    4. Alpha Test js-controller Kiera (v6.0)
    • Feuersturm
      Feuersturm @foxriver76 last edited by Feuersturm
      @foxriver76 update auf js-controller 6.0.1-alpha.0-20240525-56d9e4a2e
      Installation
      proxmox@ioBrokerTestsystem:~$ iob stop
      proxmox@ioBrokerTestsystem:~$ cd /opt/iobroker/
      proxmox@ioBrokerTestsystem:/opt/iobroker$ npm i iobroker.js-controller@next --omit=dev
      [sudo] password for proxmox:
      npm warn ERESOLVE overriding peer dependency
      npm warn While resolving: @mui/x-date-pickers@7.5.1
      npm warn Found: @mui/material@5.14.14
      npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/material
      npm warn   @mui/material@"5.14.14" from @iobroker/adapter-react-v5@4.13.22
      npm warn     @iobroker/adapter-react-v5@"^4.13.13" from @iobroker/json-config@6.17.13
      npm warn     node_modules/@iobroker/json-config
      npm warn     1 more (iobroker.radar-trap)
      npm warn
      npm warn Could not resolve dependency:
      npm warn peer @mui/material@"^5.15.14" from @mui/x-date-pickers@7.5.1
      npm warn node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-pickers
      npm warn   @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.22
      npm warn
      npm warn Conflicting peer dependency: @mui/material@5.15.18
      npm warn node_modules/@mui/material
      npm warn While resolving: @iobroker/adapter-core@3.1.4
      npm warn Found: @iobroker/types@6.0.0
      npm warn node_modules/iobroker.admin/node_modules/@iobroker/types
      npm warn   @iobroker/types@"6.0.0" from iobroker.admin@6.17.14
      npm warn     iobroker.admin@"6.17.14" from the root project
      npm warn
      npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
      npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
      npm warn   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14
      npm warn
      npm warn Conflicting peer dependency: @iobroker/types@5.0.19
      npm warn node_modules/@iobroker/types
      npm warn reify invalid or damaged lockfile detected
      npm warn reify please re-try this operation once it completes
      npm warn reify so that the damage can be corrected, or perform
      npm warn reify a fresh install with no lockfile if the problem persists.
      added 35 packages, removed 10 packages, and changed 13 packages in 1m
      397 packages are looking for funding
        run `npm fund` for details
      Keine Auffälligkeiten beim starten von ioBroker 🙂
      lobomau Feuersturm 2 Replies Last reply Reply Quote 0
      • lobomau
        lobomau @Feuersturm last edited by
        @feuersturm dein Auszug ist nicht komplett, oder? Müsste doch der längere Befehl sein, oder?
        Thomas Braun Feuersturm 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @lobomau last edited by
          @lobomau sagte in Alpha Test js-controller Kiera (v6.0):
          Das ist ein falscher Zeilenumbruch. Bestimmt per puTTY hantiert, das fabriziert das schon mal ganz gerne.
          • Feuersturm
            Feuersturm @lobomau last edited by
            @lobomau In putty gab es einen Zeilenumbruch und das copy paste Ergebnis wurde hier im Forum nicht richtig dargestellt. In den Codetags im Editor hier waren die Zeichen enthalten, wurden aber im Beitrag nicht angezeigt. Hab es korrigiert
            • Feuersturm
              Feuersturm @Feuersturm last edited by
              @foxriver76
              Auf meinem zweiten Testsystem wo nodejs20 installiert ist und ich auch gerade einmal js-controller 6.0.1-alpha.0-20240525-56d9e4a2e installiert habe:
              Installation
              proxmox@ioB-Prod-Testsystem:~$ iob stop
              proxmox@ioB-Prod-Testsystem:~$ cd /opt/iobroker/
              proxmox@ioB-Prod-Testsystem:/opt/iobroker$ npm i iobroker.js-controller@next --omit=dev
              npm WARN ERESOLVE overriding peer dependency
