    4. Iobroker nach Node.js Update nicht mehr erreichbar
      Stefan-I.O. @Thomas Braun last edited by
      @thomas-braun said in Iobroker nach Node.js Update nicht mehr erreichbar:
      @stefan-i-o
      Buster ist tot und erhält die vermisste Datei auch daher nicht mehr.
      Installier da das aktuelle Release 'Bookworm'.
      Kannst Du mir bitte erklären, wie ich das anstellen kann?
        Stefan-I.O. @Ro75 last edited by Stefan-I.O.
        @ro75 said in Iobroker nach Node.js Update nicht mehr erreichbar:
        @stefan-i-o mach mal
        sudo apt update
        sudo apt full-upgrade
        Ro75.
        pi@raspberrypi:~ $ sudo apt full-upgrade
        Reading package lists... Done
        Building dependency tree
        Calculating upgrade... Done
        The following packages were automatically installed and are no longer required:
          libdav1d3 python-colorzero
        Use 'sudo apt autoremove' to remove them.
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo full-upgrade
        -bash: pi@raspberrypi:~: command not found
        pi@raspberrypi:~ $ sudo: full-upgrade: command not found
        -bash: sudo:: command not found
        pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo apt full-upgrade
        pi@raspberrypi:~ $ Reading package lists... Done
        -bash: Reading: command not found
        pi@raspberrypi:~ $ Building dependency tree
        -bash: Building: command not found
        pi@raspberrypi:~ $ Reading state information... Done
        pi@raspberrypi:~ $ Calculating upgrade... Done
        -bash: Calculating: command not found
        pi@raspberrypi:~ $ The following packages were automatically installed and are no longer required:
        -bash: The: command not found
        pi@raspberrypi:~ $   libdav1d3 python-colorzero
        -bash: libdav1d3: command not found
        pi@raspberrypi:~ $ Use 'sudo apt autoremove' to remove them.
        -bash: Use: command not found
        pi@raspberrypi:~ $ 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded
          Thomas Braun Most Active @Stefan-I.O. last edited by
          @stefan-i-o
          Backup des ioBrokers haben, dann danach NEUinstallieren:
          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
          Backup in den ioBroker wieder einspielen, fertig.
          Und dann künftig neben dem ioBroker auch das Betriebssystem auf Stand halten.
            @stefan-i-o
            Eine andere Möglichkeit gibt es nicht das Betriebssystem zu aktualisieren, als IoBroker neu aufzusetzen?
              Thomas Braun Most Active @Stefan-I.O. last edited by Thomas Braun
              @stefan-i-o
              Nein. Nicht bei einem so großen Sprung.
              Den ioBroker setzt du ja auch nicht neu auf, weil du ein Backup hast
                @stefan-i-o
                Vielen Dank für den Hinweis!
                Ich habe das System neu aufgesetzt und das Backup eingespielt.
                Jetzt bin ich plötzlich bei Node 20.13.1 und NPM 10.5.2 (Nicht aktuell!?)
                Passt das so?
                Nochmal ein Update ausführen?
                  @stefan-i-o sagte in Iobroker nach Node.js Update nicht mehr erreichbar:
                  Nein, das passt so. npm lässt man in Ruhe, das schwimmt immer in passender Version bei nodejs mit.
                  Beim nächsten Update von nodejs wird sich auch die Version von npm anpassen.
                    OK, "iob nodejs-update" ist aber grundsätzlich richtig, um Node.js zukünftig zu aktualisieren?
                    D.h. das Problem lag in meinem Fall an einer alten Linux-Version?
                      Vielleicht kannst Du mir noch zur mitteilen, warum der Info-Adapter nach dem Backup einspielen nicht mehr aktiv wird:
                        Jein, das ist nur erforderlich bei Upgrades auf eine neue Major-Version oder bei verfummelter Installation von nodejs.
                        Bei dir läuft das aber nun bei der üblichen Systempflege mit.
                        Ja. Deswegen setzt man auch keine abgekündigten Versionen ein.
                          @stefan-i-o
                          Der Info-Adapter ist veraltet und wird nicht mehr unterstützt. Kannst du rauswerfen.
                            Kann es sein, das die "influxdb" nicht Bestandteil des Backups war, und separat neu installiert werden muss?
                              Wenn du es nicht im Backup eingestellt hast dann nicht. Die Datenbank selber muss aber wohl wieder installiert werden.
                              Leg das entsprechende Repo wieder an.
                              https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                                Stefan-I.O. last edited by Stefan-I.O.
                                Influx hatte ich dummerweise leider nicht im Backup aktiviert 😞
                                Die Installation habe ich nochmal wie folgt durchgeführt (Quelle: Verdrahtet.info) :
                                wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                                source /etc/os-release
                                echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                sudo apt-get update
                                sudo apt-get install influxdb
                                sudo service influxdb start
                                sudo influx
                                sudo: influx: command not found
                                In ioBroker ist influxdb zumindest wieder grün:
                                sudo apt-get update
                                sudo influx
                                  @stefan-i-o
                                  Die Installation ist so falsch. Mit apt-key macht man das nicht mehr.
                                  Warum machste es nicht mit dem aktuellen Repo?
                                  iobroker oberfläche iobroker.web node js update fehler
                                  1963
