    4. JavaScript
    5. Hilfe für Javascript Legastheniker und js v8.3.x
    • O
      oFbEQnpoLKKl6mbY5e13 @haus-automatisierung last edited by oFbEQnpoLKKl6mbY5e13
      Könntest du bitte trotz Trashschedule-Adapter helfen, das Skript auf httpGet umzustellen?
      Mein aktueller Stand:
      const city_id = XXXXX;
      const area_id = XXX;
      const logging = false;
      const name = 'Müllabfuhr';
      const numberOfEntries = 69;
      const instanz = '0_userdata.' + instance + '.muell-test';
      if (logging) log('starting muell.' + instanz);
      extendObject(instanz, {
             type: "device",
             common: {
         }, function (err) {
             if (err) {
                 log('could not create device: ', 'warn');
                 return;
      let baseData = {};
      // query names first
      httpGet('https://mymuell.jumomind.com/mmapp/api.php?r=trash&city_id=' + city_id + '&area_id=' + area_id, { timeout: 2000 }, (error, response) => {
         if (!error && response.data == 200) {
             console.log(response.statusCode);
             console.log(response.data);
         } else {
             console.error(error);
         var data = JSON.parse(response.data);  // info ist ein Objekt
                 data.forEach((v, i) => {
                     baseData[v._name] = v;
         updateMuell();
      schedule('{"time":{"exactTime":true,"start":"12:17"},"period":{"days":1}}', updateMuell);
      function updateMuell() {
         var options = 'https://mymuell.jumomind.com/webservice.php?idx=termins&city_id=' + city_id + '&area_id=' + area_id + '&ws=3'
         httpGet(options), (error, response)
                 var info = JSON.parse(response.data);  // info ist ein Objekt
                 if (info[0].Ack === 'Success') {
                     var data = info[0]._data;  // xy ist eine Eigenschaft des Objektes info
                     let counter = 0;
                     const date = (new Date())
                     const todayStr = date.getFullYear() + "-" + ('00' + (date.getMonth() + 1 )).slice(-2) + "-" + ('00' + date.getDate()).slice(-2)
                     log(todayStr);
                         if (todayStr < v.cal_date && counter <= numberOfEntries) {
                             const basePath = instanz + '.' + ('000' + counter).slice(-3);
                             log(v.cal_date + ' -> ' + basePath, 'debug');
                             // States erstellen
                             extendObject(basePath, {
                                     type: "channel",
                                     common: {
                                 }, function (err) {
                                     if (err) {
                                         return;
                             createState(basePath + '.date', v.cal_date_normal, {
                                 desc: 'Datum der Abholung',
                                 type: 'string',
                                 read: true,
                                 write: false
                                 setState(basePath + '.date', v.cal_date_normal, true);
                             createState(basePath + '.desc', baseData[v.cal_garbage_type].title, {
                                 desc: 'Beschreibung der Abholung',
                                 type: 'string',
                                 read: true,
                                 write: false
                                 setState(basePath + '.desc', baseData[v.cal_garbage_type].title, true);
                             createState(basePath + '.color', {
                                 desc: 'Farbe',
                                 type: 'string',
                                 role: 'level.color',
                                 read: true,
                                 write: false
                                 setState(basePath + '.color', baseData[v.cal_garbage_type].color, true);
                             counter++;
      2024-05-26 18:33:57.582  - info: javascript.0 (3416) Start JavaScript script.js.common._Tests.Test_17 (JavaScript/js)
      2024-05-26 18:33:57.614  - info: javascript.0 (3416) script.js.common._Tests.Test_17: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
      2024-05-26 18:33:57.705  - error: javascript.0 (3416) script.js.common._Tests.Test_17: null
      2024-05-26 18:33:57.707  - error: javascript.0 (3416) Error in callback: TypeError: Cannot read properties of undefined (reading 'headers')
      2024-05-26 18:33:57.708  - error: javascript.0 (3416)     at getHttpRequestConfig (/opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:139:18)
      2024-05-26 18:33:57.708  - error: javascript.0 (3416)     at httpGet (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1179:20)
      2024-05-26 18:33:57.708  - error: javascript.0 (3416)     at updateMuell (script.js.common._Tests.Test_17:47:5)
      2024-05-26 18:33:57.709  - error: javascript.0 (3416)     at Object.<anonymous> (script.js.common._Tests.Test_17:38:5)
      2024-05-26 18:33:57.709  - error: javascript.0 (3416)     at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1189:38
      2024-05-26 18:33:57.709  - error: javascript.0 (3416)     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      2024-05-26 18:33:59.284  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
      T Homoran 2 Replies Last reply Reply Quote 0
        TT-Tom @oFbEQnpoLKKl6mbY5e13 last edited by
        @ofbeqnpolkkl6mby5e13
        response.data sind deine Daten die zurückkommen, die wirst du nicht auf den Status prüfen wollen.