              npm WARN While resolving: @mui/x-date-pickers@7.5.0
              npm WARN Found: @mui/material@5.14.14
              npm WARN node_modules/@iobroker/adapter-react-v5/node_modules/@mui/material
              npm WARN   @mui/material@"5.14.14" from @iobroker/adapter-react-v5@4.13.20
              npm WARN     @iobroker/adapter-react-v5@"^4.13.6" from @iobroker/dm-gui-components@6.17.6
              npm WARN     node_modules/@iobroker/dm-gui-components
              npm WARN     2 more (@iobroker/json-config, iobroker.radar-trap)
              npm WARN
              npm WARN Could not resolve dependency:
              npm WARN peer @mui/material@"^5.15.14" from @mui/x-date-pickers@7.5.0
              npm WARN node_modules/@iobroker/adapter-react-v5/node_modules/@mui/x-date-pickers
              npm WARN   @mui/x-date-pickers@"^7.5.0" from @iobroker/adapter-react-v5@4.13.20
              npm WARN
              npm WARN Conflicting peer dependency: @mui/material@5.15.18
              npm WARN node_modules/@mui/material
              npm WARN While resolving: @iobroker/adapter-core@3.1.4
              npm WARN Found: @iobroker/types@6.0.0
              npm WARN node_modules/iobroker.admin/node_modules/@iobroker/types
              npm WARN   @iobroker/types@"6.0.0" from iobroker.admin@6.17.14
              npm WARN     iobroker.admin@"6.17.14" from the root project
              npm WARN
              npm WARN peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4
              npm WARN node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
              npm WARN   @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14
              npm WARN
              npm WARN Conflicting peer dependency: @iobroker/types@5.0.19
              npm WARN node_modules/@iobroker/types
              added 13 packages, removed 134 packages, and changed 27 packages in 1m
              291 packages are looking for funding
              iobroker Start
              Hier tauchen einige Errors auf. Der gleiche Fehler taucht bei sehr vielen Adaptern auf. Hier ein Auszug aus dem Log:
              2024-05-25 22:28:39.073  - info: host.ioB-Prod-Testsystem iobroker.js-controller version 6.0.1 js-controller starting
              2024-05-25 22:28:39.088  - info: host.ioB-Prod-Testsystem Copyright (c) 2014-2023 bluefox, 2014 hobbyquaker
              2024-05-25 22:28:39.096  - info: host.ioB-Prod-Testsystem hostname: ioB-Prod-Testsystem, node: v20.13.1
              2024-05-25 22:28:39.101  - info: host.ioB-Prod-Testsystem ip addresses: 192.168.178.105 fe80::be24:11ff:fe8c:71a4
              2024-05-25 22:28:42.804  - info: host.ioB-Prod-Testsystem connected to Objects and States
              2024-05-25 22:28:42.853  - info: host.ioB-Prod-Testsystem added notifications configuration of host
              2024-05-25 22:28:44.062  - info: host.ioB-Prod-Testsystem 68 instances found
              2024-05-25 22:28:44.220  - info: host.ioB-Prod-Testsystem starting 47 instances
              2024-05-25 22:28:44.957  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.nodeCurrent"
              2024-05-25 22:28:44.983  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.nodeNewest"
              2024-05-25 22:28:45.014  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.nodeNewestNext"
              2024-05-25 22:28:45.040  - info: host.ioB-Prod-Testsystem instance system.adapter.admin.0 started with pid 11898
              2024-05-25 22:28:45.055  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.npmCurrent"
              2024-05-25 22:28:45.112  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.npmNewest"
              2024-05-25 22:28:45.126  - info: host.ioB-Prod-Testsystem Delete state "system.host.ioB-Prod-Testsystem.versions.npmNewestNext"
              2024-05-25 22:28:45.138  - info: host.ioB-Prod-Testsystem Some obsolete host states deleted.
