    4. Alpha Test js-controller Kiera (v6.0)
      Thomas Braun Most Active last edited by
      @foxriver76 js-controller-inst-log.txt
      • Feuersturm
        Feuersturm @haus-automatisierung last edited by
        @haus-automatisierung sagte in Alpha Test js-controller Kiera (v6.0):
        Bitte als Issue auf GitHub öffnen. Sonst laufen da zig Themen durcheinander.
        erledigt https://github.com/ioBroker/ioBroker.javascript/issues/1576
        @TT-Tom fyi
        • Feuersturm
          Feuersturm @foxriver76 last edited by
          @foxriver76
          Update js-controller auf 6.0.1-alpha.0-20240524-14a872375
          proxmox@ioBrokerTestsystem:~$ iob stop
          proxmox@ioBrokerTestsystem:~$ cd /opt/iobroker/
          proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next --om        it=dev
          [sudo] password for proxmox:
          npm warn ERESOLVE overriding peer dependency
          npm warn While resolving: @mui/x-date-pickers@7.5.1
          npm warn Found: @mui/material@5.14.14
          npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/material
          npm warn   @mui/material@"5.14.14" from @iobroker/adapter-react-v5@4.13.22
          npm warn     @iobroker/adapter-react-v5@"^4.13.13" from @iobroker/json-config@6.        17.13
          npm warn     node_modules/@iobroker/json-config
          npm warn     1 more (iobroker.radar-trap)
          npm warn
          npm warn Could not resolve dependency:
          npm warn peer @mui/material@"^5.15.14" from @mui/x-date-pickers@7.5.1
          npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-picker        s
          npm warn   @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.22
          npm warn
          npm warn Conflicting peer dependency: @mui/material@5.15.18
          npm warn node_modules/@mui/material
          npm warn   node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-pick        ers
          npm warn     @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.2        2
          npm warn reify invalid or damaged lockfile detected
          npm warn reify please re-try this operation once it completes
          npm warn reify so that the damage can be corrected, or perform
          npm warn reify a fresh install with no lockfile if the problem persists.
          changed 12 packages in 6m
          397 packages are looking for funding
            run `npm fund` for details
          iobroker log vom start des Systems enthält keine relevanten Fehler
          • mcm1957
            mcm1957 last edited by
            @foxriver76
            Bitte samsung 0.6.0 in die Liste der zu aktualisierenden Adapter eintragen.
            Release ist im Latest.
              DLehmann last edited by
              update gemacht - das Testsystem startet.
              hier meine Instanzen
              root@iobroker-test:/opt/iobroker# iobroker list instances
              + system.adapter.adguard.0                : adguard               : iobroker-test                            -  enabled
              + system.adapter.admin.0                  : admin                 : iobroker-test                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : iobroker-test                            -  enabled
                system.adapter.alias-manager.0          : alias-manager         : iobroker-test                            -  enabled
                system.adapter.backitup.0               : backitup              : iobroker-test                            - disabled
              + system.adapter.cloud.0                  : cloud                 : iobroker-test                            -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker-test                            -  enabled
                system.adapter.devices.0                : devices               : iobroker-test                            -  enabled
                system.adapter.discovery.0              : discovery             : iobroker-test                            - disabled
                system.adapter.dwd.0                    : dwd                   : iobroker-test                            -  enabled
                system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker-test                            -  enabled
              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-test                            -  enabled
                system.adapter.feiertage.0              : feiertage             : iobroker-test                            -  enabled
              + system.adapter.gotify.0                 : gotify                : iobroker-test                            -  enabled
                system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-test                            -  enabled
              + system.adapter.history.0                : history               : iobroker-test                            -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-test                            -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-test                            -  enabled, port: 0
              + system.adapter.hue.0                    : hue                   : iobroker-test                            -  enabled, port: 443
              + system.adapter.iot.0                    : iot                   : iobroker-test                            -  enabled
              + system.adapter.iqontrol.0               : iqontrol              : iobroker-test                            -  enabled
                system.adapter.jarvis.0                 : jarvis                : iobroker-test                            -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker-test                            -  enabled
              + system.adapter.ping.0                   : ping                  : iobroker-test                            -  enabled
              + system.adapter.pvforecast.0             : pvforecast            : iobroker-test                            -  enabled
