    3. Einsteigerfragen
    4. vis-2 Visualisirung keine Anzeige
      Homoran Global Moderator Administrators @Schwaberik last edited by Homoran
      @schwaberik dann gib mal die Langfassung von iob diag zum besten
        Schwaberik @Homoran last edited by Homoran
        @homoran said in vis-2 Visualisirung keine Anzeige:
        Ich hofe das ist das richtige,
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        Hardware Vendor : Synology
        Kernel          : x86_64
        Userland        : amd64
        Docker          : v9.1.1
        Virtualization  : Docker
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         16:33:06 up 4 days, 23:20,  0 user,  load average: 0.46, 0.68, 0.82
        CPU threads: 4
        *** Time and Time Zones ***
        Sun Mar 10 15:33:06 UTC 2024
        Sun Mar 10 16:33:06 CET 2024
        CET +0100
        Etc/UTC
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            6.1G        2.4G        856M         57M        3.5G        3.7G
        Swap:           5.8G        525M        5.3G
        Total:           11G        2.9G        6.1G
                 5776 M total memory
                 2278 M used memory
                 2195 M active memory
                 2238 M inactive memory
                  816 M free memory
                   17 M buffer memory
                 3333 M swap cache
                 5515 M total swap
                  501 M used swap
                 5014 M free swap
        *** FILESYSTEM ***
        Filesystem        Type   Size  Used Avail Use% Mounted on
        /dev/vg1/volume_1 btrfs  3.5T  1.3T  2.3T  37% /
        tmpfs             tmpfs   64M     0   64M   0% /dev
        tmpfs             tmpfs  2.9G     0  2.9G   0% /sys/fs/cgroup
        shm               tmpfs   64M     0   64M   0% /dev/shm
        /dev/vg1/volume_1 btrfs  3.5T  1.3T  2.3T  37% /opt/iobroker
        /dev/vg1/volume_1 btrfs  3.5T  1.3T  2.3T  37% /etc/hosts
        tmpfs             tmpfs  2.9G     0  2.9G   0% /proc/acpi
        tmpfs             tmpfs  2.9G     0  2.9G   0% /proc/scsi
        tmpfs             tmpfs  2.9G     0  2.9G   0% /sys/firmware
        TARGET             SOURCE
        FSTYPE OPTIONS
        /                  /dev/vg1/volume_1[/@syno/@docker/btrfs/subvolumes/691ad171bf6a
        90e8457ea09d1e9d9632206f0ba5ccee67221db605c3aa555f5e]       btrfs  rw,nodev,relat
        ime,ssd,synoacl,space_cache=v2,auto_reclaim_space,metadata_ratio=50,block_group_c
        ache_tree,syno_allocator,subvolid=335,subvol=/@syno/@docker/btrfs/subvolumes/691a
        d171bf6a90e8457ea09d1e9d9632206f0ba5ccee67221db605c3aa555f5e
        |-/opt/iobroker    /dev/vg1/volume_1[/@syno/docker/iobroker]
        ache_tree,syno_allocator,subvolid=281,subvol=/@syno/docker
        |-/etc/resolv.conf /dev/vg1/volume_1[/@syno/@docker/containers/3b6da15e3cd951781d
        bdc899a59e0f84f87aaa9ae8a7e67268aadcaa048ac048/resolv.conf] btrfs  rw,nodev,relat
        ache_tree,syno_allocator,subvolid=256,subvol=/@syno
        |-/etc/hostname    /dev/vg1/volume_1[/@syno/@docker/containers/3b6da15e3cd951781d
        bdc899a59e0f84f87aaa9ae8a7e67268aadcaa048ac048/hostname]    btrfs  rw,nodev,relat
        `-/etc/hosts       /dev/vg1/volume_1[/@syno/@docker/containers/3b6da15e3cd951781d
        bdc899a59e0f84f87aaa9ae8a7e67268aadcaa048ac048/hosts]       btrfs  rw,nodev,relat
        /var:
        34M     /var/
        32M     /var/lib
        19M     /var/lib/apt/lists
        19M     /var/lib/apt
        13M     /var/lib/dpkg
        /opt/iobroker/backups:
        3.3M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        311M    /opt/iobroker/iobroker-data/
        253M    /opt/iobroker/iobroker-data/files
        142M    /opt/iobroker/iobroker-data/files/vis-2
        81M     /opt/iobroker/iobroker-data/files/vis-2/static
        80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.ma
        p
        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
        19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
        19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
        15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/376.1862d3de.chunk.js.m
        ap
        USB-Devices by-id:
        USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always
        prefer the links 'by-id':
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.1
        /usr/bin/node           v18.19.1
        /usr/bin/npm            10.2.4
