    3. Einsteigerfragen
    4. Aktualisieren "javascript" auf v8.3.1
    • O
      Op @Thomas Braun last edited by
      Copy text starting here:
                              v.2024-05-22
      model name      : Intel(R) Celeron(R) CPU J3355 @ 2.00GHz
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.1.2
      Installation:           Docker
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               CEST +0200
      User-ID:                0
      Display-Server:         false
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v18.20.3
      /usr/bin/node           v18.20.3
      /usr/bin/npm            10.8.0
      /usr/bin/npx            10.8.0
      /usr/bin/corepack       0.28.0
      Recommended versions are nodejs  and npm
      MEMORY:
      Mem:             16G        1.8G        8.2G        216M        7.1G         14G
      Swap:            12G          0B         12G
      Total:           28G        1.8G         20G
      Active iob-Instances:   1
      Active repo(s): stable
      ioBroker Core:          js-controller           5.0.19
                              admin                   "admin" not found
      Objects type: jsonl
      States  type: jsonl
        system.adapter.admin.0                  : admin                 : buanet-iobroker1                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.web.0                    : web                   : buanet-iobroker1                         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                9874
      States:                 7157
      Size of iob-Database:
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      3.1M    /opt/iobroker/iobroker-data/states.jsonl
        Thomas Braun Most Active @Op last edited by Thomas Braun
        @op sagte in Aktualisieren "javascript" auf v8.3.1:
        Ohne admin wird es schwer mit der Weboberfläche.
        iob start web
        iob start admin
        Und dann bitte die Langfassung von
        iob diag
        • O
          Op @Thomas Braun last edited by Homoran
          Skript v.2024-05-22
          *** BASE SYSTEM ***
          Hardware Vendor : Synology
          Kernel          : x86_64
          Userland        : 64 bit
          Docker          : v9.1.2
          Virtualization  : Docker
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           10:29:14 up 12:21,  0 user,  load average: 0.16, 0.29, 0.33
          CPU threads: 2
          *** Time and Time Zones ***
          Sat Jun  1 08:29:14 UTC 2024
          Sat Jun  1 10:29:14 CEST 2024
          CEST +0200
          Etc/UTC
          *** Users and Groups ***
          User that called 'iob diag':
          root
          HOME=/root
          GROUPS=root
          iobroker
          sudo: unable to resolve host buanet-iobroker1: Name or service not known
          HOME=/opt/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** Display-Server-Setup ***
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:            12G          0B         12G
          Total:           28G        1.8G         20G
                  15854 M total memory
                   1756 M used memory
                   3683 M active memory
                   3691 M inactive memory
                   7823 M free memory
                     39 M buffer memory
                   6767 M swap cache
                  11561 M total swap
                      0 M used swap
                  11561 M free swap
          top - 10:29:15 up 12:21,  0 user,  load average: 0.16, 0.29, 0.33
          Tasks:  10 total,   1 running,   9 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,  0.0 id,100.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  15854.2 total,   7822.6 free,   1758.3 used,   6807.5 buff/cache
          MiB Swap:  11561.9 total,  11561.9 free,      0.0 used.  14095.9 avail Mem
          *** FILESYSTEM ***
          Filesystem     Type   Size  Used Avail Use% Mounted on
          /dev/vg1000/lv btrfs  890G  421G  470G  48% /
          tmpfs          tmpfs   64M     0   64M   0% /dev
          tmpfs          tmpfs  7.8G     0  7.8G   0% /sys/fs/cgroup
          shm            tmpfs   64M     0   64M   0% /dev/shm
          /dev/vg1000/lv btrfs  890G  421G  470G  48% /opt/iobroker
          /dev/vg1000/lv btrfs  890G  421G  470G  48% /etc/hosts
          tmpfs          tmpfs  7.8G     0  7.8G   0% /proc/acpi
          tmpfs          tmpfs  7.8G     0  7.8G   0% /proc/scsi
          tmpfs          tmpfs  7.8G     0  7.8G   0% /sys/firmware
          [Fri May 31 22:07:50 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
          [Fri May 31 22:07:50 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
          [Fri May 31 22:07:52 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
          [Fri May 31 22:07:52 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
          [Fri May 31 22:07:52 2024] EXT4-fs (loop0): couldn't mount as ext3 due to feature incompatibilities
          [Fri May 31 22:07:52 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
          [Fri May 31 22:07:57 2024] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
          [Fri May 31 22:07:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
