    4. Dieser Adapter benötigt den vis- oder vis-2-Adapter
      Homoran Global Moderator Administrators @PPB1308 last edited by
      @ppb1308 sagte in Dieser Adapter benötigt den vis- oder vis-2-Adapter:
      Dieser Adapter benötigt den vis- oder vis-2-Adapter,
      hast du den?
      was sagt die Langfassung von iob diag ?
        PPB1308 @Homoran last edited by Homoran
        @homoran said in Dieser Adapter benötigt den vis- oder vis-2-Adapter:
        hast du den?
        ja, beide.
        lt. diag imho keine Probleme bezüglich vis zu erkennen:
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: briioBrProx
                 Icon name: computer-container
                   Chassis: container
            Virtualization: lxc
          Operating System: Ubuntu 20.04.6 LTS
                    Kernel: Linux 5.15.104-1-pve
              Architecture: x86-64
        model name      : Intel(R) Core(TM) i5-8259U CPU @ 2.30GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         09:51:23 up 16:01,  1 user,  load average: 1.41, 1.07, 1.04
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Fri 2024-05-31 09:51:23 CEST
                   Universal time: Fri 2024-05-31 07:51:23 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        peter
        HOME=/home/peter
        GROUPS=peter sudo iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:           7.2G        5.7G        292M        0.0K        1.2G        1.5G
        Swap:          4.1G        0.0K        4.1G
        Total:          11G        5.7G        4.4G
        Active iob-Instances:   63
                 7168 M total memory
                 5661 M used memory
                  819 M active memory
                 5730 M inactive memory
                  292 M free memory
                    0 M buffer memory
                 1214 M swap cache
                 4096 M total swap
                    0 M used swap
                 4095 M free swap
        top - 09:51:23 up 16:01,  1 user,  load average: 1.41, 1.07, 1.04
        Tasks:  92 total,   1 running,  91 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  9.7 us,  0.0 sy,  0.0 ni, 90.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7168.0 total,    292.2 free,   5661.1 used,   1214.7 buff/cache
        MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.   1506.9 avail Mem
        *** FAILED SERVICES ***
          UNIT               LOAD   ACTIVE SUB    DESCRIPTION
        * nightscout.service loaded failed failed Nightscout CGM service
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--220--disk--0 ext4       40G   13G   25G  34% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
        tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
        tmpfs                            tmpfs     1.6G  116K  1.6G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        dmesg: read kernel buffer failed: Operation not permitted
        Show mounted filesystems:
        TARGET                                SOURCE                           FSTYPE      OPTIONS
        /                                     /dev/mapper/pve-vm--220--disk--0 ext4        rw,relatime,stripe=16
        |-/run                                tmpfs                            tmpfs       rw,nosuid,nodev,size=1623916k,mode=755,uid=100000,gid=100000,inode64
        | `-/run/lock                         tmpfs                            tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
        |-/dev                                none                             tmpfs       rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/dev/shm                          tmpfs                            tmpfs       rw,nosuid,nodev,uid=100000,gid=100000,inode64
        | |-/dev/mqueue                       mqueue                           mqueue      rw,relatime
        | |-/dev/.lxc/proc                    proc                             proc        rw,relatime
        | |-/dev/.lxc/sys                     sys                              sysfs       rw,relatime
        | |-/dev/full                         udev[/full]                      devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
        | |-/dev/null                         udev[/null]                      devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
        | |-/dev/random                       udev[/random]                    devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
        | |-/dev/tty                          udev[/tty]                       devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
        | |-/dev/urandom                      udev[/urandom]                   devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
        | |-/dev/zero                         udev[/zero]                      devtmpfs    rw,nosuid,relatime,size=8084736k,nr_inodes=2021184,mode=755,inode64
        | |-/dev/pts                          devpts                           devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/ptmx                         devpts[/ptmx]                    devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/console                      devpts[/0]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/tty1                         devpts[/1]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | `-/dev/tty2                         devpts[/2]                       devpts      rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        |-/proc                               proc                             proc        rw,nosuid,nodev,noexec,relatime
        | |-/proc/sys                         proc[/sys]                       proc        ro,relatime
        | | |-/proc/sys/net                   proc[/sys/net]                   proc        rw,nosuid,nodev,noexec,relatime
        | | |-/proc/sys/fs/binfmt_misc        binfmt_misc                      binfmt_misc rw,nosuid,nodev,noexec,relatime
        | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]              tmpfs       ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/proc/sysrq-trigger               proc[/sysrq-trigger]             proc        ro,relatime
        | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/diskstats                   lxcfs[/proc/diskstats]           fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/loadavg                     lxcfs[/proc/loadavg]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/meminfo                     lxcfs[/proc/meminfo]             fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]            fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/stat                        lxcfs[/proc/stat]                fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/swaps                       lxcfs[/proc/swaps]               fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | `-/proc/uptime                      lxcfs[/proc/uptime]              fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        `-/sys                                sysfs                            sysfs       ro,nosuid,nodev,noexec,relatime
          |-/sys/fs/fuse/connections          fusectl                          fusectl     rw,nosuid,nodev,noexec,relatime
          |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]      sysfs       rw,nosuid,nodev,noexec,relatime
          |-/sys/kernel/debug                 debugfs                          debugfs     rw,nosuid,nodev,noexec,relatime
          |-/sys/kernel/security              securityfs                       securityfs  rw,nosuid,nodev,noexec,relatime
          |-/sys/fs/pstore                    pstore                           pstore      rw,nosuid,nodev,noexec,relatime
          |-/sys/firmware/efi/efivars         efivarfs                         efivarfs    rw,nosuid,nodev,noexec,relatime
          |-/sys/fs/cgroup                    none                             cgroup2     rw,nosuid,nodev,noexec,relatime
          `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]   fuse.lxcfs  rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        /var:
        5.5G    /var/
        3.9G    /var/log/journal/f13addc1d6aa9ba4cb18ff805da8906a
        3.9G    /var/log
        849M    /var/lib
        Archived and active journals take up 1.3G in the file system.
        /opt/iobroker/backups:
        75M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.7G    /opt/iobroker/iobroker-data/
        1.1G    /opt/iobroker/iobroker-data/files
        243M    /opt/iobroker/iobroker-data/files/vis-2
        236M    /opt/iobroker/iobroker-data/backup-objects
        187M    /opt/iobroker/iobroker-data/files/javascript.admin
        65M     /opt/iobroker/iobroker-data/states.jsonl
        52M     /opt/iobroker/iobroker-data/objects.jsonl
        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.20.3
        /usr/bin/node           v18.20.3
        /usr/bin/npm            10.7.0
        /usr/bin/npx            10.7.0
        /usr/bin/corepack       0.28.0
        nodejs:
          Installed: 18.20.3-1nodesource1
          Candidate: 18.20.3-1nodesource1
          Version table:
         *** 18.20.3-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.20.2-1nodesource1 1001
             18.20.1-1nodesource1 1001
             18.20.0-1nodesource1 1001
             18.19.1-1nodesource1 1001
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             10.19.0~dfsg-3ubuntu1.6 500
                500 http://archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                500 http://archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
             10.19.0~dfsg-3ubuntu1 500
                500 http://archive.ubuntu.com/ubuntu focal/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.17.14
        javascript:     8.4.2
        nodejs modules from github:     6
        +-- @jpgorganizer/utils@1.2.1 (git+ssh://git@github.com/jpgorganizer/ioBroker.utils.git#952f8556cf8d45f865a84c9a911a7b2b87633f3a)
        | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
        +-- iobroker.life360@0.2.21 (git+ssh://git@github.com/MiGoller/ioBroker.life360.git#888e08024c2d93d86aa6eb74f281c574dce86c42)
        +-- iobroker.nightscout@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.nightscout.git#1f5b39fa318cb78d844eb3c248c4baf00e51098f)
        +-- iobroker.onvif-alt@0.2.0 (git+ssh://git@github.com/Jey-Cee/iobroker.onvif-alt.git#f524cdbc00567a3351217272ab5af29d9947c967)
        | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
        Adapter State
        + system.adapter.admin.0                  : admin                 : briioBrProx                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alarm.0                  : alarm                 : briioBrProx                              -  enabled
        + system.adapter.alexa2.0                 : alexa2                : briioBrProx                              -  enabled
          system.adapter.alias-manager.0          : alias-manager         : briioBrProx                              -  enabled
        + system.adapter.backitup.0               : backitup              : briioBrProx                              -  enabled
        + system.adapter.bring.0                  : bring                 : briioBrProx                              -  enabled
        + system.adapter.cameras.0                : cameras               : briioBrProx                              -  enabled, port: 8200, bind: 127.0.0.1
        + system.adapter.cloud.0                  : cloud                 : briioBrProx                              -  enabled
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: briioBrProx                              -  enabled
          system.adapter.daswetter.0              : daswetter             : briioBrProx                              -  enabled
        + system.adapter.deconz.0                 : deconz                : briioBrProx                              -  enabled, port: 80
        + system.adapter.discovery.0              : discovery             : briioBrProx                              -  enabled
          system.adapter.dwd.0                    : dwd                   : briioBrProx                              -  enabled
