[gelöst]kein Zugriff per Web (Port8081)
was sagt denn der Befehl:
ps -A |grep " io.*"
wenn du per ssh auf deiner Installation bist
Hallo
es wird dann flgendes angezeigt
pi@ioBroker-Pi3:~ $ ps -A |grep " io.*"
597 ? 00:18:13 iobroker.js-con
694 ? 00:01:50 io.hm-rpc.0
736 ? 00:00:57 io.hm-rega.0
757 ? 00:00:45 io.history.0
767 ? 00:00:29 io.socketio.0
793 ? 00:15:18 io.javascript.0
811 ? 00:02:10 io.rpi2.0
827 ? 00:00:59 io.hm-rpc.3
893 ? 00:00:34 io.sonos.0
pi@ioBroker-Pi3:~ $
Dann versuch mal
cd /opt/iobroker sudo iobroker stop sudo iobroker del admin sudo npm install iobroker.admin --production sudo iobroker add admin sudo iobroker start
Guten Morgen
leider ohne Erfolg mit dieser Warnmeldung
pi@ioBroker-Pi3:/opt/iobroker $ sudo npm install iobroker.admin --production iobroker@1.0.0 /opt/iobroker └── iobroker.admin@2.0.9 npm WARN Failed to parse json npm WARN Unexpected token '\n' at 73:65 npm WARN "homepage": "https://github.com/TimBeyer/cls-bluerird#readme" npm WARN ^ npm WARN File: /opt/iobroker/node_modules/cls-bluebird/package.json npm WARN Failed to parse json npm WARN Unexpected token '\u0002' at 5:30 npm WARN "raw": "asj1@~0�2.3", "scope": .sll, npm WARN ^ npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/asn1/package.json npm WARN Failed to parse json npm WARN Unexpected token '_' at 2:4 npm WARN _args":`� npm WARN ^ npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/debug/package.json npm WARN Failed to parse json npm WARN Unexpected token ';' at 2:10 npm WARN "_args"; [ npm WARN ^ npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/engine.io/package.json npm WARN Failed to parse json npm WARN Unexpected token 'z' at 1:1 npm WARN z npm WARN ^ npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/hawk/package.json npm WARN Failed to parse json npm WARN Unexpected token '&' at 2:3 npm WARN &_azgs": [ npm WARN ^ npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/minimist/package.json npm WARN Failed to parse json npm WARN Unexpected token '\u0002' at 3:6 npm WARN [( 0 { npm WARN ^ npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/tweetnacl/package.json npm WARN Failed to parse json npm WARN No value found for key [args at 2:11 npm WARN "[args":$[ npm WARN ^ npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/uuid/package.json pi@ioBroker-Pi3:/opt/iobroker $
Was sagt
node -v npm -v
Gruß Rainer
pi@ioBroker-Pi3:/opt/iobroker $ node -v
v6.12.2
pi@ioBroker-Pi3:/opt/iobroker $ npm -v
3.10.10
Welche js-controller version hast du?
Wo seh ich das ?
Habs gefunden unter
iobroker update
Controller "js-controller" : 1.2.3 , installed 1.2.3
Dippi
Was um alles in der Welt ist dann
@dippi:iobroker@1.0.0 `
Ich hatte befürchtet, dass du noch diese version hast.Gruß Rainer
keine Ahnung was ich da gemacht habe, wahrscheinlich vor lauter verzweiflung ein Update gemacht.
Muss ich wieder downgraden ?
Wenn ja hast du mir den Befehl dafür ?
Gruß Dippi
Nein!
Wenn du jetzt das Update gemacht hast weißich evtl. weiter.
Wenn du schon immer 1.2.3 drauf hattest nicht.
Gruß Rainer
Das Update hab ich glaub schon erst jetzt gemacht.
Dann versuch mal
cd /opt/iobroker sudo iobroker stop sudo npm cache clean sudo npm install iobroker.admin sudo iobroker upload admin sudo iobroker start
ich bekomme diese Warnmeldungen
express node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/express
express-fileupload node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/express-fileupload
npm WARN ^
npm WARN ^
npm WARN _args":`�
npm WARN ^
npm WARN "_args"; [
npm WARN ^
npm WARN z
npm WARN ^
npm WARN &_azgs": [
npm WARN ^
npm WARN [( 0 {
npm WARN ^
npm WARN "[args":$[
npm WARN ^
pi@ioBroker-Pi3:/opt/iobroker $ sudo iobroker upload admin
got /home/pi/node_modules/iobroker.admin/admin
upload [2] admin.admin /home/pi/node_modules/iobroker.admin/admin/words.js words.js application/javascript
upload [1] admin.admin /home/pi/node_modules/iobroker.admin/admin/index.html index.html text/html
upload [0] admin.admin /home/pi/node_modules/iobroker.admin/admin/admin.png admin.png image/png
system.adapter.admin does not exist
pi@ioBroker-Pi3:/opt/iobroker $ sudo iobroker start
Starting iobroker controller daemon…
iobroker controller daemon started. PID: 19950
Hast du mal den raspi neu gestartet, dass 1.2.3 auch gestartet wird?