        /usr/bin/npx            10.2.4
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.1-1nodesource1
          Candidate: 18.19.1-1nodesource1
          Version table:
         *** 18.19.1-1nodesource1 1001
               1001 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.19.0+dfsg-6~deb12u1 500
               500 http://deb.debian.org/debian-security bookworm-security/main amd64 Pa
        ckages
             18.19.0-1nodesource1 1001
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
        18.13.0+dfsg1-1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.19
        admin:          6.13.16
        javascript:     7.8.0
        Adapters from github:   1
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker-iobr
        oker-1                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : iobroker-iobr
        oker-1                      -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker-iobr
        oker-1                      -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker-iobr
        oker-1                      -  enabled
          system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker-iobr
        oker-1                      - disabled
          system.adapter.helios.0                 : helios                : iobroker-iobr
        oker-1                      - disabled
        + system.adapter.hmip.0                   : hmip                  : iobroker-iobr
        oker-1                      -  enabled
        + system.adapter.hue.0                    : hue                   : iobroker-iobr
        oker-1                      -  enabled, port: 443
        + system.adapter.javascript.0             : javascript            : iobroker-iobr
        oker-1                      -  enabled
          system.adapter.smartthings.0            : smartthings           : iobroker-iobr
        oker-1                      - disabled
          system.adapter.tapo.0                   : tapo                  : iobroker-iobr
        oker-1                      - disabled
        + system.adapter.vis-2.0                  : vis-2                 : iobroker-iobr
        oker-1                      -  enabled
        + system.adapter.web.0                    : web                   : iobroker-iobr
        oker-1                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "backitup"     : 2.10.11  , installed 2.10.11
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "helios"       : 0.0.3    , installed 0.0.3
        Adapter    "hmip"         : 1.22.0   , installed 1.22.0
        Adapter    "hue"          : 3.10.2   , installed 3.10.2
        Adapter    "javascript"   : 7.8.0    , installed 7.8.0
        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
        Adapter    "tapo"         : 0.0.8    , installed 0.2.9
        Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Objects and States
        Objects:        9450
        States:         7203
        jHit:1 http://deb.debian.org/debian bookworm InRelease
        Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        Proto Recv-Q Send-Q Local Address           Foreign Address         State       U
        ser       Inode      PID/Program name
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1
        000       51167577   -
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1
        000       51165083   -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1
        000       51168477   -
        tcp6       0      0 :::8082                 :::*                    LISTEN      1
        000       51171965   -
        15:55:17.179  - info: cloud.0 (320) Trying to connect as system.user.admin to clo
        ud
        2024-03-10 15:55:17.299  - info: cloud.0 (320) Adapter redirected temporally to "
        https://iobroker.net:10556" in one minute. Reason: command from server
        2024-03-10 15:55:17.301  - info: cloud.0 (320) Connection changed: disconnect
        2024-03-10 15:56:17.309  - info: cloud.0 (320) Trying to connect as system.user.a
        dmin to cloud
        2024-03-10 15:56:17.418  - info: cloud.0 (320) Connection changed: connect
        2024-03-10 15:57:55.294  - info: admin.0 (164) ==> Connected system.user.admin fr
        om ::ffff:172.17.0.1
        2024-03-10 16:15:19.037  - info: admin.0 (164) <== Disconnect system.user.admin f
        rom ::ffff:172.17.0.1 admin
        2024-03-10 16:20:25.907  - info: admin.0 (164) ==> Connected system.user.admin fr
