    4. [Vorlage Blockly] Wunderground Upload
      D12A13 @Linedancer last edited by
      @Linedancer danke für die Vorlage.
      Ich habe es mir einmal angepasst und wieder importierbar gemacht, falls Ihr auch ein Blockly script haben wollt.
        <variables>
          <variable id="y0*3*6I2Yi,CF`]M~h[2">ID</variable>
          <variable id="M#rIoys:i17;BN8w{52D">PWD</variable>
          <variable id="_g}m6=-Y!_;d_q6.nYj%">windspeed_mph</variable>
          <variable id="t_Uq913Tw~AGFBze$7A[">rain_in</variable>
          <variable id="Y0[w@0OIDX^XCUp|haUU">rain_daily</variable>
          <variable id="?SVbcJ?1**tBw$l1~Xh`">baro_in</variable>
          <variable id="!]N$0-~^=*se;mdt~|GV">Aussentemp_F</variable>
          <variable id="ac2QCA3id7.c|WGkY8U-">Taupunkt_F</variable>
          <variable id="L[-9VuA$TtC{}Aw7Z_4t">url</variable>
          <variable id="qYP~o]}86Ah?{kkywtVa">result</variable>
        </variables>
        <block type="schedule" id="NVQ4`W#p(8mnMqzc.so@" x="338" y="12">
          <field name="SCHEDULE">*/2 * * * *</field>
            <block type="create" id="Ryy@[}Z8I!]_}]:y!y#Z">
              <field name="NAME">javascript.0.WEATHERMAN.Last_Wunderground_upload</field>
                <block type="variables_set" id="J6pfV3Pv:-PcV-U8o3e(">
                  <field name="VAR" id="y0*3*6I2Yi,CF`]M~h[2">ID</field>
                    <block type="text" id="4o}!@aUA-7n3A_,+!Zf=">
                      <field name="TEXT">ID</field>
                    <block type="variables_set" id="lNS})+2:]k7-.RJdgaeC">
                      <field name="VAR" id="M#rIoys:i17;BN8w{52D">PWD</field>
                        <block type="text" id="*`IA18YFG:Rqdhs/%lt.">
                          <field name="TEXT">PW</field>
                        <block type="variables_set" id="IuV!Ik{*|@RQ?@o@p54s">
                          <field name="VAR" id="_g}m6=-Y!_;d_q6.nYj%">windspeed_mph</field>
                            <block type="math_rndfixed" id=")Nr+l:1Yegww1EF#^trH">
                              <field name="n">2</field>
                              <value name="x">
                                <shadow type="math_number" id="vN~A3f_oOWr=sNCfrH;w">
                                  <field name="NUM">3.1234</field>
                                <block type="math_arithmetic" id="Hr]VNoyEq)zWSA3Ov.!B">
                                  <field name="OP">DIVIDE</field>
                                    <shadow type="math_number" id="y8`^YX%BoO1CEijv?e;J">
                                      <field name="NUM">1.60934</field>
                                    <block type="get_value" id="PcDIA^0^.^0!CyEyQ%Ih">
                                      <field name="OID">hm-rpc.0.OEQ1864642.1.WIND_SPEED</field>
                                    <shadow type="math_number" id="Q-V3X%h4_JnJ%4vwTwe(">
                            <block type="comment" id="[|mfN)utM;gIrF5{Q{r2">
                              <field name="COMMENT">mph instantaneous wind speed</field>
                                <block type="variables_set" id=")G^m+8#;HudLoG-nk7to" disabled="true">
                                  <field name="VAR" id="t_Uq913Tw~AGFBze$7A[">rain_in</field>
                                    <block type="math_rndfixed" id="Twaj.z}A5()!7aQJ,x;-">
                                      <value name="x">
                                        <shadow type="math_number">
                                        <block type="math_arithmetic" id="EJ:zeKou)@z-Z2-COK:-">
                                              <field name="NUM">3.937</field>
                                            <block type="get_value" id="loyLQaYwd;tGF{H~%?S_">
                                              <field name="OID">hm-rpc.0.OEQ1864642.1.RAINING</field>
                                            <shadow type="math_number" id="P86!-zN:C~XagS8aI*Rh">
                                              <field name="NUM">25.4</field>
