    4. Alpha Test js-controller Kiera (v6.0)
    • Feuersturm
      Feuersturm @foxriver76 last edited by
      @foxriver76
      Update js-controller auf 6.0.1-alpha.0-20240524-14a872375
      proxmox@ioBrokerTestsystem:~$ iob stop
      proxmox@ioBrokerTestsystem:~$ cd /opt/iobroker/
      proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next --om        it=dev
      [sudo] password for proxmox:
      npm warn ERESOLVE overriding peer dependency
      npm warn While resolving: @mui/x-date-pickers@7.5.1
      npm warn Found: @mui/material@5.14.14
      npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/material
      npm warn   @mui/material@"5.14.14" from @iobroker/adapter-react-v5@4.13.22
      npm warn     @iobroker/adapter-react-v5@"^4.13.13" from @iobroker/json-config@6.        17.13
      npm warn     node_modules/@iobroker/json-config
      npm warn     1 more (iobroker.radar-trap)
      npm warn
      npm warn Could not resolve dependency:
      npm warn peer @mui/material@"^5.15.14" from @mui/x-date-pickers@7.5.1
      npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-picker        s
      npm warn   @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.22
      npm warn
      npm warn Conflicting peer dependency: @mui/material@5.15.18
      npm warn node_modules/@mui/material
      npm warn   node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-pick        ers
      npm warn     @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.2        2
      npm warn reify invalid or damaged lockfile detected
      npm warn reify please re-try this operation once it completes
      npm warn reify so that the damage can be corrected, or perform
      npm warn reify a fresh install with no lockfile if the problem persists.
      changed 12 packages in 6m
      397 packages are looking for funding
        run `npm fund` for details
      iobroker log vom start des Systems enthält keine relevanten Fehler
      • mcm1957
        mcm1957 last edited by
        @foxriver76
        Bitte samsung 0.6.0 in die Liste der zu aktualisierenden Adapter eintragen.
        Release ist im Latest.
          DLehmann last edited by
          update gemacht - das Testsystem startet.
          hier meine Instanzen
          root@iobroker-test:/opt/iobroker# iobroker list instances
          + system.adapter.adguard.0                : adguard               : iobroker-test                            -  enabled
          + system.adapter.admin.0                  : admin                 : iobroker-test                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker-test                            -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker-test                            -  enabled
            system.adapter.backitup.0               : backitup              : iobroker-test                            - disabled
          + system.adapter.cloud.0                  : cloud                 : iobroker-test                            -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker-test                            -  enabled
            system.adapter.devices.0                : devices               : iobroker-test                            -  enabled
            system.adapter.discovery.0              : discovery             : iobroker-test                            - disabled
            system.adapter.dwd.0                    : dwd                   : iobroker-test                            -  enabled
            system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker-test                            -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-test                            -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker-test                            -  enabled
          + system.adapter.gotify.0                 : gotify                : iobroker-test                            -  enabled
            system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker-test                            -  enabled
          + system.adapter.history.0                : history               : iobroker-test                            -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-test                            -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-test                            -  enabled, port: 0
          + system.adapter.hue.0                    : hue                   : iobroker-test                            -  enabled, port: 443
          + system.adapter.iot.0                    : iot                   : iobroker-test                            -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : iobroker-test                            -  enabled
            system.adapter.jarvis.0                 : jarvis                : iobroker-test                            -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker-test                            -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker-test                            -  enabled
          + system.adapter.pvforecast.0             : pvforecast            : iobroker-test                            -  enabled
            system.adapter.ring.0                   : ring                  : iobroker-test                            - disabled
          + system.adapter.scenes.0                 : scenes                : iobroker-test                            -  enabled
          + system.adapter.scheduler.0              : scheduler             : iobroker-test                            -  enabled
          + system.adapter.smartcontrol.0           : smartcontrol          : iobroker-test                            -  enabled
          + system.adapter.sonnen.0                 : sonnen                : iobroker-test                            -  enabled
          + system.adapter.tesla-motors.0           : tesla-motors          : iobroker-test                            -  enabled
          + system.adapter.teslamateapi.0           : teslamateapi          : iobroker-test                            -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-test                            -  enabled
            system.adapter.vis.0                    : vis                   : iobroker-test                            -  enabled
          + system.adapter.web.0                    : web                   : iobroker-test                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          Beim npm update kam folgende Meldung
          root@iobroker-test:/opt/iobroker# npm update
          npm WARN ERESOLVE overriding peer dependency
          npm WARN While resolving: @iobroker/adapter-core@3.1.4
          npm WARN Found: @iobroker/types@5.0.20-alpha.0-20240522-9b71d3242
          npm WARN node_modules/@iobroker/types
          npm WARN   @iobroker/types@"5.0.20-alpha.0-20240522-9b71d3242" from iobroker.admin@6.17.13
