    3. Einsteigerfragen
    4. Installation
    5. node js Update - npm bad error EBADENGINE
      Thomas Braun Most Active @madjack84 last edited by
      @madjack84
      iob update
      iob upgrade all -y
      madjack84 1 Reply Last reply Reply Quote 0
      • madjack84
        madjack84 @madjack84 last edited by
        @madjack84
        hier noch das NPM log
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: ioalbrecht
                 Icon name: computer-vm
                   Chassis: vm
            Virtualization: kvm
          Operating System: Ubuntu 20.04.6 LTS
                    Kernel: Linux 5.4.0-182-generic
              Architecture: x86-64
        model name	: Common KVM processor
        Docker          : false
        Virtualization  : kvm
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         19:43:38 up 37 min,  1 user,  load average: 0.17, 0.11, 0.15
        CPU threads: 2
        *** Time and Time Zones ***
                       Local time: Fri 2024-05-31 19:43:38 CEST
                   Universal time: Fri 2024-05-31 17:43:38 UTC
                         RTC time: Fri 2024-05-31 17:43:39
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        upgrade
        HOME=/home/upgrade
        GROUPS=upgrade adm dialout cdrom sudo dip plugdev lxd iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video redis
        *** Display-Server-Setup ***
        Display-Server: false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:           3.9G        1.8G        1.3G        1.0M        866M        1.9G
        Swap:          3.9G          0B        3.9G
        Total:         7.9G        1.8G        5.2G
        Active iob-Instances: 	19
                 3920 M total memory
                 1760 M used memory
                 1960 M active memory
                  470 M inactive memory
                 1293 M free memory
                   90 M buffer memory
                  775 M swap cache
                 3935 M total swap
                    0 M used swap
                 3935 M free swap
        top - 19:43:39 up 37 min,  1 user,  load average: 0.17, 0.11, 0.15
        Tasks: 145 total,   1 running, 144 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3920.1 total,   1293.8 free,   1760.0 used,    866.4 buff/cache
        MiB Swap:   3936.0 total,   3936.0 free,      0.0 used.   1922.3 avail Mem
        *** FAILED SERVICES ***
          UNIT                             LOAD   ACTIVE SUB    DESCRIPTION
        * snap.mosquitto.mosquitto.service loaded failed failed Service for snap application mosquitto.mosquitto
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                        Type      Size  Used Avail Use% Mounted on
        udev                              devtmpfs  1.9G     0  1.9G   0% /dev
        tmpfs                             tmpfs     393M  1.1M  391M   1% /run
        /dev/mapper/ubuntu--vg-ubuntu--lv ext4       20G   15G  4.3G  78% /
        tmpfs                             tmpfs     2.0G     0  2.0G   0% /dev/shm
        tmpfs                             tmpfs     5.0M     0  5.0M   0% /run/lock
        tmpfs                             tmpfs     2.0G     0  2.0G   0% /sys/fs/cgroup
        /dev/sda2                         ext4      974M  312M  595M  35% /boot
        /dev/loop0                        squashfs   56M   56M     0 100% /snap/core18/2823
        /dev/loop1                        squashfs   56M   56M     0 100% /snap/core18/2812
        /dev/loop2                        squashfs   64M   64M     0 100% /snap/core20/2318
        /dev/loop3                        squashfs  1.2M  1.2M     0 100% /snap/mosquitto/873
        /dev/loop4                        squashfs   92M   92M     0 100% /snap/lxd/24061
        /dev/loop5                        squashfs   64M   64M     0 100% /snap/core20/2264
        /dev/loop6                        squashfs  1.2M  1.2M     0 100% /snap/mosquitto/856
        /dev/loop7                        squashfs   92M   92M     0 100% /snap/lxd/23991
        /dev/loop8                        squashfs   39M   39M     0 100% /snap/snapd/21465
        /dev/loop9                        squashfs   39M   39M     0 100% /snap/snapd/21759
        tmpfs                             tmpfs     393M     0  393M   0% /run/user/1000
        [Fri May 31 19:06:31 2024] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
        [Fri May 31 19:06:32 2024] EXT4-fs (dm-0): re-mounted. Opts: (null)
        [Fri May 31 19:06:34 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
        Show mounted filesystems:
        TARGET                                SOURCE                            FSTYPE      OPTIONS
        /                                     /dev/mapper/ubuntu--vg-ubuntu--lv ext4        rw,relatime
        |-/sys                                sysfs                             sysfs       rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security              securityfs                        securityfs  rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup                    tmpfs                             tmpfs       ro,nosuid,nodev,noexec,mode=755
        | | |-/sys/fs/cgroup/unified          cgroup2                           cgroup2     rw,nosuid,nodev,noexec,relatime,nsdelegate