              2024-05-25 22:28:47.059  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
              2024-05-25 22:28:47.061  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
              2024-05-25 22:28:47.064  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
              2024-05-25 22:28:47.066  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
              2024-05-25 22:28:47.069  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
              2024-05-25 22:28:47.071  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
              2024-05-25 22:28:47.073  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:28:47.076  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              2024-05-25 22:28:47.078  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
              2024-05-25 22:28:47.081  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
              2024-05-25 22:28:47.083  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
              2024-05-25 22:28:47.086  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
              2024-05-25 22:28:47.088  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/index.js:19:27)
              2024-05-25 22:28:47.091  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:28:47.094  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Node.js v20.13.1
              2024-05-25 22:28:47.097  - error: host.ioB-Prod-Testsystem instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-05-25 22:28:47.100  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.admin.0 because enabled
              2024-05-25 22:28:49.059  - info: host.ioB-Prod-Testsystem instance system.adapter.javascript.0 started with pid 11905
              2024-05-25 22:28:52.945  - info: host.ioB-Prod-Testsystem instance system.adapter.scenes.0 started with pid 11916
              2024-05-25 22:28:54.831  - info: javascript.0 (11905) starting. Version 8.4.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
              2024-05-25 22:28:57.173  - info: host.ioB-Prod-Testsystem instance system.adapter.scheduler.0 started with pid 11942
              2024-05-25 22:28:58.780  - info: scenes.0 (11916) starting. Version 3.0.4 in /opt/iobroker/node_modules/iobroker.scenes, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
              2024-05-25 22:29:01.702  - info: host.ioB-Prod-Testsystem instance system.adapter.fritzbox.0 started with pid 11957
              2024-05-25 22:29:04.205  - info: scheduler.0 (11942) starting. Version 1.3.12 in /opt/iobroker/node_modules/iobroker.scheduler, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
              2024-05-25 22:29:05.626  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.fritzbox/node_modules/@iobroker/adapter-core/build/controllerTools.js:80
              2024-05-25 22:29:05.632  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
              2024-05-25 22:29:05.635  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
              2024-05-25 22:29:05.638  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
              2024-05-25 22:29:05.641  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/@iobroker/adapter-core/build/controllerTools.js:80:11)
              2024-05-25 22:29:05.645  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/@iobroker/adapter-core/build/controllerTools.js:154:18)
              2024-05-25 22:29:05.648  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:29:05.651  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              2024-05-25 22:29:05.654  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
              2024-05-25 22:29:05.657  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
              2024-05-25 22:29:05.660  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
              2024-05-25 22:29:05.663  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
              2024-05-25 22:29:05.666  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.fritzbox/node_modules/@iobroker/adapter-core/build/index.js:19:27)
              2024-05-25 22:29:05.669  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:29:05.672  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Node.js v20.13.1
              2024-05-25 22:29:05.675  - error: host.ioB-Prod-Testsystem instance system.adapter.fritzbox.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-05-25 22:29:05.679  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.fritzbox.0 because enabled
              2024-05-25 22:29:05.765  - info: host.ioB-Prod-Testsystem instance system.adapter.hm-rpc.0 started with pid 11968
              2024-05-25 22:29:08.260  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
              2024-05-25 22:29:08.263  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
              2024-05-25 22:29:08.265  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
              2024-05-25 22:29:08.268  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
              2024-05-25 22:29:08.271  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
              2024-05-25 22:29:08.274  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
              2024-05-25 22:29:08.276  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:29:08.279  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              2024-05-25 22:29:08.282  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
              2024-05-25 22:29:08.285  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
              2024-05-25 22:29:08.289  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
              2024-05-25 22:29:08.291  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
              2024-05-25 22:29:08.296  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rpc/node_modules/@iobroker/adapter-core/build/index.js:19:27)
              2024-05-25 22:29:08.299  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:29:08.302  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Node.js v20.13.1
              2024-05-25 22:29:08.305  - error: host.ioB-Prod-Testsystem instance system.adapter.hm-rpc.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-05-25 22:29:08.308  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.hm-rpc.0 because enabled
              2024-05-25 22:29:09.392  - info: host.ioB-Prod-Testsystem instance system.adapter.hm-rega.0 started with pid 11975
              2024-05-25 22:29:11.653  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hm-rega/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
              2024-05-25 22:29:11.656  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
              2024-05-25 22:29:11.659  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
              2024-05-25 22:29:11.664  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
              2024-05-25 22:29:11.669  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
              2024-05-25 22:29:11.673  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
              2024-05-25 22:29:11.676  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:29:11.680  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              2024-05-25 22:29:11.683  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
