    3. Einsteigerfragen
    4. Aktualisieren "javascript" auf v8.3.1
      Thomas Braun Most Active @Op last edited by
      @op
      Ausgaben davon hier rein, damit man sieht wo und wie du da nun unterwegs bist.
      • O
        Op @Thomas Braun last edited by
        Copy text starting here:
                                v.2024-05-22
        model name      : Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v9.1.2
        Installation:           Docker
        Kernel:                 x86_64
        Userland:               64 bit
        Timezone:               CEST +0200
        User-ID:                0
        Display-Server:         false
        Pending OS-Updates:     0
        Pending iob updates:    0
        Nodejs-Installation:
        /usr/bin/nodejs         v18.20.3
        /usr/bin/node           v18.20.3
        /usr/bin/npm            10.8.0
        /usr/bin/npx            10.8.0
        /usr/bin/corepack       0.28.0
        Recommended versions are nodejs  and npm
        MEMORY:
        Mem:             16G        1.8G        8.2G        216M        7.1G         14G
        Swap:            12G          0B         12G
        Total:           28G        1.8G         20G
        Active iob-Instances:   1
        Active repo(s): stable
        ioBroker Core:          js-controller           5.0.19
                                admin                   "admin" not found
        Objects type: jsonl
        States  type: jsonl
          system.adapter.admin.0                  : admin                 : buanet-iobroker1                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.web.0                    : web                   : buanet-iobroker1                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                9874
        States:                 7157
        Size of iob-Database:
        25M     /opt/iobroker/iobroker-data/objects.jsonl
        3.1M    /opt/iobroker/iobroker-data/states.jsonl
          Thomas Braun Most Active @Op last edited by Thomas Braun
          @op sagte in Aktualisieren "javascript" auf v8.3.1:
          Ohne admin wird es schwer mit der Weboberfläche.
          iob start web
          iob start admin
          Und dann bitte die Langfassung von
          iob diag
          • O
            Op @Thomas Braun last edited by Homoran
            Skript v.2024-05-22
            *** BASE SYSTEM ***
            Hardware Vendor : Synology
            Kernel          : x86_64
            Userland        : 64 bit
            Docker          : v9.1.2
            Virtualization  : Docker
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             10:29:14 up 12:21,  0 user,  load average: 0.16, 0.29, 0.33
            CPU threads: 2
            *** Time and Time Zones ***
            Sat Jun  1 08:29:14 UTC 2024
            Sat Jun  1 10:29:14 CEST 2024
            CEST +0200
            Etc/UTC
            *** Users and Groups ***
            User that called 'iob diag':
            root
            HOME=/root
            GROUPS=root
            iobroker
            sudo: unable to resolve host buanet-iobroker1: Name or service not known
            HOME=/opt/iobroker
            GROUPS=iobroker tty dialout audio video plugdev
            *** Display-Server-Setup ***
            Desktop:
            Terminal:
            *** MEMORY ***
            Swap:            12G          0B         12G
            Total:           28G        1.8G         20G
                    15854 M total memory
                     1756 M used memory
                     3683 M active memory
                     3691 M inactive memory
                     7823 M free memory
                       39 M buffer memory
                     6767 M swap cache
                    11561 M total swap
                        0 M used swap
                    11561 M free swap
            top - 10:29:15 up 12:21,  0 user,  load average: 0.16, 0.29, 0.33
            Tasks:  10 total,   1 running,   9 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,  0.0 id,100.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  15854.2 total,   7822.6 free,   1758.3 used,   6807.5 buff/cache
            MiB Swap:  11561.9 total,  11561.9 free,      0.0 used.  14095.9 avail Mem
            *** FILESYSTEM ***
            Filesystem     Type   Size  Used Avail Use% Mounted on
            /dev/vg1000/lv btrfs  890G  421G  470G  48% /
            tmpfs          tmpfs   64M     0   64M   0% /dev
            tmpfs          tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
            shm            tmpfs   64M     0   64M   0% /dev/shm
            /dev/vg1000/lv btrfs  890G  421G  470G  48% /opt/iobroker
            /dev/vg1000/lv btrfs  890G  421G  470G  48% /etc/hosts
            tmpfs          tmpfs  7.8G     0  7.8G   0% /proc/acpi
            tmpfs          tmpfs  7.8G     0  7.8G   0% /proc/scsi
            tmpfs          tmpfs  7.8G     0  7.8G   0% /sys/firmware
            [Fri May 31 22:07:50 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
            [Fri May 31 22:07:50 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
            [Fri May 31 22:07:52 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
            [Fri May 31 22:07:52 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
            [Fri May 31 22:07:52 2024] EXT4-fs (loop0): couldn't mount as ext3 due to feature incompatibilities
