    4. Alpha Test js-controller Kiera (v6.0)
      Thomas Braun Most Active @foxriver76 last edited by
      @foxriver76 sagte in Alpha Test js-controller Kiera (v6.0):
      @mcm1957 ja sollte reichen, Windows bin ich sowieso gespannt
      Ich hab das volle Log. Aber das sind 4300 Zeilen. Krieg ich nirgends hochgeladen.
        @thomas-braun .txt
          Thomas Braun Most Active last edited by
          @foxriver76 js-controller-inst-log.txt
          • Feuersturm
            Feuersturm @haus-automatisierung last edited by
            @haus-automatisierung sagte in Alpha Test js-controller Kiera (v6.0):
            Bitte als Issue auf GitHub öffnen. Sonst laufen da zig Themen durcheinander.
            erledigt https://github.com/ioBroker/ioBroker.javascript/issues/1576
            @TT-Tom fyi
            Feuer-sturm created this issue in ioBroker/ioBroker.javascript
            closed [Bug]: npm modules in javascript instance are broker after update to newer version #1576
            • Feuersturm
              Feuersturm @foxriver76 last edited by
              @foxriver76
              Update js-controller auf 6.0.1-alpha.0-20240524-14a872375
              proxmox@ioBrokerTestsystem:~$ iob stop
              proxmox@ioBrokerTestsystem:~$ cd /opt/iobroker/
              proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next --om        it=dev
              [sudo] password for proxmox:
              npm warn ERESOLVE overriding peer dependency
              npm warn While resolving: @mui/x-date-pickers@7.5.1
              npm warn Found: @mui/material@5.14.14
              npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/material
              npm warn   @mui/material@"5.14.14" from @iobroker/adapter-react-v5@4.13.22
              npm warn     @iobroker/adapter-react-v5@"^4.13.13" from @iobroker/json-config@6.        17.13
              npm warn     node_modules/@iobroker/json-config
              npm warn     1 more (iobroker.radar-trap)
              npm warn
              npm warn Could not resolve dependency:
              npm warn peer @mui/material@"^5.15.14" from @mui/x-date-pickers@7.5.1
              npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-picker        s
              npm warn   @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.22
              npm warn
              npm warn Conflicting peer dependency: @mui/material@5.15.18
              npm warn node_modules/@mui/material
              npm warn   node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-pick        ers
              npm warn     @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.2        2
              npm warn reify invalid or damaged lockfile detected
              npm warn reify please re-try this operation once it completes
              npm warn reify so that the damage can be corrected, or perform
              npm warn reify a fresh install with no lockfile if the problem persists.
              changed 12 packages in 6m
              397 packages are looking for funding
                run `npm fund` for details
              iobroker log vom start des Systems enthält keine relevanten Fehler
              • mcm1957
                mcm1957 last edited by
                @foxriver76
                Bitte samsung 0.6.0 in die Liste der zu aktualisierenden Adapter eintragen.
                Release ist im Latest.
                  DLehmann last edited by
                  update gemacht - das Testsystem startet.
