    3. Einsteigerfragen
    4. Installation
    5. iobroker influxdb1.x econnrefused 192.168.178.120:8086
      ronk last edited by ronk
      nun auch hier nach Adapterupdate javascript keine Verbindung mehr zu influxdb.
      Error: connect ECONNREFUSED 192.168.178.58:8086
      iob diag:
      Skript v.2024-05-22
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       17:27:50 up 26 min,  2 users,  load average: 4.50, 3.25, 2.51
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-05-26 17:27:50 CEST
                 Universal time: Sun 2024-05-26 15:27:50 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      ronny
      HOME=/home/ronny
      GROUPS=ronny adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
      *** Display-Server-Setup ***
      Display-Server: true
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        1.6G        551M         56M        2.0G        2.4G
      Swap:           104M          0B        104M
      Total:          4.1G        1.6G        656M
      Active iob-Instances:   15
               3794 M total memory
               1516 M used memory
               2045 M active memory
                684 M inactive memory
                526 M free memory
                227 M buffer memory
               1653 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      top - 17:27:51 up 26 min,  2 users,  load average: 4.50, 3.25, 2.51
      Tasks: 238 total,   1 running, 237 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3794.3 total,    525.2 free,   1517.6 used,   1881.1 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2276.7 avail Mem
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * influxdb.service loaded failed failed InfluxDB is an open-source, distributed, time series database
      * rc-local.service loaded failed failed /etc/rc.local Compatibility
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      Filesystem                               Type      Size  Used Avail Use% Mounted on
      /dev/root                                ext4       29G   23G  4.2G  85% /
      devtmpfs                                 devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs                                    tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs                                    tmpfs     759M  3.3M  756M   1% /run
      tmpfs                                    tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/mmcblk0p1                           vfat      255M   31M  225M  13% /boot
      tmpfs                                    tmpfs     380M   36K  380M   1% /run/user/1000
      //192.168.178.1/fritz.nas/FRITZ_1/Backup cifs      118G  4.9G  113G   5% /opt/iobroker/backups
      [Sun May 26 17:01:35 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:16:F4:39 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e446591d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sun May 26 17:01:36 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Sun May 26 17:01:36 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Sun May 26 17:01:37 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Sun May 26 17:01:37 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun May 26 17:01:37 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun May 26 17:01:40 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #324609: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #324609: comm du: Directory block failed checksum
      [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325045: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325045: comm du: Directory block failed checksum
      [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325090: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325090: comm du: Directory block failed checksum
      [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325078: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325078: comm du: Directory block failed checksum
      [Sun May 26 17:24:58 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325086: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sun May 26 17:24:58 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325086: comm du: Directory block failed checksum
      [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325082: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325082: comm du: Directory block failed checksum
      [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325088: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325088: comm du: Directory block failed checksum
      [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325084: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325084: comm du: Directory block failed checksum
      [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #325080: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #325080: comm du: Directory block failed checksum
      [Sun May 26 17:24:59 2024] EXT4-fs warning (device mmcblk0p2): ext4_dirblock_csum_verify:404: inode #324539: comm du: No space for directory leaf checksum. Please run e2fsck -D.
