    4. Unifi Steuern ohne Adapter (Script,SSH)
      liv-in-sky @draexler last edited by
      @draexler sagte in Adapter: ioBroker.unifi:
      @ilovegym Kann man über ssh auch voucher für gästewlan generieren?
      teste mal das - da kannst du angeblich vouchers anlegen - habe die nicht aktiviert, daher kann ich nicht testen
      du musst die node-unifi in die zusätzlichen npm module in der js.instanz eintragen
      const Unifi = require('node-unifi');
      const unifi = new Unifi.Controller({hostname:"192.168.178.xx",port:'8443', sslverify: false});
      (async () => {
        try {
          // LOGIN
          const loginData = await unifi.login('user', 'password!');
          console.log('login: ' + loginData);
         //const switchmac="b4:fb:e4:f3:96:63"
          // Get data from a specific unifi device based on MAC address
          //const deviceData = await unifi.getAccessDevices(switchmac);
          // Console.log('getAccessDevices: ' + JSON.stringify(deviceData));
          // Get device id
          //const deviceId = deviceData[0]._id;
          //console.log('deviceId: ' + deviceId + ' ip: ' + deviceData[0].ip);
       // GET SITE STATS
         // const sites = await unifi.getSitesStats();
         // console.log('getSitesStats: ' + sites[0].name + ':' + sites.length);
         // console.log(JSON.stringify(sites));
          // GET SITE SYSINFO
         // const sysinfo = await unifi.getSiteSysinfo();
         // console.log('getSiteSysinfo: ' + sysinfo.length);
          //console.log(JSON.stringify(sysinfo));
          // GET CLIENT DEVICES
        //  const clientData = await unifi.getClientDevices();
         // console.log('getClientDevices: ' + clientData.length);
         // console.log(JSON.stringify(clientData));
          // GET ALL USERS EVER CONNECTED
          //const usersData = await unifi.getAllUsers();
          //console.log('getAllUsers: ' + usersData.length);
          //console.log(JSON.stringify(usersData));
          const clientVoucher = await unifi.createVouchers(123,1,0,"testthis");
          // LOGOUT
          const logoutData = await unifi.logout();
          console.log('logout: ' + JSON.stringify(logoutData));
        } catch (error) {
          console.log('ERROR: ' + error);
      draexler 1 Reply Last reply Reply Quote 0
      • draexler
        draexler @liv-in-sky last edited by
        @liv-in-sky Hört sich schon mal gut an. Also trage ich einfach in der js.instanz bei den npm Komponenten "node-unifi" ein? Wenn ja, wie geht es dann weiter? Arbeite wie die meisten hier nur mit Blockly...
          liv-in-sky @draexler last edited by liv-in-sky
          ja
          eintragen und enter drücken - sonst wird es nicht angenommen - die instanz startet dann neu
          ansschliessend script anlegen und hostname (zeile3) und user und kennwort (zeile8) anpassen
          dann:
          aufrufen und im voucher-admin nachsehen, ob was angekommen ist
            @draexler
            hier siehst du was in die klammer der funktion createVouchers kommen muss
            es müßte reichen, wenn du minutes,count,quota und note einträgst createVouchers(180,1,0,"testthisvoucher");
            • kmxak
              ich frage mal direkt dazwischen ob man den voucher code auch irgendwo abgreifen kann damit ich den irgendwo darstellen kann und nicht im portal schauen muss
                liv-in-sky @kmxak last edited by
                @kmxak
                das selbe script nur mit der funktion - teste mal -- ich hoffe es stimmt so
                const myVouchers = await unifi.getVouchers();
                console.log("vouchers: "+ myVouchers)
                • kmxak
                  mh ich bekomme aktuell Error: failed to detect UniFiOS status
                    @kmxak
                    ich nutze die controller auf linux installiert - hast du den auch
                    • kmxak
                      ne ich hab ne udm pro
                        @kmxak
                        das ist die seite, wo ich die infos her habe - https://github.com/jens-maus/node-unifi
                        laut diesem issue, sollte es theoretisch funktionieren https://github.com/jens-maus/node-unifi/issues/227
                        BobFrankston created this issue in jens-maus/node-unifi
                        open UDM Pro seems to need a URL without a port number #227
                          wer interesse hat, was alles gehen sollte
                          https://github.com/jens-maus/node-unifi/blob/master/unifi.js
                          bei mir werden rechts die ganzen funktionen angezeigt:
                            liv-in-sky @kmxak last edited by liv-in-sky
                            @kmxak
                            bei mir sind wohl noch alte vouchers im system
                            mit diesem script sehe ich sie und könnte sie dann in der vis anzeigen ode rüber telegram versenden ...
