    4. [gelöst]kein Zugriff per Web (Port8081)
      der_Auge last edited by
      Dann versuch mal
      cd /opt/iobroker
      sudo iobroker stop
      sudo iobroker del admin
      sudo npm install iobroker.admin --production
      sudo iobroker add admin
      sudo iobroker start
        dippi last edited by
        Guten Morgen
        leider ohne Erfolg mit dieser Warnmeldung
        pi@ioBroker-Pi3:/opt/iobroker $ sudo npm install iobroker.admin --production
        iobroker@1.0.0 /opt/iobroker
        └── iobroker.admin@2.0.9
        npm WARN Failed to parse json
        npm WARN Unexpected token '\n' at 73:65
        npm WARN   "homepage": "https://github.com/TimBeyer/cls-bluerird#readme"
        npm WARN        ^
        npm WARN File: /opt/iobroker/node_modules/cls-bluebird/package.json
        npm WARN Unexpected token '\u0002' at 5:30
        npm WARN         "raw": "asj1@~0�2.3",       "scope": .sll,
        npm WARN                              ^
        npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/asn1/package.json
        npm WARN Unexpected token '_' at 2:4
        npm WARN    _args":`�
        npm WARN    ^
        npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/debug/package.json
        npm WARN Unexpected token ';' at 2:10
        npm WARN   "_args"; [
        npm WARN          ^
        npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/engine.io/package.json
        npm WARN Unexpected token 'z' at 1:1
        npm WARN z
        npm WARN ^
        npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/hawk/package.json
        npm WARN Unexpected token '&' at 2:3
        npm WARN   &_azgs": [
        npm WARN   ^
        npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/minimist/package.json
        npm WARN Unexpected token '\u0002' at 3:6
        npm WARN     [( 0   {
        npm WARN      ^
        npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/tweetnacl/package.json
        npm WARN No value found for key [args at 2:11
        npm WARN   "[args":$[
        npm WARN           ^
        npm WARN File: /opt/iobroker/node_modules/iobroker.sonos/node_modules/uuid/package.json
          Was sagt
          node -v
          npm -v
          Gruß Rainer
            pi@ioBroker-Pi3:/opt/iobroker $ node -v
            v6.12.2
            pi@ioBroker-Pi3:/opt/iobroker $ npm -v
            3.10.10
              Welche js-controller version hast du?
                Wo seh ich das ?
                  Habs gefunden unter
                  iobroker update
                  Controller "js-controller" : 1.2.3 , installed 1.2.3
                  Dippi
                    Was um alles in der Welt ist dann
                    @dippi:
                    iobroker@1.0.0 `
                    Ich hatte befürchtet, dass du noch diese version hast.
                    Gruß Rainer
                      keine Ahnung was ich da gemacht habe, wahrscheinlich vor lauter verzweiflung ein Update gemacht.
                      Muss ich wieder downgraden ?
                      Wenn ja hast du mir den Befehl dafür ?
                      Gruß Dippi
                        Nein!
                        Wenn du jetzt das Update gemacht hast weißich evtl. weiter.
                        Wenn du schon immer 1.2.3 drauf hattest nicht.
                        Gruß Rainer
                          Das Update hab ich glaub schon erst jetzt gemacht.
                            Dann versuch mal
                            cd /opt/iobroker
                            sudo iobroker stop
                            sudo npm cache clean
                            sudo iobroker upload admin
                            sudo iobroker start
                              ich bekomme diese Warnmeldungen
                              • express node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/express
                              • express-fileupload node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/express-fileupload
                              npm WARN ^
                              npm WARN ^
                              npm WARN _args":`�
                              npm WARN ^
                              npm WARN "_args"; [
                              npm WARN ^
                              npm WARN z
                              npm WARN ^
                              npm WARN &_azgs": [
                              npm WARN ^
                              npm WARN [( 0 {
                              npm WARN ^
                              npm WARN "[args":$[
                              npm WARN ^
                              pi@ioBroker-Pi3:/opt/iobroker $ sudo iobroker upload admin
                              got /home/pi/node_modules/iobroker.admin/admin
                              upload [2] admin.admin /home/pi/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                              upload [1] admin.admin /home/pi/node_modules/iobroker.admin/admin/index.html index.html text/html
                              upload [0] admin.admin /home/pi/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                              system.adapter.admin does not exist
                              pi@ioBroker-Pi3:/opt/iobroker $ sudo iobroker start
                              Starting iobroker controller daemon…
                              iobroker controller daemon started. PID: 19950
                                Hast du mal den raspi neu gestartet, dass 1.2.3 auch gestartet wird?