      [Sun May 26 17:24:59 2024] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1072: inode #324539: comm du: Directory block failed checksum
      Show mounted filesystems:
      TARGET        SOURCE                                   FSTYPE      OPTIONS
      /        /dev/mmcblk0p2                           ext4        rw,noatime
      |-/dev        devtmpfs                                 devtmpfs    rw,relatime,size=1678472k,nr_inodes=419618,mode=755
      | |-/dev/shm        tmpfs                                    tmpfs       rw,nosuid,nodev
      | |-/dev/pts        devpts                                   devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
      | `-/dev/mqueue        mqueue                                   mqueue      rw,nosuid,nodev,noexec,relatime
      |-/proc        proc                                     proc        rw,relatime
      | `-/proc/sys/fs/binfmt_misc        systemd-1                                autofs      rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |   `-/proc/sys/fs/binfmt_misc        binfmt_misc                              binfmt_misc rw,nosuid,nodev,noexec,relatime
      |-/sys        sysfs                                    sysfs       rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/security        securityfs                               securityfs  rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/cgroup        cgroup2                                  cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
      | |-/sys/fs/pstore        pstore                                   pstore      rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/bpf        bpf                                      bpf         rw,nosuid,nodev,noexec,relatime,mode=700
      | |-/sys/kernel/debug        debugfs                                  debugfs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/kernel/tracing        tracefs                                  tracefs     rw,nosuid,nodev,noexec,relatime
      | |-/sys/fs/fuse/connections        fusectl                                  fusectl     rw,nosuid,nodev,noexec,relatime
      | `-/sys/kernel/config        configfs                                 configfs    rw,nosuid,nodev,noexec,relatime
      |-/run        tmpfs                                    tmpfs       rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
      | |-/run/lock        tmpfs                                    tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
      | |-/run/credentials/systemd-sysctl.service                                                        ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-sysusers.service                                                      ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup-dev.service                                            ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/credentials/systemd-tmpfiles-setup.service                                                ramfs                                    ramfs       ro,nosuid,nodev,noexec,relatime,mode=700
      | |-/run/rpc_pipefs        sunrpc                                   rpc_pipefs  rw,relatime
      | |-/run/user/1000        tmpfs                                    tmpfs       rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
      | |-/run/docker/netns/baec15910bef        nsfs[net:[4026532852]]                   nsfs        rw
      | |-/run/docker/netns/9ccad93d5340        nsfs[net:[4026532933]]                   nsfs        rw
      | |-/run/docker/netns/5c56e1cacff4        nsfs[net:[4026532609]]                   nsfs        rw
      | |-/run/docker/netns/84f9adbecec1        nsfs[net:[4026532422]]                   nsfs        rw
      | `-/run/docker/netns/cdf8b87c3a2e        nsfs[net:[4026533013]]                   nsfs        rw
      |-/home/iobroker_backup/fritzNAS        systemd-1                                autofs      rw,relatime,fd=47,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
      |-/boot        /dev/mmcblk0p1                           vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      |-/var/lib/docker/overlay2/a5275e136d3b8c31c6b4a6a7f9454b4c49d6fa9ba99ad4303dae39c0448ae262/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/ZXOIITVSJWC2J45LRYORORNTX6:/var/lib/docker/overlay2/l/3LB5VQVUZLTIWLHCXYXYVTBYTP:/var/lib/docker/overlay2/l/WDJFTTDVG4RVBG7KEKKW23TPFC:/var/lib/docker/overlay2/l/IWAVT44WFCJBLPUYNWZRDBA2XF,upperdir=/var/lib/docker/overlay2/a5275e136d3b8c31c6b4a6a7f9454b4c49d6fa9ba99ad4303dae39c0448ae262/diff,workdir=/var/lib/docker/overlay2/a5275e136d3b8c31c6b4a6a7f9454b4c49d6fa9ba99ad4303dae39c0448ae262/work