                  hier meine Instanzen
                  root@iobroker-test:/opt/iobroker# iobroker list instances
                  + system.adapter.adguard.0                : adguard               : iobroker-test                            -  enabled
                  + system.adapter.admin.0                  : admin                 : iobroker-test                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.alexa2.0                 : alexa2                : iobroker-test                            -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : iobroker-test                            -  enabled
                    system.adapter.backitup.0               : backitup              : iobroker-test                            - disabled
                  + system.adapter.cloud.0                  : cloud                 : iobroker-test                            -  enabled
                    system.adapter.daswetter.0              : daswetter             : iobroker-test                            -  enabled
                    system.adapter.devices.0                : devices               : iobroker-test                            -  enabled
                    system.adapter.discovery.0              : discovery             : iobroker-test                            - disabled
                    system.adapter.dwd.0                    : dwd                   : iobroker-test                            -  enabled
                    system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker-test                            -  enabled
                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-test                            -  enabled
                    system.adapter.feiertage.0              : feiertage             : iobroker-test                            -  enabled
                  + system.adapter.gotify.0                 : gotify                : iobroker-test                            -  enabled
                    system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-test                            -  enabled
                  + system.adapter.history.0                : history               : iobroker-test                            -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-test                            -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-test                            -  enabled, port: 0
                  + system.adapter.hue.0                    : hue                   : iobroker-test                            -  enabled, port: 443
                  + system.adapter.iot.0                    : iot                   : iobroker-test                            -  enabled
                  + system.adapter.iqontrol.0               : iqontrol              : iobroker-test                            -  enabled
                    system.adapter.jarvis.0                 : jarvis                : iobroker-test                            -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker-test                            -  enabled
                  + system.adapter.ping.0                   : ping                  : iobroker-test                            -  enabled
                  + system.adapter.pvforecast.0             : pvforecast            : iobroker-test                            -  enabled
                    system.adapter.ring.0                   : ring                  : iobroker-test                            - disabled
                  + system.adapter.scenes.0                 : scenes                : iobroker-test                            -  enabled
                  + system.adapter.scheduler.0              : scheduler             : iobroker-test                            -  enabled
                  + system.adapter.smartcontrol.0           : smartcontrol          : iobroker-test                            -  enabled
                  + system.adapter.sonnen.0                 : sonnen                : iobroker-test                            -  enabled
                  + system.adapter.tesla-motors.0           : tesla-motors          : iobroker-test                            -  enabled
                  + system.adapter.teslamateapi.0           : teslamateapi          : iobroker-test                            -  enabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-test                            -  enabled
                    system.adapter.vis.0                    : vis                   : iobroker-test                            -  enabled
                  + system.adapter.web.0                    : web                   : iobroker-test                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + instance is alive
                  Beim npm update kam folgende Meldung
                  root@iobroker-test:/opt/iobroker# npm update
                  npm WARN ERESOLVE overriding peer dependency
                  npm WARN While resolving: @iobroker/adapter-core@3.1.4
                  npm WARN Found: @iobroker/types@5.0.20-alpha.0-20240522-9b71d3242
                  npm WARN node_modules/@iobroker/types
                  npm WARN   @iobroker/types@"5.0.20-alpha.0-20240522-9b71d3242" from iobroker.admin@6.17.13
                  npm WARN   node_modules/iobroker.admin
                  npm WARN     iobroker.admin@"6.17.13" from the root project
                  npm WARN
                  npm WARN Could not resolve dependency:
                  npm WARN peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
                  npm WARN node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
                  npm WARN   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.13
                  npm WARN
                  npm WARN Conflicting peer dependency: @iobroker/types@5.0.19
                  up to date in 2m
                  137 packages are looking for funding
                  Die drei Instanzen wollen nicht starten
                  ecovacs-deebot
                  heatingcontrol
                  jarvis
                  Folgende Fehlermeldungen kommen hierzu
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	instance system.adapter.jarvis.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: Node.js v20.13.1
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                  host.iobroker-test
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:126:18)
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: ^
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                  host.iobroker-test
                  2024-05-24 20:39:36.517	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	instance system.adapter.heatingcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: Node.js v20.13.1
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                  host.iobroker-test
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: ^
                  host.iobroker-test
                  2024-05-24 20:39:33.235	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                  host.iobroker-test
                  2024-05-24 20:39:33.234	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                  host.iobroker-test
                  2024-05-24 20:39:30.682	error	instance system.adapter.ecovacs-deebot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.iobroker-test
                  2024-05-24 20:39:30.682	error	Caught by controller[0]: Node.js v20.13.1
                  host.iobroker-test
                  2024-05-24 20:39:30.682	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                  host.iobroker-test
                  2024-05-24 20:39:30.682	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: ^
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                  host.iobroker-test
                  2024-05-24 20:39:30.681	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                    TT-Tom @foxriver76 last edited by
                    @foxriver76
                    habe das Update eingespielt, lief ohne Probleme durch. Es sind auch alle Instanzen gestartet ohne Probleme. Da npm update mit der ersten Version von Hand ausgeführt wurde, kann ich nicht genau bestätigen, ob es jetzt funktioniert.
                    schönes WE noch
                    • foxriver76
                      Gerne nochmal updaten.
                      Das Problem, dass er sich über invalide Instanz Objekte vom Typ device beschwert wurde behoben und nochmal ein anderer Versuch für die alten Adapter-Core Versionen wird ausprobiert.
