    4. Alpha Test js-controller Kiera (v6.0)
    • mcm1957
      mcm1957 @mcm1957 last edited by
      Das Ganze noch mal mit verbose
      npm verb cli C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js
      npm info using npm@10.5.2
      npm info using node@v20.13.1
      npm verb title npm i iobroker.js-controller@next
      npm verb argv "i" "iobroker.js-controller@next" "--omit" "dev" "--loglevel" "verbose"
      npm verb logfile logs-max:10 dir:C:\Users\MartinAdmin\AppData\Local\npm-cache\_logs\2024-05-24T17_27_06_077Z-
      npm verb logfile C:\Users\MartinAdmin\AppData\Local\npm-cache\_logs\2024-05-24T17_27_06_077Z-debug-0.log
      npm http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 993ms (cache revalidated)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-states-redis 30ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-objects-redis 51ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-objects-file 73ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-objects-jsonl 92ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-states-file 120ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-states-jsonl 145ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fjs-controller-adapter 163ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fplugin-base 88ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fjs-controller-cli 153ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fjs-controller-common 154ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fplugin-sentry 93ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/deep-clone 82ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fjs-controller-common-db 156ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/jsonwebtoken 80ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/pidusage 72ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/readline-sync 41ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/promisify-child-process 73ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@alcalzone%2fjsonl-db 28ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/node.extend 20ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@iobroker%2fdb-base 41ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/ioredis 59ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@alcalzone%2fpak 70ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/event-stream 60ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/readline 75ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/chokidar 83ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/ci-info 52ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/debug 96ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/winston-daily-rotate-file 46ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/triple-beam 63ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/node-forge 74ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/winston-transport 60ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/winston 79ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@datalust%2fwinston-seq 68ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/diskusage 63ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/winston-seq-updated 49ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/winston-syslog 58ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2fnode 54ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2fintegrations 75ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/jws 85ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/source-map-support 94ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lodash.includes 111ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lodash.isboolean 112ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lodash.isinteger 116ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lodash.isnumber 81ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lodash.isplainobject 69ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lodash.isstring 65ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lodash.once 58ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/ms 30ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/safe-buffer 26ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/respjs 8ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@alcalzone%2fproper-lockfile 14ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/alcalzone-shared 15ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/fs-extra 17ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/retry 19ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/signal-exit 21ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lodash.defaults 21ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/cluster-key-slot 26ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/denque 29ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lodash.flatten 41ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lodash.isarguments 46ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/p-map 48ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/redis-commands 51ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/redis-parser 41ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/redis-errors 46ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/standard-as-callback 39ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/is 30ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/axios 15ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/execa 29ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/npm-run-path 26ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/merge-stream 29ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/human-signals 32ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/strip-final-newline 32ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/onetime 34ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/glob-parent 33ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/is-binary-path 37ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/anymatch 42ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/braces 45ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/is-glob 50ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/readdirp 54ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/fsevents 57ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/duplexer 45ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/split 31ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/from 51ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/pause-stream 44ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/map-stream 55ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/stream-combiner 39ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/through 38ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@dabh%2fdiagnostics 29ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/seq-logging 36ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/one-time 38ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/logform 42ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@colors%2fcolors 47ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/safe-stable-stringify 50ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/readable-stream 56ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/es6-promise 60ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/nan 59ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/object-hash 56ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/glossy 52ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/file-stream-rotator 66ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/unix-dgram 53ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/localforage 32ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 44ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 65ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 83ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@sentry-internal%2ftracing 106ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2ftypes 112ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2fcore 141ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/source-map 119ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@sentry%2futils 155ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/lie 8ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/fill-range 26ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/binary-extensions 29ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/picomatch 36ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/is-extglob 34ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/picomatch 35ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/to-regex-range 8ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/mimic-fn 12ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/is-number 10ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/jwa 9ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/kuler 34ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/enabled 40ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/fecha 33ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/@types%2ftriple-beam 40ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/fn.name 34ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/colorspace 52ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/text-hex 11ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/color 15ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/color-convert 11ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/color-string 13ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/simple-swizzle 18ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/color-name 22ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/color-name 24ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/is-arrayish 9ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/bindings 9ms (cache hit)
      npm http fetch GET 200 https://registry.npmjs.org/file-uri-to-path 10ms (cache hit)
      npm verb reify failed optional dependency C:\ioBroker\node_modules\fsevents
      npm http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/advisories/bulk 254ms
      npm http fetch GET 200 https://registry.npmjs.org/follow-redirects 97ms (cache revalidated)
      npm http fetch GET 200 https://registry.npmjs.org/request 182ms (cache revalidated)
      npm http fetch GET 200 https://registry.npmjs.org/ip 191ms (cache revalidated)
      npm http fetch GET 200 https://registry.npmjs.org/tough-cookie 210ms (cache revalidated)
      npm info run iobroker.js-controller@6.0.1-alpha.0-20240524-14a872375 preinstall node_modules/iobroker.js-controller node build/esm/lib/preinstallCheck.js
      npm http fetch GET 200 https://registry.npmjs.org/iobroker.broadlink2 626ms (cache revalidated)
      npm info run iobroker.js-controller@6.0.1-alpha.0-20240524-14a872375 preinstall { code: 0, signal: null }
      npm info run diskusage@1.2.0 install node_modules/diskusage node-gyp rebuild
      npm info run iobroker.js-controller@6.0.1-alpha.0-20240524-14a872375 install node_modules/iobroker.js-controller node iobroker.js setup first
      npm info run unix-dgram@2.0.6 install node_modules/unix-dgram node-gyp rebuild
      npm http fetch GET 200 https://registry.npmjs.org/mdns-discovery 642ms (cache revalidated)
      npm http fetch GET 200 https://registry.npmjs.org/dns-packet 58ms (cache revalidated)
      npm http fetch GET 200 https://registry.npmjs.org/node-ssdp 889ms (cache revalidated)
      npm http fetch GET 200 https://registry.npmjs.org/iobroker.kecontact 619ms (cache revalidated)
      npm http fetch GET 200 https://registry.npmjs.org/dropbox-v2-api 627ms (cache revalidated)
      npm http fetch GET 200 https://registry.npmjs.org/iobroker.discovery 255ms (cache revalidated)
      npm http fetch GET 200 https://registry.npmjs.org/iobroker.backitup 586ms (cache revalidated)
      npm info run unix-dgram@2.0.6 install { code: 1, signal: null }
      npm verb reify failed optional dependency C:\ioBroker\node_modules\unix-dgram
      npm verb reify failed optional dependency C:\ioBroker\node_modules\bindings
      npm verb reify failed optional dependency C:\ioBroker\node_modules\file-uri-to-path
      npm info run diskusage@1.2.0 install { code: 1, signal: null }
      npm verb reify failed optional dependency C:\ioBroker\node_modules\diskusage
      npm verb reify failed optional dependency C:\ioBroker\node_modules\es6-promise
      npm info run iobroker.js-controller@6.0.1-alpha.0-20240524-14a872375 install { code: 0, signal: null }
      removed 32 packages, changed 14 packages, and audited 619 packages in 1m
      72 packages are looking for funding
        run `npm fund` for details
      26 vulnerabilities (21 moderate, 5 high)
      To address issues that do not require attention, run:
        npm audit fix
      To address all issues possible (including breaking changes), run:
        npm audit fix --force
      Some issues need review, and may require choosing
      a different dependency.
      Run `npm audit` for details.
      npm verb exit 0
      npm info ok
      • mcm1957
        Und der iob fix
        C:\ioBroker>
        C:\ioBroker>del iobroker.bat
        C:\ioBroker>iob fix
        Windows installation starting... (fixing = true)
        NPM version: 10.5.2
        No path given, using C:\ioBroker\iobroker-data
        Compressing C:\ioBroker\iobroker-data\states.jsonl
        Compressing C:\ioBroker\iobroker-data\objects.jsonl
        Compressed 2 JSONL files. Done
        NPM version: 10.5.2
        Write "iobroker start" to start the ioBroker
        npm install node-windows@1.0.0-beta.8 --force --loglevel error --production --save --prefix "C:/ioBroker"
        up to date, audited 619 packages in 9s
          npm audit fix
        npm install dotenv@^16.3.1 --force --loglevel error --production --save --prefix "C:/ioBroker"
        up to date, audited 619 packages in 7s
          npm audit fix
        npm install windows-shortcuts@^0.1.6 --force --loglevel error --production --save --prefix "C:/ioBroker"
          npm audit fix
        Running Admin shell
        ioBroker service name: ioBroker
        ioBroker ist nicht gestartet.
        Sie erhalten weitere Hilfe, wenn Sie NET HELPMSG 3521 eingeben.
        Written iobnodevars.bat successfully.
        ioBroker service is already installed.
        Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Stop ioBroker Service.lnk" created with Admin flag!
        Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Start ioBroker Service.lnk" created with Admin flag!
        Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\Restart ioBroker Service.lnk" created with Admin flag!
        Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Command line.lnk" created with Admin flag!