      |-/var/lib/docker/overlay2/6294d7fe20fc30cf191fd349e80093aea9b7d723428fe061df028c53598e2051/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/Y4KIDLIINUL4F2DXESC4O5KRBJ:/var/lib/docker/overlay2/l/LXPEYR7VBFQ6BZETH37VPMGFLQ:/var/lib/docker/overlay2/l/RG5KXMBTXWGWYY4H3ISX2NQ2AT:/var/lib/docker/overlay2/l/7SZ7C77PC5ONRYST6QJB4BZYRA:/var/lib/docker/overlay2/l/OJZY7YGXRVAA7QCVIKVEOXJEX3:/var/lib/docker/overlay2/l/JNSS5BO3UKLABDPSVWBUP4DWQ7:/var/lib/docker/overlay2/l/NLDOZSC7FVQY6O25WPNZSDPDTW:/var/lib/docker/overlay2/l/DVOKLYVEJGXBDOGHGVWHIIRT2I:/var/lib/docker/overlay2/l/T54RJWMX2RGJNSLQHKWZ4IYHMN:/var/lib/docker/overlay2/l/KD3VFV5TWC6CQHAQX4GW2EQORH:/var/lib/docker/overlay2/l/63AK5PBC3MFBRJYMHDH6HUWU5P:/var/lib/docker/overlay2/l/SFPY6ZYRB4L6MTPU3TXMK5NCNR:/var/lib/docker/overlay2/l/CK7PHP4NVYM4RC5L5FPXQJOGCN:/var/lib/docker/overlay2/l/5EHULSCTZM6FKKP5MCMB2V63YH:/var/lib/docker/overlay2/l/RKNTNECVBYMERRMUZRRGIISS7C:/var/lib/docker/overlay2/l/5OG5USPEL6SAIDNEUNVQBPKJSM:/var/lib/docker/overlay2/l/3H2TFNRJ7VIFMSWBPRH5JS5MHJ:/var/lib/docker/overlay2/l/GO6JHZDVILQZG57AZ4EG3RAJVI:/var/lib/docker/overlay2/l/PC5SBE6QGP4IZVQQZZLYB54GXX,upperdir=/var/lib/docker/overlay2/6294d7fe20fc30cf191fd349e80093aea9b7d723428fe061df028c53598e2051/diff,workdir=/var/lib/docker/overlay2/6294d7fe20fc30cf191fd349e80093aea9b7d723428fe061df028c53598e2051/work
      |-/var/lib/docker/overlay2/c65b180a672d4ad649614237d47bba43809101080c5afe9afd38e7721b75f766/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/WBOYRJN6BCIHKCZJ6BPHZ37L3Y:/var/lib/docker/overlay2/l/7PMBGDN3W4JVMZFHEA4VVFEWOA:/var/lib/docker/overlay2/l/L4X52U3RRFPAUV6A2FH5HVKUJU:/var/lib/docker/overlay2/l/REZGUYYZ3US7PQUZWSAPSH326P:/var/lib/docker/overlay2/l/3WLQHIHKHYSMWBKJXM6LJYXP3T,upperdir=/var/lib/docker/overlay2/c65b180a672d4ad649614237d47bba43809101080c5afe9afd38e7721b75f766/diff,workdir=/var/lib/docker/overlay2/c65b180a672d4ad649614237d47bba43809101080c5afe9afd38e7721b75f766/work
      |-/var/lib/docker/overlay2/308ee548ba35785941d368549826341eaa5bd7062275ce3d1ca94137b70b91f6/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/B7R4UXH2SL2EH2RNJS5S2DU4KQ:/var/lib/docker/overlay2/l/AV3C4K3WX3M2KALWG55MT5CEGZ:/var/lib/docker/overlay2/l/5TZELNBRLQV34FU25JYNQPIU6I:/var/lib/docker/overlay2/l/3ZA2SRHIKDVMBT7HIARZ432R5G:/var/lib/docker/overlay2/l/TDGWKQ4LZHZN66QG672TOA5EVG:/var/lib/docker/overlay2/l/5FLAUAG6OTPPCO7LNPBV4YJRHO:/var/lib/docker/overlay2/l/M4XKCWRYMA3ULE6ASYZ5M7GI53,upperdir=/var/lib/docker/overlay2/308ee548ba35785941d368549826341eaa5bd7062275ce3d1ca94137b70b91f6/diff,workdir=/var/lib/docker/overlay2/308ee548ba35785941d368549826341eaa5bd7062275ce3d1ca94137b70b91f6/work
      |-/var/lib/docker/overlay2/d54e898deebaef7274983ac69024d2d9354c694df846f106332bc50cfad6750a/merged overlay                                  overlay     rw,relatime,lowerdir=/var/lib/docker/overlay2/l/AEAXG5LKPHDFV3ECO2R7VI55WT:/var/lib/docker/overlay2/l/TOYFTJO536Y2CEFDKOGOPZWU6I:/var/lib/docker/overlay2/l/IRTVWCUYRMJT6673HFMWQV5SWX:/var/lib/docker/overlay2/l/HK4YRXKD6HZIFOKUXWK4I2LMLN:/var/lib/docker/overlay2/l/LEVA2AJAJNZIDJL5K4U4Y7AVHX:/var/lib/docker/overlay2/l/VJK7DLUJQVJH2KPMWPQ2ESYY7P:/var/lib/docker/overlay2/l/RKVLUAOKNZUX35Z6ENMAS7F2GI:/var/lib/docker/overlay2/l/LZT6TFXGCTFOXPCIYZCS3KCCI4:/var/lib/docker/overlay2/l/KGKN7LZBUMSQMYVY2L2IZNTOTV:/var/lib/docker/overlay2/l/SNUQZSIGTJ2HAYRJ4SSNSDIMUD:/var/lib/docker/overlay2/l/7EQICGQIM32XJQZRP76XAMWXJE:/var/lib/docker/overlay2/l/XP5HQXJAX2NKBCZNUZMK3YVFOM:/var/lib/docker/overlay2/l/R24LNBXO44TBEBMVZV6X7NSZZE:/var/lib/docker/overlay2/l/SW5OMAT4IVAQMBOWNHBVMPJPVP:/var/lib/docker/overlay2/l/LAZI6DH7DOFEEOWHEUB7YTXMAQ,upperdir=/var/lib/docker/overlay2/d54e898deebaef7274983ac69024d2d9354c694df846f106332bc50cfad6750a/diff,workdir=/var/lib/docker/overlay2/d54e898deebaef7274983ac69024d2d9354c694df846f106332bc50cfad6750a/work
      `-/opt/iobroker/backups        //192.168.178.1/fritz.nas/FRITZ_1/Backup cifs        rw,relatime,vers=3.1.1,cache=loose,username=iobroker_backup,uid=1002,noforceuid,gid=1002,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
      /var:
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/Test2': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Gc': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/IDS': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/GrBase': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Hyphen': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Hex': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/IDC': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/Hst': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/unicore/lib/GrExt': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/TAP/Harness': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/TAP/Parser/Scheduler': Bad message