        + system.adapter.email.0                  : email                 : briioBrProx                              -  enabled
        + system.adapter.enigma2.0                : enigma2               : briioBrProx                              -  enabled
        + system.adapter.enigma2.1                : enigma2               : briioBrProx                              -  enabled
        + system.adapter.fb-checkpresence.0       : fb-checkpresence      : briioBrProx                              -  enabled
          system.adapter.feiertage.0              : feiertage             : briioBrProx                              -  enabled
        + system.adapter.firetv.0                 : firetv                : briioBrProx                              -  enabled
          system.adapter.flot.0                   : flot                  : briioBrProx                              -  enabled
          system.adapter.fontui.0                 : fontui                : briioBrProx                              -  enabled
          system.adapter.fritzbox.0               : fritzbox              : briioBrProx                              -  enabled
        + system.adapter.fullybrowser.0           : fullybrowser          : briioBrProx                              -  enabled
          system.adapter.harmony.0                : harmony               : briioBrProx                              -  enabled
        + system.adapter.history.0                : history               : briioBrProx                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : briioBrProx                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : briioBrProx                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : briioBrProx                              -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : briioBrProx                              -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : briioBrProx                              -  enabled, port: 0
        + system.adapter.homeconnect.0            : homeconnect           : briioBrProx                              -  enabled
        + system.adapter.hue-extended.0           : hue-extended          : briioBrProx                              -  enabled
        + system.adapter.hue.0                    : hue                   : briioBrProx                              -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : briioBrProx                              -  enabled
          system.adapter.ical.1                   : ical                  : briioBrProx                              -  enabled
          system.adapter.ical.2                   : ical                  : briioBrProx                              -  enabled
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: briioBrProx                              -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : briioBrProx                              -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : briioBrProx                              -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : briioBrProx                              -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : briioBrProx                              -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : briioBrProx                              -  enabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: briioBrProx                              -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : briioBrProx                              -  enabled
        + system.adapter.info.0                   : info                  : briioBrProx                              -  enabled
        + system.adapter.iot.0                    : iot                   : briioBrProx                              -  enabled
        + system.adapter.javascript.0             : javascript            : briioBrProx                              -  enabled
        + system.adapter.javascript.1             : javascript            : briioBrProx                              -  enabled
        + system.adapter.kodi.0                   : kodi                  : briioBrProx                              -  enabled, port: 9090
        + system.adapter.life360.0                : life360               : briioBrProx                              -  enabled
          system.adapter.link.0                   : link                  : briioBrProx                              - disabled
        + system.adapter.linkeddevices.0          : linkeddevices         : briioBrProx                              -  enabled
          system.adapter.luftdaten.0              : luftdaten             : briioBrProx                              -  enabled
          system.adapter.material.0               : material              : briioBrProx                              -  enabled
          system.adapter.mobile.0                 : mobile                : briioBrProx                              - disabled
        + system.adapter.moma.0                   : moma                  : briioBrProx                              -  enabled
        + system.adapter.mqtt-client.0            : mqtt-client           : briioBrProx                              -  enabled, port: 1883
        + system.adapter.netatmo.0                : netatmo               : briioBrProx                              -  enabled
        + system.adapter.nina.0                   : nina                  : briioBrProx                              -  enabled
        + system.adapter.onvif.0                  : onvif                 : briioBrProx                              -  enabled
        + system.adapter.pi-hole.0                : pi-hole               : briioBrProx                              -  enabled
        + system.adapter.ping.0                   : ping                  : briioBrProx                              -  enabled
        + system.adapter.plex.0                   : plex                  : briioBrProx                              -  enabled
        + system.adapter.plexconnect.0            : plexconnect           : briioBrProx                              -  enabled, port: 41814