        | | |-/sys/fs/cgroup/systemd          cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,xattr,name=systemd
        | | |-/sys/fs/cgroup/devices          cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,devices
        | | |-/sys/fs/cgroup/cpuset           cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,cpuset
        | | |-/sys/fs/cgroup/net_cls,net_prio cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,net_cls,net_prio
        | | |-/sys/fs/cgroup/memory           cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,memory
        | | |-/sys/fs/cgroup/rdma             cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,rdma
        | | |-/sys/fs/cgroup/cpu,cpuacct      cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,cpu,cpuacct
        | | |-/sys/fs/cgroup/freezer          cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,freezer
        | | |-/sys/fs/cgroup/hugetlb          cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,hugetlb
        | | |-/sys/fs/cgroup/perf_event       cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,perf_event
        | | |-/sys/fs/cgroup/pids             cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,pids
        | | `-/sys/fs/cgroup/blkio            cgroup                            cgroup      rw,nosuid,nodev,noexec,relatime,blkio
        | |-/sys/fs/pstore                    pstore                            pstore      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf                       none                              bpf         rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/debug                 debugfs                           debugfs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/tracing               tracefs                           tracefs     rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config                configfs                          configfs    rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections          fusectl                           fusectl     rw,nosuid,nodev,noexec,relatime
        |-/proc                               proc                              proc        rw,nosuid,nodev,noexec,relatime
        | `-/proc/sys/fs/binfmt_misc          systemd-1                         autofs      rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15764
        |   `-/proc/sys/fs/binfmt_misc        binfmt_misc                       binfmt_misc rw,nosuid,nodev,noexec,relatime
        |-/dev                                udev                              devtmpfs    rw,nosuid,noexec,relatime,size=1960344k,nr_inodes=490086,mode=755
        | |-/dev/pts                          devpts                            devpts      rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | |-/dev/shm                          tmpfs                             tmpfs       rw,nosuid,nodev
        | |-/dev/hugepages                    hugetlbfs                         hugetlbfs   rw,relatime,pagesize=2M
        | `-/dev/mqueue                       mqueue                            mqueue      rw,nosuid,nodev,noexec,relatime
        |-/run                                tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=401424k,mode=755
        | |-/run/lock                         tmpfs                             tmpfs       rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs                   sunrpc                            rpc_pipefs  rw,relatime
        | |-/run/snapd/ns                     tmpfs[/snapd/ns]                  tmpfs       rw,nosuid,nodev,noexec,relatime,size=401424k,mode=755
        | | |-/run/snapd/ns/lxd.mnt           nsfs[mnt:[4026532318]]            nsfs        rw
        | | `-/run/snapd/ns/mosquitto.mnt     nsfs[mnt:[4026532320]]            nsfs        rw
        | `-/run/user/1000                    tmpfs                             tmpfs       rw,nosuid,nodev,relatime,size=401420k,mode=700,uid=1000,gid=1000
        |-/boot                               /dev/sda2                         ext4        rw,relatime
        |-/snap/core18/2823                   /dev/loop0                        squashfs    ro,nodev,relatime
        |-/snap/core18/2812                   /dev/loop1                        squashfs    ro,nodev,relatime
        |-/snap/core20/2318                   /dev/loop2                        squashfs    ro,nodev,relatime
        |-/snap/mosquitto/873                 /dev/loop3                        squashfs    ro,nodev,relatime
        |-/snap/lxd/24061                     /dev/loop4                        squashfs    ro,nodev,relatime
        |-/snap/core20/2264                   /dev/loop5                        squashfs    ro,nodev,relatime
        |-/snap/mosquitto/856                 /dev/loop6                        squashfs    ro,nodev,relatime
        |-/snap/lxd/23991                     /dev/loop7                        squashfs    ro,nodev,relatime
        |-/snap/snapd/21465                   /dev/loop8                        squashfs    ro,nodev,relatime
        `-/snap/snapd/21759                   /dev/loop9                        squashfs    ro,nodev,relatime
        /var:
        2.4G	/var/
        1.2G	/var/lib
        926M	/var/lib/snapd
        901M	/var/log
        897M	/var/log/journal/9eafc192ff0e4f099ca8b43790018b7d
        Archived and active journals take up 896.1M in the file system.