      du: cannot read directory '/var/lib/docker/overlay2/8bd87b394eac97a69f2b7eaf35e0b29fe8ce790ab6d3f2f09ded78c1314fb43f/diff/usr/share/perl/5.36.0/TAP/Parser/Result': Bad message
      16G     /var/
      13G     /var/lib/docker
      13G     /var/lib
      11G     /var/lib/docker/overlay2
      1.8G    /var/log
      Archived and active journals take up 1.6G in the file system.
      /opt/iobroker/backups:
      1.3G    /opt/iobroker/backups/
      47M     /opt/iobroker/backups/influxDBtmp
      /opt/iobroker/iobroker-data:
      288M    /opt/iobroker/iobroker-data/
      231M    /opt/iobroker/iobroker-data/files
      138M    /opt/iobroker/iobroker-data/files/javascript.admin
      118M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      117M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/61.54b23816.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.3
      /usr/bin/node           v18.20.3
      /usr/bin/npm            10.7.0
      /usr/bin/npx            10.7.0
      /usr/bin/corepack       0.28.0
      nodejs:
        Installed: 18.20.3-1nodesource1
        Candidate: 18.20.3-1nodesource1
        Version table:
       *** 18.20.3-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.20.2-1nodesource1 1001
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.19
      admin:          6.13.16
      javascript:     8.3.1
      nodejs modules from github:     0
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.go-e.0                   : go-e                  : raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
      + system.adapter.mqtt-client.0            : mqtt-client           : raspberrypi                              -  enabled, port: 1883
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 192.168.178.58
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.solax.0                  : solax                 : raspberrypi                              -  enabled
      + system.adapter.tesla-motors.0           : tesla-motors          : raspberrypi                              -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              - disabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "accuweather"  : 1.4.0    , installed 1.4.0
      Adapter    "backitup"     : 2.11.0   , installed 2.11.0
      Adapter    "discovery"    : 4.4.0    , installed 4.4.0
      Adapter    "go-e"         : 1.0.29   , installed 1.0.29
      Adapter    "javascript"   : 8.3.1    , installed 8.3.1
      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
      Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
      Adapter    "socketio"     : 6.7.0    , installed 6.7.0
      Adapter    "solax"        : 0.9.6    , installed 0.9.6
      Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
      Adapter    "ws"           : 2.6.1    , installed 2.6.1
      Objects and States
      Objects:        3373
      States:         3335
      Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 https://download.docker.com/linux/debian bookworm InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14112      703/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          1936       1043/smbd
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          1935       1043/smbd
      tcp        0      0 192.168.178.58:1883     0.0.0.0:*               LISTEN      1002       26464      5190/io.mqtt.0
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15934      651/cupsd
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          14143      687/vncserver-x11-c
      tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      0          19734      1711/docker-proxy
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1002       18504      747/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1002       16695      747/iobroker.js-con
      tcp        0      0 0.0.0.0:3100            0.0.0.0:*               LISTEN      0          18936      1678/docker-proxy
      tcp6       0      0 :::3000                 :::*                    LISTEN      116        18497      746/grafana
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14114      703/sshd: /usr/sbin
      tcp6       0      0 :::139                  :::*                    LISTEN      0          1934       1043/smbd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15933      651/cupsd
      tcp6       0      0 :::445                  :::*                    LISTEN      0          1933       1043/smbd