        + system.adapter.pollenflug.0             : pollenflug            : briioBrProx                              -  enabled
        + system.adapter.proxmox.0                : proxmox               : briioBrProx                              -  enabled, port: 8006
          system.adapter.proxy.0                  : proxy                 : briioBrProx                              -  enabled
        + system.adapter.pushover.0               : pushover              : briioBrProx                              -  enabled
        + system.adapter.shelly.0                 : shelly                : briioBrProx                              -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : briioBrProx                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartgarden.0            : smartgarden           : briioBrProx                              -  enabled
        + system.adapter.socketio.0               : socketio              : briioBrProx                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.socketio.1               : socketio              : briioBrProx                              -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : briioBrProx                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.synology.0               : synology              : briioBrProx                              -  enabled, port: 32400
          system.adapter.tahoma.0                 : tahoma                : briioBrProx                              - disabled
        + system.adapter.tankerkoenig.0           : tankerkoenig          : briioBrProx                              -  enabled
        + system.adapter.text2command.0           : text2command          : briioBrProx                              -  enabled
        + system.adapter.tr-064.0                 : tr-064                : briioBrProx                              -  enabled
        + system.adapter.tr-064.1                 : tr-064                : briioBrProx                              -  enabled
        + system.adapter.tr-064.2                 : tr-064                : briioBrProx                              -  enabled
        + system.adapter.trashschedule.0          : trashschedule         : briioBrProx                              -  enabled
          system.adapter.tvspielfilm.0            : tvspielfilm           : briioBrProx                              -  enabled
        + system.adapter.upnp.0                   : upnp                  : briioBrProx                              -  enabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : briioBrProx                              -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : briioBrProx                              -  enabled
          system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: briioBrProx                              -  enabled
          system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: briioBrProx                              -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: briioBrProx                              -  enabled
          system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: briioBrProx                              -  enabled
          system.adapter.vis-2-widgets-sweethome3d.0: vis-2-widgets-sweethome3d: briioBrProx                              -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : briioBrProx                              -  enabled
          system.adapter.vis-bars.0               : vis-bars              : briioBrProx                              -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : briioBrProx                              -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : briioBrProx                              -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : briioBrProx                              -  enabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : briioBrProx                              -  enabled
          system.adapter.vis-history.0            : vis-history           : briioBrProx                              -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : briioBrProx                              -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : briioBrProx                              -  enabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : briioBrProx                              -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : briioBrProx                              -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : briioBrProx                              -  enabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : briioBrProx                              -  enabled
          system.adapter.vis-lcars.0              : vis-lcars             : briioBrProx                              -  enabled
          system.adapter.vis-map.0                : vis-map               : briioBrProx                              -  enabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : briioBrProx                              -  enabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : briioBrProx                              -  enabled
          system.adapter.vis-material.0           : vis-material          : briioBrProx                              -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : briioBrProx                              -  enabled
          system.adapter.vis-metro.0              : vis-metro             : briioBrProx                              -  enabled
          system.adapter.vis-players.0            : vis-players           : briioBrProx                              -  enabled
          system.adapter.vis-plumb.0              : vis-plumb             : briioBrProx                              -  enabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : briioBrProx                              -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : briioBrProx                              -  enabled
          system.adapter.vis-weather.0            : vis-weather           : briioBrProx                              -  enabled
