialized successfully
          2024-05-24 18:16:08.170 - info: daikin.0 (1646) Set polling Intervall to 300s
          Adapter funktiniert aber danach
            Fortune95 @foxriver76 last edited by
            @foxriver76
            Aktuelle Version läuft.
            Nur der Adapter Heatingcontrol läuft nicht an:
            2024-05-24 18:21:38.650  - error: host.iobroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-co        re/build/controllerTools.js:83
            2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
            2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]:     ^
            2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
            2024-05-24 18:21:38.651  - error: host.iobroker Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_m        odules/@iobroker/adapter-core/build/controllerTools.js:83:11)
            2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_m        odules/@iobroker/adapter-core/build/controllerTools.js:157:18)
            2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
            2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
            2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
            2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
            2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
            2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
            2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_m        odules/@iobroker/adapter-core/build/index.js:19:27)
            2024-05-24 18:21:38.652  - error: host.iobroker Caught by controller[0]: Node.js v20.13.1
            2024-05-24 18:21:38.652  - error: host.iobroker instance system.adapter.heatingcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            Adapter Instanzen:
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
            + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
              system.adapter.devices.0                : devices               : iobroker                                 - disabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
            + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
              system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 - disabled
              system.adapter.esphome.0                : esphome               : iobroker                                 - disabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
              system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
            + system.adapter.gruenbeck.0              : gruenbeck             : iobroker                                 -  enabled
              system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 - disabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
              system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 - disabled
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.jeelink.0                : jeelink               : iobroker                                 -  enabled
            + system.adapter.klf200.0                 : klf200                : iobroker                                 -  enabled
            + system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled
              system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
            + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.12.219
              system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 0.0.0.0
            + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled
            + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
            + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
            + system.adapter.selverf.0                : selverf               : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1895, bind: 192.168.12.219
            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
            + system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
            + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
              system.adapter.vis-2.0                  : vis-2                 : iobroker                                 - disabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
            + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
            + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.12.212:6638
              TT-Tom @Fortune95 last edited by TT-Tom
              @fortune95
              Da hilft npm update unter /opt/iobroker hatte den Fehler auch
              https://forum.iobroker.net/post/1162312
              https://forum.iobroker.net/post/1161997
              • foxriver76
                foxriver76 Developer @TT-Tom last edited by
                @tt-tom hm sollte jetzt eigentlich automatisch ausgeführt werden bei install der neusten Version 6.0.1-alpha.0-20240524-14a872375
                  TT-Tom @foxriver76 last edited by
                  @foxriver76
                  Kann es persönlich erst heute Nacht noch einmal testen.
                  • foxriver76
                    Ansonsten bitte nochmal updaten und log von update zeigen
                    F Thomas Braun Feuersturm 3 Replies Last reply Reply Quote 0
                      @foxriver76
                      Habs versucht geht aber immer noch nicht.
                      Update hat auch nichhts gefunden...
                      iobroker@iobroker:/opt/iobroker$ npm update
                      up to date in 2m
                      207 packages are looking for funding
                        run `npm fund` for details
                        Thomas Braun Most Active @foxriver76 last edited by Thomas Braun
                        @foxriver76
                        Hier sind die Meldungen bzgl. letsencrypt wieder zurück.
