    3. Einsteigerfragen
    4. Installation
    5. iobroker influxdb1.x econnrefused 192.168.178.120:8086
    • Meister Mopper
      Meister Mopper @pepa last edited by
      @pepa sagte in iobroker influxdb1.x econnrefused 192.168.178.120:8086:
      Skript v.2024-04-21
      *** BASE SYSTEM ***
       Static hostname: ppmint-ESPRIMO-Q556-2
             Icon name: computer-desktop
               Chassis: desktop
      Operating System: Linux Mint 21.3
                Kernel: Linux 5.15.0-106-generic
          Architecture: x86-64
       Hardware Vendor: FUJITSU
        Hardware Model: ESPRIMO Q556/2
      model name	: Intel(R) Core(TM) i3-6100T CPU @ 3.20GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       16:23:19 up 1 day, 23:54,  2 users,  load average: 0.38, 0.37, 0.28
      CPU threads: 4
      *** Time and Time Zones ***
                     Local time: Sun 2024-05-12 16:23:19 CEST
                 Universal time: Sun 2024-05-12 14:23:19 UTC
                       RTC time: Sun 2024-05-12 14:23:25
                    NTP service: active
                RTC in local TZ: yes
      Warning: The system is configured to read the RTC time in the local time zone.
               This mode cannot be fully supported. It will create various problems
               with time zone changes and daylight saving time adjustments. The RTC
               time is never updated, it relies on external facilities to maintain it.
               If at all possible, use RTC in UTC by calling
               'timedatectl set-local-rtc 0'.
      *** Users and Groups ***
      User that called 'iob diag':
      ppmint
      HOME=/home/ppmint
      GROUPS=ppmint adm cdrom sudo dip plugdev lpadmin sambashare iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop: 	cinnamon
      Terminal: 	x11
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:            7.8G        2.6G        1.1G        521M        4.1G        4.3G
      Swap:           2.0G         47M        2.0G
      Total:          9.8G        2.7G        3.1G
      Active iob-Instances: 	13
               7782 M total memory
               2632 M used memory
               2169 M active memory
               3240 M inactive memory
               1063 M free memory
                895 M buffer memory
               3191 M swap cache
               2047 M total swap
                 47 M used swap
               2000 M free swap
      top - 16:23:20 up 1 day, 23:54,  2 users,  load average: 0.38, 0.37, 0.28
      Tasks: 261 total,   1 running, 260 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  2.9 us,  2.9 sy,  0.0 ni, 94.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7783.0 total,   1061.3 free,   2632.6 used,   4089.1 buff/cache
      MiB Swap:   2048.0 total,   2001.0 free,     47.0 used.   4329.8 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * casper-md5check.service loaded failed failed casper-md5check Verify Live ISO checksums
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** FILESYSTEM ***
      Filesystem     Type   Size  Used Avail Use% Mounted on
      tmpfs          tmpfs  779M  1.7M  777M   1% /run
      /dev/sda2      ext4   234G   31G  191G  15% /
      tmpfs          tmpfs  3.9G   23M  3.8G   1% /dev/shm
      tmpfs          tmpfs  5.0M  4.0K  5.0M   1% /run/lock
      /dev/nvme0n1p1 vfat   511M  6.1M  505M   2% /boot/efi
      tmpfs          tmpfs  779M  128K  779M   1% /run/user/1000
      [Fri May 10 16:28:54 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Fri May 10 16:28:55 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
      [Fri May 10 17:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Fri May 10 18:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Fri May 10 19:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Fri May 10 20:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Fri May 10 21:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Fri May 10 22:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Fri May 10 23:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 00:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 01:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 02:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 03:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 04:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 05:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 06:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 07:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 08:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 09:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 10:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 11:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 12:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 13:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 14:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 15:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 16:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 17:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 18:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 19:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 20:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 21:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 22:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sat May 11 23:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 00:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 01:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 02:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 03:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 04:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 05:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 06:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 07:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 08:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 09:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 10:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 11:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 12:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 13:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 14:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 15:00:00 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun May 12 16:00:01 2024] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      Show mounted filesystems:
      TARGET                                        SOURCE         FSTYPE          OPTIONS
      /                                             /dev/sda2      ext4            rw,relatime,errors=remount-ro
      |-/sys                                        sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security                      securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup                            cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore                            pstore         pstore          rw,nosuid,nodev,noexec,relatime
      | |-/sys/firmware/efi/efivars                 efivarfs       efivarfs        rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf                               bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug                         debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing                       tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections                  fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config                        configfs       configfs        rw,nosuid,nodev,noexec,relatime
      |-/proc                                       proc           proc            rw,nosuid,nodev,noexec,relatime
      | `-/proc/sys/fs/binfmt_misc                  systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=20386
      |   `-/proc/sys/fs/binfmt_misc                binfmt_misc    binfmt_misc     rw,nosuid,nodev,noexec,relatime
      |-/dev                                        udev           devtmpfs        rw,nosuid,relatime,size=3918988k,nr_inodes=979747,mode=755,inode64
      | |-/dev/pts                                  devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | |-/dev/shm                                  tmpfs          tmpfs           rw,nosuid,nodev,inode64
      | |-/dev/hugepages                            hugetlbfs      hugetlbfs       rw,relatime,pagesize=2M
      | `-/dev/mqueue                               mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
      |-/run                                        tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=796980k,mode=755,inode64
      | |-/run/lock                                 tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
      | |-/run/credentials/systemd-sysusers.service none           ramfs           ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs                           sunrpc         rpc_pipefs      rw,relatime
      | `-/run/user/1000                            tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=796976k,nr_inodes=199244,mode=700,uid=1000,gid=1000,inode64
      |   |-/run/user/1000/gvfs                     gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      |   `-/run/user/1000/doc                      portal         fuse.portal     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot/efi                                   /dev/nvme0n1p1 vfat            rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
      /var:
      2.2G	/var/
      1.4G	/var/cache
      1.3G	/var/cache/apt
      1.2G	/var/cache/apt/archives
      690M	/var/lib
      Archived and active journals take up 104.0M in the file system.