          npm WARN   node_modules/iobroker.admin
          npm WARN     iobroker.admin@"6.17.13" from the root project
          npm WARN
          npm WARN Could not resolve dependency:
          npm WARN peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
          npm WARN node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
          npm WARN   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.13
          npm WARN
          npm WARN Conflicting peer dependency: @iobroker/types@5.0.19
          up to date in 2m
          137 packages are looking for funding
          Die drei Instanzen wollen nicht starten
          ecovacs-deebot
          heatingcontrol
          jarvis
          Folgende Fehlermeldungen kommen hierzu
          host.iobroker-test
          2024-05-24 20:39:36.517	error	instance system.adapter.jarvis.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: Node.js v20.13.1
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/index.js:19:27)
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          host.iobroker-test
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:126:18)
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: ^
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
          host.iobroker-test
          2024-05-24 20:39:36.517	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.jarvis/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
          host.iobroker-test
          2024-05-24 20:39:33.235	error	instance system.adapter.heatingcontrol.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: Node.js v20.13.1
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/index.js:19:27)
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          host.iobroker-test
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: ^
          host.iobroker-test
          2024-05-24 20:39:33.235	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
          host.iobroker-test
          2024-05-24 20:39:33.234	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.heatingcontrol/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
          host.iobroker-test
          2024-05-24 20:39:30.682	error	instance system.adapter.ecovacs-deebot.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker-test
          2024-05-24 20:39:30.682	error	Caught by controller[0]: Node.js v20.13.1
          host.iobroker-test
          2024-05-24 20:39:30.682	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
          host.iobroker-test
          2024-05-24 20:39:30.682	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/index.js:19:27)
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: at resolveNamedModule (/opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: ^
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
          host.iobroker-test
          2024-05-24 20:39:30.681	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.ecovacs-deebot/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
            TT-Tom @foxriver76 last edited by
            @foxriver76
            habe das Update eingespielt, lief ohne Probleme durch. Es sind auch alle Instanzen gestartet ohne Probleme. Da npm update mit der ersten Version von Hand ausgeführt wurde, kann ich nicht genau bestätigen, ob es jetzt funktioniert.
            schönes WE noch
            • foxriver76
              Gerne nochmal updaten.
              Das Problem, dass er sich über invalide Instanz Objekte vom Typ device beschwert wurde behoben und nochmal ein anderer Versuch für die alten Adapter-Core Versionen wird ausprobiert.
              Thomas Braun Feuersturm 3 Replies Last reply Reply Quote 1
                Thomas Braun Most Active @foxriver76 last edited by
                @foxriver76
                echad@chet:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@next --omit=dev
                npm WARN node_modules/iobroker.admin/node_modules/@iobroker/types
                npm WARN
                npm WARN
                added 35 packages, removed 196 packages, and changed 16 packages in 59s
                189 packages are looking for funding
                Die Meldungen zum Build mit letsencrypt sind weg, das Log ist soweit ruhig.
                  Thomas Braun Most Active @foxriver76 last edited by Thomas Braun
                  @foxriver76
                  Das Thema mit den Skripten hab ich auch eingrenzen können. Ich hatte ein externes npm-Modul eingetragen. Das Ding sorgt im Moment für diese Fehlermeldungen:
                  2024-05-25 12:54:44.240  - info: javascript.0 (170137) starting. Version 8.3.1 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                  2024-05-25 12:54:54.549  - error: javascript.0 (170137) An error happened which is most likely from one of your scripts, but the originating script could not be detected.
                  2024-05-25 12:54:54.550  - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                  2024-05-25 12:54:54.551  - error: javascript.0 (170137) Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                      at legacyMainResolve (node:internal/modules/esm/resolve:215:26)
                      at packageResolve (node:internal/modules/esm/resolve:841:14)
                      at moduleResolve (node:internal/modules/esm/resolve:927:18)
                      at defaultResolve (node:internal/modules/esm/resolve:1157:11)
                      at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:383:12)
                      at ModuleLoader.resolve (node:internal/modules/esm/loader:352:25)
                      at ModuleLoader.getModuleJob (node:internal/modules/esm/loader:227:38)
                      at ModuleLoader.import (node:internal/modules/esm/loader:315:34)
                      at defaultImportModuleDynamically (node:internal/modules/esm/utils:194:31)
                      at importModuleDynamicallyCallback (node:internal/modules/esm/utils:216:12)
                  Wenn ich das Modul playactor herausnehme starten die anderen Skripte korrekt.
                  foxriver76 mcm1957 2 Replies Last reply Reply Quote 0
                  • foxriver76
                    foxriver76 Developer @Thomas Braun last edited by
                    @thomas-braun ah top. Evtl. Kann @haus-automatisierung was zu sagen ob da aktuell noch was falsch läuft das bekannt ist, ansonsten kann ich auch mal rein schauen.
                      Fortune95 @foxriver76 last edited by
                      @foxriver76
                      Update lief durch, nur der Heatcontrol Adapter startet wie zuvor nicht.
                      Soll ich ein issue beim Adapter öffnen?
                      • foxriver76
                        foxriver76 Developer @Fortune95 last edited by
                        @fortune95 welche Version hat dein Admin?