Ich hab es nochmal versucht und nach dem Cache clean den RP neugestartet und dann weiter gemacht, nun sieht es etwas besser aus glsub ich
pi@ioBroker-Pi3:~ $ sudo npm install iobroker.admin - after@0.8.2 node_modules/iobroker.admin/node_modules/after - array-flatten@1.1.1 node_modules/iobroker.admin/node_modules/array-flatten - arraybuffer.slice@0.0.6 node_modules/iobroker.admin/node_modules/arraybuffer.slice - asn1@0.2.3 node_modules/iobroker.admin/node_modules/asn1 - assert-plus@1.0.0 node_modules/iobroker.admin/node_modules/assert-plus - asynckit@0.4.0 node_modules/iobroker.admin/node_modules/asynckit - aws-sign2@0.7.0 node_modules/iobroker.admin/node_modules/aws-sign2 - aws4@1.6.0 node_modules/iobroker.admin/node_modules/aws4 - backo2@1.0.2 node_modules/iobroker.admin/node_modules/backo2 - balanced-match@1.0.0 node_modules/iobroker.admin/node_modules/balanced-match - base64-arraybuffer@0.1.5 node_modules/iobroker.admin/node_modules/base64-arraybuffer - base64id@1.0.0 node_modules/iobroker.admin/node_modules/base64id - blob@0.0.4 node_modules/iobroker.admin/node_modules/blob - bytes@3.0.0 node_modules/iobroker.admin/node_modules/bytes - callsite@1.0.0 node_modules/iobroker.admin/node_modules/callsite - better-assert@1.0.2 node_modules/iobroker.admin/node_modules/better-assert - caseless@0.12.0 node_modules/iobroker.admin/node_modules/caseless - co@4.6.0 node_modules/iobroker.admin/node_modules/co - component-bind@1.0.0 node_modules/iobroker.admin/node_modules/component-bind - component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/component-emitter - component-inherit@0.0.3 node_modules/iobroker.admin/node_modules/component-inherit - concat-map@0.0.1 node_modules/iobroker.admin/node_modules/concat-map - brace-expansion@1.1.8 node_modules/iobroker.admin/node_modules/brace-expansion - connect-flash@0.1.1 node_modules/iobroker.admin/node_modules/connect-flash - content-disposition@0.5.2 node_modules/iobroker.admin/node_modules/content-disposition - content-type@1.0.4 node_modules/iobroker.admin/node_modules/content-type - cookie@0.3.1 node_modules/iobroker.admin/node_modules/cookie - cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/cookie-signature - cookie-parser@1.4.3 node_modules/iobroker.admin/node_modules/cookie-parser - core-util-is@1.0.2 node_modules/iobroker.admin/node_modules/core-util-is - crc@3.4.4 node_modules/iobroker.admin/node_modules/crc - dashdash@1.14.1 node_modules/iobroker.admin/node_modules/dashdash - delayed-stream@1.0.0 node_modules/iobroker.admin/node_modules/delayed-stream - combined-stream@1.0.5 node_modules/iobroker.admin/node_modules/combined-stream - depd@1.1.1 node_modules/iobroker.admin/node_modules/depd - destroy@1.0.4 node_modules/iobroker.admin/node_modules/destroy - ee-first@1.1.1 node_modules/iobroker.admin/node_modules/ee-first - encodeurl@1.0.1 node_modules/iobroker.admin/node_modules/encodeurl - component-emitter@1.2.1 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/component-emitter - ms@0.7.2 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/ms - debug@2.3.3 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/debug - ms@0.7.2 node_modules/iobroker.admin/node_modules/engine.io/node_modules/ms - debug@2.3.3 node_modules/iobroker.admin/node_modules/engine.io/node_modules/debug - escape-html@1.0.3 node_modules/iobroker.admin/node_modules/escape-html - etag@1.8.1 node_modules/iobroker.admin/node_modules/etag - setprototypeof@1.