    4. Hilfe beim Zigbee Controller mit Sonoff Zigbee 3.0
      Homoran Global Moderator Administrators @Jan Lange last edited by
      @jan-lange sagte in Hilfe beim Zigbee Controller mit Sonoff Zigbee 3.0:
      dass er sich sich nicht verbinden kann.
      /dev/serial/by-id hast du ja korrekt (?) drin!
      was sagt jetzt das debug-log beim Start der Instanz?
        Thomas Braun Most Active @Jan Lange last edited by
        @jan-lange
        Und mit welchen Meldungen tut der Adapter das nun?
        Jan Lange 1 Reply Last reply Reply Quote 0
        • Jan Lange
          Jan Lange @Thomas Braun last edited by Jan Lange
          als COM Id habe ich hinterlegt "/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124092219-if00"
          total 0
          drwxr-xr-x 2 root root 60 May 31 13:08 .
          drwxr-xr-x 4 root root 80 May 31 13:08 ..
          lrwxrwxrwx 1 root root 13 May 31 13:08 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124092219-if00 -> ../../ttyACM0
          Hier der Log aus der Console
          2024-05-31 14:36:03.302  - info: host.raspberry4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-05-31 14:36:03.340  - info: admin.0 (2912) <== Disconnect system.user.admin from ::ffff:192.168.0.23
          2024-05-31 14:36:02.563  - info: host.raspberry4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
          2024-05-31 14:36:02.571  - info: zigbee.0 (3717) Got terminate signal TERMINATE_YOURSELF
          2024-05-31 14:36:02.602  - info: host.raspberry4 stopInstance system.adapter.zigbee.0 send kill signal
          2024-05-31 14:36:02.575  - info: zigbee.0 (3717) cleaned everything up...
          2024-05-31 14:36:02.582  - info: zigbee.0 (3717) Zigbee: disabling joining new devices.
          2024-05-31 14:36:02.634  - warn: zigbee.0 (3717) Failed to stop zigbee during startup
          2024-05-31 14:36:02.635  - info: zigbee.0 (3717) terminating
          2024-05-31 14:36:02.636  - info: zigbee.0 (3717) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-05-31 14:36:03.076  - info: zigbee.0 (3717) terminating
          2024-05-31 14:36:05.672  - info: host.raspberry4 instance system.adapter.zigbee.0 started with pid 3768
          2024-05-31 14:36:10.832  - info: zigbee.0 (3768) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.14.0, js-controller: 5.0.19
          2024-05-31 14:36:10.939  - info: zigbee.0 (3768) delete old Backup files. keep only last 10
          2024-05-31 14:36:10.942  - info: zigbee.0 (3768) Starting Zigbee  npm ...
          2024-05-31 14:36:11.303  - info: zigbee.0 (3768) Installed Version: iobroker.zigbee@1.10.3
          2024-05-31 14:36:15.301  - error: zigbee.0 (3768) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
          2024-05-31 14:36:15.302  - error: zigbee.0 (3768) Failed to start Zigbee
          2024-05-31 14:36:15.303  - error: zigbee.0 (3768) Error herdsman start
          Thomas Braun Homoran crunchip 4 Replies Last reply Reply Quote 0
            @jan-lange
            Keine Bildchen des Logs posten.
              @jan-lange kaum zu entziffern, bitte als text in code-tags posten.
              und vorher die Logstufe der Instanz auf debug stellen
                Da ist die PanID, die extended PanID oder der Transportschlüssel falsch. Früher standen die Abweichungen mal im Log. Ist wohl irgendwann unter den Tisch gefallen.
                Jan Lange 2 Replies Last reply Reply Quote 0
                • Jan Lange
                  Hier noch mal der Log mit debug Info:
                  2024-05-31 14:39:51.043  - info: host.raspberry4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2024-05-31 14:39:51.056  - info: zigbee.0 (3869) Got terminate signal TERMINATE_YOURSELF
                  2024-05-31 14:39:51.061  - info: zigbee.0 (3869) cleaned everything up...
                  2024-05-31 14:39:51.079  - info: zigbee.0 (3869) Zigbee: disabling joining new devices.