                        Und mal bitte npm ls @iobroker/adapter-core Ausgabe zeigen
                          @foxriver76
                          Der Admin hat die Version 6.17.13
                          iobroker@iobroker:~$ npm ls @iobroker/adapter-core
                          iobroker@ /home/iobroker
                          `-- iobroker.js-controller@6.0.1-alpha.0-20240522-72e34be5c
                            `-- @iobroker/adapter-core@3.1.4
                          Thomas Braun foxriver76 2 Replies Last reply Reply Quote 0
                          • mcm1957
                            mcm1957 @Thomas Braun last edited by
                            @thomas-braun said in Alpha Test js-controller Kiera (v6.0):
                            Bitte jedenfalls mit aktuellster Version testen:
                            https://github.com/ioBroker/ioBroker.javascript#840-2024-05-25
                            8.4.0 (2024-05-25)
                            (klein0r) Added checks/warnings for more incorrect blockly connections
                            (klein0r) Added option to disable certificate validation in httpGet
                            (klein0r) Added expire option to Blockly block
                            (klein0r) Fixed variables.astro times when date is not available
                            (klein0r) Fixed jsonConfig for libraries and library typings
                            (klein0r) Implemented new js-controller 6.x functions for package handling
                            (klein0r) Updated to ChatGPT-4o
                              Thomas Braun Most Active @Fortune95 last edited by
                              @fortune95
                              Bestimmt falsch unterwegs, an der Stelle liegt kein npm-Modul...
                              echad@chet:/home/iobroker $ npm ls @iobroker/adapter-core
                              /home/iobroker
                              `-- (empty)
                              • foxriver76
                                @fortune95 im folder /opt/iobroker bitte das Kommando ausführen.
                                  @foxriver76
                                  iobroker@iobroker:/opt/iobroker$ npm ls @iobroker/adapter-core
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  +-- iobroker.admin@6.17.13
                                  | +-- @iobroker/adapter-core@3.1.4
                                  | `-- @iobroker/socket-classes@1.5.0
                                  +-- iobroker.alias-manager@1.2.6
                                  | `-- @iobroker/adapter-core@2.6.12
                                  +-- iobroker.backitup@2.11.0
                                  +-- iobroker.bydhvs@1.5.0
                                  +-- iobroker.daswetter@3.1.13
                                  | `-- @iobroker/adapter-core@3.0.4
                                  +-- iobroker.device-reminder@3.1.2
                                  +-- iobroker.discovery@4.5.0
                                  +-- iobroker.dwd@2.8.5
                                  | `-- @iobroker/adapter-core@2.6.12 deduped
                                  +-- iobroker.ebus@3.3.0
                                  +-- iobroker.energiefluss-erweitert@0.4.1
                                  +-- iobroker.esphome@0.5.0-beta.8
                                  +-- iobroker.feiertage@1.2.0
                                  +-- iobroker.fritzdect@2.5.9
                                  +-- iobroker.gruenbeck@0.0.43
                                  +-- iobroker.heatingcontrol@2.12.5
                                  +-- iobroker.hm-rega@4.0.0
                                  +-- iobroker.hm-rpc@1.17.0
                                  | `-- @iobroker/dm-utils@0.1.9
                                  +-- iobroker.homeconnect@1.4.0
                                  +-- iobroker.homekit-controller@0.5.10
                                  +-- iobroker.ical@1.15.0
                                  +-- iobroker.influxdb@4.0.2
                                  +-- iobroker.iot@3.3.0
                                  +-- iobroker.iqontrol@2.3.0
                                  +-- iobroker.javascript@8.3.1
                                  +-- iobroker.jeelink@1.2.3
                                  +-- iobroker.js-controller@6.0.1-alpha.0-20240525-56d9e4a2e
                                  +-- iobroker.klf200@1.2.0
                                  +-- iobroker.mercedesme@0.2.3
                                  +-- iobroker.mihome-vacuum@4.2.0
                                  +-- iobroker.modbus@6.2.2
                                  +-- iobroker.mqtt@5.2.0
                                  +-- iobroker.node-red@5.2.1
                                  +-- iobroker.openknx@0.9.0
                                  +-- iobroker.pushover@3.0.6
                                  +-- iobroker.pvforecast@2.9.1
                                  +-- iobroker.selverf@0.6.3
                                  +-- iobroker.shelly@7.0.0
                                  +-- iobroker.shuttercontrol@1.7.0
                                  +-- iobroker.simple-api@2.8.0
                                  +-- iobroker.sma-em@1.0.1
                                  +-- iobroker.smartcontrol@2.0.1
                                  +-- iobroker.socketio@6.7.0
                                  +-- iobroker.sonoff@3.0.3
                                  +-- iobroker.tankerkoenig@3.4.0
                                  +-- iobroker.telegram@3.2.1
                                  +-- iobroker.text2command@3.0.3
                                  +-- iobroker.tr-064@4.3.0
                                  +-- iobroker.unifi@0.7.0
                                  +-- iobroker.vis-2@2.9.64
                                  +-- iobroker.web@6.2.5
                                  | +-- iobroker.socketio@6.6.1
                                  | | `-- @iobroker/adapter-core@3.1.4 deduped
                                  | `-- iobroker.ws@2.5.11
                                  +-- iobroker.ws@2.6.1
                                  +-- iobroker.yahka@1.0.3
                                  +-- iobroker.yamaha@0.5.3
                                  `-- iobroker.zigbee@1.10.3
                                  • foxriver76
                                    foxriver76 Developer @Fortune95 last edited by foxriver76
                                    @fortune95 Jop liegt an heating Control der hat eine Version von Adapter Core fest spezifiziert die inkompatibel ist. Ist im Endeffekt schon auf GitHub gefixt aber gerne mal ein issue machen dass diese released wird
                                    mcm1957 F 2 Replies Last reply Reply Quote 1
                                    • mcm1957
                                      mcm1957 @foxriver76 last edited by
                                      @foxriver76 said in Alpha Test js-controller Kiera (v6.0):
                                      Ich würd vorschlagen heatcontrol und allfällige ander bekanntermaßen inkompatible Adapter im Comment #2 ebenfalls als 'inkompatibel' zu listen. Könnte weitere Meldungen sparen und wir wissen ja nicht, wann das gefixt wird.