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          14142      687/vncserver-x11-c
      tcp6       0      0 :::8081                 :::*                    LISTEN      1002       27689      3966/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1002       29906      5833/io.web.0
      tcp6       0      0 :::4000                 :::*                    LISTEN      0          18136      1719/docker-proxy
      tcp6       0      0 :::3100                 :::*                    LISTEN      0          18116      1685/docker-proxy
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1650       435/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13248      512/dhcpcd
      udp        0      0 172.19.255.255:137      0.0.0.0:*                           0          26075      737/nmbd
      udp        0      0 172.19.0.1:137          0.0.0.0:*                           0          26074      737/nmbd
      udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          26071      737/nmbd
      udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          26070      737/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26067      737/nmbd
      udp        0      0 169.254.248.216:137     0.0.0.0:*                           0          26066      737/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26063      737/nmbd
      udp        0      0 169.254.225.2:137       0.0.0.0:*                           0          26062      737/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26059      737/nmbd
      udp        0      0 169.254.210.46:137      0.0.0.0:*                           0          26058      737/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26055      737/nmbd
      udp        0      0 169.254.141.55:137      0.0.0.0:*                           0          26054      737/nmbd
      udp        0      0 169.254.255.255:137     0.0.0.0:*                           0          26051      737/nmbd
      udp        0      0 169.254.113.152:137     0.0.0.0:*                           0          26050      737/nmbd
      udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          14306      737/nmbd
      udp        0      0 192.168.178.58:137      0.0.0.0:*                           0          14305      737/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          15970      737/nmbd
      udp        0      0 172.19.255.255:138      0.0.0.0:*                           0          26077      737/nmbd
      udp        0      0 172.19.0.1:138          0.0.0.0:*                           0          26076      737/nmbd
      udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          26073      737/nmbd
      udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          26072      737/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26069      737/nmbd
      udp        0      0 169.254.248.216:138     0.0.0.0:*                           0          26068      737/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26065      737/nmbd
      udp        0      0 169.254.225.2:138       0.0.0.0:*                           0          26064      737/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26061      737/nmbd
      udp        0      0 169.254.210.46:138      0.0.0.0:*                           0          26060      737/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26057      737/nmbd
      udp        0      0 169.254.141.55:138      0.0.0.0:*                           0          26056      737/nmbd
      udp        0      0 169.254.255.255:138     0.0.0.0:*                           0          26053      737/nmbd
      udp        0      0 169.254.113.152:138     0.0.0.0:*                           0          26052      737/nmbd
      udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          14308      737/nmbd
      udp        0      0 192.168.178.58:138      0.0.0.0:*                           0          14307      737/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          15971      737/nmbd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15945      735/cups-browsed
      udp        0      0 0.0.0.0:49917           0.0.0.0:*                           108        1652       435/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        1651       435/avahi-daemon: r
      udp6       0      0 :::47428                :::*                                108        1653       435/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14259      512/dhcpcd
      2024-05-26 17:27:44.862  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