      /opt/iobroker/backups:
      7.6M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      168M	/opt/iobroker/iobroker-data/
      114M	/opt/iobroker/iobroker-data/files
      57M	/opt/iobroker/iobroker-data/files/javascript.admin
      38M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      37M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      9.3M	/opt/iobroker/iobroker-data/objects.jsonl
      8.5M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
      7.0M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
      6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v18.20.2
      /usr/bin/node 		v18.20.2
      /usr/bin/npm 		10.5.0
      /usr/bin/npx 		10.5.0
      /usr/bin/corepack 	0.25.2
      nodejs:
        Installed: 18.20.2-1nodesource1
        Candidate: 18.20.2-1nodesource1
        Version table:
       *** 18.20.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.9~dfsg-1ubuntu3.5 500
              500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
              500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	5.0.19
      admin: 		6.13.16
      javascript: 	7.8.0
      nodejs modules from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : ppmint-ESPRIMO-Q556-2                    -  enabled
      + system.adapter.discovery.0              : discovery             : ppmint-ESPRIMO-Q556-2                    -  enabled
        system.adapter.flot.0                   : flot                  : ppmint-ESPRIMO-Q556-2                    -  enabled
      + system.adapter.history.0                : history               : ppmint-ESPRIMO-Q556-2                    -  enabled
      + system.adapter.influxdb.0               : influxdb              : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : ppmint-ESPRIMO-Q556-2                    -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : ppmint-ESPRIMO-Q556-2                    -  enabled
      + system.adapter.sonoff.0                 : sonoff                : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.sql.0                    : sql                   : ppmint-ESPRIMO-Q556-2                    - disabled, port: 3306
      + system.adapter.web.0                    : web                   : ppmint-ESPRIMO-Q556-2                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sql"          : 2.2.0    , installed 2.2.0
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Objects and States
      Objects: 	432
      States: 	330
      Hit:1 https://apt.grafana.com stable InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
      Hit:4 https://linux.teamviewer.com/deb stable InRelease
      Hit:5 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:6 https://dl.google.com/linux/chrome/deb stable InRelease
      Hit:7 http://archive.ubuntu.com/ubuntu jammy-backports InRelease
      Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:9 https://ppa.launchpadcontent.net/linuxgndu/sqlitebrowser/ubuntu jammy InRelease
      Ign:10 http://packages.linuxmint.com virginia InRelease
      Hit:11 http://packages.linuxmint.com virginia Release
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:5939          0.0.0.0:*               LISTEN      0          26169      1393/teamviewerd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          867753     88824/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       25820      795/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       25827      795/iobroker.js-con
      tcp        0      0 0.0.0.0:5938            0.0.0.0:*               LISTEN      0          26167      1393/teamviewerd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       34864      2784/io.sonoff.0
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        24960      634/systemd-resolve
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          23842      821/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15646      1/init
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          867752     88824/cupsd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31152      2092/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       36958      3007/io.web.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      131        27243      1363/grafana
      tcp6       0      0 :::5938                 :::*                    LISTEN      0          26165      1393/teamviewerd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          23844      821/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          15648      1/init
      udp        0      0 0.0.0.0:34510           0.0.0.0:*                           122        25687      694/avahi-daemon: r
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        24959      634/systemd-resolve
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15647      1/init
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          866892     88825/cups-browsed
      udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       1271758    79985/chrome --prof
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           122        25685      694/avahi-daemon: r
      udp6       0      0 :::60194                :::*                                122        25688      694/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          15649      1/init
      udp6       0      0 fe80::84b2:a3b4:b84:546 :::*                                0          27085      698/NetworkManager
      udp6       0      0 :::5353                 :::*                                122        25686      694/avahi-daemon: r
      2024-05-12 16:23:15.778  - error: influxdb.1 (2592) Error: connect ECONNREFUSED 192.168.178.120:8086
      2024-05-12 16:23:16.374  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.Wifi_RSSI/sonoff.0.DVES_56CBA1.Wifi_RSSI:{"val":100,"ack":true,"ts":1715523796372,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715454457345}
      2024-05-12 16:23:16.390  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.DS18B20_Temperature/sonoff.0.DVES_56CBA1.DS18B20_Temperature:{"val":22.38,"ack":true,"ts":1715523796389,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715523746314}
      2024-05-12 16:23:22.310  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2024-05-12 16:23:22.313  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2024-05-12 16:23:25.779  - info: influxdb.1 (2592) Connecting http://192.168.178.120:8086/ ...