              2024-05-25 22:29:11.686  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
              2024-05-25 22:29:11.690  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
              2024-05-25 22:29:11.695  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
              2024-05-25 22:29:11.699  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hm-rega/node_modules/@iobroker/adapter-core/build/index.js:19:27)
              2024-05-25 22:29:11.702  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:29:11.705  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Node.js v20.13.1
              2024-05-25 22:29:11.709  - error: host.ioB-Prod-Testsystem instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-05-25 22:29:11.712  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.hm-rega.0 because enabled
              2024-05-25 22:29:13.217  - info: host.ioB-Prod-Testsystem instance system.adapter.proxmox.0 started with pid 11982
              2024-05-25 22:29:17.035  - info: host.ioB-Prod-Testsystem instance system.adapter.tr-064.0 started with pid 11993
              2024-05-25 22:29:18.402  - info: host.ioB-Prod-Testsystem instance system.adapter.admin.0 started with pid 12000
              2024-05-25 22:29:19.087  - info: proxmox.0 (11982) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.proxmox, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
              2024-05-25 22:29:19.216  - warn: proxmox.0 (11982) Using Proxmox API: https://192.168.178.2:8006/api2/json
              2024-05-25 22:29:21.748  - info: host.ioB-Prod-Testsystem instance system.adapter.worx.0 started with pid 12011
              2024-05-25 22:29:22.101  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
              2024-05-25 22:29:22.105  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
              2024-05-25 22:29:22.108  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
              2024-05-25 22:29:22.111  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
              2024-05-25 22:29:22.114  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
              2024-05-25 22:29:22.117  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
              2024-05-25 22:29:22.119  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:29:22.134  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              2024-05-25 22:29:22.137  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
              2024-05-25 22:29:22.139  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
              2024-05-25 22:29:22.142  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
              2024-05-25 22:29:22.145  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
              2024-05-25 22:29:22.147  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core/build/index.js:19:27)
              2024-05-25 22:29:22.150  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:29:22.153  - error: host.ioB-Prod-Testsystem Caught by controller[1]: Node.js v20.13.1
              2024-05-25 22:29:22.156  - error: host.ioB-Prod-Testsystem instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-05-25 22:29:22.159  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.admin.0 because enabled
              2024-05-25 22:29:25.494  - info: host.ioB-Prod-Testsystem instance system.adapter.unifi.0 started with pid 12026
              2024-05-25 22:29:27.823  - info: tr-064.0 (11993) starting. Version 4.3.0 in /opt/iobroker/node_modules/iobroker.tr-064, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
              2024-05-25 22:29:30.140  - info: host.ioB-Prod-Testsystem instance system.adapter.hue.0 started with pid 12052
              2024-05-25 22:29:30.848  - info: worx.0 (12011) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.worx, node: v20.13.1, js-controller: 6.0.1-alpha.0-20240525-56d9e4a2e
              2024-05-25 22:29:32.056  - info: worx.0 (12011) Use new aws-iot-device-sdk-v2.
              2024-05-25 22:29:32.065  - info: worx.0 (12011) Changed timeout for edgecut to 5000
              2024-05-25 22:29:32.093  - info: worx.0 (12011) Login to worx
              2024-05-25 22:29:33.930  - info: worx.0 (12011) Connected to worx server
              2024-05-25 22:29:34.338  - info: worx.0 (12011) Found 1 devices
              2024-05-25 22:29:34.350  - info: worx.0 (12011) Found device Maehphisto with id 201930198403020782E0
              2024-05-25 22:29:34.762  - info: host.ioB-Prod-Testsystem instance system.adapter.backitup.0 started with pid 12080
              2024-05-25 22:29:35.162  - info: worx.0 (12011) Multi-ZoneKeeper found! Create State : zoneKeeper
              2024-05-25 22:29:36.336  - info: worx.0 (12011) DoubleShedule found, create states...
              2024-05-25 22:29:38.606  - error: host.ioB-Prod-Testsystem Caught by controller[0]: /opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/controllerTools.js:83
              2024-05-25 22:29:38.613  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     throw new Error(`Cannot resolve JS-Controller module ${name}.js`);
              2024-05-25 22:29:38.615  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     ^
              2024-05-25 22:29:38.634  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Error: Cannot resolve JS-Controller module letsencrypt.js
              2024-05-25 22:29:38.637  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at resolveNamedModule (/opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/controllerTools.js:83:11)
              2024-05-25 22:29:38.639  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/controllerTools.js:157:18)
              2024-05-25 22:29:38.659  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:29:38.662  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
              2024-05-25 22:29:38.664  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
              2024-05-25 22:29:38.684  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
              2024-05-25 22:29:38.686  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
              2024-05-25 22:29:38.691  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
              2024-05-25 22:29:38.698  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.hue/node_modules/@iobroker/adapter-core/build/index.js:19:27)
              2024-05-25 22:29:38.701  - error: host.ioB-Prod-Testsystem Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
              2024-05-25 22:29:38.716  - error: host.ioB-Prod-Testsystem Caught by controller[0]: Node.js v20.13.1
              2024-05-25 22:29:38.729  - error: host.ioB-Prod-Testsystem instance system.adapter.hue.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-05-25 22:29:38.732  - info: host.ioB-Prod-Testsystem Restart adapter system.adapter.hue.0 because enabled
              2024-05-25 22:29:38.951  - info: host.ioB-Prod-Testsystem instance system.adapter.fritzbox.0 started with pid 12087
              • foxriver76
                foxriver76 Developer @Feuersturm last edited by
                @feuersturm welche Admin Version ist auf dem System installiert mit den Fehlern?
