Alpha Test js-controller Kiera (v6.0)
@thomas-braun .txt
@haus-automatisierung sagte in Alpha Test js-controller Kiera (v6.0):
Bitte als Issue auf GitHub öffnen. Sonst laufen da zig Themen durcheinander.
erledigt https://github.com/ioBroker/ioBroker.javascript/issues/1576
@TT-Tom fyi -
@foxriver76
Update js-controller auf 6.0.1-alpha.0-20240524-14a872375proxmox@ioBrokerTestsystem:~$ iob stop proxmox@ioBrokerTestsystem:~$ cd /opt/iobroker/ proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next --om it=dev [sudo] password for proxmox: npm warn ERESOLVE overriding peer dependency npm warn While resolving: @mui/x-date-pickers@7.5.1 npm warn Found: @mui/material@5.14.14 npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/material npm warn @mui/material@"5.14.14" from @iobroker/adapter-react-v5@4.13.22 npm warn node_modules/@iobroker/adapter-react-v5 npm warn @iobroker/adapter-react-v5@"^4.13.13" from @iobroker/json-config@6. 17.13 npm warn node_modules/@iobroker/json-config npm warn 1 more (iobroker.radar-trap) npm warn npm warn Could not resolve dependency: npm warn peer @mui/material@"^5.15.14" from @mui/x-date-pickers@7.5.1 npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-picker s npm warn @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.22 npm warn node_modules/@iobroker/adapter-react-v5 npm warn npm warn Conflicting peer dependency: @mui/material@5.15.18 npm warn node_modules/@mui/material npm warn peer @mui/material@"^5.15.14" from @mui/x-date-pickers@7.5.1 npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-pick ers npm warn @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.2 2 npm warn node_modules/@iobroker/adapter-react-v5 npm warn reify invalid or damaged lockfile detected npm warn reify please re-try this operation once it completes npm warn reify so that the damage can be corrected, or perform npm warn reify a fresh install with no lockfile if the problem persists. changed 12 packages in 6m 397 packages are looking for funding run `npm fund` for detailsiobroker log vom start des Systems enthält keine relevanten Fehler
Bitte
samsung 0.6.0in die Liste der zu aktualisierenden Adapter eintragen.Release ist im Latest.
Danke -
update gemacht - das Testsystem startet.
hier meine Instanzen
root@iobroker-test:/opt/iobroker# iobroker list instances + system.adapter.adguard.0 : adguard : iobroker-test - enabled + system.adapter.admin.0 : admin : iobroker-test - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : iobroker-test - enabled system.adapter.alias-manager.0 : alias-manager : iobroker-test - enabled system.adapter.backitup.0 : backitup : iobroker-test - disabled + system.adapter.cloud.0 : cloud : iobroker-test - enabled system.adapter.daswetter.0 : daswetter : iobroker-test - enabled system.adapter.devices.0 : devices : iobroker-test - enabled system.adapter.discovery.0 : discovery : iobroker-test - disabled system.adapter.dwd.0 : dwd : iobroker-test - enabled system.adapter.ecovacs-deebot.0 : ecovacs-deebot : iobroker-test - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-test - enabled system.adapter.feiertage.0 : feiertage : iobroker-test - enabled + system.adapter.gotify.0 : gotify : iobroker-test - enabled system.adapter.heatingcontrol.0 : heatingcontrol : iobroker-test - enabled + system.adapter.history.0 : history : iobroker-test - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker-test - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : iobroker-test - enabled, port: 0 + system.adapter.hue.0 : hue : iobroker-test - enabled, port: 443 + system.adapter.iot.0 : iot : iobroker-test - enabled + system.adapter.iqontrol.0 : iqontrol : iobroker-test - enabled system.adapter.jarvis.0 : jarvis : iobroker-test - enabled + system.adapter.javascript.0 : javascript : iobroker-test - enabled + system.adapter.ping.0 : ping : iobroker-test - enabled + system.adapter.pvforecast.0 : pvforecast : iobroker-test - enabled system.adapter.ring.0 : ring : iobroker-test - disabled + system.adapter.scenes.0 : scenes : iobroker-test - enabled + system.adapter.scheduler.0 : scheduler : iobroker-test - enabled + system.adapter.smartcontrol.0 : smartcontrol : iobroker-test - enabled + system.adapter.sonnen.0 : sonnen : iobroker-test - enabled + system.adapter.tesla-motors.0 : tesla-motors : iobroker-test - enabled + system.adapter.teslamateapi.0 : teslamateapi : iobroker-test - enabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker-test - enabled system.adapter.vis.0 : vis : iobroker-test - enabled + system.adapter.web.0 : web : iobroker-test - enabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is aliveBeim npm update kam folgende Meldung