        /opt/iobroker/backups:
        352M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.4G	/opt/iobroker/iobroker-data/
        726M	/opt/iobroker/iobroker-data/files
        511M	/opt/iobroker/iobroker-data/files/ring.0
        498M	/opt/iobroker/iobroker-data/files/ring.0/doorbell_91774976
        386M	/opt/iobroker/iobroker-data/backup-objects
        47M	/opt/iobroker/iobroker-data/states.jsonl
        35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        29M	/opt/iobroker/iobroker-data/objects.jsonl
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2473751-if00
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v20.14.0
        /usr/bin/node 		v20.14.0
        /usr/bin/npm 		10.7.0
        /usr/bin/npx 		10.7.0
        /usr/bin/corepack 	0.28.1
        nodejs:
          Installed: 20.14.0-1nodesource1
          Candidate: 20.14.0-1nodesource1
          Version table:
         *** 20.14.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             10.19.0~dfsg-3ubuntu1.6 500
                500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                500 http://de.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
             10.19.0~dfsg-3ubuntu1 500
                500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.12
        admin: 		6.13.16
        javascript: 	7.1.4
        nodejs modules from github: 	1
        | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
        Adapter State
        + system.adapter.admin.0                  : admin                 : ioalbrecht                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : ioalbrecht                               -  enabled
          system.adapter.alias-manager.0          : alias-manager         : ioalbrecht                               -  enabled
        + system.adapter.backitup.0               : backitup              : ioalbrecht                               -  enabled
          system.adapter.daswetter.0              : daswetter             : ioalbrecht                               -  enabled
          system.adapter.devices.0                : devices               : ioalbrecht                               -  enabled
          system.adapter.discovery.0              : discovery             : ioalbrecht                               - disabled
          system.adapter.feiertage.0              : feiertage             : ioalbrecht                               -  enabled
          system.adapter.flot.0                   : flot                  : ioalbrecht                               - disabled
        + system.adapter.history.0                : history               : ioalbrecht                               -  enabled
        + system.adapter.info.0                   : info                  : ioalbrecht                               -  enabled
        + system.adapter.iot.0                    : iot                   : ioalbrecht                               -  enabled
        + system.adapter.javascript.0             : javascript            : ioalbrecht                               -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioalbrecht                               -  enabled, port: 54321
        + system.adapter.mihome.0                 : mihome                : ioalbrecht                               -  enabled, port: 9898, bind: 0.0.0.0
        + system.adapter.mqtt-client.0            : mqtt-client           : ioalbrecht                               -  enabled, port: 1883
        + system.adapter.mqtt-client.1            : mqtt-client           : ioalbrecht                               -  enabled, port: 1883
        + system.adapter.ping.0                   : ping                  : ioalbrecht                               -  enabled
          system.adapter.ring.0                   : ring                  : ioalbrecht                               - disabled
          system.adapter.samsung.0                : samsung               : ioalbrecht                               - disabled
        + system.adapter.simple-api.0             : simple-api            : ioalbrecht                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.telegram.0               : telegram              : ioalbrecht                               -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : ioalbrecht                               -  enabled
        + system.adapter.vw-connect.0             : vw-connect            : ioalbrecht                               -  enabled
        + system.adapter.web.0                    : web                   : ioalbrecht                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.wled.0                   : wled                  : ioalbrecht                               - disabled
        + system.adapter.zigbee.0                 : zigbee                : ioalbrecht                               -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2473751-if00
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.4 [Updatable]
        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
        Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