                system.adapter.ring.0                   : ring                  : iobroker-test                            - disabled
              + system.adapter.scenes.0                 : scenes                : iobroker-test                            -  enabled
              + system.adapter.scheduler.0              : scheduler             : iobroker-test                            -  enabled
              + system.adapter.smartcontrol.0           : smartcontrol          : iobroker-test                            -  enabled
              + system.adapter.sonnen.0                 : sonnen                : iobroker-test                            -  enabled
              + system.adapter.tesla-motors.0           : tesla-motors          : iobroker-test                            -  enabled
              + system.adapter.teslamateapi.0           : teslamateapi          : iobroker-test                            -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-test                            -  enabled
                system.adapter.vis.0                    : vis                   : iobroker-test                            -  enabled
              + system.adapter.web.0                    : web                   : iobroker-test                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              Beim npm update kam folgende Meldung
              root@iobroker-test:/opt/iobroker# npm update
              npm WARN ERESOLVE overriding peer dependency
              npm WARN While resolving: @iobroker/adapter-core@3.1.4
              npm WARN Found: @iobroker/types@5.0.20-alpha.0-20240522-9b71d3242
              npm WARN node_modules/@iobroker/types
              npm WARN   @iobroker/types@"5.0.20-alpha.0-20240522-9b71d3242" from iobroker.admin@6.17.13
              npm WARN   node_modules/iobroker.admin
              npm WARN     iobroker.admin@"6.17.13" from the root project
              npm WARN
              npm WARN Could not resolve dependency:
              npm WARN peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
              npm WARN node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
              npm WARN   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.13
              npm WARN
              npm WARN Conflicting peer dependency: @iobroker/types@5.0.19
              up to date in 2m
              137 packages are looking for funding
              Die drei Instanzen wollen nicht starten
              ecovacs-deebot
              heatingcontrol
              jarvis
              Folgende Fehlermeldungen kommen hierzu
              host.iobroker-test
              2024-05-24 20:39:36.517	error	instance system.adapter.jarvis.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: Node.js v20.13.1
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/index.js:19:27)
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              host.iobroker-test
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:126:18)
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: ^
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
              host.iobroker-test
              2024-05-24 20:39:36.517	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
              host.iobroker-test
              2024-05-24 20:39:33.235	error	instance system.adapter.heatingcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: Node.js v20.13.1
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/index.js:19:27)
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              host.iobroker-test
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: ^
              host.iobroker-test
              2024-05-24 20:39:33.235	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
              host.iobroker-test
              2024-05-24 20:39:33.234	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
              host.iobroker-test
              2024-05-24 20:39:30.682	error	instance system.adapter.ecovacs-deebot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.iobroker-test
              2024-05-24 20:39:30.682	error	Caught by controller[0]: Node.js v20.13.1
              host.iobroker-test
              2024-05-24 20:39:30.682	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
              host.iobroker-test
              2024-05-24 20:39:30.682	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/index.js:19:27)
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: ^
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
              host.iobroker-test
              2024-05-24 20:39:30.681	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                TT-Tom @foxriver76 last edited by
                @foxriver76
                habe das Update eingespielt, lief ohne Probleme durch. Es sind auch alle Instanzen gestartet ohne Probleme. Da npm update mit der ersten Version von Hand ausgeführt wurde, kann ich nicht genau bestätigen, ob es jetzt funktioniert.
                schönes WE noch
                • foxriver76
                  Gerne nochmal updaten.
                  Das Problem, dass er sich über invalide Instanz Objekte vom Typ device beschwert wurde behoben und nochmal ein anderer Versuch für die alten Adapter-Core Versionen wird ausprobiert.
                  Thomas Braun Feuersturm 3 Replies Last reply Reply Quote 1
                    Thomas Braun Most Active @foxriver76 last edited by
                    @foxriver76
                    echad@chet:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@next --omit=dev
                    npm WARN node_modules/iobroker.admin/node_modules/@iobroker/types
                    npm WARN
                    npm WARN
                    added 35 packages, removed 196 packages, and changed 16 packages in 59s
                    189 packages are looking for funding
                    Die Meldungen zum Build mit letsencrypt sind weg, das Log ist soweit ruhig.