root@iobroker-test:/opt/iobroker# npm update npm WARN ERESOLVE overriding peer dependency npm WARN While resolving: @iobroker/adapter-core@3.1.4 npm WARN Found: @iobroker/types@5.0.20-alpha.0-20240522-9b71d3242 npm WARN node_modules/@iobroker/types npm WARN @iobroker/types@"5.0.20-alpha.0-20240522-9b71d3242" from iobroker.admin@6.17.13 npm WARN node_modules/iobroker.admin npm WARN iobroker.admin@"6.17.13" from the root project npm WARN npm WARN Could not resolve dependency: npm WARN peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4 npm WARN node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm WARN @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.13 npm WARN node_modules/iobroker.admin npm WARN npm WARN Conflicting peer dependency: @iobroker/types@5.0.19 npm WARN node_modules/@iobroker/types npm WARN peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4 npm WARN node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm WARN @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.13 npm WARN node_modules/iobroker.admin up to date in 2m 137 packages are looking for funding run `npm fund` for detailsDie drei Instanzen wollen nicht starten
ecovacs-deebot
heatingcontrol
jarvisFolgende Fehlermeldungen kommen hierzu
host.iobroker-test 2024-05-24 20:39:36.517 error instance system.adapter.jarvis.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: Node.js v20.13.1 host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/index.js:19:27) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: at require (node:internal/modules/helpers:179:18) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:126:18) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11) host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: ^ host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`); host.iobroker-test 2024-05-24 20:39:36.517 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:83 host.iobroker-test 2024-05-24 20:39:33.235 error instance system.adapter.heatingcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: Node.js v20.13.1 host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/index.js:19:27) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: at require (node:internal/modules/helpers:179:18) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11) host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: ^ host.iobroker-test 2024-05-24 20:39:33.235 error Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`); host.iobroker-test 2024-05-24 20:39:33.234 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:83 host.iobroker-test 2024-05-24 20:39:30.682 error instance system.adapter.ecovacs-deebot.0 terminated with code 1 (JS_CONTROLLER_STOPPED) host.iobroker-test 2024-05-24 20:39:30.682 error Caught by controller[0]: Node.js v20.13.1 host.iobroker-test 2024-05-24 20:39:30.682 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14) host.iobroker-test 2024-05-24 20:39:30.682 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/index.js:19:27) host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: at require (node:internal/modules/helpers:179:18) host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19) host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12) host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32) host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10) host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14) host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18) host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11) host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: ^ host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`); host.iobroker-test 2024-05-24 20:39:30.681 error Caught by controller[0]: /opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:83 -
@foxriver76
habe das Update eingespielt, lief ohne Probleme durch. Es sind auch alle Instanzen gestartet ohne Probleme. Da npm update mit der ersten Version von Hand ausgeführt wurde, kann ich nicht genau bestätigen, ob es jetzt funktioniert.
schönes WE noch -
Gerne nochmal updaten.
Das Problem, dass er sich über invalide Instanz Objekte vom Typ
devicebeschwert wurde behoben und nochmal ein anderer Versuch für die alten Adapter-Core Versionen wird ausprobiert. -
echad@chet:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@next --omit=dev npm WARN ERESOLVE overriding peer dependency npm WARN While resolving: @iobroker/adapter-core@3.1.4 npm WARN Found: @iobroker/types@5.0.20-alpha.0-20240522-9b71d3242 npm WARN node_modules/iobroker.admin/node_modules/@iobroker/types npm WARN @iobroker/types@"5.0.20-alpha.0-20240522-9b71d3242" from iobroker.admin@6.17.13 npm WARN node_modules/iobroker.admin npm WARN iobroker.admin@"6.17.13" from the root project npm WARN npm WARN Could not resolve dependency: npm WARN peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4 npm WARN node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm WARN @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.13 npm WARN node_modules/iobroker.admin npm WARN npm WARN Conflicting peer dependency: @iobroker/types@5.0.19 npm WARN node_modules/@iobroker/types npm WARN peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4 npm WARN node_modules/iobroker.admin/node_modules/@iobroker/adapter-core npm WARN @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.13 npm WARN node_modules/iobroker.admin added 35 packages, removed 196 packages, and changed 16 packages in 59s 189 packages are looking for funding run `npm fund` for details echad@chet:/opt/iobroker $Die Meldungen zum Build mit letsencrypt sind weg, das Log ist soweit ruhig.