                • Feuersturm
                  @foxriver76 sagte in Alpha Test js-controller Kiera (v6.0):
                  system.adapter.admin                   : admin          - v6.17.14
                  • foxriver76
                    @feuersturm Kannst du mir vom betroffenen Host npm ls @iobroker/adapter-core zeigen (ausgeführt in opt/iobroker)
                    • Feuersturm
                      Na klar:
                      proxmox@ioB-Prod-Testsystem:/opt/iobroker$ npm ls @iobroker/adapter-core
                      iobroker.inst@2.0.3 /opt/iobroker
                      +-- iobroker.admin@6.17.14
                      | +-- @iobroker/adapter-core@3.1.4
                      | `-- @iobroker/socket-classes@1.5.0
                      |   `-- @iobroker/adapter-core@3.0.4
                      +-- iobroker.backitup@2.11.0
                      +-- iobroker.daswetter@3.1.13
                      +-- iobroker.dwd@2.8.5
                      | `-- @iobroker/adapter-core@2.6.12
                      +-- iobroker.esphome@0.5.0-beta.8
                      +-- iobroker.fritzbox@0.6.0
                      | `-- @iobroker/adapter-core@3.0.6
                      +-- iobroker.fullcalendar@2.3.16
                      | `-- @iobroker/adapter-core@3.1.4
                      +-- iobroker.fully-tablet-control@0.3.8
                      | `-- @iobroker/adapter-core@2.6.12 deduped
                      +-- iobroker.hm-rega@4.0.0
                      | `-- @iobroker/adapter-core@3.0.3
                      +-- iobroker.hm-rpc@1.17.0
                      | +-- @iobroker/adapter-core@3.0.4
                      | `-- @iobroker/dm-utils@0.1.9
                      +-- iobroker.hue@3.11.0
                      +-- iobroker.ical@1.15.0
                      +-- iobroker.influxdb@4.0.2
                      +-- iobroker.javascript@8.4.0
                      +-- iobroker.js-controller@6.0.1-alpha.0-20240525-56d9e4a2e
                      +-- iobroker.mqtt@5.2.0
                      +-- iobroker.nina@0.0.26
                      +-- iobroker.openweathermap@1.0.4
                      +-- iobroker.proxmox@2.3.0
                      +-- iobroker.radar-trap@2.2.0
                      +-- iobroker.rainbird@0.2.3
                      | `-- @iobroker/adapter-core@1.0.3
                      +-- iobroker.samsung@0.6.0
                      +-- iobroker.sayit@3.0.5
                      +-- iobroker.scenes@3.0.4
                      +-- iobroker.scheduler@1.3.12
                      +-- iobroker.seq@0.3.0
                      +-- iobroker.shuttercontrol@1.7.0
                      +-- iobroker.simple-api@2.8.0
                      +-- iobroker.socketio@6.7.0
                      +-- iobroker.sonos@3.0.0
                      +-- iobroker.spotify-premium@1.5.0
                      +-- iobroker.tankerkoenig@3.4.0
                      +-- iobroker.telegram@3.3.1
                      +-- iobroker.tr-064@4.3.0
                      +-- iobroker.trashschedule@3.3.0
                      +-- iobroker.unifi@0.7.0
                      +-- iobroker.valloxmv@1.2.0
                      +-- iobroker.vis-2@2.9.64
                      +-- iobroker.vis-google-fonts@1.0.4
                      +-- iobroker.vis-history@1.0.0
                      +-- iobroker.vis-metro@1.2.0
                      +-- iobroker.vis-timeandweather@1.2.2
                      +-- iobroker.vis@1.5.6
                      +-- iobroker.web@6.2.6
                      +-- iobroker.worx@3.0.2
                      `-- iobroker.ws@2.6.1
                      • foxriver76
                        foxriver76 Developer @Feuersturm last edited by foxriver76
                        @feuersturm Hm oaky, es scheint irgendein Adapter bringt eine exakte Version mit von Adapter-Core (3.0.4) aber ich muss suchen welcher. Dadurch wird dann für viele Adapter nicht die 3.1.4 mit verwendet.
