    5. Blockly zeigt Warn Meldungen.
      Einstein2002 @Homoran last edited by
      on({ id: [].concat(['0_userdata.0.Terrasse_mit_TV']), val: true }, async (obj) => {
        let value = obj.state.val;
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_LED.cmnd.POWER' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_LED/cmnd/POWER */, true);
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Terrasse_DG.cmnd.POWER' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Terrasse_DG/cmnd/POWER */, true);
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER1' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER1 */, true);
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER1' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER1 */, true);
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER2' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER2 */, false);
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER2' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER2 */, false);
      on({ id: [].concat(['0_userdata.0.Terrasse_mit_TV']), val: false }, async (obj) => {
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_LED.cmnd.POWER' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_LED/cmnd/POWER */, false);
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Terrasse_DG.cmnd.POWER' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Terrasse_DG/cmnd/POWER */, false);
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER2' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER2 */, true);
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER2' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER2 */, true);
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.Terrasse_Rollo.cmnd.POWER1' /* SmartHome/Haus/Obergeschoss/Terrasse/Terrasse_Rollo/cmnd/POWER1 */, false);
        setState('mqtt.0.SmartHome.Haus.Obergeschoss.Terrasse.TV_Rollo.cmnd.POWER1' /* SmartHome/Haus/Obergeschoss/Terrasse/TV_Rollo/cmnd/POWER1 */, false);
      Bei ON ist die 1. Zeile
      Das ist das zweite Script
        Einstein2002 @paul53 last edited by
        @paul53 sagte in Blockly zeigt Warn Meldungen.:
        @einstein2002 sagte: ich habe zwei Blockly
        Man wendet keine zwei Trigger auf den gleichen Datenpunkt an, sondern:
        Ich versuch das mal umzubauen.
          Homoran Global Moderator Administrators @Einstein2002 last edited by
          @einstein2002 sagte in Blockly zeigt Warn Meldungen.:
          da ist jetzt ein Unterstrich mehr
            oh man, ich hatte den neu angelegt und dabei wohl einen Unterstrich eingefügt.
            Danke!!!!
              paul53 @Homoran last edited by paul53
              @homoran sagte: da sind switch1 und switch2 vertauscht
              Genau deshalb würde es passen: "POWER2" sind negiert, alle anderen nicht.
              E Homoran 2 Replies Last reply Reply Quote 0
                Ja das Passt schon, da hängt ein Sonoff Dual R3 dahinter, der hat Power1 und Power2.
                Als Rollladen Schalter darf immer nur einer auf True stehen. Deswegen habe ich dies so gewählt, ich bin gerade am anlegen von Alias Punkten und versuche so meine Objekte neu anzulegen. Wenn ich nachher eine passende Lösung gefunden habe teile ich diese hier im Forum.
                Bitte noch etwas um Geduld, ich bin da noch immer nicht so fit und brauche etwas Zeit.
                  Hallo Paul53,
                  das wird so nicht funktionieren, folgende Bedingung habe ich:
                  Ein paar LED am Boden, die sollen angehen wenn ich die Terrasse öffne, dann soll der Rollo hochfahren, Power1 wird auf True gesetzt, dadurch wird Power2 Automatisch False.
                  Der andere Auslöser bewirkt das gleiche wie oben, hat aber den zweiten Rollo mit Power1 auf True und Power2 auf False, dann noch einen weiteren Sonoff der eine weitere Steckdose anschaltet.
                  Das würde ja noch mit dem "Wert" gehen, aber jetzt beim Ausschalten der Terrasse kommt die Problematik:
                  Ich muss die Steckdose auf False setzten,
                  der Rollo mit Power2 aber auf True, das bewirkt das Herunterfahren des Rollos. Der "Wert" wäre aber bei beiden "False"
                  Ist das richtig??
                    paul53 @Einstein2002 last edited by
                    @einstein2002 sagte: Der "Wert" wäre aber bei beiden "False"
                    Nein, der nicht-Block negiert: false --> true, true --> false.
                      Okay, habe das "nicht" überlesen!! Klar dann geht es. Sorry mein Fehler!
                        aber doch unterschiedlich
                        im oberen Teil ist der dritte negiert, im unteren Teil der zweite
                          Das liegt aber an der Reihenfolge, die habe ich nicht eingehalten. Da habe ich Power 1 und Power2 vertauscht
                            @einstein2002 das ist da leider icht zu sehen.
                            Aber dann hat @paul53 natürlich recht.