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/setprototypeof - statuses@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/statuses - extend@3.0.1 node_modules/iobroker.admin/node_modules/extend - extsprintf@1.3.0 node_modules/iobroker.admin/node_modules/extsprintf - fast-deep-equal@1.0.0 node_modules/iobroker.admin/node_modules/fast-deep-equal - fast-json-stable-stringify@2.0.0 node_modules/iobroker.admin/node_modules/fast-json-stable-stringify - statuses@1.3.1 node_modules/iobroker.admin/node_modules/finalhandler/node_modules/statuses - forever-agent@0.6.1 node_modules/iobroker.admin/node_modules/forever-agent - forwarded@0.1.2 node_modules/iobroker.admin/node_modules/forwarded - fresh@0.5.2 node_modules/iobroker.admin/node_modules/fresh - fs.realpath@1.0.0 node_modules/iobroker.admin/node_modules/fs.realpath - getpass@0.1.7 node_modules/iobroker.admin/node_modules/getpass - graceful-fs@4.1.11 node_modules/iobroker.admin/node_modules/graceful-fs - har-schema@2.0.0 node_modules/iobroker.admin/node_modules/har-schema - has-cors@1.1.0 node_modules/iobroker.admin/node_modules/has-cors - hoek@4.2.0 node_modules/iobroker.admin/node_modules/hoek - boom@4.3.1 node_modules/iobroker.admin/node_modules/boom - boom@5.2.0 node_modules/iobroker.admin/node_modules/cryptiles/node_modules/boom - cryptiles@3.1.2 node_modules/iobroker.admin/node_modules/cryptiles - iconv-lite@0.4.19 node_modules/iobroker.admin/node_modules/iconv-lite - indexof@0.0.1 node_modules/iobroker.admin/node_modules/indexof - inherits@2.0.3 node_modules/iobroker.admin/node_modules/inherits - ipaddr.js@1.5.2 node_modules/iobroker.admin/node_modules/ipaddr.js - is-typedarray@1.0.0 node_modules/iobroker.admin/node_modules/is-typedarray - isarray@0.0.1 node_modules/iobroker.admin/node_modules/isarray - has-binary@0.1.7 node_modules/iobroker.admin/node_modules/has-binary - isstream@0.1.2 node_modules/iobroker.admin/node_modules/isstream - jsbn@0.1.1 node_modules/iobroker.admin/node_modules/jsbn - ecc-jsbn@0.1.1 node_modules/iobroker.admin/node_modules/ecc-jsbn - json-schema@0.2.3 node_modules/iobroker.admin/node_modules/json-schema - json-schema-traverse@0.3.1 node_modules/iobroker.admin/node_modules/json-schema-traverse - ajv@5.5.2 node_modules/iobroker.admin/node_modules/ajv - har-validator@5.0.3 node_modules/iobroker.admin/node_modules/har-validator - json-stringify-safe@5.0.1 node_modules/iobroker.admin/node_modules/json-stringify-safe - json3@3.3.2 node_modules/iobroker.admin/node_modules/json3 - jsonfile@2.4.0 node_modules/iobroker.admin/node_modules/jsonfile - media-typer@0.3.0 node_modules/iobroker.admin/node_modules/media-typer - merge-descriptors@1.0.1 node_modules/iobroker.admin/node_modules/merge-descriptors - methods@1.1.2 node_modules/iobroker.admin/node_modules/methods - mime@1.4.1 node_modules/iobroker.admin/node_modules/mime - mime-db@1.30.0 node_modules/iobroker.admin/node_modules/mime-db - mime-types@2.1.17 node_modules/iobroker.admin/node_modules/mime-types - form-data@2.3.1 node_modules/iobroker.admin/node_modules/form-data - minimatch@3.0.4 node_modules/iobroker.admin/node_modules/minimatch - ms@2.0.0 node_modules/iobroker.admin/node_modules/ms - debug@2.6.9 node_modules/iobroker.admin/node_modules/debug - negotiator@0.6.1 node_modules/iobroker.admin/node_modules/negotiator - accepts@1.3.4 node_modules/iobroker.admin/node_modules/accepts - accepts@1.3.3 node_modules/iobroker.admin/node_modules/engine.io/node_modules/accepts - oauth-sign@0.8.2 node_modules/iobroker.admin/node_modules/oauth-sign - object-assign@4.1.0 node_modules/iobroker.admin/node_modules/object-assign - object-component@0.0.3 node_modules/iobroker.admin/node_modules/object-component - on-finished@2.3.0 node_modules/iobroker.admin/node_modules/on-finished - on-headers@1.0.1 node_modules/iobroker.admin/node_modules/on-headers - options@0.0.6 