                        Exemplarisch:
                        2024-05-24 18:58:01.008  - error: host.chet Caught by controller[0]: /opt/iobroker/node_modules/iobroker.whatsapp-cmb/node_modules/@iobroker/adapter-core/build/controllerTools.js:94
                        2024-05-24 18:58:01.010  - error: host.chet Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                        2024-05-24 18:58:01.010  - error: host.chet Caught by controller[0]:     ^
                        2024-05-24 18:58:01.011  - error: host.chet Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                        2024-05-24 18:58:01.011  - error: host.chet Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.whatsapp-cmb/node_modules/@iobroker/adapter-core/build/controllerTools.js:94:11)
                        2024-05-24 18:58:01.011  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.whatsapp-cmb/node_modules/@iobroker/adapter-core/build/controllerTools.js:137:18)
                        2024-05-24 18:58:01.012  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1434:14)
                        2024-05-24 18:58:01.012  - error: host.chet Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1518:10)
                        2024-05-24 18:58:01.012  - error: host.chet Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1249:32)
                        2024-05-24 18:58:01.012  - error: host.chet Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1065:12)
                        2024-05-24 18:58:01.012  - error: host.chet Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1271:19)
                        2024-05-24 18:58:01.013  - error: host.chet Caught by controller[0]:     at require (node:internal/modules/helpers:123:16)
                        2024-05-24 18:58:01.013  - error: host.chet Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.whatsapp-cmb/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                        2024-05-24 18:58:01.013  - error: host.chet Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1434:14)
                        2024-05-24 18:58:01.013  - error: host.chet Caught by controller[0]: Node.js v22.2.0
                        2024-05-24 18:58:01.013  - error: host.chet instance system.adapter.whatsapp-cmb.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        Betrifft aber auch weitere Adapter, mit gleichen Meldungen.
                        • foxriver76
                          foxriver76 Developer @Thomas Braun last edited by
                          @thomas-braun hast du zufällig das log von der Installation parat?
                          mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
                          • mcm1957
                            mcm1957 @foxriver76 last edited by mcm1957
                            @foxriver76
                            Ich kann das Update noch starten (allerdings windows) (via npm i ...)
                            Wie erstelle ich das beste log ?
                            Nur den Screen loggen?
                              @foxriver76
                              Nee, aber da stand auch nix drin. Das ist offenbar bei npm 10.7.0 radikal gekürzt worden. Jedenfalls das nach STDOUT geschriebene. Muss mal schauen wo das ganze Ding genau landet.
                              • foxriver76
                                foxriver76 Developer @mcm1957 last edited by
                                @mcm1957 ja sollte reichen, Windows bin ich sowieso gespannt
                                • mcm1957
                                  @foxriver76
                                  Soda:
                                  Mal Snapshot während er mit npm rumnuckelt ...
                                  Ansonsten ist er seht schweigsam:
                                  ***               Welcome to ioBroker.                 ***
                                  ***     Type 'iob help' for list of instructions.      ***
                                  ***                For more help see                   ***
                                  ***     https://github.com/ioBroker/ioBroker.docs      ***
                                  Your environment has been set up for using Node.js 20.13.1 (x64) and npm.
                                  C:\ioBroker>npm i iobroker.js-controller@next --omit=dev
                                  changed 12 packages, and audited 619 packages in 2m
                                  72 packages are looking for funding
                                  26 vulnerabilities (21 moderate, 5 high)
                                  To address issues that do not require attention, run:
                                    npm audit fix
                                  To address all issues possible (including breaking changes), run:
                                    npm audit fix --force
                                  Some issues need review, and may require choosing
                                  a different dependency.
                                  Run `npm audit` for details.
                                  C:\ioBroker>
                                  Im Log nix auffälligs, system läuft soweit (mal grob gechecked)
                                  ical.1
                                  2024-05-24 19:18:16.241	warn	Error reading from URL "http://11111.ics"
                                  ical.1
                                  2024-05-24 19:18:15.892	info	starting. Version 1.15.0 in C:/ioBroker/node_modules/iobroker.ical, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240524-14a872375
                                  host.Envy
                                  2024-05-24 19:18:14.133	info	instance system.adapter.ical.1 started with pid 1604
                                  host.Envy
                                  2024-05-24 19:18:14.125	info	instance scheduled system.adapter.ical.1 0,4 0,30 * * * *
                                  host.Envy
                                  2024-05-24 19:18:11.929	info	Restart adapter system.adapter.notification-manager.0 because enabled
                                  host.Envy
                                  2024-05-24 19:18:11.928	error	instance system.adapter.notification-manager.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                  2024-05-24 19:18:11.379	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                  2024-05-24 19:18:11.377	error	notification-manager.0 already running
                                  host.Envy
                                  2024-05-24 19:18:10.032	info	instance system.adapter.notification-manager.0 started with pid 17028
                                  host.Envy
                                  2024-05-24 19:18:07.928	info	Restart adapter system.adapter.backitup.0 because enabled
                                  host.Envy
                                  2024-05-24 19:18:07.928	error	instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                  backitup.0
                                  2024-05-24 19:18:07.378	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                  backitup.0
                                  2024-05-24 19:18:07.377	error	backitup.0 already running
                                  host.Envy
                                  2024-05-24 19:18:06.016	info	instance system.adapter.backitup.0 started with pid 1772
                                  host.Envy
                                  2024-05-24 19:18:04.960	info	Restart adapter system.adapter.admin.0 because enabled
                                  host.Envy
                                  2024-05-24 19:18:04.960	error	instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                  admin.0
                                  2024-05-24 19:18:04.388	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                  admin.0
                                  2024-05-24 19:18:04.386	error	admin.0 already running
                                  host.Envy
                                  2024-05-24 19:18:02.125	info	Some obsolete host states deleted.