                                    <block type="comment" id="b4+*^4yIKMi*J_4;%E.Q">
                                      <field name="COMMENT">rain inches over the past hour</field>
                                        <block type="variables_set" id="KavP@R0V/~7;G^;G/*lE">
                                          <field name="VAR" id="Y0[w@0OIDX^XCUp|haUU">rain_daily</field>
                                            <block type="math_rndfixed" id="(FWK!~Yi~,OS$aLgb+q$">
                                              <value name="x">
                                                <shadow type="math_number" id="KgBvBA!Ys-8Vr-zwC)Gu">
                                                <block type="math_arithmetic" id="xx2y4{FP^qg).tBzcw4i">
                                                    <shadow type="math_number" id="q}Qu!!A_q*bMo2]/6npC">
                                                    <block type="get_value" id="{OwS|_!RcuS#gd9I7dYB">
                                                      <field name="OID">hm-rega.0.22943</field>
                                                    <shadow type="math_number" id="mZ)Ma|[J(lS$pA]lv,ZD">
                                            <block type="comment" id="p9gJJn~3#ucjv)%.FfXj">
                                              <field name="COMMENT">rain inches so far today in local time</field>
                                                <block type="variables_set" id="2o.mspN{c2VuYMvet|^e">
                                                  <field name="VAR" id="?SVbcJ?1**tBw$l1~Xh`">baro_in</field>
                                                    <block type="math_rndfixed" id="j+z|al.?V$$Se*GaQ7Z*">
                                                      <field name="n">4</field>
                                                      <value name="x">
                                                        <shadow type="math_number" id="EVsQxzS+I0ET:Yeyzo_!">
                                                        <block type="math_arithmetic" id="IOs;[N;fdtiNHk2GC:3K">
                                                            <shadow type="math_number" id="X-R?36spX2@GhM+Bhih[">
                                                              <field name="NUM">0.0295301</field>
                                                            <block type="get_value" id="yuXUY_6Kz%x6D2742NaL">
                                                              <field name="OID">hm-rpc.0.NEQ0544128.10.AIR_PRESSURE</field>
                                                            <shadow type="math_number" id="m%SnK7;T58uvrpj1Kq/X">
                                                              <field name="NUM">33.8639</field>
                                                    <block type="comment" id="?gZQ[RcS)+@Y[Ah|r|T=">
                                                      <field name="COMMENT">barometric pressure inches</field>
                                                        <block type="variables_set" id="}ZNtE{YDT~uH^(9oC@uJ">
                                                          <field name="VAR" id="!]N$0-~^=*se;mdt~|GV">Aussentemp_F</field>
                                                            <block type="math_rndfixed" id="@/~BOZH,*T=u;l?1:3Vq">
                                                              <value name="x">
        <shadow type="math_number" id="Fn`edZw$aNhYzWP(UbBY">
        <block type="math_arithmetic" id="~)9T~(f~8P[fqQ+zVlzZ">
        <field name="OP">ADD</field>
        <shadow type="math_number" id="%PDN|YJ@naL)yZi3QAvx">
        <field name="NUM">1</field>
        <block type="math_arithmetic" id="c,;et0f(JDhiPflCEvQ~">
        <shadow type="math_number" id="#wm=O,l0nAF9wv.iOX11">
        <field name="NUM">1.8</field>
        <block type="get_value" id="qOqzkEcqx~:Aulh^61Hv">
        <field name="OID">hm-rpc.0.OEQ1864642.1.TEMPERATURE</field>
        <shadow type="math_number" id="pYs?t#+euS,=;_ewnVvA">
