    4. JavaScript
    5. Hilfe für Javascript Legastheniker und js v8.3.x
    • O
      oFbEQnpoLKKl6mbY5e13 @paul53 last edited by oFbEQnpoLKKl6mbY5e13
      Danke!
      2024-05-26 22:19:52.596  - info: javascript.0 (3416) Start JavaScript script.js.common._Tests.Test_17 (JavaScript/js)
      2024-05-26 22:19:52.597  - error: javascript.0 (3416) script.js.common._Tests.Test_17 compile failed:
      at script.js.common._Tests.Test_17:118
      2024-05-26 22:19:52.598  - error: javascript.0 (3416) })();
      2024-05-26 22:19:52.598  - error: javascript.0 (3416)  ^
      2024-05-26 22:19:52.598  - error: javascript.0 (3416) SyntaxError: Unexpected token ')'
      2024-05-26 22:19:52.598  - error: javascript.0 (3416)     at new Script (node:vm:99:7)
      2024-05-26 22:19:52.598  - error: javascript.0 (3416)     at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1917:21)
      2024-05-26 22:19:52.599  - error: javascript.0 (3416)     at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2183:37)
      2024-05-26 22:19:52.599  - error: javascript.0 (3416)     at /opt/iobroker/node_modules/iobroker.javascript/main.js:2281:17
      2024-05-26 22:19:52.599  - error: javascript.0 (3416)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1703:17)
      2024-05-26 22:19:52.599  - error: javascript.0 (3416)     at process.processImmediate (node:internal/timers:478:21)
      2024-05-26 22:19:55.316  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
      An welcher Stelle ist die Klammer zu viel?
        @homoran sagte: nur noch mit timeout of x msec exceeded und nicht mehr die ganzen null Meldungen
        Homoran 1 Reply Last reply Reply Quote 2
          paul53 @oFbEQnpoLKKl6mbY5e13 last edited by
          @ofbeqnpolkkl6mby5e13 sagte: An welcher Stelle ist die Klammer zu viel?
          ?? Die komplette Testfunktion:
          httpGet(options, (error, response) => {
              console.log(response.statusCode);
              console.log(response.data);
          • O
            Aber das war nur ein winziger Ausschnitt aus einem größeren Skript:
            const city_id = XXXXX;
            const area_id = XXX;
            const logging = false;
            const name = 'Müllabfuhr';
            const numberOfEntries = 69;
            const instanz = '0_userdata.' + instance + '.muell-test';
            if (logging) log('starting muell.' + instanz);
            extendObject(instanz, {
                   type: "device",
                   common: {
               }, function (err) {
                   if (err) {
                       log('could not create device: ', 'warn');
                       return;
            let baseData = {};
            // query names first
            httpGet('https://mymuell.jumomind.com/mmapp/api.php?r=trash&city_id=' + city_id + '&area_id=' + area_id, { timeout: 2000 }, (error, response) => {
               if (!error && response.statusCode == 200) {
               } else {
                   console.error(error);
               var data = JSON.parse(response.data);  // info ist ein Objekt
                       data.forEach((v, i) => {
                           baseData[v._name] = v;
               updateMuell();
            schedule('{"time":{"exactTime":true,"start":"12:17"},"period":{"days":1}}', updateMuell);
            function updateMuell() {
               var options = 'https://mymuell.jumomind.com/webservice.php?idx=termins&city_id=' + city_id + '&area_id=' + area_id + '&ws=3'
               httpGet(options), (error, response) => {
                   var info = JSON.parse(response.data);  // info ist ein Objekt
                       if (info[0].Ack === 'Success') {
                           var data = info[0]._data;  // xy ist eine Eigenschaft des Objektes info
                           let counter = 0;
                           const date = (new Date())
                           const todayStr = date.getFullYear() + "-" + ('00' + (date.getMonth() + 1 )).slice(-2) + "-" + ('00' + date.getDate()).slice(-2)
                           log(todayStr);
                               if (todayStr < v.cal_date && counter <= numberOfEntries) {
                                   const basePath = instanz + '.' + ('000' + counter).slice(-3);
                                   log(v.cal_date + ' -> ' + basePath, 'debug');
                                   // States erstellen
                                   extendObject(basePath, {
                                           type: "channel",
                                           common: {
                                       }, function (err) {
                                           if (err) {