                                        @foxriver76
                                        Du warst schneller 🙂 Danke!
                                        Mit der github Version startet der Adapter jetzt.
                                          Thomas Braun Most Active @mcm1957 last edited by
                                          @mcm1957 @haus-automatisierung
                                          Start mit dem custom modul playactor aktiv:
                                          2024-05-25 14:25:54.749  - info: javascript.0 (179133) starting. Version 8.4.0 (non-npm: ioBroker/ioBroker.javascript) in /opt/iobroker/node_modules/iobroker.javascript, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
                                          2024-05-25 14:26:03.646  - warn: javascript.0 (179133) Cannot install custom npm package playactor: Error: Cannot find package '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/package.json' imported from /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js
                                          2024-05-25 14:26:04.391  - info: javascript.0 (179133) requesting all states
                                          2024-05-25 14:26:04.393  - info: javascript.0 (179133) requesting all objects
                                          2024-05-25 14:26:07.025  - info: javascript.0 (179133) received all objects
                                          2024-05-25 14:26:07.474  - info: javascript.0 (179133) received all states
                                          2024-05-25 14:26:07.722  - info: javascript.0 (179133) Start JavaScript script.js.common.awtrix (Blockly)
                                          2024-05-25 14:26:07.781  - info: javascript.0 (179133) script.js.common.awtrix: registered 3 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.795  - info: javascript.0 (179133) Start JavaScript script.js.common.frostwarner (Blockly)
                                          2024-05-25 14:26:07.805  - info: javascript.0 (179133) script.js.common.frostwarner: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.805  - info: javascript.0 (179133) Start JavaScript script.js.common.lautstaerke_bad (Blockly)
                                          2024-05-25 14:26:07.812  - info: javascript.0 (179133) script.js.common.lautstaerke_bad: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.813  - info: javascript.0 (179133) Start JavaScript script.js.common.lautstaerke_kueche (Blockly)
                                          2024-05-25 14:26:07.819  - info: javascript.0 (179133) script.js.common.lautstaerke_kueche: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.820  - info: javascript.0 (179133) Start JavaScript script.js.common.nuki_ext_wohnungstuer_entriegelt (Blockly)
                                          2024-05-25 14:26:07.827  - info: javascript.0 (179133) script.js.common.nuki_ext_wohnungstuer_entriegelt: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.827  - info: javascript.0 (179133) Start JavaScript script.js.common.paketlieferungen (Blockly)
                                          2024-05-25 14:26:07.918  - info: javascript.0 (179133) script.js.common.paketlieferungen: registered 1 subscription, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.918  - info: javascript.0 (179133) Start JavaScript script.js.common.pakettruhe_offen (Blockly)
                                          2024-05-25 14:26:07.924  - info: javascript.0 (179133) script.js.common.pakettruhe_offen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.926  - info: javascript.0 (179133) Start JavaScript script.js.common.ps4_waker (Blockly)
                                          2024-05-25 14:26:07.932  - info: javascript.0 (179133) script.js.common.ps4_waker: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.933  - info: javascript.0 (179133) Start JavaScript script.js.common.sonnenaufgang (Blockly)
                                          2024-05-25 14:26:07.939  - info: javascript.0 (179133) script.js.common.sonnenaufgang: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.940  - info: javascript.0 (179133) Start JavaScript script.js.common.sonnenuntergang (Blockly)
                                          2024-05-25 14:26:07.946  - info: javascript.0 (179133) script.js.common.sonnenuntergang: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.947  - info: javascript.0 (179133) Start JavaScript script.js.common.speedtest (Javascript/js)
                                          2024-05-25 14:26:07.954  - info: javascript.0 (179133) script.js.common.speedtest: Speedtest: Erster Start des Skriptes! Datenpunkte werden erstellt!
                                          2024-05-25 14:26:07.958  - info: javascript.0 (179133) script.js.common.speedtest: Speedtest: Datenpunkte erstellt! Erster Speedtest wird in 180 Sekunden ausgeführt!