                                  Ich hab es nochmal versucht und nach dem Cache clean den RP neugestartet und dann weiter gemacht, nun sieht es etwas besser aus glsub ich
                                  pi@ioBroker-Pi3:~ $ sudo npm install iobroker.admin
                                  - after@0.8.2 node_modules/iobroker.admin/node_modules/after
                                  - array-flatten@1.1.1 node_modules/iobroker.admin/node_modules/array-flatten
                                  - arraybuffer.slice@0.0.6 node_modules/iobroker.admin/node_modules/arraybuffer.slice
                                  - asn1@0.2.3 node_modules/iobroker.admin/node_modules/asn1
                                  - assert-plus@1.0.0 node_modules/iobroker.admin/node_modules/assert-plus
                                  - asynckit@0.4.0 node_modules/iobroker.admin/node_modules/asynckit
                                  - aws-sign2@0.7.0 node_modules/iobroker.admin/node_modules/aws-sign2
                                  - aws4@1.6.0 node_modules/iobroker.admin/node_modules/aws4
                                  - backo2@1.0.2 node_modules/iobroker.admin/node_modules/backo2
                                  - balanced-match@1.0.0 node_modules/iobroker.admin/node_modules/balanced-match
                                  - base64-arraybuffer@0.1.5 node_modules/iobroker.admin/node_modules/base64-arraybuffer
                                  - base64id@1.0.0 node_modules/iobroker.admin/node_modules/base64id
                                  - blob@0.0.4 node_modules/iobroker.admin/node_modules/blob
                                  - bytes@3.0.0 node_modules/iobroker.admin/node_modules/bytes
                                  - callsite@1.0.0 node_modules/iobroker.admin/node_modules/callsite
                                  - better-assert@1.0.2 node_modules/iobroker.admin/node_modules/better-assert
                                  - caseless@0.12.0 node_modules/iobroker.admin/node_modules/caseless
                                  - co@4.6.0 node_modules/iobroker.admin/node_modules/co
                                  - component-bind@1.0.0 node_modules/iobroker.admin/node_modules/component-bind
                                  - component-emitter@1.1.2 node_modules/iobroker.admin/node_modules/component-emitter
                                  - component-inherit@0.0.3 node_modules/iobroker.admin/node_modules/component-inherit
                                  - concat-map@0.0.1 node_modules/iobroker.admin/node_modules/concat-map
                                  - brace-expansion@1.1.8 node_modules/iobroker.admin/node_modules/brace-expansion
                                  - connect-flash@0.1.1 node_modules/iobroker.admin/node_modules/connect-flash
                                  - content-disposition@0.5.2 node_modules/iobroker.admin/node_modules/content-disposition
                                  - content-type@1.0.4 node_modules/iobroker.admin/node_modules/content-type
                                  - cookie@0.3.1 node_modules/iobroker.admin/node_modules/cookie
                                  - cookie-signature@1.0.6 node_modules/iobroker.admin/node_modules/cookie-signature
                                  - cookie-parser@1.4.3 node_modules/iobroker.admin/node_modules/cookie-parser
                                  - core-util-is@1.0.2 node_modules/iobroker.admin/node_modules/core-util-is
                                  - crc@3.4.4 node_modules/iobroker.admin/node_modules/crc
                                  - dashdash@1.14.1 node_modules/iobroker.admin/node_modules/dashdash
                                  - delayed-stream@1.0.0 node_modules/iobroker.admin/node_modules/delayed-stream
                                  - combined-stream@1.0.5 node_modules/iobroker.admin/node_modules/combined-stream
                                  - depd@1.1.1 node_modules/iobroker.admin/node_modules/depd
                                  - destroy@1.0.4 node_modules/iobroker.admin/node_modules/destroy
                                  - ee-first@1.1.1 node_modules/iobroker.admin/node_modules/ee-first
                                  - encodeurl@1.0.1 node_modules/iobroker.admin/node_modules/encodeurl