        Adapter    "deconz"       : 1.4.1    , installed 1.3.19 [Updatable]
        Adapter    "discovery"    : 4.4.0    , installed 3.1.0  [Updatable]
        Adapter    "feiertage"    : 1.2.0    , installed 1.1.4  [Updatable]
        Adapter    "iot"          : 3.2.2    , installed 2.0.11 [Updatable]
        Adapter    "javascript"   : 8.3.1    , installed 7.1.4  [Updatable]
        Controller "js-controller": 5.0.19   , installed 5.0.12 [Updatable]
        Adapter    "mihome"       : 1.4.0    , installed 1.4.0
        Adapter    "mihome-vacuum": 4.2.0    , installed 4.0.0  [Updatable]
        Adapter    "mqtt-client"  : 1.8.0    , installed 1.7.0  [Updatable]
        Adapter    "ring"         : 5.0.10   , installed 3.2.2  [Updatable]
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
        Adapter    "socketio"     : 6.7.0    , installed 6.6.1  [Updatable]
        Adapter    "telegram"     : 3.2.1    , installed 3.1.0  [Updatable]
        Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "ws"           : 2.6.1    , installed 2.5.11 [Updatable]
        Adapter    "zigbee"       : 1.10.3   , installed 1.8.24 [Updatable]
        Objects and States
        Objects: 	11401
        States: 	9587
        Hit:1 http://phoscon.de/apt/deconz focal InRelease
        Hit:2 http://ppa.launchpad.net/chris-lea/redis-server/ubuntu focal InRelease
        Hit:3 http://de.archive.ubuntu.com/ubuntu focal InRelease
        Hit:4 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:6 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
        Hit:7 http://de.archive.ubuntu.com/ubuntu focal-security InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        22411      648/systemd-resolve
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          25267      721/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          24892      672/mosquitto
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27453      669/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27394      669/iobroker.js-con
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15775      1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          25278      721/sshd: /usr/sbin
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       29602      1410/io.simple-api.
        tcp6       0      0 :::1883                 :::*                    LISTEN      0          24893      672/mosquitto
        tcp6       0      0 :::111                  :::*                    LISTEN      0          15783      1/init
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       27613      963/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31154      1569/io.web.0
        udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       28129      1093/io.mihome.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        22410      648/systemd-resolve
        udp        0      0 192.168.188.74:68       0.0.0.0:*                           100        22414      646/systemd-network
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15778      1/init
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       28081      1065/io.mihome-vacu
        udp6       0      0 :::111                  :::*                                0          15788      1/init
        udp6       0      0 fe80::e091:47ff:fe6:546 :::*                                100        22631      646/systemd-network
        2024-05-31 19:29:58.040  - info: host.ioalbrecht iobroker npm error code EBADENGINE
        2024-05-31 19:29:58.044  - info: host.ioalbrecht iobroker npm error engine Unsupported engine
        2024-05-31 19:29:58.046  - info: host.ioalbrecht iobroker npm error engine Not compatible with your version of node/npm: ring-client-api@11.7.1
        2024-05-31 19:29:58.047  - info: host.ioalbrecht iobroker npm error notsup Not compatible with your version of node/npm: ring-client-api@11.7.1npm error notsup Required: {"node":"^16 || ^18"}npm error notsup Actual:   {"npm":"10.7.0","node":"v20.14.0"}
        2024-05-31 19:29:58.051  - info: host.ioalbrecht iobroker
        2024-05-31 19:29:58.053  - info: host.ioalbrecht iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-31T17_29_55_322Z-debug-0.log
        2024-05-31 19:29:58.201  - info: host.ioalbrecht iobroker upload [17] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/custom.html custom.html text/html
        2024-05-31 19:29:58.209  - info: host.ioalbrecht iobroker upload [16] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/custom_m.html custom_m.html text/html
        2024-05-31 19:29:58.213  - info: host.ioalbrecht iobroker upload [15] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/de/translations.json i18n/de/translations.json application/json
        2024-05-31 19:29:58.218  - info: host.ioalbrecht iobroker upload [14] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/en/translations.json i18n/en/translations.json application/json
        2024-05-31 19:29:58.223  - info: host.ioalbrecht iobroker upload [13] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/es/translations.json i18n/es/translations.json application/json