node_modules/iobroker.admin/node_modules/options - parsejson@0.0.3 node_modules/iobroker.admin/node_modules/parsejson - parseqs@0.0.5 node_modules/iobroker.admin/node_modules/parseqs - parseuri@0.0.5 node_modules/iobroker.admin/node_modules/parseuri - parseurl@1.3.2 node_modules/iobroker.admin/node_modules/parseurl - passport-strategy@1.0.0 node_modules/iobroker.admin/node_modules/passport-strategy - passport-local@1.0.0 node_modules/iobroker.admin/node_modules/passport-local - path-is-absolute@1.0.1 node_modules/iobroker.admin/node_modules/path-is-absolute - path-to-regexp@0.1.7 node_modules/iobroker.admin/node_modules/path-to-regexp - pause@0.0.1 node_modules/iobroker.admin/node_modules/pause - passport@0.3.2 node_modules/iobroker.admin/node_modules/passport - performance-now@2.1.0 node_modules/iobroker.admin/node_modules/performance-now - proxy-addr@2.0.2 node_modules/iobroker.admin/node_modules/proxy-addr - punycode@1.4.1 node_modules/iobroker.admin/node_modules/punycode - qs@6.5.1 node_modules/iobroker.admin/node_modules/qs - random-bytes@1.0.0 node_modules/iobroker.admin/node_modules/random-bytes - range-parser@1.2.0 node_modules/iobroker.admin/node_modules/range-parser - safe-buffer@5.1.1 node_modules/iobroker.admin/node_modules/safe-buffer - statuses@1.3.1 node_modules/iobroker.admin/node_modules/send/node_modules/statuses - setprototypeof@1.0.3 node_modules/iobroker.admin/node_modules/setprototypeof - sntp@2.1.0 node_modules/iobroker.admin/node_modules/sntp - hawk@6.0.2 node_modules/iobroker.admin/node_modules/hawk - ms@0.7.2 node_modules/iobroker.admin/node_modules/socket.io-adapter/node_modules/ms - debug@2.3.3 node_modules/iobroker.admin/node_modules/socket.io-adapter/node_modules/debug - component-emitter@1.2.1 node_modules/iobroker.admin/node_modules/socket.io-client/node_modules/component-emitter - ms@0.7.2 node_modules/iobroker.admin/node_modules/socket.io-client/node_modules/ms - debug@2.3.3 node_modules/iobroker.admin/node_modules/socket.io-client/node_modules/debug - ms@0.7.1 node_modules/iobroker.admin/node_modules/socket.io-parser/node_modules/ms - debug@2.2.0 node_modules/iobroker.admin/node_modules/socket.io-parser/node_modules/debug - socket.io-parser@2.3.1 node_modules/iobroker.admin/node_modules/socket.io-parser - socket.io-adapter@0.5.0 node_modules/iobroker.admin/node_modules/socket.io-adapter - ms@0.7.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/ms - debug@2.3.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/debug - statuses@1.4.0 node_modules/iobroker.admin/node_modules/statuses - http-errors@1.6.2 node_modules/iobroker.admin/node_modules/http-errors - send@0.16.1 node_modules/iobroker.admin/node_modules/send - serve-static@1.13.1 node_modules/iobroker.admin/node_modules/serve-static - streamifier@0.1.1 node_modules/iobroker.admin/node_modules/streamifier - streamsearch@0.1.2 node_modules/iobroker.admin/node_modules/streamsearch - string_decoder@0.10.31 node_modules/iobroker.admin/node_modules/string_decoder - readable-stream@1.1.14 node_modules/iobroker.admin/node_modules/readable-stream - dicer@0.2.5 node_modules/iobroker.admin/node_modules/dicer - busboy@0.2.14 node_modules/iobroker.admin/node_modules/busboy - stringstream@0.0.5 node_modules/iobroker.admin/node_modules/stringstream - to-array@0.1.4 node_modules/iobroker.admin/node_modules/to-array - tough-cookie@2.3.3 node_modules/iobroker.admin/node_modules/tough-cookie - tunnel-agent@0.6.0 node_modules/iobroker.admin/node_modules/tunnel-agent - tweetnacl@0.14.5 node_modules/iobroker.admin/node_modules/tweetnacl - bcrypt-pbkdf@1.0.1 node_modules/iobroker.admin/node_modules/bcrypt-pbkdf - sshpk@1.13.1 