      2024-05-26 17:27:44.863  - info: influxdb.0 (14866) Influx DB Version used: 2.x
      2024-05-26 17:27:44.868  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
      2024-05-26 17:27:54.870  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
      2024-05-26 17:27:54.870  - info: influxdb.0 (14866) Influx DB Version used: 2.x
      2024-05-26 17:27:54.873  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
      2024-05-26 17:28:04.875  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
      2024-05-26 17:28:04.876  - info: influxdb.0 (14866) Influx DB Version used: 2.x
      2024-05-26 17:28:04.883  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
      2024-05-26 17:28:14.884  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
      2024-05-26 17:28:14.885  - info: influxdb.0 (14866) Influx DB Version used: 2.x
      2024-05-26 17:28:14.888  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
      2024-05-26 17:28:24.890  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
      2024-05-26 17:28:24.891  - info: influxdb.0 (14866) Influx DB Version used: 2.x
      2024-05-26 17:28:24.894  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
      2024-05-26 17:28:34.896  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
      2024-05-26 17:28:34.896  - info: influxdb.0 (14866) Influx DB Version used: 2.x
      2024-05-26 17:28:34.900  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
      2024-05-26 17:28:44.901  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
      2024-05-26 17:28:44.902  - info: influxdb.0 (14866) Influx DB Version used: 2.x
      2024-05-26 17:28:44.905  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
      2024-05-26 17:28:45.236  - info: solax.0 (4715) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2024-05-26 17:28:54.906  - info: influxdb.0 (14866) Connecting http://192.168.178.58:8086/ ...
      2024-05-26 17:28:54.907  - info: influxdb.0 (14866) Influx DB Version used: 2.x
      2024-05-26 17:28:54.911  - error: influxdb.0 (14866) Error: connect ECONNREFUSED 192.168.178.58:8086
      Lief einwandfrei, nach javascript-Adapter-update keine Verbindung. Danke.
        Thomas Braun Most Active @ronk last edited by
        @ronk
        Dein Raspberry OS 'Bookworm' ist nicht richtig installiert. War ein 'inline upgrade' von einer Vorversion aus, vermute ich...
          ronk @Thomas Braun last edited by ronk
          ja, stimmt. hat aber bis jetzt funktioniert... Ich komme auch nicht mehr auf die Webseite der influxdb-Installation merke ich gerade.
            @ronk sagte in iobroker influxdb1.x econnrefused 192.168.178.120:8086:
            Aber nicht richtig...
            Die Kiste dreht im roten Bereich und der influxdb.service startet nicht.
            systemctl status influxdb.service
              Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarc        h64
              The programs included with the Debian GNU/Linux system are free software;
              the exact distribution terms for each program are described in the
              individual files in /usr/share/doc/*/copyright.
              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
              permitted by applicable law.
              Last login: Sun May 26 17:42:47 2024 from 192.168.178.20
              ronny@raspberrypi:~ $ systemctl status influxdb.service
              × influxdb.service - InfluxDB is an open-source, distributed, time series database
                   Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; preset: enabled)
                   Active: failed (Result: exit-code) since Sun 2024-05-26 17:34:08 CEST; 9min ago
                     Docs: https://docs.influxdata.com/influxdb/
                  Process: 792 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=2)
                      CPU: 208ms
              Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/mgc.go:1407 +0x398 fp=0x4000072fd0 sp=0x4000072f40 pc=0x7f89bfaa58
              Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]: runtime.goexit()
              Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/asm_arm64.s:1172 +0x4 fp=0x4000072fd0 sp=0x4000072fd0 pc=0x7f89c4af04
              Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]: created by runtime.gcBgMarkStartWorkers
              Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/mgc.go:1199 +0x28
              Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
              Mai 26 17:34:08 raspberrypi systemd[1]: Stopped influxdb.service - InfluxDB is an open-source, distributed, time series database.
              Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
              Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
              Mai 26 17:34:08 raspberrypi systemd[1]: Failed to start influxdb.service - InfluxDB is an open-source, distributed, time series database.
                @ronk
                Dein Dateisystem läuft voll und der Kernel hat ein fscheck durchführen müssen.
                Dann spukt da noch irgendwas von einem Docker herum.
                  ja, da läuft eine Dockerinstallation mit TeslaSolarCharger.
                    @ronk
                    Bei dem Thema bin ich dann auch raus.
                    Schau das du deine Basis sauber hinbekommst. Wirst du aber nur per Neuinstallation das OS richtig hinbekommen, sage ich voraus.
                      nuja, das lief alles einträchtig nebeneinander. Also von grundauf neuinstallieren?
                        Thomas Braun Most Active @ronk last edited by Thomas Braun
                        @ronk
                        Nuja, nicht wirklich. Wie du siehst.
                        Die Empfehlung Raspberry OS 'Bookworm' komplett neuzuinstallieren gab es nicht ohne Grund.
                          okay. danke dir.
                          Läuft wieder.
                            @ronk
                            Das ging aber schnell... Eine ordentliche Neuinstallation kann das nicht gewesen sein und da ist immer noch das Flickwerk am Start.
                              nein, war natürlich keine Neuinstallation. Im Zuge eines geplanten Umbaus auf SSD (noch läuft die SD-Karte unauffällig, toitoitoi) setze ich alles voraussichtlich im Herbst neu auf.
                              Habe aber iob diag nochmal laufen lassen, keinerlei Warnungen oder Fehler mehr erkennbar. Den TeslaSolarCharger brauche ich wirklich sehr oft, iobroker ist Beifang, nur um die Sache etwas hübscher aussehen zu lassen.
                              Eine Frage habe ich noch: was genau ist an (m)einem InRelease-upgrade Flickwerk (gerne am Beispiel meiner geposteten Quotes)? Auch ich bin ein Freund sauberer Neuinstallationen. Aber wenn alles problemlos läuft? Warum nicht?
                              Vielen Dank
                                Homoran Global Moderator Administrators @ronk last edited by
                                tut es ja nicht! Nur scheinbar.
                                Ab und zu blitzt ein Problem auf.
                                Das sind Zeitbomben.
                                irgendwann klappt es möglicherweise nicht, wenn du
                                  Falscher Kernel über die falsche Firmware falsch eingehängt.
                                  Hier versucht es auch jemand:
                                  https://gnulinux.ch/pios-auf-bookworm-upgrade-ohne-neuinstallation-und-gewehr
                                  Der schreibt aber auch:
                                  Bitte beachten, dass dieser Vorgang nicht offiziell empfohlen wird und möglicherweise nicht für alle Anwendungen geeignet ist, besonders das Upgrade einer Installation mit grafischer Oberfläche wurde nicht getestet und wird höchstwahrscheinlich nicht ohne weiteres möglich sein. Auch ein Upgrade der 32-Bit Version von PiOS wurde nicht getestet.
                                  Hier noch:
                                  the changes in release from bullseye to bookworm is a lot, the desktop was swapped from a modified lxde to a wayland/wayfire setup, so no longer lxde, the network was changed from dhcpd to network manager, many other stuff was changed behind the UI.
                                  use a spare to do a fresh install of raspberry bookworm os using imager you can then grab anything important to you from your old install.
                                  https://forums.raspberrypi.com/viewtopic.php?t=363376
                                    Aha, so ist das also. Vielen Dank.
                                    Dann sollte ich das doch schnellstmöglich in Ordnung bringen.
                                    Die Sicherungen, die ich mir von Backitup für influxdb und Grafana mit anlegen lasse kann man für die Wiederherstellung nach Neuinstallation nutzen? Also alle Datenpunkte und die Datenbank lassen sich darüber wieder einspielen?
                                      crunchip Forum Testing Most Active @ronk last edited by
                                      Ja
                                      econnectrefused influxdb iobroker instanzen
                                      1746