                                  - component-emitter@1.2.1 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/component-emitter
                                  - ms@0.7.2 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/ms
                                  - debug@2.3.3 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/debug
                                  - ms@0.7.2 node_modules/iobroker.admin/node_modules/engine.io/node_modules/ms
                                  - debug@2.3.3 node_modules/iobroker.admin/node_modules/engine.io/node_modules/debug
                                  - escape-html@1.0.3 node_modules/iobroker.admin/node_modules/escape-html
                                  - etag@1.8.1 node_modules/iobroker.admin/node_modules/etag
                                  - setprototypeof@1.1.0 node_modules/iobroker.admin/node_modules/express/node_modules/setprototypeof
                                  - statuses@1.3.1 node_modules/iobroker.admin/node_modules/express/node_modules/statuses
                                  - extend@3.0.1 node_modules/iobroker.admin/node_modules/extend
                                  - extsprintf@1.3.0 node_modules/iobroker.admin/node_modules/extsprintf
                                  - fast-deep-equal@1.0.0 node_modules/iobroker.admin/node_modules/fast-deep-equal
                                  - fast-json-stable-stringify@2.0.0 node_modules/iobroker.admin/node_modules/fast-json-stable-stringify
                                  - statuses@1.3.1 node_modules/iobroker.admin/node_modules/finalhandler/node_modules/statuses
                                  - forever-agent@0.6.1 node_modules/iobroker.admin/node_modules/forever-agent
                                  - forwarded@0.1.2 node_modules/iobroker.admin/node_modules/forwarded
                                  - fresh@0.5.2 node_modules/iobroker.admin/node_modules/fresh
                                  - fs.realpath@1.0.0 node_modules/iobroker.admin/node_modules/fs.realpath
                                  - getpass@0.1.7 node_modules/iobroker.admin/node_modules/getpass
                                  - graceful-fs@4.1.11 node_modules/iobroker.admin/node_modules/graceful-fs
                                  - har-schema@2.0.0 node_modules/iobroker.admin/node_modules/har-schema
                                  - has-cors@1.1.0 node_modules/iobroker.admin/node_modules/has-cors
                                  - hoek@4.2.0 node_modules/iobroker.admin/node_modules/hoek
                                  - boom@4.3.1 node_modules/iobroker.admin/node_modules/boom
                                  - boom@5.2.0 node_modules/iobroker.admin/node_modules/cryptiles/node_modules/boom
                                  - cryptiles@3.1.2 node_modules/iobroker.admin/node_modules/cryptiles
                                  - iconv-lite@0.4.19 node_modules/iobroker.admin/node_modules/iconv-lite
                                  - indexof@0.0.1 node_modules/iobroker.admin/node_modules/indexof
                                  - inherits@2.0.3 node_modules/iobroker.admin/node_modules/inherits
                                  - ipaddr.js@1.5.2 node_modules/iobroker.admin/node_modules/ipaddr.js
                                  - is-typedarray@1.0.0 node_modules/iobroker.admin/node_modules/is-typedarray
                                  - isarray@0.0.1 node_modules/iobroker.admin/node_modules/isarray
                                  - has-binary@0.1.7 node_modules/iobroker.admin/node_modules/has-binary
                                  - isstream@0.1.2 node_modules/iobroker.admin/node_modules/isstream
                                  - jsbn@0.1.1 node_modules/iobroker.admin/node_modules/jsbn
                                  - ecc-jsbn@0.1.1 node_modules/iobroker.admin/node_modules/ecc-jsbn
                                  - json-schema@0.2.3 node_modules/iobroker.admin/node_modules/json-schema
                                  - json-schema-traverse@0.3.1 node_modules/iobroker.admin/node_modules/json-schema-traverse
                                  - ajv@5.5.2 node_modules/iobroker.admin/node_modules/ajv
                                  - har-validator@5.0.3 node_modules/iobroker.admin/node_modules/har-validator