        2024-03-10 16:20:45.182  - info: admin.0 (164) <== Disconnect system.user.admin f
        2024-03-10 16:26:25.320  - info: hmip.0 (221) State value to set for "hmip.0.devi
        ces.3014F711A000139F2991A48C.channels.1.previousShutterLevel" has to be type "str
        ing" but received type "number"
        2024-03-10 16:26:25.322  - info: hmip.0 (221) State value to set for "hmip.0.devi
        ces.3014F711A000139F2991A48C.channels.1.previousSlatsLevel" has to be type "strin
        2024-03-10 16:26:25.665  - info: hmip.0 (221) State value to set for "hmip.0.devi
        2024-03-10 16:26:25.705  - info: hmip.0 (221) State value to set for "hmip.0.devi
        2024-03-10 15:55:08.594  - info: hmip.0 (221) unknown channel type - EXTERNAL_BAS
        E_CHANNEL - {"id":"e76c83c4-dfc0-41a7-805b-e4be2ca0a662","type":"EXTERNAL","homeI
        d":"0fd7af40-373d-4446-919b-dcc74ee090f0","lastStatusUpdate":1710071811477,"label
        ":"Hue color spot rechts","functionalChannels":{"0":{"label":"","deviceId":"e76c8
        3c4-dfc0-41a7-805b-e4be2ca0a662","index":0,"groupIndex":0,"functionalChannelType"
        :"EXTERNAL_BASE_CHANNEL","groups":["699eef24-b57e-442e-9295-1385e79a092a"],"chann
        elId":"433050f6-f03d-4496-b5c8-b3bc7da8d0b6","unreach":false},"1":{"label":"","de
        viceId":"e76c83c4-dfc0-41a7-805b-e4be2ca0a662","index":1,"groupIndex":1,"function
        alChannelType":"EXTERNAL_UNIVERSAL_LIGHT_CHANNEL","groups":["47c82098-a6e0-4090-b
        621-3f2ab55c5fcd"],"channelId":"f7567fd6-e377-4763-b308-6d79ad2df3ac","on":true,"
        dimLevel":1,"colorTemperature":2732,"hue":null,"saturationLevel":null,"channelRol
        e":"UNIVERSAL_LIGHT_ACTUATOR","supportedOptionalFeatures":{"IOptionalFeatureDimme
        rState":true,"IOptionalFeatureColorTemperature":true,"IOptionalFeatureHueSaturati
        onValue":true,"IFeatureLightGroupActuatorChannel":true},"minimalColorTemperature"
        :2000,"maximumColorTemperature":6500}},"firmwareVersion":"1.104.2","modelType":"L
        CG002","permanentlyReachable":true,"externalService":"HUE","supported":true,"hasC
        ustomLabel":false,"deviceArchetype":"EXTERNAL","connectionType":"EXTERNAL"}
        2024-03-10 15:55:08.594  - info: hmip.0 (221) unknown channel type - EXTERNAL_UNI
        VERSAL_LIGHT_CHANNEL - {"id":"e76c83c4-dfc0-41a7-805b-e4be2ca0a662","type":"EXTER
        NAL","homeId":"0fd7af40-373d-4446-919b-dcc74ee090f0","lastStatusUpdate":171007181
        1477,"label":"Hue color spot rechts","functionalChannels":{"0":{"label":"","devic
        eId":"e76c83c4-dfc0-41a7-805b-e4be2ca0a662","index":0,"groupIndex":0,"functionalC
        hannelType":"EXTERNAL_BASE_CHANNEL","groups":["699eef24-b57e-442e-9295-1385e79a09
        2a"],"channelId":"433050f6-f03d-4496-b5c8-b3bc7da8d0b6","unreach":false},"1":{"la
        bel":"","deviceId":"e76c83c4-dfc0-41a7-805b-e4be2ca0a662","index":1,"groupIndex":
        1,"functionalChannelType":"EXTERNAL_UNIVERSAL_LIGHT_CHANNEL","groups":["47c82098-
        a6e0-4090-b621-3f2ab55c5fcd"],"channelId":"f7567fd6-e377-4763-b308-6d79ad2df3ac",
        "on":true,"dimLevel":1,"colorTemperature":2732,"hue":null,"saturationLevel":null,
        "channelRole":"UNIVERSAL_LIGHT_ACTUATOR","supportedOptionalFeatures":{"IOptionalF
        eatureDimmerState":true,"IOptionalFeatureColorTemperature":true,"IOptionalFeature
        HueSaturationValue":true,"IFeatureLightGroupActuatorChannel":true},"minimalColorT
        emperature":2000,"maximumColorTemperature":6500}},"firmwareVersion":"1.104.2","mo
        delType":"LCG002","permanentlyReachable":true,"externalService":"HUE","supported"
        :true,"hasCustomLabel":false,"deviceArchetype":"EXTERNAL","connectionType":"EXTER
        NAL"}
        2024-03-10 15:55:08.953  - info: web.0 (278) starting. Version 6.2.3 in /opt/iobr
        oker/node_modules/iobroker.web, node: v18.19.1, js-controller: 5.0.19
        2024-03-10 15:55:09.140  - info: web.0 (278) socket.io server listening on port 8
        082
        2024-03-10 15:55:09.143  - info: web.0 (278) http server listening on port 8082
        2024-03-10 15:55:11.799  - info: host.iobroker-iobroker-1 instance system.adapter
        .vis-2.0 started with pid 305
        2024-03-10 15:55:12.849  - info: vis-2.0 (305) starting. Version 2.9.32 in /opt/i
        obroker/node_modules/iobroker.vis-2, node: v18.19.1, js-controller: 5.0.19
        2024-03-10 15:55:12.890  - error: vis-2.0 (305) No license found for vis. Please
        get one on https://iobroker.net !