        Da müsste also response.statusCode stehen.
        O Homoran 2 Replies Last reply Reply Quote 0
        • O
          oFbEQnpoLKKl6mbY5e13 @TT-Tom last edited by oFbEQnpoLKKl6mbY5e13
          @tt-tom
          Okay, danke, das klingt plausibel. Habe ich angepasst.
          Edit:
          Damit ist der Fehler weg, aber die Objektstruktur wird nicht angelegt. Nur der oberste Ordner Muell-Test.
          Auf der Konsole werden Infos ausgegeben, die das alte Skript nicht ausgibt:
          2024-05-26 20:13:44.259  - info: javascript.0 (3416) Start JavaScript script.js.common._Tests.Test_17 (JavaScript/js)
          2024-05-26 20:13:44.302  - info: javascript.0 (3416) script.js.common._Tests.Test_17: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
          2024-05-26 20:13:44.397  - info: javascript.0 (3416) script.js.common._Tests.Test_17: 200
          2024-05-26 20:13:44.398  - info: javascript.0 (3416) script.js.common._Tests.Test_17: [{"title":"Bioabfall","name":"SZ_BIO","_name":"SZ_BIO","color":"a52a2a"},{"title":"Gelber Sack","name":"SZ_G","_name":"SZ_G","color":"FFFF00"},{"title":"Altpapier (120l, 240l)","name":"SZ_P","_name":"SZ_P","color":"2fc2e8"},{"title":"Restabfall (bis 240l)","name":"SZ_R","_name":"SZ_R","color":"2F4F4F"},{"title":"Weihnachtsbaum","name":"SZ_W","_name":"SZ_W","color":"36b515"}]
          2024-05-26 20:14:15.701  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
            Homoran Global Moderator Administrators @TT-Tom last edited by Homoran
            @tt-tom sorry dass ich hier nochmal reingrätsche.
            Ich hab ein altes wiffi-script auch noch umbauen wollten und natürlich nicht hinbekommen. Größenwahnsinnig wie ich durch die ersten Erfolge geworden bin hab ich natürlich duesmal keine Kopie erstellt.
            Also den Rat von @haus-automatisierung beherzigt und mal eben versucht das ganze in Blockly nachzubauen.
            nach gefühlten Stunden kopieren und konfigurieren von Blöcken hatte ich die Hauptfunktion laufen.
            Jetzt kommt immer wieder timeout überschritten, cannot get vars of null
            wie fange ich error im Blockly ab?
            if !error....
              Bin leider nur am Handy unterwegs, kann aber nachher nochmal nachschauen. Aber auf error prüfen ist schon mal die richtige Richtung. Wie sieht das Blockly denn in JS aus.
                TT-Tom @oFbEQnpoLKKl6mbY5e13 last edited by TT-Tom
                Hast du auch beide Zeilen angepasst? Der Fehler kam zweimal vor. Zeile 47 glaube ich
                  @tt-tom sagte in Hilfe für Javascript Legastheniker und js v8.3.x:
                  danke schonmal. hab jetzt als erste Hilfe den Timeout hochgesetzt.
