    3. Einsteigerfragen
    4. Installation
    5. iobroker influxdb1.x econnrefused 192.168.178.120:8086
      ronk @Thomas Braun last edited by
      Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarc        h64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Sun May 26 17:42:47 2024 from 192.168.178.20
      ronny@raspberrypi:~ $ systemctl status influxdb.service
      × influxdb.service - InfluxDB is an open-source, distributed, time series database
           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; preset: enabled)
           Active: failed (Result: exit-code) since Sun 2024-05-26 17:34:08 CEST; 9min ago
             Docs: https://docs.influxdata.com/influxdb/
          Process: 792 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=2)
              CPU: 208ms
      Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/mgc.go:1407 +0x398 fp=0x4000072fd0 sp=0x4000072f40 pc=0x7f89bfaa58
      Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]: runtime.goexit()
      Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/asm_arm64.s:1172 +0x4 fp=0x4000072fd0 sp=0x4000072fd0 pc=0x7f89c4af04
      Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]: created by runtime.gcBgMarkStartWorkers
      Mai 26 17:34:08 raspberrypi influxd-systemd-start.sh[794]:         /go/src/runtime/mgc.go:1199 +0x28
      Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
      Mai 26 17:34:08 raspberrypi systemd[1]: Stopped influxdb.service - InfluxDB is an open-source, distributed, time series database.
      Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
      Mai 26 17:34:08 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
      Mai 26 17:34:08 raspberrypi systemd[1]: Failed to start influxdb.service - InfluxDB is an open-source, distributed, time series database.
        Thomas Braun Most Active @ronk last edited by
        @ronk
        Dein Dateisystem läuft voll und der Kernel hat ein fscheck durchführen müssen.
        Dann spukt da noch irgendwas von einem Docker herum.
          ja, da läuft eine Dockerinstallation mit TeslaSolarCharger.
            @ronk
            Bei dem Thema bin ich dann auch raus.
            Schau das du deine Basis sauber hinbekommst. Wirst du aber nur per Neuinstallation das OS richtig hinbekommen, sage ich voraus.
              nuja, das lief alles einträchtig nebeneinander. Also von grundauf neuinstallieren?
                Thomas Braun Most Active @ronk last edited by Thomas Braun
                @ronk
                Nuja, nicht wirklich. Wie du siehst.
                Die Empfehlung Raspberry OS 'Bookworm' komplett neuzuinstallieren gab es nicht ohne Grund.
                  ronk @Thomas Braun last edited by ronk
                  okay. danke dir.
                  Läuft wieder.
                    @ronk
                    Das ging aber schnell... Eine ordentliche Neuinstallation kann das nicht gewesen sein und da ist immer noch das Flickwerk am Start.
                      nein, war natürlich keine Neuinstallation. Im Zuge eines geplanten Umbaus auf SSD (noch läuft die SD-Karte unauffällig, toitoitoi) setze ich alles voraussichtlich im Herbst neu auf.
                      Habe aber iob diag nochmal laufen lassen, keinerlei Warnungen oder Fehler mehr erkennbar. Den TeslaSolarCharger brauche ich wirklich sehr oft, iobroker ist Beifang, nur um die Sache etwas hübscher aussehen zu lassen.
                      Eine Frage habe ich noch: was genau ist an (m)einem InRelease-upgrade Flickwerk (gerne am Beispiel meiner geposteten Quotes)? Auch ich bin ein Freund sauberer Neuinstallationen. Aber wenn alles problemlos läuft? Warum nicht?
                      Vielen Dank
                        Homoran Global Moderator Administrators @ronk last edited by
                        @ronk sagte in iobroker influxdb1.x econnrefused 192.168.178.120:8086:
                        tut es ja nicht! Nur scheinbar.
                        Ab und zu blitzt ein Problem auf.
                        Das sind Zeitbomben.
                        irgendwann klappt es möglicherweise nicht, wenn du
                          Falscher Kernel über die falsche Firmware falsch eingehängt.
                          Hier versucht es auch jemand:
                          https://gnulinux.ch/pios-auf-bookworm-upgrade-ohne-neuinstallation-und-gewehr
                          Der schreibt aber auch:
                          Bitte beachten, dass dieser Vorgang nicht offiziell empfohlen wird und möglicherweise nicht für alle Anwendungen geeignet ist, besonders das Upgrade einer Installation mit grafischer Oberfläche wurde nicht getestet und wird höchstwahrscheinlich nicht ohne weiteres möglich sein. Auch ein Upgrade der 32-Bit Version von PiOS wurde nicht getestet.
                          Hier noch:
                          the changes in release from bullseye to bookworm is a lot, the desktop was swapped from a modified lxde to a wayland/wayfire setup, so no longer lxde, the network was changed from dhcpd to network manager, many other stuff was changed behind the UI.
                          use a spare to do a fresh install of raspberry bookworm os using imager you can then grab anything important to you from your old install.
                          https://forums.raspberrypi.com/viewtopic.php?t=363376
                            Aha, so ist das also. Vielen Dank.
                            Dann sollte ich das doch schnellstmöglich in Ordnung bringen.
                            Die Sicherungen, die ich mir von Backitup für influxdb und Grafana mit anlegen lasse kann man für die Wiederherstellung nach Neuinstallation nutzen? Also alle Datenpunkte und die Datenbank lassen sich darüber wieder einspielen?
                              crunchip Forum Testing Most Active @ronk last edited by
                              Ja
                              econnectrefused influxdb iobroker instanzen
                              1746