        2024-03-10 15:55:13.670  - info: hmip.0 (221) hmip adapter connected and ready
        2024-03-10 15:55:15.786  - info: host.iobroker-iobroker-1 instance system.adapter
        .cloud.0 started with pid 320
        2024-03-10 15:55:16.965  - info: cloud.0 (320) starting. Version 4.4.1 in /opt/io
        broker/node_modules/iobroker.cloud, node: v18.19.1, js-controller: 5.0.19
        2024-03-10 15:55:16.993  - info: cloud.0 (320) Connecting with https://iobroker.n
        et:10555 with "private Daten entfernt"
        2024-03-10
          Bastel2001 @Schwaberik last edited by Bastel2001
          Guten Abend,
          ich häng mich mal dran, da ich genau das gleiche Problem habe, Wenn ich die Vis-2 starte, dann kommt die "IOBroker-Eieruhr", dann wird das Edit-Fenster aufgebaut und wenn es dann so aussieht als wenn der Vorgang fertig ist, dann ist das Fenster weiß. F12 hilft mir nicht so viel, weil ich nicht weiß worauf ich achten muß. Die letzte Fehlermeldung dort ist:
          ws connection error: CLOSED_NO_STATUS
          Ruft man dann die Vis-2 nochmals auf das verstirbt der PI komplett und es hilft nur ein hartes Reset.
          Mein Gedanke, das sich Vis-am aktuelle VIS-Projekt stört und der Fehler daher kommt, war auch nicht weiterführend. Ich habe im Vis ein leeren Projekt erzeugt und dann Vis-2 nochmal gestartet, aber das Problem bleibt dasselbe.
          Hier noch meine iob diag:
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: IOBroker64
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.2
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
           20:45:15 up 25 min,  1 user,  load average: 3.06, 1.45, 1.14
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
                         Local time: Sun 2024-03-10 20:45:15 CET
                     Universal time: Sun 2024-03-10 19:45:15 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          X-Server:       false
          Desktop:
          Terminal:       tty
          Boot Target:    multi-user.target
          *** MEMORY ***
          Mem:            3.8G        1.7G        1.0G        0.0K        1.0G        2.0G
          Swap:            99M        1.0M         98M
          Total:          3.9G        1.7G        1.1G
                   3793 M total memory
                   1733 M used memory
                   1789 M active memory
                    768 M inactive memory
                   1027 M free memory
                    126 M buffer memory
                    905 M swap cache
                     99 M total swap
                      1 M used swap
                     98 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4      234G  5.5G  217G   3% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     759M  1.2M  758M   1% /run
          /dev/sda1      vfat      253M   31M  222M  13% /boot
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Sun Mar 10 20:19:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:79:AC:89 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=8d884217-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sun Mar 10 20:19:33 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun Mar 10 20:19:33 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
          [Sun Mar 10 20:19:34 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
          TARGET  SOURCE    FSTYPE OPTIONS
          /       /dev/sda2 ext4   rw,noatime,stripe=8191
          `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          778M    /var/
          346M    /var/cache
          339M    /var/cache/apt
          238M    /var/cache/apt/archives
          172M    /var/log
          Archived and active journals take up 168.0M in the file system.
