    5. Futterautomatik
    Futterautomatik
      paul53 @Aphofis last edited by paul53
      @aphofis sagte: ob die Steuerung so korekt ist
      So funktioniert es nicht. "Futter Pumpen Pause" enthält die Minuten der Pause?
      Versuche es mal so:
        <variables>
          <variable id="-rJfc0$)%|5~2[%Tv0x]">clock</variable>
          <variable id="Q7*Gw)fesXb}OUBj1{`;">Uhrzeit</variable>
          <variable id="u)9}*R19v/Qs3Rt)$4,W">Dauer</variable>
          <variable type="cron" id="schedule1">schedule1</variable>
          <variable type="interval" id="Intervall">Intervall</variable>
        </variables>
        <block type="procedures_callnoreturn" id="3a)9A+{U=BTerQFdk^7e" x="-2937" y="-1287">
          <mutation name="setUhr">
            <arg name="clock"></arg>
          </mutation>
          <value name="ARG0">
            <block type="get_value" id="Rmv(=Tg+:6/}8B(?~nI#">
              <field name="OID">0_userdata.0.Futterautomatik.Futterautomatik_Uhrzeit_1</field>
            <block type="on_ext" id="X}o|@dWx#6!BiHho8e)o">
              <value name="OID0">
                <shadow type="field_oid" id="dXPC7;GFYg(#~T78}@mB">
                  <field name="oid">0_userdata.0.Futterautomatik.Futterautomatik_Uhrzeit_1</field>
                <block type="schedule_clear" id="nt-N]NBg?,fY%.)hYJ4D">
                  <field name="NAME">schedule1</field>
                    <block type="procedures_callnoreturn" id="yvhs4uL6uUxnW!c$UF/{">
                      </mutation>
                      <value name="ARG0">
                        <block type="on_source" id="SfI,}teG@`dg#_g%Zp#:">
        <block type="procedures_defnoreturn" id="fK5kmsd)LwZ7|P2xa^9U" x="-2937" y="-1037">
          <mutation>
            <arg name="clock" varid="-rJfc0$)%|5~2[%Tv0x]"></arg>
          </mutation>
          <field name="NAME">setUhr</field>
          <statement name="STACK">
            <block type="variables_set" id="aOx5`vU/=f;#)rmrW[|7">
              <field name="VAR" id="Q7*Gw)fesXb}OUBj1{`;">Uhrzeit</field>
                <block type="time_calculation" id="z|fju~f8!/H*jUdb=P@O">
                  <field name="OPERATION">-</field>
                  <value name="DATE_TIME">
                    <shadow type="time_get" id="Iw8E5Q%[d9Ru3tLb$w$w">
                      <field name="OPTION">object</field>
                    <block type="convert_from_date" id="D@Luc}]DE^0K5x%TjDGx">
                        <block type="variables_get" id="MW;d_-~On=rg3DwueID^">
                          <field name="VAR" id="-rJfc0$)%|5~2[%Tv0x]">clock</field>
                    <shadow type="math_number" id="ZKVA~fs3mR8IPdRXKAIP">
                      <field name="NUM">5</field>
                <block type="schedule_create" id="6x%+6G+PaD[w*{FuFm=K">
                  <value name="SCHEDULE">
                    <shadow type="field_cron" id="m4F75|F$}NA}2;e/avWa">
                      <field name="CRON">* * * * *</field>
                    <block type="cron_builder" id="q6(U2T{7uu}mYF)9QMKr">
                      <mutation xmlns="http://www.w3.org/1999/xhtml" seconds="false" as_line="false"></mutation>
                      <field name="LINE">FALSE</field>
                      <field name="WITH_SECONDS">FALSE</field>
                      <value name="DOW">
                        <shadow type="text" id=")8oVcqHY5re?jv#0QsO8">
                          <field name="TEXT">*</field>
                      <value name="MONTHS">
                        <shadow type="text" id="GfQ!DoE|TZTliq*)8,@j">
                      <value name="DAYS">
                        <shadow type="text" id="S6hVuxIjcYJMlS^~:zE5">
                      <value name="HOURS">
                        <shadow type="text" id="NP{*G*@dWEP9M9mNlZFF">
                        <block type="convert_from_date" id="@,PtojVn?d$syb`uI9ij">
                          <field name="OPTION">h</field>
                            <block type="variables_get" id="DjFQr]GZNcpA[xAQ86vh">
