    3. Einsteigerfragen
    4. Steuerung Gecko in Touch 2 per iob möglich? (Wellis)
    • Stefan-Berlin1
      Stefan-Berlin1 @Stefan-Berlin1 last edited by Stefan-Berlin1
      @stefan-berlin1
      so habs genauso gemacht:
      javascript.0
      2024-05-06 22:54:38.970	info	script.js.common.Spa.SpaUpdateConfig: end
      javascript.0
      2024-05-06 22:54:38.970	info	script.js.common.Spa.SpaUpdateConfig: *** stderr: Error: Command failed: python3 /SpaController/spa_config.py b7031c49-70a1-4f9b-917b-24df54c20973 http://172.17.0.4:8087 javascript.0.Datenpunkte.SwimSpa *** there were no spas found on your network.
      javascript.0
      2024-05-06 22:54:28.785	info	script.js.common.Spa.SpaUpdateConfig: *** executing: python3 /SpaController/spa_config.py b7031c49-70a1-4f9b-917b-24df54c20973 http://172.17.0.4:8087 javascript.0.Datenpunkte.SwimSpa
      javascript.0
      2024-05-06 22:54:28.783	info	script.js.common.Spa.SpaUpdateConfig: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
      javascript.0
      2024-05-06 22:54:28.783	info	script.js.common.Spa.SpaUpdateConfig: start
      javascript.0
      2024-05-06 22:54:28.730	info	Start javascript script.js.common.Spa.SpaUpdateConfig
      javascript.0
      2024-05-06 22:54:26.690	info	received all states
      javascript.0
      2024-05-06 22:54:26.654	info	received all objects
      javascript.0
      2024-05-06 22:54:26.013	info	requesting all objects
      javascript.0
      2024-05-06 22:54:26.013	info	requesting all states
      javascript.0
      2024-05-06 22:54:25.540	info	starting. Version 7.8.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v18.20.2, js-controller: 5.0.19
      javascript.0
      2024-05-06 22:53:54.234	info	terminating
      javascript.0
      2024-05-06 22:53:53.737	info	Terminated (NO_ERROR): Without reason
      javascript.0
      2024-05-06 22:53:53.736	info	terminating
      javascript.0
      2024-05-06 22:53:53.732	info	Stop script script.js.common.Spa.SpaUpdateConfig
      javascript.0
      2024-05-06 22:53:53.731	warn	Restart initiated
      javascript.0
      2024-05-06 22:53:53.730	info	Global Script script.js.global.SpaGlobal updated. Restart instance.
      die global Spa ist aktiviert
      hier mal die updateconfig auswertung:
      23:02:01.914	info	javascript.0 (4092) Debugging of script.js.common.Spa.SpaUpdateConfig was stopped, because started in normal mode
      23:02:01.915	info	javascript.0 (4092) Start javascript script.js.common.Spa.SpaUpdateConfig
      23:02:01.935	info	javascript.0 (4092) script.js.common.Spa.SpaUpdateConfig: start
      23:02:01.935	info	javascript.0 (4092) script.js.common.Spa.SpaUpdateConfig: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
      23:02:25.699	info	javascript.0 (4092) Stop script script.js.common.Spa.SpaUpdateConfig
      23:03:04.144	info	javascript.0 (4160) Start javascript script.js.common.Spa.SpaUpdateConfig
      23:03:04.223	info	javascript.0 (4160) script.js.common.Spa.SpaUpdateConfig: start
      23:03:04.223	info	javascript.0 (4160) script.js.common.Spa.SpaUpdateConfig: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
      23:03:04.224	info	javascript.0 (4160) script.js.common.Spa.SpaUpdateConfig: resetting scriptRunning, because it's false since more than 5 minutes
      23:03:04.226	info	javascript.0 (4160) script.js.common.Spa.SpaUpdateConfig: *** executing: python3 /SpaController/spa_config.py b7031c49-70a1-4f9b-917b-24df54c20973 http://172.17.0.4:8087 javascript.0.Datenpunkte.SwimSpa
      23:03:14.882	info	javascript.0 (4160) script.js.common.Spa.SpaUpdateConfig: *** stderr: Error: Command failed: python3 /SpaController/spa_config.py b7031c49-70a1-4f9b-917b-24df54c20973 http://172.17.0.4:8087 javascript.0.Datenpunkte.SwimSpa *** there were no spas found on your network.