          4.0K    /opt/iobroker/backups/
          655M    /opt/iobroker/iobroker-data/
          593M    /opt/iobroker/iobroker-data/files
          205M    /opt/iobroker/iobroker-data/files/vis-2
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          29M     /opt/iobroker/iobroker-data/objects.jsonl
          22M     /opt/iobroker/iobroker-data/states.jsonl
          22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
          USB-Devices by-id:
          /usr/bin/npm            10.2.4
          /usr/bin/npx            10.2.4
          nodejs:
            Version table:
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          js-controller:  5.0.12
          admin:          6.13.16
          javascript:     7.8.0
          Adapters from github:   3
          Adapter State
          + system.adapter.accuweather.0            : accuweather           : IOBroker64                               -  enabled
          + system.adapter.admin.0                  : admin                 : IOBroker64                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alias-manager.0          : alias-manager         : IOBroker64                               - disabled
          + system.adapter.backitup.0               : backitup              : IOBroker64                               -  enabled
          + system.adapter.cloud.0                  : cloud                 : IOBroker64                               -  enabled
          + system.adapter.daswetter.0              : daswetter             : IOBroker64                               -  enabled
          + system.adapter.deconz.0                 : deconz                : IOBroker64                               -  enabled, port: 80
            system.adapter.devices.0                : devices               : IOBroker64                               - disabled
          + system.adapter.discovergy.0             : discovergy            : IOBroker64                               -  enabled
          + system.adapter.discovery.0              : discovery             : IOBroker64                               -  enabled
          + system.adapter.dwd.0                    : dwd                   : IOBroker64                               -  enabled
          + system.adapter.email.0                  : email                 : IOBroker64                               -  enabled
            system.adapter.feiertage.0              : feiertage             : IOBroker64                               -  enabled
            system.adapter.flot.0                   : flot                  : IOBroker64                               - disabled
            system.adapter.heatingcontrol.0         : heatingcontrol        : IOBroker64                               -  enabled
          + system.adapter.history.0                : history               : IOBroker64                               -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : IOBroker64                               -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : IOBroker64                               -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : IOBroker64                               -  enabled, port: 2000
            system.adapter.homeconnect.0            : homeconnect           : IOBroker64                               -  enabled
            system.adapter.homepilot20.0            : homepilot20           : IOBroker64                               -  enabled
            system.adapter.ical.0                   : ical                  : IOBroker64                               -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : IOBroker64                               - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : IOBroker64                               - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : IOBroker64                               - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IOBroker64                               - disabled
          + system.adapter.influxdb.0               : influxdb              : IOBroker64                               -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : IOBroker64                               -  enabled
            system.adapter.lg-thinq.2               : lg-thinq              : IOBroker64                               -  enabled
            system.adapter.linkeddevices.0          : linkeddevices         : IOBroker64                               -  enabled
          + system.adapter.maxcube.0                : maxcube               : IOBroker64                               -  enabled, port: 62910, bind: 0.0.0.0
          + system.adapter.mqtt-client.0            : mqtt-client           : IOBroker64                               -  enabled, port: 1883
          + system.adapter.mqtt.0                   : mqtt                  : IOBroker64                               -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.mqtt.1                   : mqtt                  : IOBroker64                               -  enabled, port: 1887, bind: 0.0.0.0
          + system.adapter.ping.0                   : ping                  : IOBroker64                               -  enabled
            system.adapter.pollenflug.0             : pollenflug            : IOBroker64                               -  enabled
            system.adapter.pvforecast.0             : pvforecast            : IOBroker64                               -  enabled
          + system.adapter.radar2.0                 : radar2                : IOBroker64                               -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : IOBroker64                               -  enabled
            system.adapter.schoolfree.0             : schoolfree            : IOBroker64                               -  enabled
          + system.adapter.shelly.0                 : shelly                : IOBroker64                               -  enabled, port: 1890, bind: 192.168.178.180
          + system.adapter.shuttercontrol.0         : shuttercontrol        : IOBroker64                               -  enabled
            system.adapter.simple-api.0             : simple-api            : IOBroker64                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : IOBroker64                               -  enabled, port: 1885, bind: 0.0.0.0
            system.adapter.sql.0                    : sql                   : IOBroker64                               - disabled, port: 3306
            system.adapter.tankerkoenig.0           : tankerkoenig          : IOBroker64                               -  enabled
          + system.adapter.tr-064.0                 : tr-064                : IOBroker64                               -  enabled
            system.adapter.trashschedule.0          : trashschedule         : IOBroker64                               -  enabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IOBroker64                               -  enabled
            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IOBroker64                               -  enabled
            system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: IOBroker64                               -  enabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IOBroker64                               -  enabled
            system.adapter.vis-2.0                  : vis-2                 : IOBroker64                               -  enabled
