    4. E-INK Display OpenEPaperLink - Displayanzeige mit Batterie
      Beowolf @BananaJoe last edited by
      @bananajoe
      So, ich habe jetzt das Skript mal ein wenig umgebaut.
      sendTo('puppeteer.0', 'screenshot', {
          url: urlOfVISView,
          path: imageSaveToFilenameWithPath,
          width: viewWidth,
          height: viewHeight,
          quality: jpgQuality,
          waitOption: {
              waitForSelector: waitForSelector,
              waitForTimeout: 20000
          fullPage: false,
          clip: {
              x: cutoutX,
              y: cutoutY,
              width: cutoutWidth,
              height: cutoutHeight
      }, obj => {
          if (obj.error) {
              console.warn("Fehler beim Aufruf der View: " + urlOfVISView + " => " + obj.error.message);
          } else {
              const http = require('http');
              const https = require('https');
              const { URL } = require('url');
              const boundary = '--------------------------' + Date.now().toString(16);
              const CRLF = '\r\n';
              // Payload-Erstellung
              const payload = Buffer.concat([
                  Buffer.from(`--${boundary}${CRLF}Content-Disposition: form-data; name="dither"${CRLF}${CRLF}0${CRLF}`),
                  Buffer.from(`--${boundary}${CRLF}Content-Disposition: form-data; name="mac"${CRLF}${CRLF}${ePaperMAC}${CRLF}`),
                  Buffer.from(`--${boundary}${CRLF}Content-Disposition: form-data; name="image"; filename="screenshot.jpg"${CRLF}Content-Type: image/jpeg${CRLF}${CRLF}`),
                  Buffer.from(obj.result, 'binary'),
                  Buffer.from(`${CRLF}--${boundary}--${CRLF}`)
              // URL Parsing
              const url = new URL(imageUploadURL);
              const options = {
                  hostname: url.hostname,
                  port: url.port || (url.protocol === 'https:' ? 443 : 80),
                  path: url.pathname + (url.search || ''),
                  method: 'POST',
                  headers: {
                      'Content-Type': 'multipart/form-data; boundary=' + boundary,
                      'Content-Length': payload.length
              // Protokollwahl
              const protocol = url.protocol === 'https:' ? https : http;
              // HTTP Request
              const req = protocol.request(options, function(res) {
                  console.log('ImageUploadStatusCode:', res.statusCode);
                  res.on('data', function(chunk) {
                      console.log('Response:', chunk.toString());
              req.on('error', function(e) {
                  console.error('Fehler beim Hochladen:', e.message);
              req.write(payload);
              req.end();
      Na ja, ich bin jetzt mal ehrlich. Ich habe ChatGPT solange damit gernervt bis ich eine Version hatte die jetzt funktioniert.
      Ich habe keine Ahnung was da wie gemacht wird, aber es läuft. Die TAG werden sehr schnell aktualisiert und alles ohne Fehlermeldungen. 😊
      Manfred
      • BananaJoe
        BananaJoe Most Active @bimmi last edited by
        @bimmi ich hatte zwischendurch das Problem das der Speicherplatz (also nicht RAM sondern "Disk") der AP voll war, dann gab es auch mal "halbe" Bilder auf den Tags. Habe die ganzen Firmware-Dateien im Dateisystem gelöscht die da noch rumlagen, nun sind es wieder immer um die 400K frei
          Beowolf last edited by
          Ich hatte einen AP jetzt etwas länger abgeschaltet (ohne Strom). Jetzt steht bei allen TAGs "Timeout".
          Finden sich AP und TAGs automatisch wieder? Es sind jetzt schon mehr 24 Stunden her.
            bimmi @Beowolf last edited by
            @beowolf wenn länger kein tag erreichbar war, dann verbinden sie sich "theoretisch" alle 24 Stunden erneut. Beschleunigen kannst Du es, in dem Du die Tags kurzschließt, dann Batterien gemäß Anleitung wieder einsetzen!
              bimmi @BananaJoe last edited by
              @bananajoe Die "pending" Grafiken werden bei einem Neustart automatisch gelöscht. Steht auch so im seriellen Log. Ich hab ja einen c6 AP. Der hat 8MB freien flash.
              BananaJoe 2 Replies Last reply Reply Quote 0
              • BananaJoe
                @bimmi sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                Ich hatte das Neustarten von "alle 2h" wieder etwas hochgeschraubt ... war wohl nicht gut. Meine Variante hat halt erheblich weniger Speicher. Ich sehe gerade das es eine Firmware 2.60 gibt bei die notwendigen Tag-Files dynamisch nachgeladen werden, das sollte auch noch mal Platz sparen.