                                          2024-05-25 14:26:07.970  - info: javascript.0 (179133) script.js.common.speedtest: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.971  - info: javascript.0 (179133) Start JavaScript script.js.common.telefon_klingelt (Blockly)
                                          2024-05-25 14:26:07.977  - info: javascript.0 (179133) script.js.common.telefon_klingelt: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.979  - info: javascript.0 (179133) Start JavaScript script.js.common.treppenhaus_licht_hub (Blockly)
                                          2024-05-25 14:26:07.985  - info: javascript.0 (179133) script.js.common.treppenhaus_licht_hub: registered 2 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:07.986  - info: javascript.0 (179133) Start JavaScript script.js.common.tuerklingel_laeutet (Blockly)
                                          2024-05-25 14:26:07.992  - info: javascript.0 (179133) script.js.common.tuerklingel_laeutet: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:08.010  - info: javascript.0 (179133) Start JavaScript script.js.common.usv_warner (Blockly)
                                          2024-05-25 14:26:08.018  - info: javascript.0 (179133) script.js.common.usv_warner: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:08.019  - info: javascript.0 (179133) Start JavaScript script.js.common.wohnung_verlassen (Blockly)
                                          2024-05-25 14:26:08.026  - info: javascript.0 (179133) script.js.common.wohnung_verlassen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:08.027  - info: javascript.0 (179133) Start JavaScript script.js.common.zuhause_verlassen (Blockly)
                                          2024-05-25 14:26:08.034  - info: javascript.0 (179133) script.js.common.zuhause_verlassen: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:08.060  - info: javascript.0 (179133) Watch /home/iobroker/skripte/common/
                                          2024-05-25 14:26:08.063  - info: javascript.0 (179133) Watch /home/iobroker/skripte/global/
                                          2024-05-25 14:26:08.064  - info: javascript.0 (179133) Watch /home/iobroker/skripte/
                                          2024-05-25 14:26:08.085  - info: javascript.0 (179133) Start JavaScript script.js.nuki_extended_restart_fix (Javascript/js)
                                          2024-05-25 14:26:08.092  - info: javascript.0 (179133) script.js.nuki_extended_restart_fix: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:08.108  - info: javascript.0 (179133) Start JavaScript script.js.solix2mqtt (Javascript/js)
                                          2024-05-25 14:26:08.115  - info: javascript.0 (179133) script.js.solix2mqtt: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-25 14:26:08.115  - info: javascript.0 (179133) Start JavaScript script.js.stromzaehler2 (Javascript/js)
                                          2024-05-25 14:26:08.122  - info: javascript.0 (179133) script.js.stromzaehler2: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                          Schaut so auf den ersten Blick gut aus, die anderen Skripte starten wohl alle richtig auf.
                                          lobomau foxriver76 2 Replies Last reply Reply Quote 0
                                          • lobomau
                                            lobomau @Thomas Braun last edited by Homoran
                                            Bei mir hat das Update nicht funktioniert. Ich komme nicht mehr in den Admin Adapter.
                                            Heute morgen hatte ich nodejs auf 20 hochgezogen. Das lief ohne Probleme.
                                            Skript v.2024-05-22
                                            *** BASE SYSTEM ***
                                             Static hostname: ioBroker
                                                   Icon name: computer-container
                                                     Chassis: container ☐
                                              Virtualization: lxc
                                                      Kernel: Linux 6.5.13-5-pve
                                                Architecture: x86-64
                                            model name	: Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
                                            Docker          : false
                                            Virtualization  : lxc
                                            Kernel          : x86_64
                                            Userland        : 64 bit
                                            Systemuptime and Load:
                                             20:53:55 up 15 min,  2 users,  load average: 1.16, 1.21, 1.18
                                            CPU threads: 3
                                            *** Time and Time Zones ***
                                                           Local time: Sat 2024-05-25 20:53:55 CEST
                                                       Universal time: Sat 2024-05-25 18:53:55 UTC
                                                             RTC time: n/a
                                                          NTP service: inactive
                                                      RTC in local TZ: no
                                            *** Users and Groups ***
                                            User that called 'iob diag':
                                            lobomau
                                            HOME=/home/lobomau
                                            GROUPS=lobomau sudo iobroker
                                            iobroker
                                            HOME=/home/iobroker
                                            GROUPS=iobroker tty dialout audio video plugdev redis
                                            *** Display-Server-Setup ***
                                            Display-Server: false
                                            Desktop:
                                            Terminal: 	tty
                                            Boot Target: 	graphical.target
                                            *** MEMORY ***
                                            Mem:             10G        2.3G        7.4G        131K        718M        8.1G
                                            Swap:           3.1G          0B        3.1G
                                            Total:           13G        2.3G         10G
                                            Active iob-Instances: 	38
                                                    10000 M total memory
                                                     2236 M used memory
                                                     2055 M active memory
                                                      561 M inactive memory
                                                     7078 M free memory
                                                        0 M buffer memory
                                                      685 M swap cache
                                                     3000 M total swap
                                                        0 M used swap
                                                     3000 M free swap
                                            top - 20:53:56 up 15 min,  2 users,  load average: 1.16, 1.21, 1.18
                                            Tasks:  53 total,   1 running,  52 sleeping,   0 stopped,   0 zombie
                                            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                            MiB Mem :  10000.0 total,   7077.3 free,   2237.8 used,    685.1 buff/cache
                                            MiB Swap:   3000.0 total,   3000.0 free,      0.0 used.   7762.2 avail Mem
                                            *** FAILED SERVICES ***
                                              UNIT                                 LOAD   ACTIVE SUB    DESCRIPTION
                                            * run-rpc_pipefs.mount                 loaded failed failed RPC Pipe File System
                                            * sys-kernel-config.mount              loaded failed failed Kernel Configuration File System
                                            * systemd-networkd-wait-online.service loaded failed failed Wait for Network to be Configured
                                            LOAD   = Reflects whether the unit definition was properly loaded.