      2024-05-12 16:23:25.780  - info: influxdb.1 (2592) Influx DB Version used: 1.x
      2024-05-12 16:23:25.780  - debug: influxdb.1 (2592) Connect InfluxDB1: http://192.168.178.120:8086 [iobroker]
      2024-05-12 16:23:25.784  - error: influxdb.1 (2592) Error: connect ECONNREFUSED 192.168.178.120:8086
      2024-05-12 16:23:26.352  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.Wifi_RSSI/sonoff.0.DVES_56CBA1.Wifi_RSSI:{"val":100,"ack":true,"ts":1715523806352,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715454457345}
      2024-05-12 16:23:26.358  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.DS18B20_Temperature/sonoff.0.DVES_56CBA1.DS18B20_Temperature:{"val":22.38,"ack":true,"ts":1715523806357,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715523746314}
      2024-05-12 16:23:28.039  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2024-05-12 16:23:28.041  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2024-05-12 16:23:29.732  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2024-05-12 16:23:29.735  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2024-05-12 16:23:32.654  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2024-05-12 16:23:32.656  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2024-05-12 16:23:34.381  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry:{"type":"folder","common":{"name":"Plugin States"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2024-05-12 16:23:34.382  - silly: influxdb.1 (2592) Objects user redis pmessage */cfg.o.system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled:{"type":"state","common":{"name":"Plugin - enabled","type":"boolean","read":true,"write":true,"role":"value"},"native":{},"_id":"system.host.ppmint-ESPRIMO-Q556-2.plugins.sentry.enabled","acl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2024-05-12 16:23:35.783  - info: influxdb.1 (2592) Connecting http://192.168.178.120:8086/ ...
      2024-05-12 16:23:35.784  - info: influxdb.1 (2592) Influx DB Version used: 1.x
      2024-05-12 16:23:35.784  - debug: influxdb.1 (2592) Connect InfluxDB1: http://192.168.178.120:8086 [iobroker]
      2024-05-12 16:23:35.786  - error: influxdb.1 (2592) Error: connect ECONNREFUSED 192.168.178.120:8086
      2024-05-12 16:23:36.334  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.Wifi_RSSI/sonoff.0.DVES_56CBA1.Wifi_RSSI:{"val":100,"ack":true,"ts":1715523816333,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715454457345}
      2024-05-12 16:23:36.339  - silly: influxdb.1 (2592) States user redis pmessage sonoff.0.DVES_56CBA1.DS18B20_Temperature/sonoff.0.DVES_56CBA1.DS18B20_Temperature:{"val":22.38,"ack":true,"ts":1715523816339,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1715523746314}
      Ist nicht komplett.
      • DJMarc75
        DJMarc75 @Meister Mopper last edited by DJMarc75
        @meister-mopper sagte in iobroker influxdb1.x econnrefused 192.168.178.120:8086:
        Ist nicht komplett
        Denke schon aber da läuft einiges krumm:
        Desktop: cinnamon
        Terminal: x11
        • system.adapter.influxdb.0 : influxdb : ppmint-ESPRIMO-Q556-2 - enabled, port: 8086
        • system.adapter.influxdb.1 : influxdb : ppmint-ESPRIMO-Q556-2 - enabled, port: 8086
        • system.adapter.javascript.0 : javascript : ppmint-ESPRIMO-Q556-2 - enabled
        • system.adapter.mqtt-client.0 : mqtt-client : ppmint-ESPRIMO-Q556-2 - enabled, port: 1883
        • system.adapter.mqtt.0 : mqtt : ppmint-ESPRIMO-Q556-2 - enabled, port: 1883, bind: 0.0.0.0
        • system.adapter.ping.0 : ping : ppmint-ESPRIMO-Q556-2 - enabled
        • system.adapter.sonoff.0 : sonoff : ppmint-ESPRIMO-Q556-2 - enabled, port: 1883, bind: 0.0.0.0
        edit:
        zusätzlich bitte das LOGLevel der Instanzen nicht auf SILLY stellen 🙂
          ronk last edited by ronk
          nun auch hier nach Adapterupdate javascript keine Verbindung mehr zu influxdb.