                        Jop, daswetter scheint es zu sein, kannst du daswetter mal von GitHub updaten?
                        Das scheint allgemein bei den Adaptern von rg-engineering https://github.com/rg-engineering?tab=repositories&q=ioBroker.&type=source&language=&sort= der Fall zu sein 😞
                        Feuersturm T 2 Replies Last reply Reply Quote 0
                        • Feuersturm
                          @foxriver76 Hab daswetter von github installiert und noch einmal js-controller 6 installiert
                          Es sind immer noch sehr viele Fehler vorhanden
                          log.txt
                            TT-Tom @foxriver76 last edited by TT-Tom
                            @foxriver76
                            habe auch nochmal das Update angestoßen, nachdem ich den Admin auf 6.17.14 aktualisiert habe.
                            tom@iobtest:/opt/iobroker $ npm i iobroker.js-controller@next --omit=dev
                            npm WARN
                            npm WARN
                            npm ls @iobroker/adapter-core brachte das hier
                            tom@iobtest:/opt/iobroker $ npm ls @iobroker/adapter-core
                            iobroker.inst@3.0.0 /opt/iobroker
                            ├─┬ iobroker.accuweather@1.4.0
                            │ └── @iobroker/adapter-core@3.1.4
                            ├─┬ iobroker.admin@6.17.14
                            │ ├── @iobroker/adapter-core@3.1.4
                            │ └─┬ @iobroker/socket-classes@1.5.0
                            ├─┬ iobroker.alias-manager@1.2.6
                            │ └── @iobroker/adapter-core@2.6.12
                            ├─┬ iobroker.backitup@2.11.0
                            ├─┬ iobroker.fahrplan@1.2.3
                            │ └── @iobroker/adapter-core@2.6.12 deduped
                            ├─┬ iobroker.ical@1.15.0
                            ├─┬ iobroker.influxdb@4.0.2
                            ├─┬ iobroker.javascript@8.4.0
                            ├─┬ iobroker.js-controller@6.0.1-alpha.0-20240525-56d9e4a2e
                            ├─┬ iobroker.mqtt-client@1.8.0
                            ├─┬ iobroker.mqtt@5.2.0
                            ├─┬ iobroker.netatmo-crawler@0.8.1
                            ├─┬ iobroker.nspanel-lovelace-ui@0.0.4-preAlpha.3 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#eaa0acd87ee8a90d72fee56e8fc3531ee62a94e4)
                            ├─┬ iobroker.opendtu@1.0.1
                            ├─┬ iobroker.simple-api@2.8.0
                            ├─┬ iobroker.socketio@6.7.0
                            ├─┬ iobroker.trashschedule@3.3.0
                            ├─┬ iobroker.web@6.2.6
                            ├─┬ iobroker.ws@2.6.1
                            └─┬ iobroker.yahka@1.0.3
                            das System läuft ansonsten sauber hoch, bis auf das die npm-Module die im Javascript-Adapter eingetragen sind geladen werden.