      23:03:14.883	info	javascript.0 (4160) script.js.common.Spa.SpaUpdateConfig: end
      rrov1 1 Reply Last reply Reply Quote 0
      • rrov1
        rrov1 @Stefan-Berlin1 last edited by
        @stefan-berlin1 Hallo Stefan,
        ärgerlich, der ReferenceError ist jetzt zwar weg, aber er findet den SpaController immer noch nicht
        Bitte prüfe noch mal die Datei /SpaController/spa_config.py, ob da wirklich in Zeile 34 die Änderung drinnen steht. Ich füge hier mal eine von mir vorbereitete Version ein: spa_config.py , es wäre mir am liebsten du nimmst die mal. Ich habe die richtige IP schon eingetragen. Danach bitte SpaUpdateConfig.js noch mal ausführen und den Datenpunkt mit der IP-Adresse prüfen. Falls es nicht klappt bitte noch mal die Einträge aus dem Logfile schicken.
        Stefan-Berlin1 1 Reply Last reply Reply Quote 0
        • Stefan-Berlin1
          Stefan-Berlin1 @rrov1 last edited by
          @rrov1 Hey Stefan,
          alles korrekt ist eingetragen hab auch Deine Datei einmal genommen.
          21:52:39.504	info	javascript.0 (9003) Start javascript script.js.common.Spa.SpaUpdateConfig
          21:52:39.557	info	javascript.0 (9003) script.js.common.Spa.SpaUpdateConfig: start
          21:52:39.557	info	javascript.0 (9003) script.js.common.Spa.SpaUpdateConfig: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
          21:52:39.557	info	javascript.0 (9003) script.js.common.Spa.SpaUpdateConfig: resetting scriptRunning, because it's false since more than 5 minutes
          21:52:39.558	info	javascript.0 (9003) script.js.common.Spa.SpaUpdateConfig: *** executing: python3 /SpaController/spa_config.py b7031c49-70a1-4f9b-917b-24df54c20973 http://172.17.0.4:8087 javascript.0.Datenpunkte.SwimSpa
          21:52:49.791	info	javascript.0 (9003) script.js.common.Spa.SpaUpdateConfig: *** stderr: Error: Command failed: python3 /SpaController/spa_config.py b7031c49-70a1-4f9b-917b-24df54c20973 http://172.17.0.4:8087 javascript.0.Datenpunkte.SwimSpa *** there were no spas found on your network.
          21:52:49.791	info	javascript.0 (9003) script.js.common.Spa.SpaUpdateConfig: end
          Er findet Ihn nicht die IP (http://172.17.0.4:8087) die er aufruft ist die aus der Simple API
          • rrov1
            @stefan-berlin1 So was ärgerliches 😐 , die Aufrufe und die IP vom Simple API sind gut an der Stelle. Führe bitte noch mal folgendes aus dem Container heraus aus:
            ping 192.168.188.68
            -> sollte einfach gehen, nur als Test.
            Dann, das hatten wir schon mal vor ein paar Tagen getestet:
            python3
            from geckolib import GeckoShell
            GeckoShell.run(["logfile client.log", "discover 192.168.188.68"])
            -> er sollte den SpaController finden
            Dann noch mal:
            Und schick mir zumindest von den letzten beiden mal was die Ergebnisse sind.
            • Stefan-Berlin1
              @rrov1
              Funktioniert Ping:
              PING 192.168.188.68 (192.168.188.68) 56(84) bytes of data.