          Error: connect ECONNREFUSED 192.168.178.58:8086
          iob diag:
          Skript v.2024-05-22
          *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
           17:27:50 up 26 min,  2 users,  load average: 4.50, 3.25, 2.51
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
                         Local time: Sun 2024-05-26 17:27:50 CEST
                     Universal time: Sun 2024-05-26 15:27:50 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          ronny
          HOME=/home/ronny
          GROUPS=ronny adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            4.0G        1.6G        551M         56M        2.0G        2.4G
          Swap:           104M          0B        104M
          Total:          4.1G        1.6G        656M
          Active iob-Instances:   15
                   3794 M total memory
                   1516 M used memory
                   2045 M active memory
                    684 M inactive memory
                    526 M free memory
                    227 M buffer memory
                   1653 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          top - 17:27:51 up 26 min,  2 users,  load average: 4.50, 3.25, 2.51
          Tasks: 238 total,   1 running, 237 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3794.3 total,    525.2 free,   1517.6 used,   1881.1 buff/cache
          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2276.7 avail Mem
          * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
          * rc-local.service loaded failed failed /etc/rc.local Compatibility
          2 loaded units listed.
          *** FILESYSTEM ***
          /dev/root                                ext4       29G   23G  4.2G  85% /
          devtmpfs                                 devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs                                    tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs                                    tmpfs     759M  3.3M  756M   1% /run
          tmpfs                                    tmpfs     5.0M   16K  5.0M   1% /run/lock
          /dev/mmcblk0p1                           vfat      255M   31M  225M  13% /boot
          tmpfs                                    tmpfs     380M   36K  380M   1% /run/user/1000
          //192.168.178.1/fritz.nas/FRITZ_1/Backup cifs      118G  4.9G  113G   5% /opt/iobroker/backups
          [Sun May 26 17:01:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:16:F4:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e446591d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Sun May 26 17:01:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Sun May 26 17:01:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Sun May 26 17:01:37 2024] EXT4-fs (mmcblk0p2): recovery complete
          [Sun May 26 17:01:37 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun May 26 17:01:37 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Sun May 26 17:01:40 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #324609: comm du: No space for directory leaf checksum. Please run e2fsck -D.
          [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #324609: comm du: Directory block failed checksum
          [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325045: comm du: No space for directory leaf checksum. Please run e2fsck -D.
          [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325045: comm du: Directory block failed checksum
          [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325090: comm du: No space for directory leaf checksum. Please run e2fsck -D.
          [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325090: comm du: Directory block failed checksum
          [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325078: comm du: No space for directory leaf checksum. Please run e2fsck -D.
          [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325078: comm du: Directory block failed checksum
          [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325086: comm du: No space for directory leaf checksum. Please run e2fsck -D.
          [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325086: comm du: Directory block failed checksum
          [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325082: comm du: No space for directory leaf checksum. Please run e2fsck -D.
          [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325082: comm du: Directory block failed checksum
          [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325088: comm du: No space for directory leaf checksum. Please run e2fsck -D.
          [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325088: comm du: Directory block failed checksum
          [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325084: comm du: No space for directory leaf checksum. Please run e2fsck -D.
          [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325084: comm du: Directory block failed checksum
          [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325080: comm du: No space for directory leaf checksum. Please run e2fsck -D.
          [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325080: comm du: Directory block failed checksum
          [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #324539: comm du: No space for directory leaf checksum. Please run e2fsck -D.
          [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #324539: comm du: Directory block failed checksum
          /        /dev/mmcblk0p2                           ext4        rw,noatime
          |-/dev        devtmpfs                                 devtmpfs    rw,relatime,size=1678472k,nr_inodes=419618,mode=755
          |-/proc        proc                                     proc        rw,relatime
          |-/run        tmpfs                                    tmpfs       rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