        Shortcut "C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ioBroker automation platform\ioBroker Admin.lnk" created!
        Running Admin shell
        ioBroker wird gestartet.
        ioBroker wurde erfolgreich gestartet.
        ioBroker service installed and started. Go to http://localhost:8081 to open the admin UI.
        To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
        C:\ioBroker>
          Thomas Braun Most Active @foxriver76 last edited by
          @foxriver76 sagte in Alpha Test js-controller Kiera (v6.0):
          @mcm1957 ja sollte reichen, Windows bin ich sowieso gespannt
          Ich hab das volle Log. Aber das sind 4300 Zeilen. Krieg ich nirgends hochgeladen.
            @thomas-braun .txt
              Thomas Braun Most Active last edited by
              @foxriver76 js-controller-inst-log.txt
              • Feuersturm
                Feuersturm @haus-automatisierung last edited by
                @haus-automatisierung sagte in Alpha Test js-controller Kiera (v6.0):
                Bitte als Issue auf GitHub öffnen. Sonst laufen da zig Themen durcheinander.
                erledigt https://github.com/ioBroker/ioBroker.javascript/issues/1576
                @TT-Tom fyi
                Feuer-sturm created this issue in ioBroker/ioBroker.javascript
                closed [Bug]: npm modules in javascript instance are broker after update to newer version #1576
                • Feuersturm
                  Feuersturm @foxriver76 last edited by
                  @foxriver76
                  Update js-controller auf 6.0.1-alpha.0-20240524-14a872375
                  proxmox@ioBrokerTestsystem:~$ iob stop
                  proxmox@ioBrokerTestsystem:~$ cd /opt/iobroker/
                  proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next --om        it=dev
                  [sudo] password for proxmox:
                  npm warn ERESOLVE overriding peer dependency
                  npm warn While resolving: @mui/x-date-pickers@7.5.1
                  npm warn Found: @mui/material@5.14.14
                  npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/material
                  npm warn   @mui/material@"5.14.14" from @iobroker/adapter-react-v5@4.13.22
                  npm warn     @iobroker/adapter-react-v5@"^4.13.13" from @iobroker/json-config@6.        17.13
                  npm warn     node_modules/@iobroker/json-config
                  npm warn     1 more (iobroker.radar-trap)
                  npm warn
                  npm warn Could not resolve dependency:
                  npm warn peer @mui/material@"^5.15.14" from @mui/x-date-pickers@7.5.1
                  npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-picker        s
                  npm warn   @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.22
                  npm warn
                  npm warn Conflicting peer dependency: @mui/material@5.15.18
                  npm warn node_modules/@mui/material
                  npm warn   node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-pick        ers
                  npm warn     @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.2        2
                  npm warn reify invalid or damaged lockfile detected
                  npm warn reify please re-try this operation once it completes
                  npm warn reify so that the damage can be corrected, or perform
                  npm warn reify a fresh install with no lockfile if the problem persists.
                  changed 12 packages in 6m
                  397 packages are looking for funding
                  iobroker log vom start des Systems enthält keine relevanten Fehler
                  • mcm1957
                    @foxriver76
                    Bitte samsung 0.6.0 in die Liste der zu aktualisierenden Adapter eintragen.
                    Release ist im Latest.
                      DLehmann last edited by
                      update gemacht - das Testsystem startet.