                                  host.Envy
                                  2024-05-24 19:18:02.123	info	Delete state "system.host.Envy.versions.npmNewestNext"
                                  host.Envy
                                  2024-05-24 19:18:02.121	info	Delete state "system.host.Envy.versions.npmNewest"
                                  host.Envy
                                  2024-05-24 19:18:02.118	info	Delete state "system.host.Envy.versions.npmCurrent"
                                  host.Envy
                                  2024-05-24 19:18:02.112	info	Delete state "system.host.Envy.versions.nodeNewestNext"
                                  host.Envy
                                  2024-05-24 19:18:02.111	info	instance system.adapter.admin.0 started with pid 17072
                                  host.Envy
                                  2024-05-24 19:18:02.098	info	Delete state "system.host.Envy.versions.nodeNewest"
                                  host.Envy
                                  2024-05-24 19:18:02.086	info	Delete state "system.host.Envy.versions.nodeCurrent"
                                  host.Envy
                                  2024-05-24 19:18:01.693	info	starting 5 instances
                                  host.Envy
                                  2024-05-24 19:18:01.675	info	17 instances found
                                  host.Envy
                                  2024-05-24 19:18:01.188	info	added notifications configuration of host
                                  host.Envy
                                  2024-05-24 19:18:01.174	info	connected to Objects and States
                                  host.Envy
                                  2024-05-24 19:18:00.523	info	ip addresses: 10.17.2.100 fe80::3089:3ca1:e684:7494 10.17.2.16
                                  host.Envy
                                  2024-05-24 19:18:00.522	info	hostname: Envy, node: v20.13.1
                                  host.Envy
                                  2024-05-24 19:18:00.522	info	Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
                                  host.Envy
                                  2024-05-24 19:18:00.518	info	iobroker.js-controller version 6.0.1 js-controller starting
                                  • mcm1957
                                    mcm1957 @mcm1957 last edited by
                                    Wurde im js-controller nicht was mit npm update eingebaut?
                                    Wann sollte das denn laufen? npm wird das ja kaum triggern. Sollte da unter windows noch der fixer gestartet werden?