                      Thomas Braun Feuersturm 3 Replies Last reply Reply Quote 1
                        @foxriver76
                        echad@chet:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@next --omit=dev
                        npm WARN node_modules/iobroker.admin/node_modules/@iobroker/types
                        npm WARN
                        npm WARN
                        added 35 packages, removed 196 packages, and changed 16 packages in 59s
                        189 packages are looking for funding
                        Die Meldungen zum Build mit letsencrypt sind weg, das Log ist soweit ruhig.
                          Thomas Braun Most Active @foxriver76 last edited by Thomas Braun
                          @foxriver76
                          Das Thema mit den Skripten hab ich auch eingrenzen können. Ich hatte ein externes npm-Modul eingetragen. Das Ding sorgt im Moment für diese Fehlermeldungen:
                          2024-05-25 12:54:44.240  - info: javascript.0 (170137) starting. Version 8.3.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                          2024-05-25 12:54:54.549  - error: javascript.0 (170137) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                          2024-05-25 12:54:54.550  - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                          2024-05-25 12:54:54.551  - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                              at legacyMainResolve (node:internal/modules/esm/resolve:215:26)
                              at packageResolve (node:internal/modules/esm/resolve:841:14)
                              at moduleResolve (node:internal/modules/esm/resolve:927:18)
                              at defaultResolve (node:internal/modules/esm/resolve:1157:11)
                              at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12)
                              at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25)
                              at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38)
                              at ModuleLoader.import (node:internal/modules/esm/loader:315:34)
                              at defaultImportModuleDynamically (node:internal/modules/esm/utils:194:31)
                              at importModuleDynamicallyCallback (node:internal/modules/esm/utils:216:12)
                          Wenn ich das Modul playactor herausnehme starten die anderen Skripte korrekt.
                          foxriver76 mcm1957 2 Replies Last reply Reply Quote 0
                          • foxriver76
                            foxriver76 Developer @Thomas Braun last edited by
                            @thomas-braun ah top. Evtl. Kann @haus-automatisierung was zu sagen ob da aktuell noch was falsch läuft das bekannt ist, ansonsten kann ich auch mal rein schauen.
                              Fortune95 @foxriver76 last edited by
                              @foxriver76
                              Update lief durch, nur der Heatcontrol Adapter startet wie zuvor nicht.
                              Soll ich ein issue beim Adapter öffnen?
                              • foxriver76
                                foxriver76 Developer @Fortune95 last edited by
                                @fortune95 welche Version hat dein Admin?
                                Und mal bitte npm ls @iobroker/adapter-core Ausgabe zeigen
                                  @foxriver76
                                  Der Admin hat die Version 6.17.13
                                  iobroker@iobroker:~$ npm ls @iobroker/adapter-core
                                  iobroker@ /home/iobroker
                                  `-- iobroker.js-controller@6.0.1-alpha.0-20240522-72e34be5c
                                    `-- @iobroker/adapter-core@3.1.4
                                  Thomas Braun foxriver76 2 Replies Last reply Reply Quote 0
                                  • mcm1957
                                    mcm1957 @Thomas Braun last edited by
                                    @thomas-braun said in Alpha Test js-controller Kiera (v6.0):
                                    Bitte jedenfalls mit aktuellster Version testen:
                                    https://github.com/ioBroker/ioBroker.javascript#840-2024-05-25
                                    8.4.0 (2024-05-25)
                                    (klein0r) Added checks/warnings for more incorrect blockly connections
                                    (klein0r) Added option to disable certificate validation in httpGet
                                    (klein0r) Added expire option to Blockly block
                                    (klein0r) Fixed variables.astro times when date is not available
                                    (klein0r) Fixed jsonConfig for libraries and library typings
                                    (klein0r) Implemented new js-controller 6.x functions for package handling
                                    (klein0r) Updated to ChatGPT-4o
                                      Thomas Braun Most Active @Fortune95 last edited by
                                      @fortune95
                                      Bestimmt falsch unterwegs, an der Stelle liegt kein npm-Modul...
                                      echad@chet:/home/iobroker $ npm ls @iobroker/adapter-core
                                      /home/iobroker
                                      `-- (empty)
                                      • foxriver76
                                        @fortune95 im folder /opt/iobroker bitte das Kommando ausführen.