                                  - json-stringify-safe@5.0.1 node_modules/iobroker.admin/node_modules/json-stringify-safe
                                  - json3@3.3.2 node_modules/iobroker.admin/node_modules/json3
                                  - jsonfile@2.4.0 node_modules/iobroker.admin/node_modules/jsonfile
                                  - media-typer@0.3.0 node_modules/iobroker.admin/node_modules/media-typer
                                  - merge-descriptors@1.0.1 node_modules/iobroker.admin/node_modules/merge-descriptors
                                  - methods@1.1.2 node_modules/iobroker.admin/node_modules/methods
                                  - mime@1.4.1 node_modules/iobroker.admin/node_modules/mime
                                  - mime-db@1.30.0 node_modules/iobroker.admin/node_modules/mime-db
                                  - mime-types@2.1.17 node_modules/iobroker.admin/node_modules/mime-types
                                  - form-data@2.3.1 node_modules/iobroker.admin/node_modules/form-data
                                  - minimatch@3.0.4 node_modules/iobroker.admin/node_modules/minimatch
                                  - ms@2.0.0 node_modules/iobroker.admin/node_modules/ms
                                  - debug@2.6.9 node_modules/iobroker.admin/node_modules/debug
                                  - negotiator@0.6.1 node_modules/iobroker.admin/node_modules/negotiator
                                  - accepts@1.3.4 node_modules/iobroker.admin/node_modules/accepts
                                  - accepts@1.3.3 node_modules/iobroker.admin/node_modules/engine.io/node_modules/accepts
                                  - oauth-sign@0.8.2 node_modules/iobroker.admin/node_modules/oauth-sign
                                  - object-assign@4.1.0 node_modules/iobroker.admin/node_modules/object-assign
                                  - object-component@0.0.3 node_modules/iobroker.admin/node_modules/object-component
                                  - on-finished@2.3.0 node_modules/iobroker.admin/node_modules/on-finished
                                  - on-headers@1.0.1 node_modules/iobroker.admin/node_modules/on-headers
                                  - options@0.0.6 node_modules/iobroker.admin/node_modules/options
                                  - parsejson@0.0.3 node_modules/iobroker.admin/node_modules/parsejson
                                  - parseqs@0.0.5 node_modules/iobroker.admin/node_modules/parseqs
                                  - parseuri@0.0.5 node_modules/iobroker.admin/node_modules/parseuri
                                  - parseurl@1.3.2 node_modules/iobroker.admin/node_modules/parseurl
                                  - passport-strategy@1.0.0 node_modules/iobroker.admin/node_modules/passport-strategy
                                  - passport-local@1.0.0 node_modules/iobroker.admin/node_modules/passport-local
                                  - path-is-absolute@1.0.1 node_modules/iobroker.admin/node_modules/path-is-absolute
                                  - path-to-regexp@0.1.7 node_modules/iobroker.admin/node_modules/path-to-regexp
                                  - pause@0.0.1 node_modules/iobroker.admin/node_modules/pause
                                  - passport@0.3.2 node_modules/iobroker.admin/node_modules/passport
                                  - performance-now@2.1.0 node_modules/iobroker.admin/node_modules/performance-now
                                  - proxy-addr@2.0.2 node_modules/iobroker.admin/node_modules/proxy-addr
                                  - punycode@1.4.1 node_modules/iobroker.admin/node_modules/punycode
                                  - qs@6.5.1 node_modules/iobroker.admin/node_modules/qs
                                  - random-bytes@1.0.0 node_modules/iobroker.admin/node_modules/random-bytes
                                  - range-parser@1.2.0 node_modules/iobroker.admin/node_modules/range-parser
                                  - safe-buffer@5.1.1 node_modules/iobroker.admin/node_modules/safe-buffer
                                  - statuses@1.3.1 node_modules/iobroker.admin/node_modules/send/node_modules/statuses
                                  - setprototypeof@1.0.3 node_modules/iobroker.admin/node_modules/setprototypeof