                      <value name="MINUTES">
                        <shadow type="text" id="I(LCmtz/NJ%:Tvp,*;JL">
                        <block type="convert_from_date" id="_Y,`7y,{trk`G]:S42jP">
                          <field name="OPTION">m</field>
                            <block type="variables_get" id="u,bL$P^w2.fKVy`D-k9R">
                    <block type="procedures_callnoreturn" id="/6qq{?/)+*vm:UnA$x,0">
                      <mutation name="Pumpe"></mutation>
        <block type="procedures_defnoreturn" id="jE$gVVpa7!Xtx{X@H^Fd" x="-2262" y="-938">
          <field name="NAME">Pumpe</field>
            <block type="variables_set" id="9kptcK|P^2:}bKZXyZ8f">
              <field name="VAR" id="u)9}*R19v/Qs3Rt)$4,W">Dauer</field>
                <block type="convert_tonumber" id="Tj/%:}sl8v})GfkG,zO:">
                    <block type="get_value" id=".,XzJi)h(f$9$~(`H$I!">
                      <field name="OID">0_userdata.0.Futterautomatik.Futter_Pumpen_Pause</field>
                <block type="control" id="%}iPzHc5tUi.(P1_MvRo">
                  <field name="OID">sonoff.0.Aqua_Control.POWER8</field>
                    <block type="logic_boolean" id="SM.e~4#O=p?c/SXA|JX%">
                    <block type="debug" id="y_Y]xT#qZqZCX#n?iIsk">
                      <field name="Severity">info</field>
                      <value name="TEXT">
                        <shadow type="text" id="Od}|Jw/NX=B9~P;c8:5b">
                          <field name="TEXT">Pumpe wurde ausgeschaltet</field>
                        <block type="comment" id="KV;?nPX*TAluqR-qF9f+">
                          <field name="COMMENT">Minuten Intervall</field>
                            <block type="timeouts_setinterval" id=".SB*4vi`az$^Xh}aD$XD">
                              <field name="NAME">Intervall</field>
                              <field name="INTERVAL">1</field>
                                <block type="math_change" id="!*zN$DgW0K=76_[.1*]X">
                                  <value name="DELTA">
                                    <shadow type="math_number" id="e_D7=bSd65:`]Q{qWSZD">
                                      <field name="NUM">-1</field>
                                    <block type="controls_if" id="=/[;A-M~WF?KXEx~W0z?">
                                        <block type="logic_compare" id=";qY,PC)CB~{1#4iVHaj,">
                                          <field name="OP">LTE</field>
                                            <block type="variables_get" id="2k;4KgTu$A3wF)@V`ulP">
                                            <block type="math_number" id="?bnhw6qVm`$}~NCKlw2P">
                                              <field name="NUM">0</field>
                                        <block type="timeouts_clearinterval" id="{9.vJ@]#bASx1v{CUm7E">
                                            <block type="control" id="OB1{)Gdz{TTQkN{C.j{S">
                                                <block type="logic_boolean" id="?gR?u,JI@th[n?@_q!=i">
      Anmerkung: "POWER5" ist sicherlich falsch?
        @aphofis
        Im ersten Post ist ein Fehler: Es muss schedule1 gestoppt werden.
        • Aphofis
          Aphofis last edited by Aphofis
          Ja hab ich probiert und Ja Power5 war falsch
          hab alles mal im minuten bereich getestet. es läuft.
          Hab es aber etwas anders aufgebaut.
          Also hatte die Vorlage deiner Steuerung genommen und den Faktor raus genommen für die pumpen steuerung
          dann halt Pumpe zur uhrzeit gestoppt und die Steuerung auch von dir für die Fütterung einfach den timeout auf dann 5 min gestellt und pumpe auf 20 min timeout.
          Die pumpe wird dann zB. 9:00 Uhr ausgeschaltet und nach Datenpunkt wird dann 5 min später Futter nach Faktor zu 500ms dosiert. die Pumpe springt dann 20 min nach 9 wieder an und hatte somit eine Pause von 15 min. also perfekt.
          Ob es so einwandfrei ist, weiss ich nicht zumindest gibt niemand einen Fehler aus und die Steuerung macht was sie soll.
