    4. Auslesen HM-WDS30-OT2-SM2
    • MichaelSc
      MichaelSc @MichaelSc last edited by
      p.s.: Ah, sehe gerade auch Einträge im Log...
      hm-rpc.2
      2024-05-29 11:21:39.076 error Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      hm-rpc.2
      2024-05-29 11:21:39.064 info xmlrpc client is trying to connect to 192.168.178.200:2001/ with ["http://192.168.178.201:2001","iobroker:hm-rpc.2:599af0bf809a319337e95df3165dbba5"]
      hm-rpc.2
      2024-05-29 11:21:39.063 info xmlrpc server is trying to listen on 192.168.178.201:2001
      hm-rpc.2
      2024-05-29 11:21:38.875 info starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.12.2, js-controller: 5.0.19
      hm-rpc.2
      2024-05-29 11:21:06.901 info Terminated (NO_ERROR): Without reason
      hm-rpc.2
      2024-05-29 11:21:06.901 info terminating
      hm-rpc.2
      2024-05-29 11:21:06.858 error Cannot call init: [http://192.168.178.201:2001, ""] socket hang up
      hm-rpc.2
      2024-05-29 11:21:06.857 info xmlrpc -> 192.168.178.200:2001/ init ["http://192.168.178.201:2001",""]
      hm-rpc.2
      2024-05-29 11:21:06.856 error Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      hm-rpc.2
      2024-05-29 11:20:36.856 error Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
      hm-rpc.2
      2024-05-29 11:20:36.845 info xmlrpc client is trying to connect to 192.168.178.200:2001/ with ["http://192.168.178.201:2001","iobroker:hm-rpc.2:78001070cf5e5286086eca4a1af7d00a"]
      hm-rpc.2
      2024-05-29 11:20:36.845 info xmlrpc server is trying to listen on 192.168.178.201:2001
      hm-rpc.2
      2024-05-29 11:20:36.666 info starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.12.2, js-controller: 5.0.19
        paul53 @MichaelSc last edited by
        @michaelsc sagte: Parameter in der Instanz:
        Die sehen passend aus, wenn auf der CCU kein https aktiviert ist. Firewall auf der CCU?
          Homoran Global Moderator Administrators @MichaelSc last edited by
          @michaelsc sagte in Auslesen HM-WDS30-OT2-SM2:
          sieht meist nach u.a. Firewall der CCU aus, wie schon @paul53 schrieb.
          hast du Port 2001 freigegeben?
          Ansonsten die automatische Verwendung von https (o.ä.) mal ansehen
          MichaelSc 1 Reply Last reply Reply Quote 1
          • MichaelSc
            MichaelSc @Homoran last edited by
            @homoran @paul53 Danke für die prompte Antwort.
            Soso, die CCU3 hat eine Firewall - hab ich mich noch nie drum gekümmert.
            DIES sind derzeit die Einträge dort:
            Dass der iOBroker-Adapter-Zugriff bislang funktionierte, scheint trotz des Eintrags 1 "Ports blockiert" an den beiden folgenden Parametern zu liegen: "Zugriff auf angelernte Homematic-Geräte" und "Zugriff auf die Logikschicht", die eben nicht auf "Kein Zugriff" stehen, sondern auf "eingeschränkt. Aber das kann ich nur raten.
            Port 2001: Den gebe ich jetzt mal dort im Feld "Port-Freigabe" explizit frei.
            Im Log steht nun:
            hm-rpc.2
            2024-05-29 14:01:19.301 info Terminated (NO_ERROR): Without reason
            hm-rpc.2
            2024-05-29 14:01:19.301 info terminating
            hm-rpc.2
            2024-05-29 14:01:19.258 error Cannot call init: [http://192.168.178.201:2001, ""] Unknown XML-RPC tag 'TITLE'
            hm-rpc.2
            2024-05-29 14:01:19.255 info xmlrpc -> 192.168.178.200:2001/ init ["http://192.168.178.201:2001",""]
            hm-rpc.2
            2024-05-29 14:01:19.252 error Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
            hm-rpc.2
            2024-05-29 14:00:49.254 error Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
            hm-rpc.2
            2024-05-29 14:00:49.242 info xmlrpc client is trying to connect to 192.168.178.200:2001/ with ["http://192.168.178.201:2001","iobroker:hm-rpc.2:23873acdfc3239846071b153ff899f4c"]
            hm-rpc.2
            2024-05-29 14:00:49.242 info xmlrpc server is trying to listen on 192.168.178.201:2001
            hm-rpc.2
            2024-05-29 14:00:49.064 info starting. Version 1.17.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.12.2, js-controller: 5.0.19
            ...aber irgendwas ist noch nicht richtig, fürchte ich.