Das Thema mit den Skripten hab ich auch eingrenzen können. Ich hatte ein externes npm-Modul eingetragen. Das Ding sorgt im Moment für diese Fehlermeldungen:
2024-05-25 12:54:44.240 - info: javascript.0 (170137) starting. Version 8.3.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e 2024-05-25 12:54:54.549 - error: javascript.0 (170137) An error happened which is most likely from one of your scripts, but the originating script could not be detected. 2024-05-25 12:54:54.550 - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js 2024-05-25 12:54:54.551 - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js at legacyMainResolve (node:internal/modules/esm/resolve:215:26) at packageResolve (node:internal/modules/esm/resolve:841:14) at moduleResolve (node:internal/modules/esm/resolve:927:18) at defaultResolve (node:internal/modules/esm/resolve:1157:11) at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12) at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25) at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38) at ModuleLoader.import (node:internal/modules/esm/loader:315:34) at defaultImportModuleDynamically (node:internal/modules/esm/utils:194:31) at importModuleDynamicallyCallback (node:internal/modules/esm/utils:216:12) 2024-05-25 12:54:54.549 - error: javascript.0 (170137) An error happened which is most likely from one of your scripts, but the originating script could not be detected. 2024-05-25 12:54:54.550 - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js 2024-05-25 12:54:54.551 - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js at legacyMainResolve (node:internal/modules/esm/resolve:215:26) at packageResolve (node:internal/modules/esm/resolve:841:14) at moduleResolve (node:internal/modules/esm/resolve:927:18) at defaultResolve (node:internal/modules/esm/resolve:1157:11) at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12) at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25) at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38) at ModuleLoader.import (node:internal/modules/esm/loader:315:34) at defaultImportModuleDynamically (node:internal/modules/esm/utils:194:31) at importModuleDynamicallyCallback (node:internal/modules/esm/utils:216:12)Wenn ich das Modul
playactorherausnehme starten die anderen Skripte korrekt. -
@thomas-braun ah top. Evtl. Kann @haus-automatisierung was zu sagen ob da aktuell noch was falsch läuft das bekannt ist, ansonsten kann ich auch mal rein schauen.
Update lief durch, nur der Heatcontrol Adapter startet wie zuvor nicht.
Soll ich ein issue beim Adapter öffnen? -
@fortune95 welche Version hat dein Admin?
Und mal bitte
npm ls @iobroker/adapter-coreAusgabe zeigen -
Der Admin hat die Version 6.17.13
iobroker@iobroker:~$ npm ls @iobroker/adapter-core iobroker@ /home/iobroker `-- iobroker.js-controller@6.0.1-alpha.0-20240522-72e34be5c `-- @iobroker/adapter-core@3.1.4 -
@thomas-braun said in Alpha Test js-controller Kiera (v6.0):
Wenn ich das Modul
playactorherausnehme starten die anderen Skripte korrekt.Bitte jedenfalls mit aktuellster Version testen:
https://github.com/ioBroker/ioBroker.javascript#840-2024-05-25
8.4.0 (2024-05-25)
(klein0r) Added checks/warnings for more incorrect blockly connections
(klein0r) Added option to disable certificate validation in httpGet
(klein0r) Added expire option to Blockly block
(klein0r) Fixed variables.astro times when date is not available
(klein0r) Fixed jsonConfig for libraries and library typings
(klein0r) Implemented new js-controller 6.x functions for package handling
(klein0r) Updated to ChatGPT-4o -
Bestimmt falsch unterwegs, an der Stelle liegt kein npm-Modul...