                                    • mcm1957
                                      Das Ganze noch mal mit verbose
                                      npm verb cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
                                      npm info using npm@10.5.2
                                      npm info using node@v20.13.1
                                      npm verb title npm i iobroker.js-controller@next
                                      npm verb argv "i" "iobroker.js-controller@next" "--omit" "dev" "--loglevel" "verbose"
                                      npm verb logfile logs-max:10 dir:C:\Users\MartinAdmin\AppData\Local\npm-cache\_logs\2024-05-24T17_27_06_077Z-
                                      npm verb logfile C:\Users\MartinAdmin\AppData\Local\npm-cache\_logs\2024-05-24T17_27_06_077Z-debug-0.log
                                      npm http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 993ms (cache revalidated)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-states-redis 30ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-objects-redis 51ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-objects-file 73ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-objects-jsonl 92ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-states-file 120ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-states-jsonl 145ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fjs-controller-adapter 163ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fplugin-base 88ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fjs-controller-cli 153ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fjs-controller-common 154ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fplugin-sentry 93ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/deep-clone 82ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fjs-controller-common-db 156ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/jsonwebtoken 80ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/pidusage 72ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/readline-sync 41ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/promisify-child-process 73ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@alcalzone%2fjsonl-db 28ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/node.extend 20ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-base 41ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/ioredis 59ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@alcalzone%2fpak 70ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/event-stream 60ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/readline 75ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/chokidar 83ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/ci-info 52ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/debug 96ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/winston-daily-rotate-file 46ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/triple-beam 63ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/node-forge 74ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/winston-transport 60ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/winston 79ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@datalust%2fwinston-seq 68ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/diskusage 63ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/winston-seq-updated 49ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/winston-syslog 58ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 54ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2fintegrations 75ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/jws 85ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/source-map-support 94ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lodash.includes 111ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lodash.isboolean 112ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lodash.isinteger 116ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lodash.isnumber 81ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lodash.isplainobject 69ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lodash.isstring 65ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lodash.once 58ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/ms 30ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/safe-buffer 26ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/respjs 8ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@alcalzone%2fproper-lockfile 14ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/alcalzone-shared 15ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/fs-extra 17ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/retry 19ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/signal-exit 21ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lodash.defaults 21ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/cluster-key-slot 26ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/denque 29ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lodash.flatten 41ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lodash.isarguments 46ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/p-map 48ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/redis-commands 51ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/redis-parser 41ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/redis-errors 46ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/standard-as-callback 39ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/is 30ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/axios 15ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/execa 29ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/npm-run-path 26ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/merge-stream 29ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/human-signals 32ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/strip-final-newline 32ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/onetime 34ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/glob-parent 33ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/is-binary-path 37ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/anymatch 42ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/braces 45ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/is-glob 50ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/readdirp 54ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/fsevents 57ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/duplexer 45ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/split 31ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/from 51ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/pause-stream 44ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/map-stream 55ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/stream-combiner 39ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/through 38ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@dabh%2fdiagnostics 29ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/seq-logging 36ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/one-time 38ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/logform 42ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@colors%2fcolors 47ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/safe-stable-stringify 50ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/readable-stream 56ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/es6-promise 60ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/nan 59ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/object-hash 56ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/glossy 52ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/file-stream-rotator 66ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/unix-dgram 53ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/localforage 32ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 44ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 65ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 83ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@sentry-internal%2ftracing 106ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 112ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 141ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/source-map 119ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 155ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/lie 8ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/fill-range 26ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/binary-extensions 29ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/picomatch 36ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/is-extglob 34ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/picomatch 35ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/to-regex-range 8ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/mimic-fn 12ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/is-number 10ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/jwa 9ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/kuler 34ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/enabled 40ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/fecha 33ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/@types%2ftriple-beam 40ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/fn.name 34ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/colorspace 52ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/text-hex 11ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/color 15ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/color-convert 11ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/color-string 13ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/simple-swizzle 18ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/color-name 22ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/color-name 24ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/is-arrayish 9ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/bindings 9ms (cache hit)