                      Thomas Braun Most Active @foxriver76 last edited by Thomas Braun
                      @foxriver76
                      Das Thema mit den Skripten hab ich auch eingrenzen können. Ich hatte ein externes npm-Modul eingetragen. Das Ding sorgt im Moment für diese Fehlermeldungen:
                      2024-05-25 12:54:44.240  - info: javascript.0 (170137) starting. Version 8.3.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                      2024-05-25 12:54:54.549  - error: javascript.0 (170137) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                      2024-05-25 12:54:54.550  - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                      2024-05-25 12:54:54.551  - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                          at legacyMainResolve (node:internal/modules/esm/resolve:215:26)
                          at packageResolve (node:internal/modules/esm/resolve:841:14)
                          at moduleResolve (node:internal/modules/esm/resolve:927:18)
                          at defaultResolve (node:internal/modules/esm/resolve:1157:11)
                          at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12)
                          at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25)
                          at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38)
                          at ModuleLoader.import (node:internal/modules/esm/loader:315:34)
                          at defaultImportModuleDynamically (node:internal/modules/esm/utils:194:31)
                          at importModuleDynamicallyCallback (node:internal/modules/esm/utils:216:12)
                      Wenn ich das Modul playactor herausnehme starten die anderen Skripte korrekt.
                      foxriver76 mcm1957 2 Replies Last reply Reply Quote 0
                      • foxriver76
                        foxriver76 Developer @Thomas Braun last edited by
                        @thomas-braun ah top. Evtl. Kann @haus-automatisierung was zu sagen ob da aktuell noch was falsch läuft das bekannt ist, ansonsten kann ich auch mal rein schauen.
                          Fortune95 @foxriver76 last edited by
                          @foxriver76
                          Update lief durch, nur der Heatcontrol Adapter startet wie zuvor nicht.
                          Soll ich ein issue beim Adapter öffnen?
                          • foxriver76
                            foxriver76 Developer @Fortune95 last edited by
                            @fortune95 welche Version hat dein Admin?
                            Und mal bitte npm ls @iobroker/adapter-core Ausgabe zeigen
                              @foxriver76
                              Der Admin hat die Version 6.17.13
                              iobroker@iobroker:~$ npm ls @iobroker/adapter-core
                              iobroker@ /home/iobroker
                              `-- iobroker.js-controller@6.0.1-alpha.0-20240522-72e34be5c
                                `-- @iobroker/adapter-core@3.1.4
                              Thomas Braun foxriver76 2 Replies Last reply Reply Quote 0
                              • mcm1957
                                mcm1957 @Thomas Braun last edited by
                                @thomas-braun said in Alpha Test js-controller Kiera (v6.0):
                                Bitte jedenfalls mit aktuellster Version testen:
                                https://github.com/ioBroker/ioBroker.javascript#840-2024-05-25
                                8.4.0 (2024-05-25)
                                (klein0r) Added checks/warnings for more incorrect blockly connections
                                (klein0r) Added option to disable certificate validation in httpGet
                                (klein0r) Added expire option to Blockly block
                                (klein0r) Fixed variables.astro times when date is not available
                                (klein0r) Fixed jsonConfig for libraries and library typings
                                (klein0r) Implemented new js-controller 6.x functions for package handling
                                (klein0r) Updated to ChatGPT-4o
                                  Thomas Braun Most Active @Fortune95 last edited by
                                  @fortune95
                                  Bestimmt falsch unterwegs, an der Stelle liegt kein npm-Modul...
                                  echad@chet:/home/iobroker $ npm ls @iobroker/adapter-core
                                  /home/iobroker
                                  `-- (empty)
                                  • foxriver76
                                    @fortune95 im folder /opt/iobroker bitte das Kommando ausführen.