              64 bytes from 192.168.188.68: icmp_seq=2 ttl=63 time=1.36 ms
              64 bytes from 192.168.188.68: icmp_seq=3 ttl=63 time=1.20 ms
              64 bytes from 192.168.188.68: icmp_seq=4 ttl=63 time=1.40 ms
              64 bytes from 192.168.188.68: icmp_seq=5 ttl=63 time=1.35 ms
              64 bytes from 192.168.188.68: icmp_seq=6 ttl=63 time=1.34 ms
              2te python3 from geckolip... geht auch findet er:
              Starting discovery process...Found 1 spas
              Connecting to spa `Kirschpool ??` at 192.168.188.68 ... connected!
              Heater: Temperature 36.0°C, SetPoint 36.0°C, Real SetPoint 24.9°C, Operation Cool
              ing
              Pump 1: OFF
              Pump 2: OFF
              Waterfall: OFF
              Lights: OFF
              WaterCare: Waiting...
              Smart Winter Mode:Risk: NO
              Circulating Pump: OFF
              Ozone: OFF
              Smart Winter Mode:Active: False
              Filter Status:Clean: False
              Filter Status:Purge: False
              Economy Mode: True
              Error Sensor: VSP1CommLost, VSP2CommLost
              Welcome to the Gecko shell. Type help or ? to list commands.
              Das letzte klappt nicht:
              root@buanet-iobroker-1:/opt/iobroker# python3 /SpaController/spa_config.py b7031c
              imSpa
              /SpaController/spa_config.py Version: 0.2.4
              total arguments passed: 4
              Connect using client id: b7031c49-70a1-4f9b-917b-24df54c20973
              ioBroker Simple Rest API URL: http://172.17.0.4:8087
              Base path to datapoints: javascript.0.Datenpunkte.SwimSpa
              *** looking for spas on your network ...
              • Stefan-Berlin1
                @stefan-berlin1
                Hat es was mit der Simple Api vielleicht zu tun und den Ports?
                • rrov1
                  leider nein. Das Skript spa_config.py ist recht simpel gestrickt:
                  1. Parameteranzahl prüfen und Parameter in Variablen merken
                  2. Verbindung zum SpaController herstellen (Zeile 34 die du angepasst hast)
                  3. Diverse Werte vom SpaController abrufen und merken
                  4. Werte aufbereiten und per HTTP-Request dem Simple API übergeben.
                  Wenn bei Punkt 2 keine Verbindung aufgebaut werden kann endet das Skript an der Stelle (es hat ja sowieso nix was es dem Simple API übergeben könnte).
                  Blöd ist, das es in meinem Testcontainer läuft und die beiden Tests die du ausgeführt hast sind klare Indikatoren dafür das es keine grundsätzlichen Probleme bei dir gibt.
                  Ich habe leider heute und morgen keine Zeit mehr, am Wochenende bin ich unterwegs in den Urlaub. Ich baue, wenn ich Zeit habe nächst Woche das spa_config.py ordentlich um, so dass du da nicht mehr drin rumändern musst und melde mich noch mal.
                  • Stefan-Berlin1
                    @rrov1
                    Mach ganz ruhig, kommt ja nicht auf'n paar Tage an.
                    Genieß den Urlaub. Ich teste mal nochmal paar Variation
                    • rrov1
                      ich habe jetzt die Skripte angepasst, so dass auch von meinem Docker Test Container aus SpaController erkannt werden. Es gibt jetzt einen Datenpunkt in dem du die IP-Adresse vom SpaController hinterlegen musst, damit dieser gefunden wird. Bitte wie folgt vorgehen:
                      • im ioBroker anmelden, ins Verzeichnis SwimSpa wechseln und "git pull" aufrufen. Der git-Client sollte einige Skripte aktualisieren
                      • Python Skripte aktualisieren: "cp ./Python/*.py /SpaController/"
                      • Skript: SpaVariablen.js öffnen, Inhalt löschen und mit Inhalt von SpaVariablen.js ersetzen und 1x laufen lassen (Achtung: Aufruf in Zeile 4 ggf. anpassen), Am Ende sollte ein neuer Datenpunkt: javascript.0.Datenpunkte.SwimSpa.discoverIP vorhanden sein.