                  ist nur ein gaaanz kleiner Teil des Originals
                  schedule("*/4 * * * *", async () => {
                    httpGet('http://192.168.138.62/?json:', { timeout: 4000, responseType: 'text' }, async (err, response) => {
                      if (err) {
                        console.error(err);
                      setState('javascript.1.WIFFI.Systeminfo.ip_Homematic_CCU' /* ip_Homematic_CCU */, getAttr(response.data, 'vars.0.value'), true);
                      setState('javascript.1.WIFFI.wz_co2' /* Luftqualitaet */, getAttr(response.data, 'vars.1.value'), true);
                      setState('javascript.1.WIFFI.wz_temp' /* Temperatur */, getAttr(response.data, 'vars.2.value'), true);
                      setState('javascript.1.WIFFI.wz_feuchte' /* Luftfeuchte */, getAttr(response.data, 'vars.3.value'), true);
                      setState('javascript.1.WIFFI.wz_taupunkt' /* Taupunkt */, getAttr(response.data, 'vars.4.value'), true);
                      setState('javascript.1.WIFFI.wz_feuchte_abs' /* Absolutfeuchte */, getAttr(response.data, 'vars.5.value'), true);
                      setState('javascript.1.WIFFI.wz_baro' /* Luftdruck */, getAttr(response.data, 'vars.6.value'), true);
                      setState('javascript.1.WIFFI.wz_luftdrucktrend' /* Luftdrucktrend */, getAttr(response.data, 'vars.7.value'), true);
                      setState('javascript.1.WIFFI.wz_lux' /* Helligkeit */, getAttr(response.data, 'vars.8.value'), true);
                      setState('javascript.1.WIFFI.wz_motion_left' /* Bewegung links */, getAttr(response.data, 'vars.9.value'), true);
                      setState('javascript.1.WIFFI.wz_motion_right' /* Bewegung rechts */, getAttr(response.data, 'vars.10.value'), true);
                      setState('javascript.1.WIFFI.wz_noise' /* Geraeusch */, getAttr(response.data, 'vars.12.value'), true);
                      setState('javascript.1.WIFFI.wz_elevation' /* Sonne-Elevation */, getAttr(response.data, 'vars.13.value'), true);
                      setState('javascript.1.WIFFI.wz_azimut' /* Sonne-Azimut */, getAttr(response.data, 'vars.14.value'), true);
                      setState('javascript.1.WIFFI.wz_buzzer' /* Buzzer */, getAttr(response.data, 'vars.15.value'), true);
                  ooh.
                  sehe gerade das ist ja "hard-coded" if (err) {console.error(err);}
                  das kann man dann wohl nicht unterbinden
                    TT-Tom @Homoran last edited by
                    Das ist so richtig, damit du auch eine log-Ausgabe bekommst. Das if-Statement bedeutet soviel wie: Wenn ein Fehler vorliegt, dann schreibe ins Log die Fehlermeldung.
                    Mann könnte jetzt das ganze so um stellen, dass bei einem Fehler keine Auswertung gemacht wird.
                      aber das log wird trotzdem zugemüllt.
                      Allerdings dann (hoffentlich) nur noch mit timeout of x msec exceeded und nicht mehr die ganzen null Meldungen
                      T paul53 2 Replies Last reply Reply Quote 0
                      • O
                        @tt-tom
                        Inzwischen ja. Leider wird weiterhin keine Objektstruktur angelegt. Hier der aktuelle Stand:
                               type: "device",
                               common: {
                           }, function (err) {
                               if (err) {
                                   return;
                        let baseData = {};
                           if (!error && response.statusCode == 200) {
                           } else {
                           updateMuell();
                                       let counter = 0;
                                       log(todayStr);
                                               // States erstellen
                                                       type: "channel",
                                                       common: {
                                                   }, function (err) {
                                                       if (err) {
                                                           return;
                                                   type: 'string',
                                                   read: true,
                                                   write: false
                                                   type: 'string',
                                                   read: true,
                                                   write: false
                                                   desc: 'Farbe',
                                                   type: 'string',
                                                   read: true,
                                                   write: false
                                               counter++;
                          Ja davon gehe aus. Muss mir das aber zu Hause erst anschauen.
                          Wobei der Timeout eventuell auch höher muss, wenn die Daten nicht so schnell da sind.
                            Wie gesagt bin noch am Handy und schaue nachher mir das dann an. Das JSON kommt aber jetzt richtig rein?