          system.adapter.vis.0                    : vis                   : briioBrProx                              -  enabled
          system.adapter.vofo-speedtest.0         : vofo-speedtest        : briioBrProx                              -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : briioBrProx                              -  enabled
          system.adapter.web-speedy.0             : web-speedy            : briioBrProx                              - disabled
        + system.adapter.web.0                    : web                   : briioBrProx                              -  enabled, port: 8082, bind: 192.168.8.220, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : briioBrProx                              -  enabled
        + system.adapter.yamaha.0                 : yamaha                : briioBrProx                              -  enabled
          system.adapter.yr.0                     : yr                    : briioBrProx                              -  enabled
          system.adapter.zwave2.0                 : zwave2                : briioBrProx                              - disabled
        + instance is alive
        ioBroker-Repositories
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest) : http://iobroker.live/repo/sources-dist-latest.json
        Latest        : http://download.iobroker.net/sources-dist-latest.json
        Active repo(s): Beta (latest)
        Installed ioBroker-Instances
        Used repository: Beta (latest)
        Adapter    "admin"        : 6.17.14  , installed 6.17.14
        Adapter    "alarm"        : 3.6.0    , installed 3.6.0
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.1    , installed 2.11.0 [Updatable]
        Adapter    "bring"        : 1.8.4    , installed 1.8.4
        Adapter    "cameras"      : 2.0.5    , installed 2.0.5
        Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
        Adapter    "daswetter"    : 3.1.15   , installed 3.1.15
        Adapter    "deconz"       : 1.4.1    , installed 1.4.1
        Adapter    "discovery"    : 4.5.0    , installed 4.5.0
        Adapter    "email"        : 1.3.0    , installed 1.3.0
        Adapter    "enigma2"      : 2.1.0    , installed 2.1.0
        Adapter    "fb-checkpresence": 1.2.4 , installed 1.2.4
        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
        Adapter    "firetv"       : 2.1.0    , installed 2.1.0
        Adapter    "fritzbox"     : 0.6.0    , installed 0.2.1  [Updatable]
        Adapter    "fullcalendar" : 2.3.17   , installed 2.3.17
        Adapter    "fullybrowser" : 3.0.12   , installed 2.1.2  [Updatable]
        Adapter    "harmony"      : 1.4.0    , installed 1.4.0
        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.17.0   , installed 1.15.19 [Updatable]
        Adapter    "hmip"         : 1.23.3   , installed 1.23.2 [Updatable]
        Adapter    "homeconnect"  : 1.4.0    , installed 1.4.0
        Adapter    "hs100"        : 2.2.0    , installed 2.2.0
        Adapter    "hue"          : 3.11.0   , installed 3.11.0
        Adapter    "ical"         : 1.15.0   , installed 1.15.0
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.4.2    , installed 8.4.2
        Adapter    "kodi"         : 3.1.0    , installed 3.1.0
        Adapter    "link"         : 0.5.12   , installed 0.5.12
        Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
        Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mikrotik"     : 1.2.0    , installed 1.2.0
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "moma"         : 1.2.9    , installed 1.2.9
        Adapter    "mqtt-client"  : 1.8.0    , installed 1.8.0
        Adapter    "musiccast"    : 1.1.3    , installed 1.1.3
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "nina"         : 0.0.26   , installed 0.0.26
        Adapter    "onvif"        : 1.1.4    , installed 1.1.3  [Updatable]
        Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
        Adapter    "plex"         : 1.1.4    , installed 1.1.4
        Adapter    "plexconnect"  : 0.0.7    , installed 0.0.7
        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
        Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
        Adapter    "proxy"        : 1.3.2    , installed 1.3.2
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "radar2"       : 2.2.0    , installed 2.2.0
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "stockmarket"  : 0.0.2    , installed 0.0.2
        Adapter    "synology"     : 3.1.0    , installed 3.1.0
        Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
        Adapter    "upnp"         : 1.0.21   , installed 1.0.21
        Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
        Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
        Adapter    "vis-2-widgets-gauges": 1.0.3, installed 1.0.3
        Adapter    "vis-2-widgets-inventwo": 0.1.9, installed 0.1.9
        Adapter    "vis-2-widgets-jaeger-design": 1.1.27, installed 1.1.27
        Adapter    "vis-2-widgets-material": 1.3.32, installed 1.3.32
        Adapter    "vis-2-widgets-radar-trap": 2.0.0, installed 2.0.0
        Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
        Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 1.0.2  [Updatable]
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-map"      : 1.1.0    , installed 1.1.0
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
        Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
        Adapter    "vofo-speedtest": 2.0.1   , installed 2.0.1
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 6.2.6    , installed 6.2.6
        Adapter    "web-speedy"   : 0.2.0    , installed 0.2.0
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "ws"           : 2.6.1    , installed 2.6.1
        Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
        Objects and States
        Objects:        45006
        States:         38937
        Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
        Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
        Hit:4 http://archive.ubuntu.com/ubuntu focal-security InRelease
        Reading package lists...