                                  - sntp@2.1.0 node_modules/iobroker.admin/node_modules/sntp
                                  - hawk@6.0.2 node_modules/iobroker.admin/node_modules/hawk
                                  - ms@0.7.2 node_modules/iobroker.admin/node_modules/socket.io-adapter/node_modules/ms
                                  - debug@2.3.3 node_modules/iobroker.admin/node_modules/socket.io-adapter/node_modules/debug
                                  - component-emitter@1.2.1 node_modules/iobroker.admin/node_modules/socket.io-client/node_modules/component-emitter
                                  - ms@0.7.2 node_modules/iobroker.admin/node_modules/socket.io-client/node_modules/ms
                                  - debug@2.3.3 node_modules/iobroker.admin/node_modules/socket.io-client/node_modules/debug
                                  - ms@0.7.1 node_modules/iobroker.admin/node_modules/socket.io-parser/node_modules/ms
                                  - debug@2.2.0 node_modules/iobroker.admin/node_modules/socket.io-parser/node_modules/debug
                                  - socket.io-parser@2.3.1 node_modules/iobroker.admin/node_modules/socket.io-parser
                                  - socket.io-adapter@0.5.0 node_modules/iobroker.admin/node_modules/socket.io-adapter
                                  - ms@0.7.2 node_modules/iobroker.admin/node_modules/socket.io/node_modules/ms
                                  - debug@2.3.3 node_modules/iobroker.admin/node_modules/socket.io/node_modules/debug
                                  - statuses@1.4.0 node_modules/iobroker.admin/node_modules/statuses
                                  - http-errors@1.6.2 node_modules/iobroker.admin/node_modules/http-errors
                                  - send@0.16.1 node_modules/iobroker.admin/node_modules/send
                                  - serve-static@1.13.1 node_modules/iobroker.admin/node_modules/serve-static
                                  - streamifier@0.1.1 node_modules/iobroker.admin/node_modules/streamifier
                                  - streamsearch@0.1.2 node_modules/iobroker.admin/node_modules/streamsearch
                                  - string_decoder@0.10.31 node_modules/iobroker.admin/node_modules/string_decoder
                                  - readable-stream@1.1.14 node_modules/iobroker.admin/node_modules/readable-stream
                                  - dicer@0.2.5 node_modules/iobroker.admin/node_modules/dicer
                                  - busboy@0.2.14 node_modules/iobroker.admin/node_modules/busboy
                                  - stringstream@0.0.5 node_modules/iobroker.admin/node_modules/stringstream
                                  - to-array@0.1.4 node_modules/iobroker.admin/node_modules/to-array
                                  - tough-cookie@2.3.3 node_modules/iobroker.admin/node_modules/tough-cookie
                                  - tunnel-agent@0.6.0 node_modules/iobroker.admin/node_modules/tunnel-agent
                                  - tweetnacl@0.14.5 node_modules/iobroker.admin/node_modules/tweetnacl
                                  - bcrypt-pbkdf@1.0.1 node_modules/iobroker.admin/node_modules/bcrypt-pbkdf
                                  - sshpk@1.13.1 node_modules/iobroker.admin/node_modules/sshpk
                                  - type-is@1.6.15 node_modules/iobroker.admin/node_modules/type-is
                                  - uid-safe@2.1.5 node_modules/iobroker.admin/node_modules/uid-safe
                                  - ultron@1.0.2 node_modules/iobroker.admin/node_modules/ultron
                                  - ws@1.1.2 node_modules/iobroker.admin/node_modules/engine.io-client/node_modules/ws
                                  - unpipe@1.0.0 node_modules/iobroker.admin/node_modules/unpipe
                                  - finalhandler@1.1.0 node_modules/iobroker.admin/node_modules/finalhandler
                                  - raw-body@2.3.2 node_modules/iobroker.admin/node_modules/raw-body
                                  - body-parser@1.18.2 node_modules/iobroker.admin/node_modules/body-parser
                                  - utils-merge@1.0.1 node_modules/iobroker.admin/node_modules/utils-merge