                      • Jetzt die IP-Adresse des SpaController im neuen Datenpunkt: javascript.0.Datenpunkte.SwimSpa.discoverIP manuell eintragen.
                      • Skript: SpaUpdateConfig.js öffnen, Inhalt löschen und mit dem aus git: SpaUpdateConfig.js ersetzen, speichern und ausführen.
                      Das ist jetzt die spannende Stelle, wenn bei dir alles klappt, sollte der SpaController nun gefunden werden auf Basis seiner IP-Adresse. Es sollten Datenpunkte wie:
                      • ID
                      • IPAdresse
                      • Name
                      • U_ID
                        unterhalb von javascript.0.Datenpunkte.SwimSpa.0 gesetzt sein.
                      Schreibe mal ob das erfolgreich war.
                      • Stefan-Berlin1
                        Stefan-Berlin1 @rrov1 last edited by Stefan-Berlin1
                        @rrov1
                        Hallo hoffe Du hattest ein angenehmen Urlaub. Ich hab dies mal getestet und auch nochmal komplett neu gemacht.
                        Im Datenpunkt taucht es auf. Wenn ich die Spa Update Config Starte kommt noch ein Fehler:
                        javascript.0	01:58:42.668	info	Stopping script script.js.common.Spa.SpaUpdateConfig
                        javascript.0	01:59:07.571	info	Stopping script script.js.common.Spa.SpaUpdateConfig
                        javascript.0	01:59:13.261	info	Start JavaScript script.js.common.Spa.SpaUpdateConfig (Javascript/js)
                        javascript.0	01:59:13.302	info	script.js.common.Spa.SpaUpdateConfig: start
                        javascript.0	01:59:13.302	info	script.js.common.Spa.SpaUpdateConfig: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
                        javascript.0	01:59:13.303	info	script.js.common.Spa.SpaUpdateConfig: *** IP(s) to disover: 192.168.188.68
                        javascript.0	01:59:13.303	info	script.js.common.Spa.SpaUpdateConfig: resetting scriptRunning, because it's false since more than 5 minutes
                        javascript.0	01:59:13.303	info	script.js.common.Spa.SpaUpdateConfig: *** discovering IP: 0 => 192.168.188.68
                        javascript.0	01:59:13.304	info	script.js.common.Spa.SpaUpdateConfig: *** executing: python /SpaController/spa_config.py 4d9a30ec-aea3-4a77-af1a-01d1ea71c336 http://172.17.0.6:8087 javascript.0.Datenpunkte.SwimSpa 0 192.168.188.68
                        javascript.0	01:59:13.313	info	script.js.common.Spa.SpaUpdateConfig: *** stderr: Error: Command failed: python /SpaController/spa_config.py 4d9a30ec-aea3-4a77-af1a-01d1ea71c336 http://172.17.0.6:8087 javascript.0.Datenpunkte.SwimSpa 0 192.168.188.68 /bin/sh: 1: python: not found
                        javascript.0	01:59:13.313	info	script.js.common.Spa.SpaUpdateConfig: end
                        Ich hab nochmal die befehle ausgeführt und er findet den Spa:
                        python3
                        Gruß Stefan
                        • rrov1
                          ja, der Urlaub war schon gut, nur das Wetter war dieses Jahr an der Costa Brava nicht so gut, ich musste die Tagesaktivitäten etwas aktiver gestalten 😉 .
                          Die Shell sagt: /bin/sh: 1: python: not found
                          Der Python Interpreter sollte auf den Namen "python3" hören (vgl. dein manueller Test). Bitte prüfe in SpaGlobal.js noch mal die Zeile 4, Variable: SPA_EXECUTEABLE, dort sollte "python3" drinnen stehen.