                                          @foxriver76
                                          iobroker@iobroker:/opt/iobroker$ npm ls @iobroker/adapter-core
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          +-- iobroker.admin@6.17.13
                                          | +-- @iobroker/adapter-core@3.1.4
                                          | `-- @iobroker/socket-classes@1.5.0
                                          +-- iobroker.alias-manager@1.2.6
                                          | `-- @iobroker/adapter-core@2.6.12
                                          +-- iobroker.backitup@2.11.0
                                          +-- iobroker.bydhvs@1.5.0
                                          +-- iobroker.daswetter@3.1.13
                                          | `-- @iobroker/adapter-core@3.0.4
                                          +-- iobroker.device-reminder@3.1.2
                                          +-- iobroker.discovery@4.5.0
                                          +-- iobroker.dwd@2.8.5
                                          | `-- @iobroker/adapter-core@2.6.12 deduped
                                          +-- iobroker.ebus@3.3.0
                                          +-- iobroker.energiefluss-erweitert@0.4.1
                                          +-- iobroker.esphome@0.5.0-beta.8
                                          +-- iobroker.feiertage@1.2.0
                                          +-- iobroker.fritzdect@2.5.9
                                          +-- iobroker.gruenbeck@0.0.43
                                          +-- iobroker.heatingcontrol@2.12.5
                                          +-- iobroker.hm-rega@4.0.0
                                          +-- iobroker.hm-rpc@1.17.0
                                          | `-- @iobroker/dm-utils@0.1.9
                                          +-- iobroker.homeconnect@1.4.0
                                          +-- iobroker.homekit-controller@0.5.10
                                          +-- iobroker.ical@1.15.0
                                          +-- iobroker.influxdb@4.0.2
                                          +-- iobroker.iot@3.3.0
                                          +-- iobroker.iqontrol@2.3.0
                                          +-- iobroker.javascript@8.3.1
                                          +-- iobroker.jeelink@1.2.3
                                          +-- iobroker.js-controller@6.0.1-alpha.0-20240525-56d9e4a2e
                                          +-- iobroker.klf200@1.2.0
                                          +-- iobroker.mercedesme@0.2.3
                                          +-- iobroker.mihome-vacuum@4.2.0
                                          +-- iobroker.modbus@6.2.2
                                          +-- iobroker.mqtt@5.2.0
                                          +-- iobroker.node-red@5.2.1
                                          +-- iobroker.openknx@0.9.0
                                          +-- iobroker.pushover@3.0.6
                                          +-- iobroker.pvforecast@2.9.1
                                          +-- iobroker.selverf@0.6.3
                                          +-- iobroker.shelly@7.0.0
                                          +-- iobroker.shuttercontrol@1.7.0
                                          +-- iobroker.simple-api@2.8.0
                                          +-- iobroker.sma-em@1.0.1
                                          +-- iobroker.smartcontrol@2.0.1
                                          +-- iobroker.socketio@6.7.0
                                          +-- iobroker.sonoff@3.0.3
                                          +-- iobroker.tankerkoenig@3.4.0
                                          +-- iobroker.telegram@3.2.1
                                          +-- iobroker.text2command@3.0.3
                                          +-- iobroker.tr-064@4.3.0
                                          +-- iobroker.unifi@0.7.0
                                          +-- iobroker.vis-2@2.9.64
                                          +-- iobroker.web@6.2.5
                                          | +-- iobroker.socketio@6.6.1
                                          | | `-- @iobroker/adapter-core@3.1.4 deduped
                                          | `-- iobroker.ws@2.5.11
                                          +-- iobroker.ws@2.6.1
                                          +-- iobroker.yahka@1.0.3
                                          +-- iobroker.yamaha@0.5.3
                                          `-- iobroker.zigbee@1.10.3
                                          • foxriver76
                                            foxriver76 Developer @Fortune95 last edited by foxriver76
                                            @fortune95 Jop liegt an heating Control der hat eine Version von Adapter Core fest spezifiziert die inkompatibel ist. Ist im Endeffekt schon auf GitHub gefixt aber gerne mal ein issue machen dass diese released wird
                                            mcm1957 F 2 Replies Last reply Reply Quote 1
                                            alpha js-controller kiera test
                                            20
                                            234
                                            43351