                                  - express-session@1.15.6 node_modules/iobroker.admin/node_modules/express-session
                                  - uuid@3.1.0 node_modules/iobroker.admin/node_modules/uuid
                                  - vary@1.1.2 node_modules/iobroker.admin/node_modules/vary
                                  - express@4.16.2 node_modules/iobroker.admin/node_modules/express
                                  - verror@1.10.0 node_modules/iobroker.admin/node_modules/verror
                                  - jsprim@1.4.1 node_modules/iobroker.admin/node_modules/jsprim
                                  - http-signature@1.2.0 node_modules/iobroker.admin/node_modules/http-signature
                                  - request@2.83.0 node_modules/iobroker.admin/node_modules/request
                                  - wrappy@1.0.2 node_modules/iobroker.admin/node_modules/wrappy
                                  - once@1.4.0 node_modules/iobroker.admin/node_modules/once
                                  - inflight@1.0.6 node_modules/iobroker.admin/node_modules/inflight
                                  - glob@7.1.2 node_modules/iobroker.admin/node_modules/glob
                                  - rimraf@2.6.2 node_modules/iobroker.admin/node_modules/rimraf
                                  - fs-extra@0.22.1 node_modules/iobroker.admin/node_modules/fs-extra
                                  - express-fileupload@0.1.4 node_modules/iobroker.admin/node_modules/express-fileupload
                                  - ws@1.1.4 node_modules/iobroker.admin/node_modules/ws
                                  - wtf-8@1.0.0 node_modules/iobroker.admin/node_modules/wtf-8
                                  - engine.io-parser@1.3.2 node_modules/iobroker.admin/node_modules/engine.io-parser
                                  - engine.io@1.8.4 node_modules/iobroker.admin/node_modules/engine.io
                                  - xmlhttprequest-ssl@1.5.3 node_modules/iobroker.admin/node_modules/xmlhttprequest-ssl
                                  - xtend@4.0.1 node_modules/iobroker.admin/node_modules/xtend
                                  - passport.socketio@3.7.0 node_modules/iobroker.admin/node_modules/passport.socketio
                                  - yeast@0.1.2 node_modules/iobroker.admin/node_modules/yeast
                                  - engine.io-client@1.8.4 node_modules/iobroker.admin/node_modules/engine.io-client
                                  - socket.io-client@1.7.4 node_modules/iobroker.admin/node_modules/socket.io-client
                                  - socket.io@1.7.4 node_modules/iobroker.admin/node_modules/socket.io
                                  iobroker.inst@1.0.3 /home/pi
                                  pi@ioBroker-Pi3:~ $ sudo iobroker upload admin
                                  pi@ioBroker-Pi3:~ $ sudo iobroker start
                                  Starting iobroker controller daemon...
                                  iobroker controller daemon started. PID: 784
                                  nur ist wohl noch was mit dem admin adapter.
                                  OH ich glaub ich hab im falschen verzeichnis installiert. wenn icih wieder im iobroker Verzeichnis bin kommen wieder die Warnmeldungen
                                    @dippi:
                                    OH ich glaub ich hab im falschen verzeichnis installiert. `
                                    Das wäre meine nächste Frage gewesen.
                                    Dann hast du zweimal iobroker drauf und das gibt natürlich Probleme.
                                    Hast du ein aktuelles backup?
                                      ne leider nicht, aber hab noch nicht so viel im Iobroker drin bin erst am anfang.
                                      Scheint nach einer neu install auszusehen.
                                        @dippi:
                                        Scheint nach einer neu install auszusehen. `
                                        Wäre wahrscheinlich das einfachste 😞
                                          alles klar, trozdem vielen Dank für die Unterstüzung
                                          Dippi
                                          2277