                                               return;
                                   createState(basePath + '.date', v.cal_date_normal, {
                                       desc: 'Datum der Abholung',
                                       type: 'string',
                                       read: true,
                                       write: false
                                       setState(basePath + '.date', v.cal_date_normal, true);
                                   createState(basePath + '.desc', baseData[v.cal_garbage_type].title, {
                                       desc: 'Beschreibung der Abholung',
                                       type: 'string',
                                       read: true,
                                       write: false
                                       setState(basePath + '.desc', baseData[v.cal_garbage_type].title, true);
                                   createState(basePath + '.color', {
                                       desc: 'Farbe',
                                       type: 'string',
                                       role: 'level.color',
                                       read: true,
                                       write: false
                                       setState(basePath + '.color', baseData[v.cal_garbage_type].color, true);
                                   counter++;
              TT-Tom @oFbEQnpoLKKl6mbY5e13 last edited by
              @ofbeqnpolkkl6mby5e13 sagte in Hilfe für Javascript Legastheniker und js v8.3.x:
              Zeile 46 hinter options die ) muss weg.
              • O
                oFbEQnpoLKKl6mbY5e13 @TT-Tom last edited by
                @tt-tom
                2024-05-26 22:46:45.108  - error: javascript.0 (3416) script.js.common._Tests.Test_17 compile failed:
                at script.js.common._Tests.Test_17:111
                2024-05-26 22:46:45.109  - error: javascript.0 (3416)         };
                2024-05-26 22:46:45.109  - error: javascript.0 (3416)         ^
                2024-05-26 22:46:45.109  - error: javascript.0 (3416) SyntaxError: missing ) after argument list
                2024-05-26 22:46:45.109  - error: javascript.0 (3416)     at new Script (node:vm:99:7)
                2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1917:21)
                2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2183:37)
                2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at /opt/iobroker/node_modules/iobroker.javascript/main.js:2281:17
                2024-05-26 22:46:45.110  - error: javascript.0 (3416)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1703:17)
                2024-05-26 22:46:45.111  - error: javascript.0 (3416)     at process.processImmediate (node:internal/timers:478:21)
                2024-05-26 22:46:46.955  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
                  TT-Tom @oFbEQnpoLKKl6mbY5e13 last edited by TT-Tom
                  da fehlen irgendwo noch Klammern, bin grad mal am suchen
                  Edit: probiere mal das jetzt.
                                  let counter = 0;
                                  const todayStr = date.getFullYear() + "-" + ('00' + (date.getMonth() + 1)).slice(-2) + "-" + ('00' + date.getDate()).slice(-2)
                                  log(todayStr);
                                          // States erstellen
                                              type: "channel",
                                              common: {
                                          }, function (err) {
                                              if (err) {
                                                  return;
                                              type: 'string',
                                              read: true,
                                              write: false
                                              type: 'string',
                                              read: true,
                                              write: false
                                              desc: 'Farbe',
                                              type: 'string',
                                              read: true,
                                              write: false
                                          counter++;
                  • O
                    @tt-tom
                    Danke, es kommt kein Fehler mehr! Eine Objektstruktur wird weiterhin nicht angelegt.
                      okay dann brauche ich mal das komplette Log vom Start das Script. Muss mir mal die Daten ansehen, die da kommen.