                                            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                            SUB    = The low-level unit activation state, values depend on unit type.
                                            3 loaded units listed.
                                            *** FILESYSTEM ***
                                            Filesystem                       Type      Size  Used Avail Use% Mounted on
                                            /dev/mapper/pve-vm--100--disk--0 ext4       15G   12G  2.3G  85% /
                                            none                             tmpfs     492K  4.0K  488K   1% /dev
                                            udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                                            tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                                            tmpfs                            tmpfs     3.1G  124K  3.1G   1% /run
                                            tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                                            tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                                            dmesg: read kernel buffer failed: Operation not permitted
                                            Show mounted filesystems:
                                            TARGET                                                  SOURCE                           FSTYPE     OPTIONS
                                            /                                                       /dev/mapper/pve-vm--100--disk--0 ext4       rw,relatime,stripe=16
                                            |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3247140k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                                            | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                                            | |-/run/user/1000                                      tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=1623568k,nr_inodes=405892,mode=700,uid=101000,gid=101000,inode64
                                            | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                                            | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                                            | |-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                                            | `-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                                            |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                                            | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
                                            | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
                                            | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
                                            | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
                                            | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
                                            | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
                                            | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
                                            | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
                                            | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
                                            | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8084160k,nr_inodes=2021040,mode=755,inode64
                                            | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                                            | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                                            | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                                            | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                                            | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                                            |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
                                            | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
                                            | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
                                            | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                                            | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
                                            | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                                            | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                                            | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                                            | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                                            | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                                            | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                                            | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                                            | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                                            `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
                                              |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
                                              |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
                                              |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
                                              `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                                            /var:
                                            2.0G	/var/
                                            1.5G	/var/log/journal/455f0ce5be8748d19c89e2021e5472af
                                            1.5G	/var/log
                                            373M	/var/cache
                                            Archived and active journals take up 659.0M in the file system.
                                            /opt/iobroker/backups:
                                            1.2G	/opt/iobroker/backups/
                                            /opt/iobroker/iobroker-data:
                                            1.2G	/opt/iobroker/iobroker-data/
                                            670M	/opt/iobroker/iobroker-data/files
                                            298M	/opt/iobroker/iobroker-data/esphome.0/.esphome/build
                                            43M	/opt/iobroker/iobroker-data/objects.jsonl
                                            38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.3d563dc9.js.map
                                            35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                            25M	/opt/iobroker/iobroker-data/esphome.0/.esphome/build/esp32-test2/.pioenvs/esp32-test2/libFrameworkArduino.a
                                            24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                                            USB-Devices by-id:
                                            No Devices found 'by-id'
                                            *** NodeJS-Installation ***
                                            /usr/bin/nodejs 	v20.13.1
                                            /usr/bin/node 		v20.13.1
                                            /usr/bin/npm 		10.5.2
                                            /usr/bin/npx 		10.5.2
                                            /usr/bin/corepack 	0.28.0
                                            nodejs:
                                              Installed: 20.13.1-1nodesource1
                                              Candidate: 20.13.1-1nodesource1
                                              Version table:
                                             *** 20.13.1-1nodesource1 1001
                                                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                                    100 /var/lib/dpkg/status
                                                 20.13.0-1nodesource1 1001
                                                 20.12.2-1nodesource1 1001
                                                 20.12.1-1nodesource1 1001
                                                 20.12.0-1nodesource1 1001
                                                 20.11.1-1nodesource1 1001
                                                 20.11.0-1nodesource1 1001
                                                 20.10.0-1nodesource1 1001
                                                 20.9.0-1nodesource1 1001
                                                 20.8.1-1nodesource1 1001
                                                 20.8.0-1nodesource1 1001
                                                 20.7.0-1nodesource1 1001
                                                 20.6.1-1nodesource1 1001
                                                 20.6.0-1nodesource1 1001
                                                 20.5.1-1nodesource1 1001
                                                 20.5.0-1nodesource1 1001
                                                 20.4.0-1nodesource1 1001
                                                 20.3.1-1nodesource1 1001
                                                 20.3.0-1nodesource1 1001
                                                 20.2.0-1nodesource1 1001
                                                 20.1.0-1nodesource1 1001
                                                 20.0.0-1nodesource1 1001
                                                 18.19.0+dfsg-6~deb12u1 500
                                                    500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                                                 18.13.0+dfsg1-1 500
                                                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                            No problems detected
                                            Errors in npm tree:
                                            *** ioBroker-Installation ***
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            Core adapters versions
                                            admin: 		6.17.6
                                            javascript: 	8.3.1
                                            nodejs modules from github: 	3
                                            +-- iobroker.heatingcontrol@2.12.5 (git+ssh://git@github.com/rg-engineering/ioBroker.heatingcontrol.git#830136e1eb912d51bbb270d931c16d98bdfd4ae9)
                                            +-- iobroker.ve@0.3.1 (git+ssh://git@github.com/derAlff/ioBroker.ve.git#584088cddf3318ede48554ed97414f5ff79f460e)
                                            +-- iobroker.vis-materialdesign@0.5.86 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#cf7fc5b85debcda156a3ec7feb761cff217fa855)
                                            Adapter State
                                            + system.adapter.accuweather.0            : accuweather           : Pi4                                      -  enabled
                                              system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                              system.adapter.admin.1                  : admin                 : ioBroker                                 -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                                              system.adapter.admin.2                  : admin                 : Pi4                                      - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                              system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                                              system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