                            const unifi = new Unifi.Controller({hostname:"192.168.178.1xx",port:'8443', sslverify: false});
                            (async () => {
                             try {
                               // LOGIN
                               const loginData = await unifi.login('user', 'passw!');
                               // Get device id
                            // GET SITE STATS
                               // GET SITE SYSINFO
                            //   const clientVoucher = await unifi.createVouchers(123,1,0,"testthis");
                               console.log("vouchers: "+ JSON.stringify(myVouchers))
                               // LOGOUT
                             } catch (error) {
                            log:
                            script.js.MYSTUFF.ALLERLEI.AAAUNIFI.unifi-wlan-schalten3: vouchers: [{"duration":123,"qos_overwrite":false,"note":"testthis","code":"6566218181","for_hotspot":false,"create_time":1717058841,"quota":0,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"66583d19108fed3b1dc7283c","admin_name":"e","used":0,"status":"VALID_MULTI","status_expires":0},{"duration":123,"qos_overwrite":false,"note":"testthis","code":"7113118220","for_hotspot":false,"create_time":1717058021,"quota":0,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"665839e5108fed3b1dc72722","admin_name":"e","used":0,"status":"VALID_MULTI","status_expires":0},{"duration":123,"qos_overwrite":false,"note":"testthis","code":"4515536233","for_hotspot":false,"create_time":1717057059,"quota":0,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"66583623108fed3b1dc725f0","admin_name":"e","used":0,"status":"VALID_MULTI","status_expires":0},{"duration":5760,"qos_overwrite":false,"note":null,"code":"8241421156","for_hotspot":false,"create_time":1650354689,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"625e6a0197578402ac2db67c","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":5760,"qos_overwrite":false,"note":null,"code":"7446834263","for_hotspot":false,"create_time":1650354689,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"625e6a0197578402ac2db67b","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":525600,"qos_overwrite":false,"note":null,"code":"7358319725","for_hotspot":false,"create_time":1650354660,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"625e69e497578402ac2db679","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":1440,"qos_overwrite":false,"note":null,"code":"2729460620","for_hotspot":false,"create_time":1627921177,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"61081b1997578402177f7096","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":1440,"qos_overwrite":false,"note":null,"code":"1795017450","for_hotspot":false,"create_time":1627921177,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"61081b1997578402177f7095","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":1440,"qos_overwrite":false,"note":null,"code":"2281225310","for_hotspot":false,"create_time":1627921177,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"61081b1997578402177f7094","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":1440,"qos_overwrite":false,"note":null,"code":"0356279115","for_hotspot":false,"create_time":1627921177,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"61081b1997578402177f7093","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":1440,"qos_overwrite":false,"note":null,"code":"3544056744","for_hotspot":false,"create_time":1627921177,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"61081b1997578402177f7092","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":1440,"qos_overwrite":false,"note":null,"code":"6426769406","for_hotspot":false,"create_time":1627921177,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"61081b1997578402177f7091","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":1440,"qos_overwrite":false,"note":null,"code":"2298091277","for_hotspot":false,"create_time":1627921177,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"61081b1997578402177f7090","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":1440,"qos_overwrite":false,"note":null,"code":"8878654311","for_hotspot":false,"create_time":1627921177,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"61081b1997578402177f708f","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":1440,"qos_overwrite":false,"note":null,"code":"6946187591","for_hotspot":false,"create_time":1627921177,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"61081b1997578402177f708e","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0},{"duration":1440,"qos_overwrite":false,"note":null,"code":"0579279641","for_hotspot":false,"create_time":1627921177,"quota":1,"site_id":"5cadc7f53b6a3967dd7e5369","_id":"61081b1997578402177f708d","admin_name":"e","used":0,"status":"VALID_ONE","status_expires":0}]
                            im log ist der erste eintrag ein test mit 123... - wurde wohl angelegt - damit funktioniert es wohl
                            kmxak 1 Reply Last reply Reply Quote 0
                            • kmxak
                              die info mit dem port dazu müsste ich ja den code ändern.
                              die letzte info mit den funktionen ist nützlich. wie bekommst die anzeige hin? mir wird das in github nicht angezeigt
                                @kmxak
                                das weiß ich nicht 😞 war einfach da - wie sieht es bei dir aus
                                • kmxak
                                  kmxak Most Active @liv-in-sky last edited by
                                  @liv-in-sky sagte in Adapter: ioBroker.unifi:
                                  @kmxak
                                  (async () => {
                                   try {
                                     // LOGIN
                                     // Get device id
                                  // GET SITE STATS
                                     // GET SITE SYSINFO
                                     // LOGOUT
                                   } catch (error) {
                                  log(getObject('system.host.iobroker59').native.os.platform)
                                  log:
                                  dazu müsste ich erstmal den login fixen. ich habe ja noch andere sachen da laufen die können sich verbinden. auch der protect adapter kann sich verbinden... mal sehen wenn ich mal zeit habe ... lege es auf den haufen mit todo 😬
                                  • kmxak
                                    @kmxak
                                    sorry mein fehler war mit dem browser nicht eingeloggt.
                                    • kmxak
                                      kmxak Most Active last edited by kmxak
                                      ah, jetzt geht es... falscher port 🤦
                                      bekomme aber nur:
                                      javascript.0	11:50:46.998	info	script.js.User.Unifi.Unifi_Node: login: true
                                      javascript.0	11:50:47.064	info	script.js.User.Unifi.Unifi_Node: vouchers: [object Object],[object Object],[object Object],[object Object],[object Object]
                                      javascript.0	11:50:47.084	info	script.js.User.Unifi.Unifi_Node: logout: {"success":true}
                                      der hier funzt nicht mit deinem aus dem code geht es
                                        @kmxak sagte in Adapter: ioBroker.unifi:
                                        kannst du ja machen - die datei unifi.js liegt ja im verzeichnis vom iobroker
                                        auf eigene verantwortung
                                          mein fehler
                                          so muss es heißen
                                          • kmxak
                                            ja danke damit ging es und es funktioniert.
                                            Damit kann ich ja weiterarbeiten.
                                            ? 1 Reply Last reply Reply Quote 1
                                            152
                                            25084