node_modules/iobroker.admin/node_modules/sshpk - type-is@1.6.15 node_modules/iobroker.admin/node_modules/type-is - uid-safe@2.1.5 node_modules/iobroker.admin/node_modules/uid-safe - ultron@1.0.2 node_modules/iobroker.admin/node_modules/ultron - ws@1.1.2 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/ws - unpipe@1.0.0 node_modules/iobroker.admin/node_modules/unpipe - finalhandler@1.1.0 node_modules/iobroker.admin/node_modules/finalhandler - raw-body@2.3.2 node_modules/iobroker.admin/node_modules/raw-body - body-parser@1.18.2 node_modules/iobroker.admin/node_modules/body-parser - utils-merge@1.0.1 node_modules/iobroker.admin/node_modules/utils-merge - express-session@1.15.6 node_modules/iobroker.admin/node_modules/express-session - uuid@3.1.0 node_modules/iobroker.admin/node_modules/uuid - vary@1.1.2 node_modules/iobroker.admin/node_modules/vary - express@4.16.2 node_modules/iobroker.admin/node_modules/express - verror@1.10.0 node_modules/iobroker.admin/node_modules/verror - jsprim@1.4.1 node_modules/iobroker.admin/node_modules/jsprim - http-signature@1.2.0 node_modules/iobroker.admin/node_modules/http-signature - request@2.83.0 node_modules/iobroker.admin/node_modules/request - wrappy@1.0.2 node_modules/iobroker.admin/node_modules/wrappy - once@1.4.0 node_modules/iobroker.admin/node_modules/once - inflight@1.0.6 node_modules/iobroker.admin/node_modules/inflight - glob@7.1.2 node_modules/iobroker.admin/node_modules/glob - rimraf@2.6.2 node_modules/iobroker.admin/node_modules/rimraf - fs-extra@0.22.1 node_modules/iobroker.admin/node_modules/fs-extra - express-fileupload@0.1.4 node_modules/iobroker.admin/node_modules/express-fileupload - ws@1.1.4 node_modules/iobroker.admin/node_modules/ws - wtf-8@1.0.0 node_modules/iobroker.admin/node_modules/wtf-8 - engine.io-parser@1.3.2 node_modules/iobroker.admin/node_modules/engine.io-parser - engine.io@1.8.4 node_modules/iobroker.admin/node_modules/engine.io - xmlhttprequest-ssl@1.5.3 node_modules/iobroker.admin/node_modules/xmlhttprequest-ssl - xtend@4.0.1 node_modules/iobroker.admin/node_modules/xtend - passport.socketio@3.7.0 node_modules/iobroker.admin/node_modules/passport.socketio - yeast@0.1.2 node_modules/iobroker.admin/node_modules/yeast - engine.io-client@1.8.4 node_modules/iobroker.admin/node_modules/engine.io-client - socket.io-client@1.7.4 node_modules/iobroker.admin/node_modules/socket.io-client - socket.io@1.7.4 node_modules/iobroker.admin/node_modules/socket.io iobroker.inst@1.0.3 /home/pi └── iobroker.admin@2.0.9 pi@ioBroker-Pi3:~ $ sudo iobroker upload admin got /home/pi/node_modules/iobroker.admin/admin upload [2] admin.admin /home/pi/node_modules/iobroker.admin/admin/words.js words.js application/javascript upload [1] admin.admin /home/pi/node_modules/iobroker.admin/admin/index.html index.html text/html upload [0] admin.admin /home/pi/node_modules/iobroker.admin/admin/admin.png admin.png image/png system.adapter.admin does not exist pi@ioBroker-Pi3:~ $ sudo iobroker start Starting iobroker controller daemon... iobroker controller daemon started. PID: 784
nur ist wohl noch was mit dem admin adapter.
OH ich glaub ich hab im falschen verzeichnis installiert. wenn icih wieder im iobroker Verzeichnis bin kommen wieder die Warnmeldungen
OH ich glaub ich hab im falschen verzeichnis installiert. `
Das wäre meine nächste Frage gewesen.Dann hast du zweimal iobroker drauf und das gibt natürlich Probleme.
Hast du ein aktuelles backup?
ne leider nicht, aber hab noch nicht so viel im Iobroker drin bin erst am anfang.
Scheint nach einer neu install auszusehen.
Scheint nach einer neu install auszusehen. `
Wäre wahrscheinlich das einfachste