        <shadow type="math_number" id="j*@d,/*5vtdrrXk|~.Eh">
        <field name="NUM">32</field>
                                                            <block type="comment" id="$wwhg|u6gN%RPi*}b?QL">
                                                              <field name="COMMENT">F outdoor temperature</field>
        <block type="variables_set" id="Knc[}47D!:t{BiPPIyJ:">
        <field name="VAR" id="ac2QCA3id7.c|WGkY8U-">Taupunkt_F</field>
        <block type="math_rndfixed" id="!5=YyjNY*^/{6H5Vq!*t">
        <value name="x">
        <block type="math_arithmetic" id="m@.@N{d2^z2,pWl!#Y/Z">
        <block type="math_arithmetic" id="T9Zak.4H!|p9Dz%/2Q*7">
        <block type="get_value" id="5RZwE.v6`GbvVn~}pscq">
        <field name="OID">hm-rega.0.39443</field>
        <shadow type="math_number" id="5qN=4(xR43jIk`U_eaIz">
        <shadow type="math_number" id="2l~{%NSZ-_q6yG.n/PMH">
        <block type="comment" id="/_WCHMB2m5G]4-OEzOFc">
        <field name="COMMENT">F outdoor dewpoint F</field>
        <block type="variables_set" id="(..4D@D}1bg(~)~wtU]Y">
        <field name="VAR" id="L[-9VuA$TtC{}Aw7Z_4t">url</field>
        <block type="text_join" id="(`%c8pO+2VPBopp8V2uE">
        <mutation items="21"></mutation>
        <value name="ADD0">
        <block type="text" id="Q!k*6kwCyW4I4Cz|wd@P">
        <field name="TEXT">https://weatherstation.wunderground.com/weatherstation/updateweatherstation.php?ID=</field>
        <value name="ADD1">
        <block type="variables_get" id="xj,x#Q6z02@Ne;(-k1!A">
        <value name="ADD2">
        <block type="text" id=".T_p}5;J!Dc{8-CNah?H">
        <field name="TEXT">&amp;PASSWORD=</field>
        <value name="ADD3">
        <block type="variables_get" id="fx56Av]MfZot/a{Dmc|{">
        <value name="ADD4">
        <block type="text" id="?bO.l@nfrfe/i5II,y7O">
        <field name="TEXT">&amp;dateutc=now&amp;winddir=</field>
        <value name="ADD5">
        <block type="get_value" id="_:4@dKfy1.kKNK8pTkt|">
        <field name="OID">hm-rpc.0.OEQ1864642.1.WIND_DIRECTION</field>
        <value name="ADD6">
        <block type="text" id="RhOt)(e[UY[^%b7r.[.{">
        <field name="TEXT">&amp;windspeedmph=</field>
        <value name="ADD7">
        <block type="variables_get" id="9E;ZOzzC~ZqX=C:x/GjB">
        <value name="ADD8">
        <block type="text" id="XCSzJxAajajF*^G=U3QM">
        <field name="TEXT">&amp;baromin=</field>
        <value name="ADD9">
        <block type="variables_get" id="Jy|66pdKM[;Ymn@O]cSc">
        <value name="ADD10">
        <block type="text" id="av~BQ)iAy6I1n{#25:+N" disabled="true">
        <field name="TEXT">&amp;rainin=</field>
        <value name="ADD11">
        <block type="variables_get" id="/*W]fWFF=nd;?[h@:Y]:" disabled="true">
        <value name="ADD12">
        <block type="text" id="hQzg`g3NFN@z%M290qg5">
        <field name="TEXT">&amp;humidity=</field>
        <value name="ADD13">
        <block type="get_value" id="c8]Z},O.#(X:^fh8BQDR">
        <field name="OID">hm-rpc.0.OEQ1864642.1.HUMIDITY</field>
        <value name="ADD14">
        <block type="text" id="(b%5Hm@:BUeV)lr3NKjd">
        <field name="TEXT">&amp;tempf=</field>
        <value name="ADD15">
        <block type="variables_get" id="EY.SScRsM@YGFg^QlVM-">
        <value name="ADD16">
        <block type="text" id="uY~}7_2RK10$YisP5]Bt">
        <field name="TEXT">&amp;dailyrainin=</field>
        <value name="ADD17">
        <block type="variables_get" id="kIjIuh}xDg+=O7c?Ujk}">
        <value name="ADD18">
        <block type="text" id="RP}t]iGo4~kAFBDlLtMn">
        <field name="TEXT">&amp;dewptf=</field>
        <value name="ADD19">
        <block type="variables_get" id="DHDV?62iQQ_nxWXc];[Y">
        <value name="ADD20">
        <block type="text" id="{}f?h+FLZDi[/K#P`3C]">
        <field name="TEXT">&amp;action=updateraw</field>
        <block type="request" id="@DtdK@NaHfPFifwX2)9Z">
        <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="true"></mutation>