                      • O
                        @tt-tom
                        2024-05-26 23:06:36.838  - info: javascript.0 (3416) Start JavaScript script.js.common._Tests.Test_17 (JavaScript/js)
                        2024-05-26 23:06:36.850  - info: javascript.0 (3416) script.js.common._Tests.Test_17: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                        2024-05-26 23:06:36.925  - info: javascript.0 (3416) script.js.common._Tests.Test_17: 200
                        2024-05-26 23:06:36.926  - info: javascript.0 (3416) script.js.common._Tests.Test_17: [{"title":"Bioabfall","name":"SZ_BIO","_name":"SZ_BIO","color":"a52a2a"},{"title":"Gelber Sack","name":"SZ_G","_name":"SZ_G","color":"FFFF00"},{"title":"Altpapier (120l, 240l)","name":"SZ_P","_name":"SZ_P","color":"2fc2e8"},{"title":"Restabfall (bis 240l)","name":"SZ_R","_name":"SZ_R","color":"2F4F4F"},{"title":"Weihnachtsbaum","name":"SZ_W","_name":"SZ_W","color":"36b515"}]
                        2024-05-26 23:14:15.038  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
                          der erste teil stimmt auch nicht bzw. ist unlogisch. Hast du noch das original?
                          • O
                            @tt-tom
                            https://github.com/volkerrichert/ioBroker.mymuell/blob/master/myMuell.iob
                              okay, muss den Anfang auch nochmal anpassen. Da ist etwas verrutscht 😉
                                 updateMuell();
                                 } else {
                              • O
                                @tt-tom
                                Ah, jetzt wird die Objektstruktur angelegt! Vielen Dank!
                                Aber, im Original werden keine Daten auf der Konsole ausgegeben. Woran liegt das?
                                  im Script sind diese Zeilen für die Ausgabe
                                  ersetze sie mit diesen Zeilen
                                  if (logging) console.log(response.statusCode);
                                  if (logging) console.log(response.data);
                                  dann kommt die Meldung nur, wenn du logging auf true setzt
                                  const logging = true;
                                  O 2 Replies Last reply Reply Quote 0
                                  • O
                                    @tt-tom
                                    Aber das ist im Original doch auch nicht so und im Original werden im Normalfall keine Meldungen ausgegeben.
                                    • O
                                      @tt-tom
                                      Ach sorry, das hatte ich ja selbst hinzugefügt.
                                        so Feierabend für heute, Script läuft soweit?
                                        • O
                                          @tt-tom
                                          Ich weiß nicht...
                                          2024-05-26 23:37:50.481  - info: javascript.0 (3416) Start JavaScript script.js.common._Tests.Test_17 (JavaScript/js)
                                          2024-05-26 23:37:50.492  - info: javascript.0 (3416) script.js.common._Tests.Test_17: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                                          2024-05-26 23:37:50.656  - info: javascript.0 (3416) script.js.common._Tests.Test_17: 200
                                          2024-05-26 23:37:50.656  - info: javascript.0 (3416) script.js.common._Tests.Test_17: [{"Ack":"Success","id":"mm_termins","messages":[{"status":"OK","msg":"getTermins"}],"_data":[{"cal_id":"128222324","cal_date":"2024-01-03","cal_date_normal":"03.01.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222316","cal_date":"2024-01-03","cal_date_normal":"03.01.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222376","cal_date":"2024-01-09","cal_date_normal":"09.01.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222387","cal_date":"2024-01-10","cal_date_normal":"10.01.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128222464","cal_date":"2024-01-16","cal_date_normal":"16.01.2024","cal_garbage_type":"SZ_W","cal_comment":""},{"cal_id":"128222458","cal_date":"2024-01-16","cal_date_normal":"16.01.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222450","cal_date":"2024-01-16","cal_date_normal":"16.01.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222532","cal_date":"2024-01-23","cal_date_normal":"23.01.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222604","cal_date":"2024-01-30","cal_date_normal":"30.01.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222596","cal_date":"2024-01-30","cal_date_normal":"30.01.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222645","cal_date":"2024-02-06","cal_date_normal":"06.02.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222718","cal_date":"2024-02-13","cal_date_normal":"13.02.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222710","cal_date":"2024-02-13","cal_date_normal":"13.02.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222726","cal_date":"2024-02-14","cal_date_normal":"14.02.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128222767","cal_date":"2024-02-20","cal_date_normal":"20.02.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222841","cal_date":"2024-02-27","cal_date_normal":"27.02.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222833","cal_date":"2024-02-27","cal_date_normal":"27.02.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222890","cal_date":"2024-03-05","cal_date_normal":"05.03.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128222963","cal_date":"2024-03-12","cal_date_normal":"12.03.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128222955","cal_date":"2024-03-12","cal_date_normal":"12.03.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128222971","cal_date":"2024-03-13","cal_date_normal":"13.03.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223012","cal_date":"2024-03-19","cal_date_normal":"19.03.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223086","cal_date":"2024-03-25","cal_date_normal":"25.03.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223078","cal_date":"2024-03-25","cal_date_normal":"25.03.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223135","cal_date":"2024-04-03","cal_date_normal":"03.04.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223208","cal_date":"2024-04-09","cal_date_normal":"09.04.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223200","cal_date":"2024-04-09","cal_date_normal":"09.04.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223216","cal_date":"2024-04-10","cal_date_normal":"10.04.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223257","cal_date":"2024-04-16","cal_date_normal":"16.04.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223331","cal_date":"2024-04-23","cal_date_normal":"23.04.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223323","cal_date":"2024-04-23","cal_date_normal":"23.04.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223380","cal_date":"2024-04-30","cal_date_normal":"30.04.