          [Fri May 31 22:07:57 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
          [Fri May 31 22:08:53 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
          Show mounted filesystems:
          TARGET                           SOURCE        FSTYPE OPTIONS
          /                                /dev/vg1000/lv[/@syno/@docker/btrfs/subvolumes/f48cb06166fa6c28da81f514558cfa47f079c7fb2a6e573a7943e9fc52969acf]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata
          _ratio=50,syno_allocator,subvolid=904,subvol=/@syno/@docker/btrfs/subvolumes/f48cb06166fa6c28da81f514558cfa47f079c7fb2a6e573a7943e9fc52969acf
          |-/proc                          proc        proc   rw,nosuid,nodev,noexec,relatime
          | |-/proc/bus                    proc[/bus]        proc   ro,relatime
          | |-/proc/fs                     proc[/fs]        proc   ro,relatime
          | |-/proc/irq                    proc[/irq]        proc   ro,relatime
          | |-/proc/sys                    proc[/sys]        proc   ro,relatime
          | |-/proc/sysrq-trigger          proc[/sysrq-trigger]        proc   ro,relatime
          | |-/proc/acpi                   tmpfs        tmpfs  ro,relatime
          | |-/proc/kcore                  tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
          | |-/proc/keys                   tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
          | |-/proc/timer_list             tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
          | |-/proc/sched_debug            tmpfs[/null]        tmpfs  rw,nosuid,size=65536k,mode=755
          | `-/proc/scsi                   tmpfs        tmpfs  ro,relatime
          |-/dev                           tmpfs        tmpfs  rw,nosuid,size=65536k,mode=755
          | |-/dev/console                 devpts[/0]        devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
          | |-/dev/pts                     devpts        devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=666
          | |-/dev/mqueue                  mqueue        mqueue rw,nosuid,nodev,noexec,relatime
          | `-/dev/shm                     shm        tmpfs  rw,nosuid,nodev,noexec,relatime,size=65536k
          |-/sys                           sysfs        sysfs  ro,nosuid,nodev,noexec,relatime
          | |-/sys/firmware                tmpfs        tmpfs  ro,relatime
          | `-/sys/fs/cgroup               tmpfs        tmpfs  rw,nosuid,nodev,noexec,relatime,mode=755
          |   |-/sys/fs/cgroup/systemd     cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/sys
          temd-cgroups-agent,name=systemd
          |   |-/sys/fs/cgroup/synomonitor cgroup[/system.slice/pkg-Docker-dockerd.service]        cgroup ro,nosuid,nodev,noexec,relatime,name=synomonitor
          |   |-/sys/fs/cgroup/cpuacct     cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,cpuacct
          |   |-/sys/fs/cgroup/devices     cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,devices
          |   |-/sys/fs/cgroup/cpu         cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,cpu
          |   |-/sys/fs/cgroup/memory      cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,memory
          |   |-/sys/fs/cgroup/blkio       cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,blkio
          |   |-/sys/fs/cgroup/freezer     cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,freezer
          |   `-/sys/fs/cgroup/cpuset      cgroup[/docker/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808]                                       cgroup ro,nosuid,nodev,noexec,relatime,cpuset
          |-/opt/iobroker                  /dev/vg1000/lv[/@syno/docker/iobrokerNeu]        btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata
          _ratio=50,syno_allocator,subvolid=855,subvol=/@syno/docker/iobrokerNeu
          |-/etc/resolv.conf               /dev/vg1000/lv[/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata
          _ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/resolv.conf
          |-/etc/hostname                  /dev/vg1000/lv[/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata
          _ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/hostname
          `-/etc/hosts                     /dev/vg1000/lv[/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata
          _ratio=50,syno_allocator,subvolid=257,subvol=/@syno/@docker/containers/88557c91023656e60e25afcc881ee4e24c3b065af12890e92540adf545f8b808/hosts
          /var:
          34M     /var/
          32M     /var/lib
          19M     /var/lib/apt/lists
          19M     /var/lib/apt
          13M     /var/lib/dpkg
          /opt/iobroker/backups:
          7.8M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          63M     /opt/iobroker/iobroker-data/
          25M     /opt/iobroker/iobroker-data/files
          13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          3.2M    /opt/iobroker/iobroker-data/states.jsonl
          2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
          2.5M    /opt/iobroker/iobroker-data/backup-objects/2024-06-01_08-22_objects.jsonl.gz