        Pending Updates: 3
        *** Listening Ports ***
        tcp        0      0 192.168.8.220:8082      0.0.0.0:*               LISTEN      1000       45259877   1817/io.web.0
        tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      110        45236082   117/mongod
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       45238359   116/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       45239415   116/iobroker.js-con
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          45237968   320/master
        tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1000       45260787   2478/io.cameras.0
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        45237354   96/systemd-resolved
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          45237696   130/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       45239874   572/io.sonoff.0
        tcp        0      0 192.168.8.220:8701      0.0.0.0:*               LISTEN      1000       45246473   677/io.hm-rpc.3
        tcp        0      0 192.168.8.220:2010      0.0.0.0:*               LISTEN      1000       45240262   662/io.hm-rpc.2
        tcp        0      0 192.168.8.220:2001      0.0.0.0:*               LISTEN      1000       45240092   617/io.hm-rpc.0
        tcp        0      0 192.168.8.220:9292      0.0.0.0:*               LISTEN      1000       45240197   647/io.hm-rpc.1
        tcp6       0      0 :::8087                 :::*                    LISTEN      1000       45266603   2725/io.simple-api.
        tcp6       0      0 :::8084                 :::*                    LISTEN      1000       45259711   1747/io.socketio.0
        tcp6       0      0 :::8085                 :::*                    LISTEN      1000       45268159   2811/io.socketio.1
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       49414612   88185/io.admin.0
        tcp6       0      0 :::8000                 :::*                    LISTEN      1000       45270974   2691/io.upnp.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          45237698   130/sshd: /usr/sbin
        tcp6       0      0 :::41814                :::*                    LISTEN      1000       45268427   2893/io.plexconnect
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          45237969   320/master
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       45269031   2691/io.upnp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       45238878   557/io.deconz.0
        udp        0      0 192.168.8.220:5353      0.0.0.0:*                           1000       45251629   1054/io.tr-064.1
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       45248264   971/io.shelly.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        45237353   96/systemd-resolved
        udp6       0      0 :::1900                 :::*                                1000       45238882   557/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1000       45238881   557/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1000       45238880   557/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1000       45238879   557/io.deconz.0
        udp6       0      0 fe80::e82c:8aff:feb:546 :::*                                105        45238339   84/systemd-networkd
        2024-05-31 09:51:21.139  - warn: mqtt-client.0 (724) client error: Error: connect ECONNREFUSED 192.168.8.221:1883
        2024-05-31 09:51:41.950  - warn: fullybrowser.0 (2610) updateDeviceERROR 192.168.8.181
        2024-05-31 09:51:51.140  - warn: mqtt-client.0 (724) client error: Error: connect ECONNREFUSED 192.168.8.221:1883
        2024-05-31 09:51:51.172  - info: hue-extended.0 (1281) State value to set for "hue-extended.0.resourcelinks.peter_sensor_dg.classid" has to be type "string" but received type "number"
        2024-05-31 09:52:08.749  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
        2024-05-31 09:52:08.749  - info: life360.0 (2684) Waiting for online operations to finish ...
        2024-05-31 09:52:08.834  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
        2024-05-31 09:52:08.834  - info: life360.0 (2684) Waiting for online operations to finish ...
        2024-05-31 09:52:08.932  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
        2024-05-31 09:52:08.932  - info: life360.0 (2684) Waiting for online operations to finish ...
        2024-05-31 09:52:09.040  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
        2024-05-31 09:52:09.040  - info: life360.0 (2684) Waiting for online operations to finish ...
        2024-05-31 09:52:09.155  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
        2024-05-31 09:52:09.156  - info: life360.0 (2684) Waiting for online operations to finish ...
        2024-05-31 09:52:09.425  - error: life360.0 (2684) Connection established but failed to authenticate. Check your credentials!