                            serialport; dayjs, moment-parseformat
                            meine Instanzen
                            tom@iobtest:/opt/iobroker $ iob list instances
                              system.adapter.accuweather.0            : accuweather           : iobtest                                  - disabled
                            + system.adapter.admin.0                  : admin                 : iobtest                                  -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                              system.adapter.alias-manager.0          : alias-manager         : iobtest                                  - disabled
                            + system.adapter.backitup.0               : backitup              : iobtest                                  -  enabled
                              system.adapter.devices.0                : devices               : iobtest                                  - disabled
                            + system.adapter.fahrplan.0               : fahrplan              : iobtest                                  -  enabled
                              system.adapter.ical.0                   : ical                  : iobtest                                  -  enabled
                            + system.adapter.influxdb.0               : influxdb              : iobtest                                  -  enabled, port: 8086
                            + system.adapter.javascript.0             : javascript            : iobtest                                  -  enabled
                            + system.adapter.javascript.1             : javascript            : iobtest                                  -  enabled
                            + system.adapter.mqtt-client.0            : mqtt-client           : iobtest                                  -  enabled, port: 7531
                            + system.adapter.mqtt.0                   : mqtt                  : iobtest                                  -  enabled, port: 1883, bind: 0.0.0.0
                              system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobtest                                  -  enabled
                              system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobtest                                  - disabled
                              system.adapter.opendtu.0                : opendtu               : iobtest                                  - disabled
                              system.adapter.trashschedule.0          : trashschedule         : iobtest                                  - disabled
                              system.adapter.web.0                    : web                   : iobtest                                  - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                              system.adapter.yahka.0                  : yahka                 : iobtest                                  - disabled
                            + instance is alive
                            • foxriver76
                              foxriver76 Developer @Thomas Braun last edited by
                              @thomas-braun Kannst du mir mal die root package.json zeigen, also den Inhalt von /opt/iobroker/package.json
                                Thomas Braun Most Active @foxriver76 last edited by Thomas Braun
                                @foxriver76
                                echad@chet:~ $ cat /opt/iobroker/package.json
                                {"name":"iobroker.inst","version":"3.0.0","private":true,"description":"Automate your Life","engines":{"node":">=16.0.0"},"dependencies":{"@iobroker-javascript.0/playactor":"npm:playactor@^0.4.1","iobroker.admin":"6.17.14","iobroker.alexa2":"3.26.5","iobroker.alias-manager":"1.2.6","iobroker.awtrix-light":"1.2.0","iobroker.backitup":"2.11.0","iobroker.ble":"0.14.0","iobroker.cloud":"5.0.1","iobroker.devices":"1.1.5","iobroker.drops-weather":"github:inbux/ioBroker.drops-weather","iobroker.echarts":"1.7.2","iobroker.firetv":"2.1.0","iobroker.followthesun":"0.5.0","iobroker.govee-app":"github:TA2k/ioBroker.govee-app#6a0f84cfb34eb3a0ca647c7a519b9d5a48ccfb85","iobroker.govee-local":"0.2.6","iobroker.history":"3.0.1","iobroker.ical":"1.15.0","iobroker.iceroad":"1.2.1","iobroker.iot":"3.3.0","iobroker.javascript":"8.4.0","iobroker.js-controller":"^6.0.1-alpha.0-20240525-56d9e4a2e","iobroker.midea":"github:TA2k/ioBroker.midea#0d037c0c9a025b193546f881f747c8f998bfc724","iobroker.mihome":"1.4.0","iobroker.mihome-cloud":"0.1.1","iobroker.mihome-vacuum":"4.2.0","iobroker.mqtt":"5.2.0","iobroker.nina":"0.0.26","iobroker.nuki-extended":"2.7.0","iobroker.nut":"1.6.0","iobroker.opendtu":"1.0.1","iobroker.openweathermap":"1.0.4","iobroker.parcel":"github:TA2k/ioBroker.parcel","iobroker.rpi2":"1.3.2","iobroker.sainlogic":"0.10.5","iobroker.samsung":"0.6.0","iobroker.samsung_tizen":"1.1.0","iobroker.simple-api":"2.8.0","iobroker.socketio":"6.7.0","iobroker.switchbot-hub":"github:DrozmotiX/ioBroker.switchbot-hub#de8c1ad97edafedb16cbbb2c6dc14b032848df8e","iobroker.tado":"0.5.4","iobroker.tankerkoenig":"3.4.0","iobroker.tr-064":"4.3.0","iobroker.tradfri":"3.1.3","iobroker.trashschedule":"3.3.0","iobroker.tuya":"3.15.0","iobroker.vis-2":"2.9.64","iobroker.weather-warnings":"0.6.7","iobroker.web":"6.2.6","iobroker.whatsapp-cmb":"0.3.0","iobroker.ws":"2.6.1","iobroker.zigbee":"1.10.3"}}
                                echad@chet:~ $
                                • foxriver76
                                  @thomas-braun gibt es den folder /opt/iobroker/node_modules/@iobroker-javascript.0/playactor ?
                                    @foxriver76
                                    Ja, den gibt es:
                                    echad@chet:~ $ ls -lah /opt/iobroker/node_modules/@iobroker-javascript.0/
                                    total 48K
                                    drwxrwxr-x+   3 iobroker iobroker 4.0K May 22 13:03 .