        2024-05-31 19:29:58.228  - info: host.ioalbrecht iobroker upload [12] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        2024-05-31 19:29:58.233  - info: host.ioalbrecht iobroker upload [11] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/it/translations.json i18n/it/translations.json application/json
        2024-05-31 19:29:58.238  - info: host.ioalbrecht iobroker upload [10] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        2024-05-31 19:29:58.244  - info: host.ioalbrecht iobroker upload [9] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        2024-05-31 19:29:58.249  - info: host.ioalbrecht iobroker upload [8] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        2024-05-31 19:29:58.254  - info: host.ioalbrecht iobroker upload [7] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        2024-05-31 19:29:58.259  - info: host.ioalbrecht iobroker upload [6] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
        2024-05-31 19:29:58.265  - info: host.ioalbrecht iobroker upload [5] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        2024-05-31 19:29:58.269  - info: host.ioalbrecht iobroker upload [4] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/index.html index.html text/html
        2024-05-31 19:29:58.274  - info: host.ioalbrecht iobroker upload [3] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/index_m.html index_m.html text/html
        2024-05-31 19:29:58.279  - info: host.ioalbrecht iobroker upload [2] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/jsonCustom.json jsonCustom.json application/json
        2024-05-31 19:29:58.284  - info: host.ioalbrecht iobroker upload [1] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/mqtt-client.png mqtt-client.png image/png
        2024-05-31 19:29:58.289  - info: host.ioalbrecht iobroker upload [0] mqtt-client.admin /opt/iobroker/node_modules/iobroker.mqtt-client/admin/words.js words.js application/javascript
        2024-05-31 19:29:59.304  - info: host.ioalbrecht iobroker exit 0
        iob diag has finished.
        Press any key for a summary
        upgrade@ioalbrecht:~$ cd /home/iobroker/.npm/_logs/
        upgrade@ioalbrecht:/home/iobroker/.npm/_logs$ ls
        2024-05-31T04_51_03_286Z-debug-0.log 2024-05-31T16_51_03_282Z-debug-0.log 2024-05-31T17_10_24_820Z-debug-0.log 2024-05-31T17_29_55_322Z-debug-0.log
        2024-05-31T16_41_37_801Z-debug-0.log 2024-05-31T17_08_51_571Z-debug-0.log 2024-05-31T17_15_46_197Z-debug-0.log 2024-05-31T17_52_53_784Z-debug-0.log
        2024-05-31T16_41_38_253Z-debug-0.log 2024-05-31T17_09_50_211Z-debug-0.log 2024-05-31T17_24_54_814Z-debug-0.log
        upgrade@ioalbrecht:/home/iobroker/.npm/_logs$ nano /home/iobroker/.npm/_logs/2024-05-31T17_52_53_784Z-debug-0.log
        GNU nano 4.8 /home/iobroker/.npm/_logs/2024-05-31T17_52_53_784Z-debug-0.log
        12 silly logfile done cleaning log files
        13 silly idealTree buildDeps
        14 silly fetch manifest iobroker.mqtt-client@1.8.0
        15 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.alexa2
        16 http fetch GET 200 https://registry.npmjs.org/iobroker.mqtt-client 1407ms (cache revalidated)
        17 silly placeDep ROOT iobroker.mqtt-client@1.8.0 REPLACE for: iobroker.inst@3.0.0 want: 1.8.0
        18 verbose stack Error: Unsupported engine
        18 verbose stack at checkEngine (/usr/lib/node_modules/npm/node_modules/npm-install-checks/lib/index.js:14:25)
        18 verbose stack at #checkEngineAndPlatform (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:220:11)
        18 verbose stack at Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:206:41)
        18 verbose stack at async Promise.all (index 1)
        18 verbose stack at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:131:5)
        18 verbose stack at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
        18 verbose stack at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
        19 verbose pkgid ring-client-api@11.7.1
        20 verbose cwd /opt/iobroker
        21 verbose Linux 5.4.0-182-generic
        22 verbose node v20.14.0
        23 verbose npm v10.7.0
        24 error code EBADENGINE
        25 error engine Unsupported engine
        26 error engine Not compatible with your version of node/npm: ring-client-api@11.7.1
        27 error notsup Not compatible with your version of node/npm: ring-client-api@11.7.1
        27 error notsup Required: {"node":"^16 || ^18"}
        27 error notsup Actual: {"npm":"10.7.0","node":"v20.14.0"}
        28 verbose exit 1
        29 verbose code 1
        30 silly unfinished npm timer reify 1717177974152
        31 silly unfinished npm timer reify:loadTrees 1717177974174
        32 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-05-31T17_52_53_784Z-debug-0.log
        • madjack84
          madjack84 @Thomas Braun last edited by
          @thomas-braun sagte in node js Update - npm bad error EBADENGINE:
          iob upgrade all -y
          läuft gerade und die ersten Adapter sind durchgelaufen....