        <field name="WITH_STATEMENT">TRUE</field>
        <field name="LOG"></field>
        <value name="URL">
        <shadow type="text" id="M(AOk0tWYIWcpx2bEYJ.">
        <block type="variables_get" id="vr9m*ZXavDVMWFaR_iN[">
        <block type="controls_if" id="=dHWKib4(|bqIz[deQxp">
        <block type="logic_compare" id="3^Or==q!t};6PCe3yo3a">
        <field name="OP">GT</field>
        <block type="text_indexOf" id="M6}Pr%6[L-p@i:~0v:uR">
        <field name="END">FIRST</field>
        <block type="variables_get" id=";r~4V,}SMS,3}E((4rq:">
        <field name="VAR" id="qYP~o]}86Ah?{kkywtVa">result</field>
        <value name="FIND">
        <shadow type="text" id="B[@H~FSpM_!7B}%5XsAX">
        <field name="TEXT">false</field>
        <block type="telegram" id="^383WMpd;gqr;Wqg5TmX">
        <field name="INSTANCE">.0</field>
        <value name="MESSAGE">
        <shadow type="text" id="DJA?*T2{EtJM?Vy#zZN.">
        <field name="TEXT">Der Wunderground Upload ist fehlgeschlagen</field>
        <statement name="ELSE">
        <block type="update" id="Dhlt1isqfpkSs@W+g!TB">
        <field name="OID">javascript.0.WEATHERMAN.Last_Wunderground_upload</field>
        <block type="time_get" id="G8N-|m^zK#|]1Jy2XHa9">
        <mutation xmlns="http://www.w3.org/1999/xhtml" format="true" language="false"></mutation>
        <field name="OPTION">custom</field>
        <field name="FORMAT">TT.MM, SS:mm:ss</field>
      C 1 Reply Last reply Reply Quote 1
        c1olli @D12A13 last edited by
        mir zeigt Javascript den Block "Request" als veraltet an.
        Hat jemand das evtl. schon umgebaut?
          crunchip Forum Testing Most Active @c1olli last edited by
          @c1olli so wie hier ändern
          https://forum.iobroker.net/post/1162752
            c1olli @crunchip last edited by
            @crunchip
            Das hatte ich schon vorher ausprobiert, aber leider kamen danach Fehlermeldungen.
            Liegt auch daran, dass ich die Logik dahinter nicht verstehe.
              c1olli @c1olli last edited by
              Das sind die Fehlermeldungen
              javascript.0
              2024-05-26 14:38:00.369	error	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2024-05-26 14:38:00.369	error	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1190:38
              javascript.0
              2024-05-26 14:38:00.369	error	at Object.<anonymous> (script.js.common.Wetter_Homeatic:27:16)
              javascript.0
              2024-05-26 14:38:00.369	error	script.js.common.Wetter_Homeatic: TypeError: Cannot read properties of undefined (reading 'indexOf')
              javascript.0
              2024-05-26 14:36:00.359	error	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2024-05-26 14:36:00.359	error	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1190:38
              javascript.0
              2024-05-26 14:36:00.359	error	at Object.<anonymous> (script.js.common.Wetter_Homeatic:27:16)
              javascript.0
              2024-05-26 14:36:00.359	error	script.js.common.Wetter_Homeatic: TypeError: Cannot read properties of undefined (reading 'indexOf')
              javascript.0
              2024-05-26 14:34:00.389	error	at processTicksAndRejections (node:internal/process/task_queues:95:5)
              javascript.0
              2024-05-26 14:34:00.389	error	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1190:38
              javascript.0
              2024-05-26 14:34:00.389	error	at Object.<anonymous> (script.js.common.Wetter_Homeatic:27:16)
              javascript.0
              2024-05-26 14:34:00.388	error	script.js.common.Wetter_Homeatic: TypeError: Cannot read properties of undefined (reading 'indexOf')
                @c1olli zeig doch mal das Blockly
                  @crunchip
                  Es war das obere Script, aber nun funktioniert nichts mehr und das erste Script lässt sich auch nicht mehr importieren.