                                      npm http fetch GET 200 https://registry.npmjs.org/file-uri-to-path 10ms (cache hit)
                                      npm verb reify failed optional dependency C:\ioBroker\node_modules\fsevents
                                      npm http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/advisories/bulk 254ms
                                      npm http fetch GET 200 https://registry.npmjs.org/follow-redirects 97ms (cache revalidated)
                                      npm http fetch GET 200 https://registry.npmjs.org/request 182ms (cache revalidated)
                                      npm http fetch GET 200 https://registry.npmjs.org/ip 191ms (cache revalidated)
                                      npm http fetch GET 200 https://registry.npmjs.org/tough-cookie 210ms (cache revalidated)
                                      npm info run iobroker.js-controller@6.0.1-alpha.0-20240524-14a872375 preinstall node_modules/iobroker.js-controller node build/esm/lib/preinstallCheck.js
                                      npm http fetch GET 200 https://registry.npmjs.org/iobroker.broadlink2 626ms (cache revalidated)
                                      npm info run iobroker.js-controller@6.0.1-alpha.0-20240524-14a872375 preinstall { code: 0, signal: null }
                                      npm info run diskusage@1.2.0 install node_modules/diskusage node-gyp rebuild
                                      npm info run iobroker.js-controller@6.0.1-alpha.0-20240524-14a872375 install node_modules/iobroker.js-controller node iobroker.js setup first
                                      npm info run unix-dgram@2.0.6 install node_modules/unix-dgram node-gyp rebuild
                                      npm http fetch GET 200 https://registry.npmjs.org/mdns-discovery 642ms (cache revalidated)
                                      npm http fetch GET 200 https://registry.npmjs.org/dns-packet 58ms (cache revalidated)
                                      npm http fetch GET 200 https://registry.npmjs.org/node-ssdp 889ms (cache revalidated)
                                      npm http fetch GET 200 https://registry.npmjs.org/iobroker.kecontact 619ms (cache revalidated)
                                      npm http fetch GET 200 https://registry.npmjs.org/dropbox-v2-api 627ms (cache revalidated)
                                      npm http fetch GET 200 https://registry.npmjs.org/iobroker.discovery 255ms (cache revalidated)
                                      npm http fetch GET 200 https://registry.npmjs.org/iobroker.backitup 586ms (cache revalidated)
                                      npm info run unix-dgram@2.0.6 install { code: 1, signal: null }
                                      npm verb reify failed optional dependency C:\ioBroker\node_modules\unix-dgram
                                      npm verb reify failed optional dependency C:\ioBroker\node_modules\bindings
                                      npm verb reify failed optional dependency C:\ioBroker\node_modules\file-uri-to-path
                                      npm info run diskusage@1.2.0 install { code: 1, signal: null }
                                      npm verb reify failed optional dependency C:\ioBroker\node_modules\diskusage
                                      npm verb reify failed optional dependency C:\ioBroker\node_modules\es6-promise
                                      npm info run iobroker.js-controller@6.0.1-alpha.0-20240524-14a872375 install { code: 0, signal: null }
                                      removed 32 packages, changed 14 packages, and audited 619 packages in 1m
                                        npm audit fix
                                      npm verb exit 0
                                      npm info ok
                                      • mcm1957
                                        Und der iob fix
                                        C:\ioBroker>
                                        C:\ioBroker>del iobroker.bat
                                        C:\ioBroker>iob fix
                                        Windows installation starting... (fixing = true)
                                        NPM version: 10.5.2
                                        No path given, using C:\ioBroker\iobroker-data
                                        Compressing C:\ioBroker\iobroker-data\states.jsonl
                                        Compressing C:\ioBroker\iobroker-data\objects.jsonl
                                        Compressed 2 JSONL files. Done
                                        NPM version: 10.5.2
                                        Write "iobroker start" to start the ioBroker
                                        npm install node-windows@1.0.0-beta.8 --force --loglevel error --production --save --prefix "C:/ioBroker"
                                        up to date, audited 619 packages in 9s
                                          npm audit fix
                                        npm install dotenv@^16.3.1 --force --loglevel error --production --save --prefix "C:/ioBroker"
                                        up to date, audited 619 packages in 7s
                                          npm audit fix
                                        npm install windows-shortcuts@^0.1.6 --force --loglevel error --production --save --prefix "C:/ioBroker"
                                          npm audit fix
                                        Running Admin shell
                                        ioBroker service name: ioBroker
                                        ioBroker ist nicht gestartet.
                                        Sie erhalten weitere Hilfe, wenn Sie NET HELPMSG 3521 eingeben.
                                        Written iobnodevars.bat successfully.
                                        ioBroker service is already installed.
                                        Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Stop ioBroker Service.lnk" created with Admin flag!
                                        Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Start ioBroker Service.lnk" created with Admin flag!
                                        Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Restart ioBroker Service.lnk" created with Admin flag!
                                        Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Command line.lnk" created with Admin flag!
                                        Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Admin.lnk" created!
                                        Running Admin shell
                                        ioBroker wird gestartet.
                                        ioBroker wurde erfolgreich gestartet.
                                        ioBroker service installed and started. Go to http://localhost:8081 to open the admin UI.
                                        To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
                                        C:\ioBroker>
                                          Ich hab das volle Log. Aber das sind 4300 Zeilen. Krieg ich nirgends hochgeladen.
                                            @thomas-braun .txt
                                            alpha js-controller kiera test
                                            20
                                            234
                                            43337