          D.h. die Informationen für die Adapter bei mir auf der Platte waren veraltet und konjugiert damit wurden nun das repo aktualisiert??? oder was ist hier der Mechanismus?
            @madjack84 sagte in node js Update - npm bad error EBADENGINE:
            das hier bekomme ich wenn ich den MQTT adapter aktualisieren möchte
            Da klemmt es bei dem ring-Adapter. Den zuerst aktualisieren.
              Der Mechanismus ist, das dein gnadenlos abgesoffener ring-Adapter bzw. eine der Abhängigkeiten so alt war/ist, das der mit aktuellen nodejs-Versionen nicht mag. Deswegen hält man seine Kiste auch regelmäßig auf Stand, dann passiert das nicht (so leicht).
              • madjack84
                ich hab heut dick gelesen:
                If it ain't broker, don't fix it 🤷‍♂️
                aber ja,... ich hab den iobroker die letzten Monate stark vernachlässigt 😞
                Dir schonmal größten Dank für die fixe Hilfe.... ich wühl mich mal durch ob alles funktioniert 🙂
                  Thomas Braun Most Active @madjack84 last edited by Thomas Braun
                  MOOOOOOOOOARRRRRR....
                  Das ist der allergrößte BULLSHIT EVER!!!!!!!
                  Wer erzählt so einen Schwachsinn immer????
                  Es gilt: Halt die Kiste immer auf einem aktuellen, stabilen Stand.
                  madjack84 2 Replies Last reply Reply Quote 1
                  • madjack84
                    https://tasmota.github.io/docs/Upgrading/
                    these guys 😄 😄 😄 hab vorhin ne Steckdose aktualisiert
                    Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                    • madjack84
                      @thomas-braun Lektion gelernt!
                      Und ich bin immer noch beeindruckt wie du das so schnell irgendwo rausgelesen hast. Hab eben die logs durch gescrollt und nix gefunden #shame
                      Danke nochmal 🙂
                        @madjack84
                        Joh, bei Tasmota sollst du auch nicht jede kleine Änderung in den Speicher dampfen. Aber so ab und an würde ich auch das auf die nächste Major-Version heben.
                        Für Server-(Dienste) gilt aber: Updaten, updaten, updaten.
                        • Meister Mopper
                          Meister Mopper @madjack84 last edited by
                          these guys hab vorhin ne Steckdose aktualisiert
                          IOT ist ein großes Sicherheitsrisiko und bedarf ständiger Upgrades.
                          Das auch hier oftmals proklamierte Argument, "meine Geräte dürfen nicht ins Internet" greift aus meiner Sicht zu kurz, denn wenn ICH darauf zugreifen kann, kann ein anderer, der auf irgendeine Weise mein System kompromittiert hat, vortäuschen ICH zu sein.
