    4. JavaScript
    5. [gelöst] Skript auf AXIOS/httpGet umbauen
    • DJMarc75
      DJMarc75 @c1olli last edited by
      @c1olli sagte in [gelöst] Skript auf AXIOS/httpGet umbauen:
      mal nachbauen
      Hier der Code:
       <variables>
         <variable id="drQ7X.#QyMv~vHo@GDs;">strasse</variable>
         <variable id="ggJ`Y7Hj%TP{~m,aUHvl">hausnummer</variable>
         <variable id="gYX7{E?a9SJhW+3w/R/7">plz</variable>
         <variable id="!c!Un^HjYgNu;8;]|E(m">stadt</variable>
       </variables>
       <block type="on_ext" id="K/U(@rJcV0T3fFm_U?fI" x="-112" y="-262">
         <value name="OID0">
           <shadow type="field_oid" id="6H,]307%,0/,9_W3]V{V">
             <field name="oid">0_userdata.0.GPS.Iris.Adressabfrage</field>
           <block type="http_get" id="er#Datp2ZE*VyGUa%*Kv">
             <field name="TIMEOUT">2000</field>
             <field name="UNIT">ms</field>
             <field name="TYPE">text</field>
             <value name="URL">
               <shadow type="text" id="Q_WE@|3:]0*%[l-.!;qf">
                 <field name="TEXT"></field>
               <block type="text_join" id="-ys2STS:FUWU@%[8~o[=">
                 <mutation items="5"></mutation>
                 <value name="ADD0">
                   <block type="text" id="B25~4=^wMHf(vUb3ay~3">
                     <field name="TEXT">https://nominatim.openstreetmap.org/reverse.php?format=json&amp;lat=</field>
                 <value name="ADD1">
                   <block type="get_value" id="V(%bMmxXw:3ABhXT0GfD">
                     <field name="OID">0_userdata.0.GPS.Iris.lat</field>
                 <value name="ADD2">
                   <block type="text" id="==#V5Ah1PyKx_!-*~JfY">
                     <field name="TEXT">&amp;lon=</field>
                 <value name="ADD3">
                   <block type="get_value" id="dx9Ys/Q#/nM}4rloE:U)">
                     <field name="OID">0_userdata.0.GPS.Iris.lon</field>
                 <value name="ADD4">
                   <block type="text" id="[JnnacT#;5U-rwb.89lc">
                     <field name="TEXT">&amp;zoom=18</field>
               <block type="variables_set" id="@R1(68Y`?jL$-(fnu32C">
                 <field name="VAR" id="drQ7X.#QyMv~vHo@GDs;">strasse</field>
                   <block type="get_attr" id="tr3S#a+i=/D8NYaWGO@j">
                     <value name="PATH">
                       <shadow type="text" id="q%EjOz6ZjLEbYmW~@f}M">
                         <field name="TEXT">address.road</field>
                     <value name="OBJECT">
                       <shadow type="get_object" id="Qer-kj87T80z@MTRH#Y1">
                       <block type="http_response" id="_gGT}ZW#@W$AmeQ`8vhb">
                         <field name="ATTR">response.data</field>
                   <block type="variables_set" id="4cb.V+y)fXV%?Q|h=Ff:">
                     <field name="VAR" id="ggJ`Y7Hj%TP{~m,aUHvl">hausnummer</field>
                       <block type="get_attr" id="bKs5r!Wek;EgN_pSUH8X">
                         <value name="PATH">
                           <shadow type="text" id=":u,bX-^sWd/E+Pk/q?YL">
                             <field name="TEXT">address.house_number</field>
                           <shadow type="get_object" id="(]w=~t!OyL@W$NhYQZHR">
                           <block type="http_response" id=";aP9$RX~6=KBUURme%h4">
                       <block type="variables_set" id="3yyJY~EYJBQarxtP#.1S">
                         <field name="VAR" id="gYX7{E?a9SJhW+3w/R/7">plz</field>
                           <block type="get_attr" id="]1EO90jX.rx27kOH@e-Z">
                             <value name="PATH">
                               <shadow type="text" id="PjSln4sjaH|$Ng0jHfV:">
                                 <field name="TEXT">address.postcode</field>
                               <shadow type="get_object" id="PbBf0NNQz0m=zUJS/fCc">
                               <block type="http_response" id=":17_jnzNm**FINVzm?5V">
                           <block type="variables_set" id="L$Qkezk1JPBs5?)CW8:K">
                             <field name="VAR" id="!c!Un^HjYgNu;8;]|E(m">stadt</field>
                               <block type="get_attr" id="Qnc1Eg[2RynX`HS{:Ah[">
                                 <value name="PATH">
                                   <shadow type="text" id="/yF-3$eHlTv9gr|[n+3g">
                                     <field name="TEXT">address.town</field>
                                   <shadow type="get_object" id="#R_ePZe`[v9xPmX{z;l!">
                                   <block type="http_response" id="1r{Q5-/}%#2@5:l}CGZW">
                               <block type="update" id="PLQro)/xPeu5MB?x31%t">
                                 <field name="OID">0_userdata.0.GPS.Iris.Adresse</field>
                                   <block type="text_join" id="(5r7}mRPM#UT5=$SV)vG">
                                     <mutation items="7"></mutation>
                                     <value name="ADD0">
                                       <block type="variables_get" id="HFU$j9)IT:p4zp1x!AS_">
                                     <value name="ADD1">
                                       <block type="text" id="XVP:]Az/`AOm+,r6tV$F">
                                         <field name="TEXT"> </field>
                                     <value name="ADD2">
                                       <block type="variables_get" id="qR=uS^ED,:!I`A4fXicK">
                                     <value name="ADD3">
                                       <block type="text" id="r[MfE/Tbm#kRpy(lIm,U">
                                         <field name="TEXT">, </field>
                                     <value name="ADD4">
                                       <block type="variables_get" id="1zR[?t$=z:gD4Gw.hx5)">
                                     <value name="ADD5">
                                       <block type="text" id=":$QEo*DLh-T`=KbRJBK[">
                                     <value name="ADD6">
                                       <block type="variables_get" id="Z=/JCdH(pxGXW0YZFas|">
      Anzupassen sind natürlich die 4 Datenpunkte.