            system.adapter.vis-bars.0               : vis-bars              : IOBroker64                               - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : IOBroker64                               - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : IOBroker64                               -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : IOBroker64                               - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : IOBroker64                               - disabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : IOBroker64                               -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : IOBroker64                               - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : IOBroker64                               - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : IOBroker64                               - disabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : IOBroker64                               - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : IOBroker64                               - disabled
            system.adapter.vis-metro.0              : vis-metro             : IOBroker64                               - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : IOBroker64                               - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : IOBroker64                               - disabled
            system.adapter.vis-weather.0            : vis-weather           : IOBroker64                               - disabled
            system.adapter.vis.0                    : vis                   : IOBroker64                               -  enabled
          + system.adapter.weatherunderground.0     : weatherunderground    : IOBroker64                               -  enabled
            system.adapter.web.0                    : web                   : IOBroker64                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.worx.0                   : worx                  : IOBroker64                               -  enabled
          + instance is alive
          Adapter    "accuweather"  : 1.3.2    , installed 1.3.2
          Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
          Adapter    "deconz"       : 1.3.23   , installed 1.3.23
          Adapter    "discovergy"   : 0.5.13   , installed 0.5.13
          Adapter    "email"        : 1.2.2    , installed 1.2.2
          Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "heatingcontrol": 2.12.3  , installed 2.12.3
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
          Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
          Controller "js-controller": 5.0.19   , installed 5.0.12 [Updatable]
          Adapter    "lg-thinq"     : 0.3.3    , installed 0.3.3
          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
          Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "mqtt-client"  : 1.7.0    , installed 1.7.0
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
          Adapter    "radar2"       : 2.1.0    , installed 2.1.0
          Adapter    "schoolfree"   : 1.1.4    , installed 1.1.4
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "sql"          : 2.2.0    , installed 2.2.0
          Adapter    "trashschedule": 3.2.0    , installed 3.2.0
          Adapter    "vis-2-widgets-energy": 0.3.9, installed 0.3.9
          Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
          Adapter    "vis-2-widgets-jaeger-design": 1.1.10, installed 1.1.10
          Adapter    "vis-2-widgets-material": 1.3.18, installed 1.3.18
          Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
          Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
          Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "worx"         : 2.3.4    , installed 2.3.4
          Objects and States
          Objects:        19525
          States:         17994
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 http://giteduberger.fr rpimonitor/ InRelease
          Hit:6 https://repos.influxdata.com/debian stable InRelease
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Pending Updates: 0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       66828      15868/iobroker.js-c
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       66840      15868/iobroker.js-c
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14045      583/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12263      536/cupsd
          tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          15369      643/perl
          tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1002       68430      17805/nc
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          12707      555/vncserver-x11-c
          tcp        0      0 192.168.178.180:1890    0.0.0.0:*               LISTEN      1001       67368      16609/io.shelly.0
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       69143      16765/io.sonoff.0
          tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       65278      16409/io.mqtt.1
          tcp        0      0 192.168.178.180:2001    0.0.0.0:*               LISTEN      1001       64274      16045/io.hm-rpc.0
          tcp        0      0 192.168.178.180:2000    0.0.0.0:*               LISTEN      1001       67071      16060/io.hm-rpc.1
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14047      583/sshd: /usr/sbin
          tcp6       0      0 :::5900                 :::*                    LISTEN      0          12706      555/vncserver-x11-c
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       68451      17523/io.simple-api
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        14697      425/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       64906      15903/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       74763      17898/io.web.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12262      536/cupsd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12280      581/cups-browsed
          udp        0      0 0.0.0.0:41696           0.0.0.0:*                           108        13911      398/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13909      398/avahi-daemon: r
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       70479      17183/io.deconz.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       70476      17183/io.deconz.0
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       68633      16476/io.radar2.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15410      907/dhcpcd
          udp6       0      0 :::546                  :::*                                0          14738      907/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        13910      398/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1001       70481      17183/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       70480      17183/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       70478      17183/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       70477      17183/io.deconz.0
          udp6       0      0 :::49304                :::*                                108        13912      398/avahi-daemon: r
          2024-03-10 20:47:25.037  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_0ea8eb.temp' to 'linkeddevices.0.Zimmer.Schlafzimmer.Temperatur'
          2024-03-10 20:47:25.356  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_0ea8eb.valve' to 'linkeddevices.0.Zimmer.Schlafzimmer.Valve'
          2024-03-10 20:47:25.615  - info: worx.0 (17930) OneTimeShedule found, create states...