                          Hier eine Startrampe für IOT-Sicherheit
                          lobomau 1 Reply Last reply Reply Quote 0
                          • lobomau
                            lobomau @Meister Mopper last edited by Homoran
                            Ich bin hier gelandet bei der Suche nach meinem Fehler:
                            Ich habe einen Adapter-Update-Stau seitdem ich auf node 22 geupdatet bin auf dem Pi4. Auf meinem Haupthost auf einem NUC habe ich die Probleme nicht. Es kann also nicht an den Adaptern liegen:
                            Admin Updateversuch:
                             $ iobroker upgrade device-watcher@2.12.6 --debug
                            Update device-watcher from @2.12.1 to @2.12.6
                            NPM version: 10.9.3
                            Installing iobroker.device-watcher@2.12.6... (System call)
                            npm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: hap-nodejs@1.1.0npm error notsup Not compatible with your version of node/npm: hap-nodejs@1.1.0npm error notsup Required: {"node":"^18 || ^20"}npm error notsup Actual: {"npm":"10.9.3","node":"v22.19.0"}
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-12T14_16_19_654Z-debug-0.log
                            Updating objects from io-package.json for adapter "device-watcher" with version "2.12.1"
                            upload [19] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/device-watcher.png device-watcher.png image/png
                            upload [18] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [17] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [16] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [15] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [14] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [13] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [12] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [11] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [10] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [9] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                            upload [8] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [7] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/add_blacklist.png images/add_blacklist.png image/png
                            upload [6] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list1.png images/list1.png image/png
                            upload [5] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list2.png images/list2.png image/png
                            upload [4] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list3.png images/list3.png image/png
                            upload [3] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/noti_push.jpeg images/noti_push.jpeg image/jpeg
                            upload [2] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/noti_push2.jpeg images/noti_push2.jpeg image/jpeg
                            upload [1] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                            upload [0] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/words.js words.js application/javascript
                            Process exited with code 0
                            Device-Watcher Updateversuch:
                            NPM version: 10.9.3
                            npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: hap-nodejs@1.1.0npm error notsup Not compatible with your version of node/npm: hap-nodejs@1.1.0npm error notsup Required: {"node":"^18 || ^20"}npm error notsup Actual: {"npm":"10.9.3","node":"v22.19.0"}
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-12T14_17_21_747Z-debug-0.log
                              Thomas Braun Most Active @lobomau last edited by Thomas Braun
                              @lobomau sagte in node js Update - npm bad error EBADENGINE:
                              hap-nodejs
                              ist nicht kompatibel mit nodejs@22. Schau nach wo der in deiner Installation hängt und aktualisier den übergeordneten Adapter ggfls. nochmal frisch drüber.
                              cd /opt/iobroker && npm ls hap-nodejs
                              • lobomau
                                lobomau last edited by lobomau
                                @thomas-braun mit
                                npm1 hap-nodejs
                                kann er nichts anfangen. Von zu Hause kann ich besser die Fehlermeldungen posten. Bis später.
                                Im Mai hattet ihr schon das Thema 'hap-nodejs@1.1.0'
                                https://forum.iobroker.net/topic/81186/nodejs-update-post-install-check
                                  Homoran Global Moderator Administrators @lobomau last edited by
                                  mit
                                  npm1 hap-nodejs
                                  das steht ja auch nicht bei @Thomas-Braun
                                    @homoran sagte in node js Update - npm bad error EBADENGINE:
                                    Bei mir stand aber dafür anderer Quark... Jetzt passt es aber.
                                      hatte ich vermutet 😂
                                      • lobomau
                                        lobomau @Homoran last edited by
                                        @homoran ich auch 😄
                                        ich hatte auch "1" und "l" ausprobiert 😉
                                        Nun lief schon mal der Befehl durch:
                                        pi@Pi4:~ $ cd /opt/iobroker && npm ls hap-nodejs
                                        iobroker.inst@3.0.0 /opt/iobroker
                                        └─┬ iobroker.yahka@1.0.9
                                          └── hap-nodejs@1.1.0
                                        Ich habe anschließend einen reboot und update, upgrade ausgeführt.
                                        noch sind wir nicht am Ziel, Fehler ist geblieben:
                                        $ iobroker upgrade admin@7.7.2 --debug
                                        Update admin from @7.6.17 to @7.7.2
                                        host.Pi4 Adapter "system.adapter.admin.2" is stopped.
                                        NPM version: 10.9.3
                                        Installing iobroker.admin@7.7.2... (System call)
                                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-12T16_24_24_746Z-debug-0.log
                                        Updating objects from io-package.json for adapter "admin" with version "7.6.17"
                                        upload [171] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                        upload [150] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/Components-BGVs6Dmn.js custom/assets/Components-BGVs6Dmn.js application/javascript
                                        upload [100] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/assets/index-B82Lauwj.js custom/assets/index-B82Lauwj.js application/javascript
                                        Homoran Thomas Braun mcm1957 3 Replies Last reply Reply Quote 0
                                          wie auch?
                                          hast du das vollständig gemacht?
                                            @lobomau
                                            Du musst yahka auf Stand bringen...
                                            yahka
                                            github:	1.1.5
                                            latest:	1.1.5 for 65 days
                                            stable:	1.1.5 for 65 days
                                            81.1k
                                            2370