                                              system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
                                              system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                                              system.adapter.bmw.0                    : bmw                   : ioBroker                                 -  enabled
                                              system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                                            + system.adapter.device-reminder.0        : device-reminder       : Pi4                                      -  enabled
                                            + system.adapter.device-watcher.0         : device-watcher        : Pi4                                      -  enabled
                                              system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
                                              system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
                                              system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 - disabled
                                            + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
                                              system.adapter.esphome.0                : esphome               : Pi4                                      - disabled
                                              system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
                                              system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
                                              system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
                                            + system.adapter.go-e.0                   : go-e                  : ioBroker                                 -  enabled
                                            + system.adapter.go-e.1                   : go-e                  : ioBroker                                 -  enabled
                                            + system.adapter.hass.0                   : hass                  : ioBroker                                 -  enabled, port: 8123
                                            + system.adapter.heatingcontrol.0         : heatingcontrol        : Pi4                                      -  enabled
                                              system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
                                              system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                                              system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                                              system.adapter.ical.0                   : ical                  : Pi4                                      -  enabled
                                              system.adapter.ical.1                   : ical                  : Pi4                                      -  enabled
                                              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
                                              system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                                              system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                            + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                                            + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                                            + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
                                            + system.adapter.lgtv.0                   : lgtv                  : Pi4                                      -  enabled
                                              system.adapter.lgtv.1                   : lgtv                  : ioBroker                                 - disabled
                                              system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 - disabled, port: 8080
                                            + system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
                                            + system.adapter.lovelace.1               : lovelace              : ioBroker                                 -  enabled, port: 8098, bind: 0.0.0.0, run as: admin
                                              system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
                                              system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
                                              system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                                            + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
                                            + system.adapter.pid.0                    : pid                   : ioBroker                                 -  enabled
                                            + system.adapter.places.0                 : places                : ioBroker                                 -  enabled
                                            + system.adapter.proxmox.1                : proxmox               : ioBroker                                 -  enabled, port: 8006
                                              system.adapter.pushover.0               : pushover              : Pi3                                      - disabled
                                              system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
                                            + system.adapter.radar2.1                 : radar2                : Pi4                                      -  enabled
                                            + system.adapter.ring.0                   : ring                  : Pi4                                      -  enabled
                                            + system.adapter.rpi2.2                   : rpi2                  : Pi4                                      -  enabled
                                            + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled
                                            + system.adapter.sayit.1                  : sayit                 : ioBroker                                 -  enabled
                                              system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
                                              system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                              system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                            + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                              system.adapter.sma-em.0                 : sma-em                : ioBroker                                 -  enabled
                                              system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
                                              system.adapter.smartmeter.0             : smartmeter            : Pi4                                      - disabled
                                              system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                            + system.adapter.sourceanalytix.0         : sourceanalytix        : Pi4                                      -  enabled
                                              system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
                                              system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
                                            + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                            + system.adapter.telegram.1               : telegram              : Pi4                                      -  enabled, port: 8443, bind: 0.0.0.0
                                            + system.adapter.tesla-motors.0           : tesla-motors          : ioBroker                                 -  enabled
                                            + system.adapter.tibberlink.0             : tibberlink            : Pi4                                      -  enabled
                                            + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
                                            + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                                            + system.adapter.tuya.0                   : tuya                  : Pi4                                      -  enabled
                                            + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                                              system.adapter.uv-protect.0             : uv-protect            : ioBroker                                 -  enabled
                                              system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 - disabled
                                              system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
                                              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
                                              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
                                              system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
                                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                                              system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
                                              system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
                                              system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
                                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                                              system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                                              system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
                                              system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
                                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                                              system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                                              system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                              system.adapter.web.1                    : web                   : ioBroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                            + system.adapter.web.2                    : web                   : Pi4                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            + system.adapter.withings.0               : withings              : ioBroker                                 -  enabled
                                              system.adapter.worx.0                   : worx                  : ioBroker                                 -  enabled
                                            + system.adapter.yahka.0                  : yahka                 : Pi4                                      -  enabled
                                            + system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : ioBroker                                 -  enabled
                                              system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker                                 -  enabled
                                            + instance is alive
                                            ioBroker-Repositories
                                            Stable (default): http://download.iobroker.net/sources-dist.json
                                            Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                            Active repo(s): Beta (latest)