            MichaelSc 1 Reply Last reply Reply Quote 0
            • MichaelSc
              p.s.: Ich musste in diesem von mir für rfd extra installierten hm-rpc.2-Adapter noch "HTTPS" aktivieren,
              JETZT ist die Instanz grün:
              paul53 MichaelSc 2 Replies Last reply Reply Quote 0
                paul53 @MichaelSc last edited by paul53
                @michaelsc sagte: "HTTPS" aktivieren
                Das ist dann aber ein anderer Port (42001).
                • MichaelSc
                  Jetzt sind auch die neuen Datenpunkte des neuen HM-Geräts im iOBroker angekommen:
                  Das nennt man dann ja gerne auch: BINGO!
                  Dank Eurer Hilfe.
                  In hm-rega.0 ist übrigens der Parameter "rfd" unter Haupteinstellungen NICHT angekreuzt, also NICHT aktiviert.
                  Der "HomeMatic IP" Parameter dort ist hingegen aktiviert.
                  Erscheint mir dann irgendwie unlogisch: Aber funktioniert jetzt ja mit der neuen rpc.2-Instanz für rfd.
                  Verständnisfrage noch:
                  • meine neue Instanz hm-rpc.2 ist jetzt "nur" für rfd-Dämons zuständig und zeigt auch nur diese.
                    Korrekt?
                  • Warum hab ich eigentlich hm-rpc.0 und hm-rpc.1:
                    Die sind ja beide laut Parametern für den "HomeMatic IP"-Dämon da.
                    Und zeigen nach meinem Dafürhalten in den Objekten jeweils dieselben Datenpunkte, einmal in rpc.0
                    und einmal in rpc.1.
                  • Ist diese rpc-Instanz "aus Versehen" doppelt angelegt und somit unnötig? Also bspw die rpc.1 ist
                    eine Dublette von rpc.0 und obsolet?
                    @michaelsc sagte: In hm-rega.0 ist übrigens der Parameter "rfd" unter Haupteinstellungen NICHT angekreuzt
                    Dann werden keine Namen und Aufzählungen für "hm-rpc.2" aus der CCU übernommen.
                    Korrekt?
                    Korrekt.
                    Sieht so aus.
                    Was mich wundert: LOWBAT ist im Kanal 1 und nicht im Kanal 0?
                    EDIT: Ist laut Doku so.
                    • MichaelSc
                      MichaelSc @paul53 last edited by
                      @paul53 said in Auslesen HM-WDS30-OT2-SM2:
                      LowBat ist in Kanal 0 und in Kanal 1 und in Kanal 2.
                      rpc-0 und rpc-1: Wenn ich eine davon entfernen will, muss ich wohl irgendwie nur sicherstellen, dass in Scripten oder in VIews keine Referenz auf Datenpunkte vorkommt, die in der zu entfernden Instanz liegen.
                      Es gibt vermutlich keine Möglichkeit, wie in einer Art Crossreference zu schauen, ob bspw in rpc-0 irgendwas von irgendwo referenziert wird, bevor ich die rpc-0 deaktiviere oder lösche, oder gibt es sowas?
                      • MichaelSc
                        Ah, es gibt eine Krücke:
                          Projekt exportieren und in der Datei dann nach Substrings suchen, also bspw nach "hm-rpc.0".
                          Davon hab ich 5 Fundstellen.
                          Und Suchen nach "hm-rpc-1": Davon hab ich 849 Fundstellen.
                          Heisst: In Views hab ich fälschlicherweise 5 mal Datenpunkte aus rpc-0 referenziert, aber richtigerweise 849 mal aus rpc-1.
                          Nach Korrektur dieser 5 Stellen in irgendwelchen Views könnte ich die rpc-0 deaktivieren bzw. auch löschen.
                        • Scripte:
                          In Scripten mit dem Filter "hm-rpc.0" suchen: Das zeigt mir zwei Scripte an, in denen hab ich wohl fälschlicherweise Datenpunkte aus rpc-0 referenziert.
                          Nach Korrektur dieser 2 Scripte könnte ich die rpc-0 deaktivieren bzw. auch löschen.
                        Man wird ja erfinderisch.
                        691