            [Fri May 31 22:07:52 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
            [Fri May 31 22:07:57 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
            [Fri May 31 22:07:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
            [Fri May 31 22:07:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
            [Fri May 31 22:08:53 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
            Show mounted filesystems:
            TARGET                           SOURCE        FSTYPE OPTIONS
            /                                /dev/vg1000/lv[/@syno/@docker/btrfs/subvolumes/f48cb06166fa6c28da81f514558cfa47f079c7fb2a6e573a7943e9fc52969acf]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata
            _ratio=50,syno_allocator,subvolid=904,subvol=/@syno/@docker/btrfs/subvolumes/f48cb06166fa6c28da81f514558cfa47f079c7fb2a6e573a7943e9fc52969acf
            |-/proc                          proc        proc   rw,nosuid,nodev,noexec,relatime
            | |-/proc/bus                    proc[/bus]        proc   ro,relatime
            | |-/proc/fs                     proc[/fs]        proc   ro,relatime
            | |-/proc/irq                    proc[/irq]        proc   ro,relatime
            | |-/proc/sys                    proc[/sys]        proc   ro,relatime
            | |-/proc/sysrq-trigger          proc[/sysrq-trigger]        proc   ro,relatime
            | |-/proc/acpi                   tmpfs        tmpfs  ro,relatime
            | |-/proc/kcore                  tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
            | |-/proc/keys                   tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
            | |-/proc/timer_list             tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
            | |-/proc/sched_debug            tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
            | `-/proc/scsi                   tmpfs        tmpfs  ro,relatime
            |-/dev                           tmpfs        tmpfs  rw,nosuid,size=65536k,mode=755
            | |-/dev/console                 devpts[/0]        devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
            | |-/dev/pts                     devpts        devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
            | |-/dev/mqueue                  mqueue        mqueue rw,nosuid,nodev,noexec,relatime
            | `-/dev/shm                     shm        tmpfs  rw,nosuid,nodev,noexec,relatime,size=65536k
            |-/sys                           sysfs        sysfs  ro,nosuid,nodev,noexec,relatime
            | |-/sys/firmware                tmpfs        tmpfs  ro,relatime
            | `-/sys/fs/cgroup               tmpfs        tmpfs  rw,nosuid,nodev,noexec,relatime,mode=755
            |   |-/sys/fs/cgroup/systemd     cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/sys
            temd-cgroups-agent,name=systemd
            |   |-/sys/fs/cgroup/synomonitor cgroup[/system.slice/pkg-Docker-dockerd.service]        cgroup ro,nosuid,nodev,noexec,relatime,name=synomonitor
            |   |-/sys/fs/cgroup/cpuacct     cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,cpuacct
            |   |-/sys/fs/cgroup/devices     cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,devices
            |   |-/sys/fs/cgroup/cpu         cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,cpu
            |   |-/sys/fs/cgroup/memory      cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,memory
            |   |-/sys/fs/cgroup/blkio       cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,blkio
            |   |-/sys/fs/cgroup/freezer     cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,freezer
            |   `-/sys/fs/cgroup/cpuset      cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,cpuset
            |-/opt/iobroker                  /dev/vg1000/lv[/@syno/docker/iobrokerNeu]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata
            _ratio=50,syno_allocator,subvolid=855,subvol=/@syno/docker/iobrokerNeu
            |-/etc/resolv.conf               /dev/vg1000/lv[/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata
            _ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/resolv.conf
            |-/etc/hostname                  /dev/vg1000/lv[/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata
            _ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/hostname
            `-/etc/hosts                     /dev/vg1000/lv[/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata
            _ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/hosts
            /var:
            34M     /var/
            32M     /var/lib
            19M     /var/lib/apt/lists
            19M     /var/lib/apt
            13M     /var/lib/dpkg
            /opt/iobroker/backups:
            7.8M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            63M     /opt/iobroker/iobroker-data/
            25M     /opt/iobroker/iobroker-data/files
            13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            3.2M    /opt/iobroker/iobroker-data/states.jsonl
            2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
            2.5M    /opt/iobroker/iobroker-data/backup-objects/2024-06-01_08-22_objects.jsonl.gz
            USB-Devices by-id:
            No Devices found 'by-id'
            *** NodeJS-Installation ***
            /usr/bin/npm            10.8.0
            /usr/bin/npx            10.8.0
            nodejs:
              Installed: 18.20.3-1nodesource1
              Candidate: 18.20.3-1nodesource1
              Version table:
             *** 18.20.3-1nodesource1 1001
                   1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 18.20.2-1nodesource1 1001
                 18.20.1-1nodesource1 1001
                 18.20.0-1nodesource1 1001
                 18.19.1-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                 18.19.0-1nodesource1 1001
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0+dfsg1-1 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  5.0.19
            admin:          "admin" not found
            javascript:     "javascript" not found
            nodejs modules from github:     0
            Adapter State
              system.adapter.alexa2.0                 : alexa2                : buanet-iobroker1                         - disabled
              system.adapter.backitup.0               : backitup              : buanet-iobroker1                         - disabled
              system.adapter.cloud.0                  : cloud                 : buanet-iobroker1                         - disabled
              system.adapter.discovery.0              : discovery             : buanet-iobroker1                         - disabled
              system.adapter.ham.0                    : ham                   : buanet-iobroker1                         - disabled
              system.adapter.history.0                : history               : buanet-iobroker1                         - disabled
              system.adapter.jarvis.0                 : jarvis                : buanet-iobroker1                         - disabled
              system.adapter.javascript.0             : javascript            : buanet-iobroker1                         - disabled
              system.adapter.openweathermap.0         : openweathermap        : buanet-iobroker1                         - disabled
              system.adapter.ping.0                   : ping                  : buanet-iobroker1                         - disabled
              system.adapter.shelly.0                 : shelly                : buanet-iobroker1                         - disabled, port: 1882, bind: 0.0.0.0
              system.adapter.shelly.1                 : shelly                : buanet-iobroker1                         - disabled, port: 1882, bind: 0.0.0.0
              system.adapter.smartthings.0            : smartthings           : buanet-iobroker1                         - disabled
              system.adapter.vis.0                    : vis                   : buanet-iobroker1                         - disabled
              system.adapter.web.0                    : web                   : buanet-iobroker1                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            Installed ioBroker-Instances
            Used repository: stable
            Objects and States
            Objects:        9874
            States:         7157
            Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 0
            2024-06-01 10:08:29.539  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v18.20.3
            2024-06-01 10:08:29.540  - info: host.buanet-iobroker1 ip addresses: 192.168.1.116 2003:d5:a71d:f101:211:32ff:fe9c:f4aa fe80::211:32ff:fe9c:f4aa
            2024-06-01 10:08:30.869  - info: host.buanet-iobroker1 connected to Objects and States
            2024-06-01 10:08:30.908  - info: host.buanet-iobroker1 added notifications configuration of host
            2024-06-01 10:08:31.619  - info: host.buanet-iobroker1 16 instances found
            2024-06-01 10:08:31.652  - info: host.buanet-iobroker1 starting 1 instance
            2024-06-01 10:08:31.658  - warn: host.buanet-iobroker1 startInstance cannot find adapter "history@3.0.1". Try to install it... 1 attempt
            2024-06-01 10:08:31.659  - info: host.buanet-iobroker1 iobroker install history@3.0.1 using installedFrom
            2024-06-01 10:08:34.185  - info: host.buanet-iobroker1 iobroker npm-install: NPM version: 10.8.0
            2024-06-01 10:08:34.187  - info: host.buanet-iobroker1 iobroker npm-install: Installing iobroker.history@3.0.1... (System call)
            2024-06-01 10:16:08.035  - error: host.buanet-iobroker1 iobroker npm-install: npm error code ETIMEDOUTnpm error syscall connectnpm error errno ETIMEDOUTnpm error network request to https://registry.npmjs.org/iobroker.history failed
            , reason: connect ETIMEDOUT 2606:4700::6810:1c22:443npm error network This is a problem related to network connectivity.npm error network In most cases you are behind a proxy or have bad network settings.npm error networknpm error
            network If you are behind a proxy, please make sure that thenpm error network 'proxy' config is set properly.  See: 'npm help config'npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-06-01T08_08_34
            _410Z-debug-0.log
            2024-06-01 10:16:08.039  - error: host.buanet-iobroker1 iobroker npm-install: host.buanet-iobroker1 Cannot install iobroker.history@3.0.1: 1
            2024-06-01 10:16:09.059  - info: host.buanet-iobroker1 iobroker npm-install: exit 25