        Homoran Global Moderator Administrators @spicer last edited by
        @spicer sagte in [gelöst] Skript auf AXIOS/httpGet umbauen:
        Es wäre für @c1olli sicher einfacher, wenn Du die xml vom Blockly posten würdest
        geht es um einfacher oder um Verstehen?
        spicer 1 Reply Last reply Reply Quote 1
        • spicer
          spicer @Homoran last edited by
          @homoran sagte in [gelöst] Skript auf AXIOS/httpGet umbauen:
          Einfacher. So muss er das nicht alles selber bauen 😉
          C 1 Reply Last reply Reply Quote 1
            c1olli @spicer last edited by
            Euch allen danke für die Mühe.
            Mir ging es hauptsächlich um das Verstehen, da ich ein anderes Blockly nur umbauen wollte, es aber nicht hinbekommen habe.
            Ich wusste eben nicht wie die Quelle der Daten anzusprechen war.
            "Data" war wohl zu einfach.
            Und die Nutzung von "debug output" hab ich jetzt auch verstanden.
            Ein kleiner Teil fehlt mir noch, aber da will ich erst einmal probieren.
              heinz527 last edited by heinz527
              und zack, habe ich es schon wieder bereut ein Update gemacht zu haben....
              Nachdem meine Protokolle mit Warnmeldungen überlaufen habe ich diesen Thread gefunden. In meinem Blockly das Feld ersetzt und: geht nicht..... Es werden keine Werte mehr eingetragen.
              Ich habe mir alles hier mehrfach durchgelesen, da ich aber kein Experte bin, bekomme ich es nicht hin....
              Kann mir jemand sagen, was ich falsch mache?
              Alt:
              var result;
              on({ id: [].concat(['mqtt.0.pv']), change: 'ne' }, async (obj) => {
                let value = obj.state.val;
                try {
                  require("request")('http://192.xxx.xxx.xxx/status', async (error, response, result) => {
                    setState('0_userdata.0.PV_Anlage.PV_Inverter_Status' /* PV_Inverter_Status */, parseFloat(getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'InverterStatus')), true);
                  setState('0_userdata.0.PV_Anlage.PV_Inverter_Temp' /* PV_Inverter_Temp */, parseFloat(getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'InverterTemperature')), true);
                  setState('0_userdata.0.PV_Anlage.PV_Shine_Stick_MAC' /* PV_Shine_Stick_MAC */, getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'Mac'), true);
                  setState('0_userdata.0.PV_Anlage.PV_OutputPower' /* PV_OutputPower */, parseFloat(getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'OutputPower')), true);
                  setState('0_userdata.0.PV_Anlage.PV_InputPower' /* PV_InputPower */, parseFloat(getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'InputPower')), true);
                  setState('0_userdata.0.PV_Anlage.PV_TodayGenerateEnergy' /* PV_TodayGenerateEnergy */, parseFloat(getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'TodayGenerateEnergy')), true);
                  setState('0_userdata.0.PV_Anlage.PV_TotalGenerateEnergy' /* PV_TotalGenerateEnergy */, parseFloat(getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'TotalGenerateEnergy')), true);
                  setState('0_userdata.0.PV_Anlage.PV_PV1Voltage' /* PV_PV1Voltage */, parseFloat(getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'PV1Voltage')), true);
                  setState('0_userdata.0.PV_Anlage.PV_GridFrequency' /* PV_GridFrequency */, parseFloat(getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'GridFrequency')), true);
                  setState('0_userdata.0.PV_Anlage.PV_TWorkTimeTotal' /* PV_TWorkTimeTotal */, parseFloat(getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'TWorkTimeTotal')), true);
                  setState('0_userdata.0.PV_Anlage.PV_PV1InputAmpere' /* PV_PV1InputAmpere */, parseFloat(getAttr((function () { try { return JSON.parse(result); } catch (e) { return {}; }})(), 'PV1InputCurrent')), true);
                  }).on("error", (e) => { console.error(e); });
                } catch (e) { console.error(e); }