          Pumpen Steuerung 1
          var clock, Uhrzeit, schedule1, timeout;
          // Beschreibe diese Funktion …
          async function Pumpe() {
            setState('sonoff.0.Aqua_Control.POWER8' /* Aqua_Control POWER8 */, false);
            console.log('Pumpe wurde ausgeschaltet');
            sendTo("telegram.0", "send", {
                text: 'Pumpe wurde ausgeschaltet'
            (() => { if (timeout) { clearTimeout(timeout); timeout = null; }})();
            timeout = setTimeout(async () => {
              timeout = null;
              setState('sonoff.0.Aqua_Control.POWER8' /* Aqua_Control POWER8 */, true);
              console.log('Pumpe wurde eingeschaltet');
                  text: 'Pumpe wurde eingeschaltet'
            }, 1200000);
          async function setUhr(clock) {
            Uhrzeit = clock.split(':');
            schedule1 = schedule((Uhrzeit[1]).toString().trim() + ' ' + (Uhrzeit[0]).toString().trim() + ' ' + '*'.toString().trim() + ' ' + '*'.toString().trim() + ' ' + '*'.toString().trim(), async () => {
              await Pumpe();
          await setUhr(getState('0_userdata.0.Futterautomatik.Futterautomatik_Uhrzeit_1').val);
          on({ id: [].concat(['0_userdata.0.Futterautomatik.Futterautomatik_Uhrzeit_1']), change: 'ne' }, async (obj) => {
            let value = obj.state.val;
            (() => { if (clock) { clearSchedule(clock); clock = null; }})();
            await setUhr((obj.state ? obj.state.val : ''));
          Futter Steuerung 1
          var clock, timeout, Uhrzeit, Dauer, schedule1, Intervall;
          async function Futter() {
              timeout = null;
              Dauer = parseFloat(getState('0_userdata.0.Futterautomatik.Futterautomatik_Faktor_1').val);
              setState('sonoff.0.Aqua_Control.POWER5' /* Aqua_Control POWER5 */, true);
              console.log('Futter wurde dosiert');
                  text: (['Futter wurde dosiert','Futterautomat ist ',getState('sonoff.0.Aqua_Control.POWER5').val].join(''))
              // Intervalldauer = Faktor
              Intervall = setInterval(async () => {
                Dauer = (typeof Dauer === 'number' ? Dauer : 0) + -1;
                if (Dauer <= 0) {
                  (() => { if (Intervall) { clearInterval(Intervall); Intervall = null; }})();
                  setState('sonoff.0.Aqua_Control.POWER5' /* Aqua_Control POWER5 */, false);
              }, 500);
            }, 300000);
              await Futter();
            @aphofis sagte:
            In beiden Steuerungen wird die falsche Variable gestoppt! Nicht clock, sondern schedule1 muss gestoppt werden.
            Aphofis 1 Reply Last reply Reply Quote 1
            • Aphofis
              Aphofis @paul53 last edited by
              @paul53 sagte in Futterautomatik:
              @aphofis sagte:
              also so !?
               (() => { if (schedule1) { clearSchedule(schedule1); schedule1 = null; }})();
                @aphofis sagte: also so !?
                Ja.
                • Aphofis
                  Ja.
                  Prima besten Dank !!!
                  Aphofis 1 Reply Last reply Reply Quote 0
                  • Aphofis
                    Aphofis @Aphofis last edited by Aphofis
                    Leider gab es ein weiteres Problem.
                    Der ESP8266 ist beim dosieren Offline gegangen und der Futterautomat stand auf true
                    bis das Futter fröhlich dosiert wurde. Hatte zum Glück zum testen nur eine geringe Menge in den Automaten gepackt.
                    kann man das irgendwie begrenzen, das maximal pro vorgang wirklich nur zB 300 ms der Futterautomat auf true steht oder gibt es vielleicht eine andere Idee °!°
                    alive auf false bringt ja nichts. Aber vielleicht kann man das begrenzen.
                      @aphofis sagte: Der ESP8266 ist beim dosieren Offline gegangen
                      Dann kann man mit ioBroker nicht mehr eingreifen. Schutzfunktionen müssten also direkt auf dem ESP implementiert werden. Davon habe ich aber keine Ahnung.
                      Aphofis 2 Replies Last reply Reply Quote 0
                      • Aphofis
                        OK!
                        Ich habe Tasmota drauf. ich gucke mal ob es Konsolen befehle gibt um zB das Relais dauerhaft auf max true xxx ms setzen kann. wenn der ESP wieder online geht kann man aber das doch prüfen mit Blockly wenn das Gerät bei start also wenn eine IP ausgegeben wird dann MUSS das Relais auf false gesetzt werden außer es ist dosier Zeit.
                        • Aphofis
                          jetzt sind die Geräte wieder Online nur die ip adressen werden nicht mehr angezeigt
                          es bleibt bei 0.0.0.0
                          also läuft doch nicht ganz.
                          • Aphofis
                            Habe es jetzt mit einem Befehl geschafft. Direkt im Tasmota kann man so zu sagen eine Max ein Zeit einstellen diese habe ich jetzt für das Relais 5 auf 300 ms gesetzt. Damit pro true schaltung nicht mehr als 300ms dosiert wird. PulseTime5 3 ist alles und das funktioniert auch nach mehreren Neustarts des ESP8266
                            378
