    4. Bose Soundtouch steuern
      apollon77 last edited by
      Nur das GitHub repo muss ioBroker sein. Das npm Paket hat „iobroker“ im Namen. Das ist schon korrekt so. Also in per Package.json muss es kleingeschrieben sein
        der_Auge last edited by
        Guten Morgen
        nach Softwareupdate auf eine Sound10 funktionieren die Programmtasten nicht mehr
        Habe mal die Taste 1 abgehängt
        ! [{"tpl":"tplJquiRadioList","data":{"oid":"bosesoundtouch.0.key","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"PRESET_1","texts":"1","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"448px","top":"364px","width":"50px","height":"50px","z-index":"4"},"widgetSet":"jqui"}]
        Geht euch das auch so?
        Es läuft die Version 0.1.0
        Jürgen
        • SwedishChef
          SwedishChef last edited by
          V0.1.3 ist als npm Paket verfügbar und auch der pull request im ioBroker.repositories für den ersten offiziellen Release.
          Wie sind die ersten Erfahrungen mit play everywhere am zones branch?
          Gesendet von meinem A0001 mit Tapatalk
            Kann bitte auch mal jemand Discovery vom github installieren und schauen ob böse (außer bei mir) korrekt gefunden wird? 😉
            Mehrere Zonen und so kann ich leider nicht testen. Hab auch nur ein Gerät 😉
              @SwedishChef:
              Wie sind die ersten Erfahrungen mit play everywhere am zones branch? `
              bekomme ich leider nicht angezeigt
              ich lade den Verwahrungsort von "http://download.iobroker.net/sources-dist-latest.json" herunter
                Im repo ist es noch nicht drin. Bissl Geduld bitte, checken wir (Bluefox oder ich) heute Abend
                  Master77 last edited by
                  Hallo zusammen.
                  Bei mir wird die neue Version auch nicht angezeigt. Wie genau kann ich denn ein Update anstoßen wenn es nicht automatisch angezeigt wird. Oder muss ich die alten Adapter (habe 2 am laufen) deinstallieren und dann die neue Version installieren und alles neu einrichten?
                  Sorry wegen der ganzen Fragen. Will nur nichts falsches machen und am Ende alles neu einrichten. Danke im voraus für eure Hilfe.
                  Gruß Markus
                  Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk
                    Du kannst weiterhin direkt von der github url installieren. Das geht immer. Auch bei Updates.
                    Wenn es im repo drin ist (fehlen noch zwei Dinge glaube ich) dann geht es auch zusätzlich einfacher.
                      Hi.
                      Also wenn ich das richtig verstehe einfach die URL nehmen und über die "Katze" installieren? Erkennt der dann automatisch das das ein Update ist? Und wie verhält sich dann das ganze bei zwei installierten Bose Adaptern? Sorry wegen der ganzen Fragen.
                      Gruß Markus
                        Ein Update installiert immer drüber. Und Halbleinenband Auswirkungen auf eingerichtete Instanzen. Von daher: Jupp über die katze (Octocat). Nach dem install/Update die Instanzen manuell neu starten und dann laufen sie mit der aktuellen Version
                          Hi
                          Super. Dankeschön…..
                          Gruß Markus
                              Hallo zusammen.
                              Update hat Dank eurer Hilfe einwandfrei funktioniert.
                              Was genau ist dieses play everywhere.
                              Ist das die Funktion wenn man mehrere Lautsprecher hat das auf allen das gleiche gespielt wird? Wenn ja wie kann ich das genau testen. Unter Objekte habe ich nichts gefunden und auf der GitHub Seite steht dafür auch kein Key Code.
                              Gruß Markus
                                stoepselinho last edited by
                                bei mir wird unter Adapter auswählen der Bose gar nicht angezeigt? oder gibt es da einen Trick
                                  Siehe ein paar Beiträge drüber. Er ist noch nicht im offiziellen repo. Es fehlen noch 2 Kleinigkeiten. Aber von der url direkt installierbar
                                    Wenn mir einer sagt wie das mit dem play everywhere funktioniert werde ich es mal antesten. Da ich zwei Bose Geräte habe kann ich es testen. Aber wie bereits erwähnt kann ich die Option nicht in Objekte finden und es gibt auf der GitHub Seite kein Wert für Key.
                                    Gruß Markus
                                    • SwedishChef
                                      @Master77:
                                      Wenn mir einer sagt wie das mit dem play everywhere funktioniert werde ich es mal antesten. Da ich zwei Bose Geräte habe kann ich es testen. Aber wie bereits erwähnt kann ich die Option nicht in Objekte finden und es gibt auf der GitHub Seite kein Wert für Key… `
                                      Du findest die states bosesoundtouch.x.playEverywhere (bool), kurz auf True setzen und das gerade gespielte von x sollte dann auf allen anderen wiedergegeben werden. Zurücksetzen auf False bitte nicht vergessen - dazu muss ich mir noch etwas geeignetes überlegen.
                                      • SwedishChef
                                        Jetzt hab ich noch ein Problem mit meinem eigenen Adapter, hab ihn nach langem Suchen endlich unter Verwahrungsort 'online' (dämlich, warum nicht latest?) gefunden und auf meinem Produktiv-System installiert.
                                        ioBroker meldet: error - instance system.adapter.bosesoundtouch.0 terminated with code 10 (Cannot find start file of adapter)
                                        Das tritt bei lokaler Installation nicht auf? Hat jemand eine Idee?
                                          Habe eben nochmal nachgesehen. Ich finde da nichts mit bosesoundtouch.x.playEverywhere.
                                          Anbei ein Bild von dem kompletten Soundtouch Ordner. Und was bedeutet bool?
                                          Gruß Markus ~~![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201712 ... 61d25e.jpg">https://uploads.tapatalk-cdn.com/20171227/547d3b6345d63e46096ae610f961d25e.jpg</link_text>" />
                                          Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk~~
                                          • SwedishChef
                                            @Master77:
                                            Anbei ein Bild von dem kompletten Soundtouch Ordner. Und was bedeutet bool? `
                                            Um playEverywhere testen zu können must du den branch 'zones' installieren, du erhältst dann Version 0.0.10:
                                            https://github.com/SwedishChef1/iobroke … ball/zones
                                            Damit sollte bosesoundtouch.x.playEverywhere vorhanden sein. Es handelt sich um einen Status, der nur 2 Zustände annehmen kann: aus (nicht angehakt, False) und ein (angehakt, True) - wird in der Welt der Programmierer 'bool' oder 'boolean' genannt.
                                            Erst wenn ich Rückmeldungen zu playEverywhere hab, dass das halbwegs funktioniert, werde ich dass in V0.1.x integrieren. Ich kann es leider selber nicht testen, da ich nur eine SoundTouch besitze.
                                            286
                                            65459