                  Es geht nur darum die die Wetterdaten von meiner Homeatic Wetterstation zu Wonderground hochzuladen.
                    crunchip Forum Testing Most Active @c1olli last edited by crunchip
                    @c1olli sagte in [Vorlage Blockly] Wunderground Upload:
                    mir schon klar, dein geändertes sollst du zeigen
                      @crunchip
                      Ich weiss nicht was ich gemacht habe, aber es läuft wieder, aber Fehlermeldungen kommen immer noch.
                      Hier das Script: (blockly export)
                        <variables>
                        </variables>
                        <block type="schedule" id="NVQ4`W#p(8mnMqzc.so@" x="28" y="56">
                                      <field name="TEXT">xxxxxx</field>
                                          <field name="TEXT">xxxxx</field>
                                              <value name="x">
                                                      <field name="OID">alias.0.Wetter.Windgeschwindigkeit</field>
                                                <block type="variables_set" id=")G^m+8#;HudLoG-nk7to">
                                                      <value name="x">
                                                        <shadow type="math_number" id="{P6Og~1k=Pd=tt)}|/e}">
                                                            <shadow type="math_number" id="(Vv26H}x0lkP`+Ono/*~">
                                                              <field name="OID">alias.0.Wetter.Regenmenge_Heute</field>
                                                              <value name="x">
        <field name="OID">alias.0.Wetter.Regen_Gestern</field>
        <value name="x">
        <field name="OID">alias.0.Wetter.Luftdruck</field>
        <value name="x">
        <field name="OID">alias.0.Wetter.Aktuelle_Temperatur</field>
        <value name="x">
        <shadow type="math_number" id="Ylxb+}~1N:%JSN9:F%Wt">
        <shadow type="math_number" id="R9pFQUxb@:t@(9z*L/*S">
        <shadow type="math_number" id="jr=|Q#kfdxO06J8TbJ_C">
        <field name="OID">0_userdata.0.Taupunkt</field>
        <value name="ADD0">
        <value name="ADD1">
        <value name="ADD2">
        <value name="ADD3">
        <value name="ADD4">
        <value name="ADD5">
        <field name="OID">hmip.0.devices.3014F711A0001860C98C9DF5.channels.1.windDirection</field>
        <value name="ADD6">
        <value name="ADD7">
        <value name="ADD8">
        <value name="ADD9">
        <field name="OID">alias.0.Wetter.Luftfeuchtigkeit</field>
        <block type="http_get" id="r)o6iKOUDP=*(Z5f66A;">
        <field name="TIMEOUT">2000</field>
        <field name="UNIT">ms</field>
        <field name="TYPE">text</field>
        <value name="URL">
        <shadow type="text" id="rjYmYz$A(1M]GVp-gGdp">
        <field name="TEXT">http://</field>
        <value name="FIND">
                      Fehlermeldung:
                      javascript.0
                      2024-05-26 18:34:00.347	error	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                      javascript.0
                      2024-05-26 18:34:00.347	error	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1190:38
                      javascript.0
                      2024-05-26 18:34:00.347	error	at Object.<anonymous> (script.js.common.Wetter_Homeatic_2:27:16)
                      javascript.0
                      2024-05-26 18:34:00.347	error	script.js.common.Wetter_Homeatic_2: TypeError: Cannot read properties of undefined (reading 'indexOf')
                      javascript.0
                      2024-05-26 18:32:00.452	error	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                      javascript.0
                      2024-05-26 18:32:00.452	error	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1190:38
                      javascript.0
                      2024-05-26 18:32:00.452	error	at Object.<anonymous> (script.js.common.Wetter_Homeatic_2:27:16)
                      javascript.0
                      2024-05-26 18:32:00.452	error	script.js.common.Wetter_Homeatic_2: TypeError: Cannot read properties of undefined (reading 'indexOf')
                      javascript.0
                      2024-05-26 18:30:00.447	error	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                      javascript.0
