    4. Iobroker nach Node.js Update nicht mehr erreichbar
      Thomas Braun Most Active @Stefan-I.O. last edited by
      @stefan-i-o
      Buster ist tot und erhält die vermisste Datei auch daher nicht mehr.
      Installier da das aktuelle Release 'Bookworm'.
        Stefan-I.O. @Thomas Braun last edited by
        @thomas-braun said in Iobroker nach Node.js Update nicht mehr erreichbar:
        @stefan-i-o
        Kannst Du mir bitte erklären, wie ich das anstellen kann?
          Stefan-I.O. @Ro75 last edited by Stefan-I.O.
          @ro75 said in Iobroker nach Node.js Update nicht mehr erreichbar:
          @stefan-i-o mach mal
          sudo apt update
          sudo apt full-upgrade
          Ro75.
          pi@raspberrypi:~ $ sudo apt full-upgrade
          Reading package lists... Done
          Building dependency tree
          Calculating upgrade... Done
          The following packages were automatically installed and are no longer required:
            libdav1d3 python-colorzero
          Use 'sudo apt autoremove' to remove them.
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo full-upgrade
          -bash: pi@raspberrypi:~: command not found
          pi@raspberrypi:~ $ sudo: full-upgrade: command not found
          -bash: sudo:: command not found
          pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo apt full-upgrade
          pi@raspberrypi:~ $ Reading package lists... Done
          -bash: Reading: command not found
          pi@raspberrypi:~ $ Building dependency tree
          -bash: Building: command not found
          pi@raspberrypi:~ $ Reading state information... Done
          pi@raspberrypi:~ $ Calculating upgrade... Done
          -bash: Calculating: command not found
          pi@raspberrypi:~ $ The following packages were automatically installed and are no longer required:
          -bash: The: command not found
          pi@raspberrypi:~ $   libdav1d3 python-colorzero
          -bash: libdav1d3: command not found
          pi@raspberrypi:~ $ Use 'sudo apt autoremove' to remove them.
          -bash: Use: command not found
          pi@raspberrypi:~ $ 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded
            @stefan-i-o
            Backup des ioBrokers haben, dann danach NEUinstallieren:
            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
            Backup in den ioBroker wieder einspielen, fertig.
            Und dann künftig neben dem ioBroker auch das Betriebssystem auf Stand halten.
              @stefan-i-o
              Eine andere Möglichkeit gibt es nicht das Betriebssystem zu aktualisieren, als IoBroker neu aufzusetzen?
                Thomas Braun Most Active @Stefan-I.O. last edited by Thomas Braun
                @stefan-i-o
                Nein. Nicht bei einem so großen Sprung.
                Den ioBroker setzt du ja auch nicht neu auf, weil du ein Backup hast
                  @stefan-i-o
                  Vielen Dank für den Hinweis!
                  Ich habe das System neu aufgesetzt und das Backup eingespielt.
                  Jetzt bin ich plötzlich bei Node 20.13.1 und NPM 10.5.2 (Nicht aktuell!?)
                  Passt das so?
                  Nochmal ein Update ausführen?
                    @stefan-i-o sagte in Iobroker nach Node.js Update nicht mehr erreichbar:
                    Nein, das passt so. npm lässt man in Ruhe, das schwimmt immer in passender Version bei nodejs mit.
                    Beim nächsten Update von nodejs wird sich auch die Version von npm anpassen.
                      OK, "iob nodejs-update" ist aber grundsätzlich richtig, um Node.js zukünftig zu aktualisieren?
                      D.h. das Problem lag in meinem Fall an einer alten Linux-Version?
                        Vielleicht kannst Du mir noch zur mitteilen, warum der Info-Adapter nach dem Backup einspielen nicht mehr aktiv wird:
                          Jein, das ist nur erforderlich bei Upgrades auf eine neue Major-Version oder bei verfummelter Installation von nodejs.
                          Bei dir läuft das aber nun bei der üblichen Systempflege mit.
                          Ja. Deswegen setzt man auch keine abgekündigten Versionen ein.
                            @stefan-i-o
                            Der Info-Adapter ist veraltet und wird nicht mehr unterstützt. Kannst du rauswerfen.
                              Kann es sein, das die "influxdb" nicht Bestandteil des Backups war, und separat neu installiert werden muss?
                                Wenn du es nicht im Backup eingestellt hast dann nicht. Die Datenbank selber muss aber wohl wieder installiert werden.
                                Leg das entsprechende Repo wieder an.
                                https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                                  Stefan-I.O. last edited by Stefan-I.O.
                                  Influx hatte ich dummerweise leider nicht im Backup aktiviert 😞
                                  Die Installation habe ich nochmal wie folgt durchgeführt (Quelle: Verdrahtet.info) :
                                  wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                                  source /etc/os-release
                                  echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                  sudo apt-get update
                                  sudo apt-get install influxdb
                                  sudo service influxdb start
                                  sudo influx
                                  sudo: influx: command not found
                                  In ioBroker ist influxdb zumindest wieder grün:
                                  sudo apt-get update
                                  sudo influx
                                    @stefan-i-o
                                    Die Installation ist so falsch. Mit apt-key macht man das nicht mehr.
                                    Warum machste es nicht mit dem aktuellen Repo?
                                    iobroker oberfläche iobroker.web node js update fehler
                                    1963