          | |-/run/credentials/systemd-sysctl.service                                                        ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-sysusers.service                                                      ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-tmpfiles-setup-dev.service                                            ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/credentials/systemd-tmpfiles-setup.service                                                ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
          | |-/run/user/1000        tmpfs                                    tmpfs       rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
          | |-/run/docker/netns/baec15910bef        nsfs[net:[4026532852]]                   nsfs        rw
          | |-/run/docker/netns/9ccad93d5340        nsfs[net:[4026532933]]                   nsfs        rw
          | |-/run/docker/netns/5c56e1cacff4        nsfs[net:[4026532609]]                   nsfs        rw
          | |-/run/docker/netns/84f9adbecec1        nsfs[net:[4026532422]]                   nsfs        rw
          | `-/run/docker/netns/cdf8b87c3a2e        nsfs[net:[4026533013]]                   nsfs        rw
          |-/home/iobroker_backup/fritzNAS        systemd-1                                autofs      rw,relatime,fd=47,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
          |-/boot        /dev/mmcblk0p1                           vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          |-/var/lib/docker/overlay2/a5275e136d3b8c31c6b4a6a7f9454b4c49d6fa9ba99ad4303dae39c0448ae262/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/ZXOIITVSJWC2J45LRYORORNTX6:/var/lib/docker/overlay2/l/3LB5VQVUZLTIWLHCXYXYVTBYTP:/var/lib/docker/overlay2/l/WDJFTTDVG4RVBG7KEKKW23TPFC:/var/lib/docker/overlay2/l/IWAVT44WFCJBLPUYNWZRDBA2XF,upperdir=/var/lib/docker/overlay2/a5275e136d3b8c31c6b4a6a7f9454b4c49d6fa9ba99ad4303dae39c0448ae262/diff,workdir=/var/lib/docker/overlay2/a5275e136d3b8c31c6b4a6a7f9454b4c49d6fa9ba99ad4303dae39c0448ae262/work
          |-/var/lib/docker/overlay2/6294d7fe20fc30cf191fd349e80093aea9b7d723428fe061df028c53598e2051/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/Y4KIDLIINUL4F2DXESC4O5KRBJ:/var/lib/docker/overlay2/l/LXPEYR7VBFQ6BZETH37VPMGFLQ:/var/lib/docker/overlay2/l/RG5KXMBTXWGWYY4H3ISX2NQ2AT:/var/lib/docker/overlay2/l/7SZ7C77PC5ONRYST6QJB4BZYRA:/var/lib/docker/overlay2/l/OJZY7YGXRVAA7QCVIKVEOXJEX3:/var/lib/docker/overlay2/l/JNSS5BO3UKLABDPSVWBUP4DWQ7:/var/lib/docker/overlay2/l/NLDOZSC7FVQY6O25WPNZSDPDTW:/var/lib/docker/overlay2/l/DVOKLYVEJGXBDOGHGVWHIIRT2I:/var/lib/docker/overlay2/l/T54RJWMX2RGJNSLQHKWZ4IYHMN:/var/lib/docker/overlay2/l/KD3VFV5TWC6CQHAQX4GW2EQORH:/var/lib/docker/overlay2/l/63AK5PBC3MFBRJYMHDH6HUWU5P:/var/lib/docker/overlay2/l/SFPY6ZYRB4L6MTPU3TXMK5NCNR:/var/lib/docker/overlay2/l/CK7PHP4NVYM4RC5L5FPXQJOGCN:/var/lib/docker/overlay2/l/5EHULSCTZM6FKKP5MCMB2V63YH:/var/lib/docker/overlay2/l/RKNTNECVBYMERRMUZRRGIISS7C:/var/lib/docker/overlay2/l/5OG5USPEL6SAIDNEUNVQBPKJSM:/var/lib/docker/overlay2/l/3H2TFNRJ7VIFMSWBPRH5JS5MHJ:/var/lib/docker/overlay2/l/GO6JHZDVILQZG57AZ4EG3RAJVI:/var/lib/docker/overlay2/l/PC5SBE6QGP4IZVQQZZLYB54GXX,upperdir=/var/lib/docker/overlay2/6294d7fe20fc30cf191fd349e80093aea9b7d723428fe061df028c53598e2051/diff,workdir=/var/lib/docker/overlay2/6294d7fe20fc30cf191fd349e80093aea9b7d723428fe061df028c53598e2051/work
          |-/var/lib/docker/overlay2/c65b180a672d4ad649614237d47bba43809101080c5afe9afd38e7721b75f766/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/WBOYRJN6BCIHKCZJ6BPHZ37L3Y:/var/lib/docker/overlay2/l/7PMBGDN3W4JVMZFHEA4VVFEWOA:/var/lib/docker/overlay2/l/L4X52U3RRFPAUV6A2FH5HVKUJU:/var/lib/docker/overlay2/l/REZGUYYZ3US7PQUZWSAPSH326P:/var/lib/docker/overlay2/l/3WLQHIHKHYSMWBKJXM6LJYXP3T,upperdir=/var/lib/docker/overlay2/c65b180a672d4ad649614237d47bba43809101080c5afe9afd38e7721b75f766/diff,workdir=/var/lib/docker/overlay2/c65b180a672d4ad649614237d47bba43809101080c5afe9afd38e7721b75f766/work
          |-/var/lib/docker/overlay2/308ee548ba35785941d368549826341eaa5bd7062275ce3d1ca94137b70b91f6/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/B7R4UXH2SL2EH2RNJS5S2DU4KQ:/var/lib/docker/overlay2/l/AV3C4K3WX3M2KALWG55MT5CEGZ:/var/lib/docker/overlay2/l/5TZELNBRLQV34FU25JYNQPIU6I:/var/lib/docker/overlay2/l/3ZA2SRHIKDVMBT7HIARZ432R5G:/var/lib/docker/overlay2/l/TDGWKQ4LZHZN66QG672TOA5EVG:/var/lib/docker/overlay2/l/5FLAUAG6OTPPCO7LNPBV4YJRHO:/var/lib/docker/overlay2/l/M4XKCWRYMA3ULE6ASYZ5M7GI53,upperdir=/var/lib/docker/overlay2/308ee548ba35785941d368549826341eaa5bd7062275ce3d1ca94137b70b91f6/diff,workdir=/var/lib/docker/overlay2/308ee548ba35785941d368549826341eaa5bd7062275ce3d1ca94137b70b91f6/work
          |-/var/lib/docker/overlay2/d54e898deebaef7274983ac69024d2d9354c694df846f106332bc50cfad6750a/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/AEAXG5LKPHDFV3ECO2R7VI55WT:/var/lib/docker/overlay2/l/TOYFTJO536Y2CEFDKOGOPZWU6I:/var/lib/docker/overlay2/l/IRTVWCUYRMJT6673HFMWQV5SWX:/var/lib/docker/overlay2/l/HK4YRXKD6HZIFOKUXWK4I2LMLN:/var/lib/docker/overlay2/l/LEVA2AJAJNZIDJL5K4U4Y7AVHX:/var/lib/docker/overlay2/l/VJK7DLUJQVJH2KPMWPQ2ESYY7P:/var/lib/docker/overlay2/l/RKVLUAOKNZUX35Z6ENMAS7F2GI:/var/lib/docker/overlay2/l/LZT6TFXGCTFOXPCIYZCS3KCCI4:/var/lib/docker/overlay2/l/KGKN7LZBUMSQMYVY2L2IZNTOTV:/var/lib/docker/overlay2/l/SNUQZSIGTJ2HAYRJ4SSNSDIMUD:/var/lib/docker/overlay2/l/7EQICGQIM32XJQZRP76XAMWXJE:/var/lib/docker/overlay2/l/XP5HQXJAX2NKBCZNUZMK3YVFOM:/var/lib/docker/overlay2/l/R24LNBXO44TBEBMVZV6X7NSZZE:/var/lib/docker/overlay2/l/SW5OMAT4IVAQMBOWNHBVMPJPVP:/var/lib/docker/overlay2/l/LAZI6DH7DOFEEOWHEUB7YTXMAQ,upperdir=/var/lib/docker/overlay2/d54e898deebaef7274983ac69024d2d9354c694df846f106332bc50cfad6750a/diff,workdir=/var/lib/docker/overlay2/d54e898deebaef7274983ac69024d2d9354c694df846f106332bc50cfad6750a/work
          `-/opt/iobroker/backups        //192.168.178.1/fritz.nas/FRITZ_1/Backup cifs        rw,relatime,vers=3.1.1,cache=loose,username=iobroker_backup,uid=1002,noforceuid,gid=1002,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
          /var:
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/Test2': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Gc': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/IDS': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/GrBase': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Hyphen': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Hex': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/IDC': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Hst': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/GrExt': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/TAP/Harness': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/TAP/Parser/Scheduler': Bad message
          du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/TAP/Parser/Result': Bad message
          16G     /var/
          13G     /var/lib/docker
          13G     /var/lib
          11G     /var/lib/docker/overlay2
          1.8G    /var/log
          Archived and active journals take up 1.6G in the file system.
          1.3G    /opt/iobroker/backups/
          47M     /opt/iobroker/backups/influxDBtmp
          288M    /opt/iobroker/iobroker-data/
          231M    /opt/iobroker/iobroker-data/files
          138M    /opt/iobroker/iobroker-data/files/javascript.admin
          118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          13M     /opt/iobroker/iobroker-data/objects.jsonl
          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/61.54b23816.chunk.js.map
          USB-Devices by-id:
          /usr/bin/nodejs         v18.20.3
          /usr/bin/node           v18.20.3
          /usr/bin/npm            10.7.0
          /usr/bin/npx            10.7.0
          /usr/bin/corepack       0.28.0
          nodejs:
            Installed: 18.20.3-1nodesource1
            Candidate: 18.20.3-1nodesource1
            Version table:
           *** 18.20.3-1nodesource1 1001
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.13.16
          javascript:     8.3.1
          Adapter State
          + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.58
          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          + system.adapter.solax.0                  : solax                 : raspberrypi                              -  enabled
          + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
            system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
          Adapter    "go-e"         : 1.0.29   , installed 1.0.29
          Adapter    "javascript"   : 8.3.1    , installed 8.3.1
          Adapter    "solax"        : 0.9.6    , installed 0.9.6
          Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
          Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Objects and States
          Objects:        3373
          States:         3335
          Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:5 https://apt.grafana.com stable InRelease
          Hit:6 https://download.docker.com/linux/debian bookworm InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14112      703/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          1936       1043/smbd
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          1935       1043/smbd
          tcp        0      0 192.168.178.58:1883     0.0.0.0:*               LISTEN      1002       26464      5190/io.mqtt.0
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15934      651/cupsd
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14143      687/vncserver-x11-c
          tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      0          19734      1711/docker-proxy
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       18504      747/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       16695      747/iobroker.js-con
          tcp        0      0 0.0.0.0:3100            0.0.0.0:*               LISTEN      0          18936      1678/docker-proxy
          tcp6       0      0 :::3000                 :::*                    LISTEN      116        18497      746/grafana
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14114      703/sshd: /usr/sbin
          tcp6       0      0 :::139                  :::*                    LISTEN      0          1934       1043/smbd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15933      651/cupsd
          tcp6       0      0 :::445                  :::*                    LISTEN      0          1933       1043/smbd
          tcp6       0      0 :::5900                 :::*                    LISTEN      0          14142      687/vncserver-x11-c
          tcp6       0      0 :::8081                 :::*                    LISTEN      1002       27689      3966/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1002       29906      5833/io.web.0
          tcp6       0      0 :::4000                 :::*                    LISTEN      0          18136      1719/docker-proxy
          tcp6       0      0 :::3100                 :::*                    LISTEN      0          18116      1685/docker-proxy
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1650       435/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13248      512/dhcpcd
          udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          26075      737/nmbd
          udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          26074      737/nmbd
          udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          26071      737/nmbd
          udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          26070      737/nmbd
          udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26067      737/nmbd
          udp        0      0 169.254.248.216:137     0.0.0.0:*                           0          26066      737/nmbd
          udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26063      737/nmbd
          udp        0      0 169.254.225.2:137       0.0.0.0:*                           0          26062      737/nmbd
          udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26059      737/nmbd
          udp        0      0 169.254.210.46:137      0.0.0.0:*                           0          26058      737/nmbd
          udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26055      737/nmbd
          udp        0      0 169.254.141.55:137      0.0.0.0:*                           0          26054      737/nmbd
          udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26051      737/nmbd
          udp        0      0 169.254.113.152:137     0.0.0.0:*                           0          26050      737/nmbd
          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14306      737/nmbd
          udp        0      0 192.168.178.58:137      0.0.0.0:*                           0          14305      737/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          15970      737/nmbd
          udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          26077      737/nmbd
          udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          26076      737/nmbd
          udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          26073      737/nmbd
          udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          26072      737/nmbd
          udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26069      737/nmbd
          udp        0      0 169.254.248.216:138     0.0.0.0:*                           0          26068      737/nmbd
          udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26065      737/nmbd
          udp        0      0 169.254.225.2:138       0.0.0.0:*                           0          26064      737/nmbd
          udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26061      737/nmbd
          udp        0      0 169.254.210.46:138      0.0.0.0:*                           0          26060      737/nmbd
          udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26057      737/nmbd
          udp        0      0 169.254.141.55:138      0.0.0.0:*                           0          26056      737/nmbd
          udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26053      737/nmbd
          udp        0      0 169.254.113.152:138     0.0.0.0:*                           0          26052      737/nmbd
          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14308      737/nmbd
          udp        0      0 192.168.178.58:138      0.0.0.0:*                           0          14307      737/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          15971      737/nmbd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15945      735/cups-browsed
          udp        0      0 0.0.0.0:49917           0.0.0.0:*                           108        1652       435/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        1651       435/avahi-daemon: r
          udp6       0      0 :::47428                :::*                                108        1653       435/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          14259      512/dhcpcd
          2024-05-26 17:27:44.862  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
          2024-05-26 17:27:44.863  - info: influxdb.0 (14866) Influx DB Version used: 2.x
          2024-05-26 17:27:44.868  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
          2024-05-26 17:27:54.870  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
          2024-05-26 17:27:54.870  - info: influxdb.0 (14866) Influx DB Version used: 2.x
          2024-05-26 17:27:54.873  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
          2024-05-26 17:28:04.875  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
          2024-05-26 17:28:04.876  - info: influxdb.0 (14866) Influx DB Version used: 2.x
          2024-05-26 17:28:04.883  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
          2024-05-26 17:28:14.884  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
          2024-05-26 17:28:14.885  - info: influxdb.0 (14866) Influx DB Version used: 2.x
          2024-05-26 17:28:14.888  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
          2024-05-26 17:28:24.890  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
          2024-05-26 17:28:24.891  - info: influxdb.0 (14866) Influx DB Version used: 2.x
          2024-05-26 17:28:24.894  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
          2024-05-26 17:28:34.896  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
          2024-05-26 17:28:34.896  - info: influxdb.0 (14866) Influx DB Version used: 2.x
          2024-05-26 17:28:34.900  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
          2024-05-26 17:28:44.901  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
          2024-05-26 17:28:44.902  - info: influxdb.0 (14866) Influx DB Version used: 2.x
          2024-05-26 17:28:44.905  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
          2024-05-26 17:28:45.236  - info: solax.0 (4715) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
          2024-05-26 17:28:54.906  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
          2024-05-26 17:28:54.907  - info: influxdb.0 (14866) Influx DB Version used: 2.x
          2024-05-26 17:28:54.911  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
          Lief einwandfrei, nach javascript-Adapter-update keine Verbindung. Danke.
            Thomas Braun Most Active @ronk last edited by
            @ronk
            Dein Raspberry OS 'Bookworm' ist nicht richtig installiert. War ein 'inline upgrade' von einer Vorversion aus, vermute ich...
              ronk @Thomas Braun last edited by ronk
              ja, stimmt. hat aber bis jetzt funktioniert... Ich komme auch nicht mehr auf die Webseite der influxdb-Installation merke ich gerade.
                @ronk sagte in iobroker influxdb1.x econnrefused 192.168.178.120:8086:
                Aber nicht richtig...
                Die Kiste dreht im roten Bereich und der influxdb.service startet nicht.
                systemctl status influxdb.service
                  Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarc        h64
                  The programs included with the Debian GNU/Linux system are free software;
                  the exact distribution terms for each program are described in the
                  individual files in /usr/share/doc/*/copyright.
                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                  permitted by applicable law.