        2024-05-31 09:52:09.426  - info: life360.0 (2684) Waiting for online operations to finish ...
        2024-05-31 09:52:09.426  - error: life360.0 (2684) Failed to connect or to login for 6 times. Aborting ...
        2024-05-31 09:52:09.426  - error: life360.0 (2684) Error: Error: Connection established but failed to authenticate. Check your credentials!
        2024-05-31 09:52:09.426  - warn: life360.0 (2684) No data received from Life360 cloud services!
        2024-05-31 09:52:12.963  - info: hue-extended.0 (1281) State value to set for "hue-extended.0.sensors.004-peter_sensor_dg_light.state.lightlevel" has to be type "string" but received type "number"
        2024-05-31 09:52:12.963  - info: hue-extended.0 (1281) State value to set for "hue-extended.0.resourcelinks.peter_sensor_dg.classid" has to be type "string" but received type "number"
        2024-05-31 09:52:12.964  - info: hue-extended.0 (1281) State value to set for "hue-extended.0.resourcelinks.peter_sensor_dg.classid" has to be type "string" but received type "number"
        2024-05-31 09:52:12.964  - info: hue-extended.0 (1281) State value to set for "hue-extended.0.groups.000-all_lights.lightlevel.state.lightlevel" has to be type "string" but received type "number"
        2024-05-31 09:52:21.142  - warn: mqtt-client.0 (724) client error: Error: connect ECONNREFUSED 192.168.8.221:1883
          wer ist .220?
            wer ist .220?
            .220 ist der ioBroker lxc.
              @ppb1308 wieso ist nur der freigegeben?
              hast du da den port 8082 gemappt?
                Thomas Braun Most Active @PPB1308 last edited by
                @ppb1308
                ls -lah /opt/iobroker/node_modules/iobroker.vis-map/
                sagt?
                  @thomas-braun said in Dieser Adapter benötigt den vis- oder vis-2-Adapter:
                  peter@briioBrProx:/opt/iobroker$ ls -lah /opt/iobroker/node_modules/iobroker.vis-map/
                  total 116K
                  drwxrwxr-x+    5 iobroker iobroker 4.0K May 31 09:31 .
                  drwxrwxr-x+ 1215 iobroker iobroker  68K May 31 09:31 ..
                  -rw-rw-r--+    1 iobroker iobroker 2.6K May 31 09:31 LICENSE
                  -rw-rw-r--+    1 iobroker iobroker 2.2K May 31 09:31 README.md
                  drwxrwxr-x+    3 iobroker iobroker 4.0K May 31 09:31 admin
                  drwxrwxr-x+    2 iobroker iobroker 4.0K May 31 09:31 img
                  -rw-rw-r--+    1 iobroker iobroker 9.1K May 31 09:31 io-package.json
                  -rw-rw-r--+    1 iobroker iobroker    1 May 31 09:31 iob_npm.done
                  -rw-rw-r--+    1 iobroker iobroker 1.2K May 31 09:31 package.json
                  drwxrwxr-x+    3 iobroker iobroker 4.0K May 31 09:31 widgets
                    ja
                      @ppb1308 dann versuch es erst mal mit iob upload all
                        ok, das hat nun fast alles upgedatet, aber das eine Vis Widget bleibt ohne Update und zeigt immer noch die Meldung im Debug "INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-justgage/www" was not found! Nothing was uploaded or deleted.":
                        das Log zum Update Versuch:
                        $ iobroker upgrade vis-justgage@2.1.7 --debug
                        Update vis-justgage from @1.0.2 to @2.1.7
                        NPM version: 10.7.0
                        Installing iobroker.vis-justgage@2.1.7... (System call)
                        npm warn ERESOLVE overriding peer dependencynpm warn While resolving: @iobroker/adapter-core@3.1.4npm warn Found: @iobroker/types@6.0.0npm warn node_modules/iobroker.admin/node_modules/@iobroker/typesnpm warn @iobroker/types@"6.0.0" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warn iobroker.admin@"6.17.14" from the root projectnpm warnnpm warn Could not resolve dependency:npm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.adminnpm warnnpm warn Conflicting peer dependency: @iobroker/types@5.0.19npm warn node_modules/@iobroker/typesnpm warn peer @iobroker/types@"^5.0.11" from @iobroker/adapter-core@3.1.4npm warn node_modules/iobroker.admin/node_modules/@iobroker/adapter-corenpm warn @iobroker/adapter-core@"^3.1.4" from iobroker.admin@6.17.14npm warn node_modules/iobroker.admin
                        npm warn deprecated left-pad@1.3.0: use String.prototype.padStart()
                        npm warn deprecated w3c-hr-time@1.0.2: Use your platform's native performance.now() and performance.timeOrigin.