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223453","cal_date":"2024-05-07","cal_date_normal":"07.05.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223445","cal_date":"2024-05-07","cal_date_normal":"07.05.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223461","cal_date":"2024-05-08","cal_date_normal":"08.05.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223502","cal_date":"2024-05-14","cal_date_normal":"14.05.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223576","cal_date":"2024-05-22","cal_date_normal":"22.05.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223568","cal_date":"2024-05-22","cal_date_normal":"22.05.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223625","cal_date":"2024-05-28","cal_date_normal":"28.05.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223689","cal_date":"2024-06-04","cal_date_normal":"04.06.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223681","cal_date":"2024-06-04","cal_date_normal":"04.06.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223739","cal_date":"2024-06-11","cal_date_normal":"11.06.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223748","cal_date":"2024-06-12","cal_date_normal":"12.06.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128223811","cal_date":"2024-06-18","cal_date_normal":"18.06.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223803","cal_date":"2024-06-18","cal_date_normal":"18.06.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223862","cal_date":"2024-06-25","cal_date_normal":"25.06.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223934","cal_date":"2024-07-02","cal_date_normal":"02.07.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128223926","cal_date":"2024-07-02","cal_date_normal":"02.07.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128223984","cal_date":"2024-07-09","cal_date_normal":"09.07.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128223993","cal_date":"2024-07-10","cal_date_normal":"10.07.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224056","cal_date":"2024-07-16","cal_date_normal":"16.07.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224048","cal_date":"2024-07-16","cal_date_normal":"16.07.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224107","cal_date":"2024-07-23","cal_date_normal":"23.07.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224179","cal_date":"2024-07-30","cal_date_normal":"30.07.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224171","cal_date":"2024-07-30","cal_date_normal":"30.07.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224220","cal_date":"2024-08-06","cal_date_normal":"06.08.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224293","cal_date":"2024-08-13","cal_date_normal":"13.08.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224285","cal_date":"2024-08-13","cal_date_normal":"13.08.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224301","cal_date":"2024-08-14","cal_date_normal":"14.08.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224342","cal_date":"2024-08-20","cal_date_normal":"20.08.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224416","cal_date":"2024-08-27","cal_date_normal":"27.08.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224408","cal_date":"2024-08-27","cal_date_normal":"27.08.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224465","cal_date":"2024-09-03","cal_date_normal":"03.09.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224538","cal_date":"2024-09-10","cal_date_normal":"10.09.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224530","cal_date":"2024-09-10","cal_date_normal":"10.09.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224546","cal_date":"2024-09-11","cal_date_normal":"11.09.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224587","cal_date":"2024-09-17","cal_date_normal":"17.09.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224661","cal_date":"2024-09-24","cal_date_normal":"24.09.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224653","cal_date":"2024-09-24","cal_date_normal":"24.09.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224704","cal_date":"2024-10-01","cal_date_normal":"01.10.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224777","cal_date":"2024-10-08","cal_date_normal":"08.10.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224769","cal_date":"2024-10-08","cal_date_normal":"08.10.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224785","cal_date":"2024-10-09","cal_date_normal":"09.10.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128224826","cal_date":"2024-10-15","cal_date_normal":"15.10.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128224900","cal_date":"2024-10-22","cal_date_normal":"22.10.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128224892","cal_date":"2024-10-22","cal_date_normal":"22.10.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128224949","cal_date":"2024-10-29","cal_date_normal":"29.10.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225013","cal_date":"2024-11-05","cal_date_normal":"05.11.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225005","cal_date":"2024-11-05","cal_date_normal":"05.11.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225063","cal_date":"2024-11-12","cal_date_normal":"12.11.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225072","cal_date":"2024-11-13","cal_date_normal":"13.11.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128225135","cal_date":"2024-11-19","cal_date_normal":"19.11.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225127","cal_date":"2024-11-19","cal_date_normal":"19.11.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225186","cal_date":"2024-11-26","cal_date_normal":"26.11.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225258","cal_date":"2024-12-03","cal_date_normal":"03.12.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225250","cal_date":"2024-12-03","cal_date_normal":"03.12.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225308","cal_date":"2024-12-10","cal_date_normal":"10.12.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225317","cal_date":"2024-12-11","cal_date_normal":"11.12.2024","cal_garbage_type":"SZ_P","cal_comment":""},{"cal_id":"128225380","cal_date":"2024-12-17","cal_date_normal":"17.12.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225372","cal_date":"2024-12-17","cal_date_normal":"17.12.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225431","cal_date":"2024-12-23","cal_date_normal":"23.12.2024","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225503","cal_date":"2024-12-31","cal_date_normal":"31.12.2024","cal_garbage_type":"SZ_R","cal_comment":""},{"cal_id":"128225495","cal_date":"2024-12-31","cal_date_normal":"31.12.2024","cal_garbage_type":"SZ_G","cal_comment":""},{"cal_id":"128225555","cal_date":"2025-01-07","cal_date_normal":"07.01.2025","cal_garbage_type":"SZ_BIO","cal_comment":""},{"cal_id":"128225566","cal_date":"2025-01-08","cal_date_normal":"08.01.2025","cal_garbage_type":"SZ_P","cal_comment":""}],"_extra":[]}]
                                          2024-05-26 23:37:50.657  - info: javascript.0 (3416) script.js.common._Tests.Test_17: 2024-05-26