                  Last login: Sun May 26 17:42:47 2024 from 192.168.178.20
                  ronny@raspberrypi:~ $ systemctl status influxdb.service
                  × influxdb.service - InfluxDB is an open-source, distributed, time series database
                       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; preset: enabled)
                       Active: failed (Result: exit-code) since Sun 2024-05-26 17:34:08 CEST; 9min ago
                         Docs: https://docs.influxdata.com/influxdb/
                      Process: 792 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=2)
                          CPU: 208ms
                  Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/mgc.go:1407 +0x398 fp=0x4000072fd0 sp=0x4000072f40 pc=0x7f89bfaa58
                  Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]: runtime.goexit()
                  Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/asm_arm64.s:1172 +0x4 fp=0x4000072fd0 sp=0x4000072fd0 pc=0x7f89c4af04
                  Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]: created by runtime.gcBgMarkStartWorkers
                  Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/mgc.go:1199 +0x28
                  Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                  Mai 26 17:34:08 raspberrypi systemd[1]: Stopped influxdb.service - InfluxDB is an open-source, distributed, time series database.
                  Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                  Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                  Mai 26 17:34:08 raspberrypi systemd[1]: Failed to start influxdb.service - InfluxDB is an open-source, distributed, time series database.
                    @ronk
                    Dein Dateisystem läuft voll und der Kernel hat ein fscheck durchführen müssen.
                    Dann spukt da noch irgendwas von einem Docker herum.
                      ja, da läuft eine Dockerinstallation mit TeslaSolarCharger.
                        @ronk
                        Bei dem Thema bin ich dann auch raus.
                        Schau das du deine Basis sauber hinbekommst. Wirst du aber nur per Neuinstallation das OS richtig hinbekommen, sage ich voraus.
                          nuja, das lief alles einträchtig nebeneinander. Also von grundauf neuinstallieren?
                            Thomas Braun Most Active @ronk last edited by Thomas Braun
                            @ronk
                            Nuja, nicht wirklich. Wie du siehst.
                            Die Empfehlung Raspberry OS 'Bookworm' komplett neuzuinstallieren gab es nicht ohne Grund.
                              okay. danke dir.
                              Läuft wieder.
                                @ronk
                                Das ging aber schnell... Eine ordentliche Neuinstallation kann das nicht gewesen sein und da ist immer noch das Flickwerk am Start.
                                  nein, war natürlich keine Neuinstallation. Im Zuge eines geplanten Umbaus auf SSD (noch läuft die SD-Karte unauffällig, toitoitoi) setze ich alles voraussichtlich im Herbst neu auf.
                                  Habe aber iob diag nochmal laufen lassen, keinerlei Warnungen oder Fehler mehr erkennbar. Den TeslaSolarCharger brauche ich wirklich sehr oft, iobroker ist Beifang, nur um die Sache etwas hübscher aussehen zu lassen.
                                  Eine Frage habe ich noch: was genau ist an (m)einem InRelease-upgrade Flickwerk (gerne am Beispiel meiner geposteten Quotes)? Auch ich bin ein Freund sauberer Neuinstallationen. Aber wenn alles problemlos läuft? Warum nicht?
                                  Vielen Dank
                                    Homoran Global Moderator Administrators @ronk last edited by
                                    tut es ja nicht! Nur scheinbar.
                                    Ab und zu blitzt ein Problem auf.
                                    Das sind Zeitbomben.
                                    irgendwann klappt es möglicherweise nicht, wenn du
                                      Falscher Kernel über die falsche Firmware falsch eingehängt.
                                      Hier versucht es auch jemand:
                                      https://gnulinux.ch/pios-auf-bookworm-upgrade-ohne-neuinstallation-und-gewehr
                                      Der schreibt aber auch:
                                      Bitte beachten, dass dieser Vorgang nicht offiziell empfohlen wird und möglicherweise nicht für alle Anwendungen geeignet ist, besonders das Upgrade einer Installation mit grafischer Oberfläche wurde nicht getestet und wird höchstwahrscheinlich nicht ohne weiteres möglich sein. Auch ein Upgrade der 32-Bit Version von PiOS wurde nicht getestet.
                                      Hier noch:
                                      the changes in release from bullseye to bookworm is a lot, the desktop was swapped from a modified lxde to a wayland/wayfire setup, so no longer lxde, the network was changed from dhcpd to network manager, many other stuff was changed behind the UI.
                                      use a spare to do a fresh install of raspberry bookworm os using imager you can then grab anything important to you from your old install.
                                      https://forums.raspberrypi.com/viewtopic.php?t=363376
                                        Aha, so ist das also. Vielen Dank.
                                        Dann sollte ich das doch schnellstmöglich in Ordnung bringen.
                                        Die Sicherungen, die ich mir von Backitup für influxdb und Grafana mit anlegen lasse kann man für die Wiederherstellung nach Neuinstallation nutzen? Also alle Datenpunkte und die Datenbank lassen sich darüber wieder einspielen?
                                          crunchip Forum Testing Most Active @ronk last edited by
                                          Ja
                                          econnectrefused influxdb iobroker instanzen
                                          1746