                                      @foxriver76
                                      iobroker@iobroker:/opt/iobroker$ npm ls @iobroker/adapter-core
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      +-- iobroker.admin@6.17.13
                                      | +-- @iobroker/adapter-core@3.1.4
                                      | `-- @iobroker/socket-classes@1.5.0
                                      +-- iobroker.alias-manager@1.2.6
                                      | `-- @iobroker/adapter-core@2.6.12
                                      +-- iobroker.backitup@2.11.0
                                      +-- iobroker.bydhvs@1.5.0
                                      +-- iobroker.daswetter@3.1.13
                                      | `-- @iobroker/adapter-core@3.0.4
                                      +-- iobroker.device-reminder@3.1.2
                                      +-- iobroker.discovery@4.5.0
                                      +-- iobroker.dwd@2.8.5
                                      | `-- @iobroker/adapter-core@2.6.12 deduped
                                      +-- iobroker.ebus@3.3.0
                                      +-- iobroker.energiefluss-erweitert@0.4.1
                                      +-- iobroker.esphome@0.5.0-beta.8
                                      +-- iobroker.feiertage@1.2.0
                                      +-- iobroker.fritzdect@2.5.9
                                      +-- iobroker.gruenbeck@0.0.43
                                      +-- iobroker.heatingcontrol@2.12.5
                                      +-- iobroker.hm-rega@4.0.0
                                      +-- iobroker.hm-rpc@1.17.0
                                      | `-- @iobroker/dm-utils@0.1.9
                                      +-- iobroker.homeconnect@1.4.0
                                      +-- iobroker.homekit-controller@0.5.10
                                      +-- iobroker.ical@1.15.0
                                      +-- iobroker.influxdb@4.0.2
                                      +-- iobroker.iot@3.3.0
                                      +-- iobroker.iqontrol@2.3.0
                                      +-- iobroker.javascript@8.3.1
                                      +-- iobroker.jeelink@1.2.3
                                      +-- iobroker.js-controller@6.0.1-alpha.0-20240525-56d9e4a2e
                                      +-- iobroker.klf200@1.2.0
                                      +-- iobroker.mercedesme@0.2.3
                                      +-- iobroker.mihome-vacuum@4.2.0
                                      +-- iobroker.modbus@6.2.2
                                      +-- iobroker.mqtt@5.2.0
                                      +-- iobroker.node-red@5.2.1
                                      +-- iobroker.openknx@0.9.0
                                      +-- iobroker.pushover@3.0.6
                                      +-- iobroker.pvforecast@2.9.1
                                      +-- iobroker.selverf@0.6.3
                                      +-- iobroker.shelly@7.0.0
                                      +-- iobroker.shuttercontrol@1.7.0
                                      +-- iobroker.simple-api@2.8.0
                                      +-- iobroker.sma-em@1.0.1
                                      +-- iobroker.smartcontrol@2.0.1
                                      +-- iobroker.socketio@6.7.0
                                      +-- iobroker.sonoff@3.0.3
                                      +-- iobroker.tankerkoenig@3.4.0
                                      +-- iobroker.telegram@3.2.1
                                      +-- iobroker.text2command@3.0.3
                                      +-- iobroker.tr-064@4.3.0
                                      +-- iobroker.unifi@0.7.0
                                      +-- iobroker.vis-2@2.9.64
                                      +-- iobroker.web@6.2.5
                                      | +-- iobroker.socketio@6.6.1
                                      | | `-- @iobroker/adapter-core@3.1.4 deduped
                                      | `-- iobroker.ws@2.5.11
                                      +-- iobroker.ws@2.6.1
                                      +-- iobroker.yahka@1.0.3
                                      +-- iobroker.yamaha@0.5.3
                                      `-- iobroker.zigbee@1.10.3
                                      • foxriver76
                                        foxriver76 Developer @Fortune95 last edited by foxriver76
                                        @fortune95 Jop liegt an heating Control der hat eine Version von Adapter Core fest spezifiziert die inkompatibel ist. Ist im Endeffekt schon auf GitHub gefixt aber gerne mal ein issue machen dass diese released wird
                                        mcm1957 F 2 Replies Last reply Reply Quote 1
                                        • mcm1957
                                          mcm1957 @foxriver76 last edited by
                                          @foxriver76 said in Alpha Test js-controller Kiera (v6.0):
                                          Ich würd vorschlagen heatcontrol und allfällige ander bekanntermaßen inkompatible Adapter im Comment #2 ebenfalls als 'inkompatibel' zu listen. Könnte weitere Meldungen sparen und wir wissen ja nicht, wann das gefixt wird.
                                            @foxriver76
                                            Du warst schneller 🙂 Danke!
                                            Mit der github Version startet der Adapter jetzt.
                                            alpha js-controller kiera test
                                            20
                                            234
                                            43351