                      hier meine Instanzen
                      root@iobroker-test:/opt/iobroker# iobroker list instances
                      + system.adapter.adguard.0                : adguard               : iobroker-test                            -  enabled
                      + system.adapter.admin.0                  : admin                 : iobroker-test                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : iobroker-test                            -  enabled
                        system.adapter.alias-manager.0          : alias-manager         : iobroker-test                            -  enabled
                        system.adapter.backitup.0               : backitup              : iobroker-test                            - disabled
                      + system.adapter.cloud.0                  : cloud                 : iobroker-test                            -  enabled
                        system.adapter.daswetter.0              : daswetter             : iobroker-test                            -  enabled
                        system.adapter.devices.0                : devices               : iobroker-test                            -  enabled
                        system.adapter.discovery.0              : discovery             : iobroker-test                            - disabled
                        system.adapter.dwd.0                    : dwd                   : iobroker-test                            -  enabled
                        system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker-test                            -  enabled
                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-test                            -  enabled
                        system.adapter.feiertage.0              : feiertage             : iobroker-test                            -  enabled
                      + system.adapter.gotify.0                 : gotify                : iobroker-test                            -  enabled
                        system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-test                            -  enabled
                      + system.adapter.history.0                : history               : iobroker-test                            -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-test                            -  enabled, port: 0
                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-test                            -  enabled, port: 0
                      + system.adapter.hue.0                    : hue                   : iobroker-test                            -  enabled, port: 443
                      + system.adapter.iot.0                    : iot                   : iobroker-test                            -  enabled
                      + system.adapter.iqontrol.0               : iqontrol              : iobroker-test                            -  enabled
                        system.adapter.jarvis.0                 : jarvis                : iobroker-test                            -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker-test                            -  enabled
                      + system.adapter.ping.0                   : ping                  : iobroker-test                            -  enabled
                      + system.adapter.pvforecast.0             : pvforecast            : iobroker-test                            -  enabled
                        system.adapter.ring.0                   : ring                  : iobroker-test                            - disabled
                      + system.adapter.scenes.0                 : scenes                : iobroker-test                            -  enabled
                      + system.adapter.scheduler.0              : scheduler             : iobroker-test                            -  enabled
                      + system.adapter.smartcontrol.0           : smartcontrol          : iobroker-test                            -  enabled
                      + system.adapter.sonnen.0                 : sonnen                : iobroker-test                            -  enabled
                      + system.adapter.tesla-motors.0           : tesla-motors          : iobroker-test                            -  enabled
                      + system.adapter.teslamateapi.0           : teslamateapi          : iobroker-test                            -  enabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-test                            -  enabled
                        system.adapter.vis.0                    : vis                   : iobroker-test                            -  enabled
                      + system.adapter.web.0                    : web                   : iobroker-test                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      Beim npm update kam folgende Meldung
                      root@iobroker-test:/opt/iobroker# npm update
                      npm WARN ERESOLVE overriding peer dependency
                      npm WARN While resolving: @iobroker/adapter-core@3.1.4
                      npm WARN Found: @iobroker/types@5.0.20-alpha.0-20240522-9b71d3242
                      npm WARN node_modules/@iobroker/types
                      npm WARN   @iobroker/types@"5.0.20-alpha.0-20240522-9b71d3242" from iobroker.admin@6.17.13
                      npm WARN   node_modules/iobroker.admin
                      npm WARN     iobroker.admin@"6.17.13" from the root project
                      npm WARN
                      npm WARN Could not resolve dependency:
                      npm WARN peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
                      npm WARN node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                      npm WARN   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.13
                      npm WARN
                      npm WARN Conflicting peer dependency: @iobroker/types@5.0.19
                      up to date in 2m
                      137 packages are looking for funding
                      Die drei Instanzen wollen nicht starten
                      ecovacs-deebot
                      heatingcontrol
                      jarvis
                      Folgende Fehlermeldungen kommen hierzu
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	instance system.adapter.jarvis.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: Node.js v20.13.1
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      host.iobroker-test
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:126:18)
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: ^
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                      host.iobroker-test
                      2024-05-24 20:39:36.517	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	instance system.adapter.heatingcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: Node.js v20.13.1
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      host.iobroker-test
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: ^
                      host.iobroker-test
                      2024-05-24 20:39:33.235	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                      host.iobroker-test
                      2024-05-24 20:39:33.234	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                      host.iobroker-test
                      2024-05-24 20:39:30.682	error	instance system.adapter.ecovacs-deebot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.iobroker-test
                      2024-05-24 20:39:30.682	error	Caught by controller[0]: Node.js v20.13.1
                      host.iobroker-test
                      2024-05-24 20:39:30.682	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      host.iobroker-test
                      2024-05-24 20:39:30.682	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: ^
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                      host.iobroker-test
                      2024-05-24 20:39:30.681	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                        TT-Tom @foxriver76 last edited by
                        @foxriver76
                        habe das Update eingespielt, lief ohne Probleme durch. Es sind auch alle Instanzen gestartet ohne Probleme. Da npm update mit der ersten Version von Hand ausgeführt wurde, kann ich nicht genau bestätigen, ob es jetzt funktioniert.
                        schönes WE noch
                        • foxriver76
                          Gerne nochmal updaten.
                          Das Problem, dass er sich über invalide Instanz Objekte vom Typ device beschwert wurde behoben und nochmal ein anderer Versuch für die alten Adapter-Core Versionen wird ausprobiert.