                            Setze das mal in Zeile 48 mit rein, damit du sehen kannst was da kommt.
                            Homoran O 2 Replies Last reply Reply Quote 0
                              steht schon in Zeile 30
                              • O
                                @tt-tom
                                Ja, die werden bei jedem Skriptstart im Log ausgegeben, was aber vorher nie so war. Die Objektstruktur wird aber nicht angelegt (nur der Ordner 0_userdata.0.muell-test).
                                • O
                                  oFbEQnpoLKKl6mbY5e13 @Homoran last edited by oFbEQnpoLKKl6mbY5e13
                                  Richtig, aber eigentllich sollte das doch nur bei der Bedingung "if (!error && response.statusCode == 200)" ausgegeben werden.
                                  Edit:
                                  Ach, ich sehe gerade response.statusCode ist auch 200.
                                    Homoran Global Moderator Administrators @oFbEQnpoLKKl6mbY5e13 last edited by
                                    @ofbeqnpolkkl6mby5e13 sagte in Hilfe für Javascript Legastheniker und js v8.3.x:
                                    ich könnte mit meinem begrenzten Wissen höchstens vorstellen dass dies nicht true ist und den Rest unterbindet
                                    • O
                                      Schätze ich auch. Allerdings, wenn ich auf "if (!error && response.statusCode == 400)" ändere, dann kommt wieder:
                                      2024-05-26 21:18:41.065  - info: javascript.0 (3416) Start JavaScript script.js.common._Tests.Test_17 (JavaScript/js)
                                      2024-05-26 21:18:41.115  - info: javascript.0 (3416) script.js.common._Tests.Test_17: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                      2024-05-26 21:18:41.294  - error: javascript.0 (3416) script.js.common._Tests.Test_17: null
                                      2024-05-26 21:18:41.296  - error: javascript.0 (3416) Error in callback: TypeError: Cannot read properties of undefined (reading 'headers')
                                      2024-05-26 21:18:41.297  - error: javascript.0 (3416)     at getHttpRequestConfig (/opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:139:18)
                                      2024-05-26 21:18:41.297  - error: javascript.0 (3416)     at httpGet (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1179:20)
                                      2024-05-26 21:18:41.298  - error: javascript.0 (3416)     at updateMuell (script.js.common._Tests.Test_17:47:5)
                                      2024-05-26 21:18:41.298  - error: javascript.0 (3416)     at Object.<anonymous> (script.js.common._Tests.Test_17:38:5)
                                      2024-05-26 21:18:41.298  - error: javascript.0 (3416)     at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1189:38
                                      2024-05-26 21:18:41.299  - error: javascript.0 (3416)     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      2024-05-26 21:18:48.201  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
                                      Edit:
                                      Ich kann mir inzwischen nicht mehr vorstellen, dass man eine Anleitung erstellen kann, die einem User bei der Umstellung auf httpGet hilft.
                                        Ich habe es noch nicht ganz aufgegeben, sammle noch Daten.
                                        Das fehlende Wissen hat den Vorteil, dass ich die Sache sus der nicht-Programmierer Perspektive sehe.
                                        Den Rest muss ich mit trial & error und "Deduktion lieber Watson" versuchen hinzubekommen
                                        • O
                                          Was mich einfach nachdenklich macht und zweifeln lässt, ist, dass ich durchaus die Umstellung gemacht habe. Dazu habe ich auch https://www.iobroker.net/#en/adapters/adapterref/iobroker.javascript/README.md
                                          genutzt. Ich habe ja nicht einfach danach gefragt, ob mir das jemand bitte umstellen kann, damit ich mich nicht damit beschäftigen muss. Trotzdem tappe ich total im Dunkeln...
                                            @ofbeqnpolkkl6mby5e13 ja, ich will es auch versuchen zu können, wenigstens nachvollziehen.
                                            mir scheint, bei denen wo es nicht klappt ist jedesmal die Funktion readJson (url, function(err, response)) mit beteiligt, wobei der url identisch zu dem httpGet url ist.
                                            das finde ich bei dir jedoch nicht
                                            6466