                console.warn('request blockly block is deprecated - please use "http (GET)" instead');
              parseFloat();
              parseFloat();
              //JTNDeG1sJTIweG1sbnMlM0QlMjJodHRwcyUzQSUyRiUyRmRldmVsb3BlcnMuZ29vZ2xlLmNvbSUyRmJsb2NrbHklMkZ4bWwlMjIlM0UlM0N2YXJpYWJsZXMlM0UlM0N2YXJpYWJsZSUyMGlkJTNEJTIyOCFsSl85ZkZzJTJDJTNEYno5QSlBJTJCRlMlMjIlM0VyZXN1bHQlM0MlMkZ2YXJpYWJsZSUzRSUzQyUyRnZhcmlhYmxlcyUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMm9uX2V4dCUyMiUyMGlkJTNEJTIyb0V3T1NRbSolNUVkVEowZ1R4fnBfRyUyMiUyMHglM0QlMjItODclMjIlMjB5JTNEJTIyLTQ4NyUyMiUzRSUzQ211dGF0aW9uJTIweG1sbnMlM0QlMjJodHRwJTNBJTJGJTJGd3d3LnczLm9yZyUyRjE5OTklMkZ4aHRtbCUyMiUyMGl0ZW1zJTNEJTIyMSUyMiUzRSUzQyUyRm11dGF0aW9uJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyQ09ORElUSU9OJTIyJTNFbmUlM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMkFDS19DT05ESVRJT04lMjIlM0UlM0MlMkZmaWVsZCUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMk9JRDAlMjIlM0UlM0NzaGFkb3clMjB0eXBlJTNEJTIyZmllbGRfb2lkJTIyJTIwaWQlM0QlMjJmdVNEaE1NJTNCeU1QJTNBc0Z+SyUyQyUyRmUlM0YlMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJvaWQlMjIlM0VtcXR0LjAucHYlM0MlMkZmaWVsZCUzRSUzQyUyRnNoYWRvdyUzRSUzQyUyRnZhbHVlJTNFJTNDc3RhdGVtZW50JTIwbmFtZSUzRCUyMlNUQVRFTUVOVCUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMnJlcXVlc3QlMjIlMjBpZCUzRCUyMllJaWlyRlJKUnElN0RoUmFVJTdEJTNEYUxYJTIyJTNFJTNDbXV0YXRpb24lMjB4bWxucyUzRCUyMmh0dHAlM0ElMkYlMkZ3d3cudzMub3JnJTJGMTk5OSUyRnhodG1sJTIyJTIwd2l0aF9zdGF0ZW1lbnQlM0QlMjJ0cnVlJTIyJTNFJTNDJTJGbXV0YXRpb24lM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJXSVRIX1NUQVRFTUVOVCUyMiUzRVRSVUUlM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMkxPRyUyMiUzRSUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVVJMJTIyJTNFJTNDc2hhZG93JTIwdHlwZSUzRCUyMnRleHQlMjIlMjBpZCUzRCUyMnBVJTNBdiFFR28wJTNBJTVEZiFHc08lMjN4YyUzQiUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMlRFWFQlMjIlM0VodHRwJTNBJTJGJTJGMTkyLjE2OC4xMDAuNzElMkZzdGF0dXMlM0MlMkZmaWVsZCUzRSUzQyUyRnNoYWRvdyUzRSUzQyUyRnZhbHVlJTNFJTNDc3RhdGVtZW50JTIwbmFtZSUzRCUyMlNUQVRFTUVOVCUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMnVwZGF0ZSUyMiUyMGlkJTNEJTIydXFzOSUzQiUzRFdiaXBsJTI1MTZIUm0yJTQwJTdCJTIyJTNFJTNDbXV0YXRpb24lMjB4bWxucyUzRCUyMmh0dHAlM0ElMkYlMkZ3d3cudzMub3JnJTJGMTk5OSUyRnhodG1sJTIyJTIwZGVsYXlfaW5wdXQlM0QlMjJmYWxzZSUyMiUzRSUzQyUyRm11dGF0aW9uJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyT0lEJTIyJTNFMF91c2VyZGF0YS4wLlBWX0FubGFnZS5QVl9JbnZlcnRlcl9TdGF0dXMlM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMldJVEhfREVMQVklMjIlM0VGQUxTRSUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X3RvbnVtYmVyJTIyJTIwaWQlM0QlMjIyMWYocUt4X0UoayUyNUxZdCUzQlclN0N5WSUyMiUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyZ2V0X2F0dHIlMjIlMjBpZCUzRCUyMlIlMjRkMTFUUzR0SHlCcVMlM0YwQSU1QndyJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyUEFUSCUyMiUzRSUzQ3NoYWRvdyUyMHR5cGUlM0QlMjJ0ZXh0JTIyJTIwaWQlM0QlMjI0bSolNDBFWUdHJTQwJTVEayUzRmZiJTNGKGdIUnAlMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJURVhUJTIyJTNFSW52ZXJ0ZXJTdGF0dXMlM0MlMkZmaWVsZCUzRSUzQyUyRnNoYWRvdyUzRSUzQyUyRnZhbHVlJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyT0JKRUNUJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyY29udmVydF9qc29uMm9iamVjdCUyMiUyMGlkJTNEJTIyJTdEOTJXKVhLUCU3QiUzQiUzQiUzQiU2MCU3QmElN0N0WlVyJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJ2YXJpYWJsZXNfZ2V0JTIyJTIwaWQlM0QlMjIlM0I2eHklMkZSWTZGcVVaJTJGJTNEJTdCaiolNUJ5RSUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMlZBUiUyMiUyMGlkJTNEJTIyOCFsSl85ZkZzJTJDJTNEYno5QSlBJTJCRlMlMjIlM0VyZXN1bHQlM0MlMkZmaWVsZCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0NuZXh0JTNFJTNDYmxvY2slMjB0eXBlJTNEJTIydXBkYXRlJTIyJTIwaWQlM0QlMjJGQiUyM1YlM0ElNUVlYiU2MEMlNUI0RWJ1MSU1QiU1RS5zJTIyJTNFJTNDbXV0YXRpb24lMjB4bWxucyUzRCUyMmh0dHAlM0ElMkYlMkZ3d3cudzMub3JnJTJGMTk5OSUyRnhodG1sJTIyJTIwZGVsYXlfaW5wdXQlM0QlMjJmYWxzZSUyMiUzRSUzQyUyRm11dGF0aW9uJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyT0lEJTIyJTNFMF91c2VyZGF0YS4wLlBWX0FubGFnZS5QVl9JbnZlcnRlcl9UZW1wJTNDJTJGZmllbGQlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJXSVRIX0RFTEFZJTIyJTNFRkFMU0UlM0MlMkZmaWVsZCUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyY29udmVydF90b251bWJlciUyMiUyMGlkJTNEJTIyQTBSLXhhciU3QzNEeW0xYyU1RXkzVyUyRkElMjIlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJWQUxVRSUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmdldF9hdHRyJTIyJTIwaWQlM0QlMjItUlNRQXJiJTJGdjRVcWVqWkRsYkZOJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyUEFUSCUyMiUzRSUzQ3NoYWRvdyUyMHR5cGUlM0QlMjJ0ZXh0JTIyJTIwaWQlM0QlMjItcnMlNjB2JTdCMiUyNElPU35NLiUyM0IxTVolN0MlMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJURVhUJTIyJTNFSW52ZXJ0ZXJUZW1wZXJhdHVyZSUzQyUyRmZpZWxkJTNFJTNDJTJGc2hhZG93JTNFJTNDJTJGdmFsdWUlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJPQkpFQ1QlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X2pzb24yb2JqZWN0JTIyJTIwaWQlM0QlMjJ1XzRXNE1BU2QlNDBNWCUyNVElMkYlMjR2KUZiJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJ2YXJpYWJsZXNfZ2V0JTIyJTIwaWQlM0QlMjJIZnZoJTVCUUwlM0ExcEQoTGJkMU9TU00lMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJWQVIlMjIlMjBpZCUzRCUyMjghbEpfOWZGcyUyQyUzRGJ6OUEpQSUyQkZTJTIyJTNFcmVzdWx0JTNDJTJGZmllbGQlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDbmV4dCUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMnVwZGF0ZSUyMiUyMGlkJTNEJTIyM0pncGlRJTVEMmY3RFR5OCFqfn5PaiUyMiUzRSUzQ211dGF0aW9uJTIweG1sbnMlM0QlMjJodHRwJTNBJTJGJTJGd3d3LnczLm9yZyUyRjE5OTklMkZ4aHRtbCUyMiUyMGRlbGF5X2lucHV0JTNEJTIyZmFsc2UlMjIlM0UlM0MlMkZtdXRhdGlvbiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMk9JRCUyMiUzRTBfdXNlcmRhdGEuMC5QVl9BbmxhZ2UuUFZfU2hpbmVfU3RpY2tfTUFDJTNDJTJGZmllbGQlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJXSVRIX0RFTEFZJTIyJTNFRkFMU0UlM0MlMkZmaWVsZCUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyZ2V0X2F0dHIlMjIlMjBpZCUzRCUyMipPaWolM0FidUVXQVh5RTJxcSUzQSUyQkoqJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyUEFUSCUyMiUzRSUzQ3NoYWRvdyUyMHR5cGUlM0QlMjJ0ZXh0JTIyJTIwaWQlM0QlMjIlNjAhJTdCa2NPZyU1RSU3RCU0MHZTfiUyQ3pNIWttVCUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMlRFWFQlMjIlM0VNYWMlM0MlMkZmaWVsZCUzRSUzQyUyRnNoYWRvdyUzRSUzQyUyRnZhbHVlJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyT0JKRUNUJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyY29udmVydF9qc29uMm9iamVjdCUyMiUyMGlkJTNEJTIydiU3QyU3REp0JTQwXyU3RG4lNUJoV0VLa3pQJTVERFAlMjIlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJWQUxVRSUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMnZhcmlhYmxlc19nZXQlMjIlMjBpZCUzRCUyMk4lNUItSG4lM0F5VENTZig4cWQlMkNaTmg1JTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyVkFSJTIyJTIwaWQlM0QlMjI4IWxKXzlmRnMlMkMlM0RiejlBKUElMkJGUyUyMiUzRXJlc3VsdCUzQyUyRmZpZWxkJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDbmV4dCUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMnVwZGF0ZSUyMiUyMGlkJTNEJTIyY253aUU4SGJib1QlN0IlM0RhJTIzUF9CJTYwYiUyMiUzRSUzQ211dGF0aW9uJTIweG1sbnMlM0QlMjJodHRwJTNBJTJGJTJGd3d3LnczLm9yZyUyRjE5OTklMkZ4aHRtbCUyMiUyMGRlbGF5X2lucHV0JTNEJTIyZmFsc2UlMjIlM0UlM0MlMkZtdXRhdGlvbiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMk9JRCUyMiUzRTBfdXNlcmRhdGEuMC5QVl9BbmxhZ2UuUFZfT3V0cHV0UG93ZXIlM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMldJVEhfREVMQVklMjIlM0VGQUxTRSUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X3RvbnVtYmVyJTIyJTIwaWQlM0QlMjIuJTdCJTNBa2xvJTdCeHIlMkZib3JsKUJ4U0I2JTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJnZXRfYXR0ciUyMiUyMGlkJTNEJTIyVjZtMTJPIXdyJTdEKmVUUDBjKW4lNUUlMkMlMjIlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJQQVRIJTIyJTNFJTNDc2hhZG93JTIwdHlwZSUzRCUyMnRleHQlMjIlMjBpZCUzRCUyMnZFQjJQUC5HeWRsS3FqVmRUUzUlMkYlMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJURVhUJTIyJTNFT3V0cHV0UG93ZXIlM0MlMkZmaWVsZCUzRSUzQyUyRnNoYWRvdyUzRSUzQyUyRnZhbHVlJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyT0JKRUNUJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyY29udmVydF9qc29uMm9iamVjdCUyMiUyMGlkJTNEJTIyJTJDMSp1UGR3JTI1JTVCWm1yJTIzJTNBNUNqNSpaJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJ2YXJpYWJsZXNfZ2V0JTIyJTIwaWQlM0QlMjJPJTVCUCUyQ2MzJTI0YlcqJTNBY3VkSjF0Z09uJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyVkFSJTIyJTIwaWQlM0QlMjI4IWxKXzlmRnMlMkMlM0RiejlBKUElMkJGUyUyMiUzRXJlc3VsdCUzQyUyRmZpZWxkJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQ25leHQlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJ1cGRhdGUlMjIlMjBpZCUzRCUyMiUzREQlMjU2JTNBJTNBISUzQUQ1c1VCJTdCME1wUktIJTIyJTNFJTNDbXV0YXRpb24lMjB4bWxucyUzRCUyMmh0dHAlM0ElMkYlMkZ3d3cudzMub3JnJTJGMTk5OSUyRnhodG1sJTIyJTIwZGVsYXlfaW5wdXQlM0QlMjJmYWxzZSUyMiUzRSUzQyUyRm11dGF0aW9uJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyT0lEJTIyJTNFMF91c2VyZGF0YS4wLlBWX0FubGFnZS5QVl9JbnB1dFBvd2VyJTNDJTJGZmllbGQlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJXSVRIX0RFTEFZJTIyJTNFRkFMU0UlM0MlMkZmaWVsZCUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyY29udmVydF90b251bWJlciUyMiUyMGlkJTNEJTIyLWc3dDRDJTJDLm0lN0R5NSU3Q28lMjVnJTJGWCUzQlQlMjIlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJWQUxVRSUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmdldF9hdHRyJTIyJTIwaWQlM0QlMjI1JTJGdHk2JTI0JTJGbGUlN0RuSm1JJTVCQUFtNSU3QiUyMiUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlBBVEglMjIlM0UlM0NzaGFkb3clMjB0eXBlJTNEJTIydGV4dCUyMiUyMGlkJTNEJTIyeCElMjQtcUd1TTMuWiUyNHhQVkJKX0glMkMlMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJURVhUJTIyJTNFSW5wdXRQb3dlciUzQyUyRmZpZWxkJTNFJTNDJTJGc2hhZG93JTNFJTNDJTJGdmFsdWUlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJPQkpFQ1QlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X2pzb24yb2JqZWN0JTIyJTIwaWQlM0QlMjIlMjQlN0RuV182JTJGJTI0bWglM0FobHVxdTF1JTJCcCUyMiUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIydmFyaWFibGVzX2dldCUyMiUyMGlkJTNEJTIyJTVFYXJoTnh2ajklNUIlM0IlMkJjJTNELkMlM0QlM0Z3UCUyMiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMlZBUiUyMiUyMGlkJTNEJTIyOCFsSl85ZkZzJTJDJTNEYno5QSlBJTJCRlMlMjIlM0VyZXN1bHQlM0MlMkZmaWVsZCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0NuZXh0JTNFJTNDYmxvY2slMjB0eXBlJTNEJTIydXBkYXRlJTIyJTIwaWQlM0QlMjJQODUlMkNWJTI0RXFsSFIlN0RkJTdCUCUyMyUyNSUyQnNhJTIyJTNFJTNDbXV0YXRpb24lMjB4bWxucyUzRCUyMmh0dHAlM0ElMkYlMkZ3d3cudzMub3JnJTJGMTk5OSUyRnhodG1sJTIyJTIwZGVsYXlfaW5wdXQlM0QlMjJmYWxzZSUyMiUzRSUzQyUyRm11dGF0aW9uJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyT0lEJTIyJTNFMF91c2VyZGF0YS4wLlBWX0FubGFnZS5QVl9Ub2RheUdlbmVyYXRlRW5lcmd5JTNDJTJGZmllbGQlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJXSVRIX0RFTEFZJTIyJTNFRkFMU0UlM0MlMkZmaWVsZCUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyY29udmVydF90b251bWJlciUyMiUyMGlkJTNEJTIySXVNX21jJTYwX0FLZXFqSk1Pei0lMkJyJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJnZXRfYXR0ciUyMiUyMGlkJTNEJTIyJTJDJTYwWWZJJTdEKHhaYiglMjNDYmY1YyU3Q051JTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyUEFUSCUyMiUzRSUzQ3NoYWRvdyUyMHR5cGUlM0QlMjJ0ZXh0JTIyJTIwaWQlM0QlMjJpJTdDTSU3QiU3Q09DNUZrJTNEUUsuWEolMkMoSUMlMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJURVhUJTIyJTNFVG9kYXlHZW5lcmF0ZUVuZXJneSUzQyUyRmZpZWxkJTNFJTNDJTJGc2hhZG93JTNFJTNDJTJGdmFsdWUlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJPQkpFQ1QlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X2pzb24yb2JqZWN0JTIyJTIwaWQlM0QlMjI3VUFsJTdEUmFkSk42UyUyM3JLaXMqRjYlMjIlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJWQUxVRSUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMnZhcmlhYmxlc19nZXQlMjIlMjBpZCUzRCUyMiUyQiUyNSklMkZQNTF+TGQlMjNwfl82amIlMjNnJTNGJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyVkFSJTIyJTIwaWQlM0QlMjI4IWxKXzlmRnMlMkMlM0RiejlBKUElMkJGUyUyMiUzRXJlc3VsdCUzQyUyRmZpZWxkJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQ25leHQlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJ1cGRhdGUlMjIlMjBpZCUzRCUyMiUyNG9tUkhhRSUyRiUyRiU2MCU2MDFiIU4lMjNaJTNCVColMjIlM0UlM0NtdXRhdGlvbiUyMHhtbG5zJTNEJTIyaHR0cCUzQSUyRiUyRnd3dy53My5vcmclMkYxOTk5JTJGeGh0bWwlMjIlMjBkZWxheV9pbnB1dCUzRCUyMmZhbHNlJTIyJTNFJTNDJTJGbXV0YXRpb24lM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJPSUQlMjIlM0UwX3VzZXJkYXRhLjAuUFZfQW5sYWdlLlBWX1RvdGFsR2VuZXJhdGVFbmVyZ3klM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMldJVEhfREVMQVklMjIlM0VGQUxTRSUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X3RvbnVtYmVyJTIyJTIwaWQlM0QlMjJmJTdDJTdCKi1NZX42YjQlN0MlNjB4a1dPZyU3Q0slMjIlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJWQUxVRSUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmdldF9hdHRyJTIyJTIwaWQlM0QlMjJyJTVEY2klNDB0RTclMjMuQiUzQXNiUTJiJTJGTWQlMjIlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJQQVRIJTIyJTNFJTNDc2hhZG93JTIwdHlwZSUzRCUyMnRleHQlMjIlMjBpZCUzRCUyMjJWd1NSbEJ6JTI0JTVCWmk4dFlWJTJGJTdDTyolMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJURVhUJTIyJTNFVG90YWxHZW5lcmF0ZUVuZXJneSUzQyUyRmZpZWxkJTNFJTNDJTJGc2hhZG93JTNFJTNDJTJGdmFsdWUlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJPQkpFQ1QlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X2pzb24yb2JqZWN0JTIyJTIwaWQlM0QlMjI1JTYwaiUyNFhxMXdoJTJCKTYlNURqSSUyQiUzQSUyMy5GJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJ2YXJpYWJsZXNfZ2V0JTIyJTIwaWQlM0QlMjJFMDZkd3lYZXdfJTIzU2syUm8oJTdEJTNGJTVFJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyVkFSJTIyJTIwaWQlM0QlMjI4IWxKXzlmRnMlMkMlM0RiejlBKUElMkJGUyUyMiUzRXJlc3VsdCUzQyUyRmZpZWxkJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQ25leHQlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJ1cGRhdGUlMjIlMjBpZCUzRCUyMk4lMjN0QlJRZCUzQn5jRiU1QlQxX3B+JTQwbXAlMjIlM0UlM0NtdXRhdGlvbiUyMHhtbG5zJTNEJTIyaHR0cCUzQSUyRiUyRnd3dy53My5vcmclMkYxOTk5JTJGeGh0bWwlMjIlMjBkZWxheV9pbnB1dCUzRCUyMmZhbHNlJTIyJTNFJTNDJTJGbXV0YXRpb24lM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJPSUQlMjIlM0UwX3VzZXJkYXRhLjAuUFZfQW5sYWdlLlBWX1BWMVZvbHRhZ2UlM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMldJVEhfREVMQVklMjIlM0VGQUxTRSUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X3RvbnVtYmVyJTIyJTIwaWQlM0QlMjJkVXltJTVEITVaaW01SlNRWmxkQklRJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJnZXRfYXR0ciUyMiUyMGlkJTNEJTIyIUklMkNZQlZnNCFMb1pqIUJoZSUyNURNJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyUEFUSCUyMiUzRSUzQ3NoYWRvdyUyMHR5cGUlM0QlMjJ0ZXh0JTIyJTIwaWQlM0QlMjJEJTJGLmgxJTVFfiU1RUpISSU3RDNzY1clMjVWJTJGJTIzJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyVEVYVCUyMiUzRVBWMVZvbHRhZ2UlM0MlMkZmaWVsZCUzRSUzQyUyRnNoYWRvdyUzRSUzQyUyRnZhbHVlJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyT0JKRUNUJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyY29udmVydF9qc29uMm9iamVjdCUyMiUyMGlkJTNEJTIyNm5TJTVFJTI1bWpzSC0lMjV2JTVEdDYlM0IlMjRSQyU2MCUyMiUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIydmFyaWFibGVzX2dldCUyMiUyMGlkJTNEJTIyKClHck4lN0Q1T1lhITUlMkJPaiFfTlFpJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyVkFSJTIyJTIwaWQlM0QlMjI4IWxKXzlmRnMlMkMlM0RiejlBKUElMkJGUyUyMiUzRXJlc3VsdCUzQyUyRmZpZWxkJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQ25leHQlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJ1cGRhdGUlMjIlMjBpZCUzRCUyMmdIeVl0SVYyRnglMjVNVVYqYjJvclUlMjIlM0UlM0NtdXRhdGlvbiUyMHhtbG5zJTNEJTIyaHR0cCUzQSUyRiUyRnd3dy53My5vcmclMkYxOTk5JTJGeGh0bWwlMjIlMjBkZWxheV9pbnB1dCUzRCUyMmZhbHNlJTIyJTNFJTNDJTJGbXV0YXRpb24lM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJPSUQlMjIlM0UwX3VzZXJkYXRhLjAuUFZfQW5sYWdlLlBWX0dyaWRGcmVxdWVuY3klM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMldJVEhfREVMQVklMjIlM0VGQUxTRSUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X3RvbnVtYmVyJTIyJTIwaWQlM0QlMjJHZXYheWR2JTdEKiglNUI2MiUzRDdfRyU3RDViJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJnZXRfYXR0ciUyMiUyMGlkJTNEJTIyejFEUGJnT1glNUUlMkMlMjRQMjBDRGpTJTVFWSUyMiUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlBBVEglMjIlM0UlM0NzaGFkb3clMjB0eXBlJTNEJTIydGV4dCUyMiUyMGlkJTNEJTIyVCU3RGVHRkVMTyU2MDZWTSUzRCUyNXZzUyUyQiU1QnAlMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJURVhUJTIyJTNFR3JpZEZyZXF1ZW5jeSUzQyUyRmZpZWxkJTNFJTNDJTJGc2hhZG93JTNFJTNDJTJGdmFsdWUlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJPQkpFQ1QlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X2pzb24yb2JqZWN0JTIyJTIwaWQlM0QlMjJMKCFzJTQwelc1JTdDWCgtKEYlM0JHTVQ0SiUyMiUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIydmFyaWFibGVzX2dldCUyMiUyMGlkJTNEJTIyJTI0ISUzRDVGbzQ2dyU3QyUyNCUzRFN5S0paUSUzRCklMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJWQVIlMjIlMjBpZCUzRCUyMjghbEpfOWZGcyUyQyUzRGJ6OUEpQSUyQkZTJTIyJTNFcmVzdWx0JTNDJTJGZmllbGQlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDbmV4dCUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMnVwZGF0ZSUyMiUyMGlkJTNEJTIyaGozTiU3QiU2MGR4JTI1dE0qVDNrYnJlSiolMjIlM0UlM0NtdXRhdGlvbiUyMHhtbG5zJTNEJTIyaHR0cCUzQSUyRiUyRnd3dy53My5vcmclMkYxOTk5JTJGeGh0bWwlMjIlMjBkZWxheV9pbnB1dCUzRCUyMmZhbHNlJTIyJTNFJTNDJTJGbXV0YXRpb24lM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJPSUQlMjIlM0UwX3VzZXJkYXRhLjAuUFZfQW5sYWdlLlBWX1RXb3JrVGltZVRvdGFsJTNDJTJGZmllbGQlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJXSVRIX0RFTEFZJTIyJTNFRkFMU0UlM0MlMkZmaWVsZCUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyY29udmVydF90b251bWJlciUyMiUyMGlkJTNEJTIyMDBhVFNYeEw5MWolM0ElMkZqJTNBOFhQWiUzQSUyMiUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIyZ2V0X2F0dHIlMjIlMjBpZCUzRCUyMnNjdCU3QiU1QkYlMkY1eGZBSVY1RCUzRE5saUMlMjIlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJQQVRIJTIyJTNFJTNDc2hhZG93JTIwdHlwZSUzRCUyMnRleHQlMjIlMjBpZCUzRCUyMihXbSU3RFhkWmpUQSowbSUyQ1clN0QlMkMlM0RXJTYwJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyVEVYVCUyMiUzRVRXb3JrVGltZVRvdGFsJTNDJTJGZmllbGQlM0UlM0MlMkZzaGFkb3clM0UlM0MlMkZ2YWx1ZSUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMk9CSkVDVCUyMiUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmNvbnZlcnRfanNvbjJvYmplY3QlMjIlMjBpZCUzRCUyMl8lNURUOXZ2Y2xLQyU3RCUzRjBjVGclM0JxJTIzKCUyMiUzRSUzQ3ZhbHVlJTIwbmFtZSUzRCUyMlZBTFVFJTIyJTNFJTNDYmxvY2slMjB0eXBlJTNEJTIydmFyaWFibGVzX2dldCUyMiUyMGlkJTNEJTIyJTJCNHI4YkN4JTI1JTdCJTdCOCU0MFR2SyU3RF9WYVAlMjIlM0UlM0NmaWVsZCUyMG5hbWUlM0QlMjJWQVIlMjIlMjBpZCUzRCUyMjghbEpfOWZGcyUyQyUzRGJ6OUEpQSUyQkZTJTIyJTNFcmVzdWx0JTNDJTJGZmllbGQlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDbmV4dCUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMnVwZGF0ZSUyMiUyMGlkJTNEJTIyTW4yJTJCJTYwQVc5biU1RTZOZDIzV1Y1JTVCWSUyMiUzRSUzQ211dGF0aW9uJTIweG1sbnMlM0QlMjJodHRwJTNBJTJGJTJGd3d3LnczLm9yZyUyRjE5OTklMkZ4aHRtbCUyMiUyMGRlbGF5X2lucHV0JTNEJTIyZmFsc2UlMjIlM0UlM0MlMkZtdXRhdGlvbiUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMk9JRCUyMiUzRTBfdXNlcmRhdGEuMC5QVl9BbmxhZ2UuUFZfUFYxSW5wdXRBbXBlcmUlM0MlMkZmaWVsZCUzRSUzQ2ZpZWxkJTIwbmFtZSUzRCUyMldJVEhfREVMQVklMjIlM0VGQUxTRSUzQyUyRmZpZWxkJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X3RvbnVtYmVyJTIyJTIwaWQlM0QlMjIlN0MoWSUzRCU3RGF0WjFwJTNGNFJFKFpWemQxJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJnZXRfYXR0ciUyMiUyMGlkJTNEJTIyJTdEU2tmJTdDQ0NmJTQwSEprNzZFRDVyaU0lMjIlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJQQVRIJTIyJTNFJTNDc2hhZG93JTIwdHlwZSUzRCUyMnRleHQlMjIlMjBpZCUzRCUyMnpYTWZoJTYwRSU3Q3gwJTNEN0MlMkNwJTIzJTYwSVlEJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyVEVYVCUyMiUzRVBWMUlucHV0Q3VycmVudCUzQyUyRmZpZWxkJTNFJTNDJTJGc2hhZG93JTNFJTNDJTJGdmFsdWUlM0UlM0N2YWx1ZSUyMG5hbWUlM0QlMjJPQkpFQ1QlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJjb252ZXJ0X2pzb24yb2JqZWN0JTIyJTIwaWQlM0QlMjJXYyU2MEhwdCUzRGg5azNDJTNBdWFZRiUyQkFBJTIyJTNFJTNDdmFsdWUlMjBuYW1lJTNEJTIyVkFMVUUlMjIlM0UlM0NibG9jayUyMHR5cGUlM0QlMjJ2YXJpYWJsZXNfZ2V0JTIyJTIwaWQlM0QlMjIlNjBxRWRlVCprWGpXcTRqWU4lNUQlM0RTJTNBJTIyJTNFJTNDZmllbGQlMjBuYW1lJTNEJTIyVkFSJTIyJTIwaWQlM0QlMjI4IWxKXzlmRnMlMkMlM0RiejlBKUElMkJGUyUyMiUzRXJlc3VsdCUzQyUyRmZpZWxkJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGdmFsdWUlM0UlM0MlMkZibG9jayUzRSUzQyUyRnZhbHVlJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ2YWx1ZSUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGbmV4dCUzRSUzQyUyRmJsb2NrJTNFJTNDJTJGc3RhdGVtZW50JTNFJTNDJTJGYmxvY2slM0UlM0MlMkZzdGF0ZW1lbnQlM0UlM0MlMkZibG9jayUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmNvbnZlcnRfdG9udW1iZXIlMjIlMjBpZCUzRCUyMipOJTI1SkslN0RMeCUyNXZfNF8lNUVOZTYlN0IlNUI5JTIyJTIweCUzRCUyMjI2NiUyMiUyMHklM0QlMjI2MTklMjIlM0UlM0MlMkZibG9jayUzRSUzQ2Jsb2NrJTIwdHlwZSUzRCUyMmNvbnZlcnRfdG9udW1iZXIlMjIlMjBpZCUzRCUyMkoxSW0uSXRXMShTMVUlNjAlM0RnQyh0cyUyMiUyMHglM0QlMjIyOTQlMjIlMjB5JTNEJTIyNjc1JTIyJTNFJTNDJTJGYmxvY2slM0UlM0MlMkZ4bWwlM0U=
              Neu:
              var result;
                httpGet('http://192.xxx.xxx.xxx/status', { timeout: 2000, responseType: 'arraybuffer' }, async (err, response) => {
                  if (err) {
                    console.error(err);
              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
              Vielen Dank im Voraus!