                                            Installed ioBroker-Instances
                                            Used repository: Beta (latest)
                                            Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
                                            Adapter    "admin"        : 6.17.14  , installed 6.17.6 [Updatable]
                                            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                            Adapter    "awtrix-light" : 1.2.0    , installed 0.16.0 [Updatable]
                                            Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                                            Adapter    "bmw"          : 2.8.0    , installed 2.8.0
                                            Adapter    "chromecast"   : 3.4.0    , installed 3.4.0
                                            Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                            Adapter    "device-watcher": 2.12.1  , installed 2.12.0 [Updatable]
                                            Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
                                            Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                                            Adapter    "esphome"      : 0.5.0-beta.8, installed 0.4.0 [Updatable]
                                            Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                                            Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
                                            Adapter    "go-e"         : 1.0.29   , installed 1.0.29
                                            Adapter    "hass"         : 1.4.0    , installed 1.4.0
                                            Adapter    "heatingcontrol": 2.12.5  , installed 2.12.5
                                            Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                            Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                                            Adapter    "ical"         : 1.15.0   , installed 1.15.0
                                            Adapter    "iot"          : 3.3.0    , installed 3.2.2  [Updatable]
                                            Adapter    "javascript"   : 8.4.0    , installed 8.3.1  [Updatable]
                                            Controller "js-controller": 5.0.19   , installed 6.0.1
                                            Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
                                            Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
                                            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                                            Adapter    "lovelace"     : 4.1.10   , installed 4.1.9  [Updatable]
                                            Adapter    "modbus"       : 6.2.2    , installed 6.1.0  [Updatable]
                                            Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                            Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                                            Adapter    "pid"          : 1.1.3    , installed 1.1.3
                                            Adapter    "places"       : 1.2.0    , installed 1.2.0
                                            Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                                            Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                                            Adapter    "radar2"       : 2.2.0    , installed 2.2.0
                                            Adapter    "ring"         : 5.0.10   , installed 5.0.10
                                            Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                                            Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
                                            Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
                                            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                            Adapter    "sma-em"       : 1.0.1    , installed 1.0.1
                                            Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                                            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                            Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                                            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                            Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
                                            Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                                            Adapter    "telegram"     : 3.3.1    , installed 3.3.1
                                            Adapter    "tesla-motors" : 1.4.5    , installed 1.4.5
                                            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                                            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                            Adapter    "uv-protect"   : 0.6.0    , installed 0.6.0
                                            Adapter    "vis-2"        : 2.9.64   , installed 2.9.60 [Updatable]
                                            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                                            Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
                                            Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
                                            Adapter    "web"          : 6.2.6    , installed 6.2.5  [Updatable]
                                            Adapter    "webui"        : 1.8.6    , installed 1.6.5  [Updatable]
                                            Adapter    "withings"     : 0.0.13   , installed 0.0.13
                                            Adapter    "worx"         : 3.0.2    , installed 2.3.4  [Updatable]
                                            Adapter    "ws"           : 2.6.1    , installed 2.6.1
                                            Adapter    "yahoo-stock-market": 0.0.6, installed 0.0.6
                                            Adapter    "zigbee2mqtt"  : 2.13.6   , installed 2.13.6
                                            Objects and States
                                            Objects: 	32352
                                            States: 	25140
                                            Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
                                            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                            Reading package lists...
                                            Pending Updates: 0
                                            *** Listening Ports ***
                                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          33110488   1/init
                                            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       33133400   2894/iobroker.js-co
                                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       33132368   2894/iobroker.js-co
                                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          33117615   857/master
                                            tcp6       0      0 :::22                   :::*                    LISTEN      0          33109589   1/init
                                            tcp6       0      0 :::111                  :::*                    LISTEN      0          33110490   1/init
                                            tcp6       0      0 :::51989                :::*                    LISTEN      1001       33143061   3696/io.nuki-extend
                                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          33117616   857/master
                                            tcp6       0      0 :::8098                 :::*                    LISTEN      1001       33143032   3667/io.lovelace.1
                                            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       33145149   3854/io.simple-api.
                                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          33110489   1/init
                                            udp6       0      0 :::111                  :::*                                0          33110491   1/init
                                            2024-05-25 20:54:20.158  - error: host.ioBroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                                            2024-05-25 20:54:20.158  - error: host.ioBroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                                            2024-05-25 20:54:20.158  - error: host.ioBroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.modbus/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                                            2024-05-25 20:54:20.158  - error: host.ioBroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                            2024-05-25 20:54:20.158  - error: host.ioBroker Caught by controller[0]: Node.js v20.13.1
                                            2024-05-25 20:54:20.158  - error: host.ioBroker instance system.adapter.modbus.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            2024-05-25 20:54:20.158  - info: host.ioBroker Restart adapter system.adapter.modbus.0 because enabled
                                            2024-05-25 20:54:21.894  - info: host.ioBroker instance system.adapter.mqtt.0 started with pid 7547
                                            2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]: /opt/iobroker/node_modules/iobroker.mqtt/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
                                            2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
                                            2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     ^
                                            2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
                                            2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
                                            2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
                                            2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                            2024-05-25 20:54:22.333  - error: host.ioBroker Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
                                            2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
                                            2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
                                            2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
                                            2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
                                            2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mqtt/node_modules/@iobroker/adapter-core/build/index.js:19:27)
                                            2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
                                            2024-05-25 20:54:22.334  - error: host.ioBroker Caught by controller[0]: Node.js v20.13.1
                                            2024-05-25 20:54:22.334  - error: host.ioBroker instance system.adapter.mqtt.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                            2024-05-25 20:54:22.334  - info: host.ioBroker Restart adapter system.adapter.mqtt.0 because enabled
                                            foxriver76 crunchip 2 Replies Last reply Reply Quote 0
                                            alpha js-controller kiera test
                                            20
                                            234
                                            43351