                              So da habe ich mal fertig:
                                <block type="on_ext" id="cWj)M#2q10ApriJ}z/J." x="-87" y="112">
                                  <value name="OID0">
                                    <shadow type="field_oid" id="#7nxk7{L]5dos]}o*Ulq">
                                      <field name="oid">0_userdata.0.Terrasse_mit_TV</field>
                                    <block type="control" id=",`L(EWw`b}Z~:?]0Oi|u">
                                      <field name="OID">alias.0.Haus.Terrasse.Unterstand.LED_Terrasse_Boden_und_Sonos_Amp.LED_Terrasse_Boden_und_Sonos_AMP</field>
                                        <block type="on_source" id="~_]2dNN779yd/4NrnTm@">
                                        <block type="control" id="C++/OsdWV8_*Q3SnO1[@">
                                          <field name="OID">alias.0.Haus.Terrasse.Terrasse_TV_Steckdose_im_DG.Terrasse_TV_Steckdose_DG</field>
                                            <block type="on_source" id="BxMF$`~}@j+71AGAP=mV">
                                            <block type="control" id="v_OmfSc.ziVQoLYX#hBj">
                                              <field name="OID">alias.0.Haus.Terrasse.Rollo_Unterstand.Rollo_Hoch_Power1</field>
                                                <block type="on_source" id="*Z}%_.YM}FDa.o}r][7g">
                                                <block type="control" id="=*R1a_=NxrAhs-#wwstI">
                                                  <field name="OID">alias.0.Haus.Terrasse.Rollo_TV.Rollo_Hoch_Power1</field>
                                                    <block type="on_source" id="I9r14*9?lH3rC#s]Pbj-">
                                    <block type="on_ext" id="F94}@P{!jE6@T-{iCB{5">
                                      <field name="CONDITION">false</field>
                                      <value name="OID0">
                                        <shadow type="field_oid" id="$qu1SRidmJz{9+c|tjI7">
                                        <block type="control" id="cV.Iz~{@^y@jj+@/klAC">
                                            <block type="on_source" id="l]D]Z8E~6Lt^z44#R78k">
                                            <block type="control" id="E7,r/yW{WUBbTvj?G07W">
                                                <block type="on_source" id="6Qp{]7J7V~[Eo62Dd3sO">
                                                <block type="control" id="xbP1k-}1n1?W7GFXNo^8">
                                                  <field name="OID">alias.0.Haus.Terrasse.Rollo_Unterstand.Rollo_Runter_Power2</field>
                                                    <block type="logic_negate" id="x0U:1pZV|Qg9t5[SraN]">
                                                      <value name="BOOL">
                                                        <block type="on_source" id="%)G^7cA1G8Nq;5m0xezI">
                                                    <block type="control" id="DKD21eq}u~y8d*=lk%UY">
                                                      <field name="OID">alias.0.Haus.Terrasse.Rollo_TV.Rollo_Runter_Power2</field>
                                                        <block type="logic_negate" id="Zve0$RJ?xcYzxn_0Go2:">
                                                          <value name="BOOL">
                                                            <block type="on_source" id=")+|zwlUrATu3B}29e2{]">
                              Damit läuft es super. 1000 Dank an Euch
                                ein schönes xml 😁
                                  ja, Fotos soll ich ja nicht machen wegen der Auflösung..
                                  Das ist der Export von einem Blockly.
                                    nee, eine geeignete Auflösung wählen.
                                    So wie jetzt
                                    geht es gerade
                                      @einstein2002 sagte: Blockly.
                                      Besser so (nur ein Trigger):
                                      E 2 Replies Last reply Reply Quote 0
                                        @paul53 Dann kommen die Negativen Werte unter "mache sonst" Power2??
                                        Ich baue das mal..... Moment
                                          So das ist es, eigentlich Logisch wenn man es im Nachhinein sieht.
                                          Danke für den Wink mit dem Zaunpfahl...
                                              <value name="OID0">
                                                        <block type="controls_if" id="8IJ|zUT{`~J}ui(W~}SV">
                                                            <block type="on_source" id="@Z/M}]3z9L6iJ2V^ne^K">
                                                            <block type="comment" id="+Z/g=.36Z3)amg8:vhJu">
                                                              <field name="COMMENT">Rollo Hoch</field>
        <block type="logic_boolean" id="]W6nLNN{TC0boiC4)YFx">
        <block type="logic_boolean" id="+^Vh:7;R`OHtw@i]E;L#">
                                                          <statement name="ELSE">
                                                            <block type="comment" id="ey]cRfF*cb={G4|P%]3k">
                                                              <field name="COMMENT">Rollo Runter</field>
        <block type="control" id="43^7o)dK?,{4x3i{qttZ">
        <block type="logic_boolean" id="=/30@P5PVmb`o^3Zz5tG">
        <block type="control" id="BAND$7+JPDKYe0d3`Jm2">
        <block type="logic_boolean" id="Q!2`J0~g:@IV6TSvX?PB">
                                          Das mit der Auflösung muss ich mal üben, dazu muss ich aber erst einmal lesen. Also ihr lieben, ganz lieben Dank an Euch alle.
                                          Echt klasse hier!!
                                          1398