                        npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                        npm warn deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                        removed 2 packages, and changed 1 package in 11s
                        Adapter "system.adapter.vis.0" restarted.
                        Adapter "system.adapter.vis-2.0" restarted.
                        Update "system.adapter.vis-justgage.0"
                        upload [2] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index.html index.html text/html
                        upload [1] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/index_m.html index_m.html text/html
                        upload [0] vis-justgage.admin /opt/iobroker/node_modules/iobroker.vis-justgage/admin/justgage.png justgage.png image/png
                        Process exited with code 0
                        Das Verzeichnis gibts auch nicht:
                        peter@briioBrProx:/opt/iobroker$ ls -lah /opt/iobroker/node_modules/iobroker.vis-justgage
                        total 124K
                        drwxrwxr-x+    5 iobroker iobroker 4.0K May 31 10:54 .
                        drwxrwxr-x+ 1215 iobroker iobroker  68K May 31 10:54 ..
                        -rw-rw-r--+    1 iobroker iobroker 1.2K May 31 10:54 LICENSE
                        -rw-rw-r--+    1 iobroker iobroker 5.9K May 31 10:54 README.md
                        drwxrwxr-x+    2 iobroker iobroker 4.0K May 31 10:54 admin
                        drwxrwxr-x+    2 iobroker iobroker 4.0K May 31 10:54 img
                        -rw-rw-r--+    1 iobroker iobroker  14K May 31 10:54 io-package.json
                        -rw-rw-r--+    1 iobroker iobroker    1 May 31 10:54 iob_npm.done
                        -rw-rw-r--+    1 iobroker iobroker 2.5K May 31 10:54 package.json
                        drwxrwxr-x+    3 iobroker iobroker 4.0K May 31 10:54 widgets
                        Qix- created this issue in visionmedia/debug
                        closed ReDos Vulnerability Regression Visibility Notice #797
                        Homoran P 2 Replies Last reply Reply Quote 0
                          wR das die defekte Version?
                            PPB1308 @PPB1308 last edited by
                            Update scheint aber nun geklappt zu haben, das Widget wird nicht mehr als ncht aktuell gelistet.
                            Hm, sehr merkwürdig.
                              PPB1308 @Homoran last edited by PPB1308
                              Hm, kann ich nicht sagen, den Core Adapter hab ich gar nicht im Visier gehabt, nur die Vis Widgets, die sich nicht updaten ließen.
                              Das scheint ja nach dem update all wohl behoben.
                              Muss ich mir um das vermeintlich fehlende Verzeichnis Sorgen machen?
                              Danke für die Hilfe!
                                den Core Adapter
                                das ist kein Adapter, aber die defekte Version war es anscheinend nicht
                                Vielleicht weiss @Thomas-Braun das noch besser
                                  @homoran @PPB1308
                                  Keine Ahnung.
                                  Aber bring alle Adapter auf Stand oder geh auf das Stable-Repository.
                                    PPB1308 @Thomas Braun last edited by
                                    ja, hab ich ja jetzt gemacht.
                                    Danke.
                                    • mcm1957
                                      mcm1957 last edited by
                                      @ppb1308
                                      Sodala
                                      adapter-core 3.1.4 ist die aktuellste und empfohlene Version
                                      vis-justgage hat kein www Verzeichnis. Keine Ahnung woher die Fehlermeldung kommt. vis-justgage ist m.W. nach nicht mit vis-2 kompatibel
                                      vis-map gibt diese Meldung via admin news aus. Die Funktion ist durch diese Meldung in keiner Weise beeinflusst. Wenn das Widget funktioniert sollte also alles OK sein. Bitte eröffne ggF ein Issue im adapter repo.
                                      1318