                                    drwxrwxr-x+ 907 iobroker iobroker  36K May 26 09:38 ..
                                    drwxrwxr-x+   4 iobroker iobroker 4.0K May 22 13:03 playactor
                                    echad@chet:~ $ ls -lah /opt/iobroker/node_modules/@iobroker-javascript.0/playactor/
                                    total 24K
                                    drwxrwxr-x+  4 iobroker iobroker 4.0K May 22 13:03 .
                                    drwxrwxr-x+  3 iobroker iobroker 4.0K May 22 13:03 ..
                                    -rw-rwxr--+  1 iobroker iobroker  992 May 22 13:03 README.md
                                    drwxrwxr-x+ 11 iobroker iobroker 4.0K May 22 13:03 dist
                                    drwxrwxr-x+ 16 iobroker iobroker 4.0K May 25 09:58 node_modules
                                    -rw-rwxr--+  1 iobroker iobroker 2.0K May 22 13:03 package.json
                                    echad@chet:~ $
                                    • mcm1957
                                      mcm1957 last edited by
                                      Im Prinzip haben ALLE Adapter von rg-engineering das Problem dass die mit festgezurrten Dependencies unterwegs sind 😞
                                      Das betrifft:
                                      • amtronwallbox
                                      • daswetter
                                      • ebus
                                      • heatingcontrol
                                      • minmax
                                      • mysql
                                      • openhomecontrol
                                      • pvoutputorg
                                      • semp
                                      • spfspot
                                      Die GitHub Versionen sollten - stichprobenartig geprüft - mittlerweile passende aber auch festgezurrte Versionen haben. Wann da neue Release kommen - keine Ahnung.
                                      @apollon77
                                      Kannst du ev. mal mit ihm reden / schreiben und ersuchen zeitnahe eine neue Version ALLER seiner Adapter zu veröffentlichen die aktuelle Versionen und diese mit sematic versioning (^1.2.3) einbinden - sofern nicht irgendein tech nischer Grund bei der einen oder anderen Abhängigkeit besteht diese auf eine absolute Version festzuzurren ?
                                      Oder seht ihr (@foxriver76 , @apollon77) das anders?
                                      foxriver76 Rene_HM 2 Replies Last reply Reply Quote 0
                                      • foxriver76
                                        foxriver76 Developer @mcm1957 last edited by foxriver76
                                        @mcm1957 sagte in Alpha Test js-controller Kiera (v6.0):
                                        amtronwallbox
                                        daswetter
                                        ebus
                                        heatingcontrol
                                        minmax
                                        mysql
                                        openhomecontrol
                                        pvoutputorg
                                        semp
                                        spfspot
                                        Sehe ich genauso, habs ihm auch hier mal geschrieben, aber gib ihm mal ein paar Tage. Wir machen das ja alle nur als Hobby + ist jetzt nur ein Alpha Test bislang.
                                        • foxriver76
                                          @thomas-braun Okay, scheint aber speziell dein Package zu sein und kein generelles Problem, axios geht z. B. bei mir. Mit einem klassischen require bekomme ich dann auch eine aussagekräftigere Fehlermeldung und zwar Error: Cannot find module '/opt/iobroker/node_modules/@iobroker-javascript.0/playactor/dist/index.js'. Please verify that the package.json has a valid "main" entry
                                          Das Package stellt nur eine bin bereit und kann nicht von anderen Modulen importiert werden. Frage wäre was machst du denn überhaupt da mit?
                                          Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                                          • mcm1957
                                            mcm1957 @foxriver76 last edited by
                                            @foxriver76 said in Alpha Test js-controller Kiera (v6.0):
                                            Ja passt schon. Wollte auch nicht auf Zeit drängen sondern primär auf 'alle' und auch auf 'nicht festgezurrt'. Das kann Ingo ggF fundierter rüberbringen - wenn ihr es auch so seht. Und wenn nicht, dann ists ne Info an mich 🙂 Festzurren ist m.E. weniger sinnvoll (wobei Ausnahmen durchaus notwendig sein können). Bin mir noch nicht sicher, ob ich nicht Adapter mit festgezurrten ioBroker Abhängigkeiten rejecten sollte. Damit wir in Zukunft nicht wieder über so was stolpern.
                                            foxriver76 1 Reply Last reply Reply Quote 1
                                            alpha js-controller kiera test
                                            20
                                            234
                                            43414