                          Thomas Braun Feuersturm 3 Replies Last reply Reply Quote 1
                            @foxriver76
                            echad@chet:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@next --omit=dev
                            npm WARN node_modules/iobroker.admin/node_modules/@iobroker/types
                            npm WARN
                            npm WARN
                            added 35 packages, removed 196 packages, and changed 16 packages in 59s
                            189 packages are looking for funding
                            Die Meldungen zum Build mit letsencrypt sind weg, das Log ist soweit ruhig.
                              Thomas Braun Most Active @foxriver76 last edited by Thomas Braun
                              @foxriver76
                              Das Thema mit den Skripten hab ich auch eingrenzen können. Ich hatte ein externes npm-Modul eingetragen. Das Ding sorgt im Moment für diese Fehlermeldungen:
                              2024-05-25 12:54:44.240  - info: javascript.0 (170137) starting. Version 8.3.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                              2024-05-25 12:54:54.549  - error: javascript.0 (170137) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                              2024-05-25 12:54:54.550  - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                              2024-05-25 12:54:54.551  - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                                  at legacyMainResolve (node:internal/modules/esm/resolve:215:26)
                                  at packageResolve (node:internal/modules/esm/resolve:841:14)
                                  at moduleResolve (node:internal/modules/esm/resolve:927:18)
                                  at defaultResolve (node:internal/modules/esm/resolve:1157:11)
                                  at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12)
                                  at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25)
                                  at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38)
                                  at ModuleLoader.import (node:internal/modules/esm/loader:315:34)
                                  at defaultImportModuleDynamically (node:internal/modules/esm/utils:194:31)
                                  at importModuleDynamicallyCallback (node:internal/modules/esm/utils:216:12)
                              Wenn ich das Modul playactor herausnehme starten die anderen Skripte korrekt.
                              foxriver76 mcm1957 2 Replies Last reply Reply Quote 0
                              • foxriver76
                                foxriver76 Developer @Thomas Braun last edited by
                                @thomas-braun ah top. Evtl. Kann @haus-automatisierung was zu sagen ob da aktuell noch was falsch läuft das bekannt ist, ansonsten kann ich auch mal rein schauen.
                                  Fortune95 @foxriver76 last edited by
                                  @foxriver76
                                  Update lief durch, nur der Heatcontrol Adapter startet wie zuvor nicht.
                                  Soll ich ein issue beim Adapter öffnen?
                                  • foxriver76
                                    foxriver76 Developer @Fortune95 last edited by
                                    @fortune95 welche Version hat dein Admin?
                                    Und mal bitte npm ls @iobroker/adapter-core Ausgabe zeigen
                                      @foxriver76
                                      Der Admin hat die Version 6.17.13
                                      iobroker@iobroker:~$ npm ls @iobroker/adapter-core
                                      iobroker@ /home/iobroker
                                      `-- iobroker.js-controller@6.0.1-alpha.0-20240522-72e34be5c
                                        `-- @iobroker/adapter-core@3.1.4
                                      Thomas Braun foxriver76 2 Replies Last reply Reply Quote 0
                                      • mcm1957
                                        mcm1957 @Thomas Braun last edited by
                                        @thomas-braun said in Alpha Test js-controller Kiera (v6.0):
                                        Bitte jedenfalls mit aktuellster Version testen:
                                        https://github.com/ioBroker/ioBroker.javascript#840-2024-05-25
                                        8.4.0 (2024-05-25)
                                        (klein0r) Added checks/warnings for more incorrect blockly connections
                                        (klein0r) Added option to disable certificate validation in httpGet
                                        (klein0r) Added expire option to Blockly block
                                        (klein0r) Fixed variables.astro times when date is not available
                                        (klein0r) Fixed jsonConfig for libraries and library typings
                                        (klein0r) Implemented new js-controller 6.x functions for package handling
                                        (klein0r) Updated to ChatGPT-4o
                                          Thomas Braun Most Active @Fortune95 last edited by
                                          @fortune95
                                          Bestimmt falsch unterwegs, an der Stelle liegt kein npm-Modul...
                                          echad@chet:/home/iobroker $ npm ls @iobroker/adapter-core
                                          /home/iobroker
                                          `-- (empty)
                                          • foxriver76
                                            @fortune95 im folder /opt/iobroker bitte das Kommando ausführen.
                                            alpha js-controller kiera test
                                            20
                                            234
                                            43393