echad@chet:/home/iobroker $ npm ls @iobroker/adapter-core /home/iobroker `-- (empty) echad@chet:/home/iobroker $ -
@fortune95 im folder
/opt/iobrokerbitte das Kommando ausführen. -
iobroker@iobroker:/opt/iobroker$ npm ls @iobroker/adapter-core iobroker.inst@3.0.0 /opt/iobroker +-- iobroker.admin@6.17.13 | +-- @iobroker/adapter-core@3.1.4 | `-- @iobroker/socket-classes@1.5.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.alias-manager@1.2.6 | `-- @iobroker/adapter-core@2.6.12 +-- iobroker.backitup@2.11.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.bydhvs@1.5.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.daswetter@3.1.13 | `-- @iobroker/adapter-core@3.0.4 +-- iobroker.device-reminder@3.1.2 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.discovery@4.5.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.dwd@2.8.5 | `-- @iobroker/adapter-core@2.6.12 deduped +-- iobroker.ebus@3.3.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.energiefluss-erweitert@0.4.1 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.esphome@0.5.0-beta.8 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.feiertage@1.2.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.fritzdect@2.5.9 | `-- @iobroker/adapter-core@2.6.12 deduped +-- iobroker.gruenbeck@0.0.43 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.heatingcontrol@2.12.5 | `-- @iobroker/adapter-core@3.0.4 +-- iobroker.hm-rega@4.0.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.hm-rpc@1.17.0 | +-- @iobroker/adapter-core@3.1.4 | `-- @iobroker/dm-utils@0.1.9 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.homeconnect@1.4.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.homekit-controller@0.5.10 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.ical@1.15.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.influxdb@4.0.2 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.iot@3.3.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.iqontrol@2.3.0 | `-- @iobroker/adapter-core@2.6.12 deduped +-- iobroker.javascript@8.3.1 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.jeelink@1.2.3 | `-- @iobroker/adapter-core@2.6.12 deduped +-- iobroker.js-controller@6.0.1-alpha.0-20240525-56d9e4a2e | `-- @iobroker/adapter-core@2.6.12 deduped +-- iobroker.klf200@1.2.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.mercedesme@0.2.3 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.mihome-vacuum@4.2.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.modbus@6.2.2 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.mqtt@5.2.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.node-red@5.2.1 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.openknx@0.9.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.pushover@3.0.6 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.pvforecast@2.9.1 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.selverf@0.6.3 | `-- @iobroker/adapter-core@2.6.12 deduped +-- iobroker.shelly@7.0.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.shuttercontrol@1.7.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.simple-api@2.8.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.sma-em@1.0.1 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.smartcontrol@2.0.1 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.socketio@6.7.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.sonoff@3.0.3 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.tankerkoenig@3.4.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.telegram@3.2.1 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.text2command@3.0.3 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.tr-064@4.3.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.unifi@0.7.0 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.vis-2@2.9.64 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.web@6.2.5 | +-- @iobroker/adapter-core@3.1.4 | +-- iobroker.socketio@6.6.1 | | `-- @iobroker/adapter-core@3.1.4 deduped | `-- iobroker.ws@2.5.11 | `-- @iobroker/adapter-core@3.1.4 deduped +-- iobroker.ws@2.6.1 | `-- @iobroker/adapter-core@3.1.4 +-- iobroker.yahka@1.0.3 | `-- @iobroker/adapter-core@2.6.12 deduped +-- iobroker.yamaha@0.5.3 | `-- @iobroker/adapter-core@2.6.12 deduped `-- iobroker.zigbee@1.10.3 `-- @iobroker/adapter-core@3.1.4 -
@fortune95 Jop liegt an heating Control der hat eine Version von Adapter Core fest spezifiziert die inkompatibel ist. Ist im Endeffekt schon auf GitHub gefixt aber gerne mal ein issue machen dass diese released wird
@foxriver76 said in Alpha Test js-controller Kiera (v6.0):
Ich würd vorschlagen heatcontrol und allfällige ander bekanntermaßen inkompatible Adapter im Comment #2 ebenfalls als 'inkompatibel' zu listen. Könnte weitere Meldungen sparen und wir wissen ja nicht, wann das gefixt wird.