                  2024-05-31 14:39:51.134  - warn: zigbee.0 (3869) Failed to stop zigbee during startup
                  2024-05-31 14:39:51.134  - info: zigbee.0 (3869) terminating
                  2024-05-31 14:39:51.136  - debug: zigbee.0 (3869) Plugin sentry destroyed
                  2024-05-31 14:39:51.136  - info: zigbee.0 (3869) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-05-31 14:39:51.160  - info: host.raspberry4 stopInstance system.adapter.zigbee.0 send kill signal
                  2024-05-31 14:39:51.563  - info: zigbee.0 (3869) terminating
                  2024-05-31 14:39:51.736  - info: host.raspberry4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2024-05-31 14:39:54.222  - info: host.raspberry4 instance system.adapter.zigbee.0 started with pid 3897
                  2024-05-31 14:39:58.744  - debug: zigbee.0 (3897) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2024-05-31 14:39:58.800  - debug: zigbee.0 (3897) Objects client ready ... initialize now
                  2024-05-31 14:39:58.804  - debug: zigbee.0 (3897) Objects create System PubSub Client
                  2024-05-31 14:39:58.806  - debug: zigbee.0 (3897) Objects create User PubSub Client
                  2024-05-31 14:39:58.887  - debug: zigbee.0 (3897) Objects client initialize lua scripts
                  2024-05-31 14:39:58.900  - debug: zigbee.0 (3897) Objects connected to redis: 127.0.0.1:9001
                  2024-05-31 14:39:58.949  - debug: zigbee.0 (3897) Redis States: Use Redis connection: 127.0.0.1:9000
                  2024-05-31 14:39:58.972  - debug: zigbee.0 (3897) States create System PubSub Client
                  2024-05-31 14:39:58.974  - debug: zigbee.0 (3897) States create User PubSub Client
                  2024-05-31 14:39:59.056  - debug: zigbee.0 (3897) States connected to redis: 127.0.0.1:9000
                  2024-05-31 14:39:59.107  - debug: zigbee.0 (3897) Plugin sentry Initialize Plugin (enabled=true)
                  2024-05-31 14:39:59.625  - info: zigbee.0 (3897) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.14.0, js-controller: 5.0.19
                  2024-05-31 14:39:59.659  - debug: zigbee.0 (3897) Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"extenedPanID":[208,221,220,221,221,210,222,173]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20240124092219-if00","adapter":"ezsp"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                  2024-05-31 14:39:59.722  - info: zigbee.0 (3897) delete old Backup files. keep only last 10
                  2024-05-31 14:39:59.724  - info: zigbee.0 (3897) Starting Zigbee  npm ...
                  2024-05-31 14:39:59.778  - debug: zigbee.0 (3897) Starting zigbee-herdsman...
                  2024-05-31 14:40:00.089  - info: zigbee.0 (3897) Installed Version: iobroker.zigbee@1.10.3
                  2024-05-31 14:40:00.488  - debug: zigbee.0 (3897) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_05_31-14_39_59.tar.gz success
                  2024-05-31 14:40:04.040  - error: zigbee.0 (3897) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
                  2024-05-31 14:40:04.042  - error: zigbee.0 (3897) Failed to start Zigbee
                  2024-05-31 14:40:04.043  - error: zigbee.0 (3897) Error herdsman start
                  • Jan Lange
                    das hatte ich ja auch vermutet. Nur wie finde ich raus welche die Richtigen sind?
                      Keine Ahnung. Wie gesagt, früher stands mal im Log drin.
                        crunchip Forum Testing Most Active @Jan Lange last edited by
                        fehlt da nicht der Port?
                          Thomas Braun Most Active @crunchip last edited by
                          @crunchip
                          Nein.
                            crunchip Forum Testing Most Active @Thomas Braun last edited by
                            @thomas-braun ok, dann wäre vllt noch möglich
                            Es ist zu achten dass am Ende kein leer Zeichen mitgenommen wird
                              @crunchip
                              Ja. Hier ist aber vermutlich das nvram/backup zu löschen.
                                @thomas-braun jep, hatte ich auch im parallel Thread geschrieben
                                • Jan Lange
                                  Jan Lange @crunchip last edited by
                                  @crunchip
                                  Also ich habe mal die Backup gelöscht wie der User in parallel Thread: Allerdings bringt das bei mir nichts.
                                  rm: cannot remove '/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json': No such file or directory
                                  In dem Ordner zigbee_0 liegt jedoch eine andere Backup Datei macht es Sinn diese mal zu löschen?
                                  dir /opt/iobroker/iobroker-data/zigbee_0/
                                  backup_2024_06_03-11_08_00.tar.gz  shepherd.db
                                  Habe auch mal versucht die Default Werte zu nutzen. Bringt leider auch nichts.
                                  • Jan Lange
                                    Jan Lange @Jan Lange last edited by Jan Lange
                                    Habs jetzt noch mal versucht und wenn ich den Typ ebenfalls auf den init Wert stehen lass, dann bekommt er die Verbindung aufgebaut. Aber auch wirklich nur dann und wie in dem anderen Post nur mit dem Standard Werten.
                                    Habe inzwischen auch mal ein Conbee testen können. Da klappt alles problemlos.
                                    1.0k
                                    2603