            2024-06-01 10:16:10.061  - warn: host.buanet-iobroker1 startInstance cannot find adapter "javascript@7.8.0". Try to install it... 1 attempt
            2024-06-01 10:16:10.062  - info: host.buanet-iobroker1 iobroker install javascript@7.8.0 using installedFrom
            2024-06-01 10:16:12.583  - info: host.buanet-iobroker1 iobroker npm-install: NPM version: 10.8.0
            2024-06-01 10:16:12.585  - info: host.buanet-iobroker1 iobroker npm-install: Installing iobroker.javascript@7.8.0... (System call)
            2024-06-01 10:23:46.273  - error: host.buanet-iobroker1 iobroker npm-install: npm error code ETIMEDOUTnpm error syscall connectnpm error errno ETIMEDOUTnpm error network request to https://registry.npmjs.org/iobroker.javascript fai
            led, reason: connect ETIMEDOUT 2606:4700::6810:23:443npm error network This is a problem related to network connectivity.npm error network In most cases you are behind a proxy or have bad network settings.npm error networknpm error
             network If you are behind a proxy, please make sure that thenpm error network 'proxy' config is set properly.  See: 'npm help config'npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-06-01T08_16_1
            2_817Z-debug-0.log
            2024-06-01 10:23:46.276  - error: host.buanet-iobroker1 iobroker npm-install: host.buanet-iobroker1 Cannot install iobroker.javascript@7.8.0: 1
            2024-06-01 10:23:47.303  - info: host.buanet-iobroker1 iobroker npm-install: exit 25
            2024-06-01 10:23:48.305  - warn: host.buanet-iobroker1 startInstance cannot find adapter "backitup@2.11.0". Try to install it... 1 attempt
            2024-06-01 10:23:48.306  - info: host.buanet-iobroker1 iobroker install backitup@2.11.0 using installedFrom
            2024-06-01 10:23:50.827  - info: host.buanet-iobroker1 iobroker npm-install: NPM version: 10.8.0
            2024-06-01 10:23:50.828  - info: host.buanet-iobroker1 iobroker npm-install: Installing iobroker.backitup@2.11.0... (System call)
            2024-06-01 10:24:07.110  - info: host.buanet-iobroker1 "system.adapter.web.0" enabled
              @op
              Da scheint mir beim Dateisystem vielleicht was zu klemmen.
              Das Ding läuft auf btrfs, es wird aber auch irgendwas mit ext versucht.
              *** FILESYSTEM ***
              Und dann scheint mit dem Netzwerk auch was zu klemmen:
              npm-install:
              npm error network request to https://registry.npmjs.org/iobroker.history failed, reason: connect ETIMEDOUT 2606:4700::6810:1c22:443
              npm error network
              npm error network If you are behind a proxy, please make sure that the
              npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-06-01T08_08_34_410Z-debug-0.log
              Hab ich aber weiter keine Ahnung von, muss sich einer der Dockeristen anschauen.
              Vielleicht kein iPv6 in deinem Netzwerk aktiv?
              Was kommet bei dem Test hier raus:
              https://internet.nl/connection
              • O
                danke für deine Mühe.
                Ich werde den Iobroker wieder löschen und neu installieren.
                Die Wiederherstellung lass ich dann weg.
                  Homoran Global Moderator Administrators @Op last edited by
                  das schrieb @Thomas-Braun allerdings nicht, sondrrn
                  @thomas-braun sagte in Aktualisieren "javascript" auf v8.3.1:
                  • O
                    Op @Homoran last edited by
                      @op ok, dann liegt es nicht daran.
                      Super das hat funktioniert
                      Das war das neu Aufsetzen?
                      Jetzt wollte ich den Javascript Adapter aktualisieren.
                      und sonst hast du nix aktualisiert?
                      • O
                        Das neue Aufsetzen hat funktioniert und ich konnte mit dem IoBroker arbeiten. Ich hatte noch ein Backup vom vorherigen IoBroker und habe dann eine Wiederherstellung gestartet. Danach ging gar nichts mehr. Ich habe jetzt den IoBroker wieder gelöscht und werde ihn nachher neu installieren. Wie oben schon beschrieben, werde ich von einer Wiederherstellung des Backups absehen.
                        Homoran haselchen 2 Replies Last reply Reply Quote 0
                          wie?
                          Das läuft unter Docker meines Wissens ganz anders
                          • haselchen
                            haselchen Most Active @Op last edited by haselchen
                            @op
                            Normal mountet = spiegelt man den opt/iobroker Ordner auf einen in der Syno angelegten Ordner.
                            Dann stoppt man den Container. Benennt ihn um, z.B. auf iobroker2.
                            Dann startet man ein neues Image (ich denke mal ein Neueres) und nennt dieses Image/den Container wie den alten (z.B. iobroker , wenn er so hieß)
                            Und gibt in den Einstellungen den Mountordner an.
                            Dann nimmt er sich die Daten von dort und du kannst mit einem neuen Image weiterarbeiten.
                            Natürlich kannst du auch einen frischen Container aufsetzen und dann mit Backitup ein Backup zurückspielen.
                            javascript synology docker iobroker update
                            1357