                                          2024-05-26 23:37:55.515  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.000.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.517  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.001.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.519  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.002.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.520  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.003.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.521  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.004.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.523  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.005.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.524  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.006.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.525  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.007.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.526  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.008.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.528  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.009.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.529  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.010.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.530  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.011.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.541  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.012.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.543  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.013.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.544  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.014.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.546  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.015.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.547  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.016.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.548  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.017.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.549  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.018.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.551  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.019.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.552  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.020.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.553  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.021.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.555  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.022.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.556  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.023.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.558  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.024.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.559  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.025.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.560  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.026.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.562  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.027.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.563  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.028.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.564  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.029.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.566  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.030.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.568  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.031.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.570  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.032.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.571  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.033.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.573  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.034.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.574  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.035.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.575  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.036.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.577  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.037.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.578  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.038.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.579  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.039.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.581  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.040.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.582  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.041.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.583  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.042.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.584  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.043.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.586  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.044.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.587  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.045.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.588  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.046.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.590  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.047.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.591  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.048.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.592  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.049.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.602  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.050.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.603  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.051.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.605  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.052.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.606  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.053.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.607  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.054.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.608  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.055.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:55.669  - warn: javascript.0 (3416) Read-only state "0_userdata.0.muell-test.056.color" has been written without ack-flag with value "null"
                                          2024-05-26 23:37:59.691  - info: javascript.0 (3416) Stopping script script.js.common._Tests.Test_17
                                            sende bitte nochmal jetzt das komplette Script, ich sehe mir das morgenfrüh an. da Passt etwas mit dem erstellen des color State nicht.
                                            6468