          2024-03-10 20:47:25.831  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_0eade4.valve' to 'linkeddevices.0.Zimmer.Ankleidezimmer.Valve'
          2024-03-10 20:47:26.217  - info: worx.0 (17930) Firmware found, create states...
          2024-03-10 20:47:26.352  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_11d37f.mode' to 'linkeddevices.0.Zimmer.Gästezimmer.HeatingMode'
          2024-03-10 20:47:26.780  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_11d37f.setpoint' to 'linkeddevices.0.Zimmer.Gästezimmer.SollTemperatur'
          2024-03-10 20:47:27.098  - info: javascript.0 (15982) script.js.Energie.PV_Berechnung: Netzview berechnen:674
          2024-03-10 20:47:27.099  - info: javascript.0 (15982) script.js.Energie.PV_Berechnung: val>0
          2024-03-10 20:47:27.099  - info: javascript.0 (15982) script.js.Energie.PV_Berechnung: Netzview berechnen End
          2024-03-10 20:47:27.103  - info: worx.0 (17930) PartyModus found, create states...
          2024-03-10 20:47:27.699  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_11d37f.temp' to 'linkeddevices.0.Zimmer.Gästezimmer.Temperatur'
          2024-03-10 20:47:27.953  - info: worx.0 (17930) Create product folder and states for WR141E
          2024-03-10 20:47:28.132  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_11d37f.valve' to 'linkeddevices.0.Zimmer.Gästezimmer.Valve'
          2024-03-10 20:47:28.689  - info: web.0 (17898) ==> Connected system.user.admin from ::ffff:192.168.178.24
          2024-03-10 20:47:28.743  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_137007.mode' to 'linkeddevices.0.Zimmer.Ankleidezimmer.HeatingMode'
          2024-03-10 20:47:30.040  - info: web.0 (17898) ==> Connected system.user.admin from ::ffff:192.168.178.24
          2024-03-10 20:47:30.115  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_137007.setpoint' to 'linkeddevices.0.Zimmer.Ankleidezimmer.SollTemperatur'
          2024-03-10 20:47:30.358  - info: host.IOBroker64 instance system.adapter.maxcube.0 started with pid 19167
          2024-03-10 20:47:30.467  - info: web.0 (17898) <== Disconnect system.user.admin from ::ffff:192.168.178.24
          2024-03-10 20:47:30.469  - info: web.0 (17898) <== Disconnect system.user.admin from ::ffff:192.168.178.24
          2024-03-10 20:47:30.472  - info: web.0 (17898) <== Disconnect system.user.admin from ::ffff:192.168.178.24
          2024-03-10 20:47:31.045  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_137007.temp' to 'linkeddevices.0.Zimmer.Ankleidezimmer.Temperatur'
          2024-03-10 20:47:32.261  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_1c0504.mode' to 'linkeddevices.0.Zimmer.Arbeitszimmer.HeatingMode'
          2024-03-10 20:47:32.962  - info: linkeddevices.0 (17462) [createLinkedObject] linked object 'maxcube.0.devices.thermostat_1c0504.setpoint' to 'linkeddevices.0.Zimmer.Arbeitszimmer.SollTemperatur'
          iob diag has finished.