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/npm            10.8.0
          /usr/bin/npx            10.8.0
          nodejs:
            Installed: 18.20.3-1nodesource1
            Candidate: 18.20.3-1nodesource1
            Version table:
           *** 18.20.3-1nodesource1 1001
                 1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.20.2-1nodesource1 1001
               18.20.1-1nodesource1 1001
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0+dfsg-6~deb12u1 500
                  500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.19
          admin:          "admin" not found
          javascript:     "javascript" not found
          nodejs modules from github:     0
          Adapter State
            system.adapter.alexa2.0                 : alexa2                : buanet-iobroker1                         - disabled
            system.adapter.backitup.0               : backitup              : buanet-iobroker1                         - disabled
            system.adapter.cloud.0                  : cloud                 : buanet-iobroker1                         - disabled
            system.adapter.discovery.0              : discovery             : buanet-iobroker1                         - disabled
            system.adapter.ham.0                    : ham                   : buanet-iobroker1                         - disabled
            system.adapter.history.0                : history               : buanet-iobroker1                         - disabled
            system.adapter.jarvis.0                 : jarvis                : buanet-iobroker1                         - disabled
            system.adapter.javascript.0             : javascript            : buanet-iobroker1                         - disabled
            system.adapter.openweathermap.0         : openweathermap        : buanet-iobroker1                         - disabled
            system.adapter.ping.0                   : ping                  : buanet-iobroker1                         - disabled
            system.adapter.shelly.0                 : shelly                : buanet-iobroker1                         - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.shelly.1                 : shelly                : buanet-iobroker1                         - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.smartthings.0            : smartthings           : buanet-iobroker1                         - disabled
            system.adapter.vis.0                    : vis                   : buanet-iobroker1                         - disabled
            system.adapter.web.0                    : web                   : buanet-iobroker1                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Installed ioBroker-Instances
          Used repository: stable
          Objects and States
          Objects:        9874
          States:         7157
          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          2024-06-01 10:08:29.539  - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v18.20.3
          2024-06-01 10:08:29.540  - info: host.buanet-iobroker1 ip addresses: 192.168.1.116 2003:d5:a71d:f101:211:32ff:fe9c:f4aa fe80::211:32ff:fe9c:f4aa
          2024-06-01 10:08:30.869  - info: host.buanet-iobroker1 connected to Objects and States
          2024-06-01 10:08:30.908  - info: host.buanet-iobroker1 added notifications configuration of host
          2024-06-01 10:08:31.619  - info: host.buanet-iobroker1 16 instances found
          2024-06-01 10:08:31.652  - info: host.buanet-iobroker1 starting 1 instance
          2024-06-01 10:08:31.658  - warn: host.buanet-iobroker1 startInstance cannot find adapter "history@3.0.1". Try to install it... 1 attempt
          2024-06-01 10:08:31.659  - info: host.buanet-iobroker1 iobroker install history@3.0.1 using installedFrom
          2024-06-01 10:08:34.185  - info: host.buanet-iobroker1 iobroker npm-install: NPM version: 10.8.0
          2024-06-01 10:08:34.187  - info: host.buanet-iobroker1 iobroker npm-install: Installing iobroker.history@3.0.1... (System call)
          2024-06-01 10:16:08.035  - error: host.buanet-iobroker1 iobroker npm-install: npm error code ETIMEDOUTnpm error syscall connectnpm error errno ETIMEDOUTnpm error network request to https://registry.npmjs.org/iobroker.history failed
          , reason: connect ETIMEDOUT 2606:4700::6810:1c22:443npm error network This is a problem related to network connectivity.npm error network In most cases you are behind a proxy or have bad network settings.npm error networknpm error
          network If you are behind a proxy, please make sure that thenpm error network 'proxy' config is set properly.  See: 'npm help config'npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-06-01T08_08_34
          _410Z-debug-0.log
          2024-06-01 10:16:08.039  - error: host.buanet-iobroker1 iobroker npm-install: host.buanet-iobroker1 Cannot install iobroker.history@3.0.1: 1
          2024-06-01 10:16:09.059  - info: host.buanet-iobroker1 iobroker npm-install: exit 25
          2024-06-01 10:16:10.061  - warn: host.buanet-iobroker1 startInstance cannot find adapter "javascript@7.8.0". Try to install it... 1 attempt