                          • Stefan-Berlin1
                            @rrov1
                            das ist ärgerlich das das Wetter so schlecht war. Dafür fährt man ja weg um dem Wetter hier zu entgehen.
                            Es hat geklappt es sind Daten zu sehen 👍 huchu . Dann werde ich mal sehen wie ich die in meine Loxone wertvoll weiter verarbeiten kann.
                            Bekomme in kürze dann auch noch eine Wellis Wärmepumpe mal schauen wie die funktioniert und wie man diese nun wieder einbindet.
                            • rrov1
                              schön zu hören, das es jetzt doch klappt 🙂 .
                              Ich habe hier auch eine Loxone Anlage. Ich habe die Integration über den Simple Rest API Adapter gelöst, sprich virtuelle Eingänge für z.B. die Temperaturen gleich über ein "getBulk" und virtuelle Ausgänge mit "set" auf Datenpunkte. Funktioniert einwandfrei.
                              Viel Erfolg noch.
                              Stefan-Berlin1 2 Replies Last reply Reply Quote 0
                              • Stefan-Berlin1
                                @rrov1 danke, ja ich hole mir schon diverse Sachen rein in die loxone. Aber meist nur Status. Steuern muss ich mal schauen wie ich das mache.
                                Mal schauen wie sich die Wärmepumpe noch ansprechen lässt wenn Sie da ist
                                • Stefan-Berlin1
                                  @rrov1
                                  Hab noch ein Problem.
                                  Sagen wir mal 30 Grad ist aktuell. Ich Stelle die Temperatur auf 38 Grad (per App und auch vor Ort). Schau Zeit x später rein steht ne andere eingestellte Temperatur als hätte jemand wieder runter geregelt. 😔
                                  Zur Info ich hab ein Wellis Life Atlas 2024 Modell.
                                  Hat 2 Sprudler Pumpen und ein Zirkalations (Filter) Pumpe und ein Wasserfall der mit Pumpe 1 angeht automatisch (bzw.kann man den manuell über Drehknopf Mischer ausmachen)
                                  1 Spa Controller
                                  2 Pumpen
                                  Datenpunkte:
                                  P1 wäre Sprudel rechte Seite (Liegefläche) inklusive Wasserfall (Wasserfall kann man nur manuell mit Drehrad (Mischer) abstellen)
                                  P2 ist Sprudler linke Seite (Sitze)
                                  Beim Datenpunkt Waterfall reagiert er wenn Circulations Pumpe an geht. Da wird es angezeigt und auch unter Punkt Sensoren Circulations Pump
                                  Kann ich den Datenpunkt (Waterfall) im SpaVariables einfach umbennen in CirculationPump?
                                  oder gibts noch in anderen Phyton Scripts den Name Waterfall...?
                                  Kannst Du mir noch ein Tipp geben wie ich die Pumpen an und ausschalten kann muss ich den Modi oder Switch ansteuern per Loxone Virtuellen Ausgang?
                                  LG
                                  • rrov1
                                    1. Hast du das Script: SpaMoveTargetTemp.js aktiv? Das wäre dafür verantwortlich die Temperatur nachzuregeln. Bitte den Datenpunkt: javascript.0.Datenpunkte.SwimSpa.automaticTargetTemp mal auf "false" setzen, damit wird diese automatische Temperaturnachführung deaktiviert.
                                    2. Du kannst im Protokoll vom ioBroker mal nach "spa_setTargetTemp.py" suchen, dann findest du die Aufrufe zum setzen der Zieltemperatur.
                                    Der "Waterfall" ist noch eher eine Baustelle, da ich sowas nicht habe und bisher nichts testen konnte. Es gibt aktuell auch keine Skripte die auf die Änderung des Datenpunktes reagieren bzw. auch kein Python Skript das die Reaktion an den SpaController weitergibt. Er ist erst mal nur da, weil die geckolib ihn kennt. Den Datenpunkt: javascript.0.Datenpunkte.SwimSpa.0.Pumpen.Waterfall umzubenennen, wäre mir nicht so lieb, weil der Pfad bei einem Update wieder angelegt werden würde und dann evtl. zu Verwirrung führt. Was wäre das Ziel hinter der Umbenennung, die Pfade tauchen in den GUI's ja nicht auf. Zur Not vielleicht lieber einen Alias anlegen?