              DJMarc75 Homoran Latzi 3 Replies Last reply Reply Quote 0
              • DJMarc75
                DJMarc75 @heinz527 last edited by
                @heinz527 bitte das Blockly als Screenshot zeigen.
                  Homoran Global Moderator Administrators @heinz527 last edited by
                  @heinz527 sagte in [gelöst] Skript auf AXIOS/httpGet umbauen:
                  wieso??
                  wegen der
                  Warnmeldungen
                  Aber läuft doch noch alles (bis dahin!) oder?
                  und die Warnmeldungen gab es schon jahrelang, allerdings nicht so prominent.
                  wie @DJMarc75 schrob
                  @djmarc75 sagte in [gelöst] Skript auf AXIOS/httpGet umbauen:
                  • Latzi
                    Latzi @heinz527 last edited by
                    @heinz527
                    versuche mal alle JSON.parse(result) durch JSON.parse(response.data) zu ersetzen
                      Homoran Global Moderator Administrators @Latzi last edited by Homoran
                      @latzi sagte in [gelöst] Skript auf AXIOS/httpGet umbauen:
                      @heinz527
                      es geht um Blockly!
                      Deswegen soll @heinz527 screenshot mit den betroffenen Blöcken zeigen
                      ...und ja, da werden noch result Blöcke drin sein
                        Danke für die schnellen Rückmeldungen!
                        Weiter oben stand es sollte jemand die xml posten, daher hatte ich die Blockly nicht gepostet.
                        OK, dann hier das Neue (ja, da steht noch was mit result drin):
                        DJMarc75 haus-automatisierung 2 Replies Last reply Reply Quote 0
                        • DJMarc75
                          @heinz527 alle RESULT durch diesen Block ersetzen:
                            heinz527 @DJMarc75 last edited by
                            @djmarc75
                            DANKESCHÖN!!!! 🙇‍♂️
                            Damit kommen wieder Werte!
                            Achso: Mich nerven Warnmeldungen (Ist mein innerer Monk.....)
                            Danke an alle für die schnelle Hilfe!!!!
                            • haus-automatisierung
                              haus-automatisierung Developer Most Active @heinz527 last edited by
                              Sauberer wäre es übrigens, wenn Du eine neue Variable anlegst und nur 1x "JSON nach Objekt" aufrufst. Und dann diese immer wieder in den "Attribut von Objekt..."-Bausteinen verwendest.
                              H paul53 2 Replies Last reply Reply Quote 1
                                heinz527 @haus-automatisierung last edited by
                                Hm.... Da muss ich mich mal in Ruhe mit beschäftigen. Bin ja damals schon froh gewesen, dass ich es hinbekommen habe 😉
                                Danke für den Hinweis!
                                  paul53 @haus-automatisierung last edited by
                                  @haus-automatisierung sagte: nur 1x "JSON nach Objekt" aufrufst. Und dann diese immer wieder in den "Attribut von Objekt..."-Bausteinen verwendest.
                                  getAttr() wandelt selbst JSON in ein Objekt.
                                    haus-automatisierung Developer Most Active @paul53 last edited by
                                    @paul53 Klar, aber dann auch bei jedem Aufruf. Daher besser direkt ein Objekt reingeben
                                      derbaum123 last edited by
                                      Hallo, ich habe folgendes Skript um mir beim Klingeln ein Bild schicken zu lassen. Leider kenne ich mich nicht mit java aus. kann mir bitte jemand mein Skript so umschreiben, dass ich folgende Fehlermeldung nicht mehr erhalten:
                                      script.js.Klingel.Haustürklingel_Snapshot: request package is deprecated - please use httpGet (or a stable lib like axios) instead!
                                      Das Skript ist folgendes:
                                      var request = require('request');
                                      var fs      = require('fs');
                                      function sendImage() {
                                          request.get({url: 'http://192.168.1.71/api/camera/snapshot?width=1280&height=960', encoding: 'binary'}, function (err, response, body) {
                                              fs.writeFile("/tmp/snap.jpg", body, 'binary', function(err) {
                                              if (err) {
                                                  console.error(err);
                                              } else {
                                                  console.log('Snapshot sent');
                                                  sendTo('telegram.0', {text: '/tmp/snap.jpg', caption: 'Es hat geklingelt'});
                                      on({id: '0_userdata.0.Klingel-Haustuere-Bewegung.Klingel-Haustuere-aktiv', change: "any"}, function (obj) {
                                          if (obj.state.val) {
                                              sendImage();
                                              //setTimeout(sendImage, 1000);
                                      Danke euch schonmal
                                        haus-automatisierung Developer Most Active @derbaum123 last edited by haus-automatisierung
                                        @derbaum123
                                        on({ id: '0_userdata.0.Klingel-Haustuere-Bewegung.Klingel-Haustuere-aktiv', change: 'any' }, async (obj) => {
                                            httpGet('http://192.168.1.71/api/camera/snapshot?width=1280&height=960', { timeout: 5000, responseType: 'arraybuffer' }, async (err, response) => {
                                              sendTo('telegram.0', 'send', {
                                                text: createTempFile('snap.jpg', response.data),
                                                caption: 'Es hat geklingelt',
                                        Alternativ komplett per Blockly (ohne JS), siehe https://forum.iobroker.net/topic/29229/iobroker-windows-kamerabild-blockly/8
                                          derbaum123 @haus-automatisierung last edited by
                                          vielen lieben Dank -> funktioniert 🙂
                                          59
                                          10986