          2024-06-01 10:16:10.062  - info: host.buanet-iobroker1 iobroker install javascript@7.8.0 using installedFrom
          2024-06-01 10:16:12.583  - info: host.buanet-iobroker1 iobroker npm-install: NPM version: 10.8.0
          2024-06-01 10:16:12.585  - info: host.buanet-iobroker1 iobroker npm-install: Installing iobroker.javascript@7.8.0... (System call)
          2024-06-01 10:23:46.273  - error: host.buanet-iobroker1 iobroker npm-install: npm error code ETIMEDOUTnpm error syscall connectnpm error errno ETIMEDOUTnpm error network request to https://registry.npmjs.org/iobroker.javascript fai
          led, reason: connect ETIMEDOUT 2606:4700::6810:23:443npm error network This is a problem related to network connectivity.npm error network In most cases you are behind a proxy or have bad network settings.npm error networknpm error
           network If you are behind a proxy, please make sure that thenpm error network 'proxy' config is set properly.  See: 'npm help config'npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-06-01T08_16_1
          2_817Z-debug-0.log
          2024-06-01 10:23:46.276  - error: host.buanet-iobroker1 iobroker npm-install: host.buanet-iobroker1 Cannot install iobroker.javascript@7.8.0: 1
          2024-06-01 10:23:47.303  - info: host.buanet-iobroker1 iobroker npm-install: exit 25
          2024-06-01 10:23:48.305  - warn: host.buanet-iobroker1 startInstance cannot find adapter "backitup@2.11.0". Try to install it... 1 attempt
          2024-06-01 10:23:48.306  - info: host.buanet-iobroker1 iobroker install backitup@2.11.0 using installedFrom
          2024-06-01 10:23:50.827  - info: host.buanet-iobroker1 iobroker npm-install: NPM version: 10.8.0
          2024-06-01 10:23:50.828  - info: host.buanet-iobroker1 iobroker npm-install: Installing iobroker.backitup@2.11.0... (System call)
          2024-06-01 10:24:07.110  - info: host.buanet-iobroker1 "system.adapter.web.0" enabled
            @op
            Da scheint mir beim Dateisystem vielleicht was zu klemmen.
            Das Ding läuft auf btrfs, es wird aber auch irgendwas mit ext versucht.
            *** FILESYSTEM ***
            Und dann scheint mit dem Netzwerk auch was zu klemmen:
            npm-install:
            npm error network request to https://registry.npmjs.org/iobroker.history failed, reason: connect ETIMEDOUT 2606:4700::6810:1c22:443
            npm error network
            npm error network If you are behind a proxy, please make sure that the
            npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2024-06-01T08_08_34_410Z-debug-0.log
            Hab ich aber weiter keine Ahnung von, muss sich einer der Dockeristen anschauen.
            Vielleicht kein iPv6 in deinem Netzwerk aktiv?
            Was kommet bei dem Test hier raus:
            https://internet.nl/connection
            • O
              danke für deine Mühe.
              Ich werde den Iobroker wieder löschen und neu installieren.
              Die Wiederherstellung lass ich dann weg.
                Homoran Global Moderator Administrators @Op last edited by
                das schrieb @Thomas-Braun allerdings nicht, sondrrn
                @thomas-braun sagte in Aktualisieren "javascript" auf v8.3.1:
                • O
                  Op @Homoran last edited by
                    @op ok, dann liegt es nicht daran.
                    Super das hat funktioniert
                    Das war das neu Aufsetzen?
                    Jetzt wollte ich den Javascript Adapter aktualisieren.
                    und sonst hast du nix aktualisiert?
                    • O
                      Das neue Aufsetzen hat funktioniert und ich konnte mit dem IoBroker arbeiten. Ich hatte noch ein Backup vom vorherigen IoBroker und habe dann eine Wiederherstellung gestartet. Danach ging gar nichts mehr. Ich habe jetzt den IoBroker wieder gelöscht und werde ihn nachher neu installieren. Wie oben schon beschrieben, werde ich von einer Wiederherstellung des Backups absehen.
                      Homoran haselchen 2 Replies Last reply Reply Quote 0
                        wie?
                        Das läuft unter Docker meines Wissens ganz anders
                        • haselchen
                          haselchen Most Active @Op last edited by haselchen
                          @op
                          Normal mountet = spiegelt man den opt/iobroker Ordner auf einen in der Syno angelegten Ordner.
                          Dann stoppt man den Container. Benennt ihn um, z.B. auf iobroker2.
                          Dann startet man ein neues Image (ich denke mal ein Neueres) und nennt dieses Image/den Container wie den alten (z.B. iobroker , wenn er so hieß)
                          Und gibt in den Einstellungen den Mountordner an.
                          Dann nimmt er sich die Daten von dort und du kannst mit einem neuen Image weiterarbeiten.
                          Natürlich kannst du auch einen frischen Container aufsetzen und dann mit Backitup ein Backup zurückspielen.
                          javascript synology docker iobroker update
                          1357