                      2024-05-26 18:30:00.447	error	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1190:38
                      javascript.0
                      2024-05-26 18:30:00.447	error	at Object.<anonymous> (script.js.common.Wetter_Homeatic_2:27:16)
                      javascript.0
                      2024-05-26 18:30:00.446	error	script.js.common.Wetter_Homeatic_2: TypeError: Cannot read properties of undefined (reading 'indexOf')
                      javascript.0
                      2024-05-26 18:28:00.634	error	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                      javascript.0
                      2024-05-26 18:28:00.634	error	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1190:38
                      javascript.0
                      2024-05-26 18:28:00.634	error	at Object.<anonymous> (script.js.common.Wetter_Homeatic_2:27:16)
                      javascript.0
                      2024-05-26 18:28:00.633	error	script.js.common.Wetter_Homeatic_2: TypeError: Cannot read properties of undefined (reading 'indexOf')
                        @c1olli zeig es mal als screen
                          @crunchip
                          Siehe PDFblocklyhomatic.pdf
                          haus-automatisierung Homoran 2 Replies Last reply Reply Quote 0
                          • haus-automatisierung
                            haus-automatisierung Developer Most Active @c1olli last edited by
                            @c1olli Größer als was? 0 wahrscheinlich?
                              Homoran Global Moderator Administrators @c1olli last edited by
                              @c1olli wieso pdf?
                              Bilder bitte hier mit der Uploadfunktion für Bilder einbinden
                                Homoran Global Moderator Administrators @haus-automatisierung last edited by
                                @haus-automatisierung sagte in [Vorlage Blockly] Wunderground Upload:
                                und auch nicht result sondern Data
                                haus-automatisierung C 2 Replies Last reply Reply Quote 0
                                  haus-automatisierung Developer Most Active @Homoran last edited by
                                  @homoran Stimmt, habe gar nicht weiter geschaut als ich den halbfertigen Block gesehen hab 🙂
                                    c1olli @Homoran last edited by
                                    Hab es als Bild nicht hinbekommen.
                                      Ich habe die Änderungen durchgeführt, aber leider ist es das nicht allein.
                                      javascript.0
                                      2024-05-27 12:06:00.437	error	at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      javascript.0
                                      2024-05-27 12:06:00.437	error	at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1190:38
                                      javascript.0
                                      2024-05-27 12:06:00.437	error	at Object.<anonymous> (script.js.common.Wetter_Homeatic_2:27:5)
                                      javascript.0
                                      2024-05-27 12:06:00.437	error	script.js.common.Wetter_Homeatic_2: ReferenceError: data is not defined
                                        Du hast den falschen "Data-Block" genommen. Der ist für Datei-Operationen gedacht. Ich hatte durch das Icon eigentlich probiert, zusammengehörige Blöcke zu kennzeichnen.
                                        Daher ist davor ja auch ein Ausrufezeichen / eine Warnung. Auch das bringt ja scheinbar nichts das anzuzeigen 😞 Langsam verzweifle ich noch
                                        C 1 Reply Last reply Reply Quote 2
                                          falsches Data
                                            c1olli @haus-automatisierung last edited by
                                            Woran verzweifeln? An mir? Ich hatte doch geschrieben, das ich nicht wirklich fit im Blockly bin. Mich wundert nur, dass es bisher ohne Fehlermeldung funktioniert hat und jetzt beim Austausch des einen Blocks zickt es rum.
                                            Wo finde finde ich denn das richtige Data? Unter Variablen hab ich einen Data Block erstellt, aber das bringt die gleiche Fehlermeldung
                                            5115