          Press any key for a summary
          Copy text starting here:
                                  v.2023-10-10
                   Icon name: computer
                Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               arm64
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          X-Server:               false
          Pending OS-Updates:     0
          Pending iob updates:    1
          Nodejs-Installation:    /usr/bin/nodejs         v18.19.1
                                  /usr/bin/npm            10.2.4
                                  /usr/bin/npx            10.2.4
          Recommended versions are nodejs 18.19.1 and npm 10.2.4
          MEMORY:
          Mem:            3.8G        2.5G        266M        0.0K        1.0G        1.2G
          Swap:            99M        3.0M         96M
          Total:          3.9G        2.5G        362M
          Active iob-Instances:   40
          ioBroker Core:          js-controller           5.0.12
                                  admin                   6.13.16
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.web.0                    : web                   : IOBroker64                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                19525
          States:                 17994
          Size of iob-Database:
          30M     /opt/iobroker/iobroker-data/objects.jsonl
          25M     /opt/iobroker/iobroker-data/states.jsonl
          === Mark text until here for copying ===
          pi@IOBroker64:~ $
          Einen schönen Abend noch.
            Bastel2001 @Bastel2001 last edited by
            Guten Abend,
            ich habe jetzt gerade nochmal mit VIS ein Projekt angelegt, nur mit einem Object. Dann die VIS-2 gestartet und jetzt öffnet diese sich. So weit so gut. Also liegt es am Projekt, leider ist das dann aber noch nicht einsatzbereit, denn die Gefahr besteht ja dann weiterhin.
            Schade eigentlich. Für mich ist der IOBroker die Nummer 1.
            Schönen Abend noch.
            bastel
              Guten Morgen
              Ich habe was mich betrift rausgefunden das ich blöderweise einen Fehler im Link hatte.
              Ich hatte das Home nich drin. Was allerdings komisch ist ist das es auf pc wo ich es erstelt hatte auch ohne ging.
              Gruss
                JEnsR last edited by
                ich habe auch das Problem der weisen Seite, bei mir ist es aber so das ich an einem Rechner anfange etwas zu machen, ich dann auf einen anderen Rechner weiter machen möchte, das es dann weis/leer ist.
                Auf dem Rechner wo es geht habe ich dann auch mal den Cache geleert, dann ging es auf dem Rechner auch nicht mehr, ich habe dann den Adapter deinstalliert und neu installiert, dann ging es wieder, allerdings nur auf dem Rechner.
                So ist das mit der vis-2 wirklich schwierig..
                Jemand eine Idee?
                  derboehsevincent last edited by
                  Hab das gleiche Problem - vis1 funktioniert problemlos - vis2 lädt kurz, dann schwarzes Bild (weil Dark Theme)
                    Woife @derboehsevincent last edited by
                    Hallo ich hatte das gleiche Problem.
                    Bei mir lag es an dem alten Projekt vom Vorgänger VIS das ich mit der Vis 2.0 Beta übernommen hatte. Dort funktionierte es noch.
                    Gelöst habe ich es so.
                    Ich habe die alte Vis über den Distanzlink gestartet und über dem Menüpunkt "Setup" den "Dateimanager" gestartet.
                    Mit dem blauen Pfeil konnte ich zurück in die Hauptebene auf "Pfad:/" springen, dort suchte ich das Projektverzeichnis "vis-2.0". In diesem löschte ich die übernommenen Projekte vom Vorgänger Vis. Danach konnte ich das Vis 2 starten.
                    PS
                    Eine nachträglicher Import des alten Projektes klappte zwar aber ich konnte das Vis 2 wieder nicht mehr starten.
                      karli_5 last edited by
                      bei mir das gleiche. Habe jetzt auch alles gelöscht und neu begonnen. Auf den PC wo ich vis-2 erstelle Funktioniert alles. Auch über die IO Broker app. Nur auch allen anderen Geräten über Browser leider nicht.
                        Homoran Global Moderator Administrators @karli_5 last edited by
                        @karli_5 sagte in vis-2 Visualisirung keine Anzeige:
                        klingt nach falsch konfiguriertem web Adapter oder Firewall
                          Homoran Global Moderator Administrators @Woife last edited by
                          @woife sagte in vis-2 Visualisirung keine Anzeige:
                          dann befindet sich in dem Vis Projekt etwas, das nicht vis-2 kompatibel ist
                          1667