                • BananaJoe
                  @bimmi Nachtrag: Ich habe auch einen ESP32-C6 AP - und:
                    @bananajoe da stimmt dann aber was nicht bei dir:
                    was sagen denn der Ordner "current"
                      A Former User @bimmi last edited by
                      @bimmi
                      Gibt ein Update für den AP auf Software 2.6b
                      B B 2 Replies Last reply Reply Quote 0
                        bimmi @Guest last edited by
                        @ilovegym hab ich drauf 👌
                          Beowolf @Guest last edited by
                          @ilovegym sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                          @bimmi
                          Habe ich auch gerade gemacht. Ist nicht wirklich ein Fortschritt.
                          Mein TAG auf dem meine Google-Termine angezeigt werden, hat einen blass roten Hintergrund.
                          Genauso wie das TAG auf dem ich die Wettervorhersage habe.
                          Die Buttons der schwarzen TAGs funktionieren nicht.
                          Oder habe ich etwas falsch gemacht?
                            @beowolf sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                            @bimmi
                            Also die Buttons funktionieren bei mir. Du musst aber mein Script neu starten evtl. Einen Hintergrund habe ich nicht. Vielleicht doch mal den Display kurz resetten?
                              bimmi @BananaJoe last edited by bimmi
                              @bananajoe sagte in E-INK Display OpenEPaperLink - Displayanzeige mit Batterie:
                              Die Access Points starten auch ohne Script täglich um 4 Uhr neu! Das ist so in der Software hinterlegt und erfolgt ohne jegliches zutun soweit mir bekannt.
                                Beowolf @bimmi last edited by Beowolf
                                @bimmi
                                So, ich habe jetzt noch mal das Update gemacht. Wieder sind ein paar Displays blass rosa.
                                Bei der Wettervorhersage, Regenvorhersage, Googlekalender (kleines Display), Wetter heute.
                                Hier mal ein Bild. Resetten der TAGs hat nichts gebracht. Ich habe die an einem Yellow AP.
                                Buttons gehen aber nach Neustart des Skript.
                                Hier mal ein Bild. Die Datumsanzeige dient nur als Vergleich.
                                  @beowolf klick mal auf den kleinen Pfeil in den Display settings und stell da mal bei LUT auf "always full refresh"
                                    @bimmi
                                    Das steht bei allen. Ich kann da auch keines andere Einstellung auswählen.
                                    Wenn ich wieder aus 2.52 zurück gehe, sind alle Displays wieder normal.
                                    Ich mache das jetzt mal über diese Seite.
                                    https://install.openepaperlink.de/
                                    Mal schauen.
                                      bimmi @Beowolf last edited by bimmi
                                      @BananaJoe (sorry war der falsche markiert vorher) ich vermute das dein Ordner current voll ist. So wie hier:
                                      Das hatte ich nämlich auch mit einer alpha Version.
                                      Die .pending werden theoretisch alle beim Neustart gelöscht. Evtl kann er das bei dir nicht. Da hilft denke ich auch ein clean Flash.
                                        Beowolf last edited by Beowolf
                                        So, habe jetzt komplett neu geflasht. Ein TAG neu angelernt. Aktuelles Datum ausgewählt. Anzeige wieder rosa.
                                        Bin wieder auf 2.52. Die läuft.
                                          @beowolf also ich kann da diverse Möglichkeiten auswählen. Das musst du an dem ap machen der die Bilder bereitstellt.
                                          • BananaJoe
                                            Mit hochschrauben meinte ich das ich auf Grund deiner Aussage das zwischendurch sogar ganz ausgeschaltet hatte - und mich also nur auf dem 04:00 Uhr Neustart verlassen hatte. Das war nicht so gut, mit dem alle 2h Neustarten lief es stabil.
                                            Hab inzwischen auch vor beiden APs einen Sinilink mit Tasmota ( https://de.aliexpress.com/item/1005006532589211.html ) damit ich die Notfalls aus ferne neu angetreten bekomme - wenn die sich ganz weghängen dann natürlich wenn ich auf Geschäftsreise bin. Hab jetzt auch ein Überwachungsskript laufen das die einal Stromlos macht wenn die länger als 5 Minuten nicht erreichbar sind. Seit dem ich wieder auf 2h runter bin musste das aber noch wieder nicht eingreifen.
                                            1028
                                            336692