                                    Um die Pumpen einzuschalten nimmst du den Datenpunkte mit dem Namen "Switch", die anderen beiden Datenpunkte sind für dich Read Only (zu erkennen am Schloss im Icon vor dem Namen des Datenpunkts). Wichtig noch zu wissen, die geckolib kennt pro Pumpe 3 Status:
                                    • OFF = AUS (logisch)
                                    • LO oder LOW = kleine Stufe (funktioniert nur, wenn es deine Pumpe unterstützt, meine z.B. nicht)
                                    • HI oder HIGH = große Stufe
                                    • Stefan-Berlin1
                                      @rrov1
                                      Danke,
                                      so Waterfall / Zirkulations Pumpe sind das gleiche in meinem Fall.
                                      ok SpaMoveTargetTemp.js den Datenpunkt hab ich auf false gesetzt.
                                      Ich hab mal beobachtet bei OZON Status wird auch immer off angezeigt. Setzt er den nicht ein zur Reinigung wenn Zirkulationspumpe an ist und Filterdurchlauf läuft?
                                      Dann noch eine Sache zu Wasserpflege Modi,
                                      dort steht auch immer " Away from home" . Bei Wasserpflege Switch hab ich nun mal auf Standart (1) gesetzt manuell. Der ist immer aktiv (APP). Sollte sich dann aber nicht auch Der Modi Name ändern?
                                      • rrov1
                                        OZON Status immer OFF: Das habe ich auch schon beobachtet. Das war bei mir noch nie ON. Ich vermute die zugrundeliegende geckolib liefert den Wert nicht. Der Entwickler hat aber leider nur ganz wenig Zeit.
                                        WasserpflegeModi: Der Status ändert sich nicht, das ist eine Liste der verfügbaren Wasserpflegestatusnamen, bei mir: ['Away From Home', 'Standard', 'Energy Saving', 'Super Energy Saving', 'Weekender']. Das ist vorgesehen, falls das jemand zur Visualisierung braucht.
                                        • Stefan-Berlin1
                                          Kannst Du mir irgendwie ein Rat geben für die Loxone Bausteine
                                          Wenn PV Überschuss dann stell die temperatur auf z.b 38 Grad
                                          Wenn kein Überschuss ist stell die Temeratur auf 25 Grad.
                                          • rrov1
                                            @stefan-berlin1
                                            Hallo Stefan,
                                            das habe ich tatsächlich nicht mit Loxone geregelt sondern mit einem Script oder besser mit 2 Scripten.
                                            Script 1: SpaMoveTargetTemp.js (im Repo enthalten), das führt die Zieltemperatur immer 5 Grad höher als die aktuelle Temperatur nach und zwar zwischen der Minimaltemperatur von 12 Grad (Konstante im Script) und einer gewünschten Maximaltemperatur wie z.B. 38 Grad). Das Script läuft einfach aller 20 Minuten. Wenn du das einsetzt, dann schau in die schedule-Funktion, Zeilen 5 & 6, das ist für meine 2 Spa's du brauchst nur Zeile 5, Zieltemperatur natürlich anpassen nach Wunsch.
                                            Script 2: Ist nicht im Repo enthalten. Das Script ist spezifisch für meine Solaranlage und Schaltet den Wasserpflegemodus ein, wenn meine Batterie in den letzten 10 Minuten über 70% gefüllt ist und genug Überschuss da ist. Natürlich schaltet das dann den Wasserpflegemodus auch wieder aus.
                                            Vieleicht reicht dir aber schon das Script mit der Zieltemperatur.
                                            rrov1
                                            81.1k
                                            